2009-04-02uml: fix link error from prefixing of i386 syscalls with ptregs_Miklos Szeredi
Fix the following link error: arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x11c): undefined reference to `ptregs_fork' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x140): undefined reference to `ptregs_execve' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x2cc): undefined reference to `ptregs_iopl' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x2d8): undefined reference to `ptregs_vm86old' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x2f0): undefined reference to `ptregs_sigreturn' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x2f4): undefined reference to `ptregs_clone' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x3ac): undefined reference to `ptregs_vm86' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x3c8): undefined reference to `ptregs_rt_sigreturn' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x3fc): undefined reference to `ptregs_sigaltstack' arch/um/sys-i386/built-in.o: In function `sys_call_table': (.rodata+0x40c): undefined reference to `ptregs_vfork' This was introduced by commit 253f29a4, "x86: pass in pt_regs pointer for syscalls that need it" Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Brian Gerst <brgerst@gmail.com> Cc: Tejun Heo <tj@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jeff Dike <jdike@addtoit.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02uml: fix compile error from net_device_ops conversionMiklos Szeredi
Fix the following compile error: arch/um/drivers/net_kern.c: In function 'uml_inetaddr_event': arch/um/drivers/net_kern.c:760: error: 'struct net_device' has no member named 'open' This was introduced by commit 8bb95b39, "uml: convert network device to netdevice ops". Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: David S. Miller <davem@davemloft.net> Cc: Jeff Dike <jdike@addtoit.com> Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02floppy: provide a PNP device table in the module.Scott James Remnant
The missing device table means that the floppy module is not auto-loaded, even when the appropriate PNP device (0700) is found. We don't actually use the table in the module, since the device doesn't have a struct pnp_driver, but it's sufficient to cause an alias in the module that udev/modprobe will use. Signed-off-by: Scott James Remnant <scott@canonical.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Philippe De Muyter <phdm@macqel.be> Acked-by: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02vfs: check bh->b_blocknr only if BH_Mapped is setNikanth Karthikesan
Check bh->b_blocknr only if BH_Mapped is set. akpm: I doubt if b_blocknr is ever uninitialised here, but it could conceivably cause a problem if we're doing a lookup for block zero. Signed-off-by: Nikanth Karthikesan <knikanth@suse.de> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02mm: define a UNIQUE value for AS_UNEVICTABLE flagLee Schermerhorn
A new "address_space flag"--AS_MM_ALL_LOCKS--was defined to use the next available AS flag while the Unevictable LRU was under development. The Unevictable LRU was using the same flag and "no one" noticed. Current mainline, since 2.6.28, has same value for two symbolic flag names. So, define a unique flag value for AS_UNEVICTABLE--up close to the other flags, [at the cost of an additional #ifdef] so we'll notice next time. Note that #ifdef is not actually required, if we don't mind having the unused flag value defined. Replace #defines with an enum. Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Cc: <stable@kernel.org> [2.6.28.x, 2.6.29.x] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02add fiemap.h to header-yEric Sandeen
Include fiemap.h in header-y; it defines the interface for the FS_IOC_FIEMAP file mapping ioctl. Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02MAINTAINERS: add hvc_consoleMichael Ellerman
Add a MAINTAINERS entry for the hypervisor virtual console driver. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Acked-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Josh Boyer <jwboyer@linux.vnet.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02mm: do_xip_mapping_read: fix length calculationMartin Schwidefsky
