Update maintainers list.
Signed-off-by: Antonino Daplas <adaplas@pol.net>
No need for a file argument. If we'd really need it it's in vma->vm_file
already. gbefb and sgivwfb used to set vma->vm_file to the file argument, but
the kernel alrady did that.
The ioctl and file arguments to ->fb_mmap are totally unused and there's not
reason a driver should need them.
Also update the ->fb_compat_ioctl prototype to be the same as ->fb_mmap.
Seems that the CS5530A chip used in Geode GX1 systems has some crazy feature
that causes SMI traps when accessing the PCI configuration space of the video
device. Various GX1 BIOSes seem to use this 'feature' to hide the real BARs
of the device. This patch disables these traps (in an early PCI fixup) so
that Linux sees the real, physical BARs and not the virtual ones provided by
the BIOS.
This should allow the GX1 framebuffer driver to work on more systems that have
different BIOSes as the driver no longer guesses at what the virtual BARs
mean.
I'm not entirely sure it the correct solution as I can neither test regular
VGA console nor the X's 'cyrix' video driver so there might be some breakage
there -- probably best to get some more testers before applying it.
On a Dell Latitude CPi-A I noticed a strangeness wrt. the handling of an
external monitor by the neomagic framebuffer driver, namely when the laptop is
docked in a C/Dock II with the lid shut.
A cold boot would result in the BIOS configuring the video chip to use the
"external monitor only" mode, yet neofb would default to "internal LCD only".
An attempt for a quick fix by using the Fn-F8 keystroke to toggle the display
combination modes resulted in a reproductible hard lock, powering down being
the only solution.
The attached patch makes neofb probe the register for the current display
mode, using that value as a default if nothing was specified as kernel/module
parameter.
Signed-off-by: Randy Dunlap <rdunlap@xenotime.net>
Add 2 lockd kernel parameters and spell 2 others correctly.
Cc: Neil Brown <neilb@cse.unsw.edu.au>
Cc: Olaf Kirch <okir@suse.de>
Cc: <buraphalinuxserver@gmail.com>
This patch adds support for the Intel IXDP2351 to the CS89x0 driver.
Signed-off-by: Deepak Saxena <dsaxena@plexity.net>
cs89x0 inconsistently used 'int' and 'u32' for device register data.
As the cs89x0 is a 16-bit chip, change the I/O accessors over to 'u16'.
(Spotted by Deepak Saxena.)
Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org>
Credit Dmitry Pervushin for the PNX010X platform support.
This fixes http://bugzilla.kernel.org/show_bug.cgi?id=5854
Root cause:
The dell_rbu driver creates entries in /sys/class/firmware/dell_rbu/ by
calling request_firmware_nowait (without hotplug ) this function inturn
starts a kernel thread which creates the entries in
/sys/class/firmware/dell_rbu/loading , data and the thread waits on the
user action to return control back to the callback fucntion of dell_rbu.
The thread calls wait_on_completion which puts it in a D state until the
user action happens. If there is no user action happening the load average
goes up as the thread D state is taken in to account. Also after
downloading the BIOS image the enrties go away momentarily but they are
recreated from the callback function in dell_rbu. This causes the thread
to get recreated causing the load average to permenently stay around 1.
Fix:
The dell_rbu also creates the entry
/sys/devices/platform/dell_rbu/image_type at driver load time. The image
type by default is mono if required the user can echo packet to image_type
to make the BIOS update mechanism using packets. Also by echoing init in
to image_type the /sys/class/firmware/dell_rbu entries can be created.
The driver code was changed to not create /sys/class/firmware/dell_rbu
entries during load time, and also to not create the above entries from the
callback function. The entries are only created by echoing init to
/sys/devices/platform/dell_rbu/image_type The user now needs to create the
entries to download the image monolithic or packet. This fixes the issue
since the kernel thread only is created when ever the user is ready to
download the BIOS image; this minimizes the life span of the kernel thread
and the load average goes back to normal.
Signed off by Abhay Salunke <abhay_salunke@dell.com>
Remove the remaining kmalloc() wrapper bits from fs/smbfs/.
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi>
Remove remaining kmalloc wrapper bits from fs/ncpfs/.
After abandon-gcc-295x.patch, this relocates the error-out-early comment.
Signed-off-by: Coywolf Qi Hunt <qiyong@fc-cn.com>
fs/quota_v2.c can, under some conditions, issue a kernel message that says,
in totality, 'failed read'. This patch does the following:
1) Gives a hint who issued the error message, so people reading the logs
don't have to go grepping the entire kernel tree (with 11 false
positives).
2) Say what amount of data we expected, and actually got.
