DID_NO_CONNECT is not a nice value to use for pkt alloc failures,
because you can probably retry and IO will become available again.
For the device reset callout, we do not want to set the scsi command
result for the above reason, and because we do not need to set
the scsi_cmd->result in this path. We and other drivers do not set it
for success for example, and we do not set it for other failure.
And scsi-ml does not send every command through this path, and it is
not expecting us to use the scsi_cmnd struct like a cmd coming thruogh
queuecommand. I think it is more for storage in case we need a cmd
struct for a tmf and to give us certain params like the LUN.
Patch was made over scsi-misc today.
Signed-off-by: Mike Christie <michaelc@cs.wisc.edu>
Signed-off-by: Robert Love <robert.w.love@intel.com>
Signed-off-by: James Bottomley <James.Bottomley@suse.de>
We are still using netdev->dev_addr to generate lport's WWNN/WWPN even if the
LLD has support for NETDEV_HW_ADDR_T_SAN. Instead, we should just use the
fip->ctl_src_addr, which is the NETDEV_HW_ADDR_T_SAN if LLD supports it or it
is just the netdev->dev_addr if it does not.
Signed-off-by: Yi Zou <yi.zou@intel.com>
Make sure we are get the SAN MAC address from the real netdev if the input
netdev is a VLAN device.
This was fixed before in 7a7f0c7 but it's introduced again recently.
Add initialization of .bsg_request in the scsi_transport_fc
template so that fcping works.
Signed-off-by: Joe Eykholt <jeykholt@cisco.com>
Customers and certification tests have pointed out that we don't
show up on the switch management software as an initiator.
On some MDS switches 'show fcns database' command shows libfc
initiators as 'fcp' not 'fcp:init' like other initiators.
On others switches, I think the switch gets the features by doing a PRLI,
but it may be only certain models or under certain configurations.
Fix this by registering our FC4 features with the RFF_ID CT request
after local port login and after the RFT_ID.
Use libfcoe as a common FIP implementation with fcoe.
FIP or non-FIP mode is fully automatic if the firmware
supports and enables it.
Even if FIP is not supported, this uses libfcoe for the non-FIP
handling of FLOGI and its response.
Use the new lport_set_port_id() notification to capture
successful FLOGI responses and port_id resets.
While transitioning between Ethernet and FC mode, all rx and
tx FC frames are queued. In Ethernet mode, all frames are
passed to the exchange manager to capture FLOGI responses.
Change to set data_src_addr to the ctl_src_addr whenever it
would have previously been zero because we're not logged in.
This seems safer so we'll never send a frame with a 0 source MAC.
This also eliminates a special case for sending FLOGI frames.
There was a locking problem where the fip->lock was held during
the call to update_mac(). The rtnl_lock() must be taken before
the fip->lock, not the other way around. This fixes that.
Now that fcoe_ctlr_recv_flog() is called only from the response handler
to a FLOGI request, some checking can be eliminated. Instead of calling
update_mac(), just fill in the granted_mac address for the passed-in
frame (skb).
Eliminate the passed-in source MAC address since it is also in the skb.
Also, in fcoe, call fcoe_set_src_mac() directly instead of going thru
the fip function pointer. This will generate less code.
Then, since fip isn't needed for LOGO response, use lport as the arg.
The libfc link up/down messages don't indicate which port is changing.
The Port ID will often be 0.
This is to notify the LLD when an FC_ID is assigned to the local port.
The fnic driver needs to push the assigned FC_ID to firmware.
It currently does this by intercepting the FLOGI responses, and
in order to make that code more common with FIP and NPIV, it
makes more sense to wait until the local port has completely
handled the FLOGI or FDISC response. Also, when we fix
point-to-point FC_ID assignment, we'll need this callback as well.
Add a call to the libfc template, which is called whenever
the local port FC_ID is being assigned. It defaults to
fc_lport_set_fid(), supplied by libfc.
As additional benefit of this function, the LLD may determine
the MAC address that caused the change by looking at the received frame.
We also print the assigned port ID as long as it isn't 0.
Setting port ID to 0 happens often in reset while retrying FLOGI,
and would be uninteresting. This replaces the previous message
which didn't identify the host adapter instance.
patch v2 note: changed one word in a comment. "intercepted" -> "provided".
Local port debug messages were using fc_els_resp_type() which showed
all CT responses as rejects.
Handle CT responses correctly based by inspecting fh_type.
