2015-07-19Merge tag 'scsi-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi Pull SCSI fixes from James Bottomley: "Two fairly simple fixes: one is a change that causes us to have a very low queue depth leading to performance issues and the other is a null deref occasionally in tapes thanks to use after put" * tag 'scsi-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jejb/scsi: scsi: fix host max depth checking for the 'queue_depth' sysfs interface st: null pointer dereference panic caused by use after kref_put by st_open
2015-07-19Merge branch 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linusLinus Torvalds
Pull MIPS fixes from Ralf Baechle: "Another round of MIPS fixes for 4.2. Things are looking quite decent at this stage but the recent work on the FPU support took its toll: - fix an incorrect overly restrictive ifdef - select O32 64-bit FP support for O32 binary compatibility - remove workarounds for Sibyte SB1250 Pass1 parts. There are rare fixing the workarounds is not worth the effort. - patch up an outdated and now incorrect comment" * 'upstream' of git://git.linux-mips.org/pub/scm/ralf/upstream-linus: MIPS: fpu.h: Allow 64-bit FPU on a 64-bit MIPS R6 CPU MIPS: SB1: Remove support for Pass 1 parts. MIPS: Require O32 FP64 support for MIPS64 with O32 compat MIPS: asm-offset.c: Patch up various comments refering to the old filename.
2015-07-19Merge branch 'parisc-4.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux Pull parisc fix from Helge Deller: "A memory leak fix from Christophe Jaillet which was introduced with kernel 4.0 and which leads to kernel crashes on parisc after 1-3 days" * 'parisc-4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/deller/parisc-linux: parisc: mm: Fix a memory leak related to pmd not attached to the pgd
2015-07-19Merge tag 'armsoc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "By far most of the fixes here are updates to DTS files to deal with some mostly minor bugs. There's also a fix to deal with non-PM kernel configs on i.MX, a regression fix for ethernet on PXA platforms and a dependency fix for OMAP" * tag 'armsoc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: keystone: dts: rename pcie nodes to help override status ARM: keystone: dts: fix dt bindings for PCIe ARM: pxa: fix dm9000 platform data regression ARM: dts: Correct audio input route & set mic bias for am335x-pepper ARM: OMAP2+: Add HAVE_ARM_SCU for AM43XX MAINTAINERS: digicolor: add dts files ARM: ux500: fix MMC/SD card regression ARM: ux500: define serial port aliases ARM: dts: OMAP5: Add #iommu-cells property to IOMMUs ARM: dts: OMAP4: Add #iommu-cells property to IOMMUs ARM: dts: Fix frequency scaling on Gumstix Pepper ARM: dts: configure regulators for Gumstix Pepper ARM: dts: omap3: overo: Update LCD panel names ARM: dts: cros-ec-keyboard: Add support for some Japanese keys ARM: imx6: gpc: always enable PU domain if CONFIG_PM is not set ARM: dts: imx53-qsb: fix TVE entry ARM: dts: mx23: fix iio-hwmon support ARM: dts: imx27: Adjust the GPT compatible string ARM: socfpga: dts: Fix entries order ARM: socfpga: dts: Fix adxl34x formating and compatible string
2015-07-19MIPS: fpu.h: Allow 64-bit FPU on a 64-bit MIPS R6 CPUMarkos Chandras
Commit 6134d94923d0 ("MIPS: asm: fpu: Allow 64-bit FPU on MIPS32 R6") added support for 64-bit FPU on a 32-bit MIPS R6 processor but it missed the 64-bit CPU case leading to FPU failures when requesting FR=1 mode (which is always the case for MIPS R6 userland) when running a 32-bit kernel on a 64-bit CPU. We also fix the MIPS R2 case. Signed-off-by: Markos Chandras <markos.chandras@imgtec.com> Fixes: 6134d94923d0 ("MIPS: asm: fpu: Allow 64-bit FPU on MIPS32 R6") Reviewed-by: Paul Burton <paul.burton@imgtec.com> Cc: <stable@vger.kernel.org> # 4.0+ Cc: linux-mips@linux-mips.org Patchwork: https://patchwork.linux-mips.org/patch/10734/ Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2015-07-19parisc: mm: Fix a memory leak related to pmd not attached to the pgdChristophe Jaillet
Commit 0e0da48dee8d ("parisc: mm: don't count preallocated pmds") introduced a memory leak. After this commit, the 'return' statement in pmd_free is executed in all cases. Even for pmd that are not attached to the pgd. So 'free_pages' can never be called anymore, leading to a memory leak. Signed-off-by: Christophe JAILLET <christophe.jaillet@wanadoo.fr> Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Mikulas Patocka <mpatocka@redhat.com> Acked-by: Helge Deller <deller@gmx.de> Cc: stable@vger.kernel.org # v4.0+ Signed-off-by: Helge Deller <deller@gmx.de>
