Track the last waker CPU, and only consider wakeup-balancing if there's a
match between current waker CPU and the previous waker CPU. This ensures
that there is some correlation between two subsequent wakeup events before
we move the task. Should help random-wakeup workloads on large SMP
systems, by reducing the migration attempts by a factor of nr_cpus.
Signed-off-by: Nick Piggin <npiggin@suse.de>
This is the latest version of the scheduler cache-hot-auto-tune patch.
The first problem was that detection time scaled with O(N^2), which is
unacceptable on larger SMP and NUMA systems. To solve this:
- I've added a 'domain distance' function, which is used to cache
measurement results. Each distance is only measured once. This means
that e.g. on NUMA distances of 0, 1 and 2 might be measured, on HT
distances 0 and 1, and on SMP distance 0 is measured. The code walks
the domain tree to determine the distance, so it automatically follows
whatever hierarchy an architecture sets up. This cuts down on the boot
time significantly and removes the O(N^2) limit. The only assumption
is that migration costs can be expressed as a function of domain
distance - this covers the overwhelming majority of existing systems,
and is a good guess even for more assymetric systems.
[ People hacking systems that have assymetries that break this
assumption (e.g. different CPU speeds) should experiment a bit with
the cpu_distance() function. Adding a ->migration_distance factor to
the domain structure would be one possible solution - but lets first
see the problem systems, if they exist at all. Lets not overdesign. ]
Another problem was that only a single cache-size was used for measuring
the cost of migration, and most architectures didnt set that variable
up. Furthermore, a single cache-size does not fit NUMA hierarchies with
L3 caches and does not fit HT setups, where different CPUs will often
have different 'effective cache sizes'. To solve this problem:
- Instead of relying on a single cache-size provided by the platform and
sticking to it, the code now auto-detects the 'effective migration
cost' between two measured CPUs, via iterating through a wide range of
cachesizes. The code searches for the maximum migration cost, which
occurs when the working set of the test-workload falls just below the
'effective cache size'. I.e. real-life optimized search is done for
the maximum migration cost, between two real CPUs.
This, amongst other things, has the positive effect hat if e.g. two
CPUs share a L2/L3 cache, a different (and accurate) migration cost
will be found than between two CPUs on the same system that dont share
any caches.
(The reliable measurement of migration costs is tricky - see the source
for details.)
Furthermore i've added various boot-time options to override/tune
migration behavior.
Firstly, there's a blanket override for autodetection:
migration_cost=1000,2000,3000
will override the depth 0/1/2 values with 1msec/2msec/3msec values.
Secondly, there's a global factor that can be used to increase (or
decrease) the autodetected values:
migration_factor=120
will increase the autodetected values by 20%. This option is useful to
tune things in a workload-dependent way - e.g. if a workload is
cache-insensitive then CPU utilization can be maximized by specifying
migration_factor=0.
I've tested the autodetection code quite extensively on x86, on 3
P3/Xeon/2MB, and the autodetected values look pretty good:
Dual Celeron (128K L2 cache):
migration cost matrix (max_cache_size: 131072, cpu: 467 MHz):
[00] [01]
[00]: - 1.7(1)
[01]: 1.7(1) -
cacheflush times [2]: 0.0 (0) 1.7 (1784008)
Here the slow memory subsystem dominates system performance, and even
though caches are small, the migration cost is 1.7 msecs.
Dual HT P4 (512K L2 cache):
migration cost matrix (max_cache_size: 524288, cpu: 2379 MHz):
[00] [01] [02] [03]
[00]: - 0.4(1) 0.0(0) 0.4(1)
[01]: 0.4(1) - 0.4(1) 0.0(0)
[02]: 0.0(0) 0.4(1) - 0.4(1)
[03]: 0.4(1) 0.0(0) 0.4(1) -
cacheflush times [2]: 0.0 (33900) 0.4 (448514)
Here it can be seen that there is no migration cost between two HT
siblings (CPU#0/2 and CPU#1/3 are separate physical CPUs). A fast memory
system makes inter-physical-CPU migration pretty cheap: 0.4 msecs.
