2010-08-11param: update drivers/acpi/debug.c to new schemeRusty Russell
The new module_param_cb() uses an ops struct, and the ops take a const struct kernel_param pointer (it's in .rodata). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-11param: use module_param in drivers/message/fusion/mptbase.cRusty Russell
No need to open code this! Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de>
2010-08-11ide: use module_param_named rather than module_param_callRusty Russell
It has the additional benefit of typechecking (in this case, an unsigned int). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de>
2010-08-11param: update drivers/char/ipmi/ipmi_watchdog.c to new schemeRusty Russell
This is one of the most interesting users of module parameters in the tree, so weaning it off the old-style non-const module_param_call scheme is a useful exercise. I was confused by set_param_int/get_param_int (vs. the normal param_set_int and param_get_int), so I renamed set_param_int to set_param_timeout, and re-used param_get_int directly instead of get_param_int. I also implemented param_check_wdog_ifnum and param_check_timeout, so now the ifnum_to_use and timeout/pretimeout parameters can just use plain module_param(). Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Corey Minyard <minyard@acm.org> Cc: openipmi-developer@lists.sourceforge.net
2010-08-11param: lock if_sdio's lbs_helper_name and lbs_fw_name against sysfs changes.Rusty Russell
Since it can be changed via sysfs, we need to make a copy. This most generic way of doing this is to keep a flag so we know when to free it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Cc: Dan Williams <dcbw@redhat.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: libertas-dev@lists.infradead.org Cc: linux-wireless@vger.kernel.org Cc: netdev@vger.kernel.org
2010-08-11param: lock myri10ge_fw_name against sysfs changes.Rusty Russell
Since it can be changed via sysfs, we need to make a copy. This most generic way of doing this is to keep a flag so we know when to free it. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Cc: Andrew Gallatin <gallatin@myri.com> Cc: Brice Goglin <brice@myri.com> Cc: netdev@vger.kernel.org
2010-08-11param: simple locking for sysfs-writable charp parametersRusty Russell
Since the writing to sysfs can free the old one, we need to block that when we access the charp variables. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Jeff Dike <jdike@addtoit.com> Cc: Dan Williams <dcbw@redhat.com> Cc: John W. Linville <linville@tuxdriver.com> Cc: Jing Huang <huangj@brocade.com> Cc: James E.J. Bottomley <James.Bottomley@suse.de> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Johannes Berg <johannes@sipsolutions.net> Cc: David S. Miller <davem@davemloft.net> Cc: user-mode-linux-devel@lists.sourceforge.net Cc: libertas-dev@lists.infradead.org Cc: linux-wireless@vger.kernel.org Cc: netdev@vger.kernel.org Cc: linux-scsi@vger.kernel.org Cc: linux-usb@vger.kernel.org
2010-08-11param: remove unnecessary writable charpRusty Russell
sysfs-writable charp arguments need to be locked against modification (since the old ones may be kfreed underneath us). String arguments are much simpler, so use them for small strings (eg. IFNAMSIZ). lkdtm only uses the parameters at module initialization time, so there's not much point making them writable. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: M. Mohan Kumar <mohan@in.ibm.com> Cc: Greg Kroah-Hartman <gregkh@suse.de> Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Julia Lawall <julia@diku.dk> Cc: devel@driverdev.osuosl.org
2010-08-11param: add kerneldoc to moduleparam.hRusty Russell
Also reorders the macros with the most common ones at the top. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: locking for kernel parametersRusty Russell
There may be cases (most obviously, sysfs-writable charp parameters) where a module needs to prevent sysfs access to parameters. Rather than express this in terms of a big lock, the functions are expressed in terms of what they protect against. This is clearer, esp. if the implementation changes to a module-level or even param-level lock. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: make param sections const.Rusty Russell
Since this section can be read-only (they're in .rodata), they should always have been const. Minor flow-through various functions. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: use free hook for charp (fix leak of charp parameters)Rusty Russell
