2010-05-10netfilter: nf_conntrack_proto: fix warning with CONFIG_PROVE_RCUPatrick McHardy
=================================================== [ INFO: suspicious rcu_dereference_check() usage. ] --------------------------------------------------- include/net/netfilter/nf_conntrack_l3proto.h:92 invoked rcu_dereference_check() without protection! other info that might help us debug this: rcu_scheduler_active = 1, debug_locks = 0 2 locks held by iptables/3197: #0: (sk_lock-AF_INET){+.+.+.}, at: [<ffffffff8149bd8c>] ip_setsockopt+0x7c/0xa0 #1: (&xt[i].mutex){+.+.+.}, at: [<ffffffff8148a5fe>] xt_find_table_lock+0x3e/0x110 stack backtrace: Pid: 3197, comm: iptables Not tainted 2.6.34-rc4 #2 Call Trace: [<ffffffff8105e2e8>] lockdep_rcu_dereference+0xb8/0xc0 [<ffffffff8147fb3b>] nf_ct_l3proto_module_put+0x6b/0x70 [<ffffffff8148d891>] state_mt_destroy+0x11/0x20 [<ffffffff814d3baf>] cleanup_match+0x2f/0x50 [<ffffffff814d3c63>] cleanup_entry+0x33/0x90 [<ffffffff814d5653>] ? __do_replace+0x1a3/0x210 [<ffffffff814d564c>] __do_replace+0x19c/0x210 [<ffffffff814d651a>] do_ipt_set_ctl+0x16a/0x1b0 [<ffffffff8147a610>] nf_sockopt+0x60/0xa0 ... The __nf_ct_l3proto_find() call doesn't actually need rcu read side protection since the caller holds a reference to the protocol. Use rcu_read_lock() anyways to avoid the warning. Kernel bugzilla #15781: https://bugzilla.kernel.org/show_bug.cgi?id=15781 Reported-by: Christian Casteyde <casteyde.christian@free.fr> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-05-01netfilter: nf_ct_h323: switch "incomplete TPKT" message to pr_debug()Patrick McHardy
The message might be falsely triggered by non-H.323 traffic on port 1720. Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-27netfilter: x_tables: rectify XT_FUNCTION_MAXNAMELEN usageJan Engelhardt
There has been quite a confusion in userspace about XT_FUNCTION_MAXNAMELEN; because struct xt_entry_match used MAX-1, userspace would have to do an awkward MAX-2 for maximum length checking (due to '\0'). This patch adds a new define that matches the definition of XT_TABLE_MAXNAMELEN - being the size of the actual struct member, not one off. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-23netfilter: nf_conntrack: extend with extra stat counterJesper Dangaard Brouer
I suspect an unfortunatly series of events occuring under a DDoS attack, in function __nf_conntrack_find() nf_contrack_core.c. Adding a stats counter to see if the search is restarted too often. Signed-off-by: Jesper Dangaard Brouer <hawk@comx.dk> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-22netfilter: ip_tables: convert pr_devel() to pr_debug()Patrick McHardy
We want to be able to use CONFIG_DYNAMIC_DEBUG in netfilter code, switch the few existing pr_devel() calls to pr_debug(). Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-21netfilter: x_tables: move sleeping allocation outside BH-disabled regionJan Engelhardt
The jumpstack allocation needs to be moved out of the critical region. Corrects this notice: BUG: sleeping function called from invalid context at mm/slub.c:1705 [ 428.295762] in_atomic(): 1, irqs_disabled(): 0, pid: 9111, name: iptables [ 428.295771] Pid: 9111, comm: iptables Not tainted 2.6.34-rc1 #2 [ 428.295776] Call Trace: [ 428.295791] [<c012138e>] __might_sleep+0xe5/0xed [ 428.295801] [<c019e8ca>] __kmalloc+0x92/0xfc [ 428.295825] [<f865b3bb>] ? xt_jumpstack_alloc+0x36/0xff [x_tables] Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-20netfilter: bridge-netfilter: fix refragmenting IP traffic encapsulated in ↵Bart De Schuymer
PPPoE traffic The MTU for IP traffic encapsulated inside PPPoE traffic is smaller than the MTU of the Ethernet device (1500). Connection tracking gathers all IP packets and sometimes will refragment them in ip_fragment(). We then need to subtract the length of the encapsulating header from the mtu used in ip_fragment(). The check in br_nf_dev_queue_xmit() which determines if ip_fragment() has to be called is also updated for the PPPoE-encapsulated packets. nf_bridge_copy_header() is also updated to make sure the PPPoE data length field has the correct value. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-20Merge branch 'master' of /repos/git/net-next-2.6Patrick McHardy
Conflicts: Documentation/feature-removal-schedule.txt net/ipv6/netfilter/ip6t_REJECT.c net/netfilter/xt_limit.c Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-20netfilter: xt_TEE: resolve oif using netdevice notifiersPatrick McHardy