The calculation of the value nr in do_xip_mapping_read is incorrect. If the copy required more than one iteration in the do while loop the copies variable will be non-zero. The maximum length that may be passed to the call to copy_to_user(buf+copied, xip_mem+offset, nr) is len-copied but the check only compares against (nr > len). This bug is the cause for the heap corruption Carsten has been chasing for so long: *** glibc detected *** /bin/bash: free(): invalid next size (normal): 0x00000000800e39f0 *** ======= Backtrace: ========= /lib64/libc.so.6[0x200000b9b44] /lib64/libc.so.6(cfree+0x8e)[0x200000bdade] /bin/bash(free_buffered_stream+0x32)[0x80050e4e] /bin/bash(close_buffered_stream+0x1c)[0x80050ea4] /bin/bash(unset_bash_input+0x2a)[0x8001c366] /bin/bash(make_child+0x1d4)[0x8004115c] /bin/bash[0x8002fc3c] /bin/bash(execute_command_internal+0x656)[0x8003048e] /bin/bash(execute_command+0x5e)[0x80031e1e] /bin/bash(execute_command_internal+0x79a)[0x800305d2] /bin/bash(execute_command+0x5e)[0x80031e1e] /bin/bash(reader_loop+0x270)[0x8001efe0] /bin/bash(main+0x1328)[0x8001e960] /lib64/libc.so.6(__libc_start_main+0x100)[0x200000592a8] /bin/bash(clearerr+0x5e)[0x8001c092] With this bug fix the commit 0e4a9b59282914fe057ab17027f55123964bc2e2 "ext2/xip: refuse to change xip flag during remount with busy inodes" can be removed again. Cc: Carsten Otte <cotte@de.ibm.com> Cc: Nick Piggin <npiggin@suse.de> Cc: Jared Hulbert <jaredeh@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02random: align rekey_work's timerAnton Blanchard
Align rekey_work. Even though it's infrequent, we may as well line it up. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Matt Mackall <mpm@selenic.com> Cc: Theodore Ts'o <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02mm: align vmstat_work's timerAnton Blanchard
Even though vmstat_work is marked deferrable, there are still benefits to aligning it. For certain applications we want to keep OS jitter as low as possible and aligning timers and work so they occur together can reduce their overall impact. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02writeback: guard against jiffies wraparound on inode->dirtied_when checks ↵Jeff Layton
(try #3) The dirtied_when value on an inode is supposed to represent the first time that an inode has one of its pages dirtied. This value is in units of jiffies. It's used in several places in the writeback code to determine when to write out an inode. The problem is that these checks assume that dirtied_when is updated periodically. If an inode is continuously being used for I/O it can be persistently marked as dirty and will continue to age. Once the time compared to is greater than or equal to half the maximum of the jiffies type, the logic of the time_*() macros inverts and the opposite of what is needed is returned. On 32-bit architectures that's just under 25 days (assuming HZ == 1000). As the least-recently dirtied inode, it'll end up being the first one that pdflush will try to write out. sync_sb_inodes does this check: /* Was this inode dirtied after sync_sb_inodes was called? */ if (time_after(inode->dirtied_when, start)) break; ...but now dirtied_when appears to be in the future. sync_sb_inodes bails out without attempting to write any dirty inodes. When this occurs, pdflush will stop writing out inodes for this superblock. Nothing can unwedge it until jiffies moves out of the problematic window. This patch fixes this problem by changing the checks against dirtied_when to also check whether it appears to be in the future. If it does, then we consider the value to be far in the past. This should shrink the problematic window of time to such a small period (30s) as not to matter. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Acked-by: Ian Kent <raven@themaw.net> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02__tty_open(): use the correct type for saved_flagsAndrew Morton
filp->f_flags is unsigned, so use that type for the local copy. Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02vfs: skip I_CLEAR state inodesWu Fengguang