Instead of using a "I kmalloced this" flag, we keep track of the kmalloced strings and use that list to check if we need to kfree (in practice, the list is very short). This means that kparams can be const again, and plugs a leak. This is important for drivers/usb/gadget/nokia.c which gets modprobe/rmmod'ed frequently on the N9000. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Cc: Artem Bityutskiy <dedekind1@gmail.com> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: add a free hook to kernel_param_ops.Rusty Russell
This allows us to generalize the KPARAM_KMALLOCED flag, by calling a function on every parameter when a module is unloaded. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11param: silence .init.text references from param opsRusty Russell
Ideally, we'd check that it was only the "set" function which was __init, and that the permissions were r/o. But that's a little hard. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Acked-by: Sam Ravnborg <sam@ravnborg.org> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11Add param ops struct for hvc_iucv driver.Sachin Sant
Today's next 20091117 build failed on s390 with drivers/char/hvc_iucv.c:1331: error: 'param_ops_vmidfilter' undeclared here (not in a function) make[2]: *** [drivers/char/hvc_iucv.o] Error 1 Most probably caused by commit 684a6d340b8a5767db4670031b0f39455346018a (param:param_ops) which introduced a param_ops structure. The following compile tested patch adds a param_ops structure for hvc_iucv. Signed-off-by: Sachin Sant <sachinp@in.ibm.com> Acked-by: Heiko Carstens <heiko.carstens@de.ibm.com> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-11nfs: update for module_param_named API changeStephen Rothwell
After merging the rr tree, today's linux-next build (powerpc ppc64_defconfig) failed like this: net/sunrpc/auth.c:74: error: 'param_ops_hashtbl_sz' undeclared here (not in a function) Caused by commit 0685652df0929cec7d78efa85127f6eb34962132 ("param:param_ops") interacting with commit f8f853ab19fcc415b6eadd273373edc424916212 ("SUNRPC: Make the credential cache hashtable size configurable") from the nfs tree. Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-11AppArmor: update for module_param_named API changeStephen Rothwell
Fixes these build errors: security/apparmor/lsm.c:701: error: 'param_ops_aabool' undeclared here (not in a function) security/apparmor/lsm.c:721: error: 'param_ops_aalockpolicy' undeclared here (not in a function) security/apparmor/lsm.c:729: error: 'param_ops_aauint' undeclared here (not in a function) Signed-off-by: Stephen Rothwell <sfr@canb.auug.org.au> Signed-off-by: John Johansen <john.johansen@canonical.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-11param: use ops in struct kernel_param, rather than get and set fns directlyRusty Russell
This is more kernel-ish, saves some space, and also allows us to expand the ops without breaking all the callers who are happy for the new members to be NULL. The few places which defined their own param types are changed to the new scheme (more which crept in recently fixed in following patches). Since we're touching them anyway, we change get() and set() to take a const struct kernel_param (which they really are). This causes some harmless warnings until we fix them (in following patches). To reduce churn, module_param_call creates the ops struct so the callers don't have to change (and casts the functions to reduce warnings). The modern version which takes an ops struct is called module_param_cb. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ville Syrjala <syrjala@sci.fi> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Alessandro Rubini <rubini@ipvvis.unipv.it> Cc: Michal Januszewski <spock@gentoo.org> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: linux-kernel@vger.kernel.org Cc: linux-input@vger.kernel.org Cc: linux-fbdev-devel@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: netdev@vger.kernel.org
2010-08-11param: move the EXPORT_SYMBOL to after the definitions.Rusty Russell
This is modern style, and good to do before we start changing things. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Reviewed-by: Takashi Iwai <tiwai@suse.de> Tested-by: Phil Carmody <ext-phil.2.carmody@nokia.com>
2010-08-11params: don't hand NULL values to param.set callbacks.Rusty Russell
An audit by Dongdong Deng revealed that most driver-author-written param calls don't handle val == NULL (which happens when parameters are specified with no =, eg "foo" instead of "foo=1"). The only real case to use this is boolean, so handle it specially for that case and remove a source of bugs for everyone else. Signed-off-by: Rusty Russell <rusty@rustcorp.com.au> Cc: Dongdong Deng <dongdong.deng@windriver.com> Cc: Américo Wang <xiyou.wangcong@gmail.com>