Signed-off-by: Valdis Kletnieks <valdis.kletnieks@vt.edu>
Cc: Jan Kara <jack@ucw.cz>
Remove redundant NULL check in reiserfs_lookup() as d_splice_alias() can take
NULL inode as input.
Remove redundant NULL check in isofs_lookup() as d_splice_alias() can take
Remove redundant NULL check in ext3_lookup() as d_splice_alias() can take NULL
inode as input.
Remove redundant NULL check in ext2_lookup() as d_splice_alias() can take NULL
inode as input.
The problem, reported in:
http://bugzilla.kernel.org/show_bug.cgi?id=5859
and by various other email messages and lkml posts is that the cpuset hook
in the oom (out of memory) code can try to take a cpuset semaphore while
holding the tasklist_lock (a spinlock).
One must not sleep while holding a spinlock.
The fix seems easy enough - move the cpuset semaphore region outside the
tasklist_lock region.
This required a few lines of mechanism to implement. The oom code where
the locking needs to be changed does not have access to the cpuset locks,
which are internal to kernel/cpuset.c only. So I provided a couple more
cpuset interface routines, available to the rest of the kernel, which
simple take and drop the lock needed here (cpusets callback_sem).
Signed-off-by: Paul Jackson <pj@sgi.com>
The QUEUE_ORDERED_* numbers got renumbered and by accident the dasd driver
was changed to use QUEUE_ORDERED_DRAIN instead of QUEUE_ORDERED_TAG.
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com>
The chps[] array in struct channel_subsystem is one too short; therefore the
code doesn't realize the chpid ff is already known. When several devices on
chpid ff become available, the message "new_channel_path: could not register
ff" is displayed for every device but the first one.
finish_arch_switch needs to update the user cpu time as well, not just the
system cpu time. Otherwise the partial user cpu time of a process that is
stored in the lowcore will be (mis-)accounted to the next process.
Add the missing third argument to the blk_queue_ordered call and use the
constant QUEUE_ORDERED_DRAIN instead of "1".
Define a dummy pm_power_off pointer to make sys_reboot happy.
Remove useless spin_retry_counter and fix compilation for UP kernels.
Add missing fourth argument to cpcmd calls under !CONFIG_SMP.
Add an include of linux/compiler.h in sigcontext.h to avoid compiler errors in
user space apps because of a missing definition for __user.
The show_task function walks the kernel stack backchain of processes assuming
that the processes are not running. Since this assumption is not correct
walking the backchain can lead to an addressing exception and therefore to a
kernel hang. So prevent the kernel hang (you still get incorrect results)
verity that all read accesses are within the bounds of the kernel stack before
performing them.
Fix processing of messages larger than 2 * SHA256_BLOCK_SIZE.
Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com>
Call KM[C] only with a multiple of block size. Check return value of KM[C]
instructions and complain about erros
Provide ECB and CBC encrypt / decrypt functions to crypto API to speed up our
hardware accelerated DES implementation. This new functions allow the crypto
API to call ECB / CBC directly with large blocks in difference to the old
functions that were calles with algorithm block size (8 bytes for DES).
This is up to factor 10 faster than our old hardware implementation :)
Beautify the s390 in-kernel-crypto des code.
Recent changes caused part of stack traces from SysRq-T to print at
KERN_EMERG loglevel. Also, parts of stack dump during oops were failing to
print at that level when they should.
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
Move the HOTPLUG_CPU option under "Processor type" instead of under "Bus
options". This makes it the same for i386 as most other processor types
(arm, ia64, parisc, ppc, s390, & x86_64; but not for powerpc). Besides, it
takes me too long to find it under Bus options. I can't be the only person
who has trouble finding it.
Add support for the PowerPC MPC83xx watchdog. The MPC83xx has a simple
watchdog that once enabled it can not be stopped, has some simple timeout
range selection, and the ability to either reset the processor or take a
machine check.
Signed-off-by: Dave Updegraff <dave@cray.org>
Cc: Wim Van Sebroeck <wim@iguana.be>
Anything that writes into a tmpfs filesystem is liable to disproportionately
decrease the available memory on a particular node. Since there's no telling
what sort of application (e.g. dd/cp/cat) might be dropping large files
there, this lets the admin choose the appropriate default behavior for their
site's situation.
Introduce a tmpfs mount option which allows specifying a memory policy and
a second option to specify the nodelist for that policy. With the default
policy, tmpfs will behave as it does today. This patch adds support for
preferred, bind, and interleave policies.
The default policy will cause pages to be added to tmpfs files on the node
which is doing the writing. Some jobs expect a single process to create
and manage the tmpfs files. This results in a node which has a
significantly reduced number of free pages.
