2007-02-14[PATCH] Scheduled removal of SA_xxx interrupt flags fixupsThomas Gleixner
The obsolete SA_xxx interrupt flags have been used despite the scheduled removal. Fixup the remaining users. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: "Luck, Tony" <tony.luck@intel.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Cc: Jeff Garzik <jeff@garzik.org> Cc: Wim Van Sebroeck <wim@iguana.be> Cc: Roland Dreier <rolandd@cisco.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: James Bottomley <James.Bottomley@steeleye.com> Cc: Greg KH <greg@kroah.com> Cc: Dave Airlie <airlied@linux.ie> Cc: James Simmons <jsimmons@infradead.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] OSS: replace kmalloc()+memset() combos with kzalloc()Robert P. J. Day
Replace kmalloc() + memset() pairs with the appropriate kzalloc() calls. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] knfsd: allow the server to provide a gid list when using AUTH_UNIX ↵NeilBrown
authentication AUTH_UNIX authentication (the standard with NFS) has a limit of 16 groups ids. This causes problems for people in more than 16 groups. So allow the server to map a uid into a list of group ids based on local knowledge rather depending on the (possibly truncated) list from the client. If there is no process on the server responding to upcalls, the gidlist in the request will still be used. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] knfsd: add some new fsid typesNeilBrown
Add support for using a filesystem UUID to identify and export point in the filehandle. For NFSv2, this UUID is xor-ed down to 4 or 8 bytes so that it doesn't take up too much room. For NFSv3+, we use the full 16 bytes, and possibly also a 64bit inode number for exports beneath the root of a filesystem. When generating an fsid to return in 'stat' information, use the UUID (hashed down to size) if it is available and a small 'fsid' was not specifically provided. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] knfsd: tidy up choice of filesystem-identifier when creating a ↵NeilBrown
filehandle If we are using the same version/fsid as a current filehandle, then there is no need to verify the the numbers are valid for this export, and they must be (we used them to find this export). This allows us to simplify the fsid selection code. Also change "ref_fh_version" and "ref_fh_fsid_type" to "version" and "fsid_type", as the important thing isn't that they are the version/type of the reference filehandle, but they are the chosen type for the new filehandle. And tidy up some indenting. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] knfsd: fix return value for writes to some files in 'nfsd' filesystemNeilBrown
Most files in the 'nfsd' filesystem are transactional. When you write, a reply is generated that can be read back only on the same 'file'. If the reply has zero length, the 'write' will incorrectly return a value of '0' instead of the length that was written. This causes 'rpc.nfsd' to give an annoying warning. This patch fixes the test. Signed-off-by: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] SPI: atmel_spi driverHaavard Skinnemoen
Driver for the Atmel on-chip SPI master controller. Tested primarily on AVR32/AT32AP7000/ATSTK1000 using mtd_dataflash and the jffs2 filesystem. Should also work fine on various AT91 ARM-based chips like AT91SAM926x and AT91RM9200. Hardware documentation can be found in the AT32AP7000 data sheet, or its AT91 siblings, which can be downloaded from http://www.atmel.com/dyn/products/datasheets.asp?family_id=682 Signed-off-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] PNX8550 UART driverVitaly Wool
Add UART support for PNX8330/8550/8950 Philips MIPS-based SoCs. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] fix PNX8550 serial breakageVitaly Wool
Fix the serial header breakage for the PNX8550 MIPS platform. Signed-off-by: Vitaly Wool <vitalywool@gmail.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] serial: replace kmalloc+memset with kzallocBurman Yan
2007-02-14[PATCH] serial: make sure UART is powered up when dumping MCTRL statusGeorge G. Davis
Since serial devices are powered down when not in use and some of those devices cannot be accessed when powered down, we need to enable power around calls to get_mcrtl() when dumping port state via uart_line_info(). This resolves hangs observed on some machines while reading serial device registers when a port is powered off. Signed-off-by: George G. Davis <gdavis@mvista.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] serial: trivial code flow simplificationBjorn Helgaas
Return failure immediately, so we don't have to test it twice. Signed-off-by: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] 8250 UART backup timerAlex Williamson
