In order to be able to detect the case that a filesystem is mounted
with an old kernel, add a uuid-tree-gen field like the free space
cache is doing it. It is part of the super block and written with
each commit. Old kernels do not know this field and don't update it.
Signed-off-by: Stefan Behrens <sbehrens@giantdisaster.de>
Signed-off-by: Josef Bacik <jbacik@fusionio.com>
Signed-off-by: Chris Mason <chris.mason@fusionio.com>
When the UUID tree is initially created, a task is spawned that
walks through the root tree. For each found subvolume root_item,
the uuid and received_uuid entries in the UUID tree are added.
This is such a quick operation so that in case somebody wants
to unmount the filesystem while the task is still running, the
unmount is delayed until the UUID tree building task is finished.
When a new subvolume or snapshot is created, a new UUID item is added
to the UUID tree. Such items are removed when the subvolume is deleted.
The ioctl to set the received subvolume UUID is also touched and will
now also add this received UUID into the UUID tree together with the
ID of the subvolume. The latter is also done when read-only snapshots
are created which inherit all the send/receive information from the
parent subvolume.
User mode programs use the BTRFS_IOC_TREE_SEARCH ioctl to search and
read in the UUID tree.
This tree is not created by mkfs.btrfs. Therefore when a filesystem
is mounted writable and the UUID tree does not exist, this tree is
created if required. The tree is also added to the fs_info structure
and initialized, but this commit does not yet read or write UUID tree
elements.
This commit adds support to print UUID tree elements to print-tree.c.
Mapping UUIDs to subvolume IDs is an operation with a high effort
today. Today, the algorithm even has quadratic effort (based on the
number of existing subvolumes), which means, that it takes minutes
to send/receive a single subvolume if 10,000 subvolumes exist. But
even linear effort would be too much since it is a waste. And these
data structures to allow mapping UUIDs to subvolume IDs are created
every time a btrfs send/receive instance is started.
It is much more efficient to maintain a searchable persistent data
structure in the filesystem, one that is updated whenever a
subvolume/snapshot is created and deleted, and when the received
subvolume UUID is set by the btrfs-receive tool.
Therefore kernel code is added with this commit that is able to
maintain data structures in the filesystem that allow to quickly
search for a given UUID and to retrieve data that is assigned to
this UUID, like which subvolume ID is related to this UUID.
This commit adds a new tree to hold UUID-to-data mapping items. The
key of the items is the full UUID plus the key type BTRFS_UUID_KEY.
Multiple data blocks can be stored for a given UUID, a type/length/
value scheme is used.
Now follows the lengthy justification, why a new tree was added
instead of using the existing root tree:
The first approach was to not create another tree that holds UUID
items. Instead, the items should just go into the top root tree.
Unfortunately this confused the algorithm to assign the objectid
of subvolumes and snapshots. The reason is that
btrfs_find_free_objectid() calls btrfs_find_highest_objectid() for
the first created subvol or snapshot after mounting a filesystem,
and this function simply searches for the largest used objectid in
the root tree keys to pick the next objectid to assign. Of course,
the UUID keys have always been the ones with the highest offset
value, and the next assigned subvol ID was wastefully huge.
To use any other existing tree did not look proper. To apply a
workaround such as setting the objectid to zero in the UUID item
key and to implement collision handling would either add
limitations (in case of a btrfs_extend_item() approach to handle
the collisions) or a lot of complexity and source code (in case a
key would be looked up that is free of collisions). Adding new code
that introduces limitations is not good, and adding code that is
complex and lengthy for no good reason is also not good. That's the
justification why a completely new tree was introduced.
Cc: Josef Bacik <jbacik@fusionio.com>
Cc: Chris Mason <chris.mason@fusionio.com>
Signed-off-by: Sergei Trofimovich <slyfox@gentoo.org>
make C=2 fs/btrfs/ CF=-D__CHECK_ENDIAN__
I tried to filter out the warnings for which patches have already
been sent to the mailing list, pending for inclusion in btrfs-next.
All these changes should be obviously safe.
If the inode ref key was not found and the current leaf slot
was 0 (first item in the leaf) the code would always return
-ENOENT. This was not correct because the desired inode ref
item might be the last item in the previous leaf.
Signed-off-by: Filipe David Borba Manana <fdmanana@gmail.com>
If the path doesn't fit in the input buffer, return ENAMETOOLONG
instead of returning with a success code (0) and a partially
filled and right justified buffer.
