Since now all the xxx_frag_kill functions now work
with the generic inet_frag_queue data type, this can
be moved into a common place.
The xxx_unlink() code is moved as well.
Signed-off-by: Pavel Emelyanov <xemul@openvz.org>
Some sysctl variables are used to tune the frag queues
management and it will be useful to work with them in
a common way in the future, so move them into one
structure, moreover they are the same for all the frag
management codes.
I don't place them in the existing inet_frags object,
introduced in the previous patch for two reasons:
1. to keep them in the __read_mostly section;
2. not to export the whole inet_frags objects outside.
There are some objects that are common in all the places
which are used to keep track of frag queues, they are:
* hash table
* LRU list
* rw lock
* rnd number for hash function
* the number of queues
* the amount of memory occupied by queues
* secret timer
Move all this stuff into one structure (struct inet_frags)
to make it possible use them uniformly in the future. Like
with the previous patch this mostly consists of hunks like
- write_lock(&ipfrag_lock);
+ write_lock(&ip4_frags.lock);
To address the issue with exporting the number of queues and
the amount of memory occupied by queues outside the .c file
they are declared in, I introduce a couple of helpers.
Introduce the struct inet_frag_queue in include/net/inet_frag.h
file and place there all the common fields from three structs:
* struct ipq in ipv4/ip_fragment.c
* struct nf_ct_frag6_queue in nf_conntrack_reasm.c
* struct frag_queue in ipv6/reassembly.c
After this, replace these fields on appropriate structures with
this structure instance and fix the users to use correct names
i.e. hunks like
- atomic_dec(&fq->refcnt);
+ atomic_dec(&fq->q.refcnt);
(these occupy most of the patch)
A performance regression was introduced by the following commit:
commit ee6a99b539a50b4e9398938a0a6d37f8bf911550
Author: Michael Chan <mchan@broadcom.com>
Date: Wed Jul 18 21:49:10 2007 -0700
[TG3]: Fix msi issue with kexec/kdump.
In making that change, the PCI latency timer and cache line size
registers were not restored after chip reset. On the 5705, the
latency timer gets reset to 0 during chip reset and this causes
very poor performance.
Update version to 3.84.
Signed-off-by: Michael Chan <mchan@broadcom