2009-01-05ocfs2: Wrap up the common use cases of ocfs2_new_path().Joel Becker
The majority of ocfs2_new_path() calls are: ocfs2_new_path(path_root_bh(otherpath), path_root_el(otherpath)); Let's call that ocfs2_new_path_from_path(). The rest do similar things from struct ocfs2_extent_tree. Let's call those ocfs2_new_path_from_et(). This will make the next change easier. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Add journal_access functions with jbd2 triggers.Joel Becker
We create wrappers for ocfs2_journal_access() that are specific to the type of metadata block. This allows us to associate jbd2 commit triggers with the block. The triggers will compute metadata ecc in a future commit. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: block read meta ecc.Joel Becker
Add block check calls to the read_block validate functions. This is the almost all of the read-side checking of metaecc. xattr buckets are not checked yet. Writes are also unchecked, and so a read-write mount will quickly fail. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Add a validation hook for quota block reads.Joel Becker
Add a currently-returns-success hook for quota block reads. We'll be adding checks to this. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Add the underlying blockcheck code.Joel Becker
This is the code that computes crc32 and ecc for ocfs2 metadata blocks. There are high-level functions that check whether the filesystem has the ecc feature, mid-level functions that work on a single block or array of buffer_heads, and the low-level ecc hamming code that can handle multiple buffers like crc32_le(). It's not hooked up to the filesystem yet. Signed-off-by: Joel Becker <joel.becker@oracle.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Add the on-disk structures for metadata checksums.Joel Becker
Define struct ocfs2_block_check, an 8-byte structure containing a 32bit crc32_le and a 16bit hamming code ecc. This will be used for metadata checksums. Add the structure to free spaces in the various metadata structures. Add the OCFS2_FEATURE_INCOMPAT_META_ECC bit. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05jbd2: Add buffer triggersJoel Becker
Filesystems often to do compute intensive operation on some metadata. If this operation is repeated many times, it can be very expensive. It would be much nicer if the operation could be performed once before a buffer goes to disk. This adds triggers to jbd2 buffer heads. Just before writing a metadata buffer to the journal, jbd2 will optionally call a commit trigger associated with the buffer. If the journal is aborted, an abort trigger will be called on any dirty buffers as they are dropped from pending transactions. ocfs2 will use this feature. Initially I tried to come up with a more generic trigger that could be used for non-buffer-related events like transaction completion. It doesn't tie nicely, because the information a buffer trigger needs (specific to a journal_head) isn't the same as what a transaction trigger needs (specific to a tranaction_t or perhaps journal_t). So I implemented a buffer set, with the understanding that journal/transaction wide triggers should be implemented separately. There is only one trigger set allowed per buffer. I can't think of any reason to attach more than one set. Contrast this with a journal or transaction in which multiple places may want to watch the entire transaction separately. The trigger sets are considered static allocation from the jbd2 perspective. ocfs2 will just have one trigger set per block type, setting the same set on every bh of the same type. Signed-off-by: Joel Becker <joel.becker@oracle.com> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: <linux-ext4@vger.kernel.org> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2/quota: Add QUOTA in mlog_attribute.Tao Ma
A new mlog mask has to be added into mlog_attribute before it can be really used in mlog. ML_QUOTA is only added in masklog.h, so add it to the array to enable it. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Pass xs->bucket into ocfs2_add_new_xattr_bucket().Joel Becker
Pass the actual target bucket for insert through to ocfs2_add_new_xattr_bucket(). Now growing a bucket has no buffer_head knowledge. ocfs2_add_new_xattr_bucket() leavs xs->bucket in the proper state for insert. However, it doesn't update the rest of the search fields in xs, so we still have to relse() and re-find. That's OK, because everything is cached. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Move buckets up into ocfs2_add_new_xattr_bucket().Joel Becker
Lift the buckets from ocfs2_add_new_xattr_cluster() up into ocfs2_add_new_xattr_bucket(). Now ocfs2_add_new_xattr_cluster() doesn't deal with buffer_heads. In fact, we no longer have to play get_bh() tricks at all. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Move buckets up into ocfs2_add_new_xattr_cluster().Joel Becker
