Signed-off-by: FUJITA Tomonori <fujita.tomonori@lab.ntt.co.jp>
To: akpm@linux-foundation.org
Cc: linux-mips@linux-mips.org
Patchwork: https://patchwork.linux-mips.org/patch/1566/
git://git.linux-nfs.org/projects/trondmy/nfs-2.6
* 'nfs-for-2.6.39' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (28 commits)
Cleanup XDR parsing for LAYOUTGET, GETDEVICEINFO
NFSv4.1 convert layoutcommit sync to boolean
NFSv4.1 pnfs_layoutcommit_inode fixes
NFS: Determine initial mount security
NFS: use secinfo when crossing mountpoints
NFS: Add secinfo procedure
NFS: lookup supports alternate client
NFS: convert call_sync() to a function
NFSv4.1 remove temp code that prevented ds commits
NFSv4.1: layoutcommit
NFSv4.1: filelayout driver specific code for COMMIT
NFSv4.1: remove GETATTR from ds commits
NFSv4.1: add generic layer hooks for pnfs COMMIT
NFSv4.1: alloc and free commit_buckets
NFSv4.1: shift filelayout_free_lseg
NFSv4.1: pull out code from nfs_commit_release
NFSv4.1: pull error handling out of nfs_commit_list
NFSv4.1: add callback to nfs4_commit_done
NFSv4.1: rearrange nfs_commit_rpcsetup
NFSv4.1: don't send COMMIT to ds for data sync writes
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (43 commits)
ext4: fix a BUG in mb_mark_used during trim.
ext4: unused variables cleanup in fs/ext4/extents.c
ext4: remove redundant set_buffer_mapped() in ext4_da_get_block_prep()
ext4: add more tracepoints and use dev_t in the trace buffer
ext4: don't kfree uninitialized s_group_info members
ext4: add missing space in printk's in __ext4_grp_locked_error()
ext4: add FITRIM to compat_ioctl.
ext4: handle errors in ext4_clear_blocks()
ext4: unify the ext4_handle_release_buffer() api
ext4: handle errors in ext4_rename
jbd2: add COW fields to struct jbd2_journal_handle
jbd2: add the b_cow_tid field to journal_head struct
ext4: Initialize fsync transaction ids in ext4_new_inode()
ext4: Use single thread to perform DIO unwritten convertion
ext4: optimize ext4_bio_write_page() when no extent conversion is needed
ext4: skip orphan cleanup if fs has unknown ROCOMPAT features
ext4: use the nblocks arg to ext4_truncate_restart_trans()
ext4: fix missing iput of root inode for some mount error paths
ext4: make FIEMAP and delayed allocation play well together
ext4: suppress verbose debugging information if malloc-debug is off
Fi up conflicts in fs/ext4/super.c due to workqueue changes
* 'for-linus' of git://git.kernel.dk/linux-2.6-block:
block: fix issue with calling blk_stop_queue() from the request_fn handler
block: fix bug with inserting flush requests as sort/merge
When the queue work handler was converted to delayed work, the
stopping was inadvertently made sync as well. Change this back
to being async stop, using __cancel_delayed_work() instead of
cancel_delayed_work().
Reported-by: Jeremy Fitzhardinge <jeremy@goop.org>
Reported-by: Chris Mason <chris.mason@oracle.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
With the introduction of the on-stack plugging, we would assume
that any request being inserted was a normal file system request.
As flush/fua requires a special insert mode, this caused problems.
Fix this up by checking for this in flush_plug_list() and use
the appropriate insert mechanism.
Big thanks goes to Markus Tripplesdorf for tirelessly testing
patches, and to Sergey Senozhatsky for helping find the real
issue.
