2010-09-09Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6 Conflicts: net/mac80211/main.c
2010-09-09Merge branch 'vhost-net' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost
2010-09-09drivers/net/bnx2x: use ARRAY_SIZE macro in bnx2x_main.cNikitas Angelinas
Replace sizeof(bnx2x_parity_mask)/(sizeof(bnx2x_parity_mask[0]) with ARRAY_SIZE(bnx2x_parity_mask) in drivers/net/bnx2x/bnx2x_main.c Signed-off-by: Nikitas Angelinas <nikitasangelinas@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09ipheth: remove incorrect devtype to WWANDan Williams
The 'wwan' devtype is meant for devices that require preconfiguration and *every* time setup before the ethernet interface can be used, like cellular modems which require a series of setup commands on serial ports or other mechanisms before the ethernet interface will handle packets. As ipheth only requires one-per-hotplug pairing setup with no preconfiguration (like APN, phone #, etc) and the network interface is usable at any time after that initial setup, remove the incorrect devtype wwan. Signed-off-by: Dan Williams <dcbw@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09MAINTAINERS: Add CAIFJoe Perches
Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09au1000-eth: change multi-line comments styleFlorian Fainelli
Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09au1000-eth: remove volatiles, switch to I/O accessorsFlorian Fainelli
Remove all the volatile keywords where they were used, switch to using the proper readl/writel accessors. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09au1000-eth: fix asm -> linux headers inclusionFlorian Fainelli
Replace asm/io.h and asm/cpu.h wih linux/io.h and linux/cpu.h Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09au1000-eth: fix bad printk usagesFlorian Fainelli
Use pr_(info|err) and pr_cont where required instead of calls to printk. Add missing pr_fmt to the driver. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09au1000-eth: fix all but one "line over 80 characters warnings"Florian Fainelli
One line has not been changed because it would not improve readability. Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09au1000-eth: stylistic fixesFlorian Fainelli
This patch fixes the following checkpatch.pl warnings: - spaces after tabs - space between function and arguments - one-line statement braces - tabs instead of spaces Signed-off-by: Florian Fainelli <florian@openwrt.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09au1000-eth: typedefs removalFlorian Fainelli
2010-09-09tipc: Optimize handling excess content on incoming messagesPaul Gortmaker
Remove code that trimmed excess trailing info from incoming messages arriving over an Ethernet interface. TIPC now ignores the extra info while the message is being processed by the node, and only trims it off if the message is retransmitted to another node. (This latter step is done to ensure the extra info doesn't cause the sk_buff to exceed the outgoing interface's MTU limit.) The outgoing buffer is guaranteed to be linear. Signed-off-by: Allan Stephens <allan.stephens@windriver.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09ixgbevf: remove private net_device_statsEric Dumazet
Use the net_device provided net_device_stats structure. Remove ixgbevf_get_stats() now its not needed. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09tunnels: missing rcu_assign_pointer()Eric Dumazet
xfrm4_tunnel_register() & xfrm6_tunnel_register() should use rcu_assign_pointer() to make sure previous writes (to handler->next) are committed to memory before chain insertion. deregister functions dont need a particular barrier. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09net/core: add lock context change annotations in net/core/sock.cNamhyung Kim
__lock_sock() and __release_sock() releases and regrabs lock but were missing proper annotations. Add it. This removes following warning from sparse. (Currently __lock_sock() does not emit any warning about it but I think it is better to add also.) net/core/sock.c:1580:17: warning: context imbalance in '__release_sock' - unexpected unlock Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09net/core: remove address space warnings on verify_iovec()Namhyung Kim
move_addr_to_kernel() and copy_from_user() requires their argument as __user pointer but were missing proper markups. Add it. This removes following warnings from sparse. net/core/iovec.c:44:52: warning: incorrect type in argument 1 (different address spaces) net/core/iovec.c:44:52: expected void [noderef] <asn:1>*uaddr net/core/iovec.c:44:52: got void *msg_name net/core/iovec.c:55:34: warning: incorrect type in argument 2 (different address spaces) net/core/iovec.c:55:34: expected void const [noderef] <asn:1>*from net/core/iovec.c:55:34: got struct iovec *msg_iov Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09sctp: fix test for end of loopJoe Perches
Add a list_has_sctp_addr function to simplify loop Based on a patches by Dan Carpenter and David Miller Signed-off-by: Joe Perches <joe@perches.com> Acked-by: Vlad Yasevich <vladislav.yasevich@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-09Merge branch 'for-davem' of git://oss.oracle.com/git/agrover/linux-2.6David S. Miller
2010-09-08Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/torvalds/linux-2.6
2010-09-08KS8851: Correct RX packet allocationEric Dumazet
Use netdev_alloc_skb_ip_align() helper and do correct allocation Tested-by: Abraham Arce <x0066660@ti.com> Signed-off-by: Abraham Arce <x0066660@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08udp: add rehash on connect()Eric Dumazet
