This adds 'ecc_strength' to struct mtd_info. This stores the maximum number of
bit errors that can be corrected in one writesize region.
For consistency with the nand code, 'strength' is similiarly added to struct
nand_ecc_ctrl. This stores the maximum number of bit errors that can be
corrected in one ecc step.
Signed-off-by: Mike Dunn <mikedunn@newsguy.com>
Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com>
The read function was so far requiring the reads to be aligned on page
boundaries, and be page length multiples in size. Relieve these
constraints to ease the userspace ubifs programs runs, which read ubifs
headers of 64 bytes.
Artem: squashed a later fix from Robert Jarzmik into this patch.
Signed-off-by: Robert Jarzmik <robert.jarzmik@free.fr>
Adds power management code with fine granularity. Every flash control
command is enclosed by runtime_put()/get()s. To make sure that no
overhead is generated by too frequent power state switches, a quality of
service request is issued.
Signed-off-by: Bastian Hecht <hechtb@gmail.com>
The first 3 arguments of 'mtd_device_parse_register()' are pointers,
but many callers pass '0' instead of 'NULL'. Fix this globally. Thanks
to coccinelle for making it easy to do with the following semantic patch:
expression mtd, types, parser_data, parts, nr_parts;
-mtd_device_parse_register(mtd, 0, parser_data, parts, nr_parts)
+mtd_device_parse_register(mtd, NULL, parser_data, parts, nr_parts)
-mtd_device_parse_register(mtd, types, 0, parts, nr_parts)
+mtd_device_parse_register(mtd, types, NULL, parts, nr_parts)
-mtd_device_parse_register(mtd, types, parser_data, 0, nr_parts)
+mtd_device_parse_register(mtd, types, parser_data, NULL, nr_parts)
This patch is part of a set which fixes unnecessary flash erase and write errors
resulting from the MTD CFI driver turning off vpp while an erase is in progress.
This patch allows sa1100_set_vpp() calls to be nested by adding a reference
counter.
Signed-off-by: Paul Parsons <lost.distance@yahoo.com>
This patch allows pcmciamtd_set_vpp() calls to be nested by adding a reference
counter.
This patch allows l440gx_set_vpp() calls to be nested by adding a reference
counter.
This patch allows physmap_set_vpp() calls to be nested by adding a reference
counter.
omap1_set_vpp() already used a reference counter. Since it is called from
physmap_set_vpp(), omap1_set_vpp() can now be simplified.
simtec_nor_vpp() already disabled hard interrupts. Since it is called from
physmap_set_vpp(), simtec_nor_vpp() can now be simplified.
This patch ensures that only those flash operations which call ENABLE_VPP() can
then call DISABLE_VPP(). Other operations should never call DISABLE_VPP().
The current patch is required to support EVALSPEAR1340CPU
Revision 2 where a new (ONFI compliant) MT29F16G08 NAND
flash from Micron is present.
This NAND flash device defines a OOB area which is
224 bytes long (oobsize).
Signed-off-by: Armando Visconti <armando.visconti@st.com>
This patch improves the error correction routine for bch8
- Loop only up to number of errors detected
- Improve the error index calculation procedure
Additionally, it also renames the "correct" routine to indicate that it is bch8
specific
Signed-off-by: Vipin Kumar <vipin.kumar@st.com>
Since change_bit() requires a (unsigned int *) as second arg,
the correct definition of err_idx[] array declared as
local variable of fsmc_correct_data() is the following:
u32 err_idx[8];
Address Latch Enable (ALE) and Command Latch Enable (CLE) defines are
platform specific and were wrongly put in driver specific fsmc.h file.
Move such defines to their respective platform.
Also instead of relying on fsmc driver, pass ALE, CLE offsets explicitly
from individual platform.
Signed-off-by: Shiraz Hashim <shiraz.hashim@st.com>
ALE and CLE offsets can be different on different devices. Let devices
pass these offsets to the fsmc driver through platform data.
ECC1 & ECC4 layout for NAND of different pages sizes for e.g. 512bytes,
2KiB, 4KiB and 8KiB are separated. Previously there existed one ECC4
layout for 2KiB & 4KiB page size due to which oob test module available
in drivers/mtd/nand/test was failing.
Signed-off-by: Bhavna Yadav <bhavna.yadav@st.com>
A newly erased page contains ff in data as well as spare area. While reading an
erased page, the read out ecc from spare area does not match the ecc generated
by fsmc ecc hardware accelerator. This is because ecc of data ff ff is not ff
ff. This leads to errors when file system erases and reads back the pages to
ensure consistency.
This patch adds a software workaround to ensure that the ecc check is not
performed for erased pages. This problem is solved by checking the number of
bits (in 512 byte data + 13 byte ecc) which are 0. If these number of bits are
less than 8, the page is considered erased and correction algorithm is not tried
on that page
This patch reverts a change that may have been mistakenly included with the set
of patches that introduced the new mtd api entry functions. Or perhaps I am
mistaken :)
The problem is in the partition wrapper functions, where the calls to the driver
methods were replaced with calls to the new mtd api functions. This causes the
api function to be called a second time, further down the call stack. This is
not only unnecessary and redundant - because the sanity checking code and (more
restrictive) bounds checks for the partition were done in the first call - but
is potentially problematic and confusing.