Lift the buckets from ocfs2_adjust_xattr_cross_cluster() up into ocfs2_add_new_xattr_cluster(). Now ocfs2_adjust_xattr_cross_cluster() doesn't deal with buffer_heads. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Pass buckets into ocfs2_mv_xattr_bucket_cross_cluster().Joel Becker
Now that ocfs2_adjust_xattr_cross_cluster() has buckets, it can pass them into ocfs2_mv_xattr_bucket_cross_cluster(). It no longer has to care about buffer_heads. The manipulation of first_bh and header_bh moves up to ocfs2_adjust_xattr_cross_cluster(). Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Start using buckets in ocfs2_adjust_xattr_cross_cluster().Joel Becker
We want to be passing around buckets instead of buffer_heads. Let's get them into ocfs2_adjust_xattr_cross_cluster. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Use ocfs2_mv_xattr_buckets() in ocfs2_mv_xattr_bucket_cross_cluster().Joel Becker
Now that ocfs2_mv_xattr_buckets() can move a partial cluster's worth of buckets, ocfs2_mv_xattr_bucket_cross_cluster() can use it. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: ocfs2_mv_xattr_buckets() can handle a partial cluster now.Joel Becker
If you look at ocfs2_mv_xattr_bucket_cross_cluster(), you'll notice that two-thirds of the code is almost identical to ocfs2_mv_xattr_buckets(). The only difference is that ocfs2_mv_xattr_buckets() moves a whole cluster's worth, while ocfs2_mv_xattr_bucket_cross_cluster() moves half the cluster. We change ocfs2_mv_xattr_buckets() to allow moving partial clusters. The original caller of ocfs2_mv_xattr_buckets() still moves the whole cluster's worth - it just passes a start_bucket of 0. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Rename ocfs2_cp_xattr_cluster() to ocfs2_mv_xattr_buckets().Joel Becker
ocfs2_cp_xattr_cluster() takes the last cluster of an xattr extent, copies its buckets to the front of a new extent, and then shrinks the bucket count of the original extent. So it's really moving the data, not copying it. While we're here, the function doesn't need a buffer_head for the old extent, just the block number. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Use ocfs2_cp_xattr_bucket() in ocfs2_mv_xattr_bucket_cross_cluster().Joel Becker
The buffer copy loop of ocfs2_mv_xattr_bucket_cross_cluster() actually looks a lot like ocfs2_cp_xattr_bucket(). Let's just use that instead. We also use bucket operations to update the buckets at the start of each extent. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Explain t_is_new in ocfs2_cp_xattr_cluster().Joel Becker
I was unsure of the JOURNAL_ACCESS parameters in ocfs2_cp_xattr_cluster(). They're based on the function argument 't_is_new', but I couldn't quite figure out how t_is_new mapped to allocation. ocfs2_cp_xattr_cluster() actually overwrites the target, regardless of t_is_new. Well, I just figured it out. So I'm adding a big fat comment for those who come after me. ocfs2_divide_xattr_cluster() has the same behavior. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Dirty the entire first bucket in ocfs2_cp_xattr_cluster().Joel Becker
ocfs2_cp_xattr_cluster() takes the last bucket of a full extent and copies it over to a new extent. It then updates the headers of both extents to reflect the new state. It is passed the first bh of the first bucket in order to update that first extent's bucket count. It reads and dirties the first bh of the new extent for the same reason. However, future code wants to always dirty the entire bucket when it is changed. So it is changed to read the entire bucket it is updating for both extents. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Dirty the entire first bucket in ocfs2_extend_xattr_bucket()Joel Becker
ocfs2_extend_xattr_bucket() takes an extent of buckets and shifts some of them down to make room for a new xattr. It is passed the first bh of the first bucket, because that is where we store the number of buckets in the extent. However, future code wants to always dirty the entire bucket when it is changed. So let's pass the entire bucket into this function, skip any block reads (we have them), and add the access/dirty logic. We also can skip passing in the target bucket bh - we only need its block number. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Narrow the transaction for deleting xattrs from a bucket.Tao Ma
We move the transaction into the loop because in ocfs2_remove_extent, we will double the credits in function ocfs2_extend_rotate_transaction. So if we have a large loop number, we will soon waste much the journal space. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Dirty the entire bucket in ocfs2_bucket_value_truncate()Joel Becker
