2007-05-02[POWERPC] get_property returns constStephen Rothwell
This is the last place that needs changing since get_property was changed to return "const void *". Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Small cleanups to the cuboot bootwrapper codeDavid Gibson
This patch makes a few small cleanups to the cuboot code. - It removes the double layered selection of images, via cuboot-plat-y, instead having the cuboot platforms directly select a suitable image-y (this changes the name of the final cuboot image from plain cuImage to cuImage.<platform>). - Factors out some code in the wrapper that's potentially useful to platforms other than uboot. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Acked-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] PS3: Defconfig updatesGeoff Levand
Updates to ps3_defconfig for linux-2.6.21. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] PS3: Fix system slowdownTakao Shinohara
The PS3 HV will deliver soft-disabled interrupts at the next HV call or interrupt. Add an HV call to local_irq_restore() to force the timely delivery of any pending interrupts. This fixes the system slowdown bug reported here http://bugzilla.kernel.org/show_bug.cgi?id=8260 Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] PS3: Interrupt routine fixups.Geoff Levand
Fixups for the ps3 interrupt routines to support all HV device in a generic way. Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] PS3: Remove duplicate variable assignementGeoff Levand
A minor change to remove a duplicate variable assignement in ps3_mm_shutdown(); Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] PS3: Add DABR supportGeoff Levand
Add PS3 support for the PowerPC processor's Data Address Breakpoint Register (DABR). Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Fix spurious vectors on weird MPICJosh Boyer
The weird TSI 10x MPIC needs an EOI after getting a spurious vector. This patch uses the existing MPIC_SPV_EOI flag to fix this issue. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Use menuconfig objects II - MacintoshJan Engelhardt
Make a "menuconfig" out of the Kconfig objects "menu, ..., endmenu", so that the user can disable all the options in that menu at once instead of having to disable each option separately. Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Fix suspend states againJohannes Berg
In commit 0fba3a1f39f8b0a50b56c8b068fa52131cbc84c2 (a very long time ago, May 2006), I fixed a bug that caused powermacs to crash when you tried entering standby/mem suspend states. As I'm now getting more familiar with the suspend code I notice a few more things: 1. we previously misunderstood what pm_ops is for, it isn't supposed to be for doing platform dependent suspend/resume stuff that needs to be done for suspend to disk (as we currently try to use it!), it is instead for entering platform dependent suspend states ("standby", "mem"). 2. due to the first point, we never properly save FPU and altivec states when suspending to disk. It probably hasn't hurt yet because the process that writes the "disk" to /sys/power/state uses neither and its context is used. This patch addresses these points as follows: 1. remove all pm_ops from powermac, powermac suspend to ram isn't currently usable via /sys/power/state but is done via the PMU instead. 2. move the code responsible for storing FPU/altivec state into save_processor_state and the set_context() call to restore_processor_state. 3. add a call to kernel_enable_spe() It may look like there is some code removal missing but that is actually because the new suspend.h file overrides the ppc/suspend.h one which was previously used. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Remove arch/powerpc's dependence on asm-ppc/pg{alloc,table}.hDavid Gibson
Currently, all 32-bit powerpc platforms use asm-ppc/pgtable.h and asm-ppc/pgalloc.h, even when otherwise compiled with ARCH=powerpc. Those asm-ppc files are a fairly nasty tangle of #ifdefs including a bunch of things which shouldn't be necessary any more in arch/powerpc. Cleaning up that mess is going to take a while, but this patch is a first step. It separates the asm-powerpc/pg{alloc,table}.h into 64 bit and 32 bit versions in asm-powerpc, which the basic .h files in asm-powerpc select based on config. We make a few tiny tweaks to the innards of the files along the way, making the outermost ifdefs (double-inclusion protection and __KERNEL__) a little cleaner, and #including asm-generic/pgtable.h from the top-level asm-powerpc/pgtable.h (since both the old 32-bit and 64-bit versions ended with such an #include). Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Fix STRICT_MM_TYPECHECKSDavid Gibson
Since we don't have it active by default, the STRICT_MM_TYPECHECKS option has bitrotted again. This patch fixes a couple of simple build fixes if the option is selected. First, pud_t mustn't be defined in page.h on 32-bit systems, because it conflicts with the version in the generic pud-folding code. Second, pci_32.c is missing a __pgprot() wrapper call. Third, a couple of PS3 files use constants of type pgprot_t when they need the raw values, we add pgprot_val() calls to fix this. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Revise PPC44x MMU code for arch/powerpcDavid Gibson
