2014-06-12Merge commit '3cf2f34' into sched/core, to fix build errorIngo Molnar
Fix this dependency on the locking tree's smp_mb*() API changes: kernel/sched/idle.c:247:3: error: implicit declaration of function ‘smp_mb__after_atomic’ [-Werror=implicit-function-declaration] Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/deadline: Delete extraneous extern for to_ratio()Paul Gortmaker
There was a prototype for it added to kernel/sched/sched.h at the same time the extern was added, so the extern in the C file was never really ever needed. See commit 332ac17ef5bfcff4766dfdfd3b4cdf10b8f8f155 ("sched/deadline: Add bandwidth management for SCHED_DEADLINE tasks") for details. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Dario Faggioli <raistlin@linux.it> Link: http://lkml.kernel.org/r/1400013605-18717-1-git-send-email-paul.gortmaker@windriver.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/idle: Optimize try-to-wake-up IPIPeter Zijlstra
[ This series reduces the number of IPIs on Andy's workload by something like 99%. It's down from many hundreds per second to very few. The basic idea behind this series is to make TIF_POLLING_NRFLAG be a reliable indication that the idle task is polling. Once that's done, the rest is reasonably straightforward. ] When enqueueing tasks on remote LLC domains, we send an IPI to do the work 'locally' and avoid bouncing all the cachelines over. However, when the remote CPU is idle (and polling, say x86 mwait), we don't need to send an IPI, we can simply kick the TIF word to wake it up and have the 'idle' loop do the work. So when _TIF_POLLING_NRFLAG is set, but _TIF_NEED_RESCHED is not (yet) set, set _TIF_NEED_RESCHED and avoid sending the IPI. Much-requested-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Peter Zijlstra <peterz@infradead.org> [Edited by Andy Lutomirski, but this is mostly Peter Zijlstra's code.] Signed-off-by: Andy Lutomirski <luto@amacapital.net> Cc: nicolas.pitre@linaro.org Cc: daniel.lezcano@linaro.org Cc: Mike Galbraith <umgwanakikbuti@gmail.com> Cc: umgwanakikbuti@gmail.com Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/ce06f8b02e7e337be63e97597fc4b248d3aa6f9b.1401902905.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/idle: Simplify wake_up_idle_cpu()Andy Lutomirski
Now that rq->idle's polling bit is a reliable indication that the cpu is polling, use it. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: nicolas.pitre@linaro.org Cc: daniel.lezcano@linaro.org Cc: umgwanakikbuti@gmail.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/922f00761445a830ebb23d058e2ae53956ce2d73.1401902905.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/idle: Clear polling before descheduling the idle threadAndy Lutomirski
Currently, the only real guarantee provided by the polling bit is that, if you hold rq->lock and the polling bit is set, then you can set need_resched to force a reschedule. The only reason the lock is needed is that the idle thread might not be running at all when setting its need_resched bit, and rq->lock keeps it pinned. This is easy to fix: just clear the polling bit before scheduling. Now the idle thread's polling bit is only ever set when rq->curr == rq->idle. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: nicolas.pitre@linaro.org Cc: daniel.lezcano@linaro.org Cc: umgwanakikbuti@gmail.com Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/b2059fcb4c613d520cb503b6fad6e47033c7c203.1401902905.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched, trace: Add a tracepoint for IPI-less remote wakeupsAndy Lutomirski
Remote wakeups of polling CPUs are a valuable performance improvement; add a tracepoint to make it much easier to verify that they're working. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: nicolas.pitre@linaro.org Cc: daniel.lezcano@linaro.org Cc: umgwanakikbuti@gmail.com Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mel Gorman <mgorman@suse.de> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/16205aee116772aa686814f9b13bccb562108047.1401902905.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05cpuidle: Set polling in poll_idleAndy Lutomirski
poll_idle is the archetypal polling idle loop; tell the core idle code about it. This avoids pointless IPIs when all of the other cpuidle states are disabled. Signed-off-by: Andy Lutomirski <luto@amacapital.net> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: nicolas.pitre@linaro.org Cc: umgwanakikbuti@gmail.com Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Rafael J. Wysocki <rjw@rjwysocki.net> Cc: linux-kernel@vger.kernel.org Cc: linux-pm@vger.kernel.org Link: http://lkml.kernel.org/r/c65ce49615d338bae8fb79df5daffab19353c900.1401902905.git.luto@amacapital.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched: Remove redundant assignment to "rt_rq" in update_curr_rt(...)Giedrius Rekasius
