2011-03-25m68k: merge m68k and m68knommu arch directoriesGreg Ungerer
There is a lot of common code that could be shared between the m68k and m68knommu arch branches. It makes sense to merge the two branches into a single directory structure so that we can more easily share that common code. This is a brute force merge, based on a script from Stephen King <sfking@fdwdc.com>, which was originally written by Arnd Bergmann <arnd@arndb.de>. > The script was inspired by the script Sam Ravnborg used to merge the > includes from m68knommu. For those files common to both arches but > differing in content, the m68k version of the file is renamed to > <file>_mm.<ext> and the m68knommu version of the file is moved into the > corresponding m68k directory and renamed <file>_no.<ext> and a small > wrapper file <file>.<ext> is used to select between the two version. Files > that are common to both but don't differ are removed from the m68knommu > tree and files and directories that are unique to the m68knommu tree are > moved to the m68k tree. Finally, the arch/m68knommu tree is removed. > > To select between the the versions of the files, the wrapper uses > > #ifdef CONFIG_MMU > #include <file>_mm.<ext> > #else > #include <file>_no.<ext> > #endif On top of this file merge I have done a simplistic merge of m68k and m68knommu Kconfig, which primarily attempts to keep existing options and menus in place. Other than a handful of options being moved it produces identical .config outputs on m68k and m68knommu targets I tested it on. With this in place there is now quite a bit of scope for merge cleanups in future patches. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-03-24Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: simplify iget & friends fs: pull inode->i_lock up out of writeback_single_inode fs: rename inode_lock to inode_hash_lock fs: move i_wb_list out from under inode_lock fs: move i_sb_list out from under inode_lock fs: remove inode_lock from iput_final and prune_icache fs: Lock the inode LRU list separately fs: factor inode disposal fs: protect inode->i_state with inode->i_lock autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd() autofs4 - remove autofs4_lock autofs4 - fix d_manage() return on rcu-walk autofs4 - fix autofs4_expire_indirect() traversal autofs4 - fix dentry leak in autofs4_expire_direct() autofs4 - reinstate last used update on access vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
2011-03-24[media] rc: update for bitop name changesStephen Rothwell
Fix the following compile failure: drivers/media/rc/ite-cir.c: In function 'ite_decode_bytes': drivers/media/rc/ite-cir.c:190: error: implicit declaration of function 'generic_find_next_le_bit' drivers/media/rc/ite-cir.c:199: error: implicit declaration of function 'generic_find_next_zero_le_bit' Caused by commit 620a32bba4a2 ("[media] rc: New rc-based ite-cir driver for several ITE CIRs") interacting with commit c4945b9ed472 ("asm-generic: rename generic little-endian bitops functions"). Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24fs: simplify iget & friendsChristoph Hellwig
Merge get_new_inode/get_new_inode_fast into iget5_locked/iget_locked as those were the only callers. Remove the internal ifind/ifind_fast helpers - ifind_fast only had a single caller, and ifind had two callers wanting it to do different things. Also clean up the comments in this area to focus on information important to a developer trying to use it, instead of overloading them with implementation details. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: pull inode->i_lock up out of writeback_single_inodeDave Chinner
First thing we do in writeback_single_inode() is take the i_lock and the last thing we do is drop it. A caller already holds the i_lock, so pull the i_lock out of writeback_single_inode() to reduce the round trips on this lock during inode writeback. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: rename inode_lock to inode_hash_lockDave Chinner
All that remains of the inode_lock is protecting the inode hash list manipulation and traversals. Rename the inode_lock to inode_hash_lock to reflect it's actual function. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: move i_wb_list out from under inode_lockDave Chinner
Protect the inode writeback list with a new global lock inode_wb_list_lock and use it to protect the list manipulations and traversals. This lock replaces the inode_lock as the inodes on the list can be validity checked while holding the inode->i_lock and hence the inode_lock is no longer needed to protect the list. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: move i_sb_list out from under inode_lockDave Chinner
Protect the per-sb inode list with a new global lock inode_sb_list_lock and use it to protect the list manipulations and traversals. This lock replaces the inode_lock as the inodes on the list can be validity checked while holding the inode->i_lock and hence the inode_lock is no longer needed to protect the list. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: remove inode_lock from iput_final and prune_icacheDave Chinner
