2008-09-01nfsd: fix compound state allocation error handlingAndy Adamson
Move the cstate_alloc call so that if it fails, the response is setup to encode the NFS error. The out label now means that the nfsd4_compound_state has not been allocated. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-08-13svcrdma: Fix race between svc_rdma_recvfrom thread and the dto_taskletTom Tucker
RDMA_READ completions are kept on a separate queue from the general I/O request queue. Since a separate lock is used to protect the RDMA_READ completion queue, a race exists between the dto_tasklet and the svc_rdma_recvfrom thread where the dto_tasklet sets the XPT_DATA bit and adds I/O to the read-completion queue. Concurrently, the recvfrom thread checks the generic queue, finds it empty and resets the XPT_DATA bit. A subsequent svc_xprt_enqueue will fail to enqueue the transport for I/O and cause the transport to "stall". The fix is to protect both lists with the same lock and set the XPT_DATA bit with this lock held. Signed-off-by: Tom Tucker <tom@opengridcomputing.com> Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu>
2008-08-12Linux 2.6.27-rc3v2.6.27-rc3Linus Torvalds
2008-08-12Merge branch 'for-2.6.27' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.27' of git://linux-nfs.org/~bfields/linux: fs/nfsd/export.c: Adjust error handling code involving auth_domain_put MAINTAINERS: mention lockd and sunrpc in nfs entries lockd: trivial sparse endian annotations
2008-08-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/ehca: Discard double CQE for one WR IB/ehca: Check idr_find() return value IB/ehca: Repoll CQ on invalid opcode IB/ehca: Rename goto label in ehca_poll_cq_one() IB/ehca: Update qp_state on cached modify_qp() IPoIB/cm: Use vmalloc() to allocate rx_rings
2008-08-12Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] use bcd2bin/bin2bcd [IA64] Ensure cpu0 can access per-cpu variables in early boot code
2008-08-12firmware/memmap: cleanupBernhard Walle
Various cleanup the drivers/firmware/memmap (after review by AKPM): - fix kdoc to conform to the standard - move kdoc from header to implementation files - remove superfluous WARN_ON() after kmalloc() - WARN_ON(x); if (!x) -> if(!WARN_ON(x)) - improve some comments Signed-off-by: Bernhard Walle <bwalle@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12ALi M7101 PMU also available on Sun Netra's tooAlexander Clouter
My Sun Netra T1 AC200 has one of these... bit harsh not letting me use it and all :) ========== alex@woodchuck:~$ lspci -nn 00:01.0 PCI bridge [0604]: Sun Microsystems Computer Corp. Simba Advanced PCI Bridge [108e:5000] (rev 13) 00:01.1 PCI bridge [0604]: Sun Microsystems Computer Corp. Simba Advanced PCI Bridge [108e:5000] (rev 13) 01:03.0 Non-VGA unclassified device [0000]: ALi Corporation M7101 Power Management Controller [PMU] [10b9:7101] 01:05.1 Ethernet controller [0200]: Sun Microsystems Computer Corp. RIO GEM [108e:1101] (rev 01) 01:05.3 USB Controller [0c03]: Sun Microsystems Computer Corp. RIO USB [108e:1103] (rev 01) 01:07.0 ISA bridge [0601]: ALi Corporation M1533/M1535 PCI to ISA Bridge [Aladdin IV/V/V+] [10b9:1533] 01:0c.0 Bridge [0680]: Sun Microsystems Computer Corp. RIO EBUS [108e:1100] (rev 01) 01:0c.1 Ethernet controller [0200]: Sun Microsystems Computer Corp. RIO GEM [108e:1101] (rev 01) 01:0c.3 USB Controller [0c03]: Sun Microsystems Computer Corp. RIO USB [108e:1103] (rev 01) 01:0d.0 IDE interface [0101]: ALi Corporation M5229 IDE [10b9:5229] (rev c3) 02:08.0 SCSI storage controller [0100]: LSI Logic / Symbios Logic 53C896/897 [1000:000b] (rev 07) 02:08.1 SCSI storage controller [0100]: LSI Logic / Symbios Logic 53C896/897 [1000:000b] (rev 07) ========== Signed-off-by: Alexander Clouter <alex@digriz.org.uk> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12Make ioctl.h compatible with userlandMichael Abbott
The attached patch seems to already exist in a number of branches -- it keeps popping up on Google for me, and is certainly already in Debian -- but is strangely absent from mainstream. The problem appears to be that the patched file ends up as part of the target toolchain, but unfortunately the gcc constant folding doesn't appear to eliminate the __invalid_size_argument_for_IOC value early enough. Certainly compiling C++ programs which use _IO... macros as constants fails without this patch. Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: fix getdelays printk formatsRandy Dunlap
