2012-07-27Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc Pull powerpc fixes from Benjamin Herrenschmidt: "Here's a handful of powerpc patches, a couple of regression fixes for problems introduced in the main batch in this merge window, a couple of defconfig updates, and some trivials. The radeonfb one is something that was long standing in SLES which I forgot to pickup earlier." * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/benh/powerpc: powerpc/ftrace: Trace function graph entry before updating index radeonfb: Add quirk for the graphics adapter in some JSxx powerpc: Lack of firmware flash support is not an error powerpc: Enable pseries hardware RNG and crypto modules powerpc: Update g5_defconfig powerpc/kvm/bookehv: Fix build regression powerpc: Set stack limit properly in crit_transfer_to_handler
2012-07-27Merge tag 'cpumask-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus Pull cpumask changes from Rusty Russell: "Trivial comment changes to cpumask code. I guess it's getting boring." Boring is good. * tag 'cpumask-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-for-linus: cpumask: cpulist_parse() comments correction init: add comments to keep initcall-names in sync with initcall levels cpumask: add a few comments of cpumask functions
2012-07-26Merge tag 'fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC fixes from Olof Johansson: "A mixed bag of fixes, some for merge window fallout (tegra, MXS), and a short series of fixes for marvell platforms that didn't make it in before 3.5." * tag 'fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: ARM: mxs: fix compile error caused by prom_update_property change ARM: dt: tegra trimslice: enable USB2 port ARM: dt: tegra trimslice: add vbus-gpio property ARM: vt8500: Add maintainer for VT8500 architecture ARM: Kirkwood: Replace mrvl with marvell ARM: Orion: fix driver probe error handling with respect to clk ARM: Dove: Fixup ge00 initialisation ARM: Kirkwood: Fix PHY disable clk problems ARM: Kirkwood: Ensure runit clock always ticks. ARM: versatile: Don't use platform clock for Integrator & VE ARM: tegra: harmony: add regulator supply name and its input supply
2012-07-26Merge branch 'for-3.6-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds Pull LED subsystem update from Bryan Wu. * 'for-3.6-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/cooloney/linux-leds: (50 commits) leds-lp8788: forgotten unlock at lp8788_led_work LEDS: propagate error codes in blinkm_detect() LEDS: memory leak in blinkm_led_common_set() leds: add new lp8788 led driver LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS leds: max8997: Simplify max8997_led_set_mode implementation leds/leds-s3c24xx: use devm_gpio_request leds: convert Network Space v2 LED driver to devm_kzalloc() and cleanup error exit path leds: convert DAC124S085 LED driver to devm_kzalloc() leds: convert LM3530 LED driver to devm_kzalloc() and cleanup error exit path leds: convert TCA6507 LED driver to devm_kzalloc() leds: convert Freescale MC13783 LED driver to devm_kzalloc() and cleanup error exit path leds: convert ADP5520 LED driver to devm_kzalloc() and cleanup error exit path leds: convert PCA955x LED driver to devm_kzalloc() and cleanup error exit path leds: convert Sun Fire LED driver to devm_kzalloc() and cleanup error exit path leds: convert PCA9532 LED driver to devm_kzalloc() leds: convert LT3593 LED driver to devm_kzalloc() leds: convert Renesas TPU LED driver to devm_kzalloc() and cleanup error exit path leds: convert LP5523 LED driver to devm_kzalloc() and cleanup error exit path leds: convert PCA9633 LED driver to devm_kzalloc() ...