Now that inode state changes are protected by the inode->i_lock and the inode LRU manipulations by the inode_lru_lock, we can remove the inode_lock from prune_icache and the initial part of iput_final(). instead of using the inode_lock to protect the inode during iput_final, use the inode->i_lock instead. This protects the inode against new references being taken while we change the inode state to I_FREEING, as well as preventing prune_icache from grabbing the inode while we are manipulating it. Hence we no longer need the inode_lock in iput_final prior to setting I_FREEING on the inode. For prune_icache, we no longer need the inode_lock to protect the LRU list, and the inodes themselves are protected against freeing races by the inode->i_lock. Hence we can lift the inode_lock from prune_icache as well. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: Lock the inode LRU list separatelyDave Chinner
Introduce the inode_lru_lock to protect the inode_lru list. This lock is nested inside the inode->i_lock to allow the inode to be added to the LRU list in iput_final without needing to deal with lock inversions. This keeps iput_final() clean and neat. Further, where marking the inode I_FREEING and removing it from the LRU, move the LRU list manipulation within the inode->i_lock to keep the list manipulation consistent with iput_final. This also means that most of the open coded LRU list removal + unused inode accounting can now use the inode_lru_list_del() wrappers which cleans the code up further. However, this locking change means what the LRU traversal in prune_icache() inverts this lock ordering and needs to use trylock semantics on the inode->i_lock to avoid deadlocking. In these cases, if we fail to lock the inode we move it to the back of the LRU to prevent spinning on it. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: factor inode disposalDave Chinner
We have a couple of places that dispose of inodes. factor the disposal into evict() to isolate this code and make it simpler to peel away the inode_lock from the code. While doing this, change the logic flow in iput_final() to separate the different cases that need to be handled to make the transitions the inode goes through more obvious. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: protect inode->i_state with inode->i_lockDave Chinner
Protect inode state transitions and validity checks with the inode->i_lock. This enables us to make inode state transitions independently of the inode_lock and is the first step to peeling away the inode_lock from the code. This requires that __iget() is done atomically with i_state checks during list traversals so that we don't race with another thread marking the inode I_FREEING between the state check and grabbing the reference. Also remove the unlock_new_inode() memory barrier optimisation required to avoid taking the inode_lock when clearing I_NEW. Simplify the code by simply taking the inode->i_lock around the state change and wakeup. Because the wakeup is no longer tricky, remove the wake_up_inode() function and open code the wakeup where necessary. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'slab/urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: SLUB: Write to per cpu data when allocating it slub: Fix debugobjects with lockless fastpath
2011-03-24lib, arch: add filter argument to show_mem and fix private implementationsDavid Rientjes
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which resulted in build warnings on all architectures that implement their own versions of show_mem(): lib/lib.a(show_mem.o): In function `show_mem': show_mem.c:(.text+0x1f4): multiple definition of `show_mem' arch/sparc/mm/built-in.o:(.text+0xd70): first defined here The fix is to remove __show_mem() and add its argument to show_mem() in all implementations to prevent this breakage. Architectures that implement their own show_mem() actually don't do anything with the argument yet, but they could be made to filter nodes that aren't allowed in the current context in the future just like the generic implementation. Reported-by: Stephen Rothwell <sfr@canb.auug.org.au> Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com> Suggested-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Rientjes <rientjes@google.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-24Merge branch 'drm-core-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: drm/vblank: update recently added vbl interface to be more future proof. drm radeon: Return -EINVAL on wrong pm sysfs access drm/radeon/kms: fix hardcoded EDID handling Revert "drm/i915: Don't save/restore hardware status page address register" drm/i915: Avoid unmapping pages from a NULL address space drm/i915: Fix use after free within tracepoint drm/i915: Restore missing command flush before interrupt on BLT ring drm/i915: Disable pagefaults along execbuffer relocation fast path drm/i915: Fix computation of pitch for dumb bo creator drm/i915: report correct render clock frequencies on SNB drm/i915/dp: Correct the order of deletion for ghost eDP devices drm/i915: Fix tiling corruption from pipelined fencing drm/i915: Re-enable self-refresh drm/i915: Prevent racy removal of request from client list drm/i915: skip redundant operations whilst enabling pipes and planes drm/i915: Remove surplus POSTING_READs before wait_for_vblank drm/radeon/kms: prefer legacy pll algo for tv-out drm: check for modesetting on modeset ioctls drm/kernel: vblank wait on crtc > 1 drm: Fix use-after-free in drm_gem_vm_close()
