2017-10-27Linux 4.4.95v4.4.95Greg Kroah-Hartman
2017-10-27FS-Cache: fix dereference of NULL user_key_payloadEric Biggers
commit d124b2c53c7bee6569d2a2d0b18b4a1afde00134 upstream. When the file /proc/fs/fscache/objects (available with CONFIG_FSCACHE_OBJECT_LIST=y) is opened, we request a user key with description "fscache:objlist", then access its payload. However, a revoked key has a NULL payload, and we failed to check for this. request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we access its payload. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. Fixes: 4fbf4291aa15 ("FS-Cache: Allow the current state of all objects to be dumped") Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27fscrypto: require write access to mount to set encryption policyEric Biggers
commit ba63f23d69a3a10e7e527a02702023da68ef8a6d upstream. [Please apply to 4.4-stable. Note: this was already backported, but only to ext4; it was missed that it should go to f2fs as well. This is needed to make xfstest generic/395 pass on f2fs.] Since setting an encryption policy requires writing metadata to the filesystem, it should be guarded by mnt_want_write/mnt_drop_write. Otherwise, a user could cause a write to a frozen or readonly filesystem. This was handled correctly by f2fs but not by ext4. Make fscrypt_process_policy() handle it rather than relying on the filesystem to get it right. Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Theodore Ts'o <tytso@mit.edu> Acked-by: Jaegeuk Kim <jaegeuk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: Fix race between updating and finding a negative keyDavid Howells
commit 363b02dab09b3226f3bd1420dad9c72b79a42a76 upstream. Consolidate KEY_FLAG_INSTANTIATED, KEY_FLAG_NEGATIVE and the rejection error into one field such that: (1) The instantiation state can be modified/read atomically. (2) The error can be accessed atomically with the state. (3) The error isn't stored unioned with the payload pointers. This deals with the problem that the state is spread over three different objects (two bits and a separate variable) and reading or updating them atomically isn't practical, given that not only can uninstantiated keys change into instantiated or rejected keys, but rejected keys can also turn into instantiated keys - and someone accessing the key might not be using any locking. The main side effect of this problem is that what was held in the payload may change, depending on the state. For instance, you might observe the key to be in the rejected state. You then read the cached error, but if the key semaphore wasn't locked, the key might've become instantiated between the two reads - and you might now have something in hand that isn't actually an error code. The state is now KEY_IS_UNINSTANTIATED, KEY_IS_POSITIVE or a negative error code if the key is negatively instantiated. The key_is_instantiated() function is replaced with key_is_positive() to avoid confusion as negative keys are also 'instantiated'. Additionally, barriering is included: (1) Order payload-set before state-set during instantiation. (2) Order state-read before payload-read when using the key. Further separate barriering is necessary if RCU is being used to access the payload content after reading the payload pointers. Fixes: 146aa8b1453b ("KEYS: Merge the type-specific data with the payload data") Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27fscrypt: fix dereference of NULL user_key_payloadEric Biggers
commit d60b5b7854c3d135b869f74fb93eaf63cbb1991a upstream. When an fscrypt-encrypted file is opened, we request the file's master key from the keyrings service as a logon key, then access its payload. However, a revoked key has a NULL payload, and we failed to check for this. request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. Fixes: 88bd6ccdcdd6 ("ext4 crypto: add encryption key management facilities") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: <stable@vger.kernel.org> [v4.1+] Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27f2fs crypto: add missing locking for keyring_key accessJaegeuk Kim
commit 745e8490b1e960ad79859dd8ba6a0b5a8d3d994e upstream. This patch adopts: ext4 crypto: add missing locking for keyring_key access Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27f2fs crypto: replace some BUG_ON()'s with error checksJaegeuk Kim
commit 66aa3e1274fcf887e9d6501a68163270fc7718e7 upstream. This patch adopts: ext4 crypto: replace some BUG_ON()'s with error checks Signed-off-by: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Jaegeuk Kim <jaegeuk@kernel.org> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27sched/autogroup: Fix autogroup_move_group() to never skip sched_move_task()Oleg Nesterov
commit 18f649ef344127ef6de23a5a4272dbe2fdb73dde upstream. The PF_EXITING check in task_wants_autogroup() is no longer needed. Remove it, but see the next patch. However the comment is correct in that autogroup_move_group() must always change task_group() for every thread so the sysctl_ check is very wrong; we can race with cgroups and even sys_setsid() is not safe because a task running with task_group() == ag->tg must participate in refcounting: int main(void) { int sctl = open("/proc/sys/kernel/sched_autogroup_enabled", O_WRONLY); assert(sctl > 0); if (fork()) { wait(NULL); // destroy the child's ag/tg pause(); } assert(pwrite(sctl, "1\n", 2, 0) == 2); assert(setsid() > 0); if (fork()) pause(); kill(getppid(), SIGKILL); sleep(1); // The child has gone, the grandchild runs with kref == 1 assert(pwrite(sctl, "0\n", 2, 0) == 2); assert(setsid() > 0); // runs with the freed ag/tg for (;;) sleep(1); return 0; } crashes the kernel. It doesn't really need sleep(1), it doesn't matter if autogroup_move_group() actually frees the task_group or this happens later. Reported-by: Vern Lovejoy <vlovejoy@redhat.com> Signed-off-by: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: hartsjc@redhat.com Cc: vbendel@redhat.com Link: http://lkml.kernel.org/r/20161114184609.GA15965@redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org> [sumits: submit to 4.4 LTS, post testing on Hikey] Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27parisc: Fix double-word compare and exchange in LWS code on 32-bit kernelsJohn David Anglin
