2011-03-04PCI: aer-inject: Override PCIe AER Mask RegistersPrarit Bhargava
I have several systems which have the same problem: The PCIe AER corrected and uncorrected masks have all the error bits set. This results in the inablility to test with the aer_inject module & utility on those systems. Add the 'aer_mask_override' module parameter which will override the corrected or uncorrected masks for a PCI device. The mask will have the bit corresponding to the status passed into the aer_inject() function. After this patch it is possible to successfully use the aer_inject utility on those PCI slots. Successfully tested by me on a Dell and Intel whitebox which exhibited the mask problem. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-02-16PCI: fix tlan build when CONFIG_PCI is not enabledRandy Dunlap
When CONFIG_PCI is not enabled, tlan.c has a build error: drivers/net/tlan.c:503: error: implicit declaration of function 'pci_wake_from_d3' so add an inline function stub for this function to pci.h when PCI is not enabled, similar to other stubbed PCI functions. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Sakari Ailus <sakari.ailus@iki.fi> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-02-16PCI: remove quirk for pre-production systemsBrandeburg, Jesse
Revert commit 7eb93b175d4de9438a4b0af3a94a112cb5266944 Author: Yu Zhao <yu.zhao@intel.com> Date: Fri Apr 3 15:18:11 2009 +0800 PCI: SR-IOV quirk for Intel 82576 NIC If BIOS doesn't allocate resources for the SR-IOV BARs, zero the Flash BAR and program the SR-IOV BARs to use the old Flash Memory Space. Please refer to Intel 82576 Gigabit Ethernet Controller Datasheet section 7.9.2.14.2 for details. http://download.intel.com/design/network/datashts/82576_Datasheet.pdf Signed-off-by: Yu Zhao <yu.zhao@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> This quirk was added before SR-IOV was in production and now all machines that originally had this issue alreayd have bios updates to correct the issue. The quirk itself is no longer needed and in fact causes bugs if run. Remove it. Signed-off-by: Jesse Brandeburg <jesse.brandeburg@intel.com> CC: Yu Zhao <yu.zhao@intel.com> CC: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-02-08PCI: Avoid potential NULL pointer dereference in pci_scan_bridgeJesper Juhl
pci_add_new_bus() calls pci_alloc_child_bus() which calls pci_alloc_bus() that allocates memory dynamically with kzalloc(). The return value of kzalloc() is the pointer that's eventually returned from pci_add_new_bus(), so since kzalloc() can fail and return NULL so can pci_add_new_bus(). Thus we may end up dereferencing a NULL pointer in drivers/pci/probe.c::pci_scan_bridge(). Seems to me we should test for this and bail out if it happens rather than crashing. Also removed some trailing whitespace that bugged me while looking at this. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-02-08PCI/lpc: irq and pci_ids patch for Intel DH89xxCC DeviceIDsSeth Heasley
This patch adds the LPC Controller DeviceIDs for the Intel DH89xxCC PCH. The code for capturing ranges of LPC Controller DeviceIDs has also been updated. Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Seth Heasley <seth.heasley@intel.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-02-08PCI: sysfs: Fix failure path for addition of "vpd" attributeBen Hutchings
Commit 280c73d ("PCI: centralize the capabilities code in pci-sysfs.c") changed the initialisation of the "rom" and "vpd" attributes, and made the failure path for the "vpd" attribute incorrect. We must free the new attribute structure (attr), but instead we currently free dev->vpd->attr. That will normally be NULL, resulting in a memory leak, but it might be a stale pointer, resulting in a double-free. Found by inspection; compile-tested only. Cc: stable@kernel.org Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2011-02-07Linux 2.6.38-rc4v2.6.38-rc4Linus Torvalds