2011-03-24SLUB: Write to per cpu data when allocating itChristoph Lameter
It turns out that the cmpxchg16b emulation has to access vmalloced percpu memory with interrupts disabled. If the memory has never been touched before then the fault necessary to establish the mapping will not to occur and the kernel will fail on boot. Fix that by reusing the CONFIG_PREEMPT code that writes the cpu number into a field on every cpu. Writing to the per cpu area before causes the mapping to be established before we get to a cmpxchg16b emulation. Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-03-24slub: Fix debugobjects with lockless fastpathThomas Gleixner
On Thu, 24 Mar 2011, Ingo Molnar wrote: > RIP: 0010:[<ffffffff810570a9>] [<ffffffff810570a9>] get_next_timer_interrupt+0x119/0x260 That's a typical timer crash, but you were unable to debug it with debugobjects because commit d3f661d6 broke those. Cc: Christoph Lameter <cl@linux.com> Tested-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2011-03-24autofs4: Do not potentially dereference NULL pointer returned by fget() in ↵Jesper Juhl
autofs_dev_ioctl_setpipefd() In fs/autofs4/dev-ioctl.c::autofs_dev_ioctl_setpipefd() we call fget(), which may return NULL, but we do not explicitly test for that NULL return so we may end up dereferencing a NULL pointer - bad. When I originally submitted this patch I had chosen EBUSY as the return value to use if this happens. Ian Kent was kind enough to explain why that would most likely be wrong and why EBADF should most likely be used instead. This version of the patch uses EBADF. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - remove autofs4_lockIan Kent
The autofs4_lock introduced by the rcu-walk changes has unnecessarily broad scope. The locking is better handled by the per-autofs super block lookup_lock. Signed-off-by: Ian Kent <raven@themaw.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - fix d_manage() return on rcu-walkIan Kent
The daemon never needs to block and, in the rcu-walk case an error return isn't used, so always return zero. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - fix autofs4_expire_indirect() traversalIan Kent
The vfs-scale changes changed the traversal used in autofs4_expire_indirect() from a list to a depth first tree traversal which isn't right. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - fix dentry leak in autofs4_expire_direct()Ian Kent
There is a missing dput() when returning from autofs4_expire_direct() when we see that the dentry is already a pending mount. Signed-off-by: Ian Kent <raven@themaw.net> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24autofs4 - reinstate last used update on accessIan Kent
When direct (and offset) mounts were introduced the the last used timeout could no longer be updated in ->d_revalidate(). This is because covered direct mounts would be followed over without calling the autofs file system. As a result the definition of the busyness check for all entries was changed to be "actually busy" being an open file or working directory within the automount. But now we have a call back in the follow so the last used update on any access can be re-instated. This requires DCACHE_MANAGE_TRANSIT to always be set. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24vfs - check non-mountpoint dentry might block in __follow_mount_rcu()Ian Kent
When following a mount in rcu-walk mode we must check if the incoming dentry is telling us it may need to block, even if it isn't actually a mountpoint. Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-24Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300 * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300: MN10300: gcc 4.6 vs am33 inline assembly MN10300: Deprecate gdbstub MN10300: Allow KGDB to use the MN10300 serial ports MN10300: Emulate single stepping in KGDB on MN10300 MN10300: Generalise kernel debugger kernel halt, reboot or power off hook KGDB: Notify GDB of machine halt, reboot or power off MN10300: Use KGDB MN10300: Create generic kernel debugger hooks MN10300: Create general kernel debugger cache flushing MN10300: Introduce a general config option for kernel debugger hooks MN10300: The icache invalidate functions should disable the icache first MN10300: gdbstub: Restrict single-stepping to non-preemptable non-SMP configs
2011-03-24Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: pstore: cleanups to pstore_dump() [IA64] New syscalls for 2.6.39
2011-03-24Merge branch 'rmobile-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'rmobile-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: mmc: Add MMC_PROGRESS_* mmc, ARM: Rename SuperH Mobile ARM zboot helpers ARM: mach-shmobile: add coherent DMA mask to CEU camera devices ARM: mach-shmobile: Dynamic backlight control for Mackerel
2011-03-24Merge branch 'sh-latest' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: Fix build alloc_thread_info_node function sh: Fix ptrace hw_breakpoint handling sh: Fix ptrace fpu state initialisation sh: Re-enable GENERIC_HARDIRQS_NO_DEPRECATED. sh: pmb: Use struct syscore_ops instead of sysdevs sh: Use struct syscore_ops instead of sysdevs sh: Conver to asm-generic/sizes.h. sh: wire up sys_syncfs.