2015-07-18Merge tag 'pxa-fixes-v4.2-rc2' of https://github.com/rjarzmik/linux into fixesDOlof Johansson
Merge "pxa fixes for v4.2" from Robert Jarzmik: ARM: pxa: fixes for v4.2-rc2 This single fix reenables ethernet cards for several pxa boards, broken by regulator addition to dm9000 driver. * tag 'pxa-fixes-v4.2-rc2' of https://github.com/rjarzmik/linux: ARM: pxa: fix dm9000 platform data regression
2015-07-18Merge branch 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-armLinus Torvalds
Pull ARM fixes from Russell King: "A small set of ARM fixes for -rc3, most of them not far off one-liners, with the exception of fixing the V7 cache invalidation for incoming SMP processors which was causing problems for SoCFPGA devices" * 'fixes' of git://ftp.arm.linux.org.uk/~rmk/linux-arm: ARM: fix __virt_to_idmap build error on !MMU ARM: invalidate L1 before enabling coherency ARM: 8404/1: dma-mapping: fix off-by-one error in bitmap size check ARM: 8402/1: perf: Don't use of_node after putting it ARM: 8400/1: use virt_to_idmap to get phys_reset address
2015-07-18Merge branch 'x86-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull x86 fixes from Ingo Molnar: "Two families of fixes: - Fix an FPU context related boot crash on newer x86 hardware with larger context sizes than what most people test. To fix this without ugly kludges or extensive reverts we had to touch core task allocator, to allow x86 to determine the task size dynamically, at boot time. I've tested it on a number of x86 platforms, and I cross-built it to a handful of architectures: (warns) (warns) testing x86-64: -git: pass ( 0), -tip: pass ( 0) testing x86-32: -git: pass ( 0), -tip: pass ( 0) testing arm: -git: pass ( 1359), -tip: pass ( 1359) testing cris: -git: pass ( 1031), -tip: pass ( 1031) testing m32r: -git: pass ( 1135), -tip: pass ( 1135) testing m68k: -git: pass ( 1471), -tip: pass ( 1471) testing mips: -git: pass ( 1162), -tip: pass ( 1162) testing mn10300: -git: pass ( 1058), -tip: pass ( 1058) testing parisc: -git: pass ( 1846), -tip: pass ( 1846) testing sparc: -git: pass ( 1185), -tip: pass ( 1185) ... so I hope the cross-arch impact 'none', as intended. (by Dave Hansen) - Fix various NMI handling related bugs unearthed by the big asm code rewrite and generally make the NMI code more robust and more maintainable while at it. These changes are a bit late in the cycle, I hope they are still acceptable. (by Andy Lutomirski)" * 'x86-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/fpu, sched: Introduce CONFIG_ARCH_WANTS_DYNAMIC_TASK_STRUCT and use it on x86 x86/fpu, sched: Dynamically allocate 'struct fpu' x86/entry/64, x86/nmi/64: Add CONFIG_DEBUG_ENTRY NMI testing code x86/nmi/64: Make the "NMI executing" variable more consistent x86/nmi/64: Minor asm simplification x86/nmi/64: Use DF to avoid userspace RSP confusing nested NMI detection x86/nmi/64: Reorder nested NMI checks x86/nmi/64: Improve nested NMI comments x86/nmi/64: Switch stacks on userspace NMI entry x86/nmi/64: Remove asm code that saves CR2 x86/nmi: Enable nested do_nmi() handling for 64-bit kernels
2015-07-18Merge branch 'timers-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer fix from Ingo Molnar: "Fix for a misplaced export that can cause build failures in certain (rare) Kconfig situations" * 'timers-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: tick: Move the export of tick_broadcast_oneshot_control to the proper place
2015-07-18Merge branch 'sched-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull scheduler fix from Ingo Molnar: "A oneliner rq throttling fix" * 'sched-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: sched/fair: Test list head instead of list entry in throttle_cfs_rq()
2015-07-18Merge branch 'perf-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf fixes from Ingo Molnar: "Mostly tooling fixes, plus a static key fix fixing /sys/devices/cpu/rdpmc" * 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: perf tools: Really allow to specify custom CC, AR or LD perf auxtrace: Fix misplaced check for HAVE_SYNC_COMPARE_AND_SWAP_SUPPORT perf hists browser: Take the --comm, --dsos, etc filters into account perf symbols: Store if there is a filter in place x86, perf: Fix static_key bug in load_mm_cr4() tools: Copy lib/hweight.c from the kernel sources perf tools: Fix the detached tarball wrt rbtree copy perf thread_map: Fix the sizeof() calculation for map entries tools lib: Improve clean target perf stat: Fix shadow declaration of close perf tools: Fix lockup using 32-bit compat vdso
