2006-12-04[PATCH] net: smc91x add missing bracketMariusz Kozlowski
Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] sk98lin debug build fixMariusz Kozlowski
Fix parenthesis mismatch. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] declance: Support the I/O ASIC LANCE w/o TURBOchannelMaciej W. Rozycki
The onboard LANCE of I/O ASIC systems is not a TURBOchannel device, at least from the software point of view. Therefore it does not rely on any kernel TURBOchannel bus services and can be supported even if support for TURBOchannel has not been enabled in the configuration. Tested with the onboard LANCE of a DECstation 5000/133. Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] declance: Fix PMAX and PMAD supportMaciej W. Rozycki
The shared buffer used by the LANCE on the PMAX only supports halfword (16-bit) accesses. And the PMAD has the buffer wired differently. This is a change to fix these issues. Tested with a DECstation 2100 (thanks Flo for making this possible) and a DECstation 5000/133 (both the PMAD and the onboard LANCE). Signed-off-by: Maciej W. Rozycki <macro@linux-mips.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] bonding: incorrect bonding state reported via ioctlAndy Gospodarek
This is a small fix-up to finish out the work done by Jay Vosburgh to add carrier-state support for bonding devices. The output in /proc/net/bonding/bondX was correct, but when collecting the same info via an iotcl it could still be incorrect. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] Update smc91x driver with ARM Versatile board infoDeepak Saxena
We need to specify a Versatile-specific SMC_IRQ_FLAGS value or the new generic IRQ layer will complain thusly: No IRQF_TRIGGER set_type function for IRQ 25 (<NULL>) Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Cc: Jeff Garzik <jeff@garzik.org> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Nicolas Pitre <nico@cam.org> On Fri, 20 Oct 2006 22:50:40 +0100 Russell King <rmk@arm.linux.org.uk> wrote: > On Fri, Oct 20, 2006 at 02:42:04PM -0700, akpm@osdl.org wrote: > > We need to specify a Versatile-specific SMC_IRQ_FLAGS value or the new > > generic IRQ layer will complain thusly: > > I don't think I heard anything back from my previous suggestion that > the IRQ flags are passed through the platform device IRQ resource. > > Doing so would avoid adding yet another platform specific block into > the file. > > BTW, Integrator platforms will also suffer from this, which will add > another ifdef to this header. > > Let's do it right and arrange to pass these flags from the platform > code. It's not like they're in a critical path. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04Merge branch 'netdev-2.6.20' of ↵Jeff Garzik
master.kernel.org:/pub/scm/linux/kernel/git/viro/bird into tmp
2006-12-04Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: (82 commits) [PATCH] pata_ali: small fixes [PATCH] pata_via: VIA 8251 bridged systems are now out and about [PATCH] trivial piix: swap bogus dot for comma space [PATCH] sata_promise: PHYMODE4 fixup [PATCH] libata: always use polling IDENTIFY [libata] pata_cs5535: fix build [PATCH] ahci: do not powerdown during initialization [PATCH] libata: prepare ata_sg_clean() for invocation from EH [PATCH] libata: separate out rw ATA taskfile building into ata_build_rw_tf() [PATCH] libata: implement ata_exec_internal_sg() [PATCH] libata: make sure IRQ is cleared after ata_bmdma_freeze() [PATCH] libata: move BMDMA host status recording from EH to interrupt handler [PATCH] libata: make sure sdev doesn't go away while rescanning [PATCH] libata: don't request sense if the port is frozen [PATCH] libata: fix READ CAPACITY simulation [PATCH] libata: implement ATA_FLAG_SETXFER_POLLING and use it in pata_via, take #2 [PATCH] libata: set IRQF_SHARED for legacy PCI IDE IRQs [PATCH] libata: remove unused HSM_ST_UNKNOWN [PATCH] libata: kill unnecessary sht->max_sectors initializations [PATCH] libata: add missing sht->slave_destroy ...
