- There are no lists in fs/romfs/inode.c, so using list_entry
is a bit confusing. Replace it with container_of.
- It is unnecessary to cast the return value of
kmem_cache_alloc, since it returns a void* pointer.
Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com>
This memcpy looks so strange, in fact it's merely a pointer dereference, so I
change the parameter's type to refer it more directly, this could make the
memcpy not needed anymore.
In the function nbd_read_stat where nbd_find_request is only once called, the
parameter served should be transformed accordingly.
Signed-off-by: Denis Cheng <crquan@gmail.com>
Cc: Paul Clements <paul.clements@steeleye.com>
Thus the traverse of the loop may delete nodes, use the safe version.
DECLARE_MUTEX_LOCKED was used for semaphores used as completions and we've
got rid of them. Well, except for one in libusual that the maintainer
explicitly wants to keep as semaphore. So convert that useage to an
explicit sema_init and kill of DECLARE_MUTEX_LOCKED so that new code is
reminded to use a completion.
Acked-by: "Satyam Sharma" <satyam.sharma@gmail.com>
SHMLBA cant possible be used in userspace, see sparc versions of that header.
Do not export asm/shmparam.h during make headers_install_all
This removes another uservisible place of PAGE_SIZE
Signed-off-by: Olaf Hering <olaf@aepfle.de>
The Synchronous Serial Controller (SSC) on Atmel microprocessors are
capable of tranceiving many frame based protocols, like I2S. Tested on the
AT32AP7000/ATSTK1000.
This driver is used in the ALSA sound driver for the AT73C213 external DAC
on the ATSTK1000 development board for AVR32. This sound driver will be
submitted soon.
Hardware documentation can be found in the AT32AP7000 data sheet, which can
be downloaded from
http://www.atmel.com/dyn/products/datasheets.asp?family_id=682
[akpm@linux-foundation.org: init spinlock at compile time]
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com>
Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com>
Cc: David Brownell <david-b@pacbell.net>
Cc: Andrew Victor <andrew@sanpeople.com>
Cc: Patrice Vilchez <patrice.vilchez@rfo.atmel.com>
Cc: Nicolas Ferre <nicolas.ferre@rfo.atmel.com>
Replace worthless comments with actual preprocessor errors when including
the wrong versions of the compiler.h files.
[akpm@linux-foundation.org: make it work]
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Use mutex instead of semaphore in fs/isofs/compress.c, and remove an
unnecessary variable.
Signed-off-by: Dave Young <hidave.darkstar@gmail.com>
Acked-by: H. Peter Anvin <hpa@zytor.com>
These aren't modular, so SLAB_PANIC is OK.
Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru>
Control the trigger limit for softlockup warnings. This is useful for
debugging softlockups, by lowering the softlockup_thresh to identify
possible softlockups earlier.
This patch:
1. Adds a sysctl softlockup_thresh with valid values of 1-60s
(Higher value to disable false positives)
2. Changes the softlockup printk to print the cpu softlockup time
[akpm@linux-foundation.org: Fix various warnings and add definition of "two"]
Signed-off-by: Ravikiran Thirumalai <kiran@scalex86.org>
Signed-off-by: Shai Fultheim <shai@scalex86.org>
kernel/softirq.c grew a few style uncleanlinesses in the past few
months, clean that up. No functional changes:
1126 76 4 1206 4b6 softlockup.o.before
1129 76 4 1209 4b9 softlockup.o.after
( the 3 bytes .text increase is due to the "<1>" appended to one of
the printk messages. )
Improve the debuggability of kernel lockups by enhancing the debug
output of the softlockup detector: print the task that causes the lockup
and try to print a more intelligent backtrace.
The old format was:
BUG: soft lockup detected on CPU#1!
