2014-08-13locking/mutexes: Use MUTEX_SPIN_ON_OWNER when appropriateDavidlohr Bueso
4badad35 ("locking/mutex: Disable optimistic spinning on some architectures") added a ARCH_SUPPORTS_ATOMIC_RMW flag to disable the mutex optimistic feature on specific archs. Because CONFIG_MUTEX_SPIN_ON_OWNER only depended on DEBUG and SMP, it was ok to have the ->owner field conditional a bit flexible. However by adding a new variable to the matter, we can waste space with the unused field, ie: CONFIG_SMP && (!CONFIG_MUTEX_SPIN_ON_OWNER && !CONFIG_DEBUG_MUTEX). Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Jason Low <jason.low2@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: aswin@hp.com Cc: Davidlohr Bueso <davidlohr@hp.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Jason Low <jason.low2@hp.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Tim Chen <tim.c.chen@linux.intel.com> Link: http://lkml.kernel.org/r/1406752916-3341-5-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-13locking/mutexes: Refactor optimistic spinning codeDavidlohr Bueso
When we fail to acquire the mutex in the fastpath, we end up calling __mutex_lock_common(). A *lot* goes on in this function. Move out the optimistic spinning code into mutex_optimistic_spin() and simplify the former a bit. Furthermore, this is similar to what we have in rwsems. No logical changes. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Jason Low <jason.low2@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: aswin@hp.com Cc: mingo@kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1406752916-3341-4-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-13locking/mcs: Remove obsolete commentDavidlohr Bueso
... as we clearly inline mcs_spin_lock() now. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Jason Low <jason.low2@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: aswin@hp.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1406752916-3341-3-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-13locking/mutexes: Document quick lock release when unlockingDavidlohr Bueso
When unlocking, we always want to reach the slowpath with the lock's counter indicating it is unlocked. -- as returned by the asm fastpath call or by explicitly setting it. While doing so, at least in theory, we can optimize and allow faster lock stealing. When unlocking, we always want to reach the slowpath with the lock's counter indicating it is unlocked. -- as returned by the asm fastpath call or by explicitly setting it. While doing so, at least in theory, we can optimize and allow faster lock stealing. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: jason.low2@hp.com Cc: aswin@hp.com Cc: Linus Torvalds <torvalds@linux-foundation.org> Link: http://lkml.kernel.org/r/1406752916-3341-2-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-13locking/mutexes: Standardize arguments in lock/unlock slowpathsDavidlohr Bueso
Just how the locking-end behaves, when unlocking, go ahead and obtain the proper data structure immediately after the previous (asm-end) call exits and there are (probably) pending waiters. This simplifies a bit some of the layering. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: jason.low2@hp.com Cc: aswin@hp.com Cc: mingo@kernel.org Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: linux-kernel@vger.kernel.org Link: http://lkml.kernel.org/r/1406752916-3341-1-git-send-email-davidlohr@hp.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-13locking: Remove deprecated smp_mb__() barriersPeter Zijlstra
Its been a while and there are no in-tree users left, so remove the deprecated barriers. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Chen, Gong <gong.chen@linux.intel.com> Cc: Jacob Pan <jacob.jun.pan@linux.intel.com> Cc: Joe Perches <joe@perches.com> Cc: John Sullivan <jsrhbz@kanargh.force9.co.uk> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Cc: Srinivas Pandruvada <srinivas.pandruvada@linux.intel.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2014-08-04Merge branch 'x86-vdso-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 vdso updates from Ingo Molnar: "Further simplifications and improvements to the VDSO code, by Andy Lutomirski" * 'x86-vdso-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86_64/vsyscall: Fix warn_bad_vsyscall log output x86/vdso: Set VM_MAYREAD for the vvar vma x86, vdso: Get rid of the fake section mechanism x86, vdso: Move the vvar area before the vdso text
2014-08-04Merge branch 'x86-uv-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 UV TLB update from Ingo Molnar: "UV TLB shootdown logic updates for version of the UV architecture" * 'x86-uv-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/uv: Update the UV3 TLB shootdown logic
2014-08-04Merge branch 'x86-ras-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RAS updates from Ingo Molnar: "The main changes in this cycle are: - RAS tracing/events infrastructure, by Gong Chen. - Various generalizations of the APEI code to make it available to non-x86 architectures, by Tomasz Nowicki" * 'x86-ras-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/ras: Fix build warnings in <linux/aer.h> acpi, apei, ghes: Factor out ioremap virtual memory for IRQ and NMI context. acpi, apei, ghes: Make NMI error notification to be GHES architecture extension. apei, mce: Factor out APEI architecture specific MCE calls. RAS, extlog: Adjust init flow trace, eMCA: Add a knob to adjust where to save event log trace, RAS: Add eMCA trace event interface RAS, debugfs: Add debugfs interface for RAS subsystem CPER: Adjust code flow of some functions x86, MCE: Robustify mcheck_init_device trace, AER: Move trace into unified interface trace, RAS: Add basic RAS trace event x86, MCE: Kill CPU_POST_DEAD
2014-08-04Merge branch 'x86-platform-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 platform updates from Ingo Molnar: "The main changes in this cycle are: - Intel SOC driver updates, by Aubrey Li. - TS5500 platform updates, by Vivien Didelot" * 'x86-platform-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/pmc_atom: Silence shift wrapping warnings in pmc_sleep_tmr_show() x86/pmc_atom: Expose PMC device state and platform sleep state x86/pmc_atom: Eisable a few S0ix wake up events for S0ix residency x86/platform: New Intel Atom SOC power management controller driver x86/platform/ts5500: Add support for TS-5400 boards x86/platform/ts5500: Add a 'name' sysfs attribute x86/platform/ts5500: Use the DEVICE_ATTR_RO() macro
2014-08-04Merge branch 'x86-mm-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 mm changes from Ingo Molnar: "The main change in this cycle is the rework of the TLB range flushing code, to simplify, fix and consolidate the code. By Dave Hansen" * 'x86-mm-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/mm: Set TLB flush tunable to sane value (33) x86/mm: New tunable for single vs full TLB flush x86/mm: Add tracepoints for TLB flushes x86/mm: Unify remote INVLPG code x86/mm: Fix missed global TLB flush stat x86/mm: Rip out complicated, out-of-date, buggy TLB flushing x86/mm: Clean up the TLB flushing code x86/smep: Be more informative when signalling an SMEP fault
2014-08-04Merge branch 'x86-efi-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull EFI changes from Ingo Molnar: "Main changes in this cycle are: - arm64 efi stub fixes, preservation of FP/SIMD registers across firmware calls, and conversion of the EFI stub code into a static library - Ard Biesheuvel - Xen EFI support - Daniel Kiper - Support for autoloading the efivars driver - Lee, Chun-Yi - Use the PE/COFF headers in the x86 EFI boot stub to request that the stub be loaded with CONFIG_PHYSICAL_ALIGN alignment - Michael Brown - Consolidate all the x86 EFI quirks into one file - Saurabh Tangri - Additional error logging in x86 EFI boot stub - Ulf Winkelvos - Support loading initrd above 4G in EFI boot stub - Yinghai Lu - EFI reboot patches for ACPI hardware reduced platforms" * 'x86-efi-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits) efi/arm64: Handle missing virtual mapping for UEFI System Table arch/x86/xen: Silence compiler warnings xen: Silence compiler warnings x86/efi: Request desired alignment via the PE/COFF headers x86/efi: Add better error logging to EFI boot stub efi: Autoload efivars efi: Update stale locking comment for struct efivars arch/x86: Remove efi_set_rtc_mmss() arch/x86: Replace plain strings with constants xen: Put EFI machinery in place xen: Define EFI related stuff arch/x86: Remove redundant set_bit(EFI_MEMMAP) call arch/x86: Remove redundant set_bit(EFI_SYSTEM_TABLES) call efi: Introduce EFI_PARAVIRT flag arch/x86: Do not access EFI memory map if it is not available efi: Use early_mem*() instead of early_io*() arch/ia64: Define early_memunmap() x86/reboot: Add EFI reboot quirk for ACPI Hardware Reduced flag efi/reboot: Allow powering off machines using EFI efi/reboot: Add generic wrapper around EfiResetSystem() ...