2012-07-27powerpc/ftrace: Trace function graph entry before updating indexSteven Rostedt
As Colin Cross ported my x86 change to ARM, he also pointed out that powerpc is also behind in this fix. The commit 722b3c746953 "ftrace/graph: Trace function entry before updating index" fixes an issue with function graph tracing for x86, where if the called entry function decides not to trace interrupts, it can fail the check if an interrupt comes in just after the curr_ret_stack is updated. The solution is to call the entry function first, then update the curr_ret_stack if the entry function wants to be traced. Cc: Colin Cross <ccross@android.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-27radeonfb: Add quirk for the graphics adapter in some JSxxTony Breeds
These devices are set to 640x480 by firmware, switch them to 800x600@60 so that the graphical installer can run on remote console. Reported by IBM during SLES10 SP2 beta testing: https://bugzilla.novell.com/show_bug.cgi?id=461002 LTC50817 Signed-off-by: Olaf Hering <olaf@aepfle.de> Signed-off-by: Tony Breeds <tony@bakeyournoodle.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-27powerpc: Lack of firmware flash support is not an errorAnton Blanchard
Reduce the severity of the warning given when firmware flash is not supported. Not all platforms have it. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-27powerpc: Enable pseries hardware RNG and crypto modulesAnton Blanchard
Enable the hardware RNG and crypto modules. I verified they both autoload via the VIO subsystem, so there is no need to build them in. Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-27powerpc: Update g5_defconfigBenjamin Herrenschmidt
This updates the g5 defconfig to include nouveau instead of nvidiafb (which works much better nowadays, in fact the latter crashes on modern distros), and to set CONFIG_VT_HW_CONSOLE_BINDING without which takeover from the firmware offb by nouveau doesn't work properly (and leads to unexplained black screens for some users). The rest is churn of going through defconfig / savedefconfig Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-27powerpc/kvm/bookehv: Fix build regressionAlexander Graf
After merging the register type check patches from Ben's tree, the hv enabled booke implementation ceased to compile. This patch fixes things up so everyone's happy again. Signed-off-by: Alexander Graf <agraf@suse.de> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-27powerpc: Set stack limit properly in crit_transfer_to_handlerStuart Yoder
Commit 9778b696a0188ad3b3524b383953ee73b31b7b68 incorrectly changes the code setting the stack limit on entry to the kernel to mark the thread_info at the bottom of the stack out of bounds anymore. This fixes it. Signed-off-by: Stuart Yoder <stuart.yoder@freescale.com> Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org>
2012-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparcLinus Torvalds
Pull sparc updates from David Miller: "Nothing much this merge window for sparc. 1) Fix FPU state management in sparc32, from Tkhai Kirill. 2) More sparc32 mm layer code cleanups, largely more side effects of the sun4c support removal in the 3.5 From Sam Ravnborg. 3) Remove unused code in sparc64, from Bjorn Helgaas and Kirill Tkhai. 4) Some declaration and comment tidies in PROM support code, from Geert Uytterhoeven." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/sparc: (24 commits) sparc32, copy_thread: Clear TIF_USEDFPU flag of created task instead of current sparc32: delete dead code in show_mem() sparc32: move kmap_init() to highmem.c sparc32: move probe_memory() to srmmu.c sparc32: drop unused BAD_PAGE stuff sparc32: centralize all mmu context handling in srmmu.c sparc32: drop quicklist sparc32: drop sparc model check in paging_init sparc32: drop sparc_unmapped_base sparc32,leon: drop leon_init() sparc32: drop fixmap.h sparc32: fixmap.h cleanup sparc32: drop unused kmap_atomic_to_page sparc32: drop swapper_pg_dir sparc32: beautify srmmu_inherit_prom_mappings() sparc32: use void * in nocache get/free sparc32: fix coding-style in srmmu.c sparc32: sort includes in srmmu.c sparc32: define a few srmmu functions __init sparc64: remove unused function straddles_64bit_va_hole() ...
2012-07-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/netLinus Torvalds
Pull networking updates and fixes from David Miller: 1) Reinstate the no-ref optimization for input route lookups in ipv4 to fix some routing cache removal perf regressions. 2) Make TCP socket pre-demux work on ipv6 side too, from Eric Dumazet. 3) Get RX hash value from correct place in be2net driver, from Sarveshwar Bandi. 4) Validation of FIB cached routes missing critical check, from Eric Dumazet. 5) EEH support in mlx4 driver, from Kleber Sacilotto de Souza. * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net: (23 commits) ipv6: Early TCP socket demux ipv4: Fix input route performance regression. pch_gbe: vlan skb len fix pch_gbe: add extra clean tx pch_gbe: fix transmit watchdog timeout ixgbe: fix panic while dumping packets on Tx hang with IOMMU be2net: Fix to parse RSS hash from Receive completions correctly. net/mlx4_en: Limit the RFS filter IDs to be < RPS_NO_FILTER hyperv: Add error handling to rndis_filter_device_add() hyperv: Add a check for ring_size value ipv4: rt_cache_valid must check expired routes net/pch_gpe: Cannot disable ethernet autonegation qeth: repair crash in qeth_l3_vlan_rx_kill_vid() netiucv: cleanup attribute usage net: wiznet add missing HAS_IOMEM dependency be2net: Missing byteswap in be_get_fw_log_level causes oops on PowerPC mlx4: Add support for EEH error recovery cdc-ncm: tag Ericsson WWAN devices (eg F5521gw) with FLAG_WWAN wanmain: comparing array with NULL caif: fix NULL pointer check ...