ocfs2_bucket_value_truncate() currently takes the first bh of the bucket, and magically plays around with the value bh - even though the bucket structure in the calling function already has it. In addition, future code wants to always dirty the entire bucket when it is changed. So let's pass the entire bucket into this function, skip any block reads (we have them), and add the access/dirty logic. ocfs2_xattr_update_value_size() is no longer necessary, as it only did one thing other than journal access/dirty. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2/quota: sparse fixes for quotaTao Ma
Fix 2 minor things in quota. They are both found by sparse check. 1. an endian bug in ocfs2_local_quota_add_chunk. 2. change olq_alloc_dquot to static. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: fix indendation in ocfs2_dquot_drop_slowTao Ma
2009-01-05ext4: Add default allocation routines for quota structuresJan Kara
Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ext3: Add default allocation routines for quota structuresJan Kara
2009-01-05reiserfs: Add default allocation routines for quota structuresJan Kara
2009-01-05quota: Export dquot_alloc() and dquot_destroy() functionsJan Kara
These are default functions for creating and destroying quota structures and they should be used from filesystems. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Unexport dqblk_v1.h and dqblk_v2.hJan Kara
Unexport header files dqblk_v[12].h since except for quota format ID they don't contain information userspace should be interested in. Move ID definitions to quota.h. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Fix build warnings (64-bit types vs long long)Jan Kara
fs/ocfs2/quota_local.c: In function 'olq_set_dquot': fs/ocfs2/quota_local.c:844: warning: format '%lld' expects type 'long long int', but argument 7 has type '__le64' fs/ocfs2/quota_local.c:844: warning: format '%lld' expects type 'long long int', but argument 8 has type '__le64' fs/ocfs2/quota_local.c:844: warning: format '%lld' expects type 'long long int', but argument 7 has type '__le64' fs/ocfs2/quota_local.c:844: warning: format '%lld' expects type 'long long int', but argument 8 has type '__le64' fs/ocfs2/quota_local.c:844: warning: format '%lld' expects type 'long long int', but argument 7 has type '__le64' fs/ocfs2/quota_local.c:844: warning: format '%lld' expects type 'long long int', but argument 8 has type '__le64' fs/ocfs2/quota_global.c: In function '__ocfs2_sync_dquot': fs/ocfs2/quota_global.c:457: warning: format '%lld' expects type 'long long int', but argument 8 has type 's64' fs/ocfs2/quota_global.c:457: warning: format '%lld' expects type 'long long int', but argument 10 has type 's64' fs/ocfs2/quota_global.c:457: warning: format '%lld' expects type 'long long int', but argument 8 has type 's64' fs/ocfs2/quota_global.c:457: warning: format '%lld' expects type 'long long int', but argument 10 has type 's64' fs/ocfs2/quota_global.c:457: warning: format '%lld' expects type 'long long int', but argument 8 has type 's64' fs/ocfs2/quota_global.c:457: warning: format '%lld' expects type 'long long int', but argument 10 has type 's64' Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Make ocfs2_get_quota_block() consistent with ocfs2_read_quota_block()Jan Kara
Make function return error status and not buffer pointer so that it's consistent with ocfs2_read_quota_block(). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Fix oops when extending quota filesJan Kara
We have to mark buffer as uptodate before calling ocfs2_journal_access() and ocfs2_set_buffer_uptodate() does not do this for us. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Fix ocfs2_read_quota_block() error handling.Joel Becker
ocfs2_bread() has become ocfs2_read_virt_blocks(), with a prototype to match ocfs2_read_blocks(). The quota code, converting from ocfs2_bread(), wraps the call to ocfs2_read_virt_blocks() in ocfs2_read_quota_block(). Unfortunately, the prototype of ocfs2_read_quota_block() matches the old prototype of ocfs2_bread(). The problem is that ocfs2_bread() returned the buffer head, and callers assumed that a NULL pointer was indicative of error. It wasn't. This is why ocfs2_bread() took an int*err argument as well. The new prototype of ocfs2_read_virt_blocks() avoids this error handling confusion. Let's change ocfs2_read_quota_block() to match. Signed-off-by: Joel Becker <joel.becker@oracle.com> Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Add missing initializationJan Kara
Add missing variable initialization to ocfs2_dquot_drop_slow(). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Use BH_JBDPrivateStart instead of BH_UnshadowMark Fasheh
This is safer. We no longer have to worry about tracking changes to jbd_state_bits. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05jbd2: Add BH_JBDPrivateStartMark Fasheh
Add this so that file systems using JBD2 can safely allocate unused b_state bits. In this case, we add it so that Ocfs2 can define a single bit for tracking the validation state of a buffer. Acked-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Enable quota accounting on mount, disable on umountJan Kara