2014-08-04Merge branch 'x86-cpufeature-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 cpufeature updates from Ingo Molnar: "The main changes in this cycle were: - Continued cleanups of CPU bugs mis-marked as 'missing features', by Borislav Petkov. - Detect the xsaves/xrstors feature and releated cleanup, by Fenghua Yu" * 'x86-cpufeature-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, cpu: Kill cpu_has_mp x86, amd: Cleanup init_amd x86/cpufeature: Add bug flags to /proc/cpuinfo x86, cpufeature: Convert more "features" to bugs x86/xsaves: Detect xsaves/xrstors feature x86/cpufeature.h: Reformat x86 feature macros
2014-08-04Merge branches 'x86-build-for-linus', 'x86-cleanups-for-linus' and ↵Linus Torvalds
'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 build/cleanup/debug updates from Ingo Molnar: "Robustify the build process with a quirk to avoid GCC reordering related bugs. Two code cleanups. Simplify entry_64.S CFI annotations, by Jan Beulich" * 'x86-build-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86, build: Change code16gcc.h from a C header to an assembly header * 'x86-cleanups-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86: Simplify __HAVE_ARCH_CMPXCHG tests x86/tsc: Get rid of custom DIV_ROUND() macro * 'x86-debug-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/debug: Drop several unnecessary CFI annotations
2014-08-04Merge branch 'sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler updates from Ingo Molnar: - Move the nohz kick code out of the scheduler tick to a dedicated IPI, from Frederic Weisbecker. This necessiated quite some background infrastructure rework, including: * Clean up some irq-work internals * Implement remote irq-work * Implement nohz kick on top of remote irq-work * Move full dynticks timer enqueue notification to new kick * Move multi-task notification to new kick * Remove unecessary barriers on multi-task notification - Remove proliferation of wait_on_bit() action functions and allow wait_on_bit_action() functions to support a timeout. (Neil Brown) - Another round of sched/numa improvements, cleanups and fixes. (Rik van Riel) - Implement fast idling of CPUs when the system is partially loaded, for better scalability. (Tim Chen) - Restructure and fix the CPU hotplug handling code that may leave cfs_rq and rt_rq's throttled when tasks are migrated away from a dead cpu. (Kirill Tkhai) - Robustify the sched topology setup code. (Peterz Zijlstra) - Improve sched_feat() handling wrt. static_keys (Jason Baron) - Misc fixes. * 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (37 commits) sched/fair: Fix 'make xmldocs' warning caused by missing description sched: Use macro for magic number of -1 for setparam sched: Robustify topology setup sched: Fix sched_setparam() policy == -1 logic sched: Allow wait_on_bit_action() functions to support a timeout sched: Remove proliferation of wait_on_bit() action functions sched/numa: Revert "Use effective_load() to balance NUMA loads" sched: Fix static_key race with sched_feat() sched: Remove extra static_key*() function indirection sched/rt: Fix replenish_dl_entity() comments to match the current upstream code sched: Transform resched_task() into resched_curr() sched/deadline: Kill task_struct->pi_top_task sched: Rework check_for_tasks() sched/rt: Enqueue just unthrottled rt_rq back on the stack in __disable_runtime() sched/fair: Disable runtime_enabled on dying rq sched/numa: Change scan period code to match intent sched/numa: Rework best node setting in task_numa_migrate() sched/numa: Examine a task move when examining a task swap sched/numa: Simplify task_numa_compare() sched/numa: Use effective_load() to balance NUMA loads ...