clear_inode() will switch inode state from I_FREEING to I_CLEAR, and do so _outside_ of inode_lock. So any I_FREEING testing is incomplete without a coupled testing of I_CLEAR. So add I_CLEAR tests to drop_pagecache_sb(), generic_sync_sb_inodes() and add_dquot_ref(). Masayoshi MIZUMA discovered the bug in drop_pagecache_sb() and Jan Kara reminds fixing the other two cases. Masayoshi MIZUMA has a nice panic flow: ===================================================================== [process A] | [process B] | | | prune_icache() | drop_pagecache() | spin_lock(&inode_lock) | drop_pagecache_sb() | inode->i_state |= I_FREEING; | | | spin_unlock(&inode_lock) | V | | | spin_lock(&inode_lock) | V | | | dispose_list() | | | list_del() | | | clear_inode() | | | inode->i_state = I_CLEAR | | | | | V | | | if (inode->i_state & (I_FREEING|I_WILL_FREE)) | | | continue; <==== NOT MATCH | | | | | | (DANGER from here on! Accessing disposing inode!) | | | | | | __iget() | | | list_move() <===== PANIC on poisoned list !! V V | (time) ===================================================================== Reported-by: Masayoshi MIZUMA <m.mizuma@jp.fujitsu.com> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02nommu: fix a number of issues with the per-MM VMA patchDavid Howells
Fix a number of issues with the per-MM VMA patch: (1) Make mmap_pages_allocated an atomic_long_t, just in case this is used on a NOMMU system with more than 2G pages. Makes no difference on a 32-bit system. (2) Report vma->vm_pgoff * PAGE_SIZE as a 64-bit value, not a 32-bit value, lest it overflow. (3) Move the allocation of the vm_area_struct slab back for fork.c. (4) Use KMEM_CACHE() for both vm_area_struct and vm_region slabs. (5) Use BUG_ON() rather than if () BUG(). (6) Make the default validate_nommu_regions() a static inline rather than a #define. (7) Make free_page_series()'s objection to pages with a refcount != 1 more informative. (8) Adjust the __put_nommu_region() banner comment to indicate that the semaphore must be held for writing. (9) Limit the number of warnings about munmaps of non-mmapped regions. Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02fb: nvidiafb recognizes geforcego 7300 chip as mobileSergey Senozhatsky
nvidiafb recognizes geforcego 7300 chip as mobile Signed-off-by: Sergey Senozhatsky <sergey.senozhatsky@mail.by> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-02generic debug pagealloc: build fixAkinobu Mita
This fixes a build failure with generic debug pagealloc: mm/debug-pagealloc.c: In function 'set_page_poison': mm/debug-pagealloc.c:8: error: 'struct page' has no member named 'debug_flags' mm/debug-pagealloc.c: In function 'clear_page_poison': mm/debug-pagealloc.c:13: error: 'struct page' has no member named 'debug_flags' mm/debug-pagealloc.c: In function 'page_poison': mm/debug-pagealloc.c:18: error: 'struct page' has no member named 'debug_flags' mm/debug-pagealloc.c: At top level: mm/debug-pagealloc.c:120: error: redefinition of 'kernel_map_pages' include/linux/mm.h:1278: error: previous definition of 'kernel_map_pages' was here mm/debug-pagealloc.c: In function 'kernel_map_pages': mm/debug-pagealloc.c:122: error: 'debug_pagealloc_enabled' undeclared (first use in this function) by fixing - debug_flags should be in struct page - define DEBUG_PAGEALLOC config option for all architectures Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Reported-by: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01serial: fixup /proc/tty/driver/serial after proc_fops conversionAlexey Dobriyan
"struct tty_driver *" lies in m->private not in v which is SEQ_TOKEN_START which is 1 which is enough to trigger NULL dereference next line: BUG: unable to handle kernel NULL pointer dereference at 000000ad IP: [<c040d689>] uart_proc_show+0xe/0x2b0 Noticed by Linus. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: (29 commits) [IA64] BUG to BUG_ON changes [IA64] Fix typo/thinko in arch/ia64/sn/kernel/sn2/sn2_smp.c ia64: remove some warnings. ia64/xen: fix the link error. ia64/pv_ops/bp/xen: implemented binary patchable pv_cpu_ops. ia64/pv_ops/binary patch: define paravirt_dv_serialize_data() and suppress false positive warning. ia64/pv_ops/bp/module: support binary patching for kernel module. ia64/pv_ops: implement binary patching optimization for native. ia64/pv_op/binarypatch: add helper functions to support binary patching for paravirt_ops. ia64/pv_ops/xen/gate.S: xen gate page paravirtualization ia64/pv_ops: paravirtualize gate.S. ia64/pv_ops: move down __kernel_syscall_via_epc. ia64/pv_ops/xen: define xen specific gate page. ia64/pv_ops: gate page paravirtualization. ia64/pv_ops/xen/pv_time_ops: implement sched_clock. ia64/pv_ops/pv_time_ops: add sched_clock hook. ia64/pv_ops/xen: paravirtualize read/write ar.itc and ar.itm ia64/pv_ops: paravirtualize mov = ar.itc. ia64/pv_ops/pvchecker: support mov = ar.itc paravirtualization ia64/pv_ops: paravirtualize fsys.S. ...