8-way P3/Xeon [2MB L2 cache]:
migration cost matrix (max_cache_size: 2097152, cpu: 700 MHz):
[00] [01] [02] [03] [04] [05] [06] [07]
[00]: - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[01]: 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[02]: 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[03]: 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1) 19.2(1)
[04]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1) 19.2(1)
[05]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1) 19.2(1)
[06]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) - 19.2(1)
[07]: 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) 19.2(1) -
cacheflush times [2]: 0.0 (0) 19.2 (19281756)
This one has huge caches and a relatively slow memory subsystem - so the
migration cost is 19 msecs.
Signed-off-by: Ashok Raj <ashok.raj@intel.com>
Signed-off-by: Ken Chen <kenneth.w.chen@intel.com>
Cc: <wilder@us.ibm.com>
Signed-off-by: John Hawkes <hawkes@sgi.com>
Add per-arch sched_cacheflush() which is a write-back cacheflush used by
the migration-cost calibration code at bootup time.
Cc: Nick Piggin <nickpiggin@yahoo.com.au>
Fixes bugzilla.kernel.org bug 2903.
Cc: <tim@cyberelk.net>
Cc: <andrea@suse.de>
Signed-off-by: Andi Kleen <ak@suse.de>
Remove unecessary page++ from memmap_init_zone loop.
Signed-off-by: Greg Ungerer <gerg@uclinux.org>
e.g. The sx8 driver uses names like sx8/0.
This would make a md component dev name like
/sys/block/md0/md/dev-sx8/0
which is not allowed. So we change the '/' to '!' just like
fs/partitions/check.c(register_disk) does.
Signed-off-by: Neil Brown <neilb@suse.de>
Adapt tiny-shmem.c to the new do_truncate() prototype.
Acked-by: Matt Mackall <mpm@selenic.com>
Acked-by: Hugh Dickins <hugh@veritas.com>
This ensures that reserved pages are not migrated. Reserved pages
currently cause the WARN_ON to trigger in migrate_page_add()
Signed-off-by: Christoph Lameter <clameter@sgi.com>
If ordered tag isn't supported, request ordering for barrier
sequencing is performed by queue draining, which basically hangs the
request queue until elv_completed_request() reports completion of all
previous fs requests.
The condition check in elv_completed_request() was only performed for
fs requests. If a special request is queued between the last
to-be-drained request and the barrier sequence, draining is never
completed and the queue is stalled forever.
This patch moves the end-of-draining condition check such that it's
performed for all requests.
Signed-off-by: Tejun Heo <htejun@gmail.com>
Signed-off-by: Jens Axboe <axboe@suse.de>
o This fix was posted for i386 long back. Posting it for x86_64.
http://marc.theaimsgroup.com/?l=linux-kernel&m=110380103229830&w=2
o This patch fixes the problem of secondary cpus boot up. This situation
is faced when kernel is built for default locations like 16MB and
onwards. In this configuration, only primary cpu (BP) comes and
secondary cpus don't boot.
o Problem occurs because in trampoline code, lgdt is not able to load the
GDT as it happens to be situated beyond 16MB. This is due to the fact
that cpu is still in real mode and default operand size is 16bit.
o This patch uses lgdtl instead of lgdt to force operand size to 32
instead of 16.
Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com>
Handling common prefixes is tricky.
... reducing the amount of changes Xen has to do.
Signed-Off-By: Jan Beulich <jbeulich@novell.com>
The explicit and implicit calls to setup_early_printk() were passing
inconsistent arguments.
It has no business being elsewhere and x86-64 doesn't need/want it.
Previously they would be only allocated before the kernel text at
1MB. This limited the maximum supported memory to 128GB.
Now allow the e820 allocator to put them everywhere. Try
to put them beyond any DMA zones to avoid filling them up.