Replace the runtime oif name resolving by netdevice notifier based resolving. When an oif is given, a netdevice notifier is registered to resolve the name on NETDEV_REGISTER or NETDEV_CHANGE and unresolve it again on NETDEV_UNREGISTER or NETDEV_CHANGE to a different name. Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-20net: emphasize rtnl lock required in call_netdevice_notifiersJiri Pirko
Since netdev_chain is guarded by rtnl_lock, ASSERT_RTNL should be present here to make sure that all callers of call_netdevice_notifiers does the locking properly. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20rps: consistent rxhashEric Dumazet
In case we compute a software skb->rxhash, we can generate a consistent hash : Its value will be the same in both flow directions. This helps some workloads, like conntracking, since the same state needs to be accessed in both directions. tbench + RFS + this patch gives better results than tbench with default kernel configuration (no RPS, no RFS) Also fixed some sparse warnings. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-20rps: cleanupsEric Dumazet
struct softnet_data holds many queues, so consistent use "sd" name instead of "queue" is better. Adds a rps_ipi_queued() helper to cleanup enqueue_to_backlog() Adds a _and_irq_disable suffix to net_rps_action() name, as David suggested. incr_input_queue_head() becomes input_queue_head_incr() Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19rps: static functionsEric Dumazet
store_rps_map() & store_rps_dev_flow_table_cnt() are static. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19rps: shortcut net_rps_action()Eric Dumazet
net_rps_action() is a bit expensive on NR_CPUS=64..4096 kernels, even if RPS is not active. Tom Herbert used two bitmasks to hold information needed to send IPI, but a single LIFO list seems more appropriate. Move all RPS logic into net_rps_action() to cleanup net_rx_action() code (remove two ifdefs) Move rps_remote_softirq_cpus into softnet_data to share its first cache line, filling an existing hole. In a future patch, we could call net_rps_action() from process_backlog() to make sure we send IPI before handling this cpu backlog. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: Date and versionVladislav Zolotarov
Set version to 1.52.53-1. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: Don't report link down if has been already downVladislav Zolotarov
Author: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Yaniv Rosner <yanivr@broadcom.com> Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: Rework power state handling codeVladislav Zolotarov
Move "don't shut down the power" logic into bnx2x_set_power_state() to make the code cleaner. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: use mask in test_registers() to avoid parity errorVladislav Zolotarov
Properly mask the value to be written to the register (according to the register size) during the self-test. Otherwise immediate parity error would be generated. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: Fixed MSI-X enabling flowVladislav Zolotarov
Try to enable less MSI-X vectors if initial request has failed. Author: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: Added new statisticsVladislav Zolotarov
Added total_mcast/bcast_pkts_transmitted statistics. Author: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Dmitry Kravkov <dmitry@broadcom.com> Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: White spacesVladislav Zolotarov
White spaces, code readability and prints. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: Protect code with NOMCPVladislav Zolotarov
Don't run code that can't be run if MCP is not present. This will prevent NULL pointer dereferencing. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: Increase DMAE max write size for 57711Vladislav Zolotarov
Increase DMAE max write size for 57711 to the maximum allowed value. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19bnx2x: Use VPD-R V0 entry to display firmware revisionVladislav Zolotarov
2010-04-19bnx2x: Parity errors handling for 57710 and 57711Vladislav Zolotarov
This patch introduces the parity errors handling code for 57710 and 57711 chips. HW is configured to stop all DMA transactions to the host and sending packets to the network once parity error is detected, which is meant to prevent silent data corruption. At the same time HW generates the attention interrupt to every function of the device where parity has been detected so that driver can start the recovery flow. The recovery is actually resetting the chip and restarting the driver on all active functions of the chip where the parity error has been reported. Signed-off-by: Vladislav Zolotarov <vladz@broadcom.com> Signed-off-by: Eilon Greenstein <eilong@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-19netfilter: xtables: remove old comments about reentrancyJan Engelhardt