2015-07-18Merge branch 'irq-urgent-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull irq fixes from Ingo Molnar: "Misc irq fixes: - two driver fixes - a Xen regression fix - a nested irq thread crash fix" * 'irq-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: irqchip/gicv3-its: Fix mapping of LPIs to collections genirq: Prevent resend to interrupts marked IRQ_NESTED_THREAD genirq: Revert sparse irq locking around __cpu_up() and move it to x86 for now gpio/davinci: Fix race in installing chained irq handler
2015-07-18Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge fixes from Andrew Morton: "25 fixes" * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (25 commits) lib/decompress: set the compressor name to NULL on error mm/cma_debug: correct size input to bitmap function mm/cma_debug: fix debugging alloc/free interface mm/page_owner: set correct gfp_mask on page_owner mm/page_owner: fix possible access violation fsnotify: fix oops in fsnotify_clear_marks_by_group_flags() /proc/$PID/cmdline: fixup empty ARGV case dma-debug: skip debug_dma_assert_idle() when disabled hexdump: fix for non-aligned buffers checkpatch: fix long line messages about patch context mm: clean up per architecture MM hook header files MAINTAINERS: uclinux-h8-devel is moderated for non-subscribers mailmap: update Sudeep Holla's email id Update Viresh Kumar's email address mm, meminit: suppress unused memory variable warning configfs: fix kernel infoleak through user-controlled format string include, lib: add __printf attributes to several function prototypes s390/hugetlb: add hugepages_supported define mm: hugetlb: allow hugepages_supported to be architecture specific revert "s390/mm: make hugepages_supported a boot time decision" ...
2015-07-17Merge branch 'for-linus-4.2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull btrfs fixes from Chris Mason: "These are all from Filipe, and cover a few problems we've had reported on the list recently (along with ones he found on his own)" * 'for-linus-4.2' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: Btrfs: fix file corruption after cloning inline extents Btrfs: fix order by which delayed references are run Btrfs: fix list transaction->pending_ordered corruption Btrfs: fix memory leak in the extent_same ioctl Btrfs: fix shrinking truncate when the no_holes feature is enabled
2015-07-17Merge tag 'rtc-v4.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux Pull rtc fixes from Alexandre Belloni: "A few fixes for the RTC susbsystem for 4.2. The mt6397 driver was introduce in 4.2 so it is worth fixing before the final release. I though the compilation warning for armada38x was fixed by akpm in commit f98b733e93e0 ("rtc-armada38x.c: remove unused local `flags'") but he actually missed some occurrences of the variables. Since I received 4 patches for that, I think we can include it now. Summary: - fix mt6397 wakealarm creation - remove a compilation warning for armada38x that was forgotten" * tag 'rtc-v4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/abelloni/linux: rtc: armada38x: Remove unused variable from armada38x_rtc_set_time() rtc: mt6397: enable wakeup before registering rtc device
2015-07-17Merge tag 'dm-4.2-fixes-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm Pull device mapper fixes from Mike Snitzer: - revert a request-based DM core change that caused IO latency to increase and adversely impact both throughput and system load - fix for a use after free bug in DM core's device cleanup - a couple DM btree removal fixes (used by dm-thinp) - a DM thinp fix for order-5 allocation failure - a DM thinp fix to not degrade to read-only metadata mode when in out-of-data-space mode for longer than the 'no_space_timeout' - fix a long-standing oversight in both dm-thinp and dm-cache by now exporting 'needs_check' in status if it was set in metadata - fix an embarrassing dm-cache busy-loop that caused worker threads to eat cpu even if no IO was actively being issued to the cache device * tag 'dm-4.2-fixes-2' of git://git.kernel.org/pub/scm/linux/kernel/git/device-mapper/linux-dm: dm cache: avoid calls to prealloc_free_structs() if possible dm cache: avoid preallocation if no work in writeback_some_dirty_blocks() dm cache: do not wake_worker() in free_migration() dm cache: display 'needs_check' in status if it is set dm thin: display 'needs_check' in status if it is set dm thin: stay in out-of-data-space mode once no_space_timeout expires dm: fix use after free crash due to incorrect cleanup sequence Revert "dm: only run the queue on completion if congested or no requests pending" dm btree: silence lockdep lock inversion in dm_btree_del() dm thin: allocate the cell_sort_array dynamically dm btree remove: fix bug in redistribute3