Reported-by: Markus Tripplesdorf <markus@trippelsdorf.de>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6:
fs: simplify iget & friends
fs: pull inode->i_lock up out of writeback_single_inode
fs: rename inode_lock to inode_hash_lock
fs: move i_wb_list out from under inode_lock
fs: move i_sb_list out from under inode_lock
fs: remove inode_lock from iput_final and prune_icache
fs: Lock the inode LRU list separately
fs: factor inode disposal
fs: protect inode->i_state with inode->i_lock
autofs4: Do not potentially dereference NULL pointer returned by fget() in autofs_dev_ioctl_setpipefd()
autofs4 - remove autofs4_lock
autofs4 - fix d_manage() return on rcu-walk
autofs4 - fix autofs4_expire_indirect() traversal
autofs4 - fix dentry leak in autofs4_expire_direct()
autofs4 - reinstate last used update on access
vfs - check non-mountpoint dentry might block in __follow_mount_rcu()
Fix the following compile failure:
drivers/media/rc/ite-cir.c: In function 'ite_decode_bytes':
drivers/media/rc/ite-cir.c:190: error: implicit declaration of function 'generic_find_next_le_bit'
drivers/media/rc/ite-cir.c:199: error: implicit declaration of function 'generic_find_next_zero_le_bit'
Caused by commit 620a32bba4a2 ("[media] rc: New rc-based ite-cir driver
for several ITE CIRs") interacting with commit c4945b9ed472
("asm-generic: rename generic little-endian bitops functions").
Merge get_new_inode/get_new_inode_fast into iget5_locked/iget_locked
as those were the only callers. Remove the internal ifind/ifind_fast
helpers - ifind_fast only had a single caller, and ifind had two
callers wanting it to do different things. Also clean up the comments
in this area to focus on information important to a developer trying
to use it, instead of overloading them with implementation details.
First thing we do in writeback_single_inode() is take the i_lock and
the last thing we do is drop it. A caller already holds the i_lock,
so pull the i_lock out of writeback_single_inode() to reduce the
round trips on this lock during inode writeback.
Signed-off-by: Dave Chinner <dchinner@redhat.com>
All that remains of the inode_lock is protecting the inode hash list
manipulation and traversals. Rename the inode_lock to
inode_hash_lock to reflect it's actual function.
Protect the inode writeback list with a new global lock
inode_wb_list_lock and use it to protect the list manipulations and
traversals. This lock replaces the inode_lock as the inodes on the
list can be validity checked while holding the inode->i_lock and
hence the inode_lock is no longer needed to protect the list.
Protect the per-sb inode list with a new global lock
inode_sb_list_lock and use it to protect the list manipulations and
Now that inode state changes are protected by the inode->i_lock and
the inode LRU manipulations by the inode_lru_lock, we can remove the
inode_lock from prune_icache and the initial part of iput_final().
instead of using the inode_lock to protect the inode during
iput_final, use the inode->i_lock instead. This protects the inode
against new references being taken while we change the inode state
to I_FREEING, as well as preventing prune_icache from grabbing the
inode while we are manipulating it. Hence we no longer need the
inode_lock in iput_final prior to setting I_FREEING on the inode.
For prune_icache, we no longer need the inode_lock to protect the
LRU list, and the inodes themselves are protected against freeing
races by the inode->i_lock. Hence we can lift the inode_lock from
prune_icache as well.
Introduce the inode_lru_lock to protect the inode_lru list. This
lock is nested inside the inode->i_lock to allow the inode to be
added to the LRU list in iput_final without needing to deal with
lock inversions. This keeps iput_final() clean and neat.
Further, where marking the inode I_FREEING and removing it from the
LRU, move the LRU list manipulation within the inode->i_lock to keep
the list manipulation consistent with iput_final. This also means
that most of the open coded LRU list removal + unused inode
accounting can now use the inode_lru_list_del() wrappers which
cleans the code up further.
However, this locking change means what the LRU traversal in
prune_icache() inverts this lock ordering and needs to use trylock
semantics on the inode->i_lock to avoid deadlocking. In these cases,
if we fail to lock the inode we move it to the back of the LRU to
prevent spinning on it.
We have a couple of places that dispose of inodes. factor the
disposal into evict() to isolate this code and make it simpler to
peel away the inode_lock from the code.
While doing this, change the logic flow in iput_final() to separate
the different cases that need to be handled to make the transitions
the inode goes through more obvious.
Protect inode state transitions and validity checks with the
inode->i_lock. This enables us to make inode state transitions
independently of the inode_lock and is the first step to peeling
This requires that __iget() is done atomically with i_state checks
during list traversals so that we don't race with another thread
marking the inode I_FREEING between the state check and grabbing the
reference.
Also remove the unlock_new_inode() memory barrier optimisation
required to avoid taking the inode_lock when clearing I_NEW.