2011-03-24Merge branch 'usb-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6 * 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: cdc-acm: fix potential null-pointer dereference on disconnect USB: cdc-acm: fix potential null-pointer dereference USB: cdc-acm: fix memory corruption / panic USB: Fix 'bad dma' problem on WDM device disconnect usb: wwan: fix compilation without CONFIG_PM_RUNTIME USB: uss720 fixup refcount position usb: musb: blackfin: fix typo in new bfin_musb_vbus_status func usb: musb: blackfin: fix typo in new dev_pm_ops struct usb: musb: blackfin: fix typo in platform driver name usb: musb: Fix for merge issue ehci-hcd: Bug fix: don't set a QH's Halt bit USB: Do not pass negative length to snoop_urb()
2011-03-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits) [media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t [media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly [media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE [media] v4l: soc-camera: Store negotiated buffer settings [media] rc: interim support for 32-bit NEC-ish scancodes [media] mceusb: topseed 0x0011 needs gen3 init for tx to work [media] lirc_zilog: error out if buffer read bytes != chunk size [media] lirc: silence some compile warnings [media] hdpvr: use same polling interval as other OS [media] ir-kbd-i2c: pass device code w/key in hauppauge case [media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap [media] remove the old RC_MAP_HAUPPAUGE_NEW RC map [media] rc/keymaps: Rename Hauppauge table as rc-hauppauge [media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping [media] rc-rc5-hauppauge-new: Add support for the old Black RC [media] rc-rc5-hauppauge-new: Add the old control to the table [media] rc-winfast: Fix the keycode tables [media] a800: Fix a few wrong IR key assignments [media] opera1: Use multimedia keys instead of an app-specific mapping [media] dw2102: Use multimedia keys instead of an app-specific mapping ... Fix up trivial conflicts (remove/modify and some real conflicts) in: arch/arm/mach-omap2/devices.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/dabusb/dabusb.c drivers/staging/dabusb/dabusb.h drivers/staging/easycap/easycap_ioctl.c drivers/staging/usbvideo/usbvideo.c drivers/staging/usbvideo/vicam.c
2011-03-24Merge branch 'for-linus' of git://android.git.kernel.org/kernel/tegraLinus Torvalds
* 'for-linus' of git://android.git.kernel.org/kernel/tegra: ARM: tegra: harmony: initialize the TPS65862 PMIC ARM: tegra: update defconfig ARM: tegra: harmony: update PCI-e initialization sequence ARM: tegra: trimslice: enable MMC/SD slots ARM: tegra: enable new drivers in defconfig ARM: tegra: Add Toshiba AC100 support ARM: tegra: harmony: Set WM8903 gpio_base ARM: tegra: harmony: I2C-related portions of audio support ARM: tegra: harmony: register i2c devices ARM: tegra: seaboard: register i2c devices ARM: tegra: harmony: Beginnings of audio support ARM: tegra: create defines for SD-related GPIO names ARM: tegra: add devices.c entries for audio
2011-03-24Merge branch 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6: spi/pl022: Add loopback support for the SPI on 5500 spi/omap_mcspi: Fix broken last word xfer of/flattree: minor cleanups dt: eliminate OF_NO_DEEP_PROBE and test for NULL match table dt: protect against NULL matches passed to of_match_node() dt: Refactor of_platform_bus_probe()
2011-03-25mmc: Add MMC_PROGRESS_*Simon Horman