2006-12-04[PATCH] ns83820 annotationsAl Viro
2006-12-04[PATCH] myri10ge annotationsAl Viro
2006-12-04[PATCH] drivers/net/arm missing __devinitAl Viro
2006-12-04[PATCH] trivial missing __init in drivers/net/*Al Viro
2006-12-04[PATCH] mv643xx_eth.c NULL noise removalAl Viro
2006-12-04[PATCH] __iomem annotations: smc91xAl Viro
2006-12-04[PATCH] pata_ali: small fixesAlan
Switch to pci_get_bus_and_slot because some x86 systems seem to be handing us a device with dev->bus = NULL. Also don't apply the isa fixup to revision C6 and later of the chip. Really we need to work out wtf is handing us pdev->bus = NULL, but firstly and more importantly we need the drivers working. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-12-04[PATCH] pata_via: VIA 8251 bridged systems are now out and aboutAlan
2006-12-04[PATCH] trivial piix: swap bogus dot for comma spaceAlan
2006-12-04[PATCH] fix fallout from header dependency trimmingAl Viro
OK, that seems to be enough to deal with the mess. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04netfilter.h needs rcuupdate.h for RCU locking functionsLinus Torvalds
This was exposed by Al's recent header file dependency reduction patches.. Cc: Al Viro <viro@ftp.linux.org.uk> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04Merge branch 'for-linus4' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/viro/bird * 'for-linus4' of master.kernel.org:/pub/scm/linux/kernel/git/viro/bird: [PATCH] severing poll.h -> mm.h [PATCH] severing skbuff.h -> mm.h [PATCH] severing skbuff.h -> poll.h [PATCH] severing skbuff.h -> highmem.h [PATCH] severing uaccess.h -> sched.h [PATCH] severing fs.h, radix-tree.h -> sched.h [PATCH] severing module.h->sched.h
2006-12-04Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [SUNHME]: Fix for sunhme failures on x86 [XFRM] xfrm_user: Better validation of user templates. [DCCP] tfrc: Binary search for reverse TFRC lookup [DCCP] ccid3: Deprecate TFRC_SMALLEST_P [DCCP] tfrc: Identify TFRC table limits and simplify code [DCCP] tfrc: Add protection against invalid parameters to TFRC routines [DCCP] tfrc: Fix small error in reverse lookup of p for given f(p) [DCCP] tfrc: Document boundaries and limits of the TFRC lookup table [DCCP] ccid3: Fix warning message about illegal ACK [DCCP] ccid3: Fix bug in calculation of send rate [DCCP]: Fix BUG in retransmission delay calculation [DCCP]: Use higher RTO default for CCID3
2006-12-04[PATCH] Enable RAID autorun on Mac partition tables.David Woodhouse
Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: (34 commits) [S390] Don't use small stacks when lockdep is used. [S390] cio: Use device_reprobe() instead of bus_rescan_devices(). [S390] cio: Retry internal operations after vary off. [S390] cio: Use path verification for last path gone after vary off. [S390] non-unique constant/macro identifiers. [S390] Memory detection fixes. [S390] cio: Make ccw_dev_id_is_equal() more robust. [S390] Convert extmem spin_lock into a mutex. [S390] set KBUILD_IMAGE. [S390] lockdep: show held locks when showing a stackdump [S390] Add dynamic size check for usercopy functions. [S390] Use diag260 for memory size detection. [S390] pfault code cleanup. [S390] Cleanup memory_chunk array usage. [S390] Misaligned wait PSW at memory detection. [S390] cpu shutdown rework [S390] cpcmd <-> __cpcmd calling issues [S390] Bad kexec control page allocation. [S390] Reset infrastructure for re-IPL. [S390] Some documentation typos. ...
2006-12-04[PATCH] m68knommu: fix missing bracket in scatterlist.hGreg Ungerer
This patch adds missing bracket. Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: fix dma-mapping.hGreg Ungerer
Make the m68knommu DMA handling consistent with other architectures. Compile problems pointed out by Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: remove __rom_end from 68360 startup codeGreg Ungerer
Remove use of __rom_end symbol all together. This helps clean out the miscellaneous symbols lying around in the m68knommu linker script. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: memory register defines for 520x ColdFire CPU'sGreg Ungerer
Here is a small patch to automatically detect the DRAM size on m520x. It was generated against 2.6.17-uc0, and tested on an Intec 5208 dev board. (This part of the patch if the memory register defines for the 520x ColdFire CPU family - Greg). Signed-off-by: Michael Broughton <mbobowik@telusplanet.net> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: auto detect memory size on M5208EVB boardMichael Broughton
Here is a small patch to automatically detect the DRAM size on m520x. It was generated against 2.6.17-uc0, and tested on an Intec 5208 dev board. Signed-off-by: Michael Broughton <mbobowik@telusplanet.net> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: add SHM supportDavid Wu
It turns out SHMAT, SHMDT, SHMGET and SHMCTL support in sys_ipc() for m68knommu in 2.6 kernel(uClinux-dist-20060803 release) is missing. (copied from m68k sources, report by David Wu <davidwu@arcturusnetworks.com>) Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: add printk level for stack dumpGreg Ungerer
Specify printk level in m68knommu stack dump code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: add printk level for oops dumpsGreg Ungerer
Specify printk level in m68knommu oops dump code. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: fix compile when CONFIG_BLK_DEV_INITRD=nAdrian Bunk