2011-02-07Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* master.kernel.org:/home/rmk/linux-2.6-arm: ALSA: AACI: allow writes to MAINCR to take effect ARM: Update mach-types ARM: 6652/1: ep93xx: correct the end address of the AC97 memory resource ARM: mxs/imx28: remove now unused clock lookup "fec.0" ARM: mxs: fix clock base address missing ARM: mxs: acknowledge gpio irq ARM: mach-imx/mach-mx25_3ds: Fix section type ARM: imx: Add VPR200 and MX51_3DS entries to uncompress.h ARM i.MX23: use correct register for setting the rate ARM i.MX23/28: remove secondary field from struct clk. It's unused ARM i.MX28: use correct register for setting the rate ARM i.MX28: fix bit operation
2011-02-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: (33 commits) Btrfs: Fix page count calculation btrfs: Drop __exit attribute on btrfs_exit_compress btrfs: cleanup error handling in btrfs_unlink_inode() Btrfs: exclude super blocks when we read in block groups Btrfs: make sure search_bitmap finds something in remove_from_bitmap btrfs: fix return value check of btrfs_start_transaction() btrfs: checking NULL or not in some functions Btrfs: avoid uninit variable warnings in ordered-data.c Btrfs: catch errors from btrfs_sync_log Btrfs: make shrink_delalloc a little friendlier Btrfs: handle no memory properly in prepare_pages Btrfs: do error checking in btrfs_del_csums Btrfs: use the global block reserve if we cannot reserve space Btrfs: do not release more reserved bytes to the global_block_rsv than we need Btrfs: fix check_path_shared so it returns the right value btrfs: check return value of btrfs_start_ioctl_transaction() properly btrfs: fix return value check of btrfs_join_transaction() fs/btrfs/inode.c: Add missing IS_ERR test btrfs: fix missing break in switch phrase btrfs: fix several uncheck memory allocations ...
2011-02-07Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc: Fix hcall tracepoint recursion powerpc/numa: Fix bug in unmap_cpu_from_node powerpc/numa: Disable VPHN on dedicated processor partitions powerpc/numa: Add length when creating OF properties via VPHN powerpc/numa: Check for all VPHN changes powerpc/numa: Only use active VPHN count fields powerpc/pseries: Remove unnecessary variable initializations in numa.c powerpc/pseries: Fix brace placement in numa.c powerpc/pseries: Fix typo in VPHN comments powerpc: Fix some 6xx/7xxx CPU setup functions powerpc: Pass the right cpu_spec to ->setup_cpu() on 64-bit powerpc/book3e: Protect complex macro args in mmu-book3e.h powerpc: Fix pfn_valid() when memory starts at a non-zero address
2011-02-07Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: arm: omap4: panda: remove usb_nop_xceiv_register(v1) OMAP1: Fix non-working LCD on OMAP310 OMAP3: Devkit8000: Change lcd power pin omap1: remove duplicated #include arm: mach-omap2: mux: free allocated memory on error exit arm: mach-omap2: board-rm680: fix rm680_vemmc regulator constraints OMAP: PM: SmartReflex: Fix possible null pointer read access OMAP: PM: SmartReflex: Fix possible memory leak arm: mach-omap2: voltage: debugfs: fix memory leak OMAP3: PM: fix save secure RAM to restore MPU power state OMAP: PM: SmartReflex: Add missing IS_ERR test
2011-02-07Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, nx: Mark the ACPI resume trampoline code as +x
2011-02-07CRED: Fix memory and refcount leaks upon security_prepare_creds() failureTetsuo Handa
In prepare_kernel_cred() since 2.6.29, put_cred(new) is called without assigning new->usage when security_prepare_creds() returned an error. As a result, memory for new and refcount for new->{user,group_info,tgcred} are leaked because put_cred(new) won't call __put_cred() unless old->usage == 1. Fix these leaks by assigning new->usage (and new->subscribers which was added in 2.6.32) before calling security_prepare_creds(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-07CRED: Fix BUG() upon security_cred_alloc_blank() failureTetsuo Handa