commit 374b3bf8e8b519f61eb9775888074c6e46b3bf0c upstream. As discussed on the debian-hppa list, double-wordcompare and exchange operations fail on 32-bit kernels. Looking at the code, I realized that the ",ma" completer does the wrong thing in the "ldw,ma 4(%r26), %r29" instruction. This increments %r26 and causes the following store to write to the wrong location. Note by Helge Deller: The patch applies cleanly to stable kernel series if this upstream commit is merged in advance: f4125cfdb300 ("parisc: Avoid trashing sr2 and sr3 in LWS code"). Signed-off-by: John David Anglin <dave.anglin@bell.net> Tested-by: Christoph Biedl <debian.axhn@manchmal.in-ulm.de> Fixes: 89206491201c ("parisc: Implement new LWS CAS supporting 64 bit operations.") Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27parisc: Avoid trashing sr2 and sr3 in LWS codeJohn David Anglin
commit f4125cfdb3008363137f744c101e5d76ead760ba upstream. There is no need to trash sr2 and sr3 in the Light-weight syscall (LWS). sr2 already points to kernel space (it's zero in userspace, otherwise syscalls wouldn't work), and since the LWS code is executed in userspace, we can simply ignore to preload sr3. Signed-off-by: John David Anglin <dave.anglin@bell.net> Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27pkcs7: Prevent NULL pointer dereference, since sinfo is not always set.Eric Sesterhenn
commit 68a1fdbbf8bd3378325e45c19e167a165f9ffc3a upstream. The ASN.1 parser does not necessarily set the sinfo field, this patch prevents a NULL pointer dereference on broken input. Fixes: 99db44350672 ("PKCS#7: Appropriately restrict authenticated attributes and content type") Signed-off-by: Eric Sesterhenn <eric.sesterhenn@x41-dsec.de> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: don't let add_key() update an uninstantiated keyDavid Howells
commit 60ff5b2f547af3828aebafd54daded44cfb0807a upstream. Currently, when passed a key that already exists, add_key() will call the key's ->update() method if such exists. But this is heavily broken in the case where the key is uninstantiated because it doesn't call __key_instantiate_and_link(). Consequently, it doesn't do most of the things that are supposed to happen when the key is instantiated, such as setting the instantiation state, clearing KEY_FLAG_USER_CONSTRUCT and awakening tasks waiting on it, and incrementing key->user->nikeys. It also never takes key_construction_mutex, which means that ->instantiate() can run concurrently with ->update() on the same key. In the case of the "user" and "logon" key types this causes a memory leak, at best. Maybe even worse, the ->update() methods of the "encrypted" and "trusted" key types actually just dereference a NULL pointer when passed an uninstantiated key. Change key_create_or_update() to wait interruptibly for the key to finish construction before continuing. This patch only affects *uninstantiated* keys. For now we still allow a negatively instantiated key to be updated (thereby positively instantiating it), although that's broken too (the next patch fixes it) and I'm not sure that anyone actually uses that functionality either. Here is a simple reproducer for the bug using the "encrypted" key type (requires CONFIG_ENCRYPTED_KEYS=y), though as noted above the bug pertained to more than just the "encrypted" key type: #include <stdlib.h> #include <unistd.h> #include <keyutils.h> int main(void) { int ringid = keyctl_join_session_keyring(NULL); if (fork()) { for (;;) { const char payload[] = "update user:foo 32"; usleep(rand() % 10000); add_key("encrypted", "desc", payload, sizeof(payload), ringid); keyctl_clear(ringid); } } else { for (;;) request_key("encrypted", "desc", "callout_info", ringid); } } It causes: BUG: unable to handle kernel NULL pointer dereference at 0000000000000018 IP: encrypted_update+0xb0/0x170 PGD 7a178067 P4D 7a178067 PUD 77269067 PMD 0 PREEMPT SMP CPU: 0 PID: 340 Comm: reproduce Tainted: G D 4.14.0-rc1-00025-g428490e38b2e #796 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS Bochs 01/01/2011 task: ffff8a467a39a340 task.stack: ffffb15c40770000 RIP: 0010:encrypted_update+0xb0/0x170 RSP: 0018:ffffb15c40773de8 EFLAGS: 00010246 RAX: 0000000000000000 RBX: ffff8a467a275b00 RCX: 0000000000000000 RDX: 0000000000000005 RSI: ffff8a467a275b14 RDI: ffffffffb742f303 RBP: ffffb15c40773e20 R08: 0000000000000000 R09: ffff8a467a275b17 R10: 0000000000000020 R11: 0000000000000000 R12: 0000000000000000 R13: 0000000000000000 R14: ffff8a4677057180 R15: ffff8a467a275b0f FS: 00007f5d7fb08700(0000) GS:ffff8a467f200000(0000) knlGS:0000000000000000 CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033 CR2: 0000000000000018 CR3: 0000000077262005 CR4: 00000000001606f0 Call Trace: key_create_or_update+0x2bc/0x460 SyS_add_key+0x10c/0x1d0 entry_SYSCALL_64_fastpath+0x1f/0xbe RIP: 0033:0x7f5d7f211259 RSP: 002b:00007ffed03904c8 EFLAGS: 00000246 ORIG_RAX: 00000000000000f8 RAX: ffffffffffffffda RBX: 000000003b2a7955 RCX: 00007f5d7f211259 RDX: 00000000004009e4 RSI: 00000000004009ff RDI: 0000000000400a04 RBP: 0000000068db8bad R08: 000000003b2a7955 R09: 0000000000000004 R10: 000000000000001a R11: 0000000000000246 R12: 0000000000400868 R13: 00007ffed03905d0 R14: 0000000000000000 R15: 0000000000000000 Code: 77 28 e8 64 34 1f 00 45 31 c0 31 c9 48 8d 55 c8 48 89 df 48 8d 75 d0 e8 ff f9 ff ff 85 c0 41 89 c4 0f 88 84 00 00 00 4c 8b 7d c8 <49> 8b 75 18 4c 89 ff e8 24 f8 ff ff 85 c0 41 89 c4 78 6d 49 8b RIP: encrypted_update+0xb0/0x170 RSP: ffffb15c40773de8 CR2: 0000000000000018 Reported-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> cc: Eric Biggers <ebiggers@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27lib/digsig: fix dereference of NULL user_key_payloadEric Biggers