The patch below works around a minor bug found in the UART of the remote management card used in many HP ia64 and parisc servers (aka the Diva UARTs). The problem is that the UART does not reassert the THRE interrupt if it has been previously cleared and the IIR THRI bit is re-enabled. This can produce a very annoying failure mode when used as a serial console, allowing a boot/reboot to hang indefinitely until an RX interrupt kicks it into working again (ie. an unattended reboot could stall). To solve this problem, a backup timer is introduced that runs alongside the standard interrupt driven mechanism. This timer wakes up periodically, checks for a hang condition and gets characters moving again. This backup mechanism is only enabled if the UART is detected as having this problem, so systems without these UARTs will have no additional overhead. This version of the patch incorporates previous comments from Pavel and removes races in the bug detection code. The test is now done before the irq linking to prevent races with interrupt handler clearing the THRE interrupt. Short delays and syncs are also added to ensure the device is able to update register state before the result is tested. Aristeu says: this was tested on the following HP machines and solved the problem: rx2600, rx2620, rx1600 and rx1620s. hpa says: I have seen this same bug in soft UART IP from "a major vendor." Signed-off-by: Alex Williamson <alex.williamson@hp.com> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Russell King <rmk@arm.linux.org.uk> Acked-by: Aristeu Sergio Rozanski Filho <aris@cathedrallabs.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: hide empty list itemsCyrill V. Gorcunov
This patch fixes showing empty config list items if "Option/Show All Options" is turned on. For example empty items appears on list of 'Block Layer' menu. Signed-off-by: Cyrill V. Gorcunov <gorcunov@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] new toplevel target: headers_check_allMike Frysinger
Add new headers_check_all target for checking all arches in one go. Useful for distros (and people with too much time on their hands) that support a ton of architectures, headers_check_all is to headers_check as headers_install_all is to headers_install Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Kbuild: Remove references to deprecated "prepare-all" target from ↵Robert P. J. Day
Makefile Remove references to the deprecated "make prepare-all" target from the top-level Makefile; use just "make prepare" instead. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Sam Ravnborg <sam@ravnborg.org> Acked-by: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: Back button behaviour normalizationCyrill V. Gorcunov
Do "Back" button behaviour normalization so it is enabled starting from second-level menu only. Signed-off-by: Cyrill V. Gorcunov <gorcunov@gmail.com> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: fix showing help info on failed searchCyrill V. Gorcunov
qconf does not clear help text in search window if previous search has been failed. Signed-off-by: Cyrill V. Gorcunov <gorcunov@mail.ru> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: relocate Search CommandShlomi Fish
Relocate the qconf search command to the "Edit"->"Find" menu option. This is per the discussion on my qconf search dialog patch. Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] qconf: immediately update integer and string values in xconfig displayKarsten Wiese
In xconfig's display integer and string values are also shown as part of the config item's descriptive text. This patch updates the descriptive text, when the corresponding value has been changed. Fix for http://bugzilla.kernel.org/show_bug.cgi?id=7744 Take2 uses updateList() so config values dependending on the changed value see the change. Signed-off-by: Karsten Wiese <fzu@wemgehoertderstaat.de> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] add .mailmap for proper git-shortlog outputNicolas Pitre
This list was built into the git-shortlog tool and has been removed in the latest version. It should be maintained separately so this is what this patch does. A couple more entries were added to the original list as well. Signed-off-by: Nicolas Pitre <nico@cam.org> Acked-by: Junio C Hamano <junkio@cox.net> Cc: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] Make mkcompile_h use LANG=C and LC_ALL=C for $CC -vs situert
Fix a minor bug in mkcompile_h. As one can see, the current locale is used while getting the version of gcc. This produces problems when a locale other than C or en_US is used. As an example, my /proc/version contains Turkish characters in iso-8859-9 encoding. This patch fixes this issue by making sure that the C locale is used to get gcc's version. Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] search a little harder for mkimageMike Frysinger