In cred_alloc_blank() since 2.6.32, abort_creds(new) is called with new->security == NULL and new->magic == 0 when security_cred_alloc_blank() returns an error. As a result, BUG() will be triggered if SELinux is enabled or CONFIG_DEBUG_CREDENTIALS=y. If CONFIG_DEBUG_CREDENTIALS=y, BUG() is called from __invalid_creds() because cred->magic == 0. Failing that, BUG() is called from selinux_cred_free() because selinux_cred_free() is not expecting cred->security == NULL. This does not affect smack_cred_free(), tomoyo_cred_free() or apparmor_cred_free(). Fix these bugs by (1) Set new->magic before calling security_cred_alloc_blank(). (2) Handle null cred->security in creds_are_invalid() and selinux_cred_free(). Signed-off-by: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-07Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: remove checks for ses->status == CifsExiting cifs: add check for kmalloc in parse_dacl cifs: don't send an echo request unless NegProt has been done cifs: enable signing flag in SMB header when server has it on cifs: Possible slab memory corruption while updating extended stats (repost) CIFS: Fix variable types in cifs_iovec_read/write (try #2) cifs: fix length vs. total_read confusion in cifs_demultiplex_thread
2011-02-07Btrfs: Fix page count calculationYan, Zheng
take offset of start position into account when calculating page count. Signed-off-by: Yan, Zheng <zheng.z.yan@intel.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-07Merge branch 'fixes'Russell King
2011-02-07cifs: remove checks for ses->status == CifsExitingJeff Layton
ses->status is never set to CifsExiting, so these checks are always false. Tested-by: JG <jg@cms.ac> Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-02-07Merge branch 'for-rmk' of git://git.pengutronix.de/git/imx/linux-2.6 into fixesRussell King
2011-02-07ALSA: AACI: allow writes to MAINCR to take effectRussell King
The AACI TRM requires the MAINCR enable bit to be held zero for two bitclk cycles plus three apb_pclk cycles. Use a delay of 1us to ensure this. Ensure that writes to MAINCR to change the addressed codec only happen when required, and that they take effect in a similar manner to the above, otherwise we seem to occasionally have stuck slot busy bits. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2011-02-07ARM: Update mach-typesRussell King
2011-02-07x86, nx: Mark the ACPI resume trampoline code as +xH. Peter Anvin
We reserve lowmem for the things that need it, like the ACPI wakeup code, way early to guarantee availability. This happens before we set up the proper pagetables, so set_memory_x() has no effect. Until we have a better solution, use an initcall to mark the wakeup code executable. Originally-by: Matthieu Castet <castet.matthieu@free.fr> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Matthias Hopf <mhopf@suse.de> Cc: rjw@sisk.pl Cc: Suresh Siddha <suresh.b.siddha@intel.com> LKML-Reference: <4D4F8019.2090104@zytor.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-07powerpc: Fix hcall tracepoint recursionAnton Blanchard
Spinlocks on shared processor partitions use H_YIELD to notify the hypervisor we are waiting on another virtual CPU. Unfortunately this means the hcall tracepoints can recurse. The patch below adds a percpu depth and checks it on both the entry and exit hcall tracepoints. Signed-off-by: Anton Blanchard <anton@samba.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: stable@kernel.org
2011-02-07powerpc/numa: Fix bug in unmap_cpu_from_nodeAnton Blanchard
When converting to the new cpumask code I screwed up: - if (cpu_isset(cpu, numa_cpumask_lookup_table[node])) { - cpu_clear(cpu, numa_cpumask_lookup_table[node]); + if (cpumask_test_cpu(cpu, node_to_cpumask_map[node])) { + cpumask_set_cpu(cpu, node_to_cpumask_map[node]); This was introduced in commit 25863de07af9 (powerpc/cpumask: Convert NUMA code to new cpumask API) Fix it. Signed-off-by: Anton Blanchard <anton@samba.org> Cc: <stable@kernel.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc/numa: Disable VPHN on dedicated processor partitionsAnton Blanchard