Also removed useless buffer pointer check outside the while loop.
We have checked 'quota_root' with qgroup_ioctl_lock held before,So
here the check is reduplicate, remove it.
Signed-off-by: Wang Shilong <wangsl.fnst@cn.fujitsu.com>
Reviewed-by: Miao Xie <miaox@cn.fujitsu.com>
Reviewed-by: Arne Jansen <sensille@gmx.net>
btrfs_free_qgroup_config() is not only called by open/close_ctree(),but
also btrfs_disable_quota().And for btrfs_disable_quota(),we have set
'quota_root' to be null before calling btrfs_free_qgroup_config(),so it
is safe to cleanup in-memory structures without lock held.
When disabling quota, we should clear out list 'dirty_qgroups',otherwise,
we will get oops if enabling quota again. Fix this by abstracting similar
code from del_qgroup_rb().
If you are sending a snapshot and specifying a parent snapshot we will walk the
trees and figure out where they differ and send the differences only. The way
we check for differences are if the leaves aren't the same and if the keys are
not the same within the leaves. So if neither leaf is the same (ie the leaf has
been cow'ed from the parent snapshot) we walk each item in the send root and
check it against the parent root. If the items match exactly then we don't do
anything. This doesn't quite work for inode refs, since they will just have the
name and the parent objectid. If you move the file from a directory and then
remove that directory and re-create a directory with the same inode number as
the old directory and then move that file back into that directory we will
assume that nothing changed and you will get errors when you try to receive.
In order to fix this we need to do extra checking to see if the inode ref really
is the same or not. So do this by passing down BTRFS_COMPARE_TREE_SAME if the
items match. Then if the key type is an inode ref we can do some extra
checking, otherwise we just keep processing. The extra checking is to look up
the generation of the directory in the parent volume and compare it to the
generation of the send volume. If they match then they are the same directory
and we are good to go. If they don't we have to add them to the changed refs
list.
This means we have to track the generation of the ref we're trying to lookup
when we iterate all the refs for a particular inode. So in the case of looking
for new refs we have to get the generation from the parent volume, and in the
case of looking for deleted refs we have to get the generation from the send
volume to compare with.
There was also the issue of using a ulist to keep track of the directories we
needed to check. Because we can get a deleted ref and a new ref for the same
inode number the ulist won't work since it indexes based on the value. So
instead just dup any directory ref we find and add it to a local list, and then
process that list as normal and do away with using a ulist for this altogether.
Before we would fail all of the tests in the far-progs that related to moving
directories (test group 32). With this patch we now pass these tests, and all
of the tests in the far-progs send testing suite. Thanks,
The plan is to have a bunch of unit tests that run when btrfs is loaded when you
build with the appropriate config option. My ultimate goal is to have a test
for every non-static function we have, but at first I'm going to focus on the
things that cause us the most problems. To start out with this just adds a
tests/ directory and moves the existing free space cache tests into that
directory and sets up all of the infrastructure. Thanks,
I noticed while looking at a deadlock that we are always starting a transaction
in cow_file_range(). This isn't really needed since we only need a transaction
if we are doing an inline extent, or if the allocator needs to allocate a chunk.
So push down all the transaction start stuff to be closer to where we actually
need a transaction in all of these cases. This will hopefully reduce our write
latency when we are committing often. Thanks,
I added a patch where we started taking the ordered operations mutex when we
waited on ordered extents. We need this because we splice the list and process
it, so if a flusher came in during this scenario it would think the list was
empty and we'd usually get an early ENOSPC. The problem with this is that this
lock is used in transaction committing. So we end up with something like this
Transaction commit
-> wait on writers
Delalloc flusher
-> run_ordered_operations (holds mutex)
->wait for filemap-flush to do its thing
flush task
-> cow_file_range
->wait on btrfs_join_transaction because we're commiting
some other task
-> commit_transaction because we notice trans->transaction->flush is set
-> run_ordered_operations (hang on mutex)
We need to disentangle the ordered operations flushing from the delalloc
flushing, since they are separate things. This solves the deadlock issue I was
seeing. Thanks,
There are several places where we BUG_ON() if we fail to remove the orphan items
and such, which is not ok, so remove those and either abort or just carry on.
This also fixes a problem where if we couldn't start a transaction we wouldn't
actually remove the orphan item reserve for the inode. Thanks,
Eric pointed out that btrfs will happily allow you to delete the default subvol.