2010-08-11documentation: fix erroneous email address.Rusty Russell
Hey, at least it has both l's. Reported-by: Marin Mitov <mitov@issp.bas.bg> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2010-08-10Merge branch 'for-linus' of git://neil.brown.name/mdLinus Torvalds
* 'for-linus' of git://neil.brown.name/md: (24 commits) md: clean up do_md_stop md: fix another deadlock with removing sysfs attributes. md: move revalidate_disk() back outside open_mutex md/raid10: fix deadlock with unaligned read during resync md/bitmap: separate out loading a bitmap from initialising the structures. md/bitmap: prepare for storing write-intent-bitmap via dm-dirty-log. md/bitmap: optimise scanning of empty bitmaps. md/bitmap: clean up plugging calls. md/bitmap: reduce dependence on sysfs. md/bitmap: white space clean up and similar. md/raid5: export raid5 unplugging interface. md/plug: optionally use plugger to unplug an array during resync/recovery. md/raid5: add simple plugging infrastructure. md/raid5: export is_congested test raid5: Don't set read-ahead when there is no queue md: add support for raising dm events. md: export various start/stop interfaces md: split out md_rdev_init md: be more careful setting MD_CHANGE_CLEAN md/raid5: ensure we create a unique name for kmem_cache when mddev has no gendisk ...
2010-08-10x86: fix up system call numbering nitLinus Torvalds
As pointed out by Jiri Slaby: when I resolved the the 32-bit x85 system call entry tables for prlimit (due to the conflict with fanotify), I forgot to add the numbering in comments that we do for every fifth entry. Reported-by: Jiri Slaby <jslaby@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10power: Remove owner field from attribute initialization code in OLPC driverGuenter Roeck
Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10i2c.h: fix kernel-doc warningsRandy Dunlap
Fix kernel-doc warnings in linux/i2c.h: Warning(include/linux/i2c.h:176): No description found for parameter 'alert' Warning(include/linux/i2c.h:259): No description found for parameter 'of_node' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10kernel/timer.c: fix kernel-doc function parameter warningRandy Dunlap
Fix kernel-doc warning, add @timer description: Warning(kernel/timer.c:335): No description found for parameter 'timer' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10docbook: fixup media support files for htmldocs alsoRandy Dunlap
'make htmldocs' produces errors due to missing a supporting media file, so add 'xmldoclinks' to the htmldocs dependencies so that the needed supporting file will be present. Documentation/DocBook/media.xml:4: warning: failed to load external entity "Documentation/DocBook/media-entities.tmpl" Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10docbook: fix fatal error from libataRandy Dunlap
'make htmldocs' has a fatal error when processing libata.xml, as seen below. The string "Example patterns:" (or any string with "example.*:" in it AFAIK) causes some part of the doc generation tool chain to try to produce an <informalexample> block without a beginning <para>, but there is an ending </para> generated, which throws things out of kilter. I don't even know where (what program) this is happening in. I searched in docproc and xmlto and in some XML stylesheets without finding anything. If anyone can give me pointers about this, please do. Until this is fixed, let's just spell "Example" as "Sample" and match up the double quotation marks while there. Documentation/DocBook/libata.xml:6575: parser error : Opening and ending tag mismatch: programlisting line 6573 and para </para><para> ^ Documentation/DocBook/libata.xml:6580: parser error : Opening and ending tag mismatch: para line 6575 and programlisting </programlisting></informalexample> ^ unable to parse Documentation/DocBook/libata.xml make[2]: *** [Documentation/DocBook/libata.html] Error 1 Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10jfs: don't allow os2 xattr namespace overlap with othersDave Kleikamp