There is no need to start up the timer and monitor topology changes on a dedicated processor partition, so disable it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc/numa: Add length when creating OF properties via VPHNAnton Blanchard
The rest of the NUMA code expects an OF associativity property with the first cell containing the length. Without this fix all topology changes cause us to misparse the property and put the cpu into node 0. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc/numa: Check for all VPHN changesAnton Blanchard
The hypervisor uses unsigned 1 byte counters to signal topology changes to the OS. Since they can wrap we need to check for any difference, not just if the hypervisor count is greater than the previous count. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc/numa: Only use active VPHN count fieldsAnton Blanchard
VPHN supports up to 8 distance fields but the number of entries in ibm,associativity-reference-points signifies how many are in use. Don't look at all the VPHN counts, only distance_ref_points_depth worth. Since we already cap our distance metrics at MAX_DISTANCE_REF_POINTS, use that to size the VPHN arrays and add a BUILD_BUG_ON to avoid it growing larger than the VPHN maximum of 8. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc/pseries: Remove unnecessary variable initializations in numa.cJesse Larrew
Remove unnecessary variable initializations in VPHN functions. Signed-off-by: Jesse Larrew <jlarrew@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc/pseries: Fix brace placement in numa.cJesse Larrew
Fix brace placement in VPHN code. Signed-off-by: Jesse Larrew <jlarrew@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc/pseries: Fix typo in VPHN commentsJesse Larrew
Correct a spelling error in VPHN comments in numa.c. Signed-off-by: Jesse Larrew <jlarrew@linux.vnet.ibm.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc: Fix some 6xx/7xxx CPU setup functionsBenjamin Herrenschmidt
Some of those functions try to adjust the CPU features, for example to remove NAP support on some revisions. However, they seem to use r5 as an index into the CPU table entry, which might have been right a long time ago but no longer is. r4 is the right register to use. This probably caused some off behaviours on some PowerMac variants using 750cx or 7455 processor revisions. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> CC: stable@kernel.org
2011-02-07powerpc: Pass the right cpu_spec to ->setup_cpu() on 64-bitBenjamin Herrenschmidt
When calling setup_cpu() on 64-bit, we pass a pointer to the cputable entry we have found. This used to be fine when cur_cpu_spec was a pointer to that entry, but nowadays, we copy the entry into a separate variable, and we do so before we call the setup_cpu() callback. That means that any attempt by that callback at patching the CPU table entry (to adjust CPU features for example) will patch the wrong table. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc/book3e: Protect complex macro args in mmu-book3e.hScott Wood
Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-07powerpc: Fix pfn_valid() when memory starts at a non-zero addressScott Wood
max_mapnr is a pfn, not an index innto mem_map[]. So don't add ARCH_PFN_OFFSET a second time. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2011-02-06Merge branch 'ixp4xx' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6 * 'ixp4xx' of git://git.kernel.org/pub/scm/linux/kernel/git/chris/linux-2.6: arm/ixp4xx: Rename FREQ macro to avoid collisions IXP4xx: Fix qmgr_release_queue() flushing unexpected queue entries.
2011-02-06Merge branch 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: lockdep, timer: Fix del_timer_sync() annotation RTC: Prevents a division by zero in kernel code.