This is my second attempt to make this enum generally available. The first attempt added MMCIF_PROGRESS_* to include/linux/mmc/sh_mmcif.h. However this is not sufficiently generic as the enum will be used by SDHI boot code. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-25mmc, ARM: Rename SuperH Mobile ARM zboot helpersSimon Horman
These headers and helpers will also be used for SDHI boot so the mmcif name will start to make a lot less sense. Signed-off-by: Simon Horman <horms@verge.net.au> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2011-03-24Merge branch 'idle-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: intel_idle: Rename cpuidle states
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (42 commits) ACPI: minor printk format change in acpi_pad ACPI: make acpi_pad /sys output more readable ACPICA: Update version to 20110316 ACPICA: Header support for SLIC table ACPI: Make sure the FADT is at least rev 2 before using the reset register ACPI: Bug compatibility for Windows on the ACPI reboot vector ACPICA: Fix access width for reset vector ACPI battery: fribble sysfs files from a resume notifier ACPI button: remove unused procfs I/F ACPI, APEI, Add PCIe AER error information printing support PCIe, AER, use pre-generated prefix in error information printing ACPI, APEI, Add ERST record ID cache ACPI: Use syscore_ops instead of sysdev class and sysdev ACPI: Remove the unused EC sysdev class ACPI: use __cpuinit for the acpi_processor_set_pdc() call tree ACPI: use __init where possible in processor driver Thermal_Framework-Fix_crash_during_hwmon_unregister ACPICA: Update version to 20110211. ACPICA: Add mechanism to defer _REG methods for some installed handlers ACPICA: Add support for FunctionalFixedHW in acpi_ut_get_region_name ...
git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/vapier/blackfin: Blackfin: bf54x: re-enable anomaly 05000353 for all revs Blackfin: enable atomic64_t support Blackfin: wire up new syncfs syscall Blackfin: SMP: flush CoreB cache when shutting down
2011-03-24Merge branch 'for-linus' of git://git.infradead.org/ubi-2.6Linus Torvalds
* 'for-linus' of git://git.infradead.org/ubi-2.6: UBIFS: fix assertion warning and refine comments UBIFS: kill CONFIG_UBIFS_FS_DEBUG_CHKS UBIFS: use GFP_NOFS properly UBI: use GFP_NOFS properly
2011-03-24Merge branch 'for-2.6.39' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.39' of git://linux-nfs.org/~bfields/linux: SUNRPC: Remove resource leak in svc_rdma_send_error() nfsd: wrong index used in inner loop nfsd4: fix comment and remove unused nfsd4_file fields nfs41: make sure nfs server return right ca_maxresponsesize_cached nfsd: fix compile error svcrpc: fix bad argument in unix_domain_find nfsd4: fix struct file leak nfsd4: minor nfs4state.c reshuffling svcrpc: fix rare race on unix_domain creation nfsd41: modify the members value of nfsd4_op_flags nfsd: add proc file listing kernel's gss_krb5 enctypes gss:krb5 only include enctype numbers in gm_upcall_enctypes NFSD, VFS: Remove dead code in nfsd_rename() nfsd: kill unused macro definition locks: use assign_type()
2011-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: Squashfs: Use vmalloc rather than kmalloc for zlib workspace Squashfs: handle corruption of directory structure Squashfs: wrap squashfs_mount() definition Squashfs: xz_wrapper doesn't need to include squashfs_fs_i.h anymore Squashfs: Update documentation to include compression options Squashfs: Update Kconfig help text to include xz compression Squashfs: add compression options support to xz decompressor Squashfs: extend decompressor framework to handle compression options