2010-04-19netfilter: xt_TEE: have cloned packet travel through Xtables tooJan Engelhardt
Since Xtables is now reentrant/nestable, the cloned packet can also go through Xtables and be subject to rules itself. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-19netfilter: xtables: make ip_tables reentrantJan Engelhardt
Currently, the table traverser stores return addresses in the ruleset itself (struct ip6t_entry->comefrom). This has a well-known drawback: the jumpstack is overwritten on reentry, making it necessary for targets to return absolute verdicts. Also, the ruleset (which might be heavy memory-wise) needs to be replicated for each CPU that can possibly invoke ip6t_do_table. This patch decouples the jumpstack from struct ip6t_entry and instead puts it into xt_table_info. Not being restricted by 'comefrom' anymore, we can set up a stack as needed. By default, there is room allocated for two entries into the traverser. arp_tables is not touched though, because there is just one/two modules and further patches seek to collapse the table traverser anyhow. Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-19netfilter: xtables: inclusion of xt_TEEJan Engelhardt
xt_TEE can be used to clone and reroute a packet. This can for example be used to copy traffic at a router for logging purposes to another dedicated machine. References: http://www.gossamer-threads.com/lists/iptables/devel/68781 Signed-off-by: Jan Engelhardt <jengelh@medozas.de> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-18net: Introduce skb_orphan_try()Eric Dumazet
Transmitted skb might be attached to a socket and a destructor, for memory accounting purposes. Traditionally, this destructor is called at tx completion time, when skb is freed. When tx completion is performed by another cpu than the sender, this forces some cache lines to change ownership. XPS was an attempt to give tx completion to initial cpu. David idea is to call destructor right before giving skb to device (call to ndo_start_xmit()). Because device queues are usually small, orphaning skb before tx completion is not a big deal. Some drivers already do this, we could do it in upper level. There is one known exception to this early orphaning, called tx timestamping. It needs to keep a reference to socket until device can give a hardware or software timestamp. This patch adds a skb_orphan_try() helper, to centralize all exceptions to early orphaning in one spot, and use it in dev_hard_start_xmit(). "tbench 16" results on a Nehalem machine (2 X5570 @ 2.93GHz) before: Throughput 4428.9 MB/sec 16 procs after: Throughput 4448.14 MB/sec 16 procs UDP should get even better results, its destructor being more complex, since SOCK_USE_WRITE_QUEUE is not set (four atomic ops instead of one) Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-18net: remove time limit in process_backlog()Eric Dumazet
- There is no point to enforce a time limit in process_backlog(), since other napi instances dont follow same rule. We can exit after only one packet processed... The normal quota of 64 packets per napi instance should be the norm, and net_rx_action() already has its own time limit. Note : /proc/net/core/dev_weight can be used to tune this 64 default value. - Use DEFINE_PER_CPU_ALIGNED for softnet_data definition. Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-17rps: rps_sock_flow_table is mostly readEric Dumazet
2010-04-16rfs: Receive Flow SteeringTom Herbert
This patch implements receive flow steering (RFS). RFS steers received packets for layer 3 and 4 processing to the CPU where the application for the corresponding flow is running. RFS is an extension of Receive Packet Steering (RPS). The basic idea of RFS is that when an application calls recvmsg (or sendmsg) the application's running CPU is stored in a hash table that is indexed by the connection's rxhash which is stored in the socket structure. The rxhash is passed in skb's received on the connection from netif_receive_skb. For each received packet, the associated rxhash is used to look up the CPU in the hash table, if a valid CPU is set then the packet is steered to that CPU using the RPS mechanisms. The convolution of the simple approach is that it would potentially allow OOO packets. If threads are thrashing around CPUs or multiple threads are trying to read from the same sockets, a quickly changing CPU value in the hash table could cause rampant OOO packets-- we consider this a non-starter. To