2005-08-29[INET]: Generalise tcp_tw_bucket, aka TIME_WAIT socketsArnaldo Carvalho de Melo
This paves the way to generalise the rest of the sock ID lookup routines and saves some bytes in TCPv4 TIME_WAIT sockets on distro kernels (where IPv6 is always built as a module): [root@qemu ~]# grep tw_sock /proc/slabinfo tw_sock_TCPv6 0 0 128 31 1 tw_sock_TCP 0 0 96 41 1 [root@qemu ~]# Now if a protocol wants to use the TIME_WAIT generic infrastructure it only has to set the sk_prot->twsk_obj_size field with the size of its inet_timewait_sock derived sock and proto_register will create sk_prot->twsk_slab, for now its only for INET sockets, but we can introduce timewait_sock later if some non INET transport protocolo wants to use this stuff. Next changesets will take advantage of this new infrastructure to generalise even more TCP code. [acme@toy net-2.6.14]$ grep built-in /tmp/before.size /tmp/after.size /tmp/before.size: 188646 11764 5068 205478 322a6 net/ipv4/built-in.o /tmp/after.size: 188144 11764 5068 204976 320b0 net/ipv4/built-in.o [acme@toy net-2.6.14]$ Tested with both IPv4 & IPv6 (::1 (localhost) & ::ffff:172.20.0.1 (qemu host)). Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Generalise tcp_v4_lookup_listenerArnaldo Carvalho de Melo
[acme@toy net-2.6.14]$ grep built-in /tmp/before /tmp/after /tmp/before: 282560 13122 9312 304994 4a762 net/ipv4/built-in.o /tmp/after: 282560 13122 9312 304994 4a762 net/ipv4/built-in.o Will be used in DCCP, not exporting it right now not to get in Adrian Bunk's exported-but-not-used-on-modules radar 8) Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Generalise tcp_v4_hash & tcp_unhashArnaldo Carvalho de Melo
It really just makes the existing code be a helper function that tcp_v4_hash and tcp_unhash uses, specifying the right inet_hashinfo, tcp_hashinfo. One thing I'll investigate at some point is to have the inet_hashinfo pointer in sk_prot, so that we get all the hashtable information from the sk pointer, this can lead to some extra indirections that may well hurt performance/code size, we'll see. Ultimate idea would be that sk_prot would provide _all_ the information about a protocol implementation. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[TCP]: Move the tcp sock states to net/tcp_states.hArnaldo Carvalho de Melo
Lots of places just needs the states, not even linux/tcp.h, where this enum was, needs it. This speeds up development of the refactorings as less sources are rebuilt when things get moved from net/tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Generalise the tcp_listen_ lock routinesArnaldo Carvalho de Melo
2005-08-29[INET]: Move tcp_port_rover to inet_hashinfoArnaldo Carvalho de Melo
Also expose all of the tcp_hashinfo members, i.e. killing those tcp_ehash, etc macros, this will more clearly expose already generic functions and some that need just a bit of work to become generic, as we'll see in the upcoming changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Generalise tcp_bind_hash & tcp_inherit_portArnaldo Carvalho de Melo
This required moving tcp_bucket_cachep to inet_hashinfo. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: fix list traversal order in ctnetlinkPablo Neira Ayuso
Currently conntracks are inserted after the head. That means that conntracks are sorted from the biggest to the smallest id. This happens because we use list_prepend (list_add) instead list_add_tail. This can result in problems during the list iteration. list_for_each(i, &ip_conntrack_hash[cb->args[0]]) { h = (struct ip_conntrack_tuple_hash *) i; if (DIRECTION(h) != IP_CT_DIR_ORIGINAL) continue; ct = tuplehash_to_ctrack(h); if (ct->id <= *id) continue; In that case just the first conntrack in the bucket will be dumped. To fix this, we iterate the list from the tail to the head via list_for_each_prev. Same thing for the list of expectations. Signed-off-by: Pablo Neira Ayuso <pablo@eurodev.net> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Fix typo in ctnl_exp_cb array (no bug, just memory waste)Pablo Neira Ayuso
This fixes the size of the ctnl_exp_cb array that is IPCTNL_MSG_EXP_MAX instead of IPCTNL_MSG_MAX. Simple typo. Signed-off-by: Pablo Neira Ayuso <pablo@eurodev.net> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: fix conntrack refcount leak in unlink_expect()Pablo Neira Ayuso
In unlink_expect(), the expectation is removed from the list so the refcount must be dropped as well. Signed-off-by: Pablo Neira Ayuso <pablo@eurodev.net> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: ctnetlink: make sure event order is correctPablo Neira Ayuso
The following sequence is displayed during events dumping of an ICMP connection: [NEW] [DESTROY] [UPDATE] This happens because the event IPCT_DESTROY is delivered in death_by_timeout(), that is called from the icmp protocol helper (ct->timeout.function) once we see the reply. To fix this, we move this event to destroy_conntrack(). Signed-off-by: Pablo Neira Ayuso <pablo@eurodev.net> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: don't use nested attributes for conntrack_expectHarald Welte
