2012-03-12printk/sched: Introduce special printk_sched() for those awkward momentsPeter Zijlstra
There's a few awkward printk()s inside of scheduler guts that people prefer to keep but really are rather deadlock prone. Fudge around it by storing the text in a per-cpu buffer and poll it using the existing printk_tick() handler. This will drop output when its more frequent than once a tick, however only the affinity thing could possible go that fast and for that just one should suffice to notify the admin he's done something silly.. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-wua3lmkt3dg8nfts66o6brne@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-12sched/nohz: Correctly initialize 'next_balance' in 'nohz' idle balancerDiwakar Tundlam
The 'next_balance' field of 'nohz' idle balancer must be initialized to jiffies. Since jiffies is initialized to negative 300 seconds the 'nohz' idle balancer does not run for the first 300s (5mins) after bootup. If no new processes are spawed or no idle cycles happen, the load on the cpus will remain unbalanced for that duration. Signed-off-by: Diwakar Tundlam <dtundlam@nvidia.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1DD7BFEDD3147247B1355BEFEFE4665237994F30EF@HQMAIL04.nvidia.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-12sched: Cleanup cpu_active madnessPeter Zijlstra
Stepan found: CPU0 CPUn _cpu_up() __cpu_up() boostrap() notify_cpu_starting() set_cpu_online() while (!cpu_active()) cpu_relax() <PREEMPT-out> smp_call_function(.wait=1) /* we find cpu_online() is true */ arch_send_call_function_ipi_mask() /* wait-forever-more */ <PREEMPT-in> local_irq_enable() cpu_notify(CPU_ONLINE) sched_cpu_active() set_cpu_active() Now the purpose of cpu_active is mostly with bringing down a cpu, where we mark it !active to avoid the load-balancer from moving tasks to it while we tear down the cpu. This is required because we only update the sched_domain tree after we brought the cpu-down. And this is needed so that some tasks can still run while we bring it down, we just don't want new tasks to appear. On cpu-up however the sched_domain tree doesn't yet include the new cpu, so its invisible to the load-balancer, regardless of the active state. So instead of setting the active state after we boot the new cpu (and consequently having to wait for it before enabling interrupts) set the cpu active before we set it online and avoid the whole mess. Reported-by: Stepan Moskovchenko <stepanm@codeaurora.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1323965362.18942.71.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-12sched: Fix load-balance wreckagePeter Zijlstra
Commit 367456c ("sched: Ditch per cgroup task lists for load-balancing") completely wrecked load-balancing due to a few silly mistakes. Correct those and remove more pointless code. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-zk04ihygwxn7qqrlpaf73b0r@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-02sched: Clean up parameter passing of proc_sched_autogroup_set_nice()Hiroshi Shimamoto
Pass nice as a value to proc_sched_autogroup_set_nice(). No side effect is expected, and the variable err will be overwritten with the return value. Signed-off-by: Hiroshi Shimamoto <h-shimamoto@ct.jp.nec.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/4F45FBB7.5090607@ct.jp.nec.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched: Ditch per cgroup task lists for load-balancingPeter Zijlstra
Per cgroup load-balance has numerous problems, chief amongst them that there is no real sane order in them. So stop pretending it makes sense and enqueue all tasks on a single list. This also allows us to more easily fix the fwd progress issue uncovered by the lock-break stuff. Rotate the list on failure to migreate and limit the total iterations to nr_running (which with releasing the lock isn't strictly accurate but close enough). Also add a filter that skips very light tasks on the first attempt around the list, this attempts to avoid shooting whole cgroups around without affecting over balance. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: pjt@google.com Link: http://lkml.kernel.org/n/tip-tx8yqydc7eimgq7i4rkc3a4g@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched: Rename load-balancing fieldsPeter Zijlstra
s/env->this_/env->dst_/g s/env->busiest_/env->src_/g s/pull_task/move_task/g Makes everything clearer. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: pjt@google.com Link: http://lkml.kernel.org/n/tip-0yvgms8t8x962drpvl0fu0kk@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched: Move load-balancing arguments into helper structPeter Zijlstra
Passing large sets of similar arguments all around the load-balancer gets tiresom when you want to modify something. Stick them all in a helper structure and pass the structure around. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: pjt@google.com Link: http://lkml.kernel.org/n/tip-5slqz0vhsdzewrfk9eza1aon@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/rt: Do not submit new work when PI-blockedThomas Gleixner
When we are PI-blocked then we want to get things done ASAP. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-vw8et3445km5b8mpihf4trae@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/rt: Prevent idle task boostingThomas Gleixner