This patch takes the definitions for the PPC44x MMU (a software loaded TLB) from asm-ppc/mmu.h, cleans them up of things no longer necessary in arch/powerpc and puts them in a new asm-powerpc/mmu_44x.h file. It also substantially simplifies arch/powerpc/mm/44x_mmu.c and makes a couple of small fixes necessary for the 44x MMU code to build and work properly in arch/powerpc. Signed-off-by: David Gibson <david@gibson.dropbear.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Uninline of_iomap functionChristian Krafft
There is no big reason to have that function inlined. Signed-off-by: Christian Krafft <krafft@de.ibm.com> Acked-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Initialise spinlock in the DEBUG_PAGEALLOC codeMichael Ellerman
Fixes: BUG: spinlock bad magic on CPU#0, swapper/0 lock: c00000000064ec30, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 Call Trace: [c00000000062b980] [c00000000000f920] .show_stack+0x6c/0x1a0 (unreliable) [c00000000062ba20] [c0000000001c2b40] .spin_bug+0xb0/0xd4 [c00000000062bab0] [c0000000001c2ed0] ._raw_spin_lock+0x44/0x184 [c00000000062bb50] [c0000000003a42b4] ._spin_lock+0x10/0x24 [c00000000062bbd0] [c00000000002b4dc] .kernel_map_pages+0x198/0x278 [c00000000062bc90] [c000000000079720] .free_hot_cold_page+0x124/0x418 [c00000000062bd70] [c000000000530278] .free_all_bootmem_core+0x14c/0x224 [c00000000062be50] [c00000000052a178] .mem_init+0x68/0x170 [c00000000062bee0] [c00000000051d874] .start_kernel+0x2a0/0x37c [c00000000062bf90] [c0000000000084c8] .start_here_common+0x54/0x8c Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Turn on corresponding PHY drivers in QE UEC platforms defconfigsKim Phillips
Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Add 'mdio' to bus scan id list for platforms with QE UECKim Phillips
Add 'mdio' to bus scan id list for platforms with QE UEC as a consequence of converting UEC mdio driver to an of_platform driver in the ucc_geth phylib conversion patch. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Replace undocumented interface properties in dts filesKim Phillips
phy-connection-type now supersedes the interface property. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Document phy-connection-type propertyKim Phillips
Since ucc_geth is being migrated to use the phylib, the existing (undocumented) 'interface' property is being deprecated in favour of 'phy-connection-type'. phy-connection-type is now maintained one-to-one with definitions in include/linux/phy.h, albeit in the form of a string. If not specified, "mii" is assumed. Signed-off-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] pseries: Handle null iommu dma-window property correctlyLinas Vepstas
Some versions of pSeries firmware fail to set up a dma-window property for PCI slots that are unoccupied. As a result, the loop searching for this propery, in pci_dma_dev_setup_pSeriesLP(), can run to the end, resulting in a NULL pointer dereference later in the routine. This patch prevents the crash, and prints a warning message. This is theoretically a rare error, as it occurs on what is hopefully just beta levels of firmware. But just in case this firmware escapes into the wild, this patch will avoid the crash. Signed-off-by: Linas Vepstas <linas@austin.ibm.com>
2007-05-02[POWERPC] powermac: Fix G5-cpufreq for cpu on/offlineJohannes Berg
The original code here is wrong, it applies "previous" knowledge. The way the cpufreq core is designed is that the policy for the secondary CPU that comes online says that it must in fact not use this policy but use the same as the other CPUs that are listed, which in fact is CPU#0. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] apm_emu: Use generic apm-emulationJohannes Berg
This patch removes a huge amount of code that is now in common code in drivers/char/apm-emulation.c Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] kernel: Remove loops_per_jiffy code for 7448HPC2 platformsZang Roy-r61911
Remove loops_per_jiffy early initialization code for 7448HPC2 platforms. Since udelay no longer uses loops_per_jiffy it is not necessary to initialize it early. Signed-off-by: Roy Zang <tie-fei.zang@freescale.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] drivers/macintosh/mac_hid.c: Make code staticAdrian Bunk
This patch makes some needlessly global code static. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Remove unneeded page_is_ram exportJohannes Berg
arch/powerpc/mm/mem.c exports page_is_ram, which is not used anywhere that could be modular. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] Move of_irq_to_resource from prom.h to prom_parse.cMathieu Desnoyers
In the powerpc architecture, of_irq_to_resource, currently sitting in prom.h, needs irq_of_parse_and_map and NO_IRQ from asm-powerpc/irq.h. The solution suggested by Benjamin Herrenschmidt is to move it to arch/powerpc/kernel/prom_parse.c. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-05-02[POWERPC] pmac_feature_call checks platformBenjamin Herrenschmidt