2014-08-04Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Kernel side changes: - Consolidate the PMU interrupt-disabled code amongst architectures (Vince Weaver) - misc fixes Tooling changes (new features, user visible changes): - Add support for pagefault tracing in 'trace', please see multiple examples in the changeset messages (Stanislav Fomichev). - Add pagefault statistics in 'trace' (Stanislav Fomichev) - Add header for columns in 'top' and 'report' TUI browsers (Jiri Olsa) - Add pagefault statistics in 'trace' (Stanislav Fomichev) - Add IO mode into timechart command (Stanislav Fomichev) - Fallback to syscalls:* when raw_syscalls:* is not available in the perl and python perf scripts. (Daniel Bristot de Oliveira) - Add --repeat global option to 'perf bench' to be used in benchmarks such as the existing 'futex' one, that was modified to use it instead of a local option. (Davidlohr Bueso) - Fix fd -> pathname resolution in 'trace', be it using /proc or a vfs_getname probe point. (Arnaldo Carvalho de Melo) - Add suggestion of how to set perf_event_paranoid sysctl, to help non-root users trying tools like 'trace' to get a working environment. (Arnaldo Carvalho de Melo) - Updates from trace-cmd for traceevent plugin_kvm plus args cleanup (Steven Rostedt, Jan Kiszka) - Support S/390 in 'perf kvm stat' (Alexander Yarygin) Tooling infrastructure changes: - Allow reserving a row for header purposes in the hists browser (Arnaldo Carvalho de Melo) - Various fixes and prep work related to supporting Intel PT (Adrian Hunter) - Introduce multiple debug variables control (Jiri Olsa) - Add callchain and additional sample information for python scripts (Joseph Schuchart) - More prep work to support Intel PT: (Adrian Hunter) - Polishing 'script' BTS output - 'inject' can specify --kallsym - VDSO is per machine, not a global var - Expose data addr lookup functions previously private to 'script' - Large mmap fixes in events processing - Include standard stringify macros in power pc code (Sukadev Bhattiprolu) Tooling cleanups: - Convert open coded equivalents to asprintf() (Andy Shevchenko) - Remove needless reassignments in 'trace' (Arnaldo Carvalho de Melo) - Cache the is_exit syscall test in 'trace) (Arnaldo Carvalho de Melo) - No need to reimplement err() in 'perf bench sched-messaging', drop barf(). (Davidlohr Bueso). - Remove ev_name argument from perf_evsel__hists_browse, can be obtained from the other parameters. (Jiri Olsa) Tooling fixes: - Fix memory leak in the 'sched-messaging' perf bench test. (Davidlohr Bueso) - The -o and -n 'perf bench mem' options are mutually exclusive, emit error when both are specified. (Davidlohr Bueso) - Fix scrollbar refresh row index in the ui browser, problem exposed now that headers will be added and will be allowed to be switched on/off. (Jiri Olsa) - Handle the num array type in python properly (Sebastian Andrzej Siewior) - Fix wrong condition for allocation failure (Jiri Olsa) - Adjust callchain based on DWARF debug info on powerpc (Sukadev Bhattiprolu) - Fix a risk for doing free on uninitialized pointer in traceevent lib (Rickard Strandqvist) - Update attr test with PERF_FLAG_FD_CLOEXEC flag (Jiri Olsa) - Enable close-on-exec flag on perf file descriptor (Yann Droneaud) - Fix build on gcc 4.4.7 (Arnaldo Carvalho de Melo) - Event ordering fixes (Jiri Olsa)" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (123 commits) Revert "perf tools: Fix jump label always changing during tracing" perf tools: Fix perf usage string leftover perf: Check permission only for parent tracepoint event perf record: Store PERF_RECORD_FINISHED_ROUND only for nonempty rounds perf record: Always force PERF_RECORD_FINISHED_ROUND event perf inject: Add --kallsyms parameter perf tools: Expose 'addr' functions so they can be reused perf session: Fix accounting of ordered samples queue perf powerpc: Include util/util.h and remove stringify macros perf tools: Fix build on gcc 4.4.7 perf tools: Add thread parameter to vdso__dso_findnew() perf tools: Add dso__type() perf tools: Separate the VDSO map name from the VDSO dso name perf tools: Add vdso__new() perf machine: Fix the lifetime of the VDSO temporary file perf tools: Group VDSO global variables into a structure perf session: Add ability to skip 4GiB or more perf session: Add ability to 'skip' a non-piped event stream perf tools: Pass machine to vdso__dso_findnew() perf tools: Add dso__data_size() ...
2014-08-04Merge branch 'locking-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull locking updates from Ingo Molnar: "The main changes in this cycle are: - big rtmutex and futex cleanup and robustification from Thomas Gleixner - mutex optimizations and refinements from Jason Low - arch_mutex_cpu_relax() removal and related cleanups - smaller lockdep tweaks" * 'locking-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (23 commits) arch, locking: Ciao arch_mutex_cpu_relax() locking/lockdep: Only ask for /proc/lock_stat output when available locking/mutexes: Optimize mutex trylock slowpath locking/mutexes: Try to acquire mutex only if it is unlocked locking/mutexes: Delete the MUTEX_SHOW_NO_WAITER macro locking/mutexes: Correct documentation on mutex optimistic spinning rtmutex: Make the rtmutex tester depend on BROKEN futex: Simplify futex_lock_pi_atomic() and make it more robust futex: Split out the first waiter attachment from lookup_pi_state() futex: Split out the waiter check from lookup_pi_state() futex: Use futex_top_waiter() in lookup_pi_state() futex: Make unlock_pi more robust rtmutex: Avoid pointless requeueing in the deadlock detection chain walk rtmutex: Cleanup deadlock detector debug logic rtmutex: Confine deadlock logic to futex rtmutex: Simplify remove_waiter() rtmutex: Document pi chain walk rtmutex: Clarify the boost/deboost part rtmutex: No need to keep task ref for lock owner check rtmutex: Simplify and document try_to_take_rtmutex() ...
2014-08-04Merge branch 'core-rcu-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull RCU changes from Ingo Molar: "The main changes: - torture-test updates - callback-offloading changes - maintainership changes - update RCU documentation - miscellaneous fixes" * 'core-rcu-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (32 commits) rcu: Allow for NULL tick_nohz_full_mask when nohz_full= missing rcu: Fix a sparse warning in rcu_report_unblock_qs_rnp() rcu: Fix a sparse warning in rcu_initiate_boost() rcu: Fix __rcu_reclaim() to use true/false for bool rcu: Remove CONFIG_PROVE_RCU_DELAY rcu: Use __this_cpu_read() instead of per_cpu_ptr() rcu: Don't use NMIs to dump other CPUs' stacks rcu: Bind grace-period kthreads to non-NO_HZ_FULL CPUs rcu: Simplify priority boosting by putting rt_mutex in rcu_node rcu: Check both root and current rcu_node when setting up future grace period rcu: Allow post-unlock reference for rt_mutex rcu: Loosen __call_rcu()'s rcu_head alignment constraint rcu: Eliminate read-modify-write ACCESS_ONCE() calls rcu: Remove redundant ACCESS_ONCE() from tick_do_timer_cpu rcu: Make rcu node arrays static const char * const signal: Explain local_irq_save() call rcu: Handle obsolete references to TINY_PREEMPT_RCU rcu: Document deadlock-avoidance information for rcu_read_unlock() scripts: Teach get_maintainer.pl about the new "R:" tag rcu: Update rcu torture maintainership filename patterns ...