2015-07-18x86/fpu, sched: Introduce CONFIG_ARCH_WANTS_DYNAMIC_TASK_STRUCT and use it ↵Ingo Molnar
on x86 Don't burden architectures without dynamic task_struct sizing with the overhead of dynamic sizing. Also optimize the x86 code a bit by caching task_struct_size. Acked-and-Tested-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1437128892-9831-3-git-send-email-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-18x86/fpu, sched: Dynamically allocate 'struct fpu'Dave Hansen
The FPU rewrite removed the dynamic allocations of 'struct fpu'. But, this potentially wastes massive amounts of memory (2k per task on systems that do not have AVX-512 for instance). Instead of having a separate slab, this patch just appends the space that we need to the 'task_struct' which we dynamically allocate already. This saves from doing an extra slab allocation at fork(). The only real downside here is that we have to stick everything and the end of the task_struct. But, I think the BUILD_BUG_ON()s I stuck in there should keep that from being too fragile. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: Andy Lutomirski <luto@amacapital.net> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Dave Hansen <dave@sr71.net> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/1437128892-9831-2-git-send-email-mingo@kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2015-07-17lib/decompress: set the compressor name to NULL on errorAneesh Kumar K.V
Without this we end up using the previous name of the compressor in the loop in unpack_rootfs. For example we get errors like "compression method gzip not configured" even when we have CONFIG_DECOMPRESS_GZIP enabled. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm/cma_debug: correct size input to bitmap functionJoonsoo Kim
In CMA, 1 bit in bitmap means 1 << order_per_bits pages so size of bitmap is cma->count >> order_per_bits rather than just cma->count. This patch fixes it. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Stefan Strogin <stefan.strogin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm/cma_debug: fix debugging alloc/free interfaceJoonsoo Kim
CMA has alloc/free interface for debugging. It is intended that alloc/free occurs in specific CMA region, but, currently, alloc/free interface is on root dir due to the bug so we can't select CMA region where alloc/free happens. This patch fixes this problem by making alloc/free interface per CMA region. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: Sasha Levin <sasha.levin@oracle.com> Cc: Stefan Strogin <stefan.strogin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm/page_owner: set correct gfp_mask on page_ownerJoonsoo Kim
Currently, we set wrong gfp_mask to page_owner info in case of isolated freepage by compaction and split page. It causes incorrect mixed pageblock report that we can get from '/proc/pagetypeinfo'. This metric is really useful to measure fragmentation effect so should be accurate. This patch fixes it by setting correct information. Without this patch, after kernel build workload is finished, number of mixed pageblock is 112 among roughly 210 movable pageblocks. But, with this fix, output shows that mixed pageblock is just 57. Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Vlastimil Babka <vbabka@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm/page_owner: fix possible access violationJoonsoo Kim
When I tested my new patches, I found that page pointer which is used for setting page_owner information is changed. This is because page pointer is used to set new migratetype in loop. After this work, page pointer could be out of bound. If this wrong pointer is used for page_owner, access violation happens. Below is error message that I got. BUG: unable to handle kernel paging request at 0000000000b00018 IP: [<ffffffff81025f30>] save_stack_address+0x30/0x40 PGD 1af2d067 PUD 166e0067 PMD 0 Oops: 0002 [#1] SMP ...snip... Call Trace: print_context_stack+0xcf/0x100 dump_trace+0x15f/0x320 save_stack_trace+0x2f/0x50 __set_page_owner+0x46/0x70 __isolate_free_page+0x1f7/0x210 split_free_page+0x21/0xb0 isolate_freepages_block+0x1e2/0x410 compaction_alloc+0x22d/0x2d0 migrate_pages+0x289/0x8b0 compact_zone+0x409/0x880 compact_zone_order+0x6d/0x90 try_to_compact_pages+0x110/0x210 __alloc_pages_direct_compact+0x3d/0xe6 __alloc_pages_nodemask+0x6cd/0x9a0 alloc_pages_current+0x91/0x100 runtest_store+0x296/0xa50 simple_attr_write+0xbd/0xe0 __vfs_write+0x28/0xf0 vfs_write+0xa9/0x1b0 SyS_write+0x46/0xb0 system_call_fastpath+0x16/0x75 This patch fixes this error by moving up set_page_owner(). Signed-off-by: Joonsoo Kim <iamjoonsoo.kim@lge.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Vlastimil Babka <vbabka@suse.cz> Acked-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17fsnotify: fix oops in fsnotify_clear_marks_by_group_flags()Jan Kara