Variable "rt_rq" is used only in block "for_each_sched_rt_entity" so the value assigned to it at the beginning of the update_curr_rt(...) gets overwritten without ever being read. Remove redundant assignment and move variable declaration to the block in which it is being used. Signed-off-by: Giedrius Rekasius <giedrius.rekasius@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: kernel-janitors@vger.kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/1401027811-30066-1-git-send-email-giedrius.rekasius@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched: Rename capacity related flagsNicolas Pitre
It is better not to think about compute capacity as being equivalent to "CPU power". The upcoming "power aware" scheduler work may create confusion with the notion of energy consumption if "power" is used too liberally. Let's rename the following feature flags since they do relate to capacity: SD_SHARE_CPUPOWER -> SD_SHARE_CPUCAPACITY ARCH_POWER -> ARCH_CAPACITY NONTASK_POWER -> NONTASK_CAPACITY Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: linaro-kernel@lists.linaro.org Cc: Andy Fleming <afleming@freescale.com> Cc: Anton Blanchard <anton@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Grant Likely <grant.likely@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael Ellerman <mpe@ellerman.id.au> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Preeti U Murthy <preeti@linux.vnet.ibm.com> Cc: Rob Herring <robh+dt@kernel.org> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Toshi Kani <toshi.kani@hp.com> Cc: Vasant Hegde <hegdevasant@linux.vnet.ibm.com> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: devicetree@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: linuxppc-dev@lists.ozlabs.org Link: http://lkml.kernel.org/n/tip-e93lpnxb87owfievqatey6b5@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched: Final power vs. capacity cleanupsNicolas Pitre
It is better not to think about compute capacity as being equivalent to "CPU power". The upcoming "power aware" scheduler work may create confusion with the notion of energy consumption if "power" is used too liberally. This contains the architecture visible changes. Incidentally, only ARM takes advantage of the available pow^H^H^Hcapacity scaling hooks and therefore those changes outside kernel/sched/ are confined to one ARM specific file. The default arch_scale_smt_power() hook is not overridden by anyone. Replacements are as follows: arch_scale_freq_power --> arch_scale_freq_capacity arch_scale_smt_power --> arch_scale_smt_capacity SCHED_POWER_SCALE --> SCHED_CAPACITY_SCALE SCHED_POWER_SHIFT --> SCHED_CAPACITY_SHIFT The local usage of "power" in arch/arm/kernel/topology.c is also changed to "capacity" as appropriate. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: linaro-kernel@lists.linaro.org Cc: Arnd Bergmann <arnd@arndb.de> Cc: Dietmar Eggemann <dietmar.eggemann@arm.com> Cc: Grant Likely <grant.likely@linaro.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mark Brown <broonie@linaro.org> Cc: Rob Herring <robh+dt@kernel.org> Cc: Russell King <linux@arm.linux.org.uk> Cc: Sudeep KarkadaNagesha <sudeep.karkadanagesha@arm.com> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: devicetree@vger.kernel.org Cc: linux-arm-kernel@lists.infradead.org Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/n/tip-48zba9qbznvglwelgq2cfygh@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched: Remove remaining dubious usage of "power"Nicolas Pitre
It is better not to think about compute capacity as being equivalent to "CPU power". The upcoming "power aware" scheduler work may create confusion with the notion of energy consumption if "power" is used too liberally. This is the remaining "power" -> "capacity" rename for local symbols. Those symbols visible to the rest of the kernel are not included yet. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: linaro-kernel@lists.linaro.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/n/tip-yyyhohzhkwnaotr3lx8zd5aa@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched: Let 'struct sched_group_power' care about CPU capacityNicolas Pitre
It is better not to think about compute capacity as being equivalent to "CPU power". The upcoming "power aware" scheduler work may create confusion with the notion of energy consumption if "power" is used too liberally. Since struct sched_group_power is really about compute capacity of sched groups, let's rename it to struct sched_group_capacity. Similarly sgp becomes sgc. Related variables and functions dealing with groups are also adjusted accordingly. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: linaro-kernel@lists.linaro.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/n/tip-5yeix833vvgf2uyj5o36hpu9@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/fair: Disambiguate existing/remaining "capacity" usageNicolas Pitre