This patch makes sure that a caller of pmac_call_feature() won't try to call into ppc_md.feature_call of another platform, which might happen if some powermac drivers are loaded on non-powermac machines. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-04-30libata: honour host controllers that want just one hostLinus Torvalds
The Marvell IDE interface on my machine would hit a BUG_ON() in lib/iomem.c because it was calling ata_pci_init_one() specifying just a single port on the host, but that would actually end up trying to initialize two ports, the second one with bogus information. This fixes "ata_pci_init_one()" so that it actually passes down the n_ports variable that it got from the low-level driver to the host allocation routine ("ata_host_alloc_pinfo()"), which results in the ATA layer actually having the correct port number information. And in order to make it all work, I also needed to fix a few places that had incorrectly hard-coded the fact that a host always had exactly two ports (both ata_pci_init_bmdma() and ata_request_legacy_irqs() would just always iterate over both ports). Acked-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30pm: include EIO from errno-base.hDavid Rientjes
For backwards compatibility, call_platform_enable_wakeup() can return 0 instead of -EIO since we aren't guaranteed to have errno defined. Cc: David Brownell <david-b@pacbell.net> Signed-off-by: David Rientjes <rientjes@google.com> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Add kvasprintf()Jeremy Fitzhardinge
Add a kvasprintf() function to complement kasprintf(). No in-tree users yet, but I have some coming up. [akpm@linux-foundation.org: EXPORT it] Signed-off-by: Jeremy Fitzhardinge <jeremy@xensource.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Keir Fraser <keir@xensource.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30power management: force pm_ops.valid callback to be assignedJohannes Berg
This patch changes the docs and behaviour from "all states valid" to "no states valid" if no .valid callback is assigned. Users of pm_ops that only need mem sleep can assign pm_valid_only_mem without any overhead, others will require more elaborate callbacks. Now that all users of pm_ops have a .valid callback this is a safe thing to do and prevents things from getting messy again as they were before. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Pavel Machek <pavel@ucw.cz> Looks-okay-to: Rafael J. Wysocki <rjw@sisk.pl> Cc: <linux-pm@lists.linux-foundation.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30power management: implement pm_ops.valid for everybodyJohannes Berg
Almost all users of pm_ops only support mem sleep, don't check in .valid and don't reject any others in .prepare so users can be confused if they check /sys/power/state, especially when new states are added (these would then result in s-t-r although they're supposed to be something different). This patch implements a generic pm_valid_only_mem function that is then exported for users and puts it to use in almost all existing pm_ops. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: linux-pm@lists.linux-foundation.org Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30power management: remove firmware disk modeJohannes Berg
This patch removes the firmware disk suspend mode which is the wrong approach, it is supposed to be used for implementing firmware-based disk suspend but cannot actually be used for that. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: <linux-pm@lists.linux-foundation.org> Cc: David Brownell <david-b@pacbell.net> Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30rework pm_ops pm_disk_mode, kill misuseJohannes Berg
This patch series cleans up some misconceptions about pm_ops. Some users of the pm_ops structure attempt to use it to stop the user from entering suspend to disk, this, however, is not possible since the user can always use "shutdown" in /sys/power/disk and then the pm_ops are never invoked. Also, platforms that don't support suspend to disk simply should not allow configuring SOFTWARE_SUSPEND (read the help text on it, it only selects suspend to disk and nothing else, all the other stuff depends on PM). The pm_ops structure is actually intended to provide a way to enter platform-defined sleep states (currently supported states are "standby" and "mem" (suspend to ram)) and additionally (if SOFTWARE_SUSPEND is configured) allows a platform to support a platform specific way to enter low-power mode once everything has been saved to disk. This is currently only used by ACPI (S4). This patch: The pm_ops.pm_disk_mode is used in totally bogus ways since nobody really seems to understand what it actually does. This patch clarifies the pm_disk_mode description. It also removes all the arm and sh users that think they can veto suspend to disk via pm_ops; not so since the user can always do echo shutdown > /sys/power/disk, they need to find a better way involving Kconfig or such. ACPI is the only user left with a non-zero pm_disk_mode. The patch also sets the default mode to shutdown again, but when a new pm_ops is registered its pm_disk_mode is selected as default, that way the default stays for ACPI where it is apparently required. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: David Brownell <david-b@pacbell.net> Acked-by: Pavel Machek <pavel@ucw.cz> Cc: <linux-pm@lists.linux-foundation.org> Cc: Len Brown <lenb@kernel.org> Acked-by: Russell King <rmk@arm.linux.org.uk> Cc: Greg KH <greg@kroah.com> Cc: "Rafael J. Wysocki" <rjw@sisk.pl> Acked-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30reiserfs: suppress lockdep warningJeff Mahoney