2009-04-01Merge branch 'x86-setup-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-setup-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, setup: guard against pre-ACPI 3 e820 code not updating %ecx
2009-04-01qeth: properly delete empty files.Linus Torvalds
Commit 64ef8957986f6a04f61e7c95fa6ffeb3a86a6661 ("qeth: remove EDDP") removed the qeth_core_offl.[hc] files, but ended up doing so by just patching them to zero size, rather than removing them properly. Actually remove the files. Reported-by: Andrew Price <andy@andrewprice.me.uk> Cc: Frank Blaschka <frank.blaschka@de.ibm.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01x86, setup: guard against pre-ACPI 3 e820 code not updating %ecxH. Peter Anvin
Impact: BIOS bug safety For pre-ACPI 3 BIOSes, pre-initialize the end of the e820 buffer just in case the BIOS returns an unchanged %ecx but without actually touching the ACPI 3 extended flags field. Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-04-01Merge branch 'x86/setup' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86/setup' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, setup: ACPI 3, BIOS workaround for E820-probing code x86, setup: preemptively save/restore edi and ebp around INT 15 E820 x86, setup: mark %esi as clobbered in E820 BIOS call
2009-04-01Merge branch 'for-linus' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6Linus Torvalds
* 'for-linus' of git://git.linux-nfs.org/projects/trondmy/nfs-2.6: (58 commits) SUNRPC: Ensure IPV6_V6ONLY is set on the socket before binding to a port NSM: Fix unaligned accesses in nsm_init_private() NFS: Simplify logic to compare socket addresses in client.c NFS: Start PF_INET6 callback listener only if IPv6 support is available lockd: Start PF_INET6 listener only if IPv6 support is available SUNRPC: Remove CONFIG_SUNRPC_REGISTER_V4 SUNRPC: rpcb_register() should handle errors silently SUNRPC: Simplify kernel RPC service registration SUNRPC: Simplify svc_unregister() SUNRPC: Allow callers to pass rpcb_v4_register a NULL address SUNRPC: rpcbind actually interprets r_owner string SUNRPC: Clean up address type casts in rpcb_v4_register() SUNRPC: Don't return EPROTONOSUPPORT in svc_register()'s helpers SUNRPC: Use IPv4 loopback for registering AF_INET6 kernel RPC services SUNRPC: Set IPV6ONLY flag on PF_INET6 RPC listener sockets NFS: Revert creation of IPv6 listeners for lockd and NFSv4 callbacks SUNRPC: Remove @family argument from svc_create() and svc_create_pooled() SUNRPC: Change svc_create_xprt() to take a @family argument SUNRPC: svc_setup_socket() gets protocol family from socket SUNRPC: Pass a family argument to svc_register() ...
2009-04-01Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tytso/ext4: (33 commits) ext4: Regularize mount options ext4: fix locking typo in mballoc which could cause soft lockup hangs ext4: fix typo which causes a memory leak on error path jbd2: Update locking coments ext4: Rename pa_linear to pa_type ext4: add checks of block references for non-extent inodes ext4: Check for an valid i_mode when reading the inode from disk ext4: Use WRITE_SYNC for commits which are caused by fsync() ext4: Add auto_da_alloc mount option ext4: Use struct flex_groups to calculate get_orlov_stats() ext4: Use atomic_t's in struct flex_groups ext4: remove /proc tuning knobs ext4: Add sysfs support ext4: Track lifetime disk writes ext4: Fix discard of inode prealloc space with delayed allocation. ext4: Automatically allocate delay allocated blocks on rename ext4: Automatically allocate delay allocated blocks on close ext4: add EXT4_IOC_ALLOC_DA_BLKS ioctl ext4: Simplify delalloc code by removing mpage_da_writepages() ext4: Save stack space by removing fake buffer heads ...