This is a problem obviously since the next time you go to mount the file system
it will freak out because it can't find the root. Fix this by adding a check to
see if our default subvol points to the subvol we are trying to delete, and if
it does not allowing it to happen. Thanks,
We have logic to see if we've already created a parent directory by check to see
if an inode inside of that directory has a lower inode number than the one we
are currently processing. The logic is that if there is a lower inode number
then we would have had to made sure the directory was created at that previous
point. The problem is that subvols inode numbers count from the lowest objectid
in the root tree, which may be less than our current progress. So just skip if
our dir item key is a root item. This fixes the original test and the xfstest
version I made that added an extra subvol create. Thanks,
Reported-by: Emil Karlson <jekarlson@gmail.com>
This patch adds an ioctl, BTRFS_IOC_FILE_EXTENT_SAME which will try to
de-duplicate a list of extents across a range of files.
Internally, the ioctl re-uses code from the clone ioctl. This avoids
rewriting a large chunk of extent handling code.
Userspace passes in an array of file, offset pairs along with a length
argument. The ioctl will then (for each dedupe) do a byte-by-byte comparison
of the user data before deduping the extent. Status and number of bytes
deduped are returned for each operation.
Signed-off-by: Mark Fasheh <mfasheh@suse.de>
Reviewed-by: Zach Brown <zab@redhat.com>
We want this for btrfs_extent_same. Basically readpage and friends do their
own extent locking but for the purposes of dedupe, we want to have both
files locked down across a set of readpage operations (so that we can
compare data). Introduce this variant and a flag which can be set for
extent_read_full_page() to indicate that we are already locked.
Partial credit for this patch goes to Gabriel de Perthuis <g2p.code@gmail.com>
as I have included a fix from him to the original patch which avoids a
deadlock on compressed extents.
There's some 250+ lines here that are easily encapsulated into their own
function. I don't change how anything works here, just create and document
the new btrfs_clone() function from btrfs_ioctl_clone() code.
The range locking in btrfs_ioctl_clone is trivially broken out into it's own
function. This reduces the complexity of btrfs_ioctl_clone() by a small bit
and makes that locking code available to future functions in
fs/btrfs/ioctl.c
In extent-tree.c:do_chunk_alloc(), early on we returned 0 (success)
when the target space was full and when chunk allocation is needed.
However, later on in that same function we return ENOSPC if
btrfs_alloc_chunk() fails (and chunk allocation was needed) and
set the space's full flag.
This was inconsistent, as -ENOSPC should be returned if the space
is full and a chunk allocation needs to performed. If the space is
full but no chunk allocation is needed, just return 0 (success).
tree-log.c was ignoring the return value from btrfs_run_delayed_items()
in several places.
In tree-log.c:replay_one_name(), if memory allocation for
the name fails, ensure we iput the dir inode we got before
before we return.
The rule originally comes from nocow writing, but snapshot-aware
defrag is a different case, the extent has been writen and we're
not going to change the extent but add a reference on the data.
So we're able to allow such compressed extents to be merged into
one bigger extent if they're pointing to the same data.
Signed-off-by: Liu Bo <bo.li.liu@oracle.com>
I'ts hardcoded to 30 seconds which is fine for most users. Higher values
defer data being synced to permanent storage with obvious consequences
when the system crashes. The upper bound is not forced, but a warning is
printed if it's more than 300 seconds (5 minutes).
Signed-off-by: David Sterba <dsterba@suse.cz>
There is no reason we can't just set the path to blocking and then do normal
GFP_NOFS allocations for these extent buffers. Thanks,
We can get ENOMEM trying to allocate dummy bufs for the rewind operation of the
tree mod log. Instead of BUG_ON()'ing in this case pass up ENOMEM. I looked
back through the callers and I'm pretty sure I got everybody who did BUG_ON(ret)
in this path. Thanks,
When doing a send with a parent subvol we will check to see if the file we are
acting on is being overwritten and move it if we think it may be needed further
down the line during the send. We check this by checking its directory and
making sure it existed in the parent and making sure the file existed in the
parent. The problem with this check is that if we create a directory and a file
in that directory, and then snapshot, and then remove and re-create that same
directory and file with different inode numbers and then try to snapshot and
send with the original parent we will try and save the original file inside of
that directory. This is a problem because during the receive we move the
directory out of the way because it is a completely new inode, which makes us
unable to find the old file inside of the directory when we try to move that out
of the way for the overwrite. We fix this by checking the parent directory of
the inode we think we are overwriting. If the parent directory generation in
the send root != the parent directory generation in the parent root then we know
it is a completely new directory and we need not bother with moving the file out
of the way because it would have been completely destroyed. This fixes bz
60673. Thanks,
Alex Lyakas reported a bug where wait_block_group_cache_progress() would wait
forever if a drive failed. This is because we just bail out if there is an
error while trying to cache a block group, we don't update anybody who may be
waiting. So this introduces a new enum for the cache state in case of error and
makes everybody bail out if we have an error. Alex tested and verified this
patch fixed his problem. This fixes bz 59431. Thanks,
If we bail out when the stripe alloc fails, we need to undo the
earlier allocation of raid_map.