We're getting lockdep warnings due to a post-2.6.21-rc7 bugfix. The xattr_sem can never be taken in the manner described. Internal inodes are protected by I_PRIVATE. Add the appropriate annotation. Cc: <stable@kernel.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30Extend print_symbol capabilityRobert Peterson
Today's print_symbol function dumps a kernel symbol with printk. This patch extends the functionality of kallsyms.c so that the symbol lookup function may be used without the printk. This is useful for modules that want to dump symbols elsewhere, for example, to debugfs. I intend to use the new function call in the GFS2 file system (which will be a separate patch). [akpm@linux-foundation.org: build fix] [clameter@sgi.com: sprint_symbol should return length of string like sprintf] Signed-off-by: Robert Peterson <rpeterso@redhat.com> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Paulo Marques <pmarques@grupopie.com> Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30[UDP]: Do not allow specific bind when wildcard bind exists.David S. Miller
When allocating local ports, do not allow a bind to a port with a specific local address when a bind to that port with a wildcard local address already exists. Noticed by Linus. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[IPV4] UDP: Fix endianness bugs in hashing changes.David S. Miller
I accidently applied an earlier version of Eric Dumazet's patch, from March 21st. His version from March 30th didn't have these bugs, so this just interdiffs to the correct patch. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (56 commits) ieee1394: remove garbage from Kconfig ieee1394: more help in Kconfig ieee1394: ohci1394: Fix mistake in printk message. ieee1394: ohci1394: remove unnecessary rcvPhyPkt bit flipping in LinkControl register ieee1394: ohci1394: fix cosmetic problem in error logging ieee1394: eth1394: send async streams at S100 on 1394b buses ieee1394: eth1394: fix error path in module_init ieee1394: eth1394: correct return codes in hard_start_xmit ieee1394: eth1394: hard_start_xmit is called in atomic context ieee1394: eth1394: some conditions are unlikely ieee1394: eth1394: clean up fragment_overlap ieee1394: eth1394: don't use alloc_etherdev ieee1394: eth1394: omit useless set_mac_address callback ieee1394: eth1394: CONFIG_INET is always defined ieee1394: eth1394: allow MTU bigger than 1500 ieee1394: unexport highlevel_host_reset ieee1394: eth1394: contain host reset ieee1394: eth1394: shorter error messages ieee1394: eth1394: correct a memset argument ieee1394: eth1394: refactor .probe and .update ...
master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jikos/hid: (21 commits) USB HID: don't warn on idVendor == 0 USB HID: add 'quirks' module parameter USB HID: add support for dynamically-created quirks USB HID: clarify static quirk handling as squirks USB HID: encapsulate quirk handling into hid-quirks.c USB HID: EMS USBII device needs HID_QUIRK_MULTI_INPUT HID: update copyright and authorship macro HID: introduce proper zeroing of unused bits in output reports USB HID: add support for WiseGroup MP-8800 Quad Joypad USB HID: add FF support for Logitech Force 3D Pro Joystick USB HID: numlock quirk for dell W7658 keyboard USB HID: Logitech MX3000 keyboard needs report descriptor quirk USB HID: extend quirk for Logitech S510 keyboard USB HID: usbkbd/usbmouse - handle errors when registering devices USB HID: add QUIRK_HIDDEV for Belkin Flip KVM HID: enable dead keys on a belkin wireless keyboard USB HID: Thustmaster firestorm dual power v1 support USB HID: specify explicit size for hid_blacklist.quirks USB HID: fix retry & reset logic USB HID: consolidate vendor/product ids ...
2007-04-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: (21 commits) [IPV4] SNMP: Support OutMcastPkts and OutBcastPkts [IPV4] SNMP: Support InMcastPkts and InBcastPkts [IPV4] SNMP: Support InTruncatedPkts [IPV4] SNMP: Support InNoRoutes [SNMP]: Add definitions for {In,Out}BcastPkts [TCP] FRTO: RFC4138 allows Nagle override when new data must be sent [TCP] FRTO: Delay skb available check until it's mandatory [XFRM]: Restrict upper layer information by bundle. [TCP]: Catch skb with S+L bugs earlier [PATCH] INET : IPV4 UDP lookups converted to a 2 pass algo [L2TP]: Add the ability to autoload a pppox protocol module. [SKB]: Introduce skb_queue_walk_safe() [AF_IUCV/IUCV]: smp_call_function deadlock [IPV6]: Fix slab corruption running ip6sic [TCP]: Update references in two old comments [XFRM]: Export SPD info [IPV6]: Track device renames in snmp6. [SCTP]: Fix sctp_getsockopt_local_addrs_old() to use local storage. [NET]: Remove NETIF_F_INTERNAL_STATS, default to internal stats. [NETPOLL]: Remove CONFIG_NETPOLL_RX ...