This should free some GFP_DMA memory compared to earlier kernels.
hard_smp_processor_id would return the local APIC id instead
of the Linux processor id. On big systems they are often
not identical. safe_smp_processor_id is just a wrapper
around it that does the necessary conversions.
Remove support for obsolete hardware and cleanup.
- Remove checks for non integrated APICs
- Replace apic_write_around with apic_write.
- Remove apic_read_around
- Remove APIC version reads used by old workarounds
- Remove old workaround for Simics
- Fix indentation
When building in a separate objtree, file names produced by BUG() & Co. can
get fairly long; printing only the first 50 characters may thus result in
(almost) no useful information. The following change makes it so that rather
the last 50 characters of the filename get printed.
Especially under Xen, where the console cannot be adjusted to more than 25
lines, it is fairly important that the information displayed during a panic
is as compact as possible. Below adjustments work towards that.
Due to a broken condition, the body of the loop that is intended to wait for
the Update-In-Progress bit to get set and then cleared again was never
entered; in fact, the entire loop was optimized out by the compiler. Here is
a change to fix the condition (and to also move the initialization of locals
out of the spin lock protected region).
It was only needed for APM
Pointed out by Jan Beulich
Cc: jbeulich@novell.com
X86_FEATURE_K8_C was a synthetic Linux CPUID flag that was used for some
code optimizations in Opteron C stepping or later. But support for pre C
stepping optimizations has been removed, so this isn't needed anymore.
early_cpu_detect only runs on the BP, but this code needs to run
on all CPUs.
Looks like a mismerge somewhere. Also add a warning comment.
Fix some trivial sparse warnings in x86_64 code.
Signed-off-by: Stephen Hemminger <shemminger@osdl.org>
Saves about ~18K .text in defconfig
There would be more optimization potential, but that's for later.
Suggestion originally from Bill Irwin.
Fix from Andy Whitcroft.
They used to be used by the reboot code, but not anymore.
Noticed by Jan Beulich
Cc: JBeulich@novell.com
o Currently, during kexec reboot, IOAPIC is re-programmed back to virtual
wire mode if there was an i8259 connected to it. This enables getting
timer interrupts in second kernel in legacy mode.
o After putting into virtual wire mode, IOAPIC delivers the i8259 interrupts
to CPU0. This works well for kexec but not for kdump as we might crash
on a different CPU and second kernel will not see timer interrupts.
o This patch modifies the redirection table entry to deliver the timer
interrupts to the cpu we are rebooting (instead of hardcoding to zero).
This ensures that second kernel receives timer interrupts even on a
non-boot cpu.
Introduce vSMP arch to the kernel.
This patch:
1. Adds CONFIG_X86_VSMP
2. Adds machine specific macros for local_irq_disabled, local_irq_enabled
and irqs_disabled
3. Writes to the vSMP CTL device to indicate kernel compiled with CONFIG_VSMP
Signed-off-by: Ravikiran Thirumalai <kiran@scalemp.com>
Signed-off-by: Shai Fultheim <shai@scalemp.com>
vSMP specific alignment patch to
1. Define INTERNODE_CACHE_SHIFT for vSMP
2. Use this for alignment of critical structures
3. Use INTERNODE_CACHE_SHIFT for ARCH_MIN_TASKALIGN,
and let the slab align task_struct allocations to the internode cacheline size
4. Introduce and use ARCH_MIN_MMSTRUCT_ALIGN for mm_struct slab allocations.
Fixes
CC fs/nfsctl.o
In file included from include2/asm/atomic.h:427,
from /home/lsrc/quilt/linux/include/linux/file.h:8,
from /home/lsrc/quilt/linux/fs/nfsctl.c:8:
/home/lsrc/quilt/linux/include/asm-generic/atomic.h:20:5: warning: "BITS_PER_LONG" is not defined
Move the #ifdef into the function body.
Signed-off-by: Brian Gerst <bgerst@didntduck.org>
Currently we attempt to restore virtual wire mode on reboot, which only
works if we can figure out where the i8259 is connected. This is very
useful when we are kexec another kernel and likely helpful to an peculiar
BIOS that make assumptions about how the system is setup.
