2012-04-24ALSA: pci: clean up using module_pci_driver()Takashi Iwai
2012-04-24ALSA: usb-audio: sound/usb/endpoint.c: suppress warningAndrew Morton
sound/usb/endpoint.c: In function 'queue_pending_output_urbs': sound/usb/endpoint.c:298: warning: 'packet' may be used uninitialized in this function Cc: Daniel Mack <zonque@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: usb-audio: Add missing error checks in snd_ebox44_create_mixer()Takashi Iwai
2012-04-24ALSA: usb-audio: M-Audio Fast Track Ultra: Add effect controlsFelix Homann
This adds controls for the effects section on the FTU devices. Some of these controls need volume quirks. They are added to mixer.c. [fixed missing break by tiwai] Signed-off-by: Felix Homann <linuxaudio@showlabor.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: usb-audio: Rename Fast Track Ultra mixer quirk functionsFelix Homann
This is in preparation for more FTU controls to come. Should help keeping names a bit shorter. Signed-off-by: Felix Homann <linuxaudio@showlabor.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: usb-audio: Add TLV to M-Audio Fast Track Ultra controlsFelix Homann
This adds db gain information to M-Audio Fast Track Ultra (8R) devices. Signed-off-by: Felix Homann <linuxaudio@showlabor.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: usb-audio: Rename and export mixer_vol_tlvFelix Homann
Rename mixer_vol_tlv to snd_usb_mixer_vol_tlv and export it to make it reuseable in mixer_quirks.c. Signed-off-by: Felix Homann <linuxaudio@showlabor.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: usb-audio: Unify M-Audio Fast Track Ultra and Ebox-44 mixer quirks.Felix Homann
Merge snd_maudio_ftu_create_ctl() and snd_ebox44_create_ctl() into snd_create_std_mono_ctl(). As opposed to the ftu and ebox-44 specific functions, a TLV callback can be specified for controls created by snd_create_std_mono_ctl(). [fixed minor checkpatch.pl warnings by tiwai] Signed-off-by: Felix Homann <linuxaudio@showlabor.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-21ALSA: snd-usb: remove refactorization left-oversDaniel Mack
Drop some struct members and definitions that became obsolete during the refactorization of the driver. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-18Merge branch 'topic/cea861-audio' into topic/miscTakashi Iwai
2012-04-18ALSA: Add definitions for CEA-861 Audio InfoFramesRicardo Neri
Along with the IEC-60958 channel status word, CEA-861 Audio InfoFrames are used in HDMI and DisplayPort to describe the parameters of the audio stream. Hence, drivers for such devices may use these definitions to, for instance, fill a CEA-861 data structure and pass it to a display driver to configure an IP. Signed-off-by: Ricardo Neri <ricardo.neri@ti.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-18Merge branch 'topic/usb-endpoint' into topic/miscTakashi Iwai
2012-04-15ALSA: snd-usb-audio: Replace mixer for Electrix Ebox-44Mark Hills
The mixer units from the firmware are corrupt, and even where they are valid they presents mono controls as L and R channels of stereo. Signed-off-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-15ALSA: snd-usb-audio: Skip un-parseable mixer units instead of erroringMark Hills
Some interfaces reference endpoints which do not exists. To accomodate these, do not fail completely, but skip over them. This allows the Electrix Ebox-44 with earlier firmware to be detected and used for audio. Signed-off-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: usb: Remove obsoleted fields from struct snd_usb_substreamTakashi Iwai
Many fields have been moved to struct snd_usb_endpoint. Also fix the proc output to correspond to the new structure. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: usb: Fix fill_max flag setTakashi Iwai
ep->fill_max is a 1 bit flag, thus it has to be boolean. sound/usb/endpoint.c: In function 'snd_usb_endpoint_set_params': sound/usb/endpoint.c:785: warning: overflow in implicit constant conversion Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: usb: Remove unused variableTakashi Iwai
sound/usb/endpoint.c: In function ‘deactivate_urbs’: sound/usb/endpoint.c:520:16: warning: unused variable ‘flags’ [-Wunused-variable] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: snd-usb: add some documentationDaniel Mack
Document the new streaming code and some of the functions so that contributers can catch up easier. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: snd-usb: add support for implicit feedbackDaniel Mack