Idle task boosting is a nono in general. There is one exception, when PREEMPT_RT and NOHZ is active: The idle task calls get_next_timer_interrupt() and holds the timer wheel base->lock on the CPU and another CPU wants to access the timer (probably to cancel it). We can safely ignore the boosting request, as the idle CPU runs this code with interrupts disabled and will complete the lock protected section without being interrupted. So there is no real need to boost. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-755rvsosz7sdzot12a3gbha6@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/wait: Add __wake_up_all_locked() APIThomas Gleixner
For code which protects the waitqueue itself with another lock it makes no sense to acquire the waitqueue lock for wakeup all. Provide __wake_up_all_locked(). This is an optimization on the vanilla kernel (to be used by the PCI code) and an important semantic distinction on -rt. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-ux6m4b8jonb9inx8xafh77ds@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/rt: Document scheduler related skip-resched-check sitesThomas Gleixner
Create a distinction between scheduler related preempt_enable_no_resched() calls and the nearly one hundred other places in the kernel that do not want to reschedule, for one reason or another. This distinction matters for -rt, where the scheduler and the non-scheduler preempt models (and checks) are different. For upstream it's purely documentational. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-gs88fvx2mdv5psnzxnv575ke@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/rt: Use schedule_preempt_disabled()Thomas Gleixner
Coccinelle based conversion. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-24swm5zut3h9c4a6s46x8rws@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/rt: Add schedule_preempt_disabled()Thomas Gleixner
Add helper to get rid of the ever repeating: preempt_enable_no_resched(); schedule(); preempt_disable(); patterns. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-wxx7btox7coby6ifv5vzhzgp@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/rt: Do not throttle when PI boostingPeter Zijlstra
When a runqueue has rt_runtime_us = 0 then the only way it can accumulate rt_time is via PI boosting. That causes the runqueue to be throttled and replenishing does not change anything due to rt_runtime_us = 0. So avoid that situation by clearing rt_time and skip the throttling alltogether. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> [ Changelog ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-7x70cypsotjb4jvcor3edctk@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01sched/rt: Keep period timer ticking when rt throttling is activePeter Zijlstra
When a runqueue is throttled we cannot disable the period timer because that timer is the only way to undo the throttling. We got stale throttling entries when a rq was throttled and then the global sysctl was disabled, which stopped the timer. Signed-off-by: Peter Zijlstra <peterz@infradead.org> [ Added changelog ] Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/n/tip-nuj34q52p6ro7szapuz84i0v@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-03-01Merge branch 'linus' into sched/coreIngo Molnar
Merge reason: we'll queue up dependent patches. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-28ecryptfs: fix printk format warning for size_tRandy Dunlap
Fix printk format warning (from Linus's suggestion): on i386: fs/ecryptfs/miscdev.c:433:38: warning: format '%lu' expects type 'long unsigned int', but argument 4 has type 'unsigned int' and on x86_64: fs/ecryptfs/miscdev.c:433:38: warning: format '%u' expects type 'unsigned int', but argument 4 has type 'long unsigned int' Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Tyler Hicks <tyhicks@canonical.com> Cc: Dustin Kirkland <dustin.kirkland@gazzang.com> Cc: ecryptfs@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-3.0-fixes: GFS2: Read resource groups on mount GFS2: Ensure rindex is uptodate for fallocate GFS2: Read in rindex if necessary during unlink GFS2: Fix race between lru_list and glock ref count
2012-02-28Merge tag 'iommu-fixes-v3.3-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu IOMMU fixes for Linux 3.3-rc5 All the fixes are for the OMAP IOMMU driver. The first patch is the biggest one. It fixes the calls of the function omap_find_iovm_area() in the omap-iommu-debug module which expects a 'struct device' parameter since commit fabdbca instead of an omap_iommu handle. The omap-iommu-debug code still passed the handle to the function which caused a crash. The second patch fixes a NULL pointer dereference in the OMAP code and the third patch makes sure that the omap-iommu is initialized before the omap-isp driver, which relies on the iommu. The last patch is only a workaround until defered probing is implemented. * tag 'iommu-fixes-v3.3-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: ARM: OMAP: make iommu subsys_initcall to fix builtin omap3isp iommu/omap: fix NULL pointer dereference iommu/omap: fix erroneous omap-iommu-debug API calls
2012-02-28GFS2: Read resource groups on mountSteven Whitehouse
This makes mount take slightly longer, but at the same time, the first write to the filesystem will be faster too. It also means that if there is a problem in the resource index, then we can refuse to mount rather than having to try and report that when the first write occurs. In addition, to avoid recursive locking, we hvae to take account of instances when the rindex glock may already be held when we are trying to update the rbtree of resource groups. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-02-28GFS2: Ensure rindex is uptodate for fallocateBob Peterson