fsnotify_clear_marks_by_group_flags() can race with fsnotify_destroy_marks() so when fsnotify_destroy_mark_locked() drops mark_mutex, a mark from the list iterated by fsnotify_clear_marks_by_group_flags() can be freed and we dereference free memory in the loop there. Fix the problem by keeping mark_mutex held in fsnotify_destroy_mark_locked(). The reason why we drop that mutex is that we need to call a ->freeing_mark() callback which may acquire mark_mutex again. To avoid this and similar lock inversion issues, we move the call to ->freeing_mark() callback to the kthread destroying the mark. Signed-off-by: Jan Kara <jack@suse.cz> Reported-by: Ashish Sangwan <a.sangwan@samsung.com> Suggested-by: Lino Sanfilippo <LinoSanfilippo@gmx.de> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17/proc/$PID/cmdline: fixup empty ARGV caseAlexey Dobriyan
/proc/*/cmdline code checks if it should look at ENVP area by checking last byte of ARGV area: rv = access_remote_vm(mm, arg_end - 1, &c, 1, 0); if (rv <= 0) goto out_free_page; If ARGV is somehow made empty (by doing execve(..., NULL, ...) or manually setting ->arg_start and ->arg_end to equal values), the decision will be based on byte which doesn't even belong to ARGV/ENVP. So, quickly check if ARGV area is empty and report 0 to match previous behaviour. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17dma-debug: skip debug_dma_assert_idle() when disabledHaggai Eran
If dma-debug is disabled due to a memory error, DMA unmaps do not affect the dma_active_cacheline radix tree anymore, and debug_dma_assert_idle() can print false warnings. Disable debug_dma_assert_idle() when dma_debug_disabled() is true. Signed-off-by: Haggai Eran <haggaie@mellanox.com> Fixes: 0abdd7a81b7e ("dma-debug: introduce debug_dma_assert_idle()") Cc: Dan Williams <dan.j.williams@intel.com> Cc: Joerg Roedel <joro@8bytes.org> Cc: Vinod Koul <vinod.koul@intel.com> Cc: Russell King <rmk+kernel@arm.linux.org.uk> Cc: James Bottomley <JBottomley@Parallels.com> Cc: Florian Fainelli <f.fainelli@gmail.com> Cc: Sebastian Ott <sebott@linux.vnet.ibm.com> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Horia Geanta <horia.geanta@freescale.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17hexdump: fix for non-aligned buffersHoracio Mijail Anton Quiles
A hexdump with a buf not aligned to the groupsize causes non-naturally-aligned memory accesses. This was causing a kernel panic on the processor BlackFin BF527, when such an unaligned buffer was fed by the function ubifs_scanned_corruption in fs/ubifs/scan.c . To fix this, change accesses to the contents of the buffer so they go through get_unaligned(). This change should be harmless to unaligned- access-capable architectures, and any performance hit should be anyway dwarfed by the snprintf() processing time. Signed-off-by: Horacio Mijail Antón Quiles <hmijail@gmail.com> Cc: Andy Shevchenko <andriy.shevchenko@linux.intel.com> Cc: David Howells <dhowells@redhat.com> Cc: Vivek Goyal <vgoyal@redhat.com> Cc: Joe Perches <joe@perches.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17checkpatch: fix long line messages about patch contextJoe Perches
Changes in ("checkpatch: categorize some long line length checks") now erroneously reports long line defects in patch context. Fix it. Signed-off-by: Joe Perches <joe@perches.com> Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm: clean up per architecture MM hook header filesLaurent Dufour
Commit 2ae416b142b6 ("mm: new mm hook framework") introduced an empty header file (mm-arch-hooks.h) for every architecture, even those which doesn't need to define mm hooks. As suggested by Geert Uytterhoeven, this could be cleaned through the use of a generic header file included via each per architecture asm/include/Kbuild file. The PowerPC architecture is not impacted here since this architecture has to defined the arch_remap MM hook. Signed-off-by: Laurent Dufour <ldufour@linux.vnet.ibm.com> Suggested-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Acked-by: Vineet Gupta <vgupta@synopsys.com> Cc: Oleg Nesterov <oleg@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17MAINTAINERS: uclinux-h8-devel is moderated for non-subscribersGeert Uytterhoeven
Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mailmap: update Sudeep Holla's email idSudeep Holla
Since the get_maintainer script still reports my old email id based on few old commits, update mailmap to report new/updated address. It also helps to fix email address for 'git shortlog' Signed-off-by: Sudeep Holla <sudeep.holla@arm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17Update Viresh Kumar's email addressViresh Kumar
Switch to my kernel.org alias instead of a badly named gmail address, which I rarely use. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm, meminit: suppress unused memory variable warningMel Gorman
The kbuild test robot reported the following tree: git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git master head: 14a6f1989dae9445d4532941bdd6bbad84f4c8da commit: 3b242c66ccbd60cf47ab0e8992119d9617548c23 x86: mm: enable deferred struct page initialisation on x86-64 date: 3 days ago config: x86_64-randconfig-x006-201527 (attached as .config) reproduce: git checkout 3b242c66ccbd60cf47ab0e8992119d9617548c23 # save the attached .config to linux build tree make ARCH=x86_64 All warnings (new ones prefixed by >>): mm/page_alloc.c: In function 'early_page_uninitialised': >> mm/page_alloc.c:247:6: warning: unused variable 'nid' [-Wunused-variable] int nid = early_pfn_to_nid(pfn); It's due to the NODE_DATA macro ignoring the nid parameter on !NUMA configurations. This patch avoids the warning by not declaring nid. Signed-off-by: Mel Gorman <mgorman@suse.de> Reported-by: Wu Fengguang <fengguang.wu@intel.com> Cc: "Kirill A. Shutemov" <kirill@shutemov.name> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17configfs: fix kernel infoleak through user-controlled format stringNicolas Iooss
Some modules call config_item_init_type_name() and config_group_init_type_name() with parameter "name" directly controlled by userspace. These two functions call config_item_set_name() with this name used as a format string, which can be used to leak information such as content of the stack to userspace. For example, make_netconsole_target() in netconsole module calls config_item_init_type_name() with the name of a newly-created directory. This means that the following commands give some unexpected output, with configfs mounted in /sys/kernel/config/ and on a system with a configured eth0 ethernet interface: # modprobe netconsole # mkdir /sys/kernel/config/netconsole/target_%lx # echo eth0 > /sys/kernel/config/netconsole/target_%lx/dev_name # echo 1 > /sys/kernel/config/netconsole/target_%lx/enabled # echo eth0 > /sys/kernel/config/netconsole/target_%lx/dev_name # dmesg |tail -n1 [ 142.697668] netconsole: target (target_ffffffffc0ae8080) is enabled, disable to update parameters The directory name is correct but %lx has been interpreted in the internal item name, displayed here in the error message used by store_dev_name() in drivers/net/netconsole.c. To fix this, update every caller of config_item_set_name to use "%s" when operating on untrusted input. This issue was found using -Wformat-security gcc flag, once a __printf attribute has been added to config_item_set_name(). Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Felipe Balbi <balbi@ti.com> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17include, lib: add __printf attributes to several function prototypesNicolas Iooss
Using __printf attributes helps to detect several format string issues at compile time (even though -Wformat-security is currently disabled in Makefile). For example it can detect when formatting a pointer as a number, like the issue fixed in commit a3fa71c40f18 ("wl18xx: show rx_frames_per_rates as an array as it really is"), or when the arguments do not match the format string, c.f. for example commit 5ce1aca81435 ("reiserfs: fix __RASSERT format string"). To prevent similar bugs in the future, add a __printf attribute to every function prototype which needs one in include/linux/ and lib/. These functions were mostly found by using gcc's -Wsuggest-attribute=format flag. Signed-off-by: Nicolas Iooss <nicolas.iooss_linux@m4x.org> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Felipe Balbi <balbi@ti.com> Cc: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17s390/hugetlb: add hugepages_supported defineDominik Dingel