Enable quota usage tracking on mount and disable it on umount. Also add support for quota on and quota off quotactls and usrquota and grpquota mount options. Add quota features among supported ones. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Implement quota recoveryJan Kara
Implement functions for recovery after a crash. Functions just read local quota file and sync info to global quota file. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Periodic quota syncingMark Fasheh
This patch creates a work queue for periodic syncing of locally cached quota information to the global quota files. We constantly queue a delayed work item, to get the periodic behavior. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Acked-by: Jan Kara <jack@suse.cz>
2009-01-05ocfs2: Add quota calls for allocation and freeing of inodes and spaceJan Kara
Add quota calls for allocation and freeing of inodes and space, also update estimates on number of needed credits for a transaction. Move out inode allocation from ocfs2_mknod_locked() because vfs_dq_init() must be called outside of a transaction. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Implementation of local and global quota file handlingJan Kara
For each quota type each node has local quota file. In this file it stores changes users have made to disk usage via this node. Once in a while this information is synced to global file (and thus with other nodes) so that limits enforcement at least aproximately works. Global quota files contain all the information about usage and limits. It's mostly handled by the generic VFS code (which implements a trie of structures inside a quota file). We only have to provide functions to convert structures from on-disk format to in-memory one. We also have to provide wrappers for various quota functions starting transactions and acquiring necessary cluster locks before the actual IO is really started. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Mark system files as not subject to quota accountingJan Kara
Mark system files as not subject to quota accounting. This prevents possible recursions into quota code and thus deadlocks. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05ocfs2: Assign feature bits and system inodes to quota feature and quota filesJan Kara
2009-01-05ocfs2: Support nested transactionsJan Kara
OCFS2 can easily support nested transactions. We just have to take care and not spoil statistics acquire semaphore unnecessarily. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Implement function for scanning active dquotsJan Kara
OCFS2 needs to scan all active dquots once in a while and sync quota information among cluster nodes. Provide a helper function for it so that it does not have to reimplement internally a list which VFS already has. Moreover this function is probably going to be useful for other clustered filesystems if they decide to use VFS quotas. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Add helpers to allow ocfs2 specific quota initialization, freeing and ↵Jan Kara
recovery OCFS2 needs to peek whether quota structure is already in memory so that it can avoid expensive cluster locking in that case. Similarly when freeing dquots, it checks whether it is the last quota structure user or not. Finally, it needs to get reference to dquot structure for specified id and quota type when recovering quota file after crash. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Update version numberJan Kara
Increase reported version number of quota support since quota core has changed significantly. Also remove __DQUOT_NUM_VERSION__ since nobody uses it. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Keep which entries were set by SETQUOTA quotactlJan Kara
Quota in a clustered environment needs to synchronize quota information among cluster nodes. This means we have to occasionally update some information in dquot from disk / network. On the other hand we have to be careful not to overwrite changes administrator did via SETQUOTA. So indicate in dquot->dq_flags which entries have been set by SETQUOTA and quota format can clear these flags when it properly propagated the changes. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Allow negative usage of space and inodesJan Kara
For clustered filesystems, it can happen that space / inode usage goes negative temporarily (because some node is allocating another node is freeing and they are not completely in sync). So let quota code allow this and change qsize_t so a signed type so that we don't underflow the variables. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2009-01-05quota: Convert union in mem_dqinfo to a pointerJan Kara
Coming quota support for OCFS2 is going to need quite a bit of additional per-sb quota information. Moreover having fs.h include all the types needed for this structure would be a pain in the a**. So remove the union from mem_dqinfo and add a private pointer for filesystem's use. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