This patch fixes a problem whereby gfs2_grow was failing and causing GFS2 to assert. The problem was that when GFS2's fallocate operation tried to acquire an "allocation" it made sure the rindex was up to date, and if not, it called gfs2_rindex_update. However, if the file being fallocated was the rindex itself, it was already locked at that point. By calling gfs2_rindex_update at an earlier point in time, we bring rindex up to date and thereby avoid trying to lock it when the "allocation" is acquired. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-02-28GFS2: Read in rindex if necessary during unlinkBob Peterson
This patch fixes a problem whereby you were unable to delete files until other file system operations were done (such as statfs, touch, writes, etc.) that caused the rindex to be read in. Signed-off-by: Bob Peterson <rpeterso@redhat.com> Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-02-28GFS2: Fix race between lru_list and glock ref countSteven Whitehouse
This patch fixes a narrow race window between the glock ref count hitting zero and glocks being removed from the lru_list. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2012-02-27Merge tag 'ktest-fix-make-min-failed-build-for-real' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest While demoing ktest at ELC in 2012, it was embarrassing that the make_min_config test failed to work because the snowball board I was testing it against had a config that would not build. But the make_min_config only tested the testing part and ignored build failures. The end result was a config file that would not boot. This time, for real. * tag 'ktest-fix-make-min-failed-build-for-real' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Fix make_min_config test when build fails
2012-02-27ktest: Fix make_min_config test when build failsSteven Rostedt
The make_min_config does not take into account when the build fails, resulting in a invalid MIN_CONFIG .config file. When the build fails, it is ignored and the boot test is executed, using the previous built kernel. The configs that should be tested are not tested and they may be added or removed depending on the result of the last kernel that succeeded to be built. If the build fails, mark the current config as a failure and the configs that were disabled may still be needed. Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2012-02-27Merge git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfsLinus Torvalds
Here are some trivial NTFS changes (a spelling fix and two use before NULL check cases found by Coverity as well as an update in MAINTAINERS for the path to the ntfs git repo) together with a simple LDM fix for parsing fragmented VBLKs. * git://git.kernel.org/pub/scm/linux/kernel/git/aia21/ntfs: NTFS: Update git repo path in MAINTAINERS file. LDM: Fix reassembly of extended VBLKs. NTFS: Correct two spelling errors "dealocate" to "deallocate" in mft.c. NTFS: Do not dereference pointer before checking for NULL. NTFS: Remove unused variable.
2012-02-27Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mce/AMD: Fix UP build error x86: Specify a size for the cmp in the NMI handler x86/nmi: Test saved %cs in NMI to determine nested NMI case x86/amd: Fix L1i and L2 cache sharing information for AMD family 15h processors x86/microcode: Remove noisy AMD microcode warning
2012-02-27Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/events: Revert trace_sched_stat_sleeptime()
2012-02-27Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: genirq: Handle pending irqs in irq_startup() genirq: Unmask oneshot irqs when thread was not woken
2012-02-27compat: fix compile breakage on s390Heiko Carstens
The new is_compat_task() define for the !COMPAT case in include/linux/compat.h conflicts with a similar define in arch/s390/include/asm/compat.h. This is the minimal patch which fixes the build issues. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-27ARM: OMAP: make iommu subsys_initcall to fix builtin omap3ispOhad Ben-Cohen
omap3isp depends on omap's iommu and will fail to probe if initialized before it (which always happen if they are builtin). Make omap's iommu subsys_initcall as an interim solution until the probe deferral mechanism is merged. Reported-by: James <angweiyang@gmail.com> Debugged-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Ohad Ben-Cohen <ohad@wizery.com> Cc: stable <stable@vger.kernel.org> Cc: Tony Lindgren <tony@atomide.com> Cc: Hiroshi Doyu <hdoyu@nvidia.com> Cc: Joerg Roedel <Joerg.Roedel@amd.com> Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
2012-02-27NTFS: Update git repo path in MAINTAINERS file.Anton Altaparmakov
Signed-off-by: Anton Altaparmakov <anton@tuxera.com>
2012-02-27Merge branch 'master' of /Volumes/CaseSensitiveDisk/linuxAnton Altaparmakov
2012-02-26Merge tag 'stable/for-linus-fixes-3.3-rc5' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen Two fixes to fix a memory corruption bug when WC pages never get converted back to WB but end up being recycled in the general memory pool as WC. There is a better way of fixing this, but there is not enough time to do the full benchmarking to pick one of the right options - so picking the one that favors stability for right now. Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> * tag 'stable/for-linus-fixes-3.3-rc5' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/xen: xen/pat: Disable PAT support for now. xen/setup: Remove redundant filtering of PTE masks.