On s390 we only can enable hugepages if the underlying hardware/hypervisor also does support this. Common code now would assume this to be signaled by setting HPAGE_SHIFT to 0. But on s390, where we only support one hugepage size, there is a link between HPAGE_SHIFT and pageblock_order. So instead of setting HPAGE_SHIFT to 0, we will implement the check for the hardware capability. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17mm: hugetlb: allow hugepages_supported to be architecture specificDominik Dingel
s390 has a constant hugepage size, by setting HPAGE_SHIFT we also change e.g. the pageblock_order, which should be independent in respect to hugepage support. With this patch every architecture is free to define how to check for hugepage support. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17revert "s390/mm: make hugepages_supported a boot time decision"Dominik Dingel
Heiko noticed that the current check for hugepage support on s390 is a little bit too harsh as systems which do not support will crash. The reason is that pageblock_order can now get negative when we set HPAGE_SHIFT to 0. To avoid all this and to avoid opening another can of worms with enabling HUGETLB_PAGE_SIZE_VARIABLE I think it would be best to simply allow architectures to define their own hugepages_supported(). Revert bea41197ead3 ("s390/mm: make hugepages_supported a boot time decision") in preparation. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17revert "s390/mm: change HPAGE_SHIFT type to int"Dominik Dingel
Heiko noticed that the current check for hugepage support on s390 is a little bit too harsh as systems which do not support will crash. The reason is that pageblock_order can now get negative when we set HPAGE_SHIFT to 0. To avoid all this and to avoid opening another can of worms with enabling HUGETLB_PAGE_SIZE_VARIABLE I think it would be best to simply allow architectures to define their own hugepages_supported(). This patch (of 4): revert commit cf54e2fce51c ("s390/mm: change HPAGE_SHIFT type to int") in preparation. Signed-off-by: Dominik Dingel <dingel@linux.vnet.ibm.com> Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Christian Borntraeger <borntraeger@de.ibm.com> Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com> Cc: Gerald Schaefer <gerald.schaefer@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17openrisc: fix CONFIG_UID16 settingAndrew Morton
openrisc-allnoconfig: kernel/uid16.c: In function 'SYSC_setgroups16': kernel/uid16.c:184:2: error: implicit declaration of function 'groups_alloc' kernel/uid16.c:184:13: warning: assignment makes pointer from integer without a cast openrisc shouldn't be setting CONFIG_UID16 when CONFIG_MULTIUSER=n. Fixes: 2813893f8b197a1 ("kernel: conditionally support non-root users, groups and capabilities") Reported-by: Fengguang Wu <fengguang.wu@gmail.com> Cc: Iulia Manda <iulia.manda21@gmail.com> Cc: Josh Triplett <josh@joshtriplett.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17MAINTAINERS: change mhocko's email address to kernel.orgMichal Hocko
I am moving from mhocko@suse.cz to mhocko@kernel.org for kernel related stuff. Signed-off-by: Michal Hocko <mhocko@suse.cz> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17fs, proc: add help for CONFIG_PROC_CHILDRENIago López Galeiras
The purpose of the option was documented in Documentation/filesystems/proc.txt but the help text was missing. Add small help text that also points to the documentation. Signed-off-by: Iago López Galeiras <iago@endocode.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-17MAINTAINERS: switch to suse.com many-in-one (fwd)Jiri Slaby
Since suse.{de,cz} is deprecated to use (but will still work for some time), switch to suse.com which is now to be used instead. Signed-off-by: Jiri Slaby <jslaby@suse.com> Acked-by: Alexander Graf <agraf@suse.de> Acked-by: David Sterba <dsterba@suse.com> Acked-by: Hannes Reinecke <hare@suse.com> Acked-by: Jan Kara <jack@suse.com> Acked-by: Jean Delvare <jdelvare@suse.com> Acked-by: Jiri Kosina <jkosina@suse.com> Acked-by: Michal Marek <mmarek@suse.com> Acked-by: NeilBrown <neilb@suse.com> Acked-by: Oliver Neukum <oneukum@suse.de> Acked-by: Takashi Iwai <tiwai@suse.com> Acked-by: Thomas Renninger <trenn@suse.de> Acked-by: Tomas Cech <sleep_walker@suse.com> Acked-by: Vojtech Pavlik <vojtech@suse.com> Signed-off-by: Jiri Kosina <jkosina@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-07-18rtc: armada38x: Remove unused variable from armada38x_rtc_set_time()Fabio Estevam
Remove the 'flags' variable in order to fix the following warning: drivers/rtc/rtc-armada38x.c:91:22: warning: unused variable 'flags' [-Wunused-variable] Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-07-18rtc: mt6397: enable wakeup before registering rtc deviceWei-Ning Huang