2011-02-06Merge branch 'irq-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'irq-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: m32r: Fixup last __do_IRQ leftover genirq: Add missing status flags to modification mask
2011-02-06Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: perf stat: Fix aggreate counter reading accounting tracing: Replace syscall_meta_data struct array with pointer array tracepoints: Fix section alignment using pointer array tracing: Replace trace_event struct array with pointer array
2011-02-06Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86-32: Make sure the stack is set up before we use it x86, mtrr: Avoid MTRR reprogramming on BP during boot on UP platforms x86, nx: Don't force pages RW when setting NX bits
2011-02-06Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: ALSA: use linux/io.h to fix compile warnings ALSA: hda - Fix memory leaks in conexant jack arrays ASoC: CX20442: fix NULL pointer dereference ASoC: Amstrad Delta: fix const related build error ALSA: oxygen: fix output routing on Xonar DG sound: silent echo'ed messages in Makefile ASoC: Fix mask/val_mask confusion snd_soc_dapm_put_volsw() ASoC: DaVinci: fix kernel panic due to uninitialized platform_data ALSA: HDA: Fix microphone(s) on Lenovo Edge 13 ASoC: Fix module refcount for auxiliary devices ALSA: HDA: cxt5066 - Use asus model for Asus U50F, select correct SPDIF output ALSA: HDA: Add a new model "asus" for Conexant 5066/205xx ALSA: HDA: Refactor some redundant code for Conexant 5066/205xx
2011-02-06arm/ixp4xx: Rename FREQ macro to avoid collisionsBen Hutchings
FREQ is a ridiculously short name for a platform-specific macro in a generic header, and it now conflicts with an enumeration in the gspca/ov519 driver. Also delete conditional reference to ixp4xx_get_board_tick_rate() which is not defined anywhere. Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2011-02-06IXP4xx: Fix qmgr_release_queue() flushing unexpected queue entries.Krzysztof Hałasa
Queues should be empty when released, if not, there is a safety valve. Make sure the queue is usable after it triggers. Signed-off-by: Krzysztof Hałasa <khc@pm.waw.pl>
2011-02-06btrfs: Drop __exit attribute on btrfs_exit_compressAlexey Charkov
As this function is called in some error paths while not removing the module, the __exit attribute prevents the kernel image from linking when btrfs is compiled in statically. Signed-off-by: Alexey Charkov <alchark@gmail.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-06btrfs: cleanup error handling in btrfs_unlink_inode()Tsutomu Itoh
When btrfs_alloc_path() fails, btrfs_free_path() need not be called. Therefore, it changes the branch ahead. Signed-off-by: Tsutomu Itoh <t-itoh@jp.fujitsu.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-06Btrfs: exclude super blocks when we read in block groupsJosef Bacik
This has been resulting in a BUT_ON(ret) after btrfs_reserve_extent in btrfs_cow_file_range. The reason is we don't actually calculate the bytes_super for a block group until we go to cache it, which means that the space_info can hand out reservations for space that it doesn't actually have, and we can run out of data space. This is also a problem if you are using space caching since we don't ever calculate bytes_super for the block groups. So instead everytime we read a block group call exclude_super_stripes, which calculates the bytes_super for the block group so it can be left out of the space_info. Then whenever caching completes we just call free_excluded_extents so that the super excluded extents are freed up. Also if we are unmounting and we hit any block groups that haven't been cached we still need to call free_excluded_extents to make sure things are cleaned up properly. Thanks, Reported-by: Arne Jansen <sensille@gmx.net> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-06Btrfs: make sure search_bitmap finds something in remove_from_bitmapJosef Bacik
When we're cleaning up the tree log we need to be able to remove free space from the block group. The problem is if that free space spans bitmaps we would not find the space since we're looking for too many bytes. So make sure the amount of bytes we search for is limited to either the number of bytes we want, or the number of bytes left in the bitmap. This was tested by a user who was hitting the BUG() after search_bitmap. With this patch he can now mount his fs. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-02-06Merge branch 'timers/locking'Ingo Molnar
2011-02-06cifs: add check for kmalloc in parse_daclStanislav Fomichev
Exit from parse_dacl if no memory returned from the call to kmalloc. Signed-off-by: Stanislav Fomichev <kernel@fomichev.me> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-02-05m32r: Fixup last __do_IRQ leftoverThomas Gleixner
Somehow I managed to miss the last __do_IRQ caller when I cleanup the remaining users. m32r is fully converted to the generic irq layer, but I managed to not commit the conversion of __do_IRQ() to generic_handle_irq() after compile testing the quilt series :( Pointed-out-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Hirokazu Takata <takata@linux-m32r.org> Cc: Paul Mundt <lethal@linux-sh.org>