Check to see if `${CROSS_COMPILE}mkimage` exists and if not, fall back to the standard `mkimage` The Blackfin toolchain includes mkimage, but we dont want to namespace collide with any of the user's system setup, so we prefix it with our toolchain name. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Oleg Verych <olecom@flower.upol.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-14[PATCH] ia64: fix noncoherent DMA API so devres buildsRoland Dreier
On ia64, drivers/base/dma-mapping.c doesn't build because it calls dma_alloc_noncoherent() and dma_free_noncoherent(), which appear to be terminally broken; the calls end up generating errors like drivers/base/dma-mapping.c: In function 'dmam_noncoherent_release': drivers/base/dma-mapping.c:32: error: 'struct ia64_machine_vector' has no member named 'platform_dma_free_coherent' because the multiple levels of macro expansion in <asm/dma-mapping.h> and <asm/machvec.h> end up turning a call to dma_free_noncoherent() into ia64_mv.platform_dma_free_coherent (instead of the intended ia64_mv.dma_free_coherent). This patch fixes this by converting dma_{alloc,free}_noncoherent() into inline functions that call the corresponding coherent functions, instead of trying to do this with macros. Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Tony Luck <tony.luck@intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13Merge branch 'master' of /home/trondmy/kernel/linux-2.6/Trond Myklebust
2007-02-13Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband: IB/mthca: Always fill MTTs from CPU IB/mthca: Merge MR and FMR space on 64-bit systems IB/mthca: Fix access to MTT and MPT tables on non-cache-coherent CPUs IB/mthca: Give reserved MTTs a separate cache line IB/mthca: Fix reserved MTTs calculation on mem-free HCAs RDMA/cxgb3: Add driver for Chelsio T3 RNIC IB: Remove redundant "_wq" from workqueue names RDMA/cma: Increment port number after close to avoid re-use IB/ehca: Fix memleak on module unloading IB/mthca: Work around gcc bug on sparc64 IPoIB: Connected mode experimental support IB/core: Use ARRAY_SIZE macro for mandatory_table IB/mthca: Use correct structure size in call to memset()
2007-02-13Merge master.kernel.org:/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] on reconnect to Samba - reset the unix capabilities [CIFS] Allow update of EOF on remote extend of file [CIFS] POSIX CIFS Extensions (continued) - POSIX Open [CIFS] Additional POSIX CIFS Extensions infolevels
2007-02-14[CIFS] on reconnect to Samba - reset the unix capabilitiesSteve French
After temporary server or network failure and reconneciton, we were not resending the unix capabilities via SetFSInfo - which confused Samba posix byte range locking code. Discovered by jra Signed-off-by: Steve French <sfrench@us.ibm.com>
2007-02-13Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [IPSEC]: Fix the address family to refer encap_family [IPSEC]: changing API of xfrm6_tunnel_register [IPSEC]: make sit use the xfrm4_tunnel_register [IPSEC]: Changing API of xfrm4_tunnel_register. [TCP]: Prevent pseudo garbage in SYN's advertized window [NET_SCHED]: sch_hfsc: replace ASSERT macro by WARN_ON [BRIDGE] br_if: Fix oops in port_carrier_check [NETFILTER]: Clear GSO bits for TCP reset packet [TG3]: Update copyright, version, and reldate. [TG3]: Add some tx timeout debug messages. [TG3]: Use constant for PHY register 0x1e. [TG3]: Power down 5704 serdes transceiver when shutting down. [TG3]: 5906 doesn't need to switch to slower clock. [TG3]: 5722/5756 don't need PHY jitter workaround. [TG3]: Use lower DMA watermark for 5703. [TG3]: Save MSI state before suspend. [XFRM]: Fix IPv4 tunnel mode decapsulation with IPV6=n [IPV6] HASHTABLES: Use appropriate seed for caluculating ehash index.
2007-02-13Merge master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpcLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc: (61 commits) [POWERPC] Use udbg_early_init() on ppc32 [POWERPC] Open Firmware serial port driver [POWERPC] Move MPIC smp routines into mpic.c [POWERPC] Cleanup pseries kexec code [POWERPC] Cleanup pseries smp initialisation code [POWERPC] Consolidate pseries platform header files into pseries.h [POWERPC] 85xx: Drop use of SYNC macro in head_fsl_booke.S [POWERPC] cell: pm_rtas_activat_signals routine cleanup [POWERPC] cell: PPU Oprofile cleanup patch [POWERPC] spufs: avoid accessing kernel memory through mmapped /mem node [POWERPC] spu sched: static timeslicing for SCHED_RR contexts [POWERPC] spu sched: use DECLARE_BITMAP [POWERPC] spu sched: forced preemption at execution [POWERPC] spu sched: update some comments [POWERPC] spu sched: simplity spu_remove_from_active_list [POWERPC] spufs: optimize spu_run [POWERPC] spufs: runqueue simplification [POWERPC] spufs: move prio to spu_context [POWERPC] spufs: state_mutex cleanup [POWERPC] spufs: simplify state_mutex ...