2014-08-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k Pull m68k changes from Geert Uytterhoeven: "Extremely non-spectacular changes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/geert/linux-m68k: m68k/sun3: Remove define statement no longer needed zorro: Use ARRAY_SIZE
2014-08-04Merge tag 'please-pull-misc-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux Pull ia64 cleanups from Tony Luck: "Miscellaneous ia64 specific cleanup" * tag 'please-pull-misc-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux: [IA64] sn: Do not needlessly convert between pointers and integers [IA64] sn: Fix zeroing of PDAs
2014-08-04Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Will Deacon: "Once again, Catalin's off on holiday and I'm looking after the arm64 tree. Please can you pull the following arm64 updates for 3.17? Note that this branch also includes the new GICv3 driver (merged via a stable tag from Jason's irqchip tree), since there is a fix for older binutils on top. Changes include: - context tracking support (NO_HZ_FULL) which narrowly missed 3.16 - vDSO layout rework following Andy's work on x86 - TEXT_OFFSET fuzzing for bootloader testing - /proc/cpuinfo tidy-up - preliminary work to support 48-bit virtual addresses, but this is currently disabled until KVM has been ported to use it (the patches do, however, bring some nice clean-up) - boot-time CPU sanity checks (especially useful on heterogenous systems) - support for syscall auditing - support for CC_STACKPROTECTOR - defconfig updates" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (55 commits) arm64: add newline to I-cache policy string Revert "arm64: dmi: Add SMBIOS/DMI support" arm64: fpsimd: fix a typo in fpsimd_save_partial_state ENDPROC arm64: don't call break hooks for BRK exceptions from EL0 arm64: defconfig: enable devtmpfs mount option arm64: vdso: fix build error when switching from LE to BE arm64: defconfig: add virtio support for running as a kvm guest arm64: gicv3: Allow GICv3 compilation with older binutils arm64: fix soft lockup due to large tlb flush range arm64/crypto: fix makefile rule for aes-glue-%.o arm64: Do not invoke audit_syscall_* functions if !CONFIG_AUDIT_SYSCALL arm64: Fix barriers used for page table modifications arm64: Add support for 48-bit VA space with 64KB page configuration arm64: asm/pgtable.h pmd/pud definitions clean-up arm64: Determine the vmalloc/vmemmap space at build time based on VA_BITS arm64: Clean up the initial page table creation in head.S arm64: Remove asm/pgtable-*level-types.h files arm64: Remove asm/pgtable-*level-hwdef.h files arm64: Convert bool ARM64_x_LEVELS to int ARM64_PGTABLE_LEVELS arm64: mm: Implement 4 levels of translation tables ...
2014-08-04Merge tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM changes from Paolo Bonzini: "These are the x86, MIPS and s390 changes; PPC and ARM will come in a few days. MIPS and s390 have little going on this release; just bugfixes, some small, some larger. The highlights for x86 are nested VMX improvements (Jan Kiszka), optimizations for old processor (up to Nehalem, by me and Bandan Das), and a lot of x86 emulator bugfixes (Nadav Amit). Stephen Rothwell reported a trivial conflict with the tracing branch" * tag 'for-linus' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (104 commits) x86/kvm: Resolve shadow warnings in macro expansion KVM: s390: rework broken SIGP STOP interrupt handling KVM: x86: always exit on EOIs for interrupts listed in the IOAPIC redir table KVM: vmx: remove duplicate vmx_mpx_supported() prototype KVM: s390: Fix memory leak on busy SIGP stop x86/kvm: Resolve shadow warning from min macro kvm: Resolve missing-field-initializers warnings Replace NR_VMX_MSR with its definition KVM: x86: Assertions to check no overrun in MSR lists KVM: x86: set rflags.rf during fault injection KVM: x86: Setting rflags.rf during rep-string emulation KVM: x86: DR6/7.RTM cannot be written KVM: nVMX: clean up nested_release_vmcs12 and code around it KVM: nVMX: fix lifetime issues for vmcs02 KVM: x86: Defining missing x86 vectors KVM: x86: emulator injects #DB when RFLAGS.RF is set KVM: x86: Cleanup of rflags.rf cleaning KVM: x86: Clear rflags.rf on emulated instructions KVM: x86: popf emulation should not change RF KVM: x86: Clearing rflags.rf upon skipped emulated instruction ...
2014-08-04Merge tag 'trace-3.17-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing filter cleanups from Steven Rostedt: "Oleg Nesterov did several clean ups with the tracing filter code. As he found some small bugs that went into 3.16, and these changes were based on that, I had to apply his changes to a separate branch than my main development branch. This was based on work that was already pulled into 3.16, and is a separate pull request to keep from having local merges in my pull request" * tag 'trace-3.17-2' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: tracing: Kill "filter_string" arg of replace_preds() tracing: Change apply_subsystem_event_filter() paths to check file->system == dir tracing: Kill ftrace_event_call->files tracing/uprobes: Kill the dead TRACE_EVENT_FL_USE_CALL_FILTER logic tracing: Kill call_filter_disable() tracing: Kill destroy_call_preds() tracing: Kill destroy_preds() and destroy_file_preds()
2014-08-04Merge tag 'trace-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace Pull tracing updates from Steven Rostedt: "This pull request has a lot of work done. The main thing is the changes to the ftrace function callback infrastructure. It's introducing a way to allow different functions to call directly different trampolines instead of all calling the same "mcount" one. The only user of this for now is the function graph tracer, which always had a different trampoline, but the function tracer trampoline was called and did basically nothing, and then the function graph tracer trampoline was called. The difference now, is that the function graph tracer trampoline can be called directly if a function is only being traced by the function graph trampoline. If function tracing is also happening on the same function, the old way is still done. The accounting for this takes up more memory when function graph tracing is activated, as it needs to keep track of which functions it uses. I have a new way that wont take as much memory, but it's not ready yet for this merge window, and will have to wait for the next one. Another big change was the removal of the ftrace_start/stop() calls that were used by the suspend/resume code that stopped function tracing when entering into suspend and resume paths. The stop of ftrace was done because there was some function that would crash the system if one called smp_processor_id()! The stop/start was a big hammer to solve the issue at the time, which was when ftrace was first introduced into Linux. Now ftrace has better infrastructure to debug such issues, and I found the problem function and labeled it with "notrace" and function tracing can now safely be activated all the way down into the guts of suspend and resume Other changes include clean ups of uprobe code, clean up of the trace_seq() code, and other various small fixes and clean ups to ftrace and tracing" * tag 'trace-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-trace: (57 commits) ftrace: Add warning if tramp hash does not match nr_trampolines ftrace: Fix trampoline hash update check on rec->flags ring-buffer: Use rb_page_size() instead of open coded head_page size ftrace: Rename ftrace_ops field from trampolines to nr_trampolines tracing: Convert local function_graph functions to static ftrace: Do not copy old hash when resetting tracing: let user specify tracing_thresh after selecting function_graph ring-buffer: Always run per-cpu ring buffer resize with schedule_work_on() tracing: Remove function_trace_stop and HAVE_FUNCTION_TRACE_MCOUNT_TEST s390/ftrace: remove check of obsolete variable function_trace_stop arm64, ftrace: Remove check of obsolete variable function_trace_stop Blackfin: ftrace: Remove check of obsolete variable function_trace_stop metag: ftrace: Remove check of obsolete variable function_trace_stop microblaze: ftrace: Remove check of obsolete variable function_trace_stop MIPS: ftrace: Remove check of obsolete variable function_trace_stop parisc: ftrace: Remove check of obsolete variable function_trace_stop sh: ftrace: Remove check of obsolete variable function_trace_stop sparc64,ftrace: Remove check of obsolete variable function_trace_stop tile: ftrace: Remove check of obsolete variable function_trace_stop ftrace: x86: Remove check of obsolete variable function_trace_stop ...