It's currently possible to bypass xattr namespace access rules by prefixing valid xattr names with "os2.", since the os2 namespace stores extended attributes in a legacy format with no prefix. This patch adds checking to deny access to any valid namespace prefix following "os2.". Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Reported-by: Sergey Vlasov <vsu@altlinux.ru> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-10Merge branch 'for-2.6.36' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.36' of git://git.kernel.dk/linux-2.6-block: (149 commits) block: make sure that REQ_* types are seen even with CONFIG_BLOCK=n xen-blkfront: fix missing out label blkdev: fix blkdev_issue_zeroout return value block: update request stacking methods to support discards block: fix missing export of blk_types.h writeback: fix bad _bh spinlock nesting drbd: revert "delay probes", feature is being re-implemented differently drbd: Initialize all members of sync_conf to their defaults [Bugz 315] drbd: Disable delay probes for the upcomming release writeback: cleanup bdi_register writeback: add new tracepoints writeback: remove unnecessary init_timer call writeback: optimize periodic bdi thread wakeups writeback: prevent unnecessary bdi threads wakeups writeback: move bdi threads exiting logic to the forker thread writeback: restructure bdi forker loop a little writeback: move last_active to bdi writeback: do not remove bdi from bdi_list writeback: simplify bdi code a little writeback: do not lose wake-ups in bdi threads ... Fixed up pretty trivial conflicts in drivers/block/virtio_blk.c and drivers/scsi/scsi_error.c as per Jens.
2010-08-10Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (94 commits) V4L/DVB: tvp7002: fix write to H-PLL Feedback Divider LSB register V4L/DVB: dvb: siano: free spinlock before schedule() V4L/DVB: media: video: pvrusb2: remove custom hex_to_bin() V4L/DVB: drivers: usbvideo: remove custom implementation of hex_to_bin() V4L/DVB: Report supported QAM modes on bt8xx V4L/DVB: media: ir-keytable: null dereference in debug code V4L/DVB: ivtv: convert to the new control framework V4L/DVB: ivtv: convert gpio subdev to new control framework V4L/DVB: wm8739: convert to the new control framework V4L/DVB: cs53l32a: convert to new control framework V4L/DVB: wm8775: convert to the new control framework V4L/DVB: cx2341x: convert to the control framework V4L/DVB: cx25840: convert to the new control framework V4L/DVB: cx25840/ivtv: replace ugly priv control with s_config V4L/DVB: saa717x: convert to the new control framework V4L/DVB: msp3400: convert to the new control framework V4L/DVB: saa7115: convert to the new control framework V4L/DVB: v4l2: hook up the new control framework into the core framework V4L/DVB: Documentation: add v4l2-controls.txt documenting the new controls API V4L/DVB: v4l2-ctrls: Whitespace cleanups ...
2010-08-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: watchdog: hpwdt: formatting of pointers in printk() watchdog: Adding support for ARM Primecell SP805 Watchdog watchdog: f71808e_wdt: new watchdog driver for Fintek F71808E and F71882FG watchdog: sch311x_wdt.c: set parent before registeriing the misc device in probe() function watchdog: wdt_pci.c: move ids to pci_ids.h watchdog: s3c2410_wdt - Fix removing of platform device
2010-08-10Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: RDMA/cxgb4: Obtain RDMA QID ranges from LLD/FW
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: xpad - add USB-ID for PL-3601 Xbox 360 pad Input: cy8ctmg100_ts - signedness bug Input: elantech - report position also with 3 fingers Input: elantech - discard the first 2 positions on some firmwares Input: adxl34x - do not mark device as disabled on startup Input: gpio_keys - add hooks to enable/disable device Input: evdev - rearrange ioctl handling Input: dynamically allocate ABS information Input: switch to input_abs_*() access functions Input: add static inline accessors for ABS properties
2010-08-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb-2.6: (148 commits) USB: serial: fix stalled writes USB: remove fake "address-of" expressions USB: fix thread-unsafe anchor utiliy routines USB: usbtest: support test device with only one iso-in or iso-out endpoint USB: usbtest: avoid to free coherent buffer in atomic context USB: xhci: Set DMA mask for host. USB: xhci: Don't flush doorbell writes. USB: xhci: Reduce reads and writes of interrupter registers. USB: xhci: Make xhci_set_hc_event_deq() static. USB: xhci: Minimize HW event ring dequeue pointer writes. USB: xhci: Make xhci_handle_event() static. USB: xhci: Remove unnecessary reads of IRQ_PENDING register. USB: xhci: Performance - move xhci_work() into xhci_irq() USB: xhci: Performance - move interrupt handlers into xhci-ring.c USB: xhci: Performance - move functions that find ep ring. USB:: fix linux/usb.h kernel-doc warnings USB: add USB serial ssu100 driver USB: usb-storage: implement autosuspend USB: ehci: fix remove of ehci debugfs dir USB: Add USB 2.0 to ssb ohci driver ...