commit 192cabd6a296cbc57b3d8c05c4c89d87fc102506 upstream. digsig_verify() requests a user key, then accesses its payload. However, a revoked key has a NULL payload, and we failed to check for this. request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. Fixes: 051dbb918c7f ("crypto: digital signature verification support") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: Dmitry Kasatkin <dmitry.kasatkin@intel.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27KEYS: encrypted: fix dereference of NULL user_key_payloadEric Biggers
commit 13923d0865ca96312197962522e88bc0aedccd74 upstream. A key of type "encrypted" references a "master key" which is used to encrypt and decrypt the encrypted key's payload. However, when we accessed the master key's payload, we failed to handle the case where the master key has been revoked, which sets the payload pointer to NULL. Note that request_key() *does* skip revoked keys, but there is still a window where the key can be revoked before we acquire its semaphore. Fix it by checking for a NULL payload, treating it like a key which was already revoked at the time it was requested. This was an issue for master keys of type "user" only. Master keys can also be of type "trusted", but those cannot be revoked. Fixes: 7e70cb497850 ("keys: add new key-type encrypted") Reviewed-by: James Morris <james.l.morris@oracle.com> Cc: Mimi Zohar <zohar@linux.vnet.ibm.com> Cc: David Safford <safford@us.ibm.com> Signed-off-by: Eric Biggers <ebiggers@google.com> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27rtlwifi: rtl8821ae: Fix connection lost problemLarry Finger
commit b8b8b16352cd90c6083033fd4487f04fae935c18 upstream. In commit 40b368af4b75 ("rtlwifi: Fix alignment issues"), the read of REG_DBI_READ was changed from 16 to 8 bits. For unknown reasonsi this change results in reduced stability for the wireless connection. This regression was located using bisection. Fixes: 40b368af4b75 ("rtlwifi: Fix alignment issues") Reported-and-tested-by: James Cameron <quozl@laptop.org> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Cc: Ping-Ke Shih <pkshih@realtek.com> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27clockevents/drivers/cs5535: Improve resilience to spurious interruptsDavid Kozub
commit eb39a7c0355393c5a8d930f342ad7a6231b552c4 upstream. The interrupt handler mfgpt_tick() is not robust versus spurious interrupts which happen before the clock event device is registered and fully initialized. The reason is that the safe guard against spurious interrupts solely checks for the clockevents shutdown state, but lacks a check for detached state. If the interrupt hits while the device is in detached state it passes the safe guard and dereferences the event handler call back which is NULL. Add the missing state check. Fixes: 8f9327cbb6e8 ("clockevents/drivers/cs5535: Migrate to new 'set-state' interface") Suggested-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: David Kozub <zub@linux.fjfi.cvut.cz> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Link: https://lkml.kernel.org/r/20171020093103.3317F6004D@linux.fjfi.cvut.cz Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27bus: mbus: fix window size calculation for 4GB windowsJan Luebbe
commit 2bbbd96357ce76cc45ec722c00f654aa7b189112 upstream. At least the Armada XP SoC supports 4GB on a single DRAM window. Because the size register values contain the actual size - 1, the MSB is set in that case. For example, the SDRAM window's control register's value is 0xffffffe1 for 4GB (bits 31 to 24 contain the size). The MBUS driver reads back each window's size from registers and calculates the actual size as (control_reg | ~DDR_SIZE_MASK) + 1, which overflows for 32 bit values, resulting in other miscalculations further on (a bad RAM window for the CESA crypto engine calculated by mvebu_mbus_setup_cpu_target_nooverlap() in my case). This patch changes the type in 'struct mbus_dram_window' from u32 to u64, which allows us to keep using the same register calculation code in most MBUS-using drivers (which calculate ->size - 1 again). Fixes: fddddb52a6c4 ("bus: introduce an Marvell EBU MBus driver") Signed-off-by: Jan Luebbe <jlu@pengutronix.de> Signed-off-by: Gregory CLEMENT <gregory.clement@free-electrons.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27brcmsmac: make some local variables 'static const' to reduce stack sizeArnd Bergmann
commit c503dd38f850be28867ef7a42d9abe5ade81a9bd upstream. With KASAN and a couple of other patches applied, this driver is one of the few remaining ones that actually use more than 2048 bytes of kernel stack: broadcom/brcm80211/brcmsmac/phy/phy_n.c: In function 'wlc_phy_workarounds_nphy_gainctrl': broadcom/brcm80211/brcmsmac/phy/phy_n.c:16065:1: warning: the frame size of 3264 bytes is larger than 2048 bytes [-Wframe-larger-than=] broadcom/brcm80211/brcmsmac/phy/phy_n.c: In function 'wlc_phy_workarounds_nphy': broadcom/brcm80211/brcmsmac/phy/phy_n.c:17138:1: warning: the frame size of 2864 bytes is larger than 2048 bytes [-Wframe-larger-than=] Here, I'm reducing the stack size by marking as many local variables as 'static const' as I can without changing the actual code. This is the first of three patches to improve the stack usage in this driver. It would be good to have this backported to stabl kernels to get all drivers in 'allmodconfig' below the 2048 byte limit so we can turn on the frame warning again globally, but I realize that the patch is larger than the normal limit for stable backports. The other two patches do not need to be backported. Acked-by: Arend van Spriel <arend.vanspriel@broadcom.com> Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Kalle Valo <kvalo@codeaurora.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27i2c: ismt: Separate I2C block read from SMBus block readPontus Andersson