2014-08-04Merge tag 'ktest-v3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest Pull config-bisect changes from Steven Rostedt: "The big change here is the rewrite of config-bisect. The old way never worked properly as it assumed the bad config was a subset of the good config, and just found the config that would break the build. The new way does a diff of the bad config verses the good config and makes the similar until it finds that one config works and the other does not and reports the config that makes that difference. The two configs do not need to be related. It is much more useful now: * tag 'ktest-v3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-ktest: ktest: Update documentation on config_bisect ktest: Add the config bisect manual back ktest: Remove unused functions ktest: Put back in the CONFIG_BISECT_CHECK ktest: Rewrite the config-bisect to actually work ktest: Some cleanup for improving readability ktest: add 2nd parameter of run_command() to set the redirect target file
2014-08-04Merge tag 'clk-for-linus-3.17' of ↵Linus Torvalds
git://git.linaro.org/people/mike.turquette/linux Pull clock framework updates from Mike Turquette: "The clock framework changes for 3.17 are mostly additions of new clock drivers and fixes/enhancements to existing clock drivers. There are also some non-critical fixes and improvements to the framework core. Changes to the clock framework core include: - improvements to printks on errors - flattening the previously hierarchal structure of per-clock entries in debugfs - allow per-clock debugfs entries that are specific to a particular clock driver - configure initial clock parent and/or initial clock rate from Device Tree - several feature enhancements to the composite clock type - misc fixes New clock drivers added include: - TI Palmas PMIC - Allwinner A23 SoC - Qualcomm APQ8084 and IPQ8064 SoCs - Rockchip rk3188, rk3066 and rk3288 SoCs - STMicroelectronics STiH407 SoC - Cirrus Logic CLPS711X SoC Many fixes, feature enhancements and further clock tree support for existing clock drivers also were merged, such as Samsung's "ARMCLK down" power saving feature for their Exynos4 & Exynos5 SoCs" * tag 'clk-for-linus-3.17' of git://git.linaro.org/people/mike.turquette/linux: (86 commits) clk: Add missing of_clk_set_defaults export clk: checking wrong variable in __set_clk_parents() clk: Propagate any error return from debug_init() clk: clps711x: Add DT bindings documentation clk: Add CLPS711X clk driver clk: st: Use round to closest divider flag clk: st: Update frequency tables for fs660c32 and fs432c65 clk: st: STiH407: Support for clockgenA9 clk: st: STiH407: Support for clockgenD0/D2/D3 clk: st: STiH407: Support for clockgenC0 clk: st: Add quadfs reset handling clk: st: Add polarity bit indication clk: st: STiH407: Support for clockgenA0 clk: st: STiH407: Support for A9 MUX Clocks clk: st: STiH407: Support for Flexgen Clocks clk: st: Adds Flexgen clock binding clk: st: Remove uncessary (void *) cast clk: st: use static const for clkgen_pll_data tables clk: st: use static const for stm_fs tables clk: st: Update ST clock binding documentation ...
2014-08-04Merge branch 'for-3.17' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata Pull libata changes from Tejun Heo: "Except for a few, all the changes are for ahci platform drivers for the arm devices. Nothing too interesting or dangerous. There's one merge from libata/for-3.16-fixes to pull in dependent changes" * 'for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/libata: (23 commits) ata: libahci: Silence compiler warning on 64-bit Documentation: bindings: document the sub-nodes AHCI bindings ata: ahci_platform: add a generic AHCI compatible ata: libahci: allow to use multiple PHYs ata: libahci_platform: move port_map parameters into the AHCI structure ahci: imx: add missing clk_disable_unprepare() on error in imx_sata_enable() ahci_xgene: Use correct OOB tunning parameters for APM X-Gene SoC AHCI SATA Host controller driver. ahci_xgene: Fix the watermark threshold for the APM X-Gene SATA host controller driver. ahci: st: Make of_device_id array const sata_sil24: Identify which card suffered IRQ status error ahci: st: Provide DT bindings for ST's SATA implementation ata: Add support for the Tegra124 SATA controller ata: ahci_platform: Increase AHCI_MAX_CLKS to 4 of: Add NVIDIA Tegra SATA controller binding dt-bindings: ata: document ability to disable spread-spectrum clock ata: ahci_imx: add disable for spread-spectrum dt-bindings: ata: add ahci_imx electrical properties ata: ahci_imx: allow hardware parameters to be specified in DT dt-bindings: ata: create bindings for imx sata controller ata: pata_samsung_cf: removes s5pc100 related ata codes ...
git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup Pull cgroup changes from Tejun Heo: "Mostly changes to get the v2 interface ready. The core features are mostly ready now and I think it's reasonable to expect to drop the devel mask in one or two devel cycles at least for a subset of controllers. - cgroup added a controller dependency mechanism so that block cgroup can depend on memory cgroup. This will be used to finally support IO provisioning on the writeback traffic, which is currently being implemented. - The v2 interface now uses a separate table so that the interface files for the new interface are explicitly declared in one place. Each controller will explicitly review and add the files for the new interface. - cpuset is getting ready for the hierarchical behavior which is in the similar style with other controllers so that an ancestor's configuration change doesn't change the descendants' configurations irreversibly and processes aren't silently migrated when a CPU or node goes down. All the changes are to the new interface and no behavior changed for the multiple hierarchies" * 'for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/cgroup: (29 commits) cpuset: fix the WARN_ON() in update_nodemasks_hier() cgroup: initialize cgrp_dfl_root_inhibit_ss_mask from !->dfl_files test cgroup: make CFTYPE_ONLY_ON_DFL and CFTYPE_NO_ internal to cgroup core cgroup: distinguish the default and legacy hierarchies when handling cftypes cgroup: replace cgroup_add_cftypes() with cgroup_add_legacy_cftypes() cgroup: rename cgroup_subsys->base_cftypes to ->legacy_cftypes cgroup: split cgroup_base_files[] into cgroup_{dfl|legacy}_base_files[] cpuset: export effective masks to userspace cpuset: allow writing offlined masks to cpuset.cpus/mems cpuset: enable onlined cpu/node in effective masks cpuset: refactor cpuset_hotplug_update_tasks() cpuset: make cs->{cpus, mems}_allowed as user-configured masks cpuset: apply cs->effective_{cpus,mems} cpuset: initialize top_cpuset's configured masks at mount cpuset: use effective cpumask to build sched domains cpuset: inherit ancestor's masks if effective_{cpus, mems} becomes empty cpuset: update cs->effective_{cpus, mems} when config changes cpuset: update cpuset->effective_{cpus,mems} at hotplug cpuset: add cs->effective_cpus and cs->effective_mems cgroup: clean up sane_behavior handling ...