Simplify the code by simply taking the inode->i_lock around the
state change and wakeup. Because the wakeup is no longer tricky,
remove the wake_up_inode() function and open code the wakeup where
necessary.
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6
* 'slab/urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6:
SLUB: Write to per cpu data when allocating it
slub: Fix debugobjects with lockless fastpath
Commit ddd588b5dd55 ("oom: suppress nodes that are not allowed from
meminfo on oom kill") moved lib/show_mem.o out of lib/lib.a, which
resulted in build warnings on all architectures that implement their own
versions of show_mem():
lib/lib.a(show_mem.o): In function `show_mem':
show_mem.c:(.text+0x1f4): multiple definition of `show_mem'
arch/sparc/mm/built-in.o:(.text+0xd70): first defined here
The fix is to remove __show_mem() and add its argument to show_mem() in
all implementations to prevent this breakage.
Architectures that implement their own show_mem() actually don't do
anything with the argument yet, but they could be made to filter nodes
that aren't allowed in the current context in the future just like the
generic implementation.
Reported-by: James Bottomley <James.Bottomley@hansenpartnership.com>
Suggested-by: Andrew Morton <akpm@linux-foundation.org>
Signed-off-by: David Rientjes <rientjes@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-core-next' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm/vblank: update recently added vbl interface to be more future proof.
drm radeon: Return -EINVAL on wrong pm sysfs access
drm/radeon/kms: fix hardcoded EDID handling
Revert "drm/i915: Don't save/restore hardware status page address register"
drm/i915: Avoid unmapping pages from a NULL address space
drm/i915: Fix use after free within tracepoint
drm/i915: Restore missing command flush before interrupt on BLT ring
drm/i915: Disable pagefaults along execbuffer relocation fast path
drm/i915: Fix computation of pitch for dumb bo creator
drm/i915: report correct render clock frequencies on SNB
drm/i915/dp: Correct the order of deletion for ghost eDP devices
drm/i915: Fix tiling corruption from pipelined fencing
drm/i915: Re-enable self-refresh
drm/i915: Prevent racy removal of request from client list
drm/i915: skip redundant operations whilst enabling pipes and planes
drm/i915: Remove surplus POSTING_READs before wait_for_vblank
drm/radeon/kms: prefer legacy pll algo for tv-out
drm: check for modesetting on modeset ioctls
drm/kernel: vblank wait on crtc > 1
drm: Fix use-after-free in drm_gem_vm_close()
changes LAYOUTGET and GETDEVICEINFO XDR parsing to:
- not use vmap, which doesn't work on incoherent archs
- use xdr_stream parsing for all xdr
Signed-off-by: Weston Andros Adamson <dros@netapp.com>
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
It turns out that the cmpxchg16b emulation has to access vmalloced
percpu memory with interrupts disabled. If the memory has never
been touched before then the fault necessary to establish the
mapping will not to occur and the kernel will fail on boot.
Fix that by reusing the CONFIG_PREEMPT code that writes the
cpu number into a field on every cpu. Writing to the per cpu
area before causes the mapping to be established before we get
to a cmpxchg16b emulation.
Tested-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Christoph Lameter <cl@linux.com>
Signed-off-by: Pekka Enberg <penberg@kernel.org>
Signed-off-by: Andy Adamson <andros@netapp.com>
Test NFS_INO_LAYOUTCOMMIT before kzalloc
Mark inode dirty to retry LAYOUTCOMMIT on kzalloc failure.
Add comments.
On Thu, 24 Mar 2011, Ingo Molnar wrote:
> RIP: 0010:[<ffffffff810570a9>] [<ffffffff810570a9>] get_next_timer_interrupt+0x119/0x260
That's a typical timer crash, but you were unable to debug it with
debugobjects because commit d3f661d6 broke those.
Cc: Christoph Lameter <cl@linux.com>
In fs/autofs4/dev-ioctl.c::autofs_dev_ioctl_setpipefd() we call fget(),
which may return NULL, but we do not explicitly test for that NULL return
so we may end up dereferencing a NULL pointer - bad.
When I originally submitted this patch I had chosen EBUSY as the return
value to use if this happens. Ian Kent was kind enough to explain why that
would most likely be wrong and why EBADF should most likely be used
instead. This version of the patch uses EBADF.
