Signed-off-by: Arvo Jarve <arvo@softshark.ee>
Signed-off-by: Manu Abraham <manu@linuxtv.org>
In this case, we will be sure that there exists a carrier
and the center frequency would be simply f1 - f2. In such
a circumstance, the TR loop is simplified to doing a simple
check for timing, rather than searching for the same.
sensitivity slightly
and 2.0
BUG! Setting CRL parameter overwrote the CR Algorithm type,
eventually leading to wrong search algorithm to be employed in
the DVB-S carrier loop optimization.
Symptom: Once the CR optimization stage is passed either way, in
a successful or failed manner, the very next carrier search will
fail, due to no Carrier Search Algorithm specified.
Signed-off-by: Marko Schluessler <marco@lordzodiac.de>
* Saves 70 mS LOCK time on the STB6100 based
* Saves 100 mS LOCK time on the TDA8261 based
LOCK_LOSS register,
which should have happenend in the DVB-S2 mode only, but reading it as it is
for the other delivery systems causes nothing to say but LOCK_LOST, which
just causes confusion amongst users.
Thanks to Peter for the in depth explanation
Need some thoughts, temporary for now ..
We need to check for tuner LOCK LOSS, especially in the case of simple PLL's
* Reduces szapping time a lot
* increased stability at Low Symbol rates
* overall increases reliability in tuning
probably should stop fiddling with code late nights. :-(
Thanks to Marco for pointing it out and fixing it.
inverted, similar to the KNC1.
Don't have this hardware and cannot verify this for myself, but from the reports this
looks to be quite a reasonable and correct hypothesis.
the same time
This is a racy situation.
Inversion is default OFF on the TT S2 3200 hardware,
unlike the KNC1 where it is default Inverted
Use an enumeration for I/Q Swap rather than an int,
easier to spot the nasty ones
The 2 callbacks created nothing more than confusion
Still messing up:
* Cleanup
* Use KNC1's default settings to startup with
* Add in tuner wrapper calls
Fix bug obviously, some enhancements as well
* enable i2c_gate before doing any transaction
* read is one single message with 2 words
* reduce sleep from 100mS to 20mS
Really silly! Disabled all clocks and expected it to run.
Add initial support for:
* KNC1 DVB-S2 Plus
* KNC1 DVB-S2 OEM (known as Satelco DVB-S2)