rtc_sysfs_add_device checks if device can wakeup before creating the wakealarm file in sysfs. Thus the driver must set wakeup capability before registering the rtc device. Signed-off-by: Wei-Ning Huang <wnhuang@google.com> Acked-by: Eddie Huang <eddie.huang@mediatek.com> Signed-off-by: Alexandre Belloni <alexandre.belloni@free-electrons.com>
2015-07-17Merge tag 'staging-4.2-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging Pull staging and IIO driver fixes from Greg KH: "Here's some staging and IIO driver fixes for 4.2-rc3. Nothing major, the majority are IIO issues that were reported, with a few other minor staging driver fixes. All have been in linux-next for a while with no reported issues" * tag 'staging-4.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging: (25 commits) staging: vt6656: check ieee80211_bss_conf bssid not NULL staging: vt6655: check ieee80211_bss_conf bssid not NULL staging:lustre: remove irq.h from socklnd.h staging: make board support depend on OF_IRQ and CLKDEV_LOOKUP iio: tmp006: Check channel info on write iio: sx9500: Add missing init in sx9500_buffer_pre{en,dis}able() iio:light:ltr501: fix regmap dependency iio:light:ltr501: fix variable in ltr501_init iio: sx9500: fix bug in compensation code iio: sx9500: rework error handling of raw readings iio: magnetometer: mmc35240: fix available sampling frequencies iio:light:stk3310: Fix REGMAP_I2C dependency iio: light: STK3310: un-invert proximity values iio:adc:cc10001_adc: fix Kconfig dependency iio: light: tcs3414: Fix bug preventing to set integration time iio:accel:bmc150-accel: fix counting direction iio:light:cm3323: clear bitmask before set iio: adc: at91_adc: allow to use full range of startup time iio: DAC: ad5624r_spi: fix bit shift of output data value iio: proximity: sx9500: Fix proximity value ...
2015-07-17Merge tag 'usb-4.2-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull USB driver fixes from Greg KH: "Here's some USB driver fixes for 4.2-rc3. The ususal number of gadget driver fixes are in here, along with some new device ids and a build fix for the mn10300 arch which required some symbols to be renamed in the mos7720 driver. All have been in linux-next for a while with no reported issues" * tag 'usb-4.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: USB: serial: Destroy serial_minors IDR on module exit usb: gadget: f_midi: fix error recovery path usb: phy: mxs: suspend to RAM causes NULL pointer dereference usb: gadget: udc: fix free_irq() after request_irq() failed usb: gadget: composite: Fix NULL pointer dereference usb: gadget: f_fs: do not set cancel function on synchronous {read,write} usb: f_mass_storage: limit number of reported LUNs usb: dwc3: core: avoid NULL pointer dereference usb: dwc2: embed storage for reg backup in struct dwc2_hsotg usb: dwc2: host: allocate qtd before atomic enqueue usb: dwc2: host: allocate qh before atomic enqueue usb: musb: host: rely on port_mode to call musb_start() USB: cp210x: add ID for Aruba Networks controllers USB: mos7720: rename registers USB: option: add 2020:4000 ID
2015-07-17Merge tag 'sound-4.2-rc3' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound fixes from Takashi Iwai: "There are two small fixes for HD-audio and USB LINE6, and the rest are a few new quirks and device ID addition that are good enough to get into 4.2" * tag 'sound-4.2-rc3' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ALSA: hda/realtek: Enable HP amp and mute LED on HP Folio 9480m [v3] ALSA: line6: Fix -EBUSY error during active monitoring ALSA: hda - Fix a wrong busy check in alt PCM open ALSA: hda - add codec ID for Broxton display audio codec ALSA: usb-audio: Add MIDI support for Steinberg MI2/MI4
2015-07-17Merge tag 'gpio-v4.2-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO fixes from Linus Walleij: "This is a first set of GPIO fixes for the v4.2 series, all hitting individual drivers and nothing else (except for a documentation oneliner. I intended to send a request earlier but life intervened)" * tag 'gpio-v4.2-2' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: gpio: pca953x: fix nested irqs rescheduling gpio: omap: prevent module from being unloaded while in use gpio: max732x: Add missing dev reference to gpiochip gpio/xilinx: Use correct address when setting initial values. gpio: zynq: Fix problem with unbalanced pm_runtime_enable gpio: omap: add missed spin_unlock_irqrestore in omap_gpio_irq_type gpio: brcmstb: fix null ptr dereference in driver remove gpio: Remove double "base" in comment