commit c6ebcedbab7ca78984959386012a17b21183e1a3 upstream. Commit b6c159a9cb69 ("i2c: ismt: Don't duplicate the receive length for block reads") broke I2C block reads. It aimed to fix normal SMBus block read, but changed the correct behavior of I2C block read in the process. According to Documentation/i2c/smbus-protocol, one vital difference between normal SMBus block read and I2C block read is that there is no byte count prefixed in the data sent on the wire: SMBus Block Read: i2c_smbus_read_block_data() S Addr Wr [A] Comm [A] S Addr Rd [A] [Count] A [Data] A [Data] A ... A [Data] NA P I2C Block Read: i2c_smbus_read_i2c_block_data() S Addr Wr [A] Comm [A] S Addr Rd [A] [Data] A [Data] A ... A [Data] NA P Therefore the two transaction types need to be processed differently in the driver by copying of the dma_buffer as done previously for the I2C_SMBUS_I2C_BLOCK_DATA case. Fixes: b6c159a9cb69 ("i2c: ismt: Don't duplicate the receive length for block reads") Signed-off-by: Pontus Andersson <epontan@gmail.com> Tested-by: Stephen Douthit <stephend@adiengineering.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27ALSA: hda: Remove superfluous '-' added by printk conversionTakashi Iwai
commit 6bf88a343db2b3c160edf9b82a74966b31cc80bd upstream. While converting the error messages to the standard macros in the commit 4e76a8833fac ("ALSA: hda - Replace with standard printk"), a superfluous '-' slipped in the code mistakenly. Its influence is almost negligible, merely shows a dB value as negative integer instead of positive integer (or vice versa) in the rare error message. So let's kill this embarrassing byte to show more correct value. Fixes: 4e76a8833fac ("ALSA: hda - Replace with standard printk") Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27ALSA: seq: Enable 'use' locking in all configurationsBen Hutchings
commit 8009d506a1dd00cf436b0c4cca0dcec130580a21 upstream. The 'use' locking macros are no-ops if neither SMP or SND_DEBUG is enabled. This might once have been OK in non-preemptible configurations, but even in that case snd_seq_read() may sleep while relying on a 'use' lock. So always use the proper implementations. Signed-off-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27drm/nouveau/mmu: flush tlbs before deleting page tablesBen Skeggs
commit 77913bbcb43ac9a07a6fe849c2fd3bf85fc8bdd8 upstream. Even though we've zeroed the PDE, the GPU may have cached the PD, so we need to flush when deleting them. Noticed while working on replacement MMU code, but a backport might be a good idea, so let's fix it in the current code too. Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27drm/nouveau/bsp/g92: disable by defaultIlia Mirkin
commit 194d68dd051c2dd5ac2b522ae16100e774e8d869 upstream. G92's seem to require some additional bit of initialization before the BSP engine can work. It feels like clocks are not set up for the underlying VLD engine, which means that all commands submitted to the xtensa chip end up hanging. VP seems to work fine though. This still allows people to force-enable the bsp engine if they want to play around with it, but makes it harder for the card to hang by default. Signed-off-by: Ilia Mirkin <imirkin@alum.mit.edu> Signed-off-by: Ben Skeggs <bskeggs@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27can: esd_usb2: Fix can_dlc value for received RTR, framesStefan Mätje
commit 72d92e865d1560723e1957ee3f393688c49ca5bf upstream. The dlc member of the struct rx_msg contains also the ESD_RTR flag to mark received RTR frames. Without the fix the can_dlc value for received RTR frames would always be set to 8 by get_can_dlc() instead of the received value. Fixes: 96d8e90382dc ("can: Add driver for esd CAN-USB/2 device") Signed-off-by: Stefan Mätje <stefan.maetje@esd.eu> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27usb: musb: Check for host-mode using is_host_active() on reset interruptJonathan Liu
commit 445ef61543da3db5b699f87fb0aa4f227165f6ed upstream. The sunxi musb has a bug where sometimes it will generate a babble error on device disconnect instead of a disconnect IRQ. When this happens the musb controller switches from host mode to device mode (it clears MUSB_DEVCTL_HM/MUSB_DEVCTL_SESSION and sets MUSB_DEVCTL_BDEVICE) and gets stuck in this state. The babble error is misdetected as a bus reset because MUSB_DEVCTL_HM was cleared. To fix this, use is_host_active() rather than (devctl & MUSB_DEVCTL_HM) to detect babble error so that sunxi musb babble recovery can handle it by restoring the mode. This information is provided by the driver logic and does not rely on register contents. Signed-off-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Bin Liu <b-liu@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27usb: musb: sunxi: Explicitly release USB PHY on exitJonathan Liu
commit 6ed05c68cbcae42cd52b8e53b66952bfa9c002ce upstream. This fixes a kernel oops when unloading the driver due to usb_put_phy being called after usb_phy_generic_unregister when the device is detached. Calling usb_phy_generic_unregister causes x->dev->driver to be NULL in usb_put_phy and results in a NULL pointer dereference. Signed-off-by: Jonathan Liu <net147@gmail.com> Signed-off-by: Bin Liu <b-liu@ti.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27can: gs_usb: fix busy loop if no more TX context is availableWolfgang Grandegger
commit 97819f943063b622eca44d3644067c190dc75039 upstream. If sending messages with no cable connected, it quickly happens that there is no more TX context available. Then "gs_can_start_xmit()" returns with "NETDEV_TX_BUSY" and the upper layer does retry immediately keeping the CPU busy. To fix that issue, I moved "atomic_dec(&dev->active_tx_urbs)" from "gs_usb_xmit_callback()" to the TX done handling in "gs_usb_receive_bulk_callback()". Renaming "active_tx_urbs" to "active_tx_contexts" and moving it into "gs_[alloc|free]_tx_context()" would also make sense. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27ALSA: usb-audio: Add native DSD support for Pro-Ject Pre Box S2 DigitalJussi Laako