2012-07-26Btrfs: using vmalloc and friends needs vmalloc.hStephen Rothwell
On powerpc, we don't get the implicit vmalloc.h include, and as a result the build fails noisily: fs/btrfs/send.c: In function 'fs_path_free': fs/btrfs/send.c:185:4: error: implicit declaration of function 'vfree' [-Werror=implicit-function-declaration] fs/btrfs/send.c: In function 'fs_path_ensure_buf': fs/btrfs/send.c:215:4: error: implicit declaration of function 'vmalloc' [-Werror=implicit-function-declaration] fs/btrfs/send.c:215:12: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/send.c:225:12: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/send.c:233:13: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/send.c: In function 'iterate_dir_item': fs/btrfs/send.c:900:10: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/send.c:909:11: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/send.c: In function 'btrfs_ioctl_send': fs/btrfs/send.c:4463:17: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/send.c:4469:17: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/send.c:4475:2: error: implicit declaration of function 'vzalloc' [-Werror=implicit-function-declaration] fs/btrfs/send.c:4475:20: warning: assignment makes pointer from integer without a cast [enabled by default] fs/btrfs/send.c:4483:21: warning: assignment makes pointer from integer without a cast [enabled by default] Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-27leds-lp8788: forgotten unlock at lp8788_led_workDevendra Naga
at default case of switch we return with out unlocking the mutex. Signed-off-by: Devendra Naga <develkernel412222@gmail.com> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-27LEDS: propagate error codes in blinkm_detect()Dan Carpenter
Use the error codes from the lower levels instead of -ENODEV. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Jan-Simon Möller <jansimon.moeller@gmx.de> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-27LEDS: memory leak in blinkm_led_common_set()Dan Carpenter
This can return without freeing the bl_work struct. Also there was no check for allocation failure. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Jan-Simon Möller <jansimon.moeller@gmx.de> Signed-off-by: Bryan Wu <bryan.wu@canonical.com>
2012-07-27cpumask: cpulist_parse() comments correctionAlex Shi
As introduced in Rusty's commit 29c0177e6a4, the function has no parameter @len, so need to remove it from comments to avoid kernel-doc warning: alexs@debian:~/linux-next$ scripts/kernel-doc -man include/linux/cpumask.h | split-man.pl /tmp/man .... Warning(include/linux/cpumask.h:602): Excess function parameter 'len' description in 'cpulist_parse' and correct the function name in comments to cpulist_parse. Signed-off-by: Alex Shi <alex.shi@intel.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-07-27init: add comments to keep initcall-names in sync with initcall levelsJim Cromie
main.c has initcall_level_names[] for parse_args to print in debug messages, add comments to keep them in sync with initcalls defined in init.h. Also add "loadable" into comment re not using *_initcall macros in modules, to disambiguate from kernel/params.c and other builtins. Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Acked-by: Borislav Petkov <borislav.petkov@amd.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-07-27cpumask: add a few comments of cpumask functionsAlex Shi
Current few cpumask functions' purposes are not quite clear. Stupid user like myself needs to dig into details for clear function purpose and return value. Add few explanation for them is helpful. Thanks for Srivatsa's comments and correction! Signed-off-by: Alex Shi <alex.shi@intel.com> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2012-07-26sparc32, copy_thread: Clear TIF_USEDFPU flag of created task instead of currentTkhai Kirill
FPU state is saved into task_struct of created task. Current task continues use of the state, so it needs TIF_USEDFPU flag is not cleared. Created task receives fresh FPU and cleared TIF_USEFPU flag is required for it. Signed-off-by: Kirill Tkhai <tkhai@yandex.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: delete dead code in show_mem()Sam Ravnborg
Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: move kmap_init() to highmem.cSam Ravnborg
Try to keep highmem support in a more central place. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: move probe_memory() to srmmu.cSam Ravnborg
Only one user so move it to the file using it. It had nothing to do in fault_32. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: drop unused BAD_PAGE stuffSam Ravnborg
2012-07-26sparc32: centralize all mmu context handling in srmmu.cSam Ravnborg