Since the acpi MADT table does not provide the location where the i8259 is
connected we have to look at the hardware to figure it out.
Most systems have the i8259 connected the local apic of the cpu so won't be
affected but people running Opteron and some serverworks chipsets should be
able to use kexec now.
In addition this patch removes the hard coded assumption that the io_apic
that delivers isa interrups is always known to the kernel as io_apic 0.
There does not appear to be anything to guarantee that assumption is true.
And From: Vivek Goyal <vgoyal@in.ibm.com>
A minor fix to the patch which remembers the location of where i8259 is
connected. Now counter i has been replaced by apic. counter i is having
some junk value which was leading to non-detection of i8259 connected to
IOAPIC.
Setting RF (resume flag) allows a debugger to resume execution after a code
breakpoint without tripping the breakpoint again. It is reset by the CPU
after executing one instruction.
Signed-off-by: Chuck Ebbert <76306.1226@compuserve.com>
The manual says Int 6 is "invalid opcode", not "invalid operand".
Fixes the following sparse warnings:
arch/x86_64/kernel/mce_amd.c:321:29: warning: Using plain integer as NULL pointer
arch/x86_64/kernel/mce_amd.c:410:41: warning: Using plain integer as NULL pointer
Signed-off-by: Luiz Capitulino <lcapitulino@mandriva.com.br>
It was set as an NMI, but the NMI bit always forces an interrupt
to end up at vector 2. So it was never used. Remove.
It looks like the new scalable TLB flush code for x86_64 is claiming
one more IRQ vector than it actually uses.
Signed-off-by: Jason Uhlenkott <jasonuhl@sgi.com>
Fix
CC arch/x86_64/kernel/nmi.o
linux/arch/x86_64/kernel/nmi.c: In function ???check_nmi_watchdog???:
linux/arch/x86_64/kernel/nmi.c:155: warning: statement with no effect
on Uniprocessor builds.
Patch uses a static PDA array early at boot and reallocates processor PDA
with node local memory when kmalloc is ready, just before pda_init.
The boot_cpu_pda is needed since the cpu_pda is used even before pda_init for
that cpu is called (to set the static per-cpu areas offset table etc)
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
Signed-off-by: Shai Fultheim <shai@scalex86.org>
Helper patch to change cpu_pda users to use macros to access cpu_pda
instead of the cpu_pda[] array.
Patch enables early intialization of cpu_to_node.
apicid_to_node is built by reading the SRAT table, from acpi_numa_init with
ACPI_NUMA and k8_scan_nodes with K8_NUMA.
x86_cpu_to_apicid is built by parsing the ACPI MADT table, from acpi_boot_init.
We combine these two tables and setup cpu_to_node.
Early intialization helps the static per_cpu_areas in getting pages from
correct node.
Change since last release:
Do not initialize early init_cpu_to_node for faking node cases.
Patch tested on TYAN dual core 4P board with K8 only, ACPI_NUMA.
Tested on EM64T NUMA. Also tested with numa=off, numa=fake, and running
a kernel compiled with NUMA on a regular EM64 2 way SMP.
Signed-off-by: Alok N Kataria <alokk@calsoftinc.com>
No functional changes.
And remove one redundant prototype.
Replacing the old home brewn __force_inline.
sync_core
Passing random input values in eax to cpuid is not a good idea
because the CPU will GPF for unknown ones.
Use the correct x86-64 version that exists for a longer time too.
This also adds a memory barrier to prevent the optimizer from
reordering.
Cc: tigran@veritas.com
RDTSC serialization using cpuid is not needed for Intel platforms.
This increases gettimeofday performance.
Cc: vojtech@suse.cz
Cc: rohit.seth@intel.com
The real vsyscall .text addresses are not mapped when the alternative()
replacement runs early, so use some black magic to access them using
the direct mapping.
Needed for follow on patches
boot.
They already do this in hardware and the Linux algorithm
actually adds errors.
Cc: mingo@elte.hu
