2009-03-17x86, dmar: move page fault handling code to dmar.cSuresh Siddha
Impact: code movement Move page fault handling code to dmar.c This will be shared both by DMA-remapping and Intr-remapping code. Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-03-17x86, x2apic: fix lock ordering during IRQ migrationSuresh Siddha
Impact: fix potential deadlock on x2apic fix "hard-safe -> hard-unsafe lock order detected" with irq_2_ir_lock On x2apic enabled system: [ INFO: hard-safe -> hard-unsafe lock order detected ] 2.6.27-03151-g4480f15b #1 ------------------------------------------------------ swapper/1 [HC0[0]:SC0[0]:HE0:SE1] is trying to acquire: (irq_2_ir_lock){--..}, at: [<ffffffff8038ebc0>] get_irte+0x2f/0x95 and this task is already holding: (&irq_desc_lock_class){+...}, at: [<ffffffff802649ed>] setup_irq+0x67/0x281 which would create a new lock dependency: (&irq_desc_lock_class){+...} -> (irq_2_ir_lock){--..} but this new dependency connects a hard-irq-safe lock: (&irq_desc_lock_class){+...} ... which became hard-irq-safe at: [<ffffffffffffffff>] 0xffffffffffffffff to a hard-irq-unsafe lock: (irq_2_ir_lock){--..} ... which became hard-irq-unsafe at: ... [<ffffffff802547b5>] __lock_acquire+0x571/0x706 [<ffffffff8025499f>] lock_acquire+0x55/0x71 [<ffffffff8062f2c4>] _spin_lock+0x2c/0x38 [<ffffffff8038ee50>] alloc_irte+0x8a/0x14b [<ffffffff8021f733>] setup_IO_APIC_irq+0x119/0x30e [<ffffffff8090860e>] setup_IO_APIC+0x146/0x6e5 [<ffffffff809058fc>] native_smp_prepare_cpus+0x24e/0x2e9 [<ffffffff808f982c>] kernel_init+0x5a/0x176 [<ffffffff8020c289>] child_rip+0xa/0x11 [<ffffffffffffffff>] 0xffffffffffffffff Fix this theoretical lock order issue by using spin_lock_irqsave() instead of spin_lock() Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@linux.intel.com>
2009-03-14Merge branches 'x86/apic', 'x86/asm', 'x86/cleanups', 'x86/debug', ↵Ingo Molnar
'x86/kconfig', 'x86/mm', 'x86/ptrace', 'x86/setup' and 'x86/urgent'; commit 'v2.6.29-rc8' into x86/core
2009-03-14x86: cpu/common.c more cleanupsIngo Molnar
Complete/fix the cleanups of cpu/common.c: - fix ugly warning due to asm/topology.h -> linux/topology.h change - standardize the style across the file - simplify/refactor the code flow where possible Cc: Jaswinder Singh Rajput <jaswinder@kernel.org> LKML-Reference: <1237009789.4387.2.camel@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-14Merge branch 'core/percpu' into x86/coreIngo Molnar
2009-03-14VM, x86, PAT: add a new vm flag to track full pfnmap at mmapPallipadi, Venkatesh
Impact: cleanup Add a new vm flag VM_PFN_AT_MMAP to identify a PFNMAP that is fully mapped with remap_pfn_range. Patch removes the overloading of VM_INSERTPAGE from the earlier patch. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Acked-by: Nick Piggin <npiggin@suse.de> LKML-Reference: <20090313233543.GA19909@linux-os.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-14x86: entry_32.S fix compile warnings - fix work mask bit widthJaswinder Singh Rajput
Fix: arch/x86/kernel/entry_32.S:446: Warning: 00000000080001d1 shortened to 00000000000001d1 arch/x86/kernel/entry_32.S:457: Warning: 000000000800feff shortened to 000000000000feff arch/x86/kernel/entry_32.S:527: Warning: 00000000080001d1 shortened to 00000000000001d1 arch/x86/kernel/entry_32.S:541: Warning: 000000000800feff shortened to 000000000000feff arch/x86/kernel/entry_32.S:676: Warning: 0000000008000091 shortened to 0000000000000091 TIF_SYSCALL_FTRACE is 0x08000000 and until now we checked the first 16 bits of the work mask - bit 27 falls outside of that. Update the entry_32.S code to check the full 32-bit mask. [ %cx => %ecx fix from Cyrill Gorcunov <gorcunov@gmail.com> ] Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: "H. Peter Anvin" <hpa@kernel.org> LKML-Reference: <1237012693.18733.3.camel@ht.satnam> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-14x86: cpu/common.c cleanupsJaswinder Singh Rajput
- fix various style problems - declare varibles before they get used - introduced clear_all_debug_regs - fix header files issues LKML-Reference: <1237009789.4387.2.camel@localhost.localdomain> Signed-off-by: Jaswinder Singh Rajput <jaswinder@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13Merge branch 'x86/core' into x86/kconfigIngo Molnar
2009-03-13x86: disable __do_IRQ supportThomas Gleixner