Fix printf format type warnings (seen on alpha & ia64): Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 6 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 7 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 8 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 9 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 12 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 13 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 16 has type '__u64' Documentation/accounting/getdelays.c:206: warning: format '%15llu' expects type 'long long unsigned int', but argument 17 has type '__u64' Documentation/accounting/getdelays.c:214: warning: format '%15llu' expects type 'long long unsigned int', but argument 4 has type '__u64' Documentation/accounting/getdelays.c:214: warning: format '%15llu' expects type 'long long unsigned int', but argument 5 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 2 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 3 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 4 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 5 has type '__u64' Documentation/accounting/getdelays.c:221: warning: format '%llu' expects type 'long long unsigned int', but argument 6 has type '__u64' Documentation/accounting/getdelays.c:236: warning: 'cmd_type' may be used uninitialized in this function Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Balbir Singh <balbir@in.ibm.com> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: fix crc32hash typeRandy Dunlap
Fix differing signedness warning: Documentation/pcmcia/crc32hash.c:29: warning: pointer targets in passing argument 1 of 'crc32' differ in signedness Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Dominik Brodowski <linux@dominikbrodowski.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: fix ifenslave typeRandy Dunlap
Documentation/networking/ifenslave.c:1084: warning: pointer targets in assignment differ in signedness >From include/linux/socket.h: * 1003.1g requires sa_family_t and that sa_data is char. and from SUSv3: (http://www.opengroup.org/onlinepubs/009695399/basedefs/sys/socket.h.html) The <sys/socket.h> header shall define the sockaddr structure that includes at least the following members: sa_family_t sa_family Address family. char sa_data[] Socket address (variable-length data). <end SUSv3> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: fix procfs exampleRandy Dunlap
Add MODULE_LICENSE() to DocBook/procfs_example.c since modpost complained about a missing license there. Remove tty procfs removal since the creation was deleted long ago (http://git.kernel.org/?p=linux/kernel/git/tglx/history.git;a=commitdiff;h=5ad9cb65e9b15e5b83e2dd1c10a4bcaccc4ec644). Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <J.A.K.Mouw@its.tudelft.nl> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: build Documentation/ sourcesRandy Dunlap
Currently source files in the Documentation/ sub-dir can easily bit-rot since they are not generally buildable, either because they are hidden in text files or because there are no Makefile rules for them. This needs to be fixed so that the source files remain usable and good examples of code instead of bad examples. Add the ability to build source files that are in the Documentation/ dir. Add to Kconfig as "BUILD_DOCSRC" config symbol. Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the Documentation/ sources. Or enable BUILD_DOCSRC in the *config system. However, this symbol depends on HEADERS_CHECK since the header files need to be installed (for userspace builds). Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32, sparc64, powerpc, sh, m68k, & mips. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12byteorder: add include/linux/byteorder.h to define endian helpersHarvey Harrison
Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12byteorder: add a new include/linux/swab.h to define byteswapping functionsHarvey Harrison
Collect the implementations from include/linux/byteorder/swab.h, swabb.h in swab.h The functionality provided covers: u16 swab16(u16 val) - return a byteswapped 16 bit value u32 swab32(u32 val) - return a byteswapped 32 bit value u64 swab64(u64 val) - return a byteswapped 64 bit value u32 swahw32(u32 val) - return a wordswapped 32 bit value u32 swahb32(u32 val) - return a high/low byteswapped 32 bit value Similar to above, but return swapped value from a naturally-aligned pointer u16 swab16p(u16 *p) u32 swab32p(u32 *p) u64 swab64p(u64 *p) u32 swahw32p(u32 *p) u32 swahb32p(u32 *p) Similar to above, but swap the value in-place (in-situ) void swab16s(u16 *p) void swab32s(u32 *p) void swab64s(u64 *p) void swahw32s(u32 *p) void swahb32s(u32 *p) Arches can override any of these with an optimized version by defining an inline in their asm/byteorder.h (example given for swab16()): u16 __arch_swab16() {} #define __arch_swab16 __arch_swab16 Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12genirq: switch /proc/irq/*/smp_affinity et al to seqfilesAlexey Dobriyan