2007-04-30Merge branch 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'for-linus' of git://git.kernel.dk/data/git/linux-2.6-block: [PATCH] elevator: elv_list_lock does not need irq disabling [BLOCK] Don't pin lots of memory in mempools cfq-iosched: speedup cic rb lookup ll_rw_blk: add io_context private pointer cfq-iosched: get rid of cfqq hash cfq-iosched: tighten queue request overlap condition cfq-iosched: improve sync vs async workloads cfq-iosched: never allow an async queue idling cfq-iosched: get rid of ->dispatch_slice cfq-iosched: don't pass unused preemption variable around cfq-iosched: get rid of ->cur_rr and ->cfq_list cfq-iosched: slice offset should take ioprio into account [PATCH] cfq-iosched: style cleanups and comments cfq-iosched: sort IDLE queues into the rbtree cfq-iosched: sort RT queues into the rbtree [PATCH] cfq-iosched: speed up rbtree handling cfq-iosched: rework the whole round-robin list concept cfq-iosched: minor updates cfq-iosched: development update cfq-iosched: improve preemption for cooperating tasks
2007-04-30Merge branch 'for-2.6.22' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'for-2.6.22' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (255 commits) [POWERPC] Remove dev_dbg redefinition in drivers/ps3/vuart.c [POWERPC] remove kernel module option for booke wdt [POWERPC] Avoid putting cpu node twice [POWERPC] Spinlock initializer cleanup [POWERPC] ppc4xx_sgdma needs dma-mapping.h [POWERPC] arch/powerpc/sysdev/timer.c build fix [POWERPC] get_property cleanups [POWERPC] Remove the unused HTDMSOUND driver [POWERPC] cell: cbe_cpufreq cleanup and crash fix [POWERPC] Declare enable_kernel_spe in a header [POWERPC] Add dt_xlate_addr() to bootwrapper [POWERPC] bootwrapper: CONFIG_ -> CONFIG_DEVICE_TREE [POWERPC] Don't define a custom bd_t for Xilixn Virtex based boards. [POWERPC] Add sane defaults for Xilinx EDK generated xparameters files [POWERPC] Add uartlite boot console driver for the zImage wrapper [POWERPC] Stop using ppc_sys for Xilinx Virtex boards [POWERPC] New registration for common Xilinx Virtex ppc405 platform devices [POWERPC] Merge common virtex header files [POWERPC] Rework Kconfig dependancies for Xilinx Virtex ppc405 platform [POWERPC] Clean up cpufreq Kconfig dependencies ...
2007-04-30[IPV4] SNMP: Support OutMcastPkts and OutBcastPktsMitsuru Chinen
A transmitted IP multicast datagram should be counted as OutMcastPkts. By the same token, a transmitted IP broadcast datagram should be counted as OutBcastPkts. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[IPV4] SNMP: Support InMcastPkts and InBcastPktsMitsuru Chinen
A received IP multicast datagram should be counted as InMcastPkts. By the same token, a received IP broadcast datagram should be counted as InBcastPkts. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[IPV4] SNMP: Support InTruncatedPktsMitsuru Chinen
An IP datagram which is being discarded because the datagram frame didn't carry enough data should be counted as InTruncatedPkts. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[IPV4] SNMP: Support InNoRoutesMitsuru Chinen
An IP datagram which is being discarded because of no routes in the forwarding path should be counted as InNoRoutes. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[SNMP]: Add definitions for {In,Out}BcastPktsMitsuru Chinen
The updated IP-MIB RFC (RFC4293) specifys new objects, InBcastPkts and OutBcastPkts. This adds definitions for them. Signed-off-by: Mitsuru Chinen <mitch@linux.vnet.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[TCP] FRTO: RFC4138 allows Nagle override when new data must be sentIlpo Järvinen
This is a corner case where less than MSS sized new data thingie is awaiting in the send queue. For F-RTO to work correctly, a new data segment must be sent at certain point or F-RTO cannot be used at all. RFC4138 allows overriding of Nagle at that point. Implementation uses frto_counter states 2 and 3 to distinguish when Nagle override is needed. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-04-30[TCP] FRTO: Delay skb available check until it's mandatoryIlpo Järvinen
No new data is needed until the first ACK comes, so no need to check for application limitedness until then. Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi> Signed-off-by: David S. Miller <davem@davemloft.net>