Impact: disable unused code x86 is fully converted to flow handlers. No need to keep the deprecated __do_IRQ() support active. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-03-13x86: ptrace, bts: fix an unreachable statementAmérico Wang
Commit c2724775ce57c98b8af9694857b941dc61056516 put a statement after return, which makes that statement unreachable. Move that statement before return. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Roland McGrath <roland@redhat.com> Cc: Markus Metzger <markus.t.metzger@intel.com> LKML-Reference: <20090313075622.GB8933@hack> Cc: <stable@kernel.org> # .29 only Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86: fix e820_update_range()Yinghai Lu
Impact: fix left range size on head | commit 5c0e6f035df983210e4d22213aed624ced502d3d | x86: fix code paths used by update_mptable | Impact: fix crashes under Xen due to unrobust e820 code fixes one e820 bug, but introduces another bug. Need to update size for left range at first in case it is header. also add __e820_add_region take more parameter. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: jbeulich@novell.com LKML-Reference: <49B9E286.502@kernel.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13cpuacct: reduce one NULL check in fast-pathLi Zefan
Impact: micro-optimization In cpuacct_charge(), task_ca() will never return NULL, so change for(...) to do { } while(...) to save one NULL check. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Menage <menage@google.com> Cc: Balbir Singh <balbir@linux.vnet.ibm.com> Cc: Bharata B Rao <bharata@linux.vnet.ibm.com> LKML-Reference: <49B863F5.2060400@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13VM, x86, PAT: Change is_linear_pfn_mapping to not use vm_pgoffPallipadi, Venkatesh
Impact: fix false positive PAT warnings - also fix VirtalBox hang Use of vma->vm_pgoff to identify the pfnmaps that are fully mapped at mmap time is broken. vm_pgoff is set by generic mmap code even for cases where drivers are setting up the mappings at the fault time. The problem was originally reported here: http://marc.info/?l=linux-kernel&m=123383810628583&w=2 Change is_linear_pfn_mapping logic to overload VM_INSERTPAGE flag along with VM_PFNMAP to mean full PFNMAP setup at mmap time. Problem also tracked at: http://bugzilla.kernel.org/show_bug.cgi?id=12800 Reported-by: Thomas Hellstrom <thellstrom@vmware.com> Tested-by: Frans Pop <elendil@planet.nl> Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha>@intel.com> Cc: Nick Piggin <npiggin@suse.de> Cc: "ebiederm@xmission.com" <ebiederm@xmission.com> Cc: <stable@kernel.org> # only for 2.6.29.1, not .28 LKML-Reference: <20090313004527.GA7176@linux-os.sc.intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-12Linus 2.6.29-rc8v2.6.29-rc8Linus Torvalds
2009-03-12bitmap: fix end condition in bitmap_find_free_regionLinus Torvalds
Guennadi Liakhovetski noticed that the end condition for the loop in bitmap_find_free_region() is wrong, and the "return if error" was also using the wrong conditional that would only trigger if the bitmap was an exact multiple of the allocation size, which is not necessarily the case with dma_alloc_from_coherent(). Such a failure would end up in bitmap_find_free_region() accessing beyond the end of the bitmap. Reported-by: Guennadi Liakhovetski <lg@denx.de> Cc: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-13x86: cpu_debug add write support for MSRsJaswinder Singh Rajput
Supported write flag for registers. currently write is enabled only for PMC MSR. [root@ht]# cat /sys/kernel/debug/x86/cpu/cpu1/pmc/0x300/value 0x0 [root@ht]# echo 1234 > /sys/kernel/debug/x86/cpu/cpu1/pmc/0x300/value [root@ht]# cat /sys/kernel/debug/x86/cpu/cpu1/pmc/0x300/value 0x4d2 [root@ht]# echo 0x1234 > /sys/kernel/debug/x86/cpu/cpu1/pmc/0x300/value [root@ht]# cat /sys/kernel/debug/x86/cpu/cpu1/pmc/0x300/value 0x1234 Signed-off-by: Jaswinder Singh Rajput <jaswinderrajput@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86: create a non-zero sized bm_pte only when neededJan Beulich
Impact: kernel image size reduction Since in most configurations the pmd page needed maps the same range of virtual addresses which is also mapped by the earlier inserted one for covering FIX_DBGP_BASE, that page (and its insertion in the page tables) can be avoided altogether by detecting the condition at compile time. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <49B91826.76E4.0078.0@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86: fix code paths used by update_mptableJan Beulich