commit 9bb201a5d5acc733943e8af7151cceab9d976a69 upstream. Add native DSD support quirk for Pro-Ject Pre Box S2 Digital USB id 2772:0230. Signed-off-by: Jussi Laako <jussi@sonarnerd.net> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27usb: hub: Allow reset retry for USB2 devices on connect bounceMathias Nyman
commit 1ac7db63333db1eeff901bfd6bbcd502b4634fa4 upstream. If the connect status change is set during reset signaling, but the status remains connected just retry port reset. This solves an issue with connecting a 90W HP Thunderbolt 3 dock with a Lenovo Carbon x1 (5th generation) which causes a 30min loop of a high speed device being re-discovererd before usb ports starts working. [...] [ 389.023845] usb 3-1: new high-speed USB device number 55 using xhci_hcd [ 389.491841] usb 3-1: new high-speed USB device number 56 using xhci_hcd [ 389.959928] usb 3-1: new high-speed USB device number 57 using xhci_hcd [...] This is caused by a high speed device that doesn't successfully go to the enabled state after the second port reset. Instead the connection bounces (connected, with connect status change), bailing out completely from enumeration just to restart from scratch. Link: https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1716332 Signed-off-by: Mathias Nyman <mathias.nyman@linux.intel.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27usb: quirks: add quirk for WORLDE MINI MIDI keyboardFelipe Balbi
commit 2811501e6d8f5747d08f8e25b9ecf472d0dc4c7d upstream. This keyboard doesn't implement Get String descriptors properly even though string indexes are valid. What happens is that when requesting for the String descriptor, the device disconnects and reconnects. Without this quirk, this loop will continue forever. Cc: Alan Stern <stern@rowland.harvard.edu> Reported-by: Владимир Мартьянов <vilgeforce@gmail.com> Signed-off-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27usb: cdc_acm: Add quirk for Elatec TWN3Maksim Salau
commit 765fb2f181cad669f2beb87842a05d8071f2be85 upstream. Elatec TWN3 has the union descriptor on data interface. This results in failure to bind the device to the driver with the following log: usb 1-1.2: new full speed USB device using streamplug-ehci and address 4 usb 1-1.2: New USB device found, idVendor=09d8, idProduct=0320 usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0 usb 1-1.2: Product: RFID Device (COM) usb 1-1.2: Manufacturer: OEM cdc_acm 1-1.2:1.0: Zero length descriptor references cdc_acm: probe of 1-1.2:1.0 failed with error -22 Adding the NO_UNION_NORMAL quirk for the device fixes the issue. `lsusb -v` of the device: Bus 001 Device 003: ID 09d8:0320 Device Descriptor: bLength 18 bDescriptorType 1 bcdUSB 2.00 bDeviceClass 2 Communications bDeviceSubClass 0 bDeviceProtocol 0 bMaxPacketSize0 32 idVendor 0x09d8 idProduct 0x0320 bcdDevice 3.00 iManufacturer 1 OEM iProduct 2 RFID Device (COM) iSerial 0 bNumConfigurations 1 Configuration Descriptor: bLength 9 bDescriptorType 2 wTotalLength 67 bNumInterfaces 2 bConfigurationValue 1 iConfiguration 0 bmAttributes 0x80 (Bus Powered) MaxPower 250mA Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 0 bAlternateSetting 0 bNumEndpoints 1 bInterfaceClass 2 Communications bInterfaceSubClass 2 Abstract (modem) bInterfaceProtocol 1 AT-commands (v.25ter) iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x83 EP 3 IN bmAttributes 3 Transfer Type Interrupt Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 2 Interface Descriptor: bLength 9 bDescriptorType 4 bInterfaceNumber 1 bAlternateSetting 0 bNumEndpoints 2 bInterfaceClass 10 CDC Data bInterfaceSubClass 0 Unused bInterfaceProtocol 0 iInterface 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x02 EP 2 OUT bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 Endpoint Descriptor: bLength 7 bDescriptorType 5 bEndpointAddress 0x81 EP 1 IN bmAttributes 2 Transfer Type Bulk Synch Type None Usage Type Data wMaxPacketSize 0x0020 1x 32 bytes bInterval 0 CDC Header: bcdCDC 1.10 CDC Call Management: bmCapabilities 0x03 call management use DataInterface bDataInterface 1 CDC ACM: bmCapabilities 0x06 sends break line coding and serial state CDC Union: bMasterInterface 0 bSlaveInterface 1 Device Status: 0x0000 (Bus Powered) Signed-off-by: Maksim Salau <msalau@iotecha.com> Acked-by: Oliver Neukum <oneukum@suse.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27USB: serial: metro-usb: add MS7820 device idJohan Hovold
commit 31dc3f819bac28a0990b36510197560258ab7421 upstream. Add device-id entry for (Honeywell) Metrologic MS7820 bar code scanner. The device has two interfaces (in this mode?); a vendor-specific interface with two interrupt endpoints and a second HID interface, which we do not bind to. Reported-by: Ladislav Dobrovsky <ladislav.dobrovsky@gmail.com> Tested-by: Ladislav Dobrovsky <ladislav.dobrovsky@gmail.com> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27USB: core: fix out-of-bounds access bug in usb_get_bos_descriptor()Alan Stern
commit 1c0edc3633b56000e18d82fc241e3995ca18a69e upstream. Andrey used the syzkaller fuzzer to find an out-of-bounds memory access in usb_get_bos_descriptor(). The code wasn't checking that the next usb_dev_cap_header structure could fit into the remaining buffer space. This patch fixes the error and also reduces the bNumDeviceCaps field in the header to match the actual number of capabilities found, in cases where there are fewer than expected. Reported-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Andrey Konovalov <andreyknvl@google.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-27USB: devio: Revert "USB: devio: Don't corrupt user memory"Hans de Goede