Signed-off-by: Jesper Juhl <jj@chaosbits.net>
Signed-off-by: Ian Kent <raven@themaw.net>
The autofs4_lock introduced by the rcu-walk changes has unnecessarily
broad scope. The locking is better handled by the per-autofs super
block lookup_lock.
The daemon never needs to block and, in the rcu-walk case an error
return isn't used, so always return zero.
The vfs-scale changes changed the traversal used in
autofs4_expire_indirect() from a list to a depth first tree traversal
which isn't right.
There is a missing dput() when returning from autofs4_expire_direct()
when we see that the dentry is already a pending mount.
When direct (and offset) mounts were introduced the the last used
timeout could no longer be updated in ->d_revalidate(). This is
because covered direct mounts would be followed over without calling
the autofs file system. As a result the definition of the busyness
check for all entries was changed to be "actually busy" being an open
file or working directory within the automount. But now we have a call
back in the follow so the last used update on any access can be
re-instated. This requires DCACHE_MANAGE_TRANSIT to always be set.
When following a mount in rcu-walk mode we must check if the incoming dentry
is telling us it may need to block, even if it isn't actually a mountpoint.
When sec=<something> is not presented as a mount option,
we should attempt to determine what security flavor the
server is using.
Signed-off-by: Bryan Schumaker <bjschuma@netapp.com>
A submount may use different security than the parent
mount does. We should figure out what sec flavor the
submount uses at mount time.
This patch adds the nfs4 operation secinfo as a
valid nfs rpc operation.
A later patch will need to perform a lookup using an
alternate client with a different security flavor.
This patch adds support for doing that on NFS v4.
This patch changes nfs4_call_sync() from a macro into a
static inline function. As a macro, the call_sync()
function will not do any type checking and depends
on the sequence arguments always having the same name.
As a function, we get to have type checking and can
rename the arguments if we so choose.
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits)
Documentation/iostats.txt: bit-size reference etc.
cfq-iosched: removing unnecessary think time checking
cfq-iosched: Don't clear queue stats when preempt.
blk-throttle: Reset group slice when limits are changed
blk-cgroup: Only give unaccounted_time under debug
cfq-iosched: Don't set active queue in preempt
block: fix non-atomic access to genhd inflight structures
block: attempt to merge with existing requests on plug flush
block: NULL dereference on error path in __blkdev_get()
cfq-iosched: Don't update group weights when on service tree
fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away
block: Require subsystems to explicitly allocate bio_set integrity mempool
jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging
fs: make fsync_buffers_list() plug
mm: make generic_writepages() use plugging
blk-cgroup: Add unaccounted time to timeslice_used.
block: fixup plugging stubs for !CONFIG_BLOCK
block: remove obsolete comments for blkdev_issue_zeroout.
blktrace: Use rq->cmd_flags directly in blk_add_trace_rq.
Fix up conflicts in fs/{aio.c,super.c}
git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300
* 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/dhowells/linux-2.6-mn10300:
MN10300: gcc 4.6 vs am33 inline assembly
MN10300: Deprecate gdbstub
MN10300: Allow KGDB to use the MN10300 serial ports
MN10300: Emulate single stepping in KGDB on MN10300
MN10300: Generalise kernel debugger kernel halt, reboot or power off hook
KGDB: Notify GDB of machine halt, reboot or power off
MN10300: Use KGDB
MN10300: Create generic kernel debugger hooks
MN10300: Create general kernel debugger cache flushing
MN10300: Introduce a general config option for kernel debugger hooks
MN10300: The icache invalidate functions should disable the icache first
MN10300: gdbstub: Restrict single-stepping to non-preemptable non-SMP configs
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
pstore: cleanups to pstore_dump()
[IA64] New syscalls for 2.6.39
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6
* 'rmobile-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
mmc: Add MMC_PROGRESS_*
mmc, ARM: Rename SuperH Mobile ARM zboot helpers
ARM: mach-shmobile: add coherent DMA mask to CEU camera devices
ARM: mach-shmobile: Dynamic backlight control for Mackerel
* 'sh-latest' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6:
sh: Fix build alloc_thread_info_node function
sh: Fix ptrace hw_breakpoint handling
sh: Fix ptrace fpu state initialisation
sh: Re-enable GENERIC_HARDIRQS_NO_DEPRECATED.
sh: pmb: Use struct syscore_ops instead of sysdevs
sh: Use struct syscore_ops instead of sysdevs
sh: Conver to asm-generic/sizes.h.
sh: wire up sys_syncfs.