Impact: fix crashes under Xen due to unrobust e820 code find_e820_area_size() must return a properly distinguishable and out-of-bounds value when it fails, and -1UL does not meet that criteria on i386/PAE. Additionally, callers of the function must check against that value. early_reserve_e820() should be prepared for the region found to be outside of the addressable range on 32-bits. e820_update_range_map() should not blindly update e820, but should do all it work on the map it got a pointer passed for (which in 50% of the cases is &e820_saved). It must also not call e820_add_region(), as that again acts on e820 unconditionally. The issues were found when trying to make this option work in our Xen kernel (i.e. where some of the silent assumptions made in the code would not hold). Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <49B9171B.76E4.0078.0@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86: clean up output resulting from update_mptable optionJan Beulich
Impact: cleanup Without apic=verbose, using the update_mptable option would result in garbled and confusing output due to the inconsistent use of printk() vs apic_printk(). Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <49B914B6.76E4.0078.0@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86: properly __init-annotate recent early_printk additionsJan Beulich
Impact: cleanup, save memory Don't keep code resident that's only needed during startup. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <49B91103.76E4.0078.0@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86: move save_mr() into .meminit.textJan Beulich
Impact: cleanup, save memory The function is only being called from boot or memory hotplug paths. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <49B910B6.76E4.0078.0@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86, 32-bit: also use cpuinfo_x86's x86_{phys,virt}_bits membersJan Beulich
Impact: 32/64-bit consolidation In a first step, this allows fixing phys_addr_valid() for PAE (which until now reported all addresses to be valid). Subsequently, this will also allow simplifying some MTRR handling code. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <49B9101E.76E4.0078.0@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86, 32-bit: also limit NODES_HIGH_SHIFT hereJan Beulich
Impact: configuration bug fix Just like for x86-64, the range of widths valid for NODE_SHIFT is not unbounded. The upper bound 64-bit uses is definitely also an upper bound for 32-bit. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <49B90F12.76E4.0078.0@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86: unify kmap_atomic_pfn() and iomap_atomic_prot_pfn(), fixIngo Molnar
Impact: build fix Move kmap_atomic_prot_pfn() to iomap_32.c. It is used on all 32-bit kernels, while highmem_32.c is only built on highmem kernels. ( Note: the debug_kmap_atomic_prot() check is removed for now, that problem is handled via another patch. ) Reported-by: Thomas Gleixner <tglx@linutronix.de> Cc: Akinobu Mita <akinobu.mita@gmail.com> LKML-Reference: <20090311143317.GA22244@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-13x86: smarten /proc/interrupts outputJan Beulich
Impact: change /proc/interrupts output ABI With the number of interrupts on large systems growing, assumptions on the width an interrupt number requires when converted to a decimal string turn invalid. Therefore, calculate the maximum number of digits dynamically. Signed-off-by: Jan Beulich <jbeulich@novell.com> LKML-Reference: <49B911EB.76E4.0078.0@novell.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-03-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sam/kbuild-fixes: kbuild: remove unused -r option for module-init-tool depmod kbuild: fix 'make rpm' when CONFIG_LOCALVERSION_AUTO=y and using SCM tree kbuild: fix mkspec to cleanup RPM_BUILD_ROOT kbuild: fix C libary confusion in unifdef.c due to getline()
2009-03-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: cpumask: mm_cpumask for accessing the struct mm_struct's cpu_vm_mask. cpumask: tsk_cpumask for accessing the struct task_struct's cpus_allowed.