2007-02-14[POWERPC] Use udbg_early_init() on ppc32David Gibson
udbg_early_init() is a function used on 64 bit systems, which initializes whichever early udbg backend is configured. This function is not called on 32-bit, however if btext early debug is enabled it does have an explicit, inline, #ifdef-ed assignment performing analagous initialization. This patch makes things more uniform by folding the btext initialization as an option into udbg_early_init() and calling that from the 32-bit setup path. Signed-off-by: David Gibson <dwg@au1.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Open Firmware serial port driverArnd Bergmann
This can be used for serial ports that are connected to an OF platform bus but are not autodetected by the lecacy serial support. It will automatically take over devices that come from the legacy serial detection, which usually is only one device. In some cases, rtas may be set up to use the serial port in the firmware, which allows easier debugging before probing the serial ports. In this case, the "used-by-rtas" property must be set by the firmware. This patch also adds code to the legacy serial driver to check for this. Signed-off-by: Arnd Bergmann <arnd.bergmann@de.ibm.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Move MPIC smp routines into mpic.cMichael Ellerman
Move a couple of MPIC smp routines into mpic.c, they're inside an SMP block in mpic.c - so they're still only built for SMP. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Cleanup pseries kexec codeMichael Ellerman
Move all the pseries kexec code into one file, platforms/pseries/kexec.c Provide helpers for setting up ppc_md.kexec_cpu_down, so that we don't have to have #ifdef CONFIG_KEXEC in setup.c Move the initialisation of the ppc_md kexec callbacks into an init routine. This is well and truly early enough to cause no change in behaviour, we can't kexec until userspace has given us a kernel to kexec into. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Cleanup pseries smp initialisation codeMichael Ellerman
Move some extern declarations from setup.c into the new pseries.h. While we're at it, provide dummy implementations for !SMP, to avoid cluttering the C file with more #ifdefs. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14[POWERPC] Consolidate pseries platform header files into pseries.hMichael Ellerman
Following the example of platforms/pasemi, consolidate a couple of tiny header files in platforms/pseries into pseries.h. This gives us a convenient place to put things that need to be available to the platform code, but not public. And hopefully will help people resist the temptation of sticking externs in C files. Signed-off-by: Michael Ellerman <michael@ellerman.id.au> Signed-off-by: Paul Mackerras <paulus@samba.org>
2007-02-14Merge branch 'cell-merge' of ↵Paul Mackerras
git+ssh://master.kernel.org/pub/scm/linux/kernel/git/arnd/cell-2.6
2007-02-13Merge branch 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6Linus Torvalds
* 'i2c-for-linus' of git://jdelvare.pck.nerim.net/jdelvare-2.6: i2c: Stop using i2c_adapter.class_dev i2c: Remove the warning on missing adapter device i2c: Declare more i2c_adapter parent devices i2c: PA Semi SMBus driver i2c-amd8111: Proposed cleanups i2c-parport: Add support for One For All remote JP1 interface i2c-viapro: Add support for the VIA CX700 south bridge i2c: Add IDs to adapters i2c: Update the list of bus IDs i2c: Add driver suspend/resume/shutdown support i2c: completion header cleanups i2c-i801: Document the SMBus unhiding quirk i2c-i801: Spelling fix i2c: Fix typo in SMBus Write Word Data description i2c-piix4: Add support for the ATI SB600 i2c-nforce2: Drop unused reference to pci_dev i2c/vt8231: Remove superfluous initialization i2c-ali1563: Fix device initialization i2c-ali1563: Improve the status messages
2007-02-13Merge branch 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linusLinus Torvalds
* 'upstream' of git://ftp.linux-mips.org/pub/scm/upstream-linus: [MIPS] Fix sigset_t endianess swapping issues in 32-bit compat code. [MIPS] Fix uniprocessor Sibyte builds. [MIPS] Make entry.S a little more readable. [MIPS] Remove stray instruction from __get_user_asm_ll32. [MIPS] 32-bit: Fix warning about cast for fetching pointer from userspace. [MIPS] DECstation: Fix irq handling [MIPS] signals: make common _BLOCKABLE macro [MIPS] signal: Move sigframe definition for native O32/N64 into signal.c [MIPS] signal: Move {restore,setup}_sigcontext prototypes to their user [MIPS] signal: Fix warnings in o32 compat code. [MIPS] IP27: Enable N32 support in defconfig. Revert "[MIPS] Fix warning in get_user when fetching pointer object from userspace." [MIPS] Don't claim we support dma_declare_coherent_memory - we don't. [MIPS] Unify dma-{coherent,noncoherent.ip27,ip32} [MIPS] Improve branch prediction in ll/sc atomic operations.
