The GPIO_I2C_INFO table does not always have
ATOM_MAX_SUPPORTED_DEVICE entries. Limit
the number of indices to the size of the
table.
Should fix Novell bug 589022.
v2: fix typo
Signed-off-by: Alex Deucher <alexdeucher@gmail.com>
Cc: Stable <stable@kernel.org>
Gleaned from the Mesa code.
Fixes https://bugs.freedesktop.org/show_bug.cgi?id=27355 .
Signed-off-by: Michel Dänzer <daenzer@vmware.com>
Cc: stable@kernel.org
Some GPUs have an APM/ACPI PM mode selection switch and some BIOSes
set this to APM. We really want this in ACPI mode for Linux.
These GPUs should be setting these registers up also.
If we resume in a bad way, we'll get 0xffffffff in wptr, and then
oops with no console. This just adds a sanity check so that we can
avoid the oops and hopefully get more details out of people's systems.
Need to enable the VID stream after link training
Turn off hw i2c by default except for mm i2c which
is hw only until we sort out the remaining prescale
issues on older chips. hw i2c can be enabled with
hw_i2c=1.
This allows us to remove the internal bit algo bus used by
the radeon i2c algo. We now register a radeon algo adapter
if the gpio line is hw capable and the hw inplementation is
available, otherwise we register a bit algo adapter.
Doesn't seem to work reliably and the pci quirks don't
always work.
- Add module option to force the display priority
0 = auto, 1 = normal, 2 = high
- Default to high on r3xx/r4xx/rv515 chips
Fixes flickering problems during heavy acceleration
due to underflow to the display controllers
- Fill in minimal support for RS600
v2 - update display priority when bandwidth is updated
so the user can change the parameter at runtime and it
will take affect on the next modeset.
training
Seems to have gotten lost in the evergreen merge.
Some systems have LCD* rather than DFP* device tags in the bios
for eDP connectors; notably the new apple iMac. This fixes
things up so eDP connectors with either tag will work.
v2: fix typo
Looks like a copy/paste typo from when evergreen support
was added.
- 8 lane links are not valid for DP
- remove unused num var
This prevented radeon.test=1 from testing transfers from/to GTT beyond the
visible VRAM size.
Fix build error when CONFIG_MAGIC_SYSRQ is not enabled:
drivers/gpu/drm/drm_fb_helper.c:915: error: 'sysrq_drm_fb_helper_restore_op' undeclared (first use in this function)
drivers/gpu/drm/drm_fb_helper.c:929: error: 'sysrq_drm_fb_helper_restore_op' undeclared (first use in this function)
- remove a few more drm only regs
- remove sampler, alu, bool, loop constant regs.
They are set via separate packet3's already
- Drop some more safe regs taht userspace shouldn't hit
- Constant base regs need relocs. This allows us to use
constant buffers rather than the constant register file.
Also we don't want userspace to be able to set arbitrary
mc base values for the const caches.
- Track SQ_CONFIG so we know whether userspace is using
the cfile or constant buffers.
Only the drm should be touching them.
Replace a BUG_ON with an error code in the event that the inode mapping
changes between calls to drm_open. This may happen for instance if udev
is loaded subsequent to the original opening of the device:
[ 644.291870] kernel BUG at drivers/gpu/drm/drm_fops.c:146!