2009-04-01Merge branch 'devel' into for-linusTrond Myklebust
2009-04-01SUNRPC: Ensure IPV6_V6ONLY is set on the socket before binding to a portTrond Myklebust
Also ensure that we use the protocol family instead of the address family when calling sock_create_kern(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-01NSM: Fix unaligned accesses in nsm_init_private()Mans Rullgard
This fixes unaligned accesses in nsm_init_private() when creating nlm_reboot keys. Signed-off-by: Mans Rullgard <mans@mansr.com> Reviewed-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2009-04-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: try to free metadata pages when we free btree blocks Btrfs: add extra flushing for renames and truncates Btrfs: make sure btrfs_update_delayed_ref doesn't increase ref_mod Btrfs: optimize fsyncs on old files Btrfs: tree logging unlink/rename fixes Btrfs: Make sure i_nlink doesn't hit zero too soon during log replay Btrfs: limit balancing work while flushing delayed refs Btrfs: readahead checksums during btrfs_finish_ordered_io Btrfs: leave btree locks spinning more often Btrfs: Only let very young transactions grow during commit Btrfs: Check for a blocking lock before taking the spin Btrfs: reduce stack in cow_file_range Btrfs: reduce stalls during transaction commit Btrfs: process the delayed reference queue in clusters Btrfs: try to cleanup delayed refs while freeing extents Btrfs: reduce stack usage in some crucial tree balancing functions Btrfs: do extent allocation and reference count updates in the background Btrfs: don't preallocate metadata blocks during btrfs_search_slot
2009-04-01Merge git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bart/ide-2.6: (59 commits) ide-floppy: do not complete rq's prematurely ide: be able to build pmac driver without IDE built-in ide-pmac: IDE cable detection on Apple PowerBook ide: inline SELECT_DRIVE() ide: turn selectproc() method into dev_select() method (take 5) MAINTAINERS: move old ide-{floppy,tape} entries to CREDITS (take 2) ide: move data register access out of tf_{read|load}() methods (take 2) ide: call {in|out}put_data() methods from tf_{read|load}() methods (take 2) ide-io-std: shorten ide_{in|out}put_data() ide: rename IDE_TFLAG_IN_[HOB_]FEATURE ide: turn set_irq() method into write_devctl() method ide: use ATA_HOB ide-disk: use ATA_ERR ide: add support for CFA specified transfer modes (take 3) ide-iops: only clear DMA words on setting DMA mode ide: identify data word 53 bit 1 doesn't cover words 62 and 63 (take 3) au1xxx-ide: auide_{in|out}sw() should be static ide-floppy: use ide_pio_bytes() ide-{floppy,tape}: fix padding for PIO transfers ide: remove CONFIG_BLK_DEV_IDEDOUBLER config option ...