avoid OOO packets, this solution implements two types of hash tables: rps_sock_flow_table and rps_dev_flow_table. rps_sock_table is a global hash table. Each entry is just a CPU number and it is populated in recvmsg and sendmsg as described above. This table contains the "desired" CPUs for flows. rps_dev_flow_table is specific to each device queue. Each entry contains a CPU and a tail queue counter. The CPU is the "current" CPU for a matching flow. The tail queue counter holds the value of a tail queue counter for the associated CPU's backlog queue at the time of last enqueue for a flow matching the entry. Each backlog queue has a queue head counter which is incremented on dequeue, and so a queue tail counter is computed as queue head count + queue length. When a packet is enqueued on a backlog queue, the current value of the queue tail counter is saved in the hash entry of the rps_dev_flow_table. And now the trick: when selecting the CPU for RPS (get_rps_cpu) the rps_sock_flow table and the rps_dev_flow table for the RX queue are consulted. When the desired CPU for the flow (found in the rps_sock_flow table) does not match the current CPU (found in the rps_dev_flow table), the current CPU is changed to the desired CPU if one of the following is true: - The current CPU is unset (equal to RPS_NO_CPU) - Current CPU is offline - The current CPU's queue head counter >= queue tail counter in the rps_dev_flow table. This checks if the queue tail has advanced beyond the last packet that was enqueued using this table entry. This guarantees that all packets queued using this entry have been dequeued, thus preserving in order delivery. Making each queue have its own rps_dev_flow table has two advantages: 1) the tail queue counters will be written on each receive, so keeping the table local to interrupting CPU s good for locality. 2) this allows lockless access to the table-- the CPU number and queue tail counter need to be accessed together under mutual exclusion from netif_receive_skb, we assume that this is only called from device napi_poll which is non-reentrant. This patch implements RFS for TCP and connected UDP sockets. It should be usable for other flow oriented protocols. There are two configuration parameters for RFS. The "rps_flow_entries" kernel init parameter sets the number of entries in the rps_sock_flow_table, the per rxqueue sysfs entry "rps_flow_cnt" contains the number of entries in the rps_dev_flow table for the rxqueue. Both are rounded to power of two. The obvious benefit of RFS (over just RPS) is that it achieves CPU locality between the receive processing for a flow and the applications processing; this can result in increased performance (higher pps, lower latency). The benefits of RFS are dependent on cache hierarchy, application load, and other factors. On simple benchmarks, we don't necessarily see improvement and sometimes see degradation. However, for more complex benchmarks and for applications where cache pressure is much higher this technique seems to perform very well. Below are some benchmark results which show the potential benfit of this patch. The netperf test has 500 instances of netperf TCP_RR test with 1 byte req. and resp. The RPC test is an request/response test similar in structure to netperf RR test ith 100 threads on each host, but does more work in userspace that netperf. e1000e on 8 core Intel No RFS or RPS 104K tps at 30% CPU No RFS (best RPS config): 290K tps at 63% CPU RFS 303K tps at 61% CPU RPC test tps CPU% 50/90/99% usec latency Latency StdDev No RFS/RPS 103K 48% 757/900/3185 4472.35 RPS only: 174K 73% 415/993/2468 491.66 RFS 223K 73% 379/651/1382 315.61 Signed-off-by: Tom Herbert <therbert@google.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15ipv6: fix the comment of ip6_xmit()Shan Wei
ip6_xmit() is used by upper transport protocol. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15net: replace ipfragok with skb->local_dfShan Wei
As Herbert Xu said: we should be able to simply replace ipfragok with skb->local_df. commit f88037(sctp: Drop ipfargok in sctp_xmit function) has droped ipfragok and set local_df value properly. The patch kills the ipfragok parameter of .queue_xmit(). Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15ipv6: cancel to setting local_df in ip6_xmit()Shan Wei
commit f88037(sctp: Drop ipfargok in sctp_xmit function) has droped ipfragok and set local_df value properly. So the change of commit 77e2f1(ipv6: Fix ip6_xmit to send fragments if ipfragok is true) is not needed. So the patch remove them. Signed-off-by: Shan Wei <shanwei@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15net/l2tp/l2tp_debugfs.c: Convert NIPQUAD to %pI4Joe Perches