I decided not to rename the function to keep the patch smaller.
We could call it just fc_resp_type() or fc_elsct_resp_type().
The strncpy for RSPN_ID and RSNN_NN requests was padding
past the allocated frame size.
Get the string length before filling in the ct header.
The code that filled in the name server RNN_ID (register node name)
request had somehow gotten a line in it from the RFT_ID code
which copies 32 bytes of data over the relatively short payload.
This caused some corruption and hangs.
Simply deleted the extraneous line.
This patch adds a check to fail gracefully when the netdevice
is bonded. Previously, the error was detected but the stack
would continue to load. This resulted in a partially enabled
fcoe intance and errors when the fcoe instance was destroy.
Signed-off-by: John Fastabend <john.r.fastabend@intel.com>
Remove the two extra function decalartions in fcoe.c.
If link is up, but no FCF is selected, don't send any ELS frames.
This came up when an fnic received a multicast advertisement but
no solitited advertisments, so no FCF was selected. It tried
to send FLOGIs anyway.
The fnic driver with FIP is reporting link up, even though it's down.
When the interface is shut down by the switch, we receive a clear
virtual link, and set the state reported to libfc as down, although
we still report it up. Clearly wrong. That causes the subsequent
link down event not to be reported, and /sys shows the host "Online".
Currently, in FIP mode, if an FCF times out, then link to libfc
is reported as down, to stop FLOGIs. That interferes with the LLD
link down being reported.
Users really need to know the physical link information, to diagnose
cabling issues, so physical link status should be reported to libfc.
If the selected FCF needs to be reported, that should be done
separately, in a later patch.
FIP's fcoe_ctlr_recv() function was previously only called from
the soft IRQ in FCoE. It's not performance critical and is more
convenient for some drivers to call it from the IRQ level. Just
Change to use skb_queue()/dequeue() which uses spinlock_irqsave
instead of separate locking with _bh locks.
Use scsi host number to identify debug messages.
Previously, no instance information was given, so if multiple
ports were active, it became confusing.
Allow FIP to be disabled by the driver for devices
that want to use libfcoe in non-FIP mode.
The driver merely sets the fcoe_ctlr mode to the state which
should be entered when the link comes up. The default is auto.
No change is needed for fcoe.c which uses auto mode.
Adds last_can_queue_ramp_down_time and updates this on every
ramp down. If last_can_queue_ramp_down_time is not zero then
do ramp up on any IO completion in added fc_fcp_can_queue_ramp_up.
Reset last_can_queue_ramp_down_time to zero once can_queue
is ramped up to added max_can_queue limit, this is to avoid any
more ramp up attempts on subsequent IO completion.
The ramp down and up are skipped for FC_CAN_QUEUE_PERIOD
to avoid infrequent changes to can_queue, this required
keeping track of ramp up time also in last_can_queue_ramp_up_time.
Adds code to ramp down can_queue if lp->qfull is set, with added
new ramp up code the can_queue will be increased after
FC_CAN_QUEUE_PERIOD, therefore it is safe to do ramp down
without fsp in this case and will avoid thrash. This required
fc_fcp_can_queue_ramp_down locking change so that it can be
called with Scsi_Host lock held.
Removes si->throttled and fsp state FC_SRB_NOMEM, not needed with
added ramp up code.
Signed-off-by: Vasu Dev <vasu.dev@intel.com>
Currently can_queue is reduced only if frame alloc fails
during fc_fcp_send_data but frame alloc can fail at several
other places in FCP data path and can_queue needs to be
reduced for any FCP frame alloc failure.
This patch adds fc_fcp_frame_alloc for all FCP frame allocations
and if fc_frame_alloc fails in fc_fcp_frame_alloc then reduce
can_queue in fc_fcp_frame_alloc, this will reduce can_queue for
all FCP frame alloc failures.
This required moving fc_fcp_reduce_can_queue up, to build without
adding its prototype. Also renamed fc_fcp_reduce_can_queue to
fc_fcp_can_queue_ramp_down.
Removes fc_fcp_reduce_can_queue calling from fc_fcp_recv since
not needed with added fc_fcp_frame_alloc reducing can_queue.
Cleans up frame allocation APIs to have just single fc_frame_alloc API.
Removes _fc_frame_alloc, renames __fc_frame_alloc to _fc_frame_alloc.