Implicit feedback is a streaming mode that does not rely on dedicated sync endpoints but uses the information provided by record streams to clock output streams. Now that the streaming logic is decoupled from the PCM streams, this is easy to implement. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: snd-usb: remove old streaming logicDaniel Mack
2012-04-13ALSA: snd-usb: switch over to new endpoint streaming logicDaniel Mack
With the previous commit that added the new streaming model, all endpoint and streaming related code is now in endpoint.c, and pcm.c only acts as a wrapper for handling the packet's payload. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: snd-usb: implement new endpoint streaming modelDaniel Mack
This patch adds a new generic streaming logic for audio over USB. It defines a model (snd_usb_endpoint) that handles everything that is related to an USB endpoint and its streaming. There are functions to activate and deactivate an endpoint (which call usb_set_interface()), and to start and stop its URBs. It also has function pointers to be called when data was received or is about to be sent, and pointer to a sync slave (another snd_usb_endpoint) that is informed when data has been received. A snd_usb_endpoint knows about its state and implements a refcounting, so only the first user will actually start the URBs and only the last one to stop it will tear them down again. With this sort of abstraction, the actual streaming is decoupled from the pcm handling, which makes the "implicit feedback" mechanisms easy to implement. In order to split changes properly, this patch only adds the new implementation but leaves the old one around, so the the driver doesn't change its behaviour. The switch to actually use the new code is submitted separately. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-13ALSA: snd-usb: add snd_usb_audio-wide mutexDaniel Mack
This is needed for new card-wide list operations. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-10ALSA: riptide: remove redundant NULL test before release_firmware()Jesper Juhl
release_firmware() deals gracefully with NULL pointers, no need to check first. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-10ALSA: sound/isa/sscape.c: add missing resource-release codeJulia Lawall
At the point of this error-handling code, both regions and the dma have been allocated, so free it as done in previous and subsequent error-handling code. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-10sound: sound/oss/msnd_pinnacle.c: add vfreesJulia Lawall
At the point of this error-handling code, HAVE_DSPCODEH may be undefined, so free INITCODE and PERMCODE as done elsewhere. A jump and label are introduced to avoid code duplication. Signed-off-by: Julia Lawall <Julia.Lawall@lip6.fr> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-07Merge tag 'asoc-3.4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus ASoC: fixes for 3.4 A bunch of driver-specific fixes and one generic fix for the new support for platform DAPM contexts - we were picking the wrong default for the idle_bias_off setting which was meaning we weren't actually achieving any useful runtime PM on platform devices.
2012-04-07ALSA: hda - clean up CX20549 test mixer setupMichael Karcher
name pins consistently (MIC1/LINE1/HP-OUT/CD) on all controls affecting those pins. remove duplicate SET_AMP_GAIN_MUTE to 0x17/index 0 and 0x17/index 1 really select MIC1, not Mixer out for recording "Mixer out" for recording is not a "pin", adjust comment Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-07ALSA: hda - CX20549 doesn't need pin_amp_workaround.Michael Karcher
CX20549 (ctx5045) doesn't accept data on index 1 for output pins, as shown in the following hda-var transaction: $ hda-verb /dev/snd/hwC0D0 0x10 set_amp_gain 0xb126 nid = 0x10, verb = 0x300, param = 0xb126 value = 0x0 $ hda-verb /dev/snd/hwC0D0 0x10 get_amp_gain 0x8001 nid = 0x10, verb = 0xb00, param = 0x8001 value = 0x0 Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-07ALSA: hda - Remove CD control from model=benq for CX20549Michael Karcher
The ID used for detection of the BenQ R55E actually identifies the Quanta TW3 ODM design, which is also used for the Gigabyte W551 laptop series. Schematics on the internet clearly indicate that the "Port C" (analog input connected to record source #4 and mixer input #4) is unconnected. Playing an audio CD through analog playback (using cdplay from cdtools) produces no sound, even with the mixer input labelled "CD" enabled, and the volume control in the CD drive set to maximum. This indicates the connection is really not present. Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-07ALSA: hda - fix record volume controls of CX20459 ("Venice")Michael Karcher