2009-04-01[IA64] BUG to BUG_ON changesStoyan Gaydarov
Replace: if (test) BUG(); with BUG_ON(test); Signed-off-by: Stoyan Gaydarov <stoyboyker@gmail.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-04-01Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (88 commits) PCI: fix HT MSI mapping fix PCI: don't enable too much HT MSI mapping x86/PCI: make pci=lastbus=255 work when acpi is on PCI: save and restore PCIe 2.0 registers PCI: update fakephp for bus_id removal PCI: fix kernel oops on bridge removal PCI: fix conflict between SR-IOV and config space sizing powerpc/PCI: include pci.h in powerpc MSI implementation PCI Hotplug: schedule fakephp for feature removal PCI Hotplug: rename legacy_fakephp to fakephp PCI Hotplug: restore fakephp interface with complete reimplementation PCI: Introduce /sys/bus/pci/devices/.../rescan PCI: Introduce /sys/bus/pci/devices/.../remove PCI: Introduce /sys/bus/pci/rescan PCI: Introduce pci_rescan_bus() PCI: do not enable bridges more than once PCI: do not initialize bridges more than once PCI: always scan child buses PCI: pci_scan_slot() returns newly found devices PCI: don't scan existing devices ... Fix trivial append-only conflict in Documentation/feature-removal-schedule.txt
2009-04-01[IA64] Fix typo/thinko in arch/ia64/sn/kernel/sn2/sn2_smp.cRandy Dunlap
sn2_ptc_init() has what looks like a cut-n-paste error. Fix it. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Tony Luck <tony.luck@intel.com>
2009-04-01Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] cio: online_store - trigger recognition for boxed devices [S390] cio: disallow online setting of device in transient state [S390] cio: introduce notifier for boxed state [S390] cio: introduce ccw_device_schedule_sch_unregister [S390] cio: wake up on failed recognition [S390] fix hypfs build failure [PATCH] sysrq: include interrupt.h instead of irq.h
2009-04-01efifb: dmi set video typeBrian Maly
The current logic for dmi matching in efifb does not allow efifb to load on all hardware that we can dmi match for. For a real world example, boot with elilo (3.7 or 3.8 vanilla) and on a Apple (MacBook) and EFI framebuffer driver will not load (you will have no video). This specific hardware is efi v1.10, so we have UGA and not GOP. Without special bootloader magic (i.e. extra elilo patches for UGA graphics detection) no screen info will be passed to the kernel and as a result efifb will not load. This patch allows the dmi match to happen by moving it to earlier in efifb_init, and sets the video type (in set_system) so that efifb can load when we have a valid dmi match and already know the specifics of the hardware. Without this patch the efifb driver will fail to load in the event screen info is not found and passed in by the bootloader, being that we will never get to look for a dmi match. A primary reason for matching with dmi is because not all bootloaders detect the video info properly. The solution is that in the event of a dmi match, we should set screen_info.orig_video_isVGA. Most bootloaders fail to set screen info on Apple hardware, and this is a big problem for people who use Apple hardware. Tested on a MacBook SantaRosa with elilo-3.8 (vanilla) and resolves the issue, the dmi match now works, EFI framebuffer now loads and video works. Signed-off-by: Brian Maly <bmaly@redhat.com> Acked-by: Huang Ying <ying.huang@intel.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Chandramouli Narayanan <mouli@linux.intel.com> Acked-by: Peter Jones <pjones@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01tridentfb: delete acceleration Kconfig optionKrzysztof Helt
Remove Kconfig option for tridentfb acceleration. The acceleration can be switched off with modules "noaccel" parameter. The acceleration for Trident chips was fixed in the 2.6.27 kernel. Also, add CyberXXX and CyberBlade names to Kconfig option's name. It should make easier to find the tridentfb choice for cyblafb driver's users. The cyblafb driver has been replaced by the tridentfb driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01atyfb: speed up Mach64 cursorKrzysztof Helt
Save one fifo entry on cursor enabling and disabling. Save another fifo entry for FB_CUR_SETPOS operation by removing redundant one. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01fb: hide hardware cursor in graphics mode (Mach64)Krzysztof Helt
A hardware cursor is left enabled in the fb_set_par() which is called when a new console is created. This is inconsistent with software cursor's behaviour. Also, this makes a hardware cursor always visible in the Xfbdev (Xorg kdrive) server. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: Risto Suominen <risto.suominen@gmail.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01nvidiafb: remove open_lock mutexAlessio Igor Bogani