Switch /proc/irq/*/smp_affinity , /proc/irq/default_smp_affinity to seq_files. cat(1) reads with 1024 chunks by default, with high enough NR_CPUS, there will be -EINVAL. As side effect, there are now two less users of the ->read_proc interface. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Paul Jackson <pj@sgi.com> Cc: Mike Travis <travis@sgi.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12seq_file: add seq_cpumask(), seq_nodemask()Alexey Dobriyan
Short enough reads from /proc/irq/*/smp_affinity return -EINVAL for no good reason. This became noticed with NR_CPUS=4096 patches, when length of printed representation of cpumask becase 1152, but cat(1) continued to read with 1024-byte chunks. bitmap_scnprintf() in good faith fills buffer, returns 1023, check returns -EINVAL. Fix it by switching to seq_file, so handler will just fill buffer and doesn't care about offsets, length, filling EOF and all this crap. For that add seq_bitmap(), and wrappers around it -- seq_cpumask() and seq_nodemask(). Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Reviewed-by: Paul Jackson <pj@sgi.com> Cc: Mike Travis <travis@sgi.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12reiserfs: removed duplicated #includeHuang Weiyi
Removed duplicated #include <linux/quotaops.h> in fs/reiserfs/super.c. Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12fs/eventpoll.c: fix sys_epoll_create1() commentAndrew Morton
The `size' argument was removed. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Ulrich Drepper <drepper@redhat.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12drivers/char/rtc.c: removed duplicated includeHuang Weiyi
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12mm/sparse.c: removed duplicated includeHuang Weiyi
2008-08-12move kernel-doc comment for might_sleep directly before its defining blockUwe Kleine-König
Signed-off-by: Uwe Kleine-König <Uwe.Kleine-Koenig@digi.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12lib/vsprintf.c: wrong conversion function usedYi Yang
Fix wrong conversion function used by strict_strtou* Signed-off-by: Yi Yang <yi.y.yang@intel.com> Reported-by: Swen Schillig <swen@vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12fbcon: prevent cursor disappearance after switching to 512 character fontKrzysztof Helt
Adjust and honor the vc_scrl_erase_char for 256 and 512 character fonts. It fixes the issue with disappearing cursor during scrolling (http://bugzilla.kernel.org/show_bug.cgi?id=11258). The issue was reported and tracked by Peter Hanzel. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Reported-by: Peter Hanzel <hanzelpeter@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12atmel_lcdfb: add board parameter specify framebuffer memory sizeHaavard Skinnemoen
Specify how much physically continuous, DMA capable memory will be allocated at driver initialization time. This allow to create framebuffer device with larger virtual resolution. Combine with y-panning this can be used to implement double buffering acceleration method. Signed-off-by: Stanislaw Gruszka <stf_xl@wp.pl> Acked-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12atmel_lcdfb: set ypanstep to 1 and enable y-panning on AT91Haavard Skinnemoen
Panning in the y-direction can be done by simply changing the DMA base address. This code is already in place, but FBIOPAN_DISPLAY will currently fail because ypanstep is 0. Set ypanstep to 1 to indicate that we do support y-panning and also set the necessary acceleration flags on AT91 (AVR32 already have them.) Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12matrox maven: convert to a new-style i2c driverJean Delvare
The legacy i2c model is going away soon, so switch to the new model. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12matroxfb: i2c structure templates clean-upJean Delvare
Clean up the use of structure templates in i2c-matroxfb. In this case it's more efficient to initialize the few fields we need individually. This makes i2c-matroxfb.ko 16% smaller on my system. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12matrox maven: fix a broken error pathJean Delvare
I broke an error path with d03c21ec0be7787ff6b75dcf56c0e96209ccbfbd, sorry about that. The machine will crash if the i2c_attach_client() or maven_init_client() calls fail, although nobody has yet reported this happening. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Petr Vandrovec <VANDROVE@vc.cvut.cz> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12do_migrate_pages(): remove unused variableMinChan Kim