We used to use nested nfattr structures for ip_conntrack_expect. This is bogus, since ip_conntrack and ip_conntrack_expect are communicated in different netlink message types. both should be encoded at the top level attributes, no extra nesting required. This patch addresses the issue. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: cleanup nfnetlink_check_attributes()Harald Welte
1) memset return parameter 'cda' (nfattr pointer array) only on success 2) a message without attributes and just a 'struct nfgenmsg' is valid, don't return -EINVAL 3) use likely() and unlikely() where apropriate Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: attribute count is an attribute of message type, not subsytemHarald Welte
Prior to this patch, every nfnetlink subsystem had to specify it's attribute count. However, in reality the attribute count depends on the message type within the subsystem, not the subsystem itself. This patch moves 'attr_count' from 'struct nfnetlink_subsys' into nfnl_callback to fix this. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: fix ctnetlink 'create_expect' parsingHarald Welte
There was a stupid copy+paste mistake where we parse the MASK nfattr into the "tuple" variable instead of the "mask" variable. This patch fixes it. Thanks to Pablo Neira. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: conntrack_netlink: Fix locking during conntrack_createPablo Neira
The current codepath allowed for ip_conntrack_lock to be unlock'ed twice. Signed-off-by: Pablo Neira <pablo@eurodev.net> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: remove bogus memset() calls from ip_conntrack_netlink.cPablo Neira
nfattr_parse_nested() calls nfattr_parse() which in turn does a memset on the 'tb' array. All callers therefore don't need to memset before calling it. Signed-off-by: Pablo Neira <pablo@eurodev.net> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Fix multiple problems with the conntrack event cachePatrick McHardy
refcnt underflow: the reference count is decremented when a conntrack entry is removed from the hash but it is not incremented when entering new entries. missing protection of process context against softirq context: all cache operations need to locally disable softirqs to avoid races. Additionally the event cache can't be initialized when a packet enteres the conntrack code but needs to be initialized whenever we cache an event and the stored conntrack entry doesn't match the current one. incorrect flushing of the event cache in ip_ct_iterate_cleanup: without real locking we can't flush the cache for different CPUs without incurring races. The cache for different CPUs can only be flushed when no packets are going through the code. ip_ct_iterate_cleanup doesn't need to drop all references, so flushing is moved to the cleanup path. Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Move bind_hash from tcp_sk to inet_skArnaldo Carvalho de Melo
This should really be in a inet_connection_sock, but I'm leaving it for a later optimization, when some more fields common to INET transport protocols now in tcp_sk or inet_sk will be chunked out into inet_connection_sock, for now its better to concentrate on getting the changes in the core merged to leave the DCCP tree with only DCCP specific code. Next changesets will take advantage of this move to generalise things like tcp_bind_hash, tcp_put_port, tcp_inherit_port, making the later receive a inet_hashinfo parameter, and even __tcp_tw_hashdance, etc in the future, when tcp_tw_bucket gets transformed into the struct timewait_sock hierarchy. tcp_destroy_sock also is eligible as soon as tcp_orphan_count gets moved to sk_prot. A cascade of incremental changes will ultimately make the tcp_lookup functions be fully generic. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Move the TCP hashtable functions/structs to inet_hashtables.[ch]Arnaldo Carvalho de Melo
2005-08-29[INET]: Just rename the TCP hashtable functions/structs to inet_Arnaldo Carvalho de Melo
This is to break down the complexity of the series of patches, making it very clear that this one just does: 1. renames tcp_ prefixed hashtable functions and data structures that were already mostly generic to inet_ to share it with DCCP and other INET transport protocols. 2. Removes not used functions (__tb_head & tb_head) 3. Removes some leftover prototypes in the headers (tcp_bucket_unlock & tcp_v4_build_header) Next changesets will move tcp_sk(sk)->bind_hash to inet_sock so that we can make functions such as tcp_inherit_port, __tcp_inherit_port, tcp_v4_get_port, __tcp_put_port, generic and get others like tcp_destroy_sock closer to generic (tcp_orphan_count will go to sk->sk_prot to allow this). Eventually most of these functions will be used passing the transport protocol inet_hashinfo structure. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Move the TCP ehash functions to include/net/inet_hashtables.hArnaldo Carvalho de Melo