[<c0105e4a>] show_trace_log_lvl+0x19/0x2e
[<c0105f43>] show_trace+0x12/0x14
[<c0105f59>] dump_stack+0x14/0x16
[<c015f6bc>] softlockup_tick+0xbe/0xd0
[<c013457d>] run_local_timers+0x12/0x14
[<c01346b8>] update_process_times+0x3e/0x63
[<c0145fb8>] tick_sched_timer+0x7c/0xc0
[<c0140a75>] hrtimer_interrupt+0x135/0x1ba
[<c011bde7>] smp_apic_timer_interrupt+0x6e/0x80
[<c0105aa3>] apic_timer_interrupt+0x33/0x38
[<c0104f8a>] syscall_call+0x7/0xb
The new format is:
BUG: soft lockup detected on CPU#1! [prctl:2363]
Pid: 2363, comm: prctl
EIP: 0060:[<c013915f>] CPU: 1
EIP is at sys_prctl+0x24/0x18c
EFLAGS: 00000213 Not tainted (2.6.22-cfs-v20 #26)
EAX: 00000001 EBX: 000003e7 ECX: 00000001 EDX: f6df0000
ESI: 000003e7 EDI: 000003e7 EBP: f6df0fb0 DS: 007b ES: 007b FS: 00d8
CR0: 8005003b CR2: 4d8c3340 CR3: 3731d000 CR4: 000006d0
[<c01040be>] show_regs+0x1ab/0x1b3
[<c015f807>] softlockup_tick+0xef/0x108
[<c0145fcc>] tick_sched_timer+0x7c/0xc0
[<c0140a89>] hrtimer_interrupt+0x135/0x1ba
Note that in the old format we only knew that some system call locked
up, we didnt know _which_. With the new format we know that it's at a
specific place in sys_prctl(). [which was where i created an artificial
kernel lockup to test the new format.]
This is also useful if the lockup happens in user-space - the user-space
EIP (and other registers) will be printed too. (such a lockup would
either suggest that the task was running at SCHED_FIFO:99 and looping
for more than 10 seconds, or that the softlockup detector has a
false-positive.)
The task name is printed too first, just in case we dont manage to print
a useful backtrace.
[satyam@infradead.org: fix warning]
Signed-off-by: Satyam Sharma <satyam@infradead.org>
The softlockup detector would like to use get_irq_regs(), so generalize the
availability on every Linux architecture.
(It is fine for an architecture to always return NULL to get_irq_regs(),
which it does by default.)
Cc: Ian Molton <spyro@f2s.com>
Cc: Kumar Gala <galak@gate.crashing.org>
Cc: Mikael Starvik <starvik@axis.com>
Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp>
this Xen related commit:
commit 966812dc98e6a7fcdf759cbfa0efab77500a8868
Author: Jeremy Fitzhardinge <jeremy@goop.org>
Date: Tue May 8 00:28:02 2007 -0700
Ignore stolen time in the softlockup watchdog
broke the softlockup watchdog to never report any lockups. (!)
print_timestamp defaults to 0, this makes the following condition
always true:
if (print_timestamp < (touch_timestamp + 1) ||
and we'll in essence never report soft lockups.
apparently the functionality of the soft lockup watchdog was never
actually tested with that patch applied ...
Cc: <stable@kernel.org>
sched_clock() is not a reliable time-source, use cpu_clock() instead.
Remove the rmb() from mce_log(), since the immunized version of
rcu_dereference() makes it unnecessary.
Cc: Andi Kleen <ak@suse.de>
Turns out that compiler writers are a bit more aggressive about optimizing
than one might expect. This patch prevents a number of such optimizations
from messing up rcu_deference(). This is not merely a theoretical problem, as
evidenced by the rmb() in mce_log().
Acked-by: Josh Triplett <josh@kernel.org>
list_del() hardly can fail, so checking for return value is pointless
(and current code always return 0).
Nobody really cared that return value anyway.
Switch single-linked binfmt formats list to usual list_head's. This leads
to one-liners in register_binfmt() and unregister_binfmt(). The downside
is one pointer more in struct linux_binfmt. This is not a problem, since
the set of registered binfmts on typical box is very small -- (ELF +
something distro enabled for you).
Test-booted, played with executable .txt files, modprobe/rmmod binfmt_misc.
- remove the following no longer used functions:
- bitmap.c: reiserfs_claim_blocks_to_be_allocated()
- bitmap.c: reiserfs_release_claimed_blocks()
- bitmap.c: reiserfs_can_fit_pages()
- make the following functions static:
- inode.c: restart_transaction()
- journal.c: reiserfs_async_progress_wait()
Acked-by: Vladimir V. Saveliev <vs@namesys.com>
Cc: Nick Piggin <npiggin@suse.de>
This is a writeback-internal marker but we're propagating it all the way back
to userspace!.
zone->lock is quite an "inner" lock and mostly constrained to page alloc as
well, so like slab locks, it probably isn't something that is critically
important to document here. However unlike slab locks, zone lock could be
used more widely in future, and page_alloc.c might possibly have more
business to do tricky things with pagecache than does slab. So... I don't
think it hurts to document it.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Introduces new zone flag interface for testing and setting flags:
int zone_test_and_set_flag(struct zone *zone, zone_flags_t flag)
Instead of setting and clearing ZONE_RECLAIM_LOCKED each time shrink_zone() is
called, this flag is test and set before starting zone reclaim. Zone reclaim
starts in __alloc_pages() when a zone's watermark fails and the system is in
zone_reclaim_mode. If it's already in reclaim, there's no need to start again
so it is simply considered full for that allocation attempt.