[ 644.291876] invalid opcode: 0000 [#1] SMP
[ 644.291882] last sysfs file: /sys/kernel/uevent_seqnum
[ 644.291888]
[ 644.291895] Pid: 7276, comm: lt-cairo-test-s Not tainted 2.6.34-rc1 #2 N150/N210/N220 /N150/N210/N220
[ 644.291903] EIP: 0060:[<c11c70e3>] EFLAGS: 00210283 CPU: 0
[ 644.291912] EIP is at drm_open+0x4b1/0x4e2
[ 644.291918] EAX: f72d8d18 EBX: f790a400 ECX: f73176b8 EDX: 00000000
[ 644.291923] ESI: f790a414 EDI: f790a414 EBP: f647ae20 ESP: f647adfc
[ 644.291929] DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068
[ 644.291937] Process lt-cairo-test-s (pid: 7276, ti=f647a000 task=f73f5c80 task.ti=f647a000)
[ 644.291941] Stack:
[ 644.291945] 00000000 f7bb7400 00000080 f6451100 f73176b8 f6479214 f6451100 f73176b8
[ 644.291957] <0> c1297ce0 f647ae34 c11c6c04 f73176b8 f7949800 00000000 f647ae54 c1080ac5
[ 644.291969] <0> f7949800 f6451100 00000000 f6451100 f73176b8 f6452780 f647ae70 c107d1e6
[ 644.291982] Call Trace:
[ 644.291991] [<c11c6c04>] ? drm_stub_open+0x8a/0xb8
[ 644.292000] [<c1080ac5>] ? chrdev_open+0xef/0x106
[ 644.292008] [<c107d1e6>] ? __dentry_open+0xd4/0x1a6
[ 644.292015] [<c107d35b>] ? nameidata_to_filp+0x31/0x45
[ 644.292022] [<c10809d6>] ? chrdev_open+0x0/0x106
[ 644.292030] [<c10864e2>] ? do_last+0x346/0x423
[ 644.292037] [<c108789f>] ? do_filp_open+0x190/0x415
[ 644.292046] [<c1071eb5>] ? handle_mm_fault+0x214/0x710
[ 644.292053] [<c107d008>] ? do_sys_open+0x4d/0xe9
[ 644.292061] [<c1016462>] ? do_page_fault+0x211/0x23f
[ 644.292068] [<c107d0f0>] ? sys_open+0x23/0x2b
[ 644.292075] [<c1002650>] ? sysenter_do_call+0x12/0x26
[ 644.292079] Code: 89 f0 89 55 dc e8 8d 96 0a 00 8b 45 e0 8b 55 dc 83 78 04 01 75 28 8b 83 18 02 00 00 85 c0 74 0f 8b 4d ec 3b 81 ac 00 00 00 74 13 <0f> 0b eb fe 8b 4d ec 8b 81 ac 00 00 00 89 83 18 02 00 00 89 f0
[ 644.292143] EIP: [<c11c70e3>] drm_open+0x4b1/0x4e2 SS:ESP 0068:f647adfc
[ 644.292175] ---[ end trace 2ddd476af89a60fa ]---
Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk>
When there is allocation failure in radeon_cs_parser_relocs parser->nrelocs
is not cleaned. This causes NULL pointer defeference in radeon_cs_parser_fini
when clean up code is trying to loop over the relocation array and free the
objects.
Fix adds a check for a possible NULL pointer in clean up code.
Signed-off-by: Pauli Nieminen <suokkos@gmail.com>
radeon_gart_fini might call GART unbind callback function which
might try to access GART table but if gart_disable is call first
the GART table will be unmapped so any access to it will oops.
Signed-off-by: Jerome Glisse <jglisse@redhat.com>
We can get this if the user moves the mouse when we are waiting to move
some stuff around in the validate. Don't fail.
Check that atom cmd and data tables are valid
before using them.
(v2)
- fix some whitespace errors noticed by Rafał Miłecki
- check a few more cases
- no longer needed with the latest new pll algo fixes.
- also don't use lcd pll limits. They don't seem
to work well for all systems. If we have a case where
they are useful, we can set the flag for that case.
fixes fdo bug 27083
I missed rs4xx in 7f1e613daf0fdd0884316ab25a749db3c671329e
Fixes fdo bug 27219.
RS4xx+ IGP chips use an internal gart, however,
some of them have the agp cap bits set in their pci
configs. Make sure to clear the AGP flag as AGP will
not work with them.
Should fix fdo bug 27225
cc: stable@kernel.org
- rs780/880 were using the wrong bandwidth functions
- convert r1xx-r4xx to use the same pm sclk/mclk structs as
r5xx+
- move bandwidth setup to a common function
Replace hardcoded numbers with rdev->num_crtc.
This fixes some issues with the last gfx init patch.
Make sure we have a crtc assigned to the encoder
before dereferencing it.
Look up i2c bus in the power table and expose it.
You'll need to load a hwmon driver for any chips
on the bus, this patch just exposes the bus.
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
serial: sh-sci: remove duplicated #include
sh: Export uncached helper symbols.
sh: Fix up NUMA build for 29-bit.
serial: sh-sci: Fix build failure for non-sh architectures.
sh: Fix up uncached offset for legacy 29-bit mode.
sh: Support CPU affinity masks for INTC controllers.