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB: Increase DMA max_segment_size on Mellanox hardware IB/mad: Improve an error message so error code is included RDMA/nes: Don't print success message at level KERN_ERR RDMA/addr: Fix return of uninitialized ret value IB/srp: try to use larger FMR sizes to cover our mappings IB/srp: add support for indirect tables that don't fit in SRP_CMD IB/srp: rework mapping engine to use multiple FMR entries IB/srp: allow sg_tablesize to be set for each target IB/srp: move IB CM setup completion into its own function IB/srp: always avoid non-zero offsets into an FMR
2011-03-24Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (90 commits) mfd: Push byte swaps out of wm8994 bulk read path mfd: Rename ab8500 gpadc header mfd: Constify WM8994 write path mfd: Push byte swap out of WM8994 bulk I/O mfd: Avoid copying data in WM8994 I2C write mfd: Remove copy from WM831x I2C write function mfd: Staticise WM8994 PM ops regulator: Add a subdriver for TI TPS6105x regulator portions v2 mfd: Add a core driver for TI TPS61050/TPS61052 chips v2 gpio: Add Tunnel Creek support to sch_gpio mfd: Add Tunnel Creek support to lpc_sch pci_ids: Add Intel Tunnel Creek LPC Bridge device ID. regulator: MAX8997/8966 support mfd: Add WM8994 bulk register write operation mfd: Append additional read write on 88pm860x mfd: Adopt mfd_data in 88pm860x input driver mfd: Adopt mfd_data in 88pm860x regulator mfd: Adopt mfd_data in 88pm860x led mfd: Adopt mfd_data in 88pm860x backlight mfd: Fix MAX8997 Kconfig entry typos ...
2011-03-24Merge branch 'for-linus' of git://git.open-osd.org/linux-open-osdLinus Torvalds
* 'for-linus' of git://git.open-osd.org/linux-open-osd: exofs: deprecate the commands pending counter exofs: Write sbi->s_nextid as part of the Create command exofs: Add option to mount by osdname exofs: Override read-ahead to align on stripe_size exofs: simple fsync race fix exofs: Optimize read_4_write exofs: Trivial: fix some indentation and debug prints exofs: Remove redundant unlikely()
2011-03-24Merge git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: (140 commits) MAINTAINERS: de-orphan fbdev. MAINTAINERS: Add file pattern for fb dt bindings. video: Move sm501fb devicetree binding documentation to a better place. fbcon: fix situation where fbcon gets deinitialised and can't reinit. video, sm501: add OF binding to support SM501 video, sm501: add edid and commandline support video, sm501: add I/O functions for use on powerpc video: Fix EDID macros H_SYNC_WIDTH and H_SYNC_OFFSET fbcon: Bugfix soft cursor detection in Tile Blitting video: add missing framebuffer_release in error path video: metronomefb: add __devexit_p around reference to metronomefb_remove video: hecubafb: add __devexit_p around reference to hecubafb_remove drivers:video:aty:radeon_base Fix typo occationally to occasionally atmel_lcdfb: add fb_blank function atmel_lcdfb: implement inverted contrast pwm video: s3c-fb: return proper error if clk_get fails uvesafb,vesafb: create WC or WB PAT-entries video: ffb: fix ffb_probe error path radeonfb: Let hwmon driver probe the "monid" I2C bus fbdev: sh_mobile_lcdc: checking NULL instead of IS_ERR() ...