2012-07-26sparc32: drop quicklistSam Ravnborg
The quicklist stuff is not used anymore - drop it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: drop sparc model check in paging_initSam Ravnborg
We already check the model in head_32.S so no need to repeat the check here Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: drop sparc_unmapped_baseSam Ravnborg
The base is always the same so no need to use a variable for this. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32,leon: drop leon_init()Sam Ravnborg
This function was only used to set of_pdt_build_more to leon_node_init(). But the leon_node_init() was a nop as prom_amba_init was never assigned. Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Konrad Eisele <konrad@gaisler.com> Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: drop fixmap.hSam Ravnborg
sparc32 does not support fixmaps - so do not pretend so by having the fixmap.h file. Move relevant parts to vaddrs.h. I looked at simplifying this even more but failed to understand the reasoning behind the extra guard page involved and due to missing testing possibilities only the trivial conversion was done. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: fixmap.h cleanupSam Ravnborg
Remove all unused stuff from fixmap.h It is only used for highmem - sparc32 has no fixmap support. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: drop unused kmap_atomic_to_pageSam Ravnborg
No users left of this function - drop it. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: drop swapper_pg_dirSam Ravnborg
We save one page of RAM dropping swapper_pg_dir. It was only used for an assignment in init-mm.c and we redid this later in srmmu.c anyway. This is likely a left-over from the sun4c removal. To avoid a dummy variable we use a simple #define swapper_pg_dir NULL Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: beautify srmmu_inherit_prom_mappings()Sam Ravnborg
2012-07-26sparc32: use void * in nocache get/freeSam Ravnborg
This allowed to us to kill a lot of casts, with no loss of readability in any places Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: fix coding-style in srmmu.cSam Ravnborg
Fix the most annoying issues that distracts me: - whitespace - missing space after "if" and "while" - spaces around operators and similar simple things. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26sparc32: sort includes in srmmu.cSam Ravnborg
2012-07-26sparc32: define a few srmmu functions __initSam Ravnborg
They are only used during early init so lets get rid of them after init to save some RAM. Signed-off-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26Merge tag 'remoteproc-for-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc Pull remoteproc update from Ohad Ben-Cohen: - custom binary format support from Sjur Brændeland - groundwork for recovery and runtime pm support - some cleanups and API simplifications Fix up conflicts in drivers/remoteproc/remoteproc_core.c due to clashes with earlier cleanups by Sjur Brændeland (with part of the cleanups moved into the new remoteproc_elf_loader.c file). * tag 'remoteproc-for-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/ohad/remoteproc: MAINTAINERS: add remoteproc's git remoteproc: Support custom firmware handlers remoteproc: Move Elf related functions to separate file remoteproc: Add function rproc_get_boot_addr remoteproc: Pass struct fw to load_segments and find_rsc_table. remoteproc: adopt the driver core's alloc/add/del/put naming remoteproc: remove the get_by_name/put API remoteproc: support non-iommu carveout assignment remoteproc: simplify unregister/free interfaces remoteproc: remove the now-redundant kref remoteproc: maintain a generic child device for each rproc remoteproc: allocate vrings on demand, free when not needed
2012-07-26ipv6: Early TCP socket demuxEric Dumazet
This is the IPv6 missing bits for infrastructure added in commit 41063e9dd1195 (ipv4: Early TCP socket demux.) Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26ipv4: Fix input route performance regression.David S. Miller
