Need to make sure and disable ASF on all chip types. Otherwise, there may be
random reboots.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
There should never be descriptor error unless hardware or driver is buggy.
But if an error occurs, print useful information, clear irq, and recover.
This device is having all sorts of problems that lead to data corruption
and system instability. It gets receive status and data out of order,
it generates descriptor and TSO errors, etc.
Until the problems are resolved, it should not be used by anyone
who cares about there system.
Gianfar needs crc32 to be selected to compile.
Signed-off-by: Dave Jiang <djiang@mvista.com>
drivers/net/Kconfig | 1 +
1 files changed, 1 insertions(+), 0 deletions(-)
The basic structure of "normal" UDP/IP/Ethernet
frames (that actually work):
- It starts with the Ethernet header (dest MAC, src MAC, etc.)
- The next part is occupied by the IP header (version info, length of
packet, id=0, fragment offset=0, checksum, from / to address, etc.)
- Then comes the UDP header (src / dest port, length, checksum)
- Actual payload
- Ethernet checksum
Now what's different for IP fragment:
- The IP header has id set to some value (same for all fragments),
offset is set appropriately (i.e. 0 for first fragment, following
according to size of other fragments), size is the length of the frame.
- UDP header is unchanged. I.e. length is according to full UDP
datagram, not just the part within the actual frame! But this is only
true within the first frame: all following frames don't have a valid
UDP-header at all.
The spidernet silicon seems to be quite intelligent: It's able to
compute (IP / UDP / Ethernet) checksums on the fly and tests if frames
are conforming to RFC -- at least conforming to RFC on complete frames.
But IP fragments are different as explained above:
I.e. for IP fragments containing part of a UDP datagram it sees
incompatible length in the headers for IP and UDP in the first frame
and, thus, skips this frame. But the content *is* correct for IP
fragments. For all following frames it finds (most probably) no valid
UDP header at all. But this *is* also correct for IP fragments.
The Linux IP-stack seems to be clever in this point. It expects the
spidernet to calculate the checksum (since the module claims to be able
to do so) and marks the skb's for "normal" frames accordingly
(ip_summed set to CHECKSUM_HW).
But for the IP fragments it does not expect the driver to be capable to
handle the frames appropriately. Thus all checksums are allready
computed. This is also flaged within the skb (ip_summed set to
CHECKSUM_NONE).
Unfortunately the spidernet driver ignores that hints. It tries to send
the IP fragments of UDP datagrams as normal UDP/IP frames. Since they
have different structure the silicon detects them the be not
"well-formed" and skips them.
The following one-liner against 2.6.21-rc2 changes this behavior. If the
IP-stack claims to have done the checksumming, the driver should not
try to checksum (and analyze) the frame but send it as is.
Signed-off-by: Norbert Eicker <n.eicker@fz-juelich.de>
Signed-off-by: Linas Vepstas <linas@austin.ibm.com>
Remove assumption that PHY interrupts use GPIOs 3 and 5.
Deal with PHY interrupts connected to any GPIO pins.
Signed-off-by: Divy Le Ray <divy@chelsio.com>
Reuse the incoming skb when a clientless abort req is recieved.
The release of RDMA connections HW resources might be deferred in
low memory situations.
Ensure that no further activity is passed up to the RDMA driver
for these connections.
* 'linus' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm:
KVM: Fix off-by-one when writing to a nonpae guest pde
Nonpae guest pdes are shadowed by two pae ptes, so we double the offset
twice: once to account for the pte size difference, and once because we
need to shadow pdes for a single guest pde.
But when writing to the upper guest pde we also need to truncate the
lower bits, otherwise the multiply shifts these bits into the pde index
and causes an access to the wrong shadow pde. If we're at the end of the
page (accessing the very last guest pde) we can even overflow into the
next host page and oops.
Signed-off-by: Avi Kivity <avi@qumranet.com>
There is a race between netlink_dump_start() and netlink_release()
that can lead to the situation when a netlink socket with non-zero
callback is freed.
Here it is:
CPU1: CPU2
netlink_release(): netlink_dump_start():
sk = netlink_lookup(); /* OK */
netlink_remove();
spin_lock(&nlk->cb_lock);
if (nlk->cb) { /* false */
spin_unlock(&nlk->cb_lock);
nlk->cb = cb;
sock_orphan(sk);
* proceed with releasing
* the socket
The proposal it to make sock_orphan before detaching the callback
in netlink_release() and to check for the sock to be SOCK_DEAD in
netlink_dump_start() before setting a new callback.