There is a change of behavior with regard to concurrent zone shrinking. It is
now possible for try_to_free_pages() or kswapd to already be shrinking a
particular zone when __alloc_pages() starts zone reclaim. In this case, it is
possible for two concurrent threads to invoke shrink_zone() for a single zone.
This change forbids a zone to be in zone reclaim twice, which was always the
behavior, but allows for concurrent try_to_free_pages() or kswapd shrinking
when starting zone reclaim.
Cc: Andrea Arcangeli <andrea@suse.de>
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: David Rientjes <rientjes@google.com>
There's no reason to sleep in try_set_zone_oom() or clear_zonelist_oom() if
the lock can't be acquired; it will be available soon enough once the zonelist
scanning is done. All other threads waiting for the OOM killer are also
contingent on the exiting task being able to acquire the lock in
clear_zonelist_oom() so it doesn't make sense to put it to sleep.
Preprocess include/linux/oom.h before exporting it to userspace.
Cc: Alexey Dobriyan <adobriyan@gmail.com>
It's not necessary to include all of linux/sched.h in linux/oom.h. Instead,
simply include prototypes for the relevant structs and include linux/types.h
for gfp_t.
Acked-by: Alexey Dobriyan <adobriyan@gmail.com>
Since no task descriptor's 'cpuset' field is dereferenced in the execution of
the OOM killer anymore, it is no longer necessary to take callback_mutex.
[akpm@linux-foundation.org: restore cpuset_lock for other patches]
Acked-by: Christoph Lameter <clameter@sgi.com>
Instead of testing for overlap in the memory nodes of the the nearest
exclusive ancestor of both current and the candidate task, it is better to
simply test for intersection between the task's mems_allowed in their task
descriptors. This does not require taking callback_mutex since it is only
used as a hint in the badness scoring.
Tasks that do not have an intersection in their mems_allowed with the current
task are not explicitly restricted from being OOM killed because it is quite
possible that the candidate task has allocated memory there before and has
since changed its mems_allowed.
Suppresses the extraneous stack and memory dump when a parallel OOM killing
has been found. There's no need to fill the ring buffer with this information
if its already been printed and the condition that triggered the previous OOM
killer has not yet been alleviated.
Adds a new sysctl, 'oom_kill_allocating_task', which will automatically kill
the OOM-triggering task instead of scanning through the tasklist to find a
memory-hogging target. This is helpful for systems with an insanely large
number of tasks where scanning the tasklist significantly degrades
performance.
A final allocation attempt with a very high watermark needs to be attempted
before invoking out_of_memory(). OOM killer serialization needs to occur
before this final attempt, otherwise tasks attempting to OOM-lock all zones in
its zonelist may spin and acquire the lock unnecessarily after the OOM
condition has already been alleviated.
If the final allocation does succeed, the zonelist is simply OOM-unlocked and
__alloc_pages() returns the page. Otherwise, the OOM killer is invoked.
If the task cannot acquire OOM-locks on all zones in its zonelist, it is put
to sleep and the allocation is retried when it gets rescheduled. One of its
zones is already marked as being in the OOM killer so it'll hopefully be
getting some free memory soon, at least enough to satisfy a high watermark
allocation attempt. This prevents needlessly killing a task when the OOM
condition would have already been alleviated if it had simply been given
enough time.
OOM killer synchronization should be done with zone granularity so that memory
policy and cpuset allocations may have their corresponding zones locked and
allow parallel kills for other OOM conditions that may exist elsewhere in the
system. DMA allocations can be targeted at the zone level, which would not be
possible if locking was done in nodes or globally.
Synchronization shall be done with a variation of "trylocks." The goal is to
put the current task to sleep and restart the failed allocation attempt later
if the trylock fails. Otherwise, the OOM killer is invoked.
Each zone in the zonelist that __alloc_pages() was called with is checked for
the newly-introduced ZONE_OOM_LOCKED flag. If any zone has this flag present,
the "trylock" to serialize the OOM killer fails and returns zero. Otherwise,
all the zones have ZONE_OOM_LOCKED set and the try_set_zone_oom() function
returns non-zero.
Convert the int all_unreclaimable member of struct zone to unsigned long
flags. This can now be used to specify several different zone flags such as
all_unreclaimable and reclaim_in_progress, which can now be removed and
converted to a per-zone flag.