We have "power" (which should actually become "capacity") and "capacity" which is a scaled down "capacity factor" in terms of unitary tasks. Let's use "capacity_factor" to make room for proper usage of "capacity" later. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: linaro-kernel@lists.linaro.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/n/tip-gk1co8sqdev3763opqm6ovml@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/fair: Change "has_capacity" to "has_free_capacity"Nicolas Pitre
The capacity of a CPU/group should be some intrinsic value that doesn't change with task placement. It is like a container which capacity is stable regardless of the amount of liquid in it (its "utilization")... unless the container itself is crushed that is, but that's another story. Therefore let's rename "has_capacity" to "has_free_capacity" in order to better convey the wanted meaning. Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: linaro-kernel@lists.linaro.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/n/tip-djzkk027jm0e8x8jxy70opzh@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/fair: Remove "power" from 'struct numa_stats'Nicolas Pitre
It is better not to think about compute capacity as being equivalent to "CPU power". The upcoming "power aware" scheduler work may create confusion with the notion of energy consumption if "power" is used too liberally. To make things explicit and not create more confusion with the existing "capacity" member, let's rename things as follows: power -> compute_capacity capacity -> task_capacity Note: none of those fields are actually used outside update_numa_stats(). Signed-off-by: Nicolas Pitre <nico@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Vincent Guittot <vincent.guittot@linaro.org> Cc: Daniel Lezcano <daniel.lezcano@linaro.org> Cc: Morten Rasmussen <morten.rasmussen@arm.com> Cc: "Rafael J. Wysocki" <rjw@rjwysocki.net> Cc: linaro-kernel@lists.linaro.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/n/tip-2e2ndymj5gyshyjq8am79f20@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched: Fix signedness bug in yield_to()Dan Carpenter
yield_to() is supposed to return -ESRCH if there is no task to yield to, but because the type is bool that is the same as returning true. The only place I see which cares is kvm_vcpu_on_spin(). Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Reviewed-by: Raghavendra <raghavendra.kt@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Gleb Natapov <gleb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paolo Bonzini <pbonzini@redhat.com> Cc: kvm@vger.kernel.org Link: http://lkml.kernel.org/r/20140523102042.GA7267@mwanda Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/fair: Use time_after() in record_wakee()Manuel Schölling
To be future-proof and for better readability the time comparisons are modified to use time_after() instead of plain, error-prone math. Signed-off-by: Manuel Schölling <manuel.schoelling@gmx.de> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1400780723-24626-1-git-send-email-manuel.schoelling@gmx.de Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/balancing: Reduce the rate of needless idle load balancingTim Chen
The current no_hz idle load balancer do load balancing for *all* idle cpus, even though the time due to load balance for a particular idle cpu could be still a while in the future. This introduces a much higher load balancing rate than what is necessary. The patch changes the behavior by only doing idle load balancing on behalf of an idle cpu only when it is due for load balancing. On SGI's systems with over 3000 cores, the cpu responsible for idle balancing got overwhelmed with idle balancing, and introduces a lot of OS noise to workloads. This patch fixes the issue. Signed-off-by: Tim Chen <tim.c.chen@linux.intel.com> Acked-by: Russ Anderson <rja@sgi.com> Reviewed-by: Rik van Riel <riel@redhat.com> Reviewed-by: Jason Low <jason.low2@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Len Brown <len.brown@intel.com> Cc: Dimitri Sivanich <sivanich@sgi.com> Cc: Hedi Berriche <hedi@sgi.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: MichelLespinasse <walken@google.com> Cc: Peter Hurley <peter@hurleysoftware.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1400621967.2970.280.camel@schen9-DESK Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-06-05sched/fair: Fix unlocked reads of some cfs_b->quota/periodBen Segall
sched_cfs_period_timer() reads cfs_b->period without locks before calling do_sched_cfs_period_timer(), and similarly unthrottle_offline_cfs_rqs() would read cfs_b->period without the right lock. Thus a simultaneous change of bandwidth could cause corruption on any platform where ktime_t or u64 writes/reads are not atomic. Extend cfs_b->lock from do_sched_cfs_period_timer() to include the read of cfs_b->period to solve that issue; unthrottle_offline_cfs_rqs() can just use 1 rather than the exact quota, much like distribute_cfs_runtime() does. There is also an unlocked read of cfs_b->runtime_expires, but a race there would only delay runtime expiry by a tick. Still, the comparison should just be != anyway, which clarifies even that problem. Signed-off-by: Ben Segall <bsegall@google.com> Tested-by: Roman Gushchin <klamm@yandex-team.ru> [peterz: Fix compile warn] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140519224945.20303.93530.stgit@sword-of-the-dawn.mtv.corp.google.com Cc: pjt@google.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/numa: Decay ->wakee_flips instead of zeroingRik van Riel