Signed-off-by: Denis Lunev <den@openvz.org>
Signed-off-by: Kirill Korotaev <dev@openvz.org>
Signed-off-by: Pavel Emelianov <xemul@openvz.org>
Acked-by: Patrick McHardy <kaber@trash.net>
This patch fixes an oops first reported in mid 2006 - see
http://lkml.org/lkml/2006/8/29/358 The cause of this bug report is that
when an error is signalled on the socket, irda_recvmsg_stream returns
without removing a local wait_queue variable from the socket's sk_sleep
queue. This causes havoc further down the road.
In response to this problem, a patch was made that invoked sock_orphan on
the socket when receiving a disconnect indication. This is not a good fix,
as this sets sk_sleep to NULL, causing applications sleeping in recvmsg
(and other places) to oops.
This is against the latest net-2.6 and should be considered for -stable
inclusion.
Signed-off-by: Olaf Kirch <olaf.kirch@oracle.com>
Signed-off-by: Samuel Ortiz <samuel@sortiz.org>
The way partial delivery is currently implemnted, it is possible to
intereleave a message (either from another steram, or unordered) that
is not part of partial delivery process. The only way to this is for
a message to not be a fragment and be 'in order' or unorderd for a
given stream. This will result in bypassing the reassembly/ordering
queues where things live duing partial delivery, and the
message will be delivered to the socket in the middle of partial delivery.
This is a two-fold problem, in that:
1. the app now must check the stream-id and flags which it may not
be doing.
2. this clearing partial delivery state from the association and results
in ulp hanging.
This patch is a band-aid over a much bigger problem in that we
don't do stream interleave.
Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
Make sure to actually assign the determined mode to
rq->sadb_x_ipsecrequest_mode.
Noticed by Joe Perches.
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6:
[BRIDGE]: Unaligned access when comparing ethernet addresses
[SCTP]: Unmap v4mapped addresses during SCTP_BINDX_REM_ADDR operation.
[SCTP]: Fix assertion (!atomic_read(&sk->sk_rmem_alloc)) failed message
[NET]: Set a separate lockdep class for neighbour table's proxy_queue
[NET]: Fix UDP checksum issue in net poll mode.
[KEY]: Fix conversion between IPSEC_MODE_xxx and XFRM_MODE_xxx.
[NET]: Get rid of alloc_skb_from_cache
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband
* 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband:
IB/mthca: Fix data corruption after FMR unmap on Sinai
* 'for-linus' of git://one.firstfloor.org/home/andi/git/linux-2.6:
[PATCH] x86: Fix potential overflow in perfctr reservation
[PATCH] x86: Fix gcc 4.2 _proxy_pda workaround
* Last write during i2c_xfer is of the wrong byte (off-by-1).
* Read length is wrong for some of the reads (mistakenly used the PEC
version)
Looks like a local change I made to be able to test-compile the i2c-pasemi
driver leaked upstream.
Acked-by: Olof Johansson <olof@lixom.net>
Users have been complaining about the w83627ehf driver flooding their logs
with debug messages like:
w83627ehf 9191-0a10: Increasing fan 4 clock divider from 64 to 128
or:
w83627ehf 9191-0290: Increasing fan 4 clock divider from 4 to 8
The reason is that we failed to actually write the LSB of the encoded clock
divider value for that fan, causing the next read to report the same old value
again and again.
Additionally, the fan number was improperly reported, making the bug harder to
find.
Provide an dummy implementation of devm_ioport_map() and
devm_ioport_unmap() to allow drivers (eg, pata_platform) to build for
platforms where CONFIG_NO_IOPORT is selected.
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Jeff Garzik <jeff@garzik.org>
sk_info_authunix is not being protected properly so the object that it
points to can be cache_put twice, leading to corruption.
We borrow svsk->sk_defer_lock to provide the protection. We should
probably rename that lock to have a more generic name - later.
Thanks to Gabriel for reporting this.
Cc: Greg Banks <gnb@melbourne.sgi.com>
Cc: Gabriel Barazer <gabriel@oxeva.fr>
Signed-off-by: Neil Brown <neilb@suse.de>
Cc: <stable@kernel.org>
It got its lock and unlock backwards.
Fixes http://bugzilla.kernel.org/show_bug.cgi?id=8334
(obviously, this code could be using plain old spin_lock_irq(), too)
Cc: <matthias.kaehlcke@gmail.com>
This patch should fix or partly fix this bug:
http://bugzilla.kernel.org/show_bug.cgi?id=8276
The problem is:
- if we see "zero link case" during reading inode operation, we call
ufs_error(which remount fs readonly), but not "mark" inode as bad (1)
- in readonly case we do not fill some data structures, which are used in
read and write case (2)
- VFS call ufs_delete_inode if link count is zero (3)
so (1)->(3)->(2) cause oops, this patch should fix such scenario
Signed-off-by: Evgeniy Dushistov <dushistov@mail.ru>
Cc: Jim Paris <jim@jtan.com>
It turns out that the last patch to change set_cs to be kept in the
controller's structure instead of the platform data was an incomplete
change, and did not change the references to platfrom data in the setup
xfer code. (This can prevent an oops.)