Flags are set and cleared as follows:
zone_set_flag(struct zone *zone, zone_flags_t flag)
zone_clear_flag(struct zone *zone, zone_flags_t flag)
Defines the first zone flags, ZONE_ALL_UNRECLAIMABLE and ZONE_RECLAIM_LOCKED,
which have the same semantics as the old zone->all_unreclaimable and
zone->reclaim_in_progress, respectively. Also converts all current users that
set or clear either flag to use the new interface.
Helper functions are defined to test the flags:
int zone_is_all_unreclaimable(const struct zone *zone)
int zone_is_reclaim_locked(const struct zone *zone)
All flag operators are of the atomic variety because there are currently
readers that are implemented that do not take zone->lock.
[akpm@linux-foundation.org: add needed include]
The OOM killer's CONSTRAINT definitions are really more appropriate in an
enum, so define them in include/linux/oom.h.
Move the OOM killer's extern function prototypes to include/linux/oom.h and
include it where necessary.
[clg@fr.ibm.com: build fix]
Signed-off-by: Cedric Le Goater <clg@fr.ibm.com>
Slab constructors currently have a flags parameter that is never used. And
the order of the arguments is opposite to other slab functions. The object
pointer is placed before the kmem_cache pointer.
Convert
ctor(void *object, struct kmem_cache *s, unsigned long flags)
to
ctor(struct kmem_cache *s, void *object)
throughout the kernel
[akpm@linux-foundation.org: coupla fixes]
Signed-off-by: Christoph Lameter <clameter@sgi.com>
Move irq handling out of new slab into __slab_alloc. That is useful for
Mathieu's cmpxchg_local patchset and also allows us to remove the crude
local_irq_off in early_kmem_cache_alloc().
Based on ideas of Andrew:
http://marc.info/?l=linux-kernel&m=102912915020543&w=2
Scale the bdi dirty limit inversly with the tasks dirty rate.
This makes heavy writers have a lower dirty limit than the occasional writer.
Andrea proposed something similar:
http://lwn.net/Articles/152277/
The main disadvantage to his patch is that he uses an unrelated quantity to
measure time, which leaves him with a workload dependant tunable. Other than
that the two approaches appear quite similar.
[akpm@linux-foundation.org: fix warning]
Scale writeback cache per backing device, proportional to its writeout speed.
By decoupling the BDI dirty thresholds a number of problems we currently have
will go away, namely:
- mutual interference starvation (for any number of BDIs);
- deadlocks with stacked BDIs (loop, FUSE and local NFS mounts).
It might be that all dirty pages are for a single BDI while other BDIs are
idling. By giving each BDI a 'fair' share of the dirty limit, each one can have
dirty pages outstanding and make progress.
A global threshold also creates a deadlock for stacked BDIs; when A writes to
B, and A generates enough dirty pages to get throttled, B will never start
writeback until the dirty pages go away. Again, by giving each BDI its own
'independent' dirty limit, this problem is avoided.
So the problem is to determine how to distribute the total dirty limit across
the BDIs fairly and efficiently. A DBI that has a large dirty limit but does
not have any dirty pages outstanding is a waste.
What is done is to keep a floating proportion between the DBIs based on
writeback completions. This way faster/more active devices get a larger share
than slower/idle devices.
[akpm@linux-foundation.org: fix warnings]
[hugh@veritas.com: Fix occasional hang when a task couldn't get out of balance_dirty_pages]
Signed-off-by: Hugh Dickins <hugh@veritas.com>
Given a set of objects, floating proportions aims to efficiently give the
proportional 'activity' of a single item as compared to the whole set. Where
'activity' is a measure of a temporal property of the items.
It is efficient in that it need not inspect any other items of the set
in order to provide the answer. It is not even needed to know how many
other items there are.
It has one parameter, and that is the period of 'time' over which the
'activity' is measured.
Count per BDI writeback pages.
Count per BDI reclaimable pages; nr_reclaimable = nr_dirty + nr_unstable.
Provide scalable per backing_dev_info statistics counters.
provide BDI constructor/destructor hooks
[akpm@linux-foundation.org: compile fix]
provide a way to tell lockdep about percpu_counters that are supposed to be
used from irq safe contexts.
alloc_percpu can fail, propagate that error.
Provide an accurate version of percpu_counter_read.
s/percpu_counter_sum/&_positive/
Because its consitent with percpu_counter_read*
Provide a method to set a percpu counter to a specified value.
percpu_counter is a s64 counter, make _add consitent.