Affine wakeups have the potential to interfere with NUMA placement. If a task wakes up too many other tasks, affine wakeups will get disabled. However, regardless of how many other tasks it wakes up, it gets re-enabled once a second, potentially interfering with NUMA placement of other tasks. By decaying wakee_wakes in half instead of zeroing it, we can avoid that problem for some workloads. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: chegu_vinod@hp.com Cc: umgwanakikbuti@gmail.com Link: http://lkml.kernel.org/r/20140516001332.67f91af2@annuminas.surriel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/numa: Update migrate_improves/degrades_locality()Rik van Riel
Update the migrate_improves/degrades_locality() functions with knowledge of pseudo-interleaving. Do not consider moving tasks around within the set of group's active nodes as improving or degrading locality. Instead, leave the load balancer free to balance the load between a numa_group's active nodes. Also, switch from the group/task_weight functions to the group/task_fault functions. The "weight" functions involve a division, but both calls use the same divisor, so there's no point in doing that from these functions. On a 4 node (x10 core) system, performance of SPECjbb2005 seems unaffected, though the number of migrations with 2 8-warehouse wide instances seems to have almost halved, due to the scheduler running each instance on a single node. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: mgorman@suse.de Cc: chegu_vinod@hp.com Link: http://lkml.kernel.org/r/20140515130306.61aae7db@cuia.bos.redhat.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/numa: Allow task switch if load imbalance improvesRik van Riel
Currently the NUMA balancing code only allows moving tasks between NUMA nodes when the load on both nodes is in balance. This breaks down when the load was imbalanced to begin with. Allow tasks to be moved between NUMA nodes if the imbalance is small, or if the new imbalance is be smaller than the original one. Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: mgorman@suse.de Cc: chegu_vinod@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org> Link: http://lkml.kernel.org/r/20140514132221.274b3463@annuminas.surriel.com
2014-05-22sched/rt: Fix 'struct sched_dl_entity' and dl_task_time() comments, to match ↵xiaofeng.yan
the current upstream code Signed-off-by: xiaofeng.yan <xiaofeng.yan@huawei.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1399605687-18094-1-git-send-email-xiaofeng.yan@huawei.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Consolidate open coded implementations of nice level frobbing into ↵Dongsheng Yang
nice_to_rlimit() and rlimit_to_nice() Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/a568a1e3cc8e78648f41b5035fa5e381d36274da.1399532322.git.yangds.fnst@cn.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Initialize rq->age_stamp on processor startCorey Minyard
If the sched_clock time starts at a large value, the kernel will spin in sched_avg_update for a long time while rq->age_stamp catches up with rq->clock. The comment in kernel/sched/clock.c says that there is no strict promise that it starts at zero. So initialize rq->age_stamp when a cpu starts up to avoid this. I was seeing long delays on a simulator that didn't start the clock at zero. This might also be an issue on reboots on processors that don't re-initialize the timer to zero on reset, and when using kexec. Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1399574859-11714-1-git-send-email-minyard@acm.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched, nohz: Change rq->nr_running to always use wrappersKirill Tkhai
Sometimes ->nr_running may cross 2 but interrupt is not being sent to rq's cpu. In this case we don't reenable the timer. Looks like this may be the reason for rare unexpected effects, if nohz is enabled. Patch replaces all places of direct changing of nr_running and makes add_nr_running() caring about crossing border. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20140508225830.2469.97461.stgit@localhost Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Fix the rq->next_balance logic in rebalance_domains() and idle_balance()Jason Low