Signed-off-by: MinChan Kim <minchan.kim@gmail.com> Acked-by: Christoph Lameter <cl@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12GRU: fix preprocessor symbol for sparseRandy Dunlap
Fix preprocessor symbol so that sparse sees it and does not generate errors: drivers/misc/sgi-gru/grutables.h:286:2: error: "Unsupported architecture" drivers/misc/sgi-gru/grutables.h:286:2: error: "Unsupported architecture" drivers/misc/sgi-gru/grutables.h:286:2: error: "Unsupported architecture" drivers/misc/sgi-gru/grutables.h:286:2: error: "Unsupported architecture" drivers/misc/sgi-gru/grutlbpurge.c:185:11: error: undefined identifier 'GRUREGION' drivers/misc/sgi-gru/grutables.h:286:2: error: "Unsupported architecture" drivers/misc/sgi-gru/grutables.h:286:2: error: "Unsupported architecture" Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jack Steiner <steiner@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12radeonfb: fix accel engine hangsDavid Miller
Some chips appear to have the 2D engine hang during screen redraw, typically in a sequence of copyarea operations. This appear to be solved by adding a flush of the engine destination pixel cache and waiting for the engine to be idle before issuing the accel operation. The performance impact seems to be fairly small. Here is a trace on an RV370 (PCI device ID 0x5b64), it records the RBBM_STATUS register, then the source x/y, destination x/y, and width/height used for the copy: ---------------------------------------- radeonfb_prim_copyarea: STATUS[00000140] src[210:70] dst[210:60] wh[a0:10] radeonfb_prim_copyarea: STATUS[00000140] src[2b8:70] dst[2b8:60] wh[88:10] radeonfb_prim_copyarea: STATUS[00000140] src[348:70] dst[348:60] wh[40:10] radeonfb_prim_copyarea: STATUS[80020140] src[390:70] dst[390:60] wh[88:10] radeonfb_prim_copyarea: STATUS[8002613f] src[40:80] dst[40:70] wh[28:10] radeonfb_prim_copyarea: STATUS[80026139] src[a8:80] dst[a8:70] wh[38:10] radeonfb_prim_copyarea: STATUS[80026133] src[e8:80] dst[e8:70] wh[80:10] radeonfb_prim_copyarea: STATUS[8002612d] src[170:80] dst[170:70] wh[30:10] radeonfb_prim_copyarea: STATUS[80026127] src[1a8:80] dst[1a8:70] wh[8:10] radeonfb_prim_copyarea: STATUS[80026121] src[1b8:80] dst[1b8:70] wh[88:10] radeonfb_prim_copyarea: STATUS[8002611b] src[248:80] dst[248:70] wh[68:10] ---------------------------------------- When things are going fine the copies complete before the next ROP is even issued, but all of a sudden the 2D unit becomes active (bit 17 in RBBM_STATUS) and the FIFO retry (bit 13) and FIFO pipeline busy (bit 14) are set as well. The FIFO begins to backup until it becomes full. What happens next is the radeon_fifo_wait() times out, and we access the chip illegally leading to a bus error which usually wedges the box. None of this makes it to the console screen, of course :-) radeon_fifo_wait() should be modified to reset the accelerator when this timeout happens instead of programming the chip anyways. ---------------------------------------- radeonfb: FIFO Timeout ! ERROR(0): Cheetah error trap taken afsr[0010080005000000] afar[000007f900800e40] TL1(0) ERROR(0): TPC[595114] TNPC[595118] O7[459788] TSTATE[11009601] ERROR(0): TPC<radeonfb_copyarea+0xfc/0x248> ERROR(0): M_SYND(0), E_SYND(0), Privileged ERROR(0): Highest priority error (0000080000000000) "Bus error response from system bus" ERROR(0): D-cache idx[0] tag[0000000000000000] utag[0000000000000000] stag[0000000000000000] ERROR(0): D-cache data0[0000000000000000] data1[0000000000000000] data2[0000000000000000] data3[0000000000000000] ERROR(0): I-cache idx[0] tag[0000000000000000] utag[0000000000000000] stag[0000000000000000] u[0000000000000000] l[00\ ERROR(0): I-cache INSN0[0000000000000000] INSN1[0000000000000000] INSN2[0000000000000000] INSN3[0000000000000000] ERROR(0): I-cache INSN4[0000000000000000] INSN5[0000000000000000] INSN6[0000000000000000] INSN7[0000000000000000] ERROR(0): E-cache idx[800e40] tag[000000000e049f4c] ERROR(0): E-cache data0[fffff8127d300180] data1[00000000004b5384] data2[0000000000000000] data3[0000000000000000] Ker:xnel panic - not syncing: Irrecoverable deferred error trap. ---------------------------------------- Another quirk is that these copyarea calls will not happen until the first drivers/char/vt.c:redraw_screen() occurs. This will only happen if you 1) VC switch or 2) run "consolechars" or 3) unblank the screen. This seems to happen because until a redraw_screen() the screen scrolling method used by fbcon is not finalized yet. I've seen this with other fb drivers too. So if all you do is boot straight into X you will never see this bug on the relevant chips. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12allocate structures for reservation tracking in hugetlbfs outside of ↵Andy Whitcroft