2011-03-24UBIFS: fix assertion warning and refine commentsArtem Bityutskiy
This patch fixes the following UBIFS assertion warning: UBIFS assert failed in do_readpage at 115 (pid 199) [<b00321b8>] (unwind_backtrace+0x0/0xdc) from [<af025118>] (do_readpage+0x108/0x594 [ubifs]) [<af025118>] (do_readpage+0x108/0x594 [ubifs]) from [<af025764>] (ubifs_write_end+0x1c0/0x2e8 [ubifs]) [<af025764>] (ubifs_write_end+0x1c0/0x2e8 [ubifs]) from [<b00a0164>] (generic_file_buffered_write+0x18c/0x270) [<b00a0164>] (generic_file_buffered_write+0x18c/0x270) from [<b00a08d4>] (__generic_file_aio_write+0x478/0x4c0) [<b00a08d4>] (__generic_file_aio_write+0x478/0x4c0) from [<b00a0984>] (generic_file_aio_write+0x68/0xc8) [<b00a0984>] (generic_file_aio_write+0x68/0xc8) from [<af024a78>] (ubifs_aio_write+0x178/0x1d8 [ubifs]) [<af024a78>] (ubifs_aio_write+0x178/0x1d8 [ubifs]) from [<b00d104c>] (do_sync_write+0xb0/0x100) [<b00d104c>] (do_sync_write+0xb0/0x100) from [<b00d1abc>] (vfs_write+0xac/0x154) [<b00d1abc>] (vfs_write+0xac/0x154) from [<b00d1c10>] (sys_write+0x3c/0x68) [<b00d1c10>] (sys_write+0x3c/0x68) from [<b002d9a0>] (ret_fast_syscall+0x0/0x2c) The 'PG_checked' flag is used to indicate that the page does not supposedly exist on the media (e.g., a hole or a page beyond the inode size), so it requires slightly bigger budget, because we have to account the indexing size increase. And this flag basically tells that the budget for this page has to be "new page budget". The "new page budget" is slightly bigger than the "existing page budget". The 'do_readpage()' function has the following assertion which sometimes is hit: 'ubifs_assert(!PageChecked(page))'. Obviously, the meaning of this assertion is: "I should not be asked to read a page which does not exist on the media". However, in 'ubifs_write_begin()' we have a small "trick". Notice, that VFS may write pages which were not read yet, so the page data were not loaded from the media to the page cache yet. If VFS tells that it is going to change only some part of the page, we obviously have to load it from the media. However, if VFS tells that it is going to change whole page, we do not read it from the media for optimization purposes. However, since we do not read it, we do not know if it exists on the media or not (a hole, etc). So we set the 'PG_checked' flag to this page to force bigger budget, just in case. So 'ubifs_write_begin()' sets 'PG_checked'. Then we are in 'ubifs_write_end()'. And VFS tells us: "hey, for some reasons I changed my mind and did not change whole page". Frankly, I do not know why this happens, but I hit this somehow on an ARM platform. And this is extremely rare. So in this case UBIFS does the following: 1. Cancels allocated budget. 2. Loads the page from the media by calling 'do_readpage()'. 3. Asks VFS to repeat the whole write operation from the very beginning (call '->write_begin() again, etc). And the assertion warning is hit at the step 2 - remember we have the 'PG_checked' set for this page, and 'do_readpage()' does not like this. So this patch fixes the problem by adding step 1.5 and cleaning the 'PG_checked' before calling 'do_readpage()'. All in all, this patch does not fix any functionality issue, but it silences UBIFS false positive warning which may happen in very very rare cases. And while on it, this patch also improves a commentary which explains the reasons of setting the 'PG_checked' flag for the page. The old commentary was a bit difficult to understand. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-24UBIFS: kill CONFIG_UBIFS_FS_DEBUG_CHKSArtem Bityutskiy
Simplify UBIFS configuration menu and kill the option to enable self-check compile-time. We do not really need this because we can do this run-time using the module parameters or the corresponding sysfs interfaces. And there is a value in simplifying the kernel configuration menu which becomes increasingly large. Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-24UBIFS: use GFP_NOFS properlyArtem Bityutskiy
This patch fixes a brown-paperbag bug which was introduced by me: I used incorrect "GFP_KERNEL | GFP_NOFS" allocation flags to make sure my allocations do not cause write-back. But the correct form is "GFP_NOFS". Signed-off-by: Artem Bityutskiy <Artem.Bityutskiy@nokia.com>
2011-03-24UBI: use GFP_NOFS properlyArtem Bityutskiy
2011-03-24drm/vblank: update recently added vbl interface to be more future proof.Dave Airlie
This makes the interface a bit cleaner by leaving a single gap in the vblank bit space instead of creating two gaps. Suggestions from Michel on mailing list/irc. Reviewed-by: Michel Dänzer <michel@daenzer.net> Signed-off-by: Dave Airlie <airlied@redhat.com>