Currently, in idle_balance(), we update rq->next_balance when we pull_tasks. However, it is also important to update this in the !pulled_tasks case too. When the CPU is "busy" (the CPU isn't idle), rq->next_balance gets computed using sd->busy_factor (so we increase the balance interval when the CPU is busy). However, when the CPU goes idle, rq->next_balance could still be set to a large value that was computed with the sd->busy_factor. Thus, we need to also update rq->next_balance in idle_balance() in the cases where !pulled_tasks too, so that rq->next_balance gets updated without taking the busy_factor into account when the CPU is about to go idle. This patch makes rq->next_balance get updated independently of whether or not we pulled_task. Also, we add logic to ensure that we always traverse at least 1 of the sched domains to get a proper next_balance value for updating rq->next_balance. Additionally, since load_balance() modifies the sd->balance_interval, we need to re-obtain the sched domain's interval after the call to load_balance() in rebalance_domains() before we update rq->next_balance. This patch adds and uses 2 new helper functions, update_next_balance() and get_sd_balance_interval() to update next_balance and obtain the sched domain's balance_interval. Signed-off-by: Jason Low <jason.low2@hp.com> Reviewed-by: Preeti U Murthy <preeti@linux.vnet.ibm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: daniel.lezcano@linaro.org Cc: alex.shi@linaro.org Cc: efault@gmx.de Cc: vincent.guittot@linaro.org Cc: morten.rasmussen@arm.com Cc: aswin@hp.com Link: http://lkml.kernel.org/r/1399596562.2200.7.camel@j-VirtualBox Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Use clamp() and clamp_val() to make sys_nice() more readableDongsheng Yang
Suggested-by: Kees Cook <keescook@chromium.org> Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1399541715-19568-1-git-send-email-yangds.fnst@cn.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Do not zero sg->cpumask and sg->sgp->power in build_sched_groups()Dietmar Eggemann
There is no need to zero struct sched_group member cpumask and struct sched_group_power member power since both structures are already allocated as zeroed memory in __sdt_alloc(). This patch has been tested with BUG_ON(!cpumask_empty(sched_group_cpus(sg))); and BUG_ON(sg->sgp->power); in build_sched_groups() on ARM TC2 and INTEL i5 M520 platform including CPU hotplug scenarios. Signed-off-by: Dietmar Eggemann <dietmar.eggemann@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1398865178-12577-1-git-send-email-dietmar.eggemann@arm.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/numa: Fix initialization of sched_domain_topology for NUMAVincent Guittot
Jet Chen has reported a kernel panics when booting qemu-system-x86_64 with kvm64 cpu. A panic occured while building the sched_domain. In sched_init_numa, we create a new topology table in which both default levels and numa levels are copied. The last row of the table must have a null pointer in the mask field. The current implementation doesn't add this last row in the computation of the table size. So we add 1 row in the allocation size that will be used as the last row of the table. The kzalloc will ensure that the mask field is NULL. Reported-by: Jet Chen <jet.chen@intel.com> Tested-by: Jet Chen <jet.chen@intel.com> Signed-off-by: Vincent Guittot <vincent.guittot@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: fengguang.wu@intel.com Link: http://lkml.kernel.org/r/1399972261-25693-1-git-send-email-vincent.guittot@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Call select_idle_sibling() when not affine_sdRik van Riel
On smaller systems, the top level sched domain will be an affine domain, and select_idle_sibling is invoked for every SD_WAKE_AFFINE wakeup. This seems to be working well. On larger systems, with the node distance between far away NUMA nodes being > RECLAIM_DISTANCE, select_idle_sibling is only called if the waker and the wakee are on nodes less than RECLAIM_DISTANCE apart. This patch leaves in place the policy of not pulling the task across nodes on such systems, while fixing the issue that select_idle_sibling is not called at all in certain circumstances. The code will look for an idle CPU in the same CPU package as the CPU where the task ran previously. Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: morten.rasmussen@arm.com Cc: george.mccollister@gmail.com Cc: ktkhai@parallels.com Cc: Mel Gorman <mgorman@suse.de> Cc: Mike Galbraith <umgwanakikbuti@gmail.com> Link: http://lkml.kernel.org/r/20140514114037.2d93266f@annuminas.surriel.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Simplify return logic in sched_read_attr()Michael Kerrisk
Gotos are chained pointlessly here, and the 'out' label can be dispensed with. Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/536CEC29.9090503@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Simplify return logic in sched_copy_attr()Michael Kerrisk