2012-02-26Merge tag 'for-linus' of git://github.com/rustyrussell/linuxLinus Torvalds
* tag 'for-linus' of git://github.com/rustyrussell/linux: mod/file2alias: make modpost compile on darwin again
2012-02-26autofs4 - update MAINTAINERS mailing list entryIan Kent
The autofs mailing list has moved to vger.kernel.org. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-27mod/file2alias: make modpost compile on darwin againAndreas Bießmann
commit e49ce14150c64b29a8dd211df785576fa19a9858 breaks cross compiling the linux kernel on darwin hosts. This fix introduce some minimal glue to adopt linker section handling for darwin hosts. Signed-off-by: Andreas Bießmann <andreas@biessmann.de> CC: Rusty Russell <rusty@rustcorp.com.au> CC: Greg Kroah-Hartman <gregkh@linuxfoundation.org> CC: Jochen Friedrich <jochen@scram.de> CC: Samuel Ortiz <sameo@linux.intel.com> CC: "K. Y. Srinivasan" <kys@microsoft.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Bernhard Walle <bernhard@bwalle.de>
2012-02-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
1) ICMP sockets leave err uninitialized but we try to return it for the unsupported MSG_OOB case, reported by Dave Jones. 2) Add new Zaurus device ID entries, from Dave Jones. 3) Pointer calculation in hso driver memset is wrong, from Dan Carpenter. 4) ks8851_probe() checks unsigned value as negative, fix also from Dan Carpenter. 5) Fix crashes in atl1c driver due to TX queue handling, from Eric Dumazet. I anticipate some TX side locking fixes coming in the near future for this driver as well. 6) The inline directive fix in Bluetooth which was breaking the build only with very new versions of GCC, from Johan Hedberg. 7) Fix crashes in the ATP CLIP code due to ARP cleanups this merge window, reported by Meelis Roos and fixed by Eric Dumazet. 8) JME driver doesn't flush RX FIFO correctly, from Guo-Fu Tseng. 9) Some ip6_route_output() callers test the return value for NULL, but this never happens as the convention is to return a dst entry with dst->error set. Fixes from RonQing Li. 10) Logitech Harmony 900 should be handled by zaurus driver not cdc_ether, update white lists and black lists accordingly. From Scott Talbert. 11) Receiving from certain kinds of devices there won't be a MAC header, so there is no MAC header to fixup in the IPSEC code, and if we try to do it we'll crash. Fix from Eric Dumazet. 12) Port type array indexing off-by-one in mlx4 driver, fix from Yevgeny Petrilin. 13) Fix regression in link-down handling in davinci_emac which causes all RX descriptors to be freed up and therefore RX to wedge completely, from Christian Riesch. 14) It took two attempts, but ctnetlink soft lockups seem to be cured now, from Pablo Neira Ayuso. 15) Endianness bug fix in ENIC driver, from Santosh Nayak. 16) The long ago conversion of the PPP fragmentation code over to abstracted SKB list handling wasn't perfect, once we get an out of sequence SKB we don't flush the rest of them like we should. From Ben McKeegan. 17) Fix regression of ->ip_summed initialization in sfc driver. From Ben Hutchings. 18) Bluetooth timeout mistakenly using msecs instead of jiffies, from Andrzej Kaczmarek. 19) Using _sync variant of work cancellation results in deadlocks, use the non _sync variants instead. From Andre Guedes. 20) Bluetooth rfcomm code had reference counting problems leading to crashes, fix from Octavian Purdila. 21) The conversion of netem over to classful qdisc handling added two bugs to netem_dequeue(), fixes from Eric Dumazet. 22) Missing pci_iounmap() in ATM Solos driver. Fix from Julia Lawall. 23) b44_pci_exit() should not have __exit tag since it's invoked from non-__exit code. From Nikola Pajkovsky. 24) The conversion of the neighbour hash tables over to RCU added a race, fixed here by adding the necessary reread of tbl->nht, fix from Michel Machado. 25) When we added VF (virtual function) attributes for network device dumps, this potentially bloats up the size of the dump of one network device such that the dump size is too large for the buffer allocated by properly written netlink applications. In particular, if you add 255 VFs to a network device, parts of GLIBC stop working. To fix this, we add an attribute that is used to turn on these extended portions of the network device dump. Sophisticaed applications like 'ip' that want to see this stuff will be changed to set the attribute, whereas things like GLIBC that don't care about VFs simply will not, and therefore won't be busted by the mere presence of VFs on a network device. Thanks to the tireless work of Greg Rose on this fix. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (53 commits) sfc: Fix assignment of ip_summed for pre-allocated skbs ppp: fix 'ppp_mp_reconstruct bad seq' errors enic: Fix endianness bug. gre: fix spelling in comments netfilter: ctnetlink: fix soft lockup when netlink adds new entries (v2) Revert "netfilter: ctnetlink: fix soft lockup when netlink adds new entries" davinci_emac: Do not free all rx dma descriptors during init mlx4_core: Fixing array indexes when setting port types phy: IC+101G and PHY_HAS_INTERRUPT flag netdev/phy/icplus: Correct broken phy_init code ipsec: be careful of non existing mac headers Move Logitech Harmony 900 from cdc_ether to zaurus hso: memsetting wrong data in hso_get_count() netfilter: ip6_route_output() never returns NULL. ethernet/broadcom: ip6_route_output() never returns NULL. ipv6: ip6_route_output() never returns NULL. jme: Fix FIFO flush issue atm: clip: remove clip_tbl ipv4: ping: Fix recvmsg MSG_OOB error handling. rtnetlink: Fix problem with buffer allocation ...
2012-02-26Fix autofs compile without CONFIG_COMPATLinus Torvalds
The autofs compat handling fix caused a compile failure when CONFIG_COMPAT isn't defined. Instead of adding random #ifdef'fery in autofs, let's just make the compat helpers earlier to use: without CONFIG_COMPAT, is_compat_task() just hardcodes to zero. We could probably do something similar for a number of other cases where we have #ifdef's in code, but this is the low-hanging fruit. Reported-and-tested-by: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-25Linux 3.3-rc5v3.3-rc5Linus Torvalds
2012-02-25Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Couple of minor driver fixes. * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: hwmon: (max34440) Fix resetting temperature history hwmon: (f75375s) Fix register write order when setting fans to full speed hwmon: (ads1015) Fix file leak in probe function hwmon: (max6639) Fix PPR register initialization to set both channels hwmon: (max6639) Fix FAN_FROM_REG calculation
2012-02-25Merge branch 'rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild three kbuild fixes for 3.3: - make deb-pkg symlink race fix. - make coccicheck fix. - Dropping the check for modutils. This is not a regression, but allows the module-init-tools replacement kmod work with the 3.3 kernel. * 'rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild: coccicheck: change handling of C={1,2} when M= is set builddeb: Don't create files in /tmp with predictable names kbuild: do not check for ancient modutils tools
2012-02-25autofs: work around unhappy compat problem on x86-64Ian Kent
When the autofs protocol version 5 packet type was added in commit 5c0a32fc2cd0 ("autofs4: add new packet type for v5 communications"), it obvously tried quite hard to be word-size agnostic, and uses explicitly sized fields that are all correctly aligned. However, with the final "char name[NAME_MAX+1]" array at the end, the actual size of the structure ends up being not very well defined: because the struct isn't marked 'packed', doing a "sizeof()" on it will align the size of the struct up to the biggest alignment of the members it has. And despite all the members being the same, the alignment of them is different: a "__u64" has 4-byte alignment on x86-32, but native 8-byte alignment on x86-64. And while 'NAME_MAX+1' ends up being a nice round number (256), the name[] array starts out a 4-byte aligned. End result: the "packed" size of the structure is 300 bytes: 4-byte, but not 8-byte aligned. As a result, despite all the fields being in the same place on all architectures, sizeof() will round up that size to 304 bytes on architectures that have 8-byte alignment for u64. Note that this is *not* a problem for 32-bit compat mode on POWER, since there __u64 is 8-byte aligned even in 32-bit mode. But on x86, 32-bit and 64-bit alignment is different for 64-bit entities, and as a result the structure that has exactly the same layout has different sizes. So on x86-64, but no other architecture, we will just subtract 4 from the size of the structure when running in a compat task. That way we will write the properly sized packet that user mode expects. Not pretty. Sadly, this very subtle, and unnecessary, size difference has been encoded in user space that wants to read packets of *exactly* the right size, and will refuse to touch anything else. Reported-and-tested-by: Thomas Meyer <thomas@m3y3r.de> Signed-off-by: Ian Kent <raven@themaw.