2009-03-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linusLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-linus: Squashfs: Valid filesystems are flagged as bad by the corrupted fs patch
2009-03-12Merge branch 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'hwmon-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: hwmon: (f75375s) Remove unnecessary and confusing initialization hwmon: (it87) Properly decode -128 degrees C temperature hwmon: (lm90) Document support for the MAX6648/6692 chips hwmon: (abituguru3) Fix I/O error handling
2009-03-12trivial: fix bad links in the ext2 and ext3 documentationJody McIntyre
Trivial patch to fix bad links in the ext2 and ext3 documentation. Signed-off-by: Jody McIntyre <scjody@sun.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12Merge branch 'fixes-20090312' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/willy/pci * 'fixes-20090312' of git://git.kernel.org/pub/scm/linux/kernel/git/willy/pci: PCIe: portdrv: call pci_disable_device during remove pci: Fix typo in message while disabling HT MSI mapping pci: don't disable too many HT MSI mapping powerpc/pseries: The RPA PCI hotplug driver depends on EEH PCIe: AER: during disable, check subordinate before walking PCI: Add PCI quirk to disable L0s ASPM state for 82575 and 82598
2009-03-12RDMA/nes: Don't allow userspace QPs to use STag zeroFaisal Latif
STag zero is a special STag that allows consumers to access any bus address without registering memory. The nes driver unfortunately allows STag zero to be used even with QPs created by unprivileged userspace consumers, which means that any process with direct verbs access to the nes device can read and write any memory accessible to the underlying PCI device (usually any memory in the system). Such access is usually given for cluster software such as MPI to use, so this is a local privilege escalation bug on most systems running this driver. The driver was using STag zero to receive the last streaming mode data; to allow STag zero to be disabled for unprivileged QPs, the driver now registers a special MR for this data. Cc: <stable@kernel.org> Signed-off-by: Faisal Latif <faisal.latif@intel.com> Signed-off-by: Roland Dreier <rolandd@cisco.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12fs: new inode i_state corruption fixNick Piggin
There was a report of a data corruption http://lkml.org/lkml/2008/11/14/121. There is a script included to reproduce the problem. During testing, I encountered a number of strange things with ext3, so I tried ext2 to attempt to reduce complexity of the problem. I found that fsstress would quickly hang in wait_on_inode, waiting for I_LOCK to be cleared, even though instrumentation showed that unlock_new_inode had already been called for that inode. This points to memory scribble, or synchronisation problme. i_state of I_NEW inodes is not protected by inode_lock because other processes are not supposed to touch them until I_LOCK (and I_NEW) is cleared. Adding WARN_ON(inode->i_state & I_NEW) to sites where we modify i_state revealed that generic_sync_sb_inodes is picking up new inodes from the inode lists and passing them to __writeback_single_inode without waiting for I_NEW. Subsequently modifying i_state causes corruption. In my case it would look like this: CPU0 CPU1 unlock_new_inode() __sync_single_inode() reg <- inode->i_state reg -> reg & ~(I_LOCK|I_NEW) reg <- inode->i_state reg -> inode->i_state reg -> reg | I_SYNC reg -> inode->i_state Non-atomic RMW on CPU1 overwrites CPU0 store and sets I_LOCK|I_NEW again. Fix for this is rather than wait for I_NEW inodes, just skip over them: inodes concurrently being created are not subject to data integrity operations, and should not significantly contribute to dirty memory either. After this change, I'm unable to reproduce any of the added warnings or hangs after ~1hour of running. Previously, the new warnings would start immediately and hang would happen in under 5 minutes. I'm also testing on ext3 now, and so far no problems there either. I don't know whether this fixes the problem reported above, but it fixes a real problem for me. Cc: "Jorge Boncompte [DTI2]" <jorge@dti2.net> Reported-by: Adrian Hunter <ext-adrian.hunter@nokia.com> Cc: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12memcg: use correct scan number at reclaimKOSAKI Motohiro
Even when page reclaim is under mem_cgroup, # of scan page is determined by status of global LRU. Fix that. Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Balbir Singh <balbir@in.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12mfd: add support for WM8351 revision BMark Brown