git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu Pull percpu updates from Tejun Heo: - Major reorganization of percpu header files which I think makes things a lot more readable and logical than before. - percpu-refcount is updated so that it requires explicit destruction and can be reinitialized if necessary. This was pulled into the block tree to replace the custom percpu refcnting implemented in blk-mq. - In the process, percpu and percpu-refcount got cleaned up a bit * 'for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/percpu: (21 commits) percpu-refcount: implement percpu_ref_reinit() and percpu_ref_is_zero() percpu-refcount: require percpu_ref to be exited explicitly percpu-refcount: use unsigned long for pcpu_count pointer percpu-refcount: add helpers for ->percpu_count accesses percpu-refcount: one bit is enough for REF_STATUS percpu-refcount, aio: use percpu_ref_cancel_init() in ioctx_alloc() workqueue: stronger test in process_one_work() workqueue: clear POOL_DISASSOCIATED in rebind_workers() percpu: Use ALIGN macro instead of hand coding alignment calculation percpu: invoke __verify_pcpu_ptr() from the generic part of accessors and operations percpu: preffity percpu header files percpu: use raw_cpu_*() to define __this_cpu_*() percpu: reorder macros in percpu header files percpu: move {raw|this}_cpu_*() definitions to include/linux/percpu-defs.h percpu: move generic {raw|this}_cpu_*_N() definitions to include/asm-generic/percpu.h percpu: only allow sized arch overrides for {raw|this}_cpu_*() ops percpu: reorganize include/linux/percpu-defs.h percpu: move accessors from include/linux/percpu.h to percpu-defs.h percpu: include/asm-generic/percpu.h should contain only arch-overridable parts percpu: introduce arch_raw_cpu_ptr() ...
2014-08-04Merge branch 'for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
Pull workqueue updates from Tejun Heo: "Lai has been doing a lot of cleanups of workqueue and kthread_work. No significant behavior change. Just a lot of cleanups all over the place. Some are a bit invasive but overall nothing too dangerous" * 'for-3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: kthread_work: remove the unused wait_queue_head kthread_work: wake up worker only when the worker is idle workqueue: use nr_node_ids instead of wq_numa_tbl_len workqueue: remove the misnamed out_unlock label in get_unbound_pool() workqueue: remove the stale comment in pwq_unbound_release_workfn() workqueue: move rescuer pool detachment to the end workqueue: unfold start_worker() into create_worker() workqueue: remove @wakeup from worker_set_flags() workqueue: remove an unneeded UNBOUND test before waking up the next worker workqueue: wake regular worker if need_more_worker() when rescuer leave the pool workqueue: alloc struct worker on its local node workqueue: reuse the already calculated pwq in try_to_grab_pending() workqueue: stronger test in process_one_work() workqueue: clear POOL_DISASSOCIATED in rebind_workers() workqueue: sanity check pool->cpu in wq_worker_sleeping() workqueue: clear leftover flags when detached workqueue: remove useless WARN_ON_ONCE() workqueue: use schedule_timeout_interruptible() instead of open code workqueue: remove the empty check in too_many_workers() workqueue: use "pool->cpu < 0" to stand for an unbound pool
2014-08-04Merge tag 'locks-v3.17-1' of git://git.samba.org/jlayton/linuxLinus Torvalds
Pull file locking related changes from Jeff Layton: "Just a couple of changes from Christoph to start us down the road toward getting rid of the fl_owner_t typedef" * tag 'locks-v3.17-1' of git://git.samba.org/jlayton/linux: locks: purge fl_owner_t from fs/locks.c locks: typedef fl_owner_t to void *
2014-08-04Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
Pull crypto update from Herbert Xu: - CTR(AES) optimisation on x86_64 using "by8" AVX. - arm64 support to ccp - Intel QAT crypto driver - Qualcomm crypto engine driver - x86-64 assembly optimisation for 3DES - CTR(3DES) speed test - move FIPS panic from module.c so that it only triggers on crypto modules - SP800-90A Deterministic Random Bit Generator (drbg). - more test vectors for ghash. - tweak self tests to catch partial block bugs. - misc fixes. * git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: (94 commits) crypto: drbg - fix failure of generating multiple of 2**16 bytes crypto: ccp - Do not sign extend input data to CCP crypto: testmgr - add missing spaces to drbg error strings crypto: atmel-tdes - Switch to managed version of kzalloc crypto: atmel-sha - Switch to managed version of kzalloc crypto: testmgr - use chunks smaller than algo block size in chunk tests crypto: qat - Fixed SKU1 dev issue crypto: qat - Use hweight for bit counting crypto: qat - Updated print outputs crypto: qat - change ae_num to ae_id crypto: qat - change slice->regions to slice->region crypto: qat - use min_t macro crypto: qat - remove unnecessary parentheses crypto: qat - remove unneeded header crypto: qat - checkpatch blank lines crypto: qat - remove unnecessary return codes crypto: Resolve shadow warnings crypto: ccp - Remove "select OF" from Kconfig crypto: caam - fix DECO RSR polling crypto: qce - Let 'DEV_QCE' depend on both HAS_DMA and HAS_IOMEM ...