To be shared with DCCP (and others), this is the start of a series of patches that will expose the already generic TCP hash table routines. The few changes noticed when calling gcc -S before/after on a pentium4 were of this type: movl 40(%esp), %edx cmpl %esi, 472(%edx) je .L168 - pushl $291 + pushl $272 pushl $.LC0 pushl $.LC1 pushl $.LC2 [acme@toy net-2.6.14]$ size net/ipv4/tcp_ipv4.before.o net/ipv4/tcp_ipv4.after.o text data bss dec hex filename 17804 516 140 18460 481c net/ipv4/tcp_ipv4.before.o 17804 516 140 18460 481c net/ipv4/tcp_ipv4.after.o Holler if some weird architecture has issues with things like this 8) Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Add new "nfnetlink_log" userspace packet logging facilityHarald Welte
This is a generic (layer3 independent) version of what ipt_ULOG is already doing for IPv4 today. ipt_ULOG, ebt_ulog and finally also ip[6]t_LOG will be deprecated by this mechanism in the long term. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Extend netfilter logging APIHarald Welte
This patch is in preparation to nfnetlink_log: - loggers now have to register struct nf_logger instead of nf_logfn - nf_log_unregister() replaced by nf_log_unregister_pf() and nf_log_unregister_logger() - add comment to ip[6]t_LOG.h to assure nobody redefines flags - add /proc/net/netfilter/nf_log to tell user which logger is currently registered for which address family - if user has configured logging, but no logging backend (logger) is available, always spit a message to syslog, not just the first time. - split ip[6]t_LOG.c into two parts: Backend: Always try to register as logger for the respective address family Frontend: Always log via nf_log_packet() API - modify all users of nf_log_packet() to accomodate additional argument Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Add refcounting and /proc/net/netfilter interface to ↵Harald Welte
nfnetlink_queue Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[INET]: Introduce inet_sk_rebuild_headerArnaldo Carvalho de Melo
From tcp_v4_rebuild_header, that already was pretty generic, I only needed to use sk->sk_protocol instead of the hardcoded IPPROTO_TCP and establish the requirement that INET transport layer protocols that want to use this function map TCP_SYN_SENT to its equivalent state. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SOCK]: Introduce sk_setup_capsArnaldo Carvalho de Melo
From tcp_v4_setup_caps, that always is preceded by a call to __sk_dst_set, so coalesce this sequence into sk_setup_caps, removing one call to a TCP function in the IP layer. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[SOCK]: Rename __tcp_v4_rehash to __sk_prot_rehashArnaldo Carvalho de Melo
This operation was already generic and DCCP will use it. Signed-off-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Cleanup INET_REFCNT_DEBUG codeArnaldo Carvalho de Melo
2005-08-29[IPV4/6]: Check if packet was actually delivered to a raw socket to decide ↵Patrick McHardy
whether to send an ICMP unreachable Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV6]: Check interface bindings on IPv6 raw socket receptionAndrew McDonald
Take account of whether a socket is bound to a particular device when selecting an IPv6 raw socket to receive a packet. Also perform this check when receiving IPv6 packets with router alert options. Signed-off-by: Andrew McDonald <andrew@mcdonald.org.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Add "nfnetlink_queue" netfilter queue handler over nfnetlinkHarald Welte
- Add new nfnetlink_queue module - Add new ipt_NFQUEUE and ip6t_NFQUEUE modules to access queue numbers 1-65535 - Mark ip_queue and ip6_queue Kconfig options as OBSOLETE - Update feature-removal-schedule to remove ip[6]_queue in December Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Core changes required by upcoming nfnetlink_queue codeHarald Welte
- split netfiler verdict in 16bit verdict and 16bit queue number - add 'queuenum' argument to nf_queue_outfn_t and its users ip[6]_queue - move NFNL_SUBSYS_ definitions from enum to #define - introduce autoloading for nfnetlink subsystem modules - add MODULE_ALIAS_NFNL_SUBSYS macro - add nf_unregister_queue_handlers() to register all handlers for a given nf_queue_outfn_t - add more verbose DEBUGP macro definition to nfnetlink.c - make nfnetlink_subsys_register fail if subsys already exists - add some more comments and debug statements to nfnetlink.c Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Move reroute-after-queue code up to the nf_queue layer.Harald Welte