Reported-by: <Ling.Alex@iac.com.tw>
Signed-off-by: Ben Dooks <ben-linux@fluff.org>
Signed-off-by: David Brownell <dbrownell@users.sourceforge.net>
Override compiler .arch directive for generic kernel build.
Signed-off-by: Ivan Kokshaysky <ink@jurassic.park.msu.ru>
Signed-off-by: Richard Henderson <rth@twiddle.net>
arch/alpha/kernel/sys_sx164.c
Earlier firmware revisions need MVI fix as well.
arch/alpha/kernel/sys_nautilus.c
On UP1500 firmware reports wrong AGP IRQ (10 instead of 5).
This causes interrupt storm if there is a PCI device that
uses IRQ 5.
Cc: Richard Henderson <rth@twiddle.net>
Files:
arch/alpha/kernel/core_mcpcia.c
arch/alpha/kernel/sys_rawhide.c
include/asm-alpha/core_mcpcia.h
Determine correct hose configuration; RAWHIDE family can have
2 or 4 hoses, so make sure non-existent hoses are ignored.
arch/alpha/kernel/err_titan.c
Supply a needed #include <asm/irq_regs.h>
arch/alpha/kernel/module.c
Add some useful output to the relocation overflow messages.
arch/alpha/kernel/sys_noritake.c
Supply necessary noritake_end_irq() to correct interrupt handling.
This fixes a problem first noted by hangs during boot probing with
a DE500-BA TULIP NIC present.
arch/alpha/kernel/sys_sio.c
Correct saving of original PIRQ register (PCI IRQ routing);
change default PIRQ setting to leave PCI IRQs 9 and 14 free to
be used for sound (Multia) and IDE (any), respectively.
include/asm-alpha/io.h
Supply the "isa_virt_to_bus" routine.
Signed-off-by: Jay Estabrook <jay.estabrook@hp.com>
While digging through my MAP_FIXED changes, I found that rather obvious
bug in /dev/mem mmap implementation for nommu archs. get_unmapped_area()
is expected to return an address, not a pfn.
Acked-By: David Howells <dhowells@redhat.com>
Make kernel-doc comments match macro names.
Correct parameter names in a few places.
Remove '#' from beginning of kernel-doc comment macro names.
Remove extra (erroneous) blank lines in kernel-doc.
Warning(plist.h:100): Cannot understand * #PLIST_HEAD_INIT - static struct plist_head initializer on line 100 - I thought it was a doc line
Warning(plist.h:112): Cannot understand * #PLIST_NODE_INIT - static struct plist_node initializer on line 112 - I thought it was a doc line
Warning(plist.h:103): No description found for parameter '_lock'
Warning(plist.h:129): No description found for parameter 'lock'
Warning(plist.h:158): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'pos'
Warning(plist.h:169): No description found for parameter 'n'
Warning(plist.h:179): No description found for parameter 'mem'
This still leaves one warning & one error that need attention:
Error(plist.h:219): cannot understand prototype: '('
Warning(plist.h): no structured comments found
Acked-by: Inaky Perez-Gonzalez <inaky.perez-gonzalez@intel.com>
Cc: Daniel Walker <dwalker@mvista.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
The patch checks for "|" in the pattern not the output and doesn't nail a
pid on to a piped name (as it is a program name not a file)
Also fixes a very very obscure security corner case. If you happen to have
decided on a core pattern that starts with the program name then the user
can run a program called "|myevilhack" as it stands. I doubt anyone does
this.
Signed-off-by: Alan Cox <alan@redhat.com>
Confirmed-by: Christopher S. Aker <caker@theshore.net>
Trivial change to pass vmsplice arguments through the compat layer on
pp64.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Acked-by: Stephen Rothwell <sfr@canb.auug.org.au>
Acked-by: Paul Mackerras <paulus@samba.org>
compare_ether_addr() implicitly requires that the addresses
passed are 2-bytes aligned in memory.
This is not true for br_stp_change_bridge_id() and
br_stp_recalculate_bridge_id() in which one of the addresses
is unsigned char *, and thus may not be 2-bytes aligned.
Signed-off-by: Evgeny Kravtsunov <emkravts@openvz.org>
During the sctp_bindx() call to add additional addresses to the
endpoint, any v4mapped addresses are converted and stored as regular
v4 addresses. However, when trying to remove these addresses, the
v4mapped addresses are not converted and the operation fails. This
patch unmaps the addresses on during the remove operation as well.
Signed-off-by: Paolo Galtieri <pgaltieri@mvista.com>
In current implementation, LKSCTP does receive buffer accounting for
data in sctp_receive_queue and pd_lobby. However, LKSCTP don't do
accounting for data in frag_list when data is fragmented. In addition,
LKSCTP doesn't do accounting for data in reasm and lobby queue in
structure sctp_ulpq.