commit 845d584f41eac3475c21e4a7d5e88d0f6e410cf7 upstream. Taking the uurb->buffer_length userspace passes in as a maximum for the actual urbs transfer_buffer_length causes 2 serious issues: 1) It breaks isochronous support for all userspace apps using libusb, as existing libusb versions pass in 0 for uurb->buffer_length, relying on the kernel using the lenghts of the usbdevfs_iso_packet_desc descriptors passed in added together as buffer length. This for example causes redirection of USB audio and Webcam's into virtual machines using qemu-kvm to no longer work. This is a userspace ABI break and as such must be reverted. Note that the original commit does not protect other users / the kernels memory, it only stops the userspace process making the call from shooting itself in the foot. 2) It may cause the kernel to program host controllers to DMA over random memory. Just as the devio code used to only look at the iso_packet_desc lenghts, the host drivers do the same, relying on the submitter of the urbs to make sure the entire buffer is large enough and not checking transfer_buffer_length. But the "USB: devio: Don't corrupt user memory" commit now takes the userspace provided uurb->buffer_length for the buffer-size while copying over the user-provided iso_packet_desc lengths 1:1, allowing the user to specify a small buffer size while programming the host controller to dma a lot more data. (Atleast the ohci, uhci, xhci and fhci drivers do not check transfer_buffer_length for isoc transfers.) This reverts commit fa1ed74eb1c2 ("USB: devio: Don't corrupt user memory") fixing both these issues. Cc: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21Linux 4.4.94v4.4.94Greg Kroah-Hartman
2017-10-21Revert "tty: goldfish: Fix a parameter of a call to free_irq"Greg Kroah-Hartman
This reverts commit 01b3db29ba1edd79b9c3e7cd294739b70257d278 which is commit 1a5c2d1de7d35f5eb9793266237903348989502b upstream. Ben writes: This fixes a bug introduced in 4.6 by commit 465893e18878 "tty: goldfish: support platform_device with id -1". For earlier kernel versions, it *introduces* a bug. So let's drop it. Reported-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Cc: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Cc: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman gregkh@linuxfoundation.org
2017-10-21cpufreq: CPPC: add ACPI_PROCESSOR dependencyArnd Bergmann
[ Upstream commit a578884fa0d2768f13d37c6591a9e1ed600482d3 ] Without the Kconfig dependency, we can get this warning: warning: ACPI_CPPC_CPUFREQ selects ACPI_CPPC_LIB which has unmet direct dependencies (ACPI && ACPI_PROCESSOR) Fixes: 5477fb3bd1e8 (ACPI / CPPC: Add a CPUFreq driver for use with CPPC) Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21nfsd/callback: Cleanup callback cred on shutdownKinglong Mee
[ Upstream commit f7d1ddbe7648af7460d23688c8c131342eb43b3a ] The rpccred gotten from rpc_lookup_machine_cred() should be put when state is shutdown. Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21target/iscsi: Fix unsolicited data seq_end_offset calculationVarun Prakash
[ Upstream commit 4d65491c269729a1e3b375c45e73213f49103d33 ] In case of unsolicited data for the first sequence seq_end_offset must be set to minimum of total data length and FirstBurstLength, so do not add cmd->write_data_done to the min of total data length and FirstBurstLength. This patch avoids that with ImmediateData=Yes, InitialR2T=No, MaxXmitDataSegmentLength < FirstBurstLength that a WRITE command with IO size above FirstBurstLength triggers sequence error messages, for example Set following parameters on target (linux-4.8.12) ImmediateData = Yes InitialR2T = No MaxXmitDataSegmentLength = 8k FirstBurstLength = 64k Log in from Open iSCSI initiator and execute dd if=/dev/zero of=/dev/sdb bs=128k count=1 oflag=direct Error messages on target Command ITT: 0x00000035 with Offset: 65536, Length: 8192 outside of Sequence 73728:131072 while DataSequenceInOrder=Yes. Command ITT: 0x00000035, received DataSN: 0x00000001 higher than expected 0x00000000. Unable to perform within-command recovery while ERL=0. Signed-off-by: Varun Prakash <varun@chelsio.com> [ bvanassche: Use min() instead of open-coding it / edited patch description ] Signed-off-by: Bart Van Assche <bart.vanassche@sandisk.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21uapi: fix linux/mroute6.h userspace compilation errorsDmitry V. Levin
[ Upstream commit 72aa107df6a275cf03359934ca5799a2be7a1bf7 ] Include <linux/in6.h> to fix the following linux/mroute6.h userspace compilation errors: /usr/include/linux/mroute6.h:80:22: error: field 'mf6cc_origin' has incomplete type struct sockaddr_in6 mf6cc_origin; /* Origin of mcast */ /usr/include/linux/mroute6.h:81:22: error: field 'mf6cc_mcastgrp' has incomplete type struct sockaddr_in6 mf6cc_mcastgrp; /* Group in question */ /usr/include/linux/mroute6.h:91:22: error: field 'src' has incomplete type struct sockaddr_in6 src; /usr/include/linux/mroute6.h:92:22: error: field 'grp' has incomplete type struct sockaddr_in6 grp; /usr/include/linux/mroute6.h:132:18: error: field 'im6_src' has incomplete type struct in6_addr im6_src, im6_dst; /usr/include/linux/mroute6.h:132:27: error: field 'im6_dst' has incomplete type struct in6_addr im6_src, im6_dst; Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21uapi: fix linux/rds.h userspace compilation errorsDmitry V. Levin