The "input converter" widget of the CX20459 has only one input amplifier, expose that one as "Capture Volume/Capture Switch". The actual record source selection is already exposed through the separately installed input mux. Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-07ALSA: hda - Rename capture sources of CX20549 to match common conventionsMichael Karcher
This includes renaming "Line In" to line, also in the mixer settings. Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-07ALSA: hda - Fix proc output for ADC amp values of CX20549Michael Karcher
The CX20549 has only one single input amp on it's input converter widget. Fix printing of values in the codec file in /proc/asound. Signed-off-by: Michael Karcher <kernel@mkarcher.dialup.fu-berlin.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-06ASoC: tegra: fix i2s compilation when !CONFIG_DEBUG_FSStephen Warren
Commit d4a2eca "ASoC: Tegra I2S: Remove dependency on pdev->id" changed the prototype of tegra_i2s_debug_add, but didn't update the dummy inline used when !CONFIG_DEBUG_FS. Fix that. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: <stable@vger.kernel.org> # 3.3
2012-04-05ASoC: set idle_bias_off=1 for all platform DAPM contextsStephen Warren
The ASoC core currently defaults to using STANDBY rather than OFF for idle ASoC platform devices, which causes a permanent pm_runtime_get() on them. This keeps the device active unnecessarily. This can be especially problematic when the ASoC platform device and DAI device are the same device. The distinction between OFF and STANDBY is likely not relevant for ASoC platform drivers, since they aren't analog devices. So, solve this issue by hard-coding idle_bias_off = 1 for all ASoC platform devices. If this turns out to be a problem, this value could be sourced from the snd_soc_platform_driver, similarly to soc_probe_codec(). Note: Prior to this change, this caused a large (10) runtime_active count for the Tegra I2S controller even when not in use, and a leak in that value as streams were started and stopped. This change probably hides a bug. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-05ASoC: imx-audmux: Check for NULL pointerFabio Estevam
Check for NULL pointer before accessing it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-05ASoC: imx-audmux: Fix ssi port numbers in sysfsFabio Estevam
Doing a 'cat /sys/kernel/debug/audmux/ssi7' causes the following oops to be printed by the kernel: Uhandled fault: external abort on non-linefetch (0x008) at 0xf53b003c Internal error: : 8 [#1] PREEMPT Modules linked in: CPU: 0 Not tainted (3.3.0-00033-gecc726e-dirty #307) PC is at audmux_read_file+0x68/0x2f4 LR is at clk_enable+0x3c/0x48 pc : [<c001b8c8>] lr : [<c00190a0>] psr: a0000013 sp : c3ad3f38 ip : c30a4000 fp : 00000003 r10: 00001000 r9 : be83fb00 r8 : c3ad3f80 r7 : c3ad3f80 r6 : 00000007 r5 : 00031010 r4 : c30a5000 r3 : f53b0000 r2 : 0000003c r1 : 380fa100 r0 : c068dda0 Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user Control: 0005317f Table: 83034000 DAC: 00000015 Process cat (pid: 1042, stack limit = 0xc3ad2270) Stack: (0xc3ad3f38 to 0xc3ad4000) 3f20: c3139180 00000000 3f40: c3bc6500 00001000 be83fb00 c3ad3f80 00001000 c3ad2000 00000000 c0095f3c 3f60: 00000003 c3bc6508 c3bc6500 be83fb00 00000000 00000000 00001000 c0096010 3f80: 00000000 00000000 b6fe2050 00000000 00001000 be83fb00 00000003 00000003 3fa0: c000eb88 c000e9e0 00001000 be83fb00 00000003 be83fb00 00001000 00000000 3fc0: 00001000 be83fb00 00000003 00000003 00000001 00000001 00000000 00000003 3fe0: 000bec8c be83fae0 0000f808 b6ea8d5c 60000010 00000003 7dff7ede 749bedf1 [<c001b8c8>] (audmux_read_file+0x68/0x2f4) from [<c0095f3c>] (vfs_read+0xb0/0x144) [<c0095f3c>] (vfs_read+0xb0/0x144) from [<c0096010>] (sys_read+0x40/0x70) [<c0096010>] (sys_read+0x40/0x70) from [<c000e9e0>] (ret_fast_syscall+0x0/0x2c) Code: e1a02186 e2822004 e3500000 e7935186 (e7937002) ---[ end trace 4d046e31309023de ]--- Fix the ssi port numbers in sysfs to fix this problem. Reported-by: Joan Carles <joancarles@fqingenieria.es> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-05ASoC: ak4642: fixup: mute needs +1 stepKuninori Morimoto
ak4642 out_tlv is +12.0dB to -115.0 dB, and it supports mute. But current settings didn't care +1 step for mute. This patch adds it Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-04-04MAINTAINERS: Don't list everyone working on Wolfson driversMark Brown
Rather than listing every single person who works on the drivers include the mailing list where they can all be found. Leave myself as a human contact. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-03MAINTAINERS: Add missing ASoC OMAP co-maintainerJarkko Nikula