Modifies fc_fcp_send_data for removed _fc_frame_alloc, fc_fcp_send_data
was the only user of removed _fc_frame_alloc.
Also Adds check in fc_frame_alloc to do mod by 4 for only non-zero
len value.
This patch is prep work to fix can_queue reducing in next patch.
Single fc_frame_alloc API helps in fixing can_queue reducing in
next patch.
Added kernel-doc comment blocks to all structures and functions.
Renamed fc_lport instances rom lp to lport to be inline with our
naming convention.
Renamed all misnamed net_device instances to netdev to be inline
with our naming convention.
Ensures that there are kernel-doc style comments for all
routines and structures.
There were also a few instances of fc_lport's named 'lp'
which were switched to 'lport' as per the libfc/libfcoe/fcoe
naming convention.
Also, emacs 'indent-region' and 'tabify' were ran on libfcoe.c.
This patch makes a variety of cleanup changes to all libfc files.
This patch adds kernel-doc headers to all functions lacking them
and attempts to better format existing headers. It also add kernel-doc
headers to structures.
This patch ensures that the current naming conventions for local ports,
remote ports and remote port private data is upheld in the following
manner.
struct instance (i.e. variable name)
fc_lport lport
fc_rport rport
fc_rport_libfc_priv rpriv
fc_rport_priv rdata
I also renamed dns_rp and ptp_rp to dns_rdata and ptp_rdata
respectively.
I used emacs 'indent-region' and 'tabify' on all libfc files
to correct spacing alignments.
I feel sorry for anyone attempting to review this patch.
This is the Open-FCoE implementation of the FC
passthrough support via bsg interface.
Passthrough support is added to both N_Ports and
VN_Ports.
Signed-off-by: Steve Ma <steve.ma@intel.com>
When handling the multi-frame responses of fc pass-thru requests,
a code segment similar to fc_fcp_recv_data (routine to receive
inbound SCSI data) is used in the response handler. This patch
is to add a routine, called fc_copy_buffer_to_sglist(), to handle
the common function of copying data from a buffer to a scatter-
gather list in order to avoid code duplication.
Export fc_els.h, fc_fs.h, fc_gs.h and fc_ns.h so that they
may be used by applications.
This will be needed for FC Passthrough applications like fcping,
but could be used by other applications.
Fix to include <linux/types.h> to exported files provided by
Chris Leech <christopher.leech@intel.com>.
Allow a vport specific string to be appended to the port symbolic
name. The new symbolic name is sent to the name server after it
is set.
This currently messes with libhbalinux, which is looking for
the fcoe "fcoe <ver> over <ethX>" string and expects whatever
comes after the "over" to be a network interface name only.
Adds an EXPORT_SYMBOL to libfc for fc_frame_alloc_fill, which is
needed to allow fcoe to allocate a frame of variable length for
the RSPN request.
Signed-off-by: Chris Leech <christopher.leech@intel.com>
They all do the same thing, so combine them into a single function.
Register the fc_host symbolic name as the symbolic port name
with the fabric name server.
Register the fc_host symbolic name as the symbolic node name
One could interpret FC-GS-5 to say that an explicit RNN_ID is required
before RSNN_NN is allowed to succeed, which is why RNN_ID was not obsoleted
along with RPN_ID acording to this document:
ftp://ftp.t11.org/t11/member/fc/gs-5/05-546v2.pdf
RPN_ID has been obsolete per FC-GS-5 for several years. The port name is
registered implicitly as part of FLOGI, and it is undesirable for ports to
change a registered port name using RPN_ID while logged into the fabric.
Add NPIV vport create and destroy handlers and register them with the
FC transport.
Right now it's exactly the same as the physical port template,
and there is no way to create a port on anything other than the
netdev. When the vport_create entry point gets hooked up it will
create lports on top of vport devices, which will use this.
Rename scsi_transport_fcoe_sw to fcoe_transport_template to be more
clear with naming now that there are two templates.
The FIP code in libfcoe needed several changes to support NPIV
1) dst_src_addr needs to be managed per-n_port-ID for FPMA fabrics with NPIV
enabled. Managing the MAC address is now handled in fcoe, with some slight
changes to update_mac() and a new get_src_addr() function pointer.