With the routing cache removal we lost the "noref" code paths on input, and this can kill some routing workloads. Reinstate the noref path when we hit a cached route in the FIB nexthops. With help from Eric Dumazet. Reported-by: Alexander Duyck <alexander.duyck@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs Pull large btrfs update from Chris Mason: "This pull request is very large, and the two main features in here have been under testing/devel for quite a while. We have subvolume quotas from the strato developers. This enables full tracking of how many blocks are allocated to each subvolume (and all snapshots) and you can set limits on a per-subvolume basis. You can also create quota groups and toss multiple subvolumes into a big group. It's everything you need to be a web hosting company and give each user their own subvolume. The userland side of the quotas is being refreshed, they'll send out details on where to grab it soon. Next is the kernel side of btrfs send/receive from Alexander Block. This leverages the same infrastructure as the quota code to figure out relationships between blocks and their owners. It can then compute the difference between two snapshots and sends the diffs in a neutral format into userland. The basic model: create a snapshot send that snapshot as the initial backup make changes create a second snapshot send the incremental as a backup delete the first snapshot (use the second snapshot for the next incremental) The receive portion is all in userland, and in the 'next' branch of my btrfs-progs repo. There's still some work to do in terms of optimizing the send side from kernel to userland. The really important part is figuring out how two snapshots are different, and this is where we are concentrating right now. The initial send of a dataset is a little slower than tar, but the incremental sends are dramatically faster than what rsync can do. On top of all of that, we have a nice queue of fixes, cleanups and optimizations." Fix up trivial modify/del conflict in fs/btrfs/ioctl.c Also fix up semantic conflict in fs/btrfs/send.c: the interface to dentry_open() changed in commit 765927b2d508 ("switch dentry_open() to struct path, make it grab references itself"), and since it now grabs whatever references it needs, we should no longer do the mntget() on the mnt (and we need to dput() the dentry reference we took). * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/linux-btrfs: (65 commits) Btrfs: uninit variable fixes in send/receive Btrfs: introduce BTRFS_IOC_SEND for btrfs send/receive Btrfs: add btrfs_compare_trees function Btrfs: introduce subvol uuids and times Btrfs: make iref_to_path non static Btrfs: add a barrier before a waitqueue_active check Btrfs: call the ordered free operation without any locks held Btrfs: Check INCOMPAT flags on remount and add helper function Btrfs: add helper for tree enumeration btrfs: allow cross-subvolume file clone Btrfs: improve multi-thread buffer read Btrfs: make btrfs's allocation smoothly with preallocation Btrfs: lock the transition from dirty to writeback for an eb Btrfs: fix potential race in extent buffer freeing Btrfs: don't return true in releasepage unless we actually freed the eb Btrfs: suppress printk() if all device I/O stats are zero Btrfs: remove unwanted printk() for btrfs device I/O stats Btrfs: rewrite BTRFS_SETGET_FUNCS Btrfs: zero unused bytes in inode item Btrfs: kill free_space pointer from inode structure ... Conflicts: fs/btrfs/ioctl.c
2012-07-26pch_gbe: vlan skb len fixAndy Cress
pch_gbe_xmit_frame skb->len verification was incorrect in vlan case causing bogus transfer length errors. One correction could be: offset = skb->protocol == htons(ETH_P_8021Q) ? 0 : 4; if (unlikely(skb->len > (adapter->hw.mac.max_frame_size - offset))) However, this verification is not necessary, so remove it. Signed-off-by: Andy Cress <andy.cress@us.kontron.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26pch_gbe: add extra clean txAndy Cress
This adds extra cleaning to the pch_gbe_clean_tx routine to avoid transmit timeouts on some BCM PHYs that have different timing. Also update the DRV_VERSION to 1.01, and show it. Signed-off-by: Andy Cress <andy.cress@us.kontron.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26pch_gbe: fix transmit watchdog timeoutAndy Cress
An extended ping test with 6 vlans resulted in a driver oops with a netdev transmit timeout. Fix WATCHDOG_TIMEOUT to be more like e1000e at 5 * HZ, to avoid unnecessary transmit timeouts. Signed-off-by: Andy Cress <andy.cress@us.kontron.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26ixgbe: fix panic while dumping packets on Tx hang with IOMMUEmil Tantilov