Peter Ujfalusi has been co-maintaining sound/soc/omap/ for years but was missing from this MAINTAINERS entry. Signed-off-by: Jarkko Nikula <jarkko.nikula@bitmer.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-02ASoC: pxa: pxa2xx-i2s: add io.h for IOMEM macroMartin Jansa
* fixes sound/soc/pxa/pxa2xx-i2s.c:86:2: error: implicit declaration of function 'IOMEM' [-Werror=implicit-function-declaration] sound/soc/pxa/pxa2xx-i2s.c:86:2: error: initializer element is not constant after 23019a733bb83c8499f192fb428b7e6e81c95a34 removed IOMEM definition from arch/arm/mach-pxa/include/mach/hardware.h Signed-off-by: Martin Jansa <Martin.Jansa@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-02ASoC: tegra: ensure clocks are enabled when touching registersStephen Warren
Debugfs files could be accessed any time, so explicitly enable clocks when reading registers to generate debugfs file content. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-02ASoC: sgtl5000: Enable VAG when DAC/ADC upZeng Zhaoming
As manual described, VAG is an internal voltage reference of DAC/ADC, So enabled it before DAC/ADC up. One more thing should care about is VAG fully ramped down requires 400ms, wait it to avoid pop. Signed-off-by: Zeng Zhaoming <zengzm.kernel@gmail.com> Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-31Linux 3.4-rc1v3.4-rc1Linus Torvalds
2012-03-31Merge branch 's3-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/amit/virtio-console Pull virtio S3 support patches from Amit Shah: "Turns out S3 is not different from S4 for virtio devices: the device is assumed to be reset, so the host and guest state are to be assumed to be out of sync upon resume. We handle the S4 case with exactly the same scenario, so just point the suspend/resume routines to the freeze/restore ones. Once that is done, we also use the PM API's macro to initialise the sleep functions. A couple of cleanups are included: there's no need for special thaw processing in the balloon driver, so that's addressed in patches 1 and 2. Testing: both S3 and S4 support have been tested using these patches using a similar method used earlier during S4 patch development: a guest is started with virtio-blk as the only disk, a virtio network card, a virtio-serial port and a virtio balloon device. Ping from guest to host, dd /dev/zero to a file on the disk, and IO from the host on the virtio-serial port, all at once, while exercising S4 and S3 (separately) were tested. They all continue to work fine after resume. virtio balloon values too were tested by inflating and deflating the balloon." Pulling from Amit, since Rusty is off getting married (and presumably shaving people). * 's3-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/amit/virtio-console: virtio-pci: switch to PM ops macro to initialise PM functions virtio-pci: S3 support virtio-pci: drop restore_common() virtio: drop thaw PM operation virtio: balloon: Allow stats update after restore from S4
2012-03-31Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second try at vfs part d#2 from Al Viro: "Miklos' first series (with do_lookup() rewrite split into edible chunks) + assorted bits and pieces. The 'untangling of do_lookup()' series is is a splitup of what used to be a monolithic patch from Miklos, so this series is basically "how do I convince myself that his patch is correct (or find a hole in it)". No holes found and I like the resulting cleanup, so in it went..." Changes from try 1: Fix a boot problem with selinux, and commit messages prettied up a bit. * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (24 commits) vfs: fix out-of-date dentry_unhash() comment vfs: split __lookup_hash untangling do_lookup() - take __lookup_hash()-calling case out of line. untangling do_lookup() - switch to calling __lookup_hash() untangling do_lookup() - merge d_alloc_and_lookup() callers untangling do_lookup() - merge failure exits in !dentry case untangling do_lookup() - massage !dentry case towards __lookup_hash() untangling do_lookup() - get rid of need_reval in !dentry case untangling do_lookup() - eliminate a loop. untangling do_lookup() - expand the area under ->i_mutex untangling do_lookup() - isolate !dentry stuff from the rest of it. vfs: move MAY_EXEC check from __lookup_hash() vfs: don't revalidate just looked up dentry vfs: fix d_need_lookup/d_revalidate order in do_lookup ext3: move headers to fs/ext3/ migrate ext2_fs.h guts to fs/ext2/ext2.h new helper: ext2_image_size() get rid of pointless includes of ext2_fs.h ext2: No longer export ext2_fs.h to user space mtdchar: kill persistently held vfsmount ...