When there are date in these queue, assertion failed message is printed
in inet_sock_destruct because sk_rmem_alloc of oldsk does not become 0
when socket is destroyed.
Signed-off-by: Tsutomu Fujii <t-fujii@nb.jp.nec.com>
Otherwise the following calltrace will lead to a wrong
lockdep warning:
neigh_proxy_process()
`- lock(neigh_table->proxy_queue.lock);
arp_redo /* via tbl->proxy_redo */
arp_process
neigh_event_ns
neigh_update
skb_queue_purge
`- lock(neighbor->arp_queue.lock);
This is not a deadlock actually, as neighbor table's proxy_queue
and the neighbor's arp_queue are different queues.
Lockdep thinks there is a deadlock as both queues are initialized
with skb_queue_head_init() and thus have a common class.
In net poll mode, the current checksum function doesn't consider the
kind of packet which is padded to reach a specific minimum length. I
believe that's the problem causing my test case failed. The following
patch fixed this issue.
Signed-off-by: Aubrey.Li <aubreylee@gmail.com>
We should not blindly convert between IPSEC_MODE_xxx and XFRM_MODE_xxx just
by incrementing / decrementing because the assumption is not true any longer.
Signed-off-by: Kazunori MIYAZAWA <miyazawa@linux-ipv6.org>
Singed-off-by: YOSHIFUJI Hideaki <yoshfuji@linux-ipv6.org>
Since this was added originally for Xen, and Xen has recently (~2.6.18)
stopped using this function, we can safely get rid of it. Good timing
too since this function has started to bit rot.
cache_k8_northbridges() is storing config values to incorrect locations
(in flush_words) and also its overflowing beyond the allocation, causing
slab verification failures.
Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com>
In mthca_arbel_fmr_unmap(), the high bits of the key are masked off.
This gets rid of the effect of adjust_key(), which makes sure that
bits 3 and 23 of the key are equal when the Sinai throughput
optimization is enabled, and so it may happen that an FMR will end up
with bits 3 and 23 in the key being different. This causes data
corruption, because when enabling the throughput optimization, the
driver promises the HCA firmware that bits 3 and 23 of all memory keys
will always be equal.
Fix by re-applying adjust_key() after masking the key.
Thanks to Or Gerlitz for reproducing the problem, and Ariel Shahar for
help in debug.
Signed-off-by: Michael S. Tsirkin <mst@dev.mellanox.co.il>
Signed-off-by: Roland Dreier <rolandd@cisco.com>
* master.kernel.org:/home/rmk/linux-2.6-arm:
[ARM] 4313/1: S3C24XX: Update s3c2410 defconfig to 2.6.21-rc6
[ARM] Update mach-types
Update defconfig to the latest kernel version
and enable the h1940 LED driver
While reviewing this code again I found a potential overflow of the bitmap.
The p4 oprofile can theoretically set bits beyond the reservation bitmap for
specific configurations. Avoid that by sizing the bitmaps properly.
Signed-off-by: Andi Kleen <ak@suse.de>
Due to an over aggressive optimizer gcc 4.2 cannot optimize away _proxy_pda
in all cases (counter intuitive, but true). This breaks loading of some
modules.
The earlier workaround to just export a dummy symbol didn't work unfortunately
because the module code ignores exports with 0 value.
Make it 1 instead.
I tend to prefer to not have to cut an -rc7, but we still have some
network device driver and suspend issues. So here's -rc7.
We must remove the request from whatever list it is currently on before we
can add it to the dirty list.
Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
Fix logic error in VMI relocation processing. NOPs would always cause
a BUG_ON to fire because the != RELOCATION_NONE in the first if clause
precluding the == VMI_RELOCATION_NOP in the second clause. Make these
direct equality tests and just warn for unsupported relocation types
(which should never happen), falling back to native in that case.
Thanks to Anthony Liguori for noting this!
Signed-off-by: Zachary Amsden <zach@vmware.com>
If the writebacks are cancelled via nfs_cancel_dirty_list, or due to the
memory allocation failing in nfs_flush_one/nfs_flush_multi, then we must
ensure that the PG_writeback flag is cleared.
Also ensure that we actually own the PG_writeback flag whenever we
schedule a new writeback by making nfs_set_page_writeback() return the
value of test_set_page_writeback().
The PG_writeback page flag ends up replacing the functionality of the
PG_FLUSHING nfs_page flag, so we rip that out too.
Do not flag an error if the COMMIT call fails and we decide to resend the
writes. Let the resend flag the error if it fails.
If a write has failed, then nfs_direct_write_result should not attempt to
send a commit. It should just exit asap and return the error to the user.
Cc: Chuck Lever <chuck.lever@oracle.com>