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6
* 'usb-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6:
USB: cdc-acm: fix potential null-pointer dereference on disconnect
USB: cdc-acm: fix memory corruption / panic
USB: Fix 'bad dma' problem on WDM device disconnect
usb: wwan: fix compilation without CONFIG_PM_RUNTIME
USB: uss720 fixup refcount position
usb: musb: blackfin: fix typo in new bfin_musb_vbus_status func
usb: musb: blackfin: fix typo in new dev_pm_ops struct
usb: musb: blackfin: fix typo in platform driver name
usb: musb: Fix for merge issue
ehci-hcd: Bug fix: don't set a QH's Halt bit
USB: Do not pass negative length to snoop_urb()
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits)
[media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t
[media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly
[media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE
[media] v4l: soc-camera: Store negotiated buffer settings
[media] rc: interim support for 32-bit NEC-ish scancodes
[media] mceusb: topseed 0x0011 needs gen3 init for tx to work
[media] lirc_zilog: error out if buffer read bytes != chunk size
[media] lirc: silence some compile warnings
[media] hdpvr: use same polling interval as other OS
[media] ir-kbd-i2c: pass device code w/key in hauppauge case
[media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap
[media] remove the old RC_MAP_HAUPPAUGE_NEW RC map
[media] rc/keymaps: Rename Hauppauge table as rc-hauppauge
[media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping
[media] rc-rc5-hauppauge-new: Add support for the old Black RC
[media] rc-rc5-hauppauge-new: Add the old control to the table
[media] rc-winfast: Fix the keycode tables
[media] a800: Fix a few wrong IR key assignments
[media] opera1: Use multimedia keys instead of an app-specific mapping
[media] dw2102: Use multimedia keys instead of an app-specific mapping
Fix up trivial conflicts (remove/modify and some real conflicts) in:
arch/arm/mach-omap2/devices.c
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/dabusb/dabusb.c
drivers/staging/dabusb/dabusb.h
drivers/staging/easycap/easycap_ioctl.c
drivers/staging/usbvideo/usbvideo.c
drivers/staging/usbvideo/vicam.c
* 'for-linus' of git://android.git.kernel.org/kernel/tegra:
ARM: tegra: harmony: initialize the TPS65862 PMIC
ARM: tegra: update defconfig
ARM: tegra: harmony: update PCI-e initialization sequence
ARM: tegra: trimslice: enable MMC/SD slots
ARM: tegra: enable new drivers in defconfig
ARM: tegra: Add Toshiba AC100 support
ARM: tegra: harmony: Set WM8903 gpio_base
ARM: tegra: harmony: I2C-related portions of audio support
ARM: tegra: harmony: register i2c devices
ARM: tegra: seaboard: register i2c devices
ARM: tegra: harmony: Beginnings of audio support
ARM: tegra: create defines for SD-related GPIO names
ARM: tegra: add devices.c entries for audio
* 'devicetree/merge' of git://git.secretlab.ca/git/linux-2.6:
spi/pl022: Add loopback support for the SPI on 5500
spi/omap_mcspi: Fix broken last word xfer
of/flattree: minor cleanups
dt: eliminate OF_NO_DEEP_PROBE and test for NULL match table
dt: protect against NULL matches passed to of_match_node()
dt: Refactor of_platform_bus_probe()
This is my second attempt to make this enum generally available.
The first attempt added MMCIF_PROGRESS_* to include/linux/mmc/sh_mmcif.h.
However this is not sufficiently generic as the enum will be
used by SDHI boot code.
Signed-off-by: Simon Horman <horms@verge.net.au>
Signed-off-by: Paul Mundt <lethal@linux-sh.org>
These headers and helpers will also be used for SDHI boot
so the mmcif name will start to make a lot less sense.
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6
* 'idle-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6:
intel_idle: Rename cpuidle states