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb
* 'for-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb:
uwb: remove duplicate cpu_to_le16()
uwb: declare MODULE_FIRMWARE() in i1480 DFU driver
uwb: make USB device id table constant
uwb: wlp: refactor wlp_get_<attribute>() macros
git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mattst88/alpha-2.6:
alpha: fix compile errors in dma-mapping-common.h
alpha: remove trailing spaces in messages
alpha: use __ratelimit
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc
* 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc:
powerpc: Remove IOMMU_VMERGE config option
powerpc: Fix swiotlb to respect the boot option
powerpc: Do not call prink when CONFIG_PRINTK is not defined
powerpc: Use correct ccr bit for syscall error status
powerpc/fsl-booke: Get coherent bit from PTE
powerpc/85xx: Make sure lwarx hint isn't set on ppc32
git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6
* 'zerolen' of git://git.kernel.org/pub/scm/linux/kernel/git/jgarzik/misc-2.6:
Delete zero-length file drivers/mtd/maps/omap_nor.c
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6:
tty_port,usb-console: Fix usb serial console open/close regression
tty: cpm_uart: use resource_size()
tty_buffer: Fix distinct type warning
hvc_console: Fix race between hvc_close and hvc_remove
uartlite: Fix build on sparc.
tty: Take a 256 byte padding into account when buffering below sub-page units
Revert "tty: Add a new VT mode which is like VT_PROCESS but doesn't require a VT_RELDISP ioctl call"
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/driver-core-2.6:
driver core: numa: fix BUILD_BUG_ON for node_read_distance
driver-core: document ERR_PTR() return values
kobject: documentation: Update to refer to kset-example.c.
sysdev: the cpu probe/release attributes should be sysdev_class_attributes
kobject: documentation: Fix erroneous example in kobject doc.
driver-core: fix missing kernel-doc in firmware_class
Driver core: Early platform kernel-doc update
sysfs: fix sysfs lockdep warning in mlx4 code
sysfs: fix sysfs lockdep warning in infiniband code
sysfs: fix sysfs lockdep warning in ipmi code
sysfs: Initialised pci bus legacy_mem field before use
sysfs: use sysfs_bin_attr_init in firmware class driver
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (45 commits)
USB: gadget/multi: cdc_do_config: remove redundant check
usb: r8a66597-hcd: fix removed from an attached hub
USB: xhci: Make endpoint interval debugging clearer.
USB: Fix usb_fill_int_urb for SuperSpeed devices
USB: cp210x: Remove double usb_control_msg from cp210x_set_config
USB: Remove last bit of CONFIG_USB_BERRY_CHARGE
USB: gadget: add gadget controller number for s3c-hsotg driver
USB: ftdi_sio: Fix locking for change_speed() function
USB: g_mass_storage: fixed module name in Kconfig
USB: gadget: f_mass_storage::fsg_bind(): fix error handling
USB: g_mass_storage: fix section mismatch warnings
USB: gadget: fix Blackfin builds after gadget cleansing
USB: goku_udc: remove potential null dereference
USB: option.c: Add Pirelli VID/PID and indicate Pirelli's modem interface is 0xff
USB: serial: Fix module name typo for qcaux Kconfig entry.
usb: cdc-wdm: Fix deadlock between write and resume
usb: cdc-wdm: Fix order in disconnect and fix locking
usb: cdc-wdm:Fix loss of data due to autosuspend
usb: cdc-wdm: Fix submission of URB after suspension
usb: cdc-wdm: Fix race between disconnect and debug messages
The content was deleted in cc87edb173effdf74e680ee6d622a935ff0c1d6f,
but the file remained as a zero-length file.
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits)
ceph: update for write_inode API change
ceph: reset osd after relevant messages timed out
ceph: fix flush_dirty_caps race with caps migration
ceph: include migrating caps in issued set
ceph: fix osdmap decoding when pools include (removed) snaps
ceph: return EBADF if waiting for caps on closed file
ceph: set osd request message front length correctly
ceph: reset front len on return to msgpool; BUG on mismatched front iov
ceph: fix snaptrace decoding on cap migration between mds
ceph: use single osd op reply msg
ceph: reset bits on connection close
ceph: remove bogus mds forward warning
ceph: remove fragile __map_osds optimization
ceph: fix connection fault STANDBY check
ceph: invalidate_authorizer without con->mutex held
ceph: don't clobber write return value when using O_SYNC
ceph: fix client_request_forward decoding
ceph: drop messages on unregistered mds sessions; cleanup
ceph: fix comments, locking in destroy_inode
ceph: move dereference after NULL test
Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6:
cifs: trivial white space
[CIFS] checkpatch cleanup
cifs: add cifs_revalidate_file
cifs: add a CIFSSMBUnixQFileInfo function
cifs: add a CIFSSMBQFileInfo function
cifs: overhaul cifs_revalidate and rename to cifs_revalidate_dentry