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-24Merge tag 'rdma-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband One InfiniBand/RDMA regression fix for 3.3: - mlx4 SR-IOV changes added static exported functions, which doesn't build on powerpc at least. Fix from Doug Ledford for this. * tag 'rdma-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: mlx4_core: Exported functions can't be static
2012-02-24Merge branch 'sfc-3.3' of git://git.kernel.org/pub/scm/linux/kernel/git/bwh/sfcDavid S. Miller
2012-02-25sfc: Fix assignment of ip_summed for pre-allocated skbsBen Hutchings
When pre-allocating skbs for received packets, we set ip_summed = CHECKSUM_UNNCESSARY. We used to change it back to CHECKSUM_NONE when the received packet had an incorrect checksum or unhandled protocol. Commit bc8acf2c8c3e43fcc192762a9f964b3e9a17748b ('drivers/net: avoid some skb->ip_summed initializations') mistakenly replaced the latter assignment with a DEBUG-only assertion that ip_summed == CHECKSUM_NONE. This assertion is always false, but it seems no-one has exercised this code path in a DEBUG build. Fix this by moving our assignment of CHECKSUM_UNNECESSARY into efx_rx_packet_gro(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
2012-02-24Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6 SCSI fixes on 20120224: "This is a set of assorted bug fixes for power management, mpt2sas, ipr, the rdac device handler and quite a big chunk for qla2xxx (plus a use after free of scsi_host in scsi_scan.c). " * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi-rc-fixes-2.6: [SCSI] scsi_dh_rdac: Fix for unbalanced reference count [SCSI] scsi_pm: Fix bug in the SCSI power management handler [SCSI] scsi_scan: Fix 'Poison overwritten' warning caused by using freed 'shost' [SCSI] qla2xxx: Update version number to 8.03.07.13-k. [SCSI] qla2xxx: Proper detection of firmware abort error code for ISP82xx. [SCSI] qla2xxx: Remove resetting memory during device initialization for ISP82xx. [SCSI] qla2xxx: Complete mailbox command timedout to avoid initialization failures during next reset cycle. [SCSI] qla2xxx: Remove check for null fcport from host reset handler. [SCSI] qla2xxx: Correct out of bounds read of ISP2200 mailbox registers. [SCSI] qla2xxx: Remove errant clearing of MBX_INTERRUPT flag during CT-IOCB processing. [SCSI] qla2xxx: Clear options-flags while issuing stop-firmware mbx command. [SCSI] qla2xxx: Add an "is reset active" helper. [SCSI] qla2xxx: Add check for null fcport references in qla2xxx_queuecommand. [SCSI] qla2xxx: Propagate up abort failures. [SCSI] isci: Fix NULL ptr dereference when no firmware is being loaded [SCSI] ipr: fix eeh recovery for 64-bit adapters [SCSI] mpt2sas: Fix mismatch in mpt2sas_base_hard_reset_handler() mutex lock-unlock
2012-02-24ppp: fix 'ppp_mp_reconstruct bad seq' errorsBen McKeegan
This patch fixes a (mostly cosmetic) bug introduced by the patch 'ppp: Use SKB queue abstraction interfaces in fragment processing' found here: http://www.spinics.net/lists/netdev/msg153312.html The above patch rewrote and moved the code responsible for cleaning up discarded fragments but the new code does not catch every case where this is necessary. This results in some discarded fragments remaining in the queue, and triggering a 'bad seq' error on the subsequent call to ppp_mp_reconstruct. Fragments are discarded whenever other fragments of the same frame have been lost. This can generate a lot of unwanted and misleading log messages. This patch also adds additional detail to the debug logging to make it clearer which fragments were lost and which other fragments were discarded as a result of losses. (Run pppd with 'kdebug 1' option to enable debug logging.) Signed-off-by: Ben McKeegan <ben@netservers.co.uk> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-24enic: Fix endianness bug.Santosh Nayak
Sparse complaints the endian bug. Signed-off-by: Santosh Nayak <santoshprasadnayak@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