This patch fixes the following compile error with CONFIG_BLK_DEV_INITRD=n and -Werror-implicit-function-declaration: ... CC arch/m68knommu/kernel/setup.o /home/bunk/linux/kernel-2.6/linux-2.6.18-rc5-mm1/arch/m68knommu/kernel/setup.c: In function 'setup_arch': /home/bunk/linux/kernel-2.6/linux-2.6.18-rc5-mm1/arch/m68knommu/kernel/setup.c:268: error: implicit declaration of function 'paging_init' make[2]: *** [arch/m68knommu/kernel/setup.o] Error 1 Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[PATCH] m68knommu: formatting cleanup in KconfigGreg Ungerer
Formatting and a spelling cleanup in m68knommu Kconfig. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-04[S390] Don't use small stacks when lockdep is used.Heiko Carstens
The lock dependency validator adds a bunch of extra stack frames to the stack, which can cause stack overflows. Especially seen on 31 bit where the small stack is only 4k. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] cio: Use device_reprobe() instead of bus_rescan_devices().Cornelia Huck
In io_subchannel_register(), it is better to just reprobe the current device if it hasn't a driver yet than to rescan the whole bus. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] cio: Retry internal operations after vary off.Cornelia Huck
If I/O was running on a just varied off chpid, it will be terminated. If this was a common I/O layer internal I/O, it needs to be retried. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] cio: Use path verification for last path gone after vary off.Cornelia Huck
If the last path to a device is gone after a chpid has been varied off, putting it on the slow queue doesn't prevent a device driver from still attempting to use it (it may stay on the slow queue for a long time). Instead, trigger a verify event which will prevent I/O attempts from the device driver immediately. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] non-unique constant/macro identifiers.Ursula Braun
Add some prefixes to constands defined in drivers/s390/net/qdio.h and drivers/s390/lcs.h to make it possible to include the three header files drivers/s390/net/qeth.h, drivers/s390/net/qdio.h and drivers/net/s390/lcs.h in one C file. This is required for the patch that generates the kerntypes.o file for use by lcrash. Signed-off-by: Ursula Braun <braunu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] Memory detection fixes.Heiko Carstens
VMALLOC_END on 31bit should be 0x8000000UL instead of 0x7fffffffL. The page mask which is used to make sure memory_end is on 4MB/2MB boundary is wrong and not needed. Therefore remove it. Make sure a vmalloc area does also exist and work on (future) machines with 4TB and more memory. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] cio: Make ccw_dev_id_is_equal() more robust.Cornelia Huck
Using memcmp to compare ccw_dev_id implies that the whole structure (incl. padding) has always been completely initialized to sane values. Comparing the structures field by field doesn't make such assumptions. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] Convert extmem spin_lock into a mutex.Heiko Carstens
There's no need to have a spin_lock here, but need sleepable context for vmem_map. Therefore convert the spin_lock into a mutex. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] set KBUILD_IMAGE.Christian Borntraeger
Set KBUILD_IMAGE to a sane value. This enables "make rpm" Signed-off-by: Christian Borntraeger <cborntra@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] lockdep: show held locks when showing a stackdumpHeiko Carstens
Follow i386/x86_64: lockdep can be used to print held locks when printing a backtrace. This can be useful when debugging things like 'scheduling while atomic' asserts. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] Add dynamic size check for usercopy functions.Gerald Schaefer
Use a wrapper for copy_to/from_user to chose the best usercopy method. The mvcos instruction is better for sizes greater than 256 bytes, if mvcos is not available a page table walk is better for sizes greater than 1024 bytes. Also removed the redundant copy_to/from_user_std_small functions. Signed-off-by: Gerald Schaefer <geraldsc@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] Use diag260 for memory size detection.Heiko Carstens
Avoid the tprot loop if diag260 works and reports that there are no holes in memory. The tprot instruction can lead to a significant delay in the ipl process if the virtual guest has a lot of memory and the host is under memory pressure. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] pfault code cleanup.Heiko Carstens
2006-12-04[S390] Cleanup memory_chunk array usage.Heiko Carstens
Need this at yet another file and don't want to add yet another extern... Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] Misaligned wait PSW at memory detection.Heiko Carstens
If the memory detection code would ever reach the point where it would load the wait psw, it would generate a specification exception and the system would crash at ipl time. This is because of a misaligned wait psw. It needs to be on a double word boundary instead of a word boundary. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] cpu shutdown reworkHeiko Carstens
Let one master cpu kill all other cpus instead of sending an external interrupt to all other cpus so they can kill themselves. Simplifies reipl/shutdown functions a lot. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] cpcmd <-> __cpcmd calling issuesHeiko Carstens
In case of reipl cpcmd gets called when all other cpus are not running anymore. To prevent deadlocks change __cpcmd so that it doesn't take any locks and call cpcmd or __cpcmd, whatever is correct in the current context. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