2014-08-04clk: Add missing of_clk_set_defaults exportSylwester Nawrocki
The of_clk_set_defaults() function is used in subsystems which can be built as module. Add the missing symbol export entry so there is no build errors like: "ERROR: "of_clk_set_defaults" [drivers/i2c/i2c-core.ko] undefined!". Fixes commit: 86be408bfbd846fab3c4ac21d6f9298bd2e4b790 "clk: Support for clock parents and rates assigned from device tree" Reported-by: kbuild test robot <fengguang.wu@intel.com> Signed-off-by: Sylwester Nawrocki <s.nawrocki@samsung.com> Acked-by: Wolfram Sang <wsa@the-dreams.de> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-08-04Merge tag 'edac_for_3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bpLinus Torvalds
Pull EDAC changes from Borislav Petkov: "EDAC queue for 3.17: - One new edac driver for Intel E3-12xx DRAM controllers. - Out-of-subsystem changes are making the non-atomic iomem 64-bit accessors' naming explicit to show both exact order of the 32-bit accesses and the non-atomicity of the 64-bit access. Usage locations are more verbose now as to what access is exactly being done vs having a not-very telling "readq" there, for example. This is needed by E3-12xx hardware where certain mmapped registers cannot be accessed with requests crossing a dword boundary. From Jason Baron. - Extending AMD MCE signatures to a new model 60h in family 15h, from Aravind Gopalakrishnan. - An unsigned check cleanup, from Fabian Frederick" * tag 'edac_for_3.17' of git://git.kernel.org/pub/scm/linux/kernel/git/bp/bp: EDAC, MCE, AMD: Add MCE decoding for F15h M60h MAINTAINERS: add ie31200_edac entry ie31200_edac: Allocate mci and map mchbar first ie31200_edac: Introduce the driver x38_edac: make use of lo_hi_readq() readq/writeq: Add explicit lo_hi_[read|write]_q and hi_lo_[read|write]_q EDAC, edac_module.c: Remove unnecessary test on unsigned value
2014-08-04Merge tag 'pci-v3.17-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "I'll be on vacation until Aug 11, and I suspect the merge window will open before then, so I'm sending this to you early. There are more things I'd like to get into v3.17, so I hope to send another pull request soon after I return. The most notable pieces here are: - Support BARs up to 128GB (up from 8GB) - Fix SR-IOV resource assignment when we fail to expand a resource - Rework pciehp to handle a common hardware erratum - Cleanup MSI - Fix NIC renaming issue - Fix VGA default device issue on EFI systems - Fix ASPM configuration (previously we didn't enable it as expected) Alex Williamson has graciously agreed to take care of any major issues with this if you take it before I return. Details: Resource management - Support BAR sizes up to 128GB (Yinghai Lu) - Keep original resource if we fail to expand it (Guo Chao) - Return conventional error values from pci_revert_fw_address() (Bjorn Helgaas) - Tidy resource assignment messages (Bjorn Helgaas) - Don't exclude low BIOS area for non-PCI cards (Christoph Schulz) PCI device hotplug - Prevent NULL dereference during pciehp probe (Andreas Noever) - Make pciehp pcie_wait_cmd() self-contained (Bjorn Helgaas) - Wait for pciehp hotplug command completion lazily (Bjorn Helgaas) - Compute pciehp timeout from hotplug command start time (Bjorn Helgaas) - Remove pciehp assumptions about which commands cause completion events (Bjorn Helgaas) - Clear pciehp Data Link Layer State Changed during init (Myron Stowe) - Remove pciehp struct controller.no_cmd_complete (Rajat Jain) - Remove cpqphp unnecessary null test (Fabian Frederick) - Remove "invalid IRQ" warning for hot-added PCIe ports (Jiang Liu) IOMMU - Add DMA alias quirk for Intel 82801 bridge (Alex Williamson) MSI - Add internal msix_clear_and_set_ctrl() (Yijing Wang) - Remove unused msi_enabled_mask() (Yijing Wang) - Cache Multiple Message Capable in struct msi_desc (Yijing Wang) - Add msi_setup_entry() to clean up initialization (Yijing Wang) - Remove unused msi_remove_pci_irq_vectors() (Yijing Wang) - Retrieve first MSI IRQ from msi_desc rather than pci_dev (Yijing Wang) - Remove unused list access in __pci_restore_msix_state() (Yijing Wang) - Use irq_get_msi_desc() to simplify code (Yijing Wang) Generic host bridge driver - Fix GPL v2 license string typo (Bjorn Helgaas) Marvell MVEBU - Fix GPL v2 license string typo (Thierry Reding) NVIDIA Tegra - Use correct initial HW settings (Phil Edworthy) - Remove rcar_pcie_setup_window() resource argument (Phil Edworthy) - Fix GPL v2 license string typo (Thierry Reding) Renesas R-Car - Remove redundant config accessor register checks (Sergei Shtylyov) - Fix GPL v2 license string typo (Bjorn Helgaas) Virtualization - Factor secondary bus reset logic (Gavin Shan) - Remove duplicate powerpc reset logic (Gavin Shan) Miscellaneous - Rework default VGA detection for EFI (Bruno Prémont) - Fix sysfs "acpi_index" and "label" errors for NIC renaming (Simone Gotti) - Configure ASPM at pci_enable_device()-time (Vidya Sagar) - Add include/linux/pci_ids.h include guard (Rasmus Villemoes)" * tag 'pci-v3.17-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (38 commits) PCI/MSI: Use irq_get_msi_desc() to simplify code PCI/MSI: Remove unused list access in __pci_restore_msix_state() PCI/MSI: Retrieve first MSI IRQ from msi_desc rather than pci_dev PCI/MSI: Remove unused function msi_remove_pci_irq_vectors() PCI/MSI: Add msi_setup_entry() to clean up MSI initialization PCI: Configure ASPM when enabling device x86: don't exclude low BIOS area when allocating address space for non-PCI cards PCI: generic: Fix GPL v2 license string typo PCI: rcar: Fix GPL v2 license string typo PCI: tegra: Fix GPL v2 license string typo PCI: mvebu: Fix GPL v2 license string typo PCI: Add include guard to include/linux/pci_ids.h x86, ia64: Move EFI_FB vga_default_device() initialization to pci_vga_fixup() PCI: Tidy resource assignment messages PCI: Return conventional error values from pci_revert_fw_address() PCI: Cleanup control flow PCI: Support BAR sizes up to 128GB PCI: cpqphp: Remove unnecessary null test before debugfs_remove() PCI: pciehp: Clear Data Link Layer State Changed during init PCI: Add bridge DMA alias quirk for Intel 82801 bridge ...