No software visible difference from revision A. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: Samuel Ortiz <sameo@openedhand.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12acer-wmi: fix regression in backlight detectionMichael Spang
Currently we disable the Acer WMI backlight device if there is no ACPI backlight device. As a result, we end up with no backlight device at all. We should instead disable it if there is an ACPI device, as the other laptop drivers do. This regression was introduced in febf2d9 ("Acer-WMI: fingers off backlight if video.ko is serving this functionality"). Each laptop driver with backlight support got a similar change around febf2d9. The changes to the other drivers look correct; see e.g. a598c82f for a similar but correct change. The regression is also in 2.6.28. Signed-off-by: Michael Spang <mspang@csclub.uwaterloo.ca> Acked-by: Thomas Renninger <trenn@suse.de> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Carlos Corbacho <carlos@strangeworlds.co.uk> Cc: Len Brown <len.brown@intel.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: <stable@kernel.org> [2.6.28.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12mmc: s3cmci: fix s3c2410_dma_config() arguments.Ben Dooks
The s3cmci driver is calling s3c2410_dma_config with incorrect data for the DCON register. The S3C2410_DCON_HWTRIG is implicit in the channel configuration and the device selection of S3C2410_DCON_CH0_SDI is incorrect as the DMA system may not select channel 0. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Acked-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12MAINTAINERS: downgrade support for man-pagesMichael Kerrisk
Unfortunately, Linux Foundation funding for my work on man-pages/testing/doc under the auspices of the LF documentation fellowship unfortunately ran out a short while ago (after earlier attempts to seek funding, only Google stepped forward with a bit of further funding for the position), so the patch below acknowledges something closer to reality. Unfortunately, there will (probably very) soon be a further downgrade from "Maintained" to "Odd Fixes" or "Orphan", unless some funding miracle occurs. So, if anyone is looking to become man-pages maintainer, there may soon be an opening (okay, don't trample me in the rush ;-).) Signed-off-by: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12ds2760_battery.c: fix division by zeroDaniel Mack
The 'battery remaining capacity' calculation in drivers/power/ds2760_battery.c lacks a parameter check to a division operation which causes the kernel to oops on my board. [ 21.233750] Division by zero in kernel. [ 21.237646] [<c002955c>] (__div0+0x0/0x20) from [<c012561c>] (Ldiv0+0x8/0x10) [ 21.244816] [<c01bef34>] (ds2760_battery_read_status+0x0/0x2a4) from [<c01bf3a4>] (ds2760_battery_get_property+0x30/0xdc) [ 21.255803] r8:c03a22c0 r7:c7886100 r6:00000009 r5:c782fe7c r4:c7886084 [ 21.262518] [<c01bf374>] (ds2760_battery_get_property+0x0/0xdc) from [<c01bde98>] (power_supply_show_property+0x48/0x114) [ 21.273480] r6:c7996000 r5:00000009 r4:00000000 [ 21.278111] [<c01bde50>] (power_supply_show_property+0x0/0x114) from [<c01be158>] (power_supply_uevent+0x188/0x280) [ 21.288537] r8:00000001 r7:c7886100 r6:c7996000 r5:000000b4 r4:00000000 [ 21.295222] [<c01bdfd0>] (power_supply_uevent+0x0/0x280) from [<c015c664>] (dev_uevent+0xd4/0x10c) [ 21.304199] [<c015c590>] (dev_uevent+0x0/0x10c) from [<c0128440>] (kobject_uevent_env+0x180/0x390) [ 21.313170] r5:00000000 r4:c78860ac [ 21.316725] [<c01282c0>] (kobject_uevent_env+0x0/0x390) from [<c0128664>] (kobject_uevent+0x14/0x18) [ 21.325850] [<c0128650>] (kobject_uevent+0x0/0x18) from [<c01bdc34>] (power_supply_changed_work+0x5c/0x70) [ 21.335506] [<c01bdbd8>] (power_supply_changed_work+0x0/0x70) from [<c004d290>] (run_workqueue+0xbc/0x144) [ 21.345167] r4:c7812040 [ 21.347716] [<c004d1d4>] (run_workqueue+0x0/0x144) from [<c004d94c>] (worker_thread+0xa8/0xbc) [ 21.356296] r7:c7812040 r6:c7820b00 r5:c782ffa4 r4:c7812048 [ 21.361957] [<c004d8a4>] (worker_thread+0x0/0xbc) from [<c0051008>] (kthread+0x5c/0x94) [ 21.369971] r7:00000000 r6:c004d8a4 r5:c7812040 r4:c782e000 [ 21.375612] [<c0050fac>] (kthread+0x0/0x94) from [<c00403d0>] (do_exit+0x0/0x688) Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Szabolcs Gyurko <szabolcs.gyurko@tlt.hu> Acked-by: Matt Reimer <mreimer@vpop.net> Acked-by: Anton Vorontsov <cbou@mail.ru> Cc: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12vfs: add missing unlock in sget()Li Zefan