2012-03-31Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fixes from Ingo Molnar. * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched: Fix incorrect usage of for_each_cpu_mask() in select_fallback_rq() sched: Fix __schedule_bug() output when called from an interrupt sched/arch: Introduce the finish_arch_post_lock_switch() scheduler callback
2012-03-31Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf updates and fixes from Ingo Molnar: "It's mostly fixes, but there's also two late items: - preliminary GTK GUI support for perf report - PMU raw event format descriptors in sysfs, to be parsed by tooling The raw event format in sysfs is a new ABI. For example for the 'CPU' PMU we have: aldebaran:~> ll /sys/bus/event_source/devices/cpu/format/* -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/any -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/cmask -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/edge -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/event -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/inv -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/offcore_rsp -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/pc -r--r--r--. 1 root root 4096 Mar 31 10:29 /sys/bus/event_source/devices/cpu/format/umask those lists of fields contain a specific format: aldebaran:~> cat /sys/bus/event_source/devices/cpu/format/offcore_rsp config1:0-63 So, those who wish to specify raw events can now use the following event format: -e cpu/cmask=1,event=2,umask=3 Most people will not want to specify any events (let alone raw events), they'll just use whatever default event the tools use. But for more obscure PMU events that have no cross-architecture generic events the above syntax is more usable and a bit more structured than specifying hex numbers." * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (41 commits) perf tools: Remove auto-generated bison/flex files perf annotate: Fix off by one symbol hist size allocation and hit accounting perf tools: Add missing ref-cycles event back to event parser perf annotate: addr2line wants addresses in same format as objdump perf probe: Finder fails to resolve function name to address tracing: Fix ent_size in trace output perf symbols: Handle NULL dso in dso__name_len perf symbols: Do not include libgen.h perf tools: Fix bug in raw sample parsing perf tools: Fix display of first level of callchains perf tools: Switch module.h into export.h perf: Move mmap page data_head offset assertion out of header perf: Fix mmap_page capabilities and docs perf diff: Fix to work with new hists design perf tools: Fix modifier to be applied on correct events perf tools: Fix various casting issues for 32 bits perf tools: Simplify event_read_id exit path tracing: Fix ftrace stack trace entries tracing: Move the tracing_on/off() declarations into CONFIG_TRACING perf report: Add a simple GTK2-based 'perf report' browser ...
2012-03-31Merge tag 'parisc-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6 Pull PARISC misc updates from James Bottomley: "This is a couple of minor updates (fixing lws futex locking and removing some obsolete cpu_*_map calls)." * tag 'parisc-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/parisc-2.6: [PARISC] remove references to cpu_*_map. [PARISC] futex: Use same lock set as lws calls
2012-03-31Merge tag 'scsi-misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6 Pull SCSI updates from James Bottomley: "This is primarily another round of driver updates (lpfc, bfa, fcoe, ipr) plus a new ufshcd driver. There shouldn't be anything controversial in here (The final deletion of scsi proc_ops which caused some build breakage has been held over until the next merge window to give us more time to stabilise it). I'm afraid, with me moving continents at exactly the wrong time, anything submitted after the merge window opened has been held over to the next merge window." * tag 'scsi-misc' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (63 commits) [SCSI] ipr: Driver version 2.5.3 [SCSI] ipr: Increase alignment boundary of command blocks [SCSI] ipr: Increase max concurrent oustanding commands [SCSI] ipr: Remove unnecessary memory barriers [SCSI] ipr: Remove unnecessary interrupt clearing on new adapters [SCSI] ipr: Fix target id allocation re-use problem [SCSI] atp870u, mpt2sas, qla4xxx use pci_dev->revision [SCSI] fcoe: Drop the rtnl_mutex before calling fcoe_ctlr_link_up [SCSI] bfa: Update the driver version to 3.0.23.0 [SCSI] bfa: BSG and User interface fixes. [SCSI] bfa: Fix to avoid vport delete hang on request queue full scenario. [SCSI] bfa: Move service parameter programming logic into firmware. [SCSI] bfa: Revised Fabric Assigned Address(FAA) feature implementation. [SCSI] bfa: Flash controller IOC pll init fixes. [SCSI] bfa: Serialize the IOC hw semaphore unlock logic. [SCSI] bfa: Modify ISR to process pending completions [SCSI] bfa: Add fc host issue lip support [SCSI] mpt2sas: remove extraneous sas_log_info messages [SCSI] libfc: fcoe_transport_create fails in single-CPU environment [SCSI] fcoe: reduce contention for fcoe_rx_list lock [v2] ...