Remove mutex from the nvidiafb_open/nvidiafb_release functions as these operations are mutexed at fb layer. Signed-off-by: Alessio Igor Bogani <abogani@texware.it> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01radeonfb: suspend/resume for ATI Mobility Radeon RV350Wolfgang Kroener
Add suspend/resume for the Acer Travelmate 290D/292LMi with the following graphic-chip: 01:00.0 VGA compatible controller [0300]: ATI Technologies Inc RV350 [Mobility Radeon 9600 M10] [1002:4e50] (prog-if 00 [VGA controller]) Subsystem: Acer Incorporated [ALI] TravelMate 290 [1025:005a] Flags: bus master, 66MHz, medium devsel, latency 128, IRQ 10 Memory at a8000000 (32-bit, prefetchable) [size=128M] I/O ports at c100 [size=256] Memory at e0010000 (32-bit, non-prefetchable) [size=64K] [virtual] Expansion ROM at a0000000 [disabled] [size=128K] Capabilities: [58] AGP version 2.0 Capabilities: [50] Power Management version 2 Kernel driver in use: radeonfb Kernel modules: radeonfb Signed-off-by: Wolfgang Kroener <lkml@azog.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01omapfb: fix argument of blank operationFelipe Contreras
The blank operation should receive FB_BLANK_POWERDOWN, not VESA_POWERDOWN. Signed-off-by: Felipe Contreras <felipe.contreras@nokia.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Andrea Righi <righi.andrea@gmail.com> Acked-by: Trilok Soni <soni.trilok@gmail.com> Cc: Imre Deak <imre.deak@solidboot.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01uvesafb: fix selecting mode with the vbemode optionMichal Januszewski
If the vbemode option is used, uvesafb calls fb_get_mode() without first setting the resolution in info->var. This results in a division by zero in fb_get_mode(), as evidenced e.g. in [1]. Fix this by ensuring the info->var structure is populated before fb_get_mode() is called. [1] http://bugzilla.kernel.org/show_bug.cgi?id=11661#c37 Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01fbdev: remove cyblafb driverKrzysztof Helt
A tridentfb driver has all the functionality of the cyblafb driver without the bugs of the latter. Changes to the tridentfb driver: - FBINFO_READS_FAST added to the tridentfb. The cyblafb used a blitter for scrolling which is faster than color expansion on Cyberblade chipsets. The blitter is slower on a discrete Blade3D core. Use the blitter for scrolling in the tridentfb only for integrated Blade3D cores. Now, scrolling speed is about equal for the tridentfb and the cyblafb. - a copyright notice addition is done on request of Jani Monoses (the first author of the tridentfb). Tested on AGP Blade3D card and PCChips M787CLR motherboard: VIA C3 cpu + VT8601 north bridge (aka Cyberblade/i1). Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Cc: "Jani Monoses" <jani@ubuntu.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01fb: add s3c-fb driver for newer Samsung SoC framebuffer devicesBen Dooks
Add support for the newer Samsung devices, such as found in the S3C2443, S3C6400 or S3C6410 series SoC. It currently does not support all the alpha- or chroma-key options but it will support more exporting more than one framebuffer ready for adding overlay and blending functions. Signed-off-by: Ben Dooks <ben-linux@fluff.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01n411: add missing Makefile entryHerton Ronaldo Krzesinski
There is no entry for n411.c to be built, include one in Makefile. Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br> Cc: Jaya Kumar <jayakumar.lkml@gmail.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01viafb: returns 0 two too earlyRoel Kluin
Otherwise this will already return 0 if iteration MAXLOOP-2 occurs in the first loop. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Joseph Chan <josephchan@via.com.tw> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01vesafb: bitwise OR has higher precedence than ?:Roel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Michal Januszewski <michalj@gmail.com> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01uvesafb: bitwise OR has higher precedence than ?:Roel Kluin
2009-04-01arkfb: fix misplaced parenthesesRoel Kluin
Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Ondrej Zajicek <santiago@crfreenet.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01asiliantfb: fix cmap memory leaksAndres Salomon
- fix cmap leak in removal path - fix cmap leak when register_framebuffer fails - check return value of fb_alloc_cmap - don't continue with driver setup if register_framebuffer fails [krzysztof.h1@wp.pl: spotted missing iounmap] [randy.dunlap@oracle.com: move data declaration before any code] Signed-off-by: Andres Salomon <dilinger@debian.org> Cc: Krzysztof Helt <krzysztof.h1@wp.pl> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01drivers/video/omap/hwa742.c: div reaches max_clk_divRoel Kluin
With for(div = 0; div < max_clk_div; div++) { ... } div reaches max_clk_div. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Joe Perches <joe@perches.com> Acked-by: Trilok Soni <soni.trilok@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