2010-08-10Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty-2.6: (68 commits) U6715 16550A serial driver support Char: nozomi, set tty->driver_data appropriately Char: nozomi, fix tty->count counting serial: max3107: Fix gpiolib support hsu: call PCI pm hooks in suspend/resume function hsu: some code cleanup hsu: add a periodic timer to check dma rx channel hsu: driver for Medfield High Speed UART device mxser: remove unnesesary NULL check serial: add support for OX16PCI958 card serial: 68328serial.c: remove dead (ALMA_ANS | DRAGONIXVZ | M68EZ328ADS) timbuart: use __devinit and __devexit macros for probe and remove serial: MMIO32 support for 8250_early.c serial: mcf: don't take spinlocks in already protected functions serial: general fixes in the serial_rs485 structure serial: fix missing bit coverage of ASYNC_FLAGS serial: "altera_uart: simplify altera_uart_console_putc()" checkpatch fixes serial: crisv10: formatting of pointers in printk() vt: Fix warning: statement with no effect due to vt_kern.h tty_io: remove casts from void* ...
2010-08-10USB: serial: fix stalled writesJohan Hovold
As David VomLehn points out, it was possible to receive an interrupt before clearing the free-urb flag which could lead to the urb being incorrectly marked as busy. For the same reason, move tx_bytes accounting so that it will never be negative. Note that the free-flags set and clear operations do not need any additional locking as they are manipulated while USB_SERIAL_WRITE_BUSY is set. Reported-by: David VomLehn <dvomlehn@cisco.com> Tested-by: David VomLehn <dvomlehn@cisco.com> Signed-off-by: Johan Hovold <jhovold@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: remove fake "address-of" expressionsAlan Stern
Fake "address-of" expressions that evaluate to NULL generally confuse readers and can provoke compiler warnings. This patch (as1412) removes three such fake expressions, using "#ifdef"s in their place. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: fix thread-unsafe anchor utiliy routinesChristian Lamparter
This patch fixes a race condition in two utility routines related to the removal/unlinking of urbs from an anchor. If two threads are concurrently accessing the same anchor, both could end up with the same urb - thinking they are the exclusive owner. Alan Stern pointed out a related issue in usb_unlink_anchored_urbs: "The URB isn't removed from the anchor until it completes (as a by-product of completion, in fact), which might not be for quite some time after the unlink call returns. In the meantime, the subroutine will keep trying to unlink it, over and over again." Cc: stable <stable@kernel.org> Cc: Oliver Neukum <oneukum@suse.de> Cc: Greg Kroah-Hartman <greg@kroah.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Christian Lamparter <chunkeey@googlemail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: usbtest: support test device with only one iso-in or iso-out endpointMing Lei
It is very common that one altsetting may include only one iso-in or iso-out single endpoint, especially for high bandwidth endpoint, so support it. Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: usbtest: avoid to free coherent buffer in atomic contextMing Lei