With this patch, the administrator can specify the policy and nodes for
that policy where they would prefer allocations.
This patch was originally written by Brent Casavant and Hugh Dickins. I
added support for the bind and preferred policies and the mpol_nodelist
mount option.
Signed-off-by: Brent Casavant <bcasavan@sgi.com>
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Signed-off-by: Robin Holt <holt@sgi.com>
Some people apparently run CONFIG_NUMA without CONFIG_SWAP. The migration
code currently depends on swap. This patch provides a set of inline
fallback functions so that the kernel properly compiles. However, calls to
migration functions will fail.
Signed-off-by: Christoph Lameter <clameter@sgi.com>
This is a 2.6 patch that adds support for the watchdog timer built into the
EPX-C3 single board computer manufactured by Winsystems, Inc.
Driver details:
This is for x86 only. This watchdog is pretty basic and simple. It is
only configurable via jumpers on the SBC, and it only has either a 1.5s or
200s interval. The watchdog can either be auto-configured to start as soon
as the machine powers up (bad idea for the 1.5s interval!) or it can be
enabled and disabled by writing to io port 0x1ee. Petting the watchdog
involves writing any value to io port 0x1ef.
The only unfortunate thing about this watchdog (and it is not at all
uncommmon in watchdogs that linux supports) is that it is not a PCI or
ISA-PNP device and as such it isn't at all probeable. Either the watchdog
exists as 2 bytes at 0x1ee, or it doesn't. Thus, using this driver on a
machine that doesn't have that watchdog can potentially hang/crash the
system, etc. So only use this driver if you in fact are on a Winsystems
EPX-C3 SBC.
Anyway this driver fits into the already-existing watchdog framework quite
nicely and I already tested it on my EPX-C3 and it works like a charm.
Signed-off-by: Calin A. Culianu <calin@ajvar.org>
LD .tmp_vmlinux1
/usr/lib/gcc-lib/i486-linux/3.3.4/../../../libc.a(mktime.o): In function `timelocal':
: multiple definition of `mktime'
kernel/built-in.o:kernel/time.c:604: first defined here
/usr/bin/ld: Warning: size of symbol `mktime' changed from 134 in kernel/built-in.o to 44 in /usr/lib/gcc-lib/i486-linux/3.3.4/../../../libc.a(mktime.o)
collect2: ld returned 1 exit status
Signed-off-by: Miklos Szeredi <miklos@szeredi.hu>
Cc: Jeff Dike <jdike@addtoit.com>
Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it>
Remove the "inline" keyword from a bunch of big functions in the kernel with
the goal of shrinking it by 30kb to 40kb
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Acked-by: Jeff Garzik <jgarzik@pobox.com>
Add a new SCHED_BATCH (3) scheduling policy: such tasks are presumed
CPU-intensive, and will acquire a constant +5 priority level penalty. Such
policy is nice for workloads that are non-interactive, but which do not
want to give up their nice levels. The policy is also useful for workloads
that want a deterministic scheduling policy without interactivity causing
extra preemptions (between that workload's tasks).
Cc: Michael Kerrisk <mtk-manpages@gmx.net>
Add driver support for a 2 port PCI IOC3-based serial card on Altix boxes:
This is a re-submission. On the original submission I was asked to
organize the code so that the MIPS ioc3 ethernet and serial parts could be
used with this driver. Stanislaw Skowronek was kind enough to provide the
shim layer for this - thanks Stanislaw. This patch includes the shim layer
and the Altix PCI ioc3 serial driver. The MIPS merged ioc3 ethernet and
serial support is forthcoming.
Signed-off-by: Patrick Gefre <pfg@sgi.com>
A Christoph suggested that the /proc/devices file be converted to use the
seq_file interface. This patch does that.
I've obxerved one or two installation that had sufficiently large sans that
they overran the 4k limit on /proc/devices.
Signed-off-by: Neil Horman <nhorman@redhat.com>
We forgot to initialise a couple of nameidata fields.
Fixed the refcounting on failure exits in sys_mq_open() and
cleaned the logics up. Rules are actually pretty simple - dentry_open()
expects vfsmount and dentry to be pinned down and it either transfers
them into created struct file or drops them. Old code had been very
confused in that area - if dentry_open() had failed either in do_open()
or do_create(), we ended up dentry and mqueue_mnt dropped twice, once
by dentry_open() cleanup and then by sys_mq_open().
Fix consists of making the rules for do_create() and do_open()
same as for dentry_open() and updating the sys_mq_open() accordingly;
that actually leads to more straightforward code and less work on
normal path.
Signed-off-by: Al Viro <aviro@redhat.com>