The rerouting functionality is required by the core, therefore it has to be implemented by the core and not in individual queue handlers. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETLINK]: Add properly module refcounting for kernel netlink sockets.Harald Welte
- Remove bogus code for compiling netlink as module - Add module refcounting support for modules implementing a netlink protocol - Add support for autoloading modules that implement a netlink protocol as soon as someone opens a socket for that protocol Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Move ipv4 specific code from net/core/netfilter.c to ↵Harald Welte
net/ipv4/netfilter.c Netfilter cleanup - Move ipv4 code from net/core/netfilter.c to net/ipv4/netfilter.c - Move ipv6 netfilter code from net/ipv6/ip6_output.c to net/ipv6/netfilter.c Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: Rename skb_ip_make_writable() to skb_make_writable()Harald Welte
There is nothing IPv4-specific in it. In fact, it was already used by IPv6, too... Upcoming nfnetlink_queue code will use it for any kind of packet. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: C99 initizalizers for NAT protocolsPatrick McHardy
2005-08-29[NET]: Remove explicit initializations of skb->input_devDavid S. Miller
Instead, set it in one place, namely the beginning of netif_receive_skb(). Based upon suggestions from Jamal Hadi Salim. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[IPV4]: possible cleanupsAdrian Bunk
This patch contains the following possible cleanups: - make needlessly global code static - #if 0 the following unused global function: - xfrm4_state.c: xfrm4_state_fini - remove the following unneeded EXPORT_SYMBOL's: - ip_output.c: ip_finish_output - ip_output.c: sysctl_ip_default_ttl - fib_frontend.c: ip_dev_find - inetpeer.c: inet_peer_idlock - ip_options.c: ip_options_compile - ip_options.c: ip_options_undo - net/core/request_sock.c: sysctl_max_syn_backlog Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->real_devDavid S. Miller
Bonding just wants the device before the skb_bond() decapsulation occurs, so simply pass that original device into packet_type->func() as an argument. It remains to be seen whether we can use this same exact thing to get rid of skb->input_dev as well. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Reduce tc_index/tc_verd to u16Patrick McHardy
2005-08-29[REQSK]: Move the syn_table destroy from tcp_listen_stop to reqsk_queue_destroyArnaldo Carvalho de Melo
2005-08-29[NETFILTER]: Add ctnetlink subsystemHarald Welte
Add ctnetlink subsystem for userspace-access to ip_conntrack table. This allows reading and updating of existing entries, as well as creating new ones (and new expect's) via nfnetlink. Please note the 'strange' byte order: nfattr (tag+length) are in host byte order, while the payload is always guaranteed to be in network byte order. This allows a simple userspace process to encapsulate netlink messages into arch-independent udp packets by just processing/swapping the headers and not knowing anything about the actual payload. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Remove HIPPI private from skbuff.hStephen Hemminger
This removes the private element from skbuff, that is only used by HIPPI. Instead it uses skb->cb[] to hold the additional data that is needed in the output path from hard_header to device driver. PS: The only qdisc that might potentially corrupt this cb[] is if netem was used over HIPPI. I will take care of that by fixing netem to use skb->stamp. I don't expect many users of netem over HIPPI Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Introduce SO_{SND,RCV}BUFFORCE socket optionsPatrick McHardy
Allows overriding of sysctl_{wmem,rmrm}_max Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFITLER]: Add nfnetlink layer.Harald Welte
Introduce "nfnetlink" (netfilter netlink) layer. This layer is used as transport layer for all userspace communication of the new upcoming netfilter subsystems, such as ctnetlink, nfnetlink_queue and some day even the mythical pkttables ;) Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NETFILTER]: connection tracking event notifiersHarald Welte
This adds a notifier chain based event mechanism for ip_conntrack state changes. As opposed to the previous implementations in patch-o-matic, we do no longer need a field in the skb to achieve this. Thanks to the valuable input from Patrick McHardy and Rusty on the idea of a per_cpu implementation. Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2005-08-29[NET]: Kill skb->tc_classidPatrick McHardy
2005-08-29[NET]: Kill skb->listDavid S. Miller
Remove the "list" member of struct sk_buff, as it is entirely redundant. All SKB list removal callers know which list the SKB is on, so storing this in sk_buff does nothing other than taking up some space. Two tricky bits were SCTP, which I took care of, and two ATM drivers which Francois Romieu <romieu@fr.zoreil.com> fixed up. Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