This patch fixes the warning below: [30753.755998] ------------[ cut here ]------------ [30753.755998] WARNING: at /home/tom/git/linux-2.6/linux-2.6-next/arch/x86/include/asm/dma-mapping.h:155 hcd_buffer_free+0xb1/0xd4 [usbcore]() [30753.755998] Hardware name: 6475EK2 [30753.755998] Modules linked in: uvcvideo ehci_hcd usbtest cdc_ether usbnet vfat fat usb_storage nfsd lockd nfs_acl auth_rpcgss exportfs mii tun videodev v4l1_compat v4l2_compat_ioctl32 fuse bridge stp llc sunrpc ipv6 cpufreq_ondemand acpi_cpufreq freq_table mperf kvm_intel kvm arc4 ecb ath5k usbhid mac80211 snd_hda_codec_conexant ch341 usbserial ath cfg80211 thinkpad_acpi snd_hda_intel pcspkr wmi hwmon yenta_socket iTCO_wdt iTCO_vendor_support i2c_i801 e1000e snd_hda_codec snd_hwdep snd_pcm snd_timer snd soundcore snd_page_alloc pata_acpi uhci_hcd ohci_hcd usbcore i915 drm_kms_helper drm i2c_algo_bit i2c_core video output [last unloaded: uvcvideo] [30753.755998] Pid: 0, comm: swapper Tainted: G W 2.6.35-rc6-gkh-wl+ #49 [30753.755998] Call Trace: [30753.755998] <IRQ> [<ffffffff8104478a>] warn_slowpath_common+0x80/0x98 [30753.755998] [<ffffffff810447b7>] warn_slowpath_null+0x15/0x17 [30753.755998] [<ffffffffa00ce02d>] hcd_buffer_free+0xb1/0xd4 [usbcore] [30753.755998] [<ffffffffa00c1345>] usb_free_coherent+0x1c/0x1e [usbcore] [30753.755998] [<ffffffffa00b13e4>] simple_free_urb+0x23/0x2f [usbtest] [30753.755998] [<ffffffffa00b210b>] iso_callback+0xbb/0x10f [usbtest] [30753.755998] [<ffffffffa00c7390>] usb_hcd_giveback_urb+0x8c/0xc0 [usbcore] [30753.755998] [<ffffffffa0449b35>] ehci_urb_done+0x84/0x95 [ehci_hcd] [30753.755998] [<ffffffffa044b5a5>] ehci_work+0x41a/0x7dd [ehci_hcd] [30753.755998] [<ffffffffa044e298>] ehci_irq+0x33b/0x370 [ehci_hcd] [30753.755998] [<ffffffff8100fb05>] ? sched_clock+0x9/0xd [30753.755998] [<ffffffff8105e641>] ? sched_clock_local+0x1c/0x82 [30753.755998] [<ffffffff8105e76a>] ? sched_clock_cpu+0xc3/0xce [30753.755998] [<ffffffff81067c7e>] ? trace_hardirqs_off+0xd/0xf [30753.755998] [<ffffffff8105e7b8>] ? cpu_clock+0x43/0x5e [30753.755998] [<ffffffffa00c6999>] usb_hcd_irq+0x45/0xa1 [usbcore] [30753.755998] [<ffffffff81092e02>] handle_IRQ_event+0x20/0xa5 [30753.755998] [<ffffffff81094cea>] handle_fasteoi_irq+0x92/0xd2 [30753.755998] [<ffffffff8100c0ed>] handle_irq+0x1f/0x2a [30753.755998] [<ffffffff8100b75d>] do_IRQ+0x57/0xbe [30753.755998] [<ffffffff8136a693>] ret_from_intr+0x0/0x16 [30753.755998] <EOI> [<ffffffff81223baa>] ? acpi_idle_enter_bm+0x231/0x269 [30753.755998] [<ffffffff81223ba3>] ? acpi_idle_enter_bm+0x22a/0x269 [30753.755998] [<ffffffff812c4b6b>] cpuidle_idle_call+0x99/0xce [30753.755998] [<ffffffff81008dd5>] cpu_idle+0x61/0xaa [30753.755998] [<ffffffff8136374b>] start_secondary+0x1c2/0x1c6 [30753.755998] ---[ end trace 904cfaf7ab4cb1a2 ]--- Signed-off-by: Ming Lei <tom.leiming@gmail.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Set DMA mask for host.Sarah Sharp
Tell the USB core that we can do DMA directly (instead of needing it to memory-map the buffers for PIO). If the xHCI host supports 64-bit addresses, set the DMA mask accordingly. Otherwise indicate the host can handle 32-bit DMA addresses. This improves performance because the USB core doesn't have to spend time remapping buffers in high memory into the 32-bit address range. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Don't flush doorbell writes.Sarah Sharp
To tell the host controller that there are transfers on the endpoint rings, we need to ring the endpoint doorbell. This is a PCI MMIO write, which can be delayed until another register read is queued. The previous code would flush the doorbell write by reading the doorbell register after the write. This may take time, and it's not necessary to force the host controller to know about the transfers right away. Don't flush the doorbell register writes. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Reduce reads and writes of interrupter registers.Sarah Sharp