spinlocks v2 [Andrew this should replace the previous version which did not check the returns from the region prepare for errors. This has been tested by us and Gerald and it looks good. Bah, while reviewing the locking based on your previous email I spotted that we need to check the return from the vma_needs_reservation call for allocation errors. Here is an updated patch to correct this. This passes testing here.] Signed-off-by: Andy Whitcroft <apw@shadowen.org> Tested-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12hugetlbfs: allocate structures for reservation tracking outside of spinlocksAndy Whitcroft
In the normal case, hugetlbfs reserves hugepages at map time so that the pages exist for future faults. A struct file_region is used to track when reservations have been consumed and where. These file_regions are allocated as necessary with kmalloc() which can sleep with the mm->page_table_lock held. This is wrong and triggers may-sleep warning when PREEMPT is enabled. Updates to the underlying file_region are done in two phases. The first phase prepares the region for the change, allocating any necessary memory, without actually making the change. The second phase actually commits the change. This patch makes use of this by checking the reservations before the page_table_lock is taken; triggering any necessary allocations. This may then be safely repeated within the locks without any allocations being required. Credit to Mel Gorman for diagnosing this failure and initial versions of the patch. Signed-off-by: Andy Whitcroft <apw@shadowen.org> Tested-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Cc: Mel Gorman <mel@csn.ul.ie> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12isight_firmware: fix a leak and double kfree()Parag Warudkar
Signed-off-by: Parag Warudkar <parag.warudkar@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12cpuidle: make sysfs attributes sysdev class attributesRabin Vincent
These attributes are really sysdev class attributes. The incorrect definition leads to an oops because of recent changes which make sysdev attributes use a different prototype. Based on Andi's f718cd4add5aea9d379faff92f162571e356cc5f ("sched: make scheduler sysfs attributes sysdev class devices") Reported-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Rabin Vincent <rabin@rab.in> Acked-by: Andi Kleen <ak@linux.intel.com> Cc: "Li, Shaohua" <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12rtc-isl1208: fix double removal of a sysfs entryAlessandro Zummo
Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Herbert Valerio Riedel <hvr@gnu.org> Cc: Hartley Sweeten <hartleys@visionengravers.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12h8300: fix section mismatchesYoshinori Sato
WARNING: vmlinux.o(.text+0x2fdf): Section mismatch in reference from the variable .LM3 to the variable .init.text:___alloc_bootmem The function .LM3() references the variable __init ___alloc_bootmem. This is often because .LM3 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x2ff5): Section mismatch in reference from the variable .LM4 to the variable .init.text:___alloc_bootmem The function .LM4() references the variable __init ___alloc_bootmem. This is often because .LM4 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x300b): Section mismatch in reference from the variable .LM5 to the variable .init.text:___alloc_bootmem The function .LM5() references the variable __init ___alloc_bootmem. This is often because .LM5 lacks a __init annotation or the annotation of ___alloc_bootmem is wrong. WARNING: vmlinux.o(.text+0x304b): Section mismatch in reference from the variable .LM10 to the variable .init.text:_free_area_init The function .LM10() references the variable __init _free_area_init. This is often because .LM10 lacks a __init annotation or the annotation of _free_area_init is wrong. WARNING: vmlinux.o(.text+0x30a3): Section mismatch in reference from the variable .LM17 to the variable .init.text:_free_all_bootmem The function .LM17() references the variable __init _free_all_bootmem. This is often because .LM17 lacks a __init annotation or the annotation of _free_all_bootmem is wrong. Signed-off-by: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12revert "rtc: cdev lock_kernel() pushdown"David Brownell