This patch resolves a "BUG: unable to handle kernel paging request at ..." oops while dumping packet data. The issue occurs with IOMMU enabled due to the address provided by phys_to_virt(). This patch makes use of skb->data on Tx and the virtual address of the pages allocated for Rx. Signed-off-by: Emil Tantilov <emil.s.tantilov@intel.com> Tested-by: Phil Schmitt <phillip.j.schmitt@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-07-26Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux Pull ACPI & power management update from Len Brown: "Re-write of the turbostat tool. lower overhead was necessary for measuring very large system when they are very idle. IVB support in intel_idle It's what I run on my IVB, others should be able to also:-) ACPICA core update We have found some bugs due to divergence between Linux and the upstream ACPICA base. Most of these patches are to reduce that divergence to reduce the risk of future bugs. Some cpuidle updates, mostly for non-Intel More will be coming, as they depend on this part. Some thermal management changes needed by non-ACPI systems. Some _OST (OS Status Indication) updates for hot ACPI hot-plug." * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux: (51 commits) Thermal: Documentation update Thermal: Add Hysteresis attributes Thermal: Make Thermal trip points writeable ACPI/AC: prevent OOPS on some boxes due to missing check power_supply_register() return value check tools/power: turbostat: fix large c1% issue tools/power: turbostat v2 - re-write for efficiency ACPICA: Update to version 20120711 ACPICA: AcpiSrc: Fix some translation issues for Linux conversion ACPICA: Update header files copyrights to 2012 ACPICA: Add new ACPI table load/unload external interfaces ACPICA: Split file: tbxface.c -> tbxfload.c ACPICA: Add PCC address space to space ID decode function ACPICA: Fix some comment fields ACPICA: Table manager: deploy new firmware error/warning interfaces ACPICA: Add new interfaces for BIOS(firmware) errors and warnings ACPICA: Split exception code utilities to a new file, utexcep.c ACPI: acpi_pad: tune round_robin_time ACPICA: Update to version 20120620 ACPICA: Add support for implicit notify on multiple devices ACPICA: Update comments; no functional change ...
2012-07-26Merge branch 'drm-next' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "One of the smaller drm -next pulls in ages! Ben (nouveau) has a rewrite in progress but we decided to leave it stew for another cycle, so just some fixes from him. - radeon: lots of documentation work, fixes, more ring and locking changes, pcie gen2, more dp fixes. - i915: haswell features, gpu reset fixes, /dev/agpgart removal on machines that we never used it on, more VGA/HDP fix., more DP fixes - drm core: cleanups from Daniel, sis 64-bit fixes, range allocator colouring. but yeah fairly quiet merge this time, probably because I missed half of it!" Trivial add-add conflict in include/linux/pci_regs.h * 'drm-next' of git://people.freedesktop.org/~airlied/linux: (255 commits) drm/nouveau: init vblank requests list drm/nv50: extend vblank semaphore to generic dmaobj + offset pair drm/nouveau: mark most of our ioctls as deprecated, move to compat layer drm/nouveau: move current gpuobj code out of nouveau_object.c drm/nouveau/gem: fix object reference leak in a failure path drm/nv50: rename INVALID_QUERY_OR_TEXTURE error to INVALID_OPERATION drm/nv84: decode PCRYPT errors drm/nouveau: dcb table quirk for fdo#50830 nouveau: Fix alignment requirements on src and dst addresses drm/i915: unbreak lastclose for failed driver init drm/i915: Set the context before setting up regs for the context. drm/i915: constify mode in crtc_mode_fixup drm/i915/lvds: ditch ->prepare special case drm/i915: dereferencing an error pointer drm/i915: fix invalid reference handling of the default ctx obj drm/i915: Add -EIO to the list of known errors for __wait_seqno drm/i915: Flush the context object from the CPU caches upon switching drm/radeon: fix dpms on/off on trinity/aruba v2 drm/radeon: on hotplug force link training to happen (v2) drm/radeon: fix hotplug of DP to DVI|HDMI passive adapters (v2) ...
2012-07-26Merge tag 'dlm-3.6' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm Pull dlm updatesfrom David Teigland: "This set includes a major redesign of recording the master node for resources. The old dir hash table, which just held the master node for each resource, has been removed. The rsb hash table has always duplicated the master node value from the dir, and is now the single record of it. Having two full hash tables of all resources has always been a waste, especially since one just duplicated a single value from the other. Local requests will now often require one instead of two lengthy hash table searches. The other substantial change is made possible by the dirtbl removal, and fixes a long standing race between resource removal and lookup by reworking how removal is done. At the same time it improves the efficiency of removal by avoiding repeated searches through a hash bucket. The other commits include minor fixes and changes." * tag 'dlm-3.6' of git://git.kernel.org/pub/scm/linux/kernel/git/teigland/linux-dlm: dlm: fix missing dir remove dlm: fix conversion deadlock from recovery dlm: use wait_event_timeout dlm: fix race between remove and lookup dlm: use idr instead of list for recovered rsbs dlm: use rsbtbl as resource directory