The interrupter register set includes a register that says whether interrupts are pending for each event ring (the IP bit). Each MSI-X vector will get its own interrupter set with separate IP bits. The status register includes an "Event Interrupt (EINT)" bit that is set when an IP bit is set in any of the interrupters. When PCI interrupts are used, the EINT bit exactly mirrors the IP bit in the single interrupter set, and it is a waste of time to check both registers when trying to figure out if the xHC interrupted or another device on the shared IRQ line interrupted. Only check the IP bit to reduce register reads. The IP bit is automatically cleared by the xHC when MSI or MSI-X is enabled. It doesn't make sense to read that register to check for shared interrupts (since MSI and MSI-X aren't shared). It also doesn't make sense to write to that register to clear the IP bit, since it is cleared by the hardware. We can tell whether MSI or MSI-X is enabled by looking at the irq number in hcd->irq. If it's -1, we know MSI or MSI-X is enabled. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Make xhci_set_hc_event_deq() static.Sarah Sharp
Now that the event handler functions no longer use xhci_set_hc_event_deq() to update the event ring dequeue pointer, that function is not used by anything in xhci-ring.c. Move that function into xhci-mem.c and make it static. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Minimize HW event ring dequeue pointer writes.Sarah Sharp
The xHCI specification suggests that writing the hardware event ring dequeue pointer register too often can be an expensive operation for the xHCI hardware to manage. It suggests minimizing the number of writes to that register. Originally, the driver wrote the event ring dequeue pointer after each event was processed. Depending on how the event ring moderation register is set up and how fast the transfers are completing, there may be several events processed for each interrupt. This patch makes the hardware event ring dequeue pointer be written only once per interrupt. Make the transfer event handler and port status event handler only write the software event ring dequeue pointer. Move the updating of the hardware event ring dequeue pointer into the interrupt function. Move the contents of xhci_set_hc_event_deq() into the interrupt handler. The interrupt handler must clear the event handler busy flag, so it might as well also write the dequeue pointer to the same register. This eliminates two 32-bit PCI reads and two 32-bit PCI writes. Reported-by: Andiry Xu <andiry.xu@amd.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Make xhci_handle_event() static.Sarah Sharp
xhci_handle_event() is now only called from within xhci-ring.c, so make it static. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Remove unnecessary reads of IRQ_PENDING register.Sarah Sharp
Remove a duplicate register read of the interrupt pending register from xhci_irq(). Also, remove waiting on the posted write of that register. The host will see it eventually. It will probably read the register itself before deciding whether to interrupt the system again, forcing the posted write to complete. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Performance - move xhci_work() into xhci_irq()Sarah Sharp
When we move xhci_work() into xhci_irq(), we don't need to read the operational register status field twice. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-10USB: xhci: Performance - move interrupt handlers into xhci-ring.cSarah Sharp
Most of the work for interrupt handling is done in xhci-ring.c, so it makes sense to move the functions that are first called when an interrupt happens (xhci_irq() or xhci_msi_irq()) into xhci-ring.c, so that the compiler can better optimize them. Shorten some lines to make it pass checkpatch. Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