In sget(), destroy_super(s) is called with s->s_umount held, which makes lockdep unhappy. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Menage <menage@google.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12pipe_rdwr_fasync: fix the error handling to prevent the leak/crashOleg Nesterov
If the second fasync_helper() fails, pipe_rdwr_fasync() returns the error but leaves the file on ->fasync_readers. This was always wrong, but since 233e70f4228e78eb2f80dc6650f65d3ae3dbf17c "saner FASYNC handling on file close" we have the new problem. Because in this case setfl() doesn't set FASYNC bit, __fput() will not do ->fasync(0), and we leak fasync_struct with ->fa_file pointing to the freed file. Signed-off-by: Oleg Nesterov <oleg@redhat.com> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Andi Kleen <andi@firstfloor.org> Cc: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12drivers/w1/masters/w1-gpio.c: fix read_bit()Daniel Mack
W1 master implementations are expected to return 0 or 1 from their read_bit() function. However, not all platforms do return these values from gpio_get_value() - namely PXAs won't. Hence the w1 gpio-master needs to break the result down to 0 or 1 itself. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Evgeniy Polyakov <johnpol@2ka.mipt.ru> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12uml: fix WARNING: vmlinux: 'memcpy' exported twiceakpm@linux-foundation.org
Fix the following warning on x86_64: LD vmlinux.o MODPOST vmlinux.o WARNING: vmlinux: 'memcpy' exported twice. Previous export was in vmlinux For x86_64, this symbol is already exported from arch/um/sys-x86_64/ksyms.c. Reported-by: Boaz Harrosh <bharrosh@panasas.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Tested-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12UML on UML fixed: it did not startRenzo Davoli
It is currently impossible to run a user-mode linux machine inside another user-mode linux (UML on UML). It breaks after a few instructions. When it tries to check whether SYSEMU is installed (the inner) UML receives an inconsistent result (from the outer UML). This is the output of a broken attempt: $ ./linux mem=256m ubd0=cow Locating the bottom of the address space ... 0x0 Locating the top of the address space ... 0xc0000000 Core dump limits : soft - 0 hard - NONE Checking that ptrace can change system call numbers...OK Checking ptrace new tags for syscall emulation...unsupported Checking syscall emulation patch for ptrace...check_sysemu : expected SIGTRAP, got status = 256 $ The problem is the following: PTRACE_SYSCALL/SINGLESTEP is currently managed inside arch_ptrace for ARCH=um. PTRACE_SYSEMU/SUSEMU_SINGLESTEP is not captured in arch_ptrace's switch, therefore it is erroneously passed back to ptrace_request (in kernel/ptrace). This simple patch simply forces ptrace to return an error on PTRACE_SYSEMU/SUSEMU_SINGLESTEP as it is unsupported on ARCH=um, and fixes the problem. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Renzo Davoli <renzo@cs.unibo.it> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Jeff Dike <jdike@addtoit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-12x86: use targets in the boot Makefile instead of CLEAN_FILESH. Peter Anvin
Impact: cleanup Instead of using CLEAN_FILES in arch/x86/Makefile, add generated files to targets in arch/x86/boot/Makefile, so they will get naturally cleaned up by "make clean". Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-03-12x86: remove additional vestiges of the zImage/bzImage splitH. Peter Anvin
Impact: cleanup Remove targets that were used for zImage only, and Makefile infrastructure that was there to support the zImage/bzImage split. Reported-by: Paul Bolle <pebolle@tiscali.nl> LKML-Reference: <1236879901.24144.26.camel@test.thuisdomein> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-03-12PCIe: portdrv: call pci_disable_device during removeAlex Chiang
The PCIe port driver calls pci_enable_device() during probe but never calls pci_disable_device() during remove. Cc: stable@kernel.org Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2009-03-12pci: Fix typo in message while disabling HT MSI mappingPrakash Punnoor
"Enabling" should read "Disabling" Signed-off-by: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2009-03-12pci: don't disable too many HT MSI mappingPrakash Punnoor
Prakash's system needs MSI disabled on some bridges, but not all. This seems to be the minimal fix for 2.6.29, but should be replaced during 2.6.30. Signed-off-by: Prakash Punnoor <prakash@punnoor.de> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