The logic in this function is a little contorted, clean it up: * Rather than having chained gotos for the -EFBIG case, just return -EFBIG directly. * Now, the label 'out' is no longer needed, and 'ret' must be zero zero by the time we fall through to this point, so just return 0. Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/536CEC24.9080201@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Fix exec_start/task_hot on migrated tasksBen Segall
task_hot checks exec_start on any runnable task, but if it has been migrated since the it last ran, then exec_start is a clock_task from another cpu. If the old cpu's clock_task was sufficiently far ahead of this cpu's then the task will not be considered for another migration until it has run. Instead reset exec_start whenever a task is migrated, since it is presumably no longer hot anyway. Signed-off-by: Ben Segall <bsegall@google.com> [ Made it compile. ] Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140515225920.7179.13924.stgit@sword-of-the-dawn.mtv.corp.google.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22Merge branch 'sched/urgent' into sched/core to avoid conflicts with upcoming ↵Ingo Molnar
changes Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22Merge branch 'pm-cpuidle' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm into sched/core Pull scheduling related CPU idle updates from Rafael J. Wysocki. Conflicts: kernel/sched/idle.c Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22Merge tag 'v3.15-rc6' into sched/core, to pick up the latest fixesIngo Molnar
2014-05-22arm64: Remove TIF_POLLING_NRFLAGPeter Zijlstra
The only idle method for arm64 is WFI and it therefore unconditionally requires the reschedule interrupt when idle. Suggested-by: Catalin Marinas <catalin.marinas@arm.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Catalin Marinas <catalin.marinas@arm.com> Link: http://lkml.kernel.org/r/20140509170649.GG13658@twins.programming.kicks-ass.net Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22metag: Remove TIF_POLLING_NRFLAGJames Hogan
The Meta idle function jumps into the interrupt handler which efficiently blocks waiting for the next interrupt when it reads the interrupt status register (TXSTATI). No other (polling) idle functions can be used, therefore TIF_POLLING_NRFLAG is unnecessary, so lets remove it. Peter Zijlstra said: > Most archs have (x86) hlt or (arm) wfi like idle instructions, and if > that is your only possible idle function, you'll require the interrupt > to wake up and there's really no point to having the POLLING bit. Signed-off-by: James Hogan <james.hogan@imgtec.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/536CEB7E.9080007@imgtec.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Fix hotplug vs. set_cpus_allowed_ptr()Lai Jiangshan
Lai found that: WARNING: CPU: 1 PID: 13 at arch/x86/kernel/smp.c:124 native_smp_send_reschedule+0x2d/0x4b() ... migration_cpu_stop+0x1d/0x22 was caused by set_cpus_allowed_ptr() assuming that cpu_active_mask is always a sub-set of cpu_online_mask. This isn't true since 5fbd036b552f ("sched: Cleanup cpu_active madness"). So set active and online at the same time to avoid this particular problem. Fixes: 5fbd036b552f ("sched: Cleanup cpu_active madness") Signed-off-by: Lai Jiangshan <laijs@cn.fujitsu.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Gautham R. Shenoy <ego@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Michael wang <wangyun@linux.vnet.ibm.com> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Rafael J. Wysocki <rafael.j.wysocki@intel.com> Cc: Srivatsa S. Bhat <srivatsa.bhat@linux.vnet.ibm.com> Cc: Toshi Kani <toshi.kani@hp.com> Link: http://lkml.kernel.org/r/53758B12.8060609@cn.fujitsu.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/cpupri: Replace NR_CPUS arraysPeter Zijlstra
Tejun reported that his resume was failing due to order-3 allocations from sched_domain building. Replace the NR_CPUS arrays in there with a dynamically allocated array. Reported-by: Tejun Heo <tj@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-7cysnkw1gik45r864t1nkudh@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/deadline: Replace NR_CPUS arraysPeter Zijlstra
Tejun reported that his resume was failing due to order-3 allocations from sched_domain building. Replace the NR_CPUS arrays in there with a dynamically allocated array. Reported-by: Tejun Heo <tj@kernel.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Juri Lelli <juri.lelli@gmail.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/n/tip-kat4gl1m5a6dwy6nzuqox45e@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/deadline: Restrict user params max value to 2^63 nsJuri Lelli