[ Upstream commit feb0869d90e51ce8b6fd8a46588465b1b5a26d09 ] Consistently use types from linux/types.h to fix the following linux/rds.h userspace compilation errors: /usr/include/linux/rds.h:106:2: error: unknown type name 'uint8_t' uint8_t name[32]; /usr/include/linux/rds.h:107:2: error: unknown type name 'uint64_t' uint64_t value; /usr/include/linux/rds.h:117:2: error: unknown type name 'uint64_t' uint64_t next_tx_seq; /usr/include/linux/rds.h:118:2: error: unknown type name 'uint64_t' uint64_t next_rx_seq; /usr/include/linux/rds.h:121:2: error: unknown type name 'uint8_t' uint8_t transport[TRANSNAMSIZ]; /* null term ascii */ /usr/include/linux/rds.h:122:2: error: unknown type name 'uint8_t' uint8_t flags; /usr/include/linux/rds.h:129:2: error: unknown type name 'uint64_t' uint64_t seq; /usr/include/linux/rds.h:130:2: error: unknown type name 'uint32_t' uint32_t len; /usr/include/linux/rds.h:135:2: error: unknown type name 'uint8_t' uint8_t flags; /usr/include/linux/rds.h:139:2: error: unknown type name 'uint32_t' uint32_t sndbuf; /usr/include/linux/rds.h:144:2: error: unknown type name 'uint32_t' uint32_t rcvbuf; /usr/include/linux/rds.h:145:2: error: unknown type name 'uint64_t' uint64_t inum; /usr/include/linux/rds.h:153:2: error: unknown type name 'uint64_t' uint64_t hdr_rem; /usr/include/linux/rds.h:154:2: error: unknown type name 'uint64_t' uint64_t data_rem; /usr/include/linux/rds.h:155:2: error: unknown type name 'uint32_t' uint32_t last_sent_nxt; /usr/include/linux/rds.h:156:2: error: unknown type name 'uint32_t' uint32_t last_expected_una; /usr/include/linux/rds.h:157:2: error: unknown type name 'uint32_t' uint32_t last_seen_una; /usr/include/linux/rds.h:164:2: error: unknown type name 'uint8_t' uint8_t src_gid[RDS_IB_GID_LEN]; /usr/include/linux/rds.h:165:2: error: unknown type name 'uint8_t' uint8_t dst_gid[RDS_IB_GID_LEN]; /usr/include/linux/rds.h:167:2: error: unknown type name 'uint32_t' uint32_t max_send_wr; /usr/include/linux/rds.h:168:2: error: unknown type name 'uint32_t' uint32_t max_recv_wr; /usr/include/linux/rds.h:169:2: error: unknown type name 'uint32_t' uint32_t max_send_sge; /usr/include/linux/rds.h:170:2: error: unknown type name 'uint32_t' uint32_t rdma_mr_max; /usr/include/linux/rds.h:171:2: error: unknown type name 'uint32_t' uint32_t rdma_mr_size; /usr/include/linux/rds.h:212:9: error: unknown type name 'uint64_t' typedef uint64_t rds_rdma_cookie_t; /usr/include/linux/rds.h:215:2: error: unknown type name 'uint64_t' uint64_t addr; /usr/include/linux/rds.h:216:2: error: unknown type name 'uint64_t' uint64_t bytes; /usr/include/linux/rds.h:221:2: error: unknown type name 'uint64_t' uint64_t cookie_addr; /usr/include/linux/rds.h:222:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:228:2: error: unknown type name 'uint64_t' uint64_t cookie_addr; /usr/include/linux/rds.h:229:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:234:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:240:2: error: unknown type name 'uint64_t' uint64_t local_vec_addr; /usr/include/linux/rds.h:241:2: error: unknown type name 'uint64_t' uint64_t nr_local; /usr/include/linux/rds.h:242:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:243:2: error: unknown type name 'uint64_t' uint64_t user_token; /usr/include/linux/rds.h:248:2: error: unknown type name 'uint64_t' uint64_t local_addr; /usr/include/linux/rds.h:249:2: error: unknown type name 'uint64_t' uint64_t remote_addr; /usr/include/linux/rds.h:252:4: error: unknown type name 'uint64_t' uint64_t compare; /usr/include/linux/rds.h:253:4: error: unknown type name 'uint64_t' uint64_t swap; /usr/include/linux/rds.h:256:4: error: unknown type name 'uint64_t' uint64_t add; /usr/include/linux/rds.h:259:4: error: unknown type name 'uint64_t' uint64_t compare; /usr/include/linux/rds.h:260:4: error: unknown type name 'uint64_t' uint64_t swap; /usr/include/linux/rds.h:261:4: error: unknown type name 'uint64_t' uint64_t compare_mask; /usr/include/linux/rds.h:262:4: error: unknown type name 'uint64_t' uint64_t swap_mask; /usr/include/linux/rds.h:265:4: error: unknown type name 'uint64_t' uint64_t add; /usr/include/linux/rds.h:266:4: error: unknown type name 'uint64_t' uint64_t nocarry_mask; /usr/include/linux/rds.h:269:2: error: unknown type name 'uint64_t' uint64_t flags; /usr/include/linux/rds.h:270:2: error: unknown type name 'uint64_t' uint64_t user_token; /usr/include/linux/rds.h:274:2: error: unknown type name 'uint64_t' uint64_t user_token; /usr/include/linux/rds.h:275:2: error: unknown type name 'int32_t' int32_t status; Signed-off-by: Dmitry V. Levin <ldv@altlinux.org> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21ceph: clean up unsafe d_parent accesses in build_dentry_pathJeff Layton
[ Upstream commit c6b0b656ca24ede6657abb4a2cd910fa9c1879ba ] While we hold a reference to the dentry when build_dentry_path is called, we could end up racing with a rename that changes d_parent. Handle that situation correctly, by using the rcu_read_lock to ensure that the parent dentry and inode stick around long enough to safely check ceph_snap and ceph_ino. Link: http://tracker.ceph.com/issues/18148 Signed-off-by: Jeff Layton <jlayton@redhat.com> Reviewed-by: Yan, Zheng <zyan@redhat.com> Signed-off-by: Ilya Dryomov <idryomov@gmail.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21i2c: at91: ensure state is restored after suspendingAlexandre Belloni
[ Upstream commit e3ccc921b7d8fd1fcd10a00720e09823d8078666 ] When going to suspend, the I2C registers may be lost because the power to VDDcore is cut. Restore them when resuming. Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com> Acked-by: Ludovic Desroches <ludovic.desroches@microchip.com> Signed-off-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21net: mvpp2: release reference to txq_cpu[] entry after unmappingThomas Petazzoni
[ Upstream commit 36fb7435b6ac4d288a2d4deea8934f9456ab46b6 ] The mvpp2_txq_bufs_free() function is called upon TX completion to DMA unmap TX buffers, and free the corresponding SKBs. It gets the references to the SKB to free and the DMA buffer to unmap from a per-CPU txq_pcpu data structure. However, the code currently increments the pointer to the next entry before doing the DMA unmap and freeing the SKB. It does not cause any visible problem because for a given SKB the TX completion is guaranteed to take place on the CPU where the TX was started. However, it is much more logical to increment the pointer to the next entry once the current entry has been completely unmapped/released. Signed-off-by: Thomas Petazzoni <thomas.petazzoni@free-electrons.com> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21scsi: scsi_dh_emc: return success in clariion_std_inquiry()Dan Carpenter