commit 30fff923 introduced in linux-2.6.33 (udp: bind() optimisation) added a secondary hash on UDP, hashed on (local addr, local port). Problem is that following sequence : fd = socket(...) connect(fd, &remote, ...) not only selects remote end point (address and port), but also sets local address, while UDP stack stored in secondary hash table the socket while its local address was INADDR_ANY (or ipv6 equivalent) Sequence is : - autobind() : choose a random local port, insert socket in hash tables [while local address is INADDR_ANY] - connect() : set remote address and port, change local address to IP given by a route lookup. When an incoming UDP frame comes, if more than 10 sockets are found in primary hash table, we switch to secondary table, and fail to find socket because its local address changed. One solution to this problem is to rehash datagram socket if needed. We add a new rehash(struct socket *) method in "struct proto", and implement this method for UDP v4 & v6, using a common helper. This rehashing only takes care of secondary hash table, since primary hash (based on local port only) is not changed. Reported-by: Krzysztof Piotr Oledzki <ole@ans.pl> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Tested-by: Krzysztof Piotr Oledzki <ole@ans.pl> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08atlx: make strings constStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Acked-by: Chris Snook <chris.snook@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08net: inet_add_protocol() can use cmpxchg()Eric Dumazet
Use cmpxchg() to get rid of spinlocks in inet_add_protocol() and friends. inet_protos[] & inet6_protos[] are moved to read_mostly section Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08cxacru: ignore cx82310_eth devicesOndrej Zary
Ignore ADSL routers, which can have the same vendor and product IDs as ADSL modems but should be handled by the cx82310_eth driver. This intentionally ignores device IDs that aren't currently handled by cx82310_eth. There may be other device IDs that perhaps shouldn't be claimed by cxacru. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-09-08RDS: Remove dead struct from rds.hAndy Grover
flows are an obsolete date type. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: rds.h: Replace u_int[size]_t with uint[size]_tAndy Grover
Replace e.g. u_int32_t types with the more common uint32_t. Reported-by: Matthew Wilcox <willy@linux.intel.com> Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Add rds.h to exported headers listAndy Grover
Also, a number of changes were made based on the assumption that rds.h wasn't exported, so roll these back. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: Implement masked atomic operationsAndy Grover
Add two CMSGs for masked versions of cswp and fadd. args struct modified to use a union for different atomic op type's arguments. Change IB to do masked atomic ops. Atomic op type in rds_message similarly unionized. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS/IB: print string constants in more placesZach Brown
This prints the constant identifier for work completion status and rdma cm event types, like we already do for IB event types. A core string array helper is added that each string type uses. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: cancel connection work structs as we shut downZach Brown
Nothing was canceling the send and receive work that might have been queued as a conn was being destroyed. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: don't call rds_conn_shutdown() from rds_conn_destroy()Zach Brown
rds_conn_shutdown() can return before the connection is shut down when it encounters an existing state that it doesn't understand. This lets rds_conn_destroy() then start tearing down the conn from under paths that are still using it. It's more reliable the shutdown work and wait for krdsd to complete the shutdown callback. This stopped some hangs I was seeing where krdsd was trying to shut down a freed conn. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: have sockets get transport module referencesZach Brown
Right now there's nothing to stop the various paths that use rs->rs_transport from racing with rmmod and executing freed transport code. The simple fix is to have binding to a transport also hold a reference to the transport's module, removing this class of races. We already had an unused t_owner field which was set for the modular transports and which wasn't set for the built-in loop transport. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: remove old rs_transport commentZach Brown
rs_transport is now also used by the rdma paths once the socket is bound. We don't need this stale comment to tell us what cscope can. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: lock rds_conn_count decrement in rds_conn_destroy()Zach Brown
rds_conn_destroy() can race with all other modifications of the rds_conn_count but it was modifying the count without locking. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: protect the list of IB devicesZach Brown
The RDS IB device list wasn't protected by any locking. Traversal in both the get_mr and FMR flushing paths could race with additon and removal. List manipulation is done with RCU primatives and is protected by the write side of a rwsem. The list traversal in the get_mr fast path is protected by a rcu read critical section. The FMR list traversal is more problematic because it can block while traversing the list. We protect this with the read side of the rwsem. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: print IB event strings as well as their numberZach Brown