Signed-off-by: Joe Perches <joe@perches.com> Acked-by: James Chapman <jchapman@katalix.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15Merge branch 'for-davem' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
2010-04-15Merge branch 'master' of ↵David S. Miller
git://git.kernel.org/pub/scm/linux/kernel/git/kaber/ipmr-2.6
2010-04-15Merge branch 'master' of ↵John W. Linville
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem Conflicts: Documentation/feature-removal-schedule.txt drivers/net/wireless/ath/ath5k/phy.c drivers/net/wireless/wl12xx/wl1271_main.c
2010-04-15netfilter: ipt_LOG/ip6t_LOG: use more appropriate log level as defaultPatrick McHardy
Use KERN_NOTICE instead of KERN_EMERG by default. This only affects kernel internal logging (like conntrack), user-specified logging rules contain a seperate log level. Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15ipv4: ipmr: fix NULL pointer deref during unres queue destructionPatrick McHardy
Fix an oversight in ipmr_destroy_unres() - the net pointer is unconditionally initialized to NULL, resulting in a NULL pointer dereference later on. Fix by adding a net pointer to struct mr_table and using it in ipmr_destroy_unres(). Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15ipv4: ipmr: fix invalid cache resolving when adding a non-matching entryPatrick McHardy
The patch to convert struct mfc_cache to list_heads (ipv4: ipmr: convert struct mfc_cache to struct list_head) introduced a bug when adding new cache entries that don't match any unresolved entries. The unres queue is searched for a matching entry, which is then resolved. When no matching entry is present, the iterator points to the head of the list, but is treated as a matching entry. Use a seperate variable to indicate that a matching entry was found. Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15ipv4: ipmr: fix IP_MROUTE_MULTIPLE_TABLES Kconfig dependenciesPatrick McHardy
IP_MROUTE_MULTIPLE_TABLES should depend on IP_MROUTE. Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15netfilter: ipv6: move xfrm_lookup at end of ip6_route_me_harderUlrich Weber
xfrm_lookup should be called after ip6_route_output skb_dst_set, otherwise skb_dst_set of xfrm_lookup is pointless Signed-off-by: Ulrich Weber <uweber@astaro.com> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15netfilter: bridge-netfilter: Fix MAC header handling with IP DNATBart De Schuymer
- fix IP DNAT on vlan- or pppoe-encapsulated traffic: The functions neigh_hh_output() or dst->neighbour->output() overwrite the complete Ethernet header, although we only need the destination MAC address. For encapsulated packets, they ended up overwriting the encapsulating header. The new code copies the Ethernet source MAC address and protocol number before calling dst->neighbour->output(). The Ethernet source MAC and protocol number are copied back in place in br_nf_pre_routing_finish_bridge_slow(). This also makes the IP DNAT more transparent because in the old scheme the source MAC of the bridge was copied into the source address in the Ethernet header. We also let skb->protocol equal ETH_P_IP resp. ETH_P_IPV6 during the execution of the PF_INET resp. PF_INET6 hooks. - Speed up IP DNAT by calling neigh_hh_bridge() instead of neigh_hh_output(): if dst->hh is available, we already know the MAC address so we can just copy it. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15netfilter: bridge-netfilter: simplify IP DNATBart De Schuymer
Remove br_netfilter.c::br_nf_local_out(). The function br_nf_local_out() was needed because the PF_BRIDGE::LOCAL_OUT hook could be called when IP DNAT happens on to-be-bridged traffic. The new scheme eliminates this mess. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Patrick McHardy <kaber@trash.net>
2010-04-15net: CONFIG_SMP should be CONFIG_RPSChangli Gao
Signed-off-by: Changli Gao <xiaosuo@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-15net: netif_rx() must disable preemptionEric Dumazet
Eric Paris reported netif_rx() is calling smp_processor_id() from preemptible context, in particular when caller is ip_dev_loopback_xmit(). RPS commit added this smp_processor_id() call, this patch makes sure preemption is disabled. rps_get_cpus() wants rcu_read_lock() anyway, we can dot it a bit earlier. Reported-by: Eric Paris <eparis@redhat.com> Signed-off-by: Eric Dumazet <eric.dumazet@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-04-14Merge branch 'vhost' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostDavid S. Miller