[ Upstream commit 4d7d39a18b8b81511f0b893b7d2203790bf8a58b ] We accidentally return an uninitialized variable on success. Fixes: b6ff1b14cdf4 ("[SCSI] scsi_dh: Update EMC handler") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Hannes Reinecke <hare@suse.de> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21slub: do not merge cache if slub_debug contains a never-merge flagGrygorii Maistrenko
[ Upstream commit c6e28895a4372992961888ffaadc9efc643b5bfe ] In case CONFIG_SLUB_DEBUG_ON=n, find_mergeable() gets debug features from commandline but never checks if there are features from the SLAB_NEVER_MERGE set. As a result selected by slub_debug caches are always mergeable if they have been created without a custom constructor set or without one of the SLAB_* debug features on. This moves the SLAB_NEVER_MERGE check below the flags update from commandline to make sure it won't merge the slab cache if one of the debug features is on. Link: http://lkml.kernel.org/r/20170101124451.GA4740@lp-laptop-d Signed-off-by: Grygorii Maistrenko <grygoriimkd@gmail.com> Reviewed-by: Pekka Enberg <penberg@kernel.org> Acked-by: David Rientjes <rientjes@google.com> Acked-by: Christoph Lameter <cl@linux.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21ocfs2/dlmglue: prepare tracking logic to avoid recursive cluster lockEric Ren
[ Upstream commit 439a36b8ef38657f765b80b775e2885338d72451 ] We are in the situation that we have to avoid recursive cluster locking, but there is no way to check if a cluster lock has been taken by a precess already. Mostly, we can avoid recursive locking by writing code carefully. However, we found that it's very hard to handle the routines that are invoked directly by vfs code. For instance: const struct inode_operations ocfs2_file_iops = { .permission = ocfs2_permission, .get_acl = ocfs2_iop_get_acl, .set_acl = ocfs2_iop_set_acl, }; Both ocfs2_permission() and ocfs2_iop_get_acl() call ocfs2_inode_lock(PR): do_sys_open may_open inode_permission ocfs2_permission ocfs2_inode_lock() <=== first time generic_permission get_acl ocfs2_iop_get_acl ocfs2_inode_lock() <=== recursive one A deadlock will occur if a remote EX request comes in between two of ocfs2_inode_lock(). Briefly describe how the deadlock is formed: On one hand, OCFS2_LOCK_BLOCKED flag of this lockres is set in BAST(ocfs2_generic_handle_bast) when downconvert is started on behalf of the remote EX lock request. Another hand, the recursive cluster lock (the second one) will be blocked in in __ocfs2_cluster_lock() because of OCFS2_LOCK_BLOCKED. But, the downconvert never complete, why? because there is no chance for the first cluster lock on this node to be unlocked - we block ourselves in the code path. The idea to fix this issue is mostly taken from gfs2 code. 1. introduce a new field: struct ocfs2_lock_res.l_holders, to keep track of the processes' pid who has taken the cluster lock of this lock resource; 2. introduce a new flag for ocfs2_inode_lock_full: OCFS2_META_LOCK_GETBH; it means just getting back disk inode bh for us if we've got cluster lock. 3. export a helper: ocfs2_is_locked_by_me() is used to check if we have got the cluster lock in the upper code path. The tracking logic should be used by some of the ocfs2 vfs's callbacks, to solve the recursive locking issue cuased by the fact that vfs routines can call into each other. The performance penalty of processing the holder list should only be seen at a few cases where the tracking logic is used, such as get/set acl. You may ask what if the first time we got a PR lock, and the second time we want a EX lock? fortunately, this case never happens in the real world, as far as I can see, including permission check, (get|set)_(acl|attr), and the gfs2 code also do so. [sfr@canb.auug.org.au remove some inlines] Link: http://lkml.kernel.org/r/20170117100948.11657-2-zren@suse.com Signed-off-by: Eric Ren <zren@suse.com> Reviewed-by: Junxiao Bi <junxiao.bi@oracle.com> Reviewed-by: Joseph Qi <jiangqi903@gmail.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Mark Fasheh <mfasheh@versity.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21crypto: xts - Add ECB dependencyMilan Broz
[ Upstream commit 12cb3a1c4184f891d965d1f39f8cfcc9ef617647 ] Since the commit f1c131b45410a202eb45cc55980a7a9e4e4b4f40 crypto: xts - Convert to skcipher the XTS mode is based on ECB, so the mode must select ECB otherwise it can fail to initialize. Signed-off-by: Milan Broz <gmazyland@gmail.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21net/mlx4_core: Fix VF overwrite of module param which disables DMFS on new ↵Majd Dibbiny
probed PFs [ Upstream commit 95f1ba9a24af9769f6e20dfe9a77c863f253f311 ] In the VF driver, module parameter mlx4_log_num_mgm_entry_size was mistakenly overwritten -- and in a manner which overrode the device-managed flow steering option encoded in the parameter. log_num_mgm_entry_size is a global module parameter which affects all ConnectX-3 PFs installed on that host. If a VF changes log_num_mgm_entry_size, this will affect all PFs which are probed subsequent to the change (by disabling DMFS for those PFs). Fixes: 3c439b5586e9 ("mlx4_core: Allow choosing flow steering mode") Signed-off-by: Majd Dibbiny <majd@mellanox.com> Reviewed-by: Jack Morgenstein <jackm@dev.mellanox.co.il> Signed-off-by: Tariq Toukan <tariqt@mellanox.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-10-21sparc64: Migrate hvcons irq to panicked cpuVijay Kumar
[ Upstream commit 7dd4fcf5b70694dc961eb6b954673e4fc9730dbd ] On panic, all other CPUs are stopped except the one which had hit panic. To keep console alive, we need to migrate hvcons irq to panicked CPU. Signed-off-by: Vijay Kumar <vijay.ac.kumar@oracle.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Sasha Levin <alexander.levin@verizon.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