2) The libfc elsct_send() hook is used to setup FCoE specific response
handlers for FIP encapsulated ELS exchanges. This lets the FCoE specific
handling know which VN_Port the exchange is for, and doesn't require
tracking OX_IDs. It might be possible to roll back to the full FIP frame
in these, but for now I've just stashed the contents of the MAC address
descriptor in the skb context block for later use. Also, because
fcoe_elsct_send() just passes control on to fc_elsct_send(), all transmits
still come through the normal frame_send() path.
3) The NPIV changes added a mutex hold in the keep alive sending, the lport
mutex is protecting the vport list. We can't take a mutex from a timer,
so move the FIP keep alive logic to the link work struct.
Add FDISC ELS handling to libfc and libfcoe, treat it the same as FLOGI where
appropriate.
Add checking for NPIV support in the FLOGI LS_ACC service parameters.
NPIV vports are managed in libfc by changing their virtual link state
when the parent N_Ports internal state changes. The vport link is only
online when the N_Port is in a ready state (logged into the fabric).
vport_state is updated as needed in this patch as well, currently the states
LINKDOWN, INITIALIZING, ACTIVE, DSIABLED, and NO_FABRIC_SUPP are used.
This also changes the fc_host port_state handling to differentiate between
LINKDOWN and OFFLINE.
Adds a function to create a new VN_Port instances, which share the EM
list with the N_Port, VN_Port lookup by fabric ID when responding to a new
request (otherwise the exchange lookup from the N_Ports EM list is trusted to
return an exchange with a cached lport value for the correct VN_Port),
a pointer to a fc_vport structure for VN_Ports, and flags to indicate if an
N_Port supports NPIV and if the switch/fabric allows it.
allocation
I'd like to keep basic initialization together with allocation, which means
this can't just be a tail-call to scsi_host_alloc.
This is needed to create a generic libfc host allocation routine for NPIV
VN_Ports, which will share the exchange ID space (through sharing exchange
manager structures) with the parent lport. In order to clone the exchange
manager list when the lport is allocated, the list head must be initialized
earlier.
Also, update fnic to use the libfc_host_alloc so that later changes do not break
it. (contribution by Joe Eykholt)
These routines are for the libfc kernel module and should be in
the libfc .c file.
Moving the libfc __init routine into fc_libfc.c caused the creation
of the fc_setup_fcp() and fc_destroy_fcp() routines so that
scsi_pkt_cachep was not exposed outside of fc_fcp.c.
include/scsi/libfc.h is currently loaded with common code
shared between libfc's sub-modules as well as shared between
libfc and fcoe. Previous patches attempted to move out
non-common code. This patch creates two files for common
libfc routines that will not be shared with fcoe, fnic or
any other LLDs.
This function is never used, let's remove it.
This patch moves all non-common routines and function prototypes
out of libfc.h and into the appropriate .c files. It makes these
routines 'static' when necessary and removes any unnecessary EXPORT_SYMBOL
statements.
A result of moving the fc_exch_seq_send, fc_seq_els_rsp_send, fc_exch_alloc
and fc_seq_start_next prototypes out of libfc.h is that they were no longer
being imported into fc_exch.c when libfc.h was included. This caused errors
where routines in fc_exch.c were looking for undefined symbols. To fix this
this patch reorganizes fc_seq_alloc, fc_seq_start_next and
fc_seq_start_next_locked. This move also made it so that
fc_seq_start_next_locked did not need to be prototyped at the top of
fc_exch.c.
The maximum number of LUNs was far too low. This value is
what most other FC HBAs are using.
The OS interrupt vectors were getting allocated before the interrupt
resources were mapped from hardware. For Legacy interrupts, since
they are shared with other devices, as soon as an interrupt is
registered with the OS, it can fire while the fnic isr resource is
still unmapped. This can cause crash because of access to unmapped resources.
For MSIX and MSI, since interrupts are not shared with other devices,
this problem didnt happen, because the interrupt is enabled as the last
step before returning from _probe. For Legacy however, since the
interrupt is shared, the handler can be called as soon as it is registered.
Solution is to register interrupt handlers with OS as last step before
enabling device interrupts.
Signed-off-by: Abhijeet Joglekar <abjoglek@cisco.com>
Move the duplicated code from FC LLDs to SCSI FC transport class.
Acked-by: James Smart <james.smart@emulex.com>
Acked-by: Giridhar Malavali <giridhar.malavali@qlogic.com>
Acked-by: Abhijeet Joglekar <abjoglek@cisco.com>
Signed-off-by: Christof Schmitt <christof.schmitt@de.ibm.com>