For example, the call stack for a call to mtd_read() on a partitioned device
currently looks like this:
mtd_read() gets struct mtd_info for the partition
+-> part_read() via the pointer assigned when the partition was created
+->mtd_read() this time gets struct mtd_info for the master
+->xyz_driver_read() via the pointer asigned by the driver
It seems that this can cause a variety of problems. For example, if you want to
add code to the api function that tests a value in mtd_info that is relevant
only to the partition. Or (in my case) you want the driver to return a value
that may be different from that returned by the mtd api function.
This patch eliminates the second call to the mtd api function. It was tested on
the docg4 nand driver with a subset of the api functions, but I inspected the
rest and don't see any problems.
Change the name of the mtd so that it is simpler, and is easier to
cope with by mtdparts.
Add board and clock setup code for the SH Mobile flctl controller.
Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Add a register used in new FLCTL hardware and a feature flag for it.
Instead of reading out the register, use a cached value. This will
make way for a proper runtime power management implementation.
Implements the command to seek and read in pages.
The nand base code wants to read out 8 bytes in the READID command.
Reflect this in the driver code.
Reorders the calls to make it a bit shorter and match the calling
procedure displayed in the datasheet.
Add support for a new hardware generation. The meaning of some bits
of the FLCMNCR register changed, so some new defines are added
parallel to the existing ones to keep backward compatibility.
The defines allow to choose an appropriate clocking scheme.
Use pr_<level> to prefix KBUILD_MODNAME via pr_fmt.
Remove obfuscating defines and use constants in pr_<level>
No need for a do {} while (0) for single statements.
Form of JFFS_<LEVEL> output changes from
"JFFS2 notice: " to "jffs2: notice: "
Added pr_fmt to xattr.c
Use pr_fmt to prefix KBUILD_MODNAME to appropriate logging messages.
Remove now unnecessary internal prefixes from formats.
Use the more current logging style.
Coalesce formats, align arguments.
Convert uses of embedded function names to %s, __func__.
A couple of long line checkpatch errors I don't care about exist.
D1 and D2 macros are mostly uses to emit debugging messages.
Convert the logging uses of D1 & D2 to jffs2_dbg(level, fmt, ...)
to be a bit more consistent style with the rest of the kernel.
All jffs2_dbg output is now at KERN_DEBUG where some of
the previous uses were emitted at various KERN_<LEVEL>s.
Since commit ca97dec2ab5c87e9fbdf7e882e1820004a3966fa the
command line parsing of MTD partitions does not work anymore.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Signed-off-by: John Crispin <blogic@openwrt.org>
Cc: stable@kernel.org [3.2+]
Acked-by: John Crispin <blogic@openwrt.org>
Some strange nand chip(such as Hynix H27UBG8T2A) can pass the `ONFI` signature
check. So the log can be printed out even it is not an ONFI nand indeed.
Change this log to the end of the function. Print out the log only when we
really detect an ONFI nand.
Signed-off-by: Huang Shijie <b32955@freescale.com>
Acked-by: Florian Fainelli <ffainelli@freebox.fr>
Acked-by: Brian Norris <computersforpeace@gmail.com>
[1] Background :
The GPMI does ECC read page operation with a DMA chain consist of three DMA
Command Structures. The middle one of the chain is used to enable the BCH,
and read out the NAND page.
The WAIT4END(wait for command end) is a comunication signal between
the GPMI and MXS-DMA.
[2] The current DMA code sets the WAIT4END bit at the last one, such as:
| cmd | ------------> | cmd | ------------------> | cmd |
set WAIT4END here
This chain works fine in the mx23/mx28.
[3] But in the new GPMI version (used in MX50/MX60), the WAIT4END bit should
be set not only at the last DMA Command Structure,
but also at the middle one, such as:
set WAIT4END here too set WAIT4END here
If we do not set WAIT4END, the BCH maybe stalls in "ECC reading page" state.
In the next ECC write page operation, a DMA-timeout occurs.
This has been catched in the MX6Q board.
[4] In order to fix the bug, rewrite the last parameter of mxs_dma_prep_slave_sg(),
and use the dma_ctrl_flags:
DMA_PREP_INTERRUPT : append a new DMA Command Structrue.
DMA_CTRL_ACK : set the WAIT4END bit for this DMA Command Structure.
[5] changes to the relative drivers:
<1> For mxs-mmc driver, just use the new flags, do not change any logic.
<2> For gpmi-nand driver, and use the new flags to set the DMA
chain, especially for ecc read page.
Acked-by: Shawn Guo <shawn.guo@linaro.org>
Acked-by: Vinod Koul <vinod.koul@linux.intel.com>
Move the header to a more common place.