2007-02-13Merge master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: (23 commits) [WATCHDOG] timers cleanup [WATCHDOG] ib700wdt.c - convert to platform_device part 2 [WATCHDOG] ib700wdt.c - convert to platform_device [WATCHDOG] ib700wdt.c spinlock/WDIOC_SETOPTIONS changes [WATCHDOG] ib700wdt.c small clean-up's [WATCHDOG] ib700wdt.c clean-up init and exit routines [WATCHDOG] ib700_wdt.c stop + set_heartbeat operations [WATCHDOG] show default value for nowayout in module parameter [WATCHDOG] advantechwdt.c - convert to platform_device part 2 [WATCHDOG] advantechwdt.c - convert to platform_device [WATCHDOG] advantechwdt.c - move set_heartbeat to a seperate function [WATCHDOG] advantechwdt.c - cleanup before platform_device patches [WATCHDOG] acquirewdt.c - convert to platform_device part 2 [WATCHDOG] acquirewdt.c - convert to platform_device [WATCHDOG] acquirewdt.c - clean before platform_device patches [WATCHDOG] pcwd_usb.c - get heartbeat from dip switches [WATCHDOG] pcwd.c - e-mail adres update [WATCHDOG] pcwd_usb.c - get heartbeat from dip switches [WATCHDOG] pcwd_usb.c - document includes [WATCHDOG] pcwd_pci.c - spinlock fixes ...
2007-02-13[PATCH] Fix SAK_work workqueue initialization.Eric W. Biederman
Somewhere in the rewrite of the work queues my cleanup of SAK handling got broken. Maybe I didn't retest it properly or possibly the API was changing so fast I missed something. Regardless currently triggering a SAK now generates an ugly BUG_ON and kills the kernel. Thanks to Alexey Dobriyan <adobriyan@openvz.org> for spotting this. This modifies the use of SAK_work to initialize it when the data structure it resides in is initialized, and to simply call schedule_work when we need to generate a SAK. I update both data structures that have a SAK_work member for consistency. All of the old PREPARE_WORK calls that are now gone. If we call schedule_work again before it has processed it has generated the first SAK it will simply ignore the duplicate schedule_work request. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-13[MIPS] Fix sigset_t endianess swapping issues in 32-bit compat code.Ralf Baechle
2007-02-13[MIPS] Fix uniprocessor Sibyte builds.Andrew Sharp
Signed-off-by: Andrew Sharp <tigerand@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] Make entry.S a little more readable.Franck Bui-Huu
When CONFIG_PREEMPT is not set, it also moves one branch instruction from ret_from_irq() to ret_from_exception(). Therefore we favour the return from irq case which should be more common than the other one. Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Acked-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] Remove stray instruction from __get_user_asm_ll32.Ralf Baechle
This did result in double clearing of the error return value on success only but should make a meassurable overhead for sigreturn. Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] 32-bit: Fix warning about cast for fetching pointer from userspace.Ralf Baechle
2007-02-13[MIPS] DECstation: Fix irq handlingAtsushi Nemoto
When I post a patch (commit f431baa55abf8adeed0c718b51deacbc151f58f1), I just tried to not change behavior of existing codes, but it seems dec/int-handler.S had been broken since its previous commit 937a801576f954bd030d7c4a5a94571710d87c0b. The caller of plat_irq_dispatch do setup/restore TI_REGS($28), so dec's plat_irq_dispatch should not do it, and there is no need to adjust RA. Signed-off-by: Atsushi Nemoto <anemo@mba.ocn.ne.jp> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] signals: make common _BLOCKABLE macroFranck Bui-Huu
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Ralf Baechle <ralf@linux-mips.org>
2007-02-13[MIPS] signal: Move sigframe definition for native O32/N64 into signal.cRalf Baechle