Signed-off-by: Dave Jones <davej@redhat.com>
Reviewed-by: Jan Schmidt <list.btrfs@jan-o-sch.net>
After reading all device items from the chunk tree, don't
exit the loop and then navigate down the tree again to find
the chunk items. Instead just read all device items and
chunk items with a single tree search. This is possible
because all device items are found before any chunk item in
the chunks tree.
There is no reason for this sort of jackassery. Thanks,
Previously we only added blocks to the list to have their backrefs checked if
the level of the block is right above the one we are searching for. This is
because we want to make sure we don't add the entire path up to the root to the
lists to make sure we process things one at a time. This assumes that if any
blocks in the path to the root are going to be not checked (shared in other
words) then they will be in the level right above the current block on up. This
isn't quite right though since we can have blocks higher up the list that are
shared because they are attached to a reloc root. But we won't add this block
to be checked and then later on we will BUG_ON(!upper->checked). So instead
keep track of wether or not we've queued a block to be checked in this current
search, and if we haven't go ahead and queue it to be checked. This patch fixed
the panic I was seeing where we BUG_ON(!upper->checked). Thanks,
If our item isn't big enough to have an actual inline item when we have skinny
metadata enabled just return 1 in find_inline_backref so we can move on to the
next item. This probably wasn't causing a problem since we check the values of
ptr and end properly, but just in case this will keep us from doing extra work.
Thanks,
First of all we no longer set EXTENT_DIRTY when we dirty an extent so this patch
removes the clearing of EXTENT_DIRTY since it confuses me. This patch also adds
clearing EXTENT_DEFRAG and also doing EXTENT_DO_ACCOUNTING when we have errors.
This is because if we are clearing delalloc without adding an ordered extent
then we need to make sure the enospc handling stuff is accounted for. Also if
this range was DEFRAG we need to make sure that bit is cleared so we dont leak
it. Thanks,
This patch removes the io_tree argument for extent_clear_unlock_delalloc since
we always use &BTRFS_I(inode)->io_tree, and it separates out the extent tree
operations from the page operations. This way we just pass in the extent bits
we want to clear and then pass in the operations we want done to the pages.
This is because I'm going to fix what extent bits we clear in some cases and
rather than add a bunch of new flags we'll just use the actual extent bits we
want to clear. Thanks,
Signed-off-by: Anand Jain <anand.jain@oracle.com>
When we read several pages at once, we needn't get the extent map object
every time we deal with a page, and we can cache the extent map object.
So, we can reduce the search time of the extent map, and besides that, we
also can reduce the lock contention of the extent map tree.
Signed-off-by: Miao Xie <miaox@cn.fujitsu.com>
In the past, we cached the checksum value in the extent state object, so we
had to split the extent state object by the block size, or we had no space
to keep this checksum value. But it increased the lock contention of the
extent state tree.
Now we removed this limit by caching the checksum into the bio object, so
it is unnecessary to do the extent state operations by the block size, we
can do it in batches, in this way, we can reduce the lock contention of
the extent state tree.
Before applying this patch, we set the uptodate flag and unlock the extent
by the page size, it is unnecessary, we can do it in batches, it can reduce
the lock contention of the extent state tree.
Before applying this patch, we cached the csum value into the extent state
tree when reading some data from the disk, this operation increased the lock
contention of the state tree.
Now, we just store the csum value into the bio structure or other unshared
structure, so we can reduce the lock contention.
This patch add some branch prediction hints into the end IO function
of the read page, it reduced the percentage of the branch misses from
5.5% to 4.9%.