Revert commit 51a776fa7a7997e726d4a478eda0854c6f9143bd ("rtc: cdev lock_kernel() pushdown"). The RTC framework does not need BKL protection. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Alessandro Zummo <alessandro.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12memcg: fix oops in mem_cgroup_shrink_usageHugh Dickins
Got an oops in mem_cgroup_shrink_usage() when testing loop over tmpfs: yes, of course, loop0 has no mm: other entry points check but this didn't. Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Acked-by: Balbir Singh <balbir@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12cpu hotplug: s390 doesn't support additional_cpus anymore.Heiko Carstens
s390 doesn't support the additional_cpus kernel parameter anymore since a long time. So we better update the code and documentation to reflect that. Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12page allocator: use no-panic variant of alloc_bootmem() in ↵Jan Beulich
alloc_large_system_hash() .. since a failed allocation is being (initially) handled gracefully, and panic()-ed upon failure explicitly in the function if retries with smaller sizes failed. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12quota: documentation for sending "below quota" messages via netlink and tiny ↵Jan Kara
doc update Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12hugetlb: call arch_prepare_hugepage() for surplus pagesGerald Schaefer
The s390 software large page emulation implements shared page tables by using page->index of the first tail page from a compound large page to store page table information. This is set up in arch_prepare_hugepage(), which is called from alloc_fresh_huge_page_node(). A similar call to arch_prepare_hugepage() is missing for surplus large pages that are allocated in alloc_buddy_huge_page(), which breaks the software emulation mode for (surplus) large pages on s390. This patch adds the missing call to arch_prepare_hugepage(). It will have no effect on other architectures where arch_prepare_hugepage() is a nop. Also, use the correct order in the error path in alloc_fresh_huge_page_node(). Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Gerald Schaefer <gerald.schaefer@de.ibm.com> Acked-by: Nick Piggin <npiggin@suse.de> Acked-by: Adam Litke <agl@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12feature-removal-schedule.txt: remove the NCR53C9x entryAdrian Bunk
Now that the driver is removed we should also remove the entry in Documentation/feature-removal-schedule.txt Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Christoph Hellwig <hch@lst.de> Cc: James Bottomley <James.Bottomley@HansenPartnership.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12Merge branches 'ehca' and 'ipoib' into for-linusRoland Dreier
2008-08-12[IA64] use bcd2bin/bin2bcdAdrian Bunk
This patch changes ia64 to use the new bcd2bin/bin2bcd functions instead of the obsolete BCD2BIN/BIN2BCD macros. Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2008-08-12IB/ehca: Discard double CQE for one WRAlexander Schmidt
Under rare circumstances, the ehca hardware might erroneously generate two CQEs for the same WQE, which is not compliant to the IB spec and will cause unpredictable errors like memory being freed twice. To avoid this problem, the driver needs to detect the second CQE and discard it. For this purpose, introduce an array holding as many elements as the SQ of the QP, called sq_map. Each sq_map entry stores a "reported" flag for one WQE in the SQ. When a work request is posted to the SQ, the respective "reported" flag is set to zero. After the arrival of a CQE, the flag is set to 1, which allows to detect the occurence of a second CQE. The mapping between WQE / CQE and the corresponding sq_map element is implemented by replacing the lowest 16 Bits of the wr_id with the index in the queue map. The original 16 Bits are stored in the sq_map entry and are restored when the CQE is passed to the application. Signed-off-by: Alexander Schmidt <alexs@linux.vnet.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
2008-08-12IB/ehca: Check idr_find() return valueAlexander Schmidt
The idr_find() function may fail when trying to get the QP that is associated with a CQE, e.g. when a QP has been destroyed between the generation of a CQE and the poll request for it. In consequence, the return value of idr_find() must be checked and the CQE must be discarded when the QP cannot be found. Signed-off-by: Alexander Schmidt <alexs@linux.vnet.ibm.com> Signed-off-by: Roland Dreier <rolandd@cisco.com>