Michael Kerrisk noticed that creating SCHED_DEADLINE reservations with certain parameters (e.g, a runtime of something near 2^64 ns) can cause a system freeze for some amount of time. The problem is that in the interface we have u64 sched_runtime; while internally we need to have a signed runtime (to cope with budget overruns) s64 runtime; At the time we setup a new dl_entity we copy the first value in the second. The cast turns out with negative values when sched_runtime is too big, and this causes the scheduler to go crazy right from the start. Moreover, considering how we deal with deadlines wraparound (s64)(a - b) < 0 we also have to restrict acceptable values for sched_{deadline,period}. This patch fixes the thing checking that user parameters are always below 2^63 ns (still large enough for everyone). It also rewrites other conditions that we check, since in __checkparam_dl we don't have to deal with deadline wraparounds and what we have now erroneously fails when the difference between values is too big. Reported-by: Michael Kerrisk <mtk.manpages@gmail.com> Suggested-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Juri Lelli <juri.lelli@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Dario Faggioli<raistlin@linux.it> Cc: Dave Jones <davej@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140513141131.20d944f81633ee937f256385@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched/deadline: Change sched_getparam() behaviour vs SCHED_DEADLINEPeter Zijlstra
The way we read POSIX one should only call sched_getparam() when sched_getscheduler() returns either SCHED_FIFO or SCHED_RR. Given that we currently return sched_param::sched_priority=0 for all others, extend the same behaviour to SCHED_DEADLINE. Requested-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Dario Faggioli <raistlin@linux.it> Cc: linux-man <linux-man@vger.kernel.org> Cc: "Michael Kerrisk (man-pages)" <mtk.manpages@gmail.com> Cc: Juri Lelli <juri.lelli@gmail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: <stable@vger.kernel.org> Link: http://lkml.kernel.org/r/20140512205034.GH13467@laptop.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Disallow sched_attr::sched_policy < 0Peter Zijlstra
The scheduler uses policy=-1 to preserve the current policy state to implement sys_sched_setparam(), this got exposed to userspace by accident through sys_sched_setattr(), cure this. Reported-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Michael Kerrisk <mtk.manpages@gmail.com> Cc: <stable@vger.kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/20140509085311.GJ30445@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22sched: Make sched_setattr() correctly return -EFBIGMichael Kerrisk
The documented[1] behavior of sched_attr() in the proposed man page text is: sched_attr::size must be set to the size of the structure, as in sizeof(struct sched_attr), if the provided structure is smaller than the kernel structure, any additional fields are assumed '0'. If the provided structure is larger than the kernel structure, the kernel verifies all additional fields are '0' if not the syscall will fail with -E2BIG. As currently implemented, sched_copy_attr() returns -EFBIG for for this case, but the logic in sys_sched_setattr() converts that error to -EFAULT. This patch fixes the behavior. [1] http://thread.gmane.org/gmane.linux.kernel/1615615/focus=1697760 Signed-off-by: Michael Kerrisk <mtk.manpages@gmail.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: <stable@vger.kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/536CEC17.9070903@gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-05-22Linux 3.15-rc6v3.15-rc6Linus Torvalds
2014-05-22Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull two powerpc fixes from Ben Herrenschmidt: "Here are a couple of fixes for 3.15. One from Anton fixes a nasty regression I introduced when trying to fix a loss of irq_work whose consequences is that we can completely lose timer interrupts on a CPU... not pretty. The other one is a change to our PCIe reset hook to use a firmware call instead of direct config space accesses to trigger a fundamental reset on the root port. This is necessary so that the FW gets a chance to disable the link down error monitoring, which would otherwise trip and cause subsequent fatal EEH error" * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: irq work racing with timer interrupt can result in timer interrupt hang powerpc/powernv: Reset root port in firmware
2014-05-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull two btrfs fixes from Chris Mason: "This has two fixes that we've been testing for 3.16, but since both are safe and fix real bugs, it makes sense to send for 3.15 instead" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: send, fix incorrect ref access when using extrefs Btrfs: fix EIO on reading file after ioctl clone works on it
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client Pull two ceph fixes from Sage Weil: "The first patch fixes a problem when we have a page count of 0 for sendpage which is triggered by zfs. The second fixes a bug in CRUSH that was resolved in the userland code a while back but fell through the cracks on the kernel side" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: crush: decode and initialize chooseleaf_vary_r libceph: fix corruption when using page_count 0 page in rbd