It's nice to not have to go digging in the code to see which event occurred. It's easy to throw together a quick array that maps the ib event enums to their strings. I didn't see anything in the stack that does this translation for us, but I also didn't look very hard. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: flush fmrs before allocating new onesChris Mason
Flushing FMRs is somewhat expensive, and is currently kicked off when the interrupt handler notices that we are getting low. The result of this is that FMR flushing only happens from the interrupt cpus. This spreads the load more effectively by triggering flushes just before we allocate a new FMR. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-09-08RDS: properly use sg_init_tableChris Mason
This is only needed to keep debugging code from bugging. Signed-off-by: Chris Mason <chris.mason@oracle.com>
2010-09-08RDS/IB: track signaled sendsZach Brown
We're seeing bugs today where IB connection shutdown clears the send ring while the tasklet is processing completed sends. Implementation details cause this to dereference a null pointer. Shutdown needs to wait for send completion to stop before tearing down the connection. We can't simply wait for the ring to empty because it may contain unsignaled sends that will never be processed. This patch tracks the number of signaled sends that we've posted and waits for them to complete. It also makes sure that the tasklet has finished executing. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: remove __init and __exit annotationZach Brown
The trivial amount of memory saved isn't worth the cost of dealing with section mismatches. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: Use SLAB_HWCACHE_ALIGN flag for kmem_cache_create()Andy Grover
We are *definitely* counting cycles as closely as DaveM, so ensure hwcache alignment for our recv ring control structs. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS/IB: always process recv completionsZach Brown
The recv refill path was leaking fragments because the recv event handler had marked a ring element as free without freeing its frag. This was happening because it wasn't processing receives when the conn wasn't marked up or connecting, as can be the case if it races with rmmod. Two observations support always processing receives in the callback. First, buildup should only post receives, thus triggering recv event handler calls, once it has built up all the state to handle them. Teardown should destroy the CQ and drain the ring before tearing down the state needed to process recvs. Both appear to be true today. Second, this test was fundamentally racy. There is nothing to stop rmmod and connection destruction from swooping in the moment after the conn state was sampled but before real receive procesing starts. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS: return to a single-threaded krdsdZach Brown
We were seeing very nasty bugs due to fundamental assumption the current code makes about concurrent work struct processing. The code simpy isn't able to handle concurrent connection shutdown work function execution today, for example, which is very much possible once a multi-threaded krdsd was introduced. The problem compounds as additional work structs are added to the mix. krdsd is no longer perforance critical now that send and receive posting and FMR flushing are done elsewhere, so the safest fix is to move back to the single threaded krdsd that the current code was built around. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: create a work queue for FMR flushingZach Brown
This patch moves the FMR flushing work in to its own mult-threaded work queue. This is to maintain performance in preparation for returning the main krdsd work queue back to a single threaded work queue to avoid deep-rooted concurrency bugs. This is also good because it further separates FMRs, which might be removed some day, from the rest of the code base. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: destroy connections on rmmodZach Brown
IB connections were not being destroyed during rmmod. First, recently IB device removal callback was changed to disconnect connections that used the removing device rather than destroying them. So connections with devices during rmmod were not being destroyed. Second, rds_ib_destroy_nodev_conns() was being called before connections are disassociated with devices. It would almost never find connections in the nodev list. We first get rid of rds_ib_destroy_conns(), which is no longer called, and refactor the existing caller into the main body of the function and get rid of the list and lock wrappers. Then we call rds_ib_destroy_nodev_conns() *after* ib_unregister_client() has removed the IB device from all the conns and put the conns on the nodev list. The result is that IB connections are destroyed by rmmod. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: wait for IB dev freeing work to finish during rmmodZach Brown
The RDS IB client removal callback can queue work to drop the final reference to an IB device. We have to make sure that this function has returned before we complete rmmod or the work threads can try to execute freed code. Signed-off-by: Zach Brown <zach.brown@oracle.com>
2010-09-08RDS/IB: Make ib_recv_refill return voidAndy Grover
2010-09-08RDS: Remove unused XLIST_PTR_TAIL and xlist_protect()Andy Grover
Not used. Signed-off-by: Andy Grover <andy.grover@oracle.com>
2010-09-08RDS: whitespaceAndy Grover