The mxs dma engine is not only used in mx23/mx28, but also used
in mx50/mx6q. It will also be used in the future chips.
Rename it to mxs-dma.h, and create a new folder include/linux/fsl/ to
store the Freescale's header files.
change mxs-dma driver, mxs-mmc driver, gpmi-nand driver, mxs-saif driver
to the new header file.
Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
Acked-by: Chris Ball <cjb@laptop.org>
Signed-off-by: Nikola Pajkovsky <n.pajkovsky@gmail.com>
While debugging on SA11x0, the following message was observed:
"Flash device refused suspend due to active operation (state 20)"
The gpmi driver selects the MTD_CMDLINE_PARTS directly.
But we should not select a visible symbol.
Just remove the select.
As of bb0eb217, MTD_FAIL_ADDR_UNKNOWN should be used to indicate mtd
erase failure not specific to any particular block.
Use MTD_FAIL_ADDR_UNKNOWN instead of 0xffffffff when setting
'erase->fail_addr' in 'efx_mtd_erase()'.
Signed-off-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Acked-by: Ben Hutchings <bhutchings@solarflare.com>
Correct spelling "modul" to "module" in
fs/hffs2/compr.c
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
In commit "c797533 mtd: abstract last MTD partition parser argument" the
third argument of "mtd_device_parse_register()" changed from start address
of the MTD device to a pointer to a struct.
The "ixp4xx_flash_probe()" function was not converted properly, causing
an oops during boot.
This patch fixes the problem by filling the needed information into a
"struct mtd_part_parser_data" and passing it to
"mtd_device_parse_register()".
Signed-off-by: Marc Kleine-Budde <mkl@blackshift.org>
This patch changes all the OTP functions like 'mtd_get_fact_prot_info()' and
makes them return zero immediately if the input 'len' parameter is 0. This is
not really needed currently, but most of the other functions do this, and it is
just consistent to do the same in the OTP functions.
This patch also moves the OTP functions from the header file to mtdcore.c
because they become a bit too big for being inlined.
In many places in drivers we verify for the zero length, but this is very
inconsistent across drivers. This is obviously the right thing to do, though.
This patch moves the check to the MTD API functions instead and removes a lot
of duplication.
Reviewed-by: Shmulik Ladkani <shmulik.ladkani@gmail.com>
Some MTD drivers return -EINVAL if the 'phys' parameter is not NULL, trying to
convey that they cannot return the physical address. However, this is not very
logical because they still can return the virtual address ('virt'). But some
drivers (lpddr) just ignore the 'phys' parameter instead, which is a more
logical thing to do.
Let's harmonize this and:
1. Always initialize 'virt' and 'phys' to 'NULL' in 'mtd_point()'.
2. Do not return an error if the physical address cannot be found.
So as a result, all drivers will set 'phys' to 'NULL' if it is not supported.
None of the 'mtd_point()' users use 'phys' anyway, so this should not break
anything. I guess we could also just delete this parameter later.
This header is tiny and contains only pmc551-private stuff, so it should
not live in 'include/linux' - let's just merge it with pmc551.c.
The MTD API function now zero the 'retlen' parameter before calling
the driver's method — do not do this again in drivers. This removes
duplicated '*retlen = 0' assignent from the following methods:
'mtd_point()'
'mtd_read()'
'mtd_write()'
'mtd_writev()'
'mtd_panic_write()'
Many drivers check whether the partition is R/O and return -EROFS if yes.
Let's stop having duplicated checks and move them to the API functions
instead.
And again a bit of noise - deleted few too sparse newlines, sorry.
We already verify that offset and length are within the MTD device size
in the MTD API functions. Let's remove the duplicated checks in drivers.
This patch only affects the following API's:
'mtd_erase()'
'mtd_point()'
'mtd_unpoint()'
'mtd_get_unmapped_area()'
'mtd_read()'
'mtd_write()'
'mtd_panic_write()'
'mtd_lock()'
'mtd_unlock()'
'mtd_is_locked()'
'mtd_block_isbad()'
'mtd_block_markbad()'
This patch adds a bit of noise by removing too sparse empty lines, but this is
not too bad.
Add verification of the offset and length to MTD API functions and verify that
MTD device offset and length are within MTD device size.
The modified API functions are:
'mtd_erase()'
'mtd_point()'
'mtd_unpoint()'
'mtd_read()'
'mtd_write()'
'mtd_panic_write()'
'mtd_lock()'
'mtd_unlock()'
'mtd_is_locked()'
'mtd_block_isbad()'
This patch also uninlines these functions and exports in mtdcore.c because they
are not performance-critical and do not have to be inlined.
The 'mtd_unpoint()' API function should be able to return an error code because
it may fail if you specify incorrect offset. This patch changes this MTD API
function and amends all the drivers correspondingly.
Also return '-EOPNOTSUPP' from 'mtd_unpoint()' when the '->unpoint()' method is
undefined. We do not really need this currently, but this just makes
sense to be consistent with 'mtd_point()'.