2014-08-03Linux 3.16v3.16Linus Torvalds
2014-08-03Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fixes from Thomas Gleixner: "Two fixes in the timer area: - a long-standing lock inversion due to a printk - suspend-related hrtimer corruption in sched_clock" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: timer: Fix lock inversion between hrtimer_bases.lock and scheduler locks sched_clock: Avoid corrupting hrtimer tree during suspend
2014-08-02x86/pmc_atom: Silence shift wrapping warnings in pmc_sleep_tmr_show()Dan Carpenter
I don't know if we really need 64 bits here but these variables are declared as u64 and it can't hurt to cast this so we prevent any shift wrapping. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Aubrey Li <aubrey.li@linux.intel.com> Link: http://lkml.kernel.org/r/20140801082715.GE28869@mwanda Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2014-08-02Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A few fixes for ARM. Some of these are correctness issues: - TLBs must be flushed after the old mappings are removed by the DMA mapping code, but before the new mappings are established. - An off-by-one entry error in the Keystone LPAE setup code. Fixes include: - ensuring that the identity mapping for LPAE does not remove the kernel image from the identity map. - preventing userspace from trapping into kgdb. - fixing a preemption issue in the Intel iwmmxt code. - fixing a build error with nommu. Other changes include: - Adding a note about which areas of memory are expected to be accessible while the identity mapping tables are in place" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: 8124/1: don't enter kgdb when userspace executes a kgdb break instruction ARM: idmap: add identity mapping usage note ARM: 8115/1: LPAE: reduce damage caused by idmap to virtual memory layout ARM: fix alignment of keystone page table fixup ARM: 8112/1: only select ARM_PATCH_PHYS_VIRT if MMU is enabled ARM: 8100/1: Fix preemption disable in iwmmxt_task_enable() ARM: DMA: ensure that old section mappings are flushed from the TLB
2014-08-02ARM: 8124/1: don't enter kgdb when userspace executes a kgdb break instructionOmar Sandoval
The kgdb breakpoint hooks (kgdb_brk_fn and kgdb_compiled_brk_fn) should only be entered when a kgdb break instruction is executed from the kernel. Otherwise, if kgdb is enabled, a userspace program can cause the kernel to drop into the debugger by executing either KGDB_BREAKINST or KGDB_COMPILED_BREAK. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Omar Sandoval <osandov@osandov.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-08-02ARM: idmap: add identity mapping usage noteRussell King
Add a note about the usage of the identity mapping; we do not support accesses outside of the identity map region and kernel image while a CPU is using the identity map. This is because the identity mapping may overwrite vmalloc space, IO mappings, the vectors pages, etc. Acked-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2014-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs fixes from Al Viro: "This contains a couple of fixes - one is the aio fix from Christoph, the other a fallocate() one from Eric" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: vfs: fix check for fallocate on active swapfile direct-io: fix AIO regression
2014-08-01Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fix from Peter Anvin: "A single fix to not invoke the espfix code on Xen PV, as it turns out to oops the guest when invoked after all. This patch leaves some amount of dead code, in particular unnecessary initialization of the espfix stacks when they won't be used, but in the interest of keeping the patch minimal that cleanup can wait for the next cycle" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86_64/entry/xen: Do not invoke espfix64 on Xen
2014-08-01Merge tag 'staging-3.16-rc8' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging driver bugfixes from Greg KH: "Here are some tiny staging driver bugfixes that I've had in my tree for the past week that resolve some reported issues. Nothing major at all, but it would be good to get them merged for 3.16-rc8 or -final" * tag 'staging-3.16-rc8' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: staging: vt6655: Fix disassociated messages every 10 seconds staging: vt6655: Fix Warning on boot handle_irq_event_percpu. staging: rtl8723au: rtw_resume(): release semaphore before exit on error iio:bma180: Missing check for frequency fractional part iio:bma180: Fix scale factors to report correct acceleration units iio: buffer: Fix demux table creation
2014-08-01Merge tag 'dm-3.16-fixes-3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper fixes from Mike Snitzer: "Fix dm bufio shrinker to properly zero-fill all fields. Fix race in dm cache that caused improper reporting of the number of dirty blocks in the cache" * tag 'dm-3.16-fixes-3' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm cache: fix race affecting dirty block count dm bufio: fully initialize shrinker
2014-08-01Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM straggler SoC fix from Olof Johansson: "A DT bugfix for Nomadik that had an ambigouos double-inversion of a gpio line, and one MAINTAINER URL update that might as well go in now. We could hold off until the merge window, but then we'll just have to mark the DT fix for stable and it just seems like in total causing more work" * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: MAINTAINERS: Update Tegra Git URL ARM: nomadik: fix up double inversion in DT
2014-08-01clk: checking wrong variable in __set_clk_parents()Dan Carpenter
There is a cut and paste bug so we check "pclk" instead of "clk". Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mike Turquette <mturquette@linaro.org>
2014-08-01dm cache: fix race affecting dirty block countAnssi Hannula
nr_dirty is updated without locking, causing it to drift so that it is non-zero (either a small positive integer, or a very large one when an underflow occurs) even when there are no actual dirty blocks. This was due to a race between the workqueue and map function accessing nr_dirty in parallel without proper protection. People were seeing under runs due to a race on increment/decrement of nr_dirty, see: https://lkml.org/lkml/2014/6/3/648 Fix this by using an atomic_t for nr_dirty. Reported-by: roma1390@gmail.com Signed-off-by: Anssi Hannula <anssi.hannula@iki.fi> Signed-off-by: Joe Thornber <ejt@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org
2014-08-01dm bufio: fully initialize shrinkerGreg Thelen
1d3d4437eae1 ("vmscan: per-node deferred work") added a flags field to struct shrinker assuming that all shrinkers were zero filled. The dm bufio shrinker is not zero filled, which leaves arbitrary kmalloc() data in flags. So far the only defined flags bit is SHRINKER_NUMA_AWARE. But there are proposed patches which add other bits to shrinker.flags (e.g. memcg awareness). Rather than simply initializing the shrinker, this patch uses kzalloc() when allocating the dm_bufio_client to ensure that the embedded shrinker and any other similar structures are zeroed. This fixes theoretical over aggressive shrinking of dm bufio objects. If the uninitialized dm_bufio_client.shrinker.flags contains SHRINKER_NUMA_AWARE then shrink_slab() would call the dm shrinker for each numa node rather than just once. This has been broken since 3.12. Signed-off-by: Greg Thelen <gthelen@google.com> Acked-by: Mikulas Patocka <mpatocka@redhat.com> Signed-off-by: Mike Snitzer <snitzer@redhat.com> Cc: stable@vger.kernel.org # v3.12+
2014-08-01ata: libahci: Silence compiler warning on 64-bitThierry Reding
Commit 725c7b570fda (ata: libahci_platform: move port_map parameters into the AHCI structure) moves flags into the struct ahci_host_priv's .flags field, which causes compiler warnings on 64-bit builds when that value is cast to a void * pointer. Cast to an unsigned long so that the subsequent cast to a pointer doesn't produce a warning. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tejun Heo <tj@kernel.org>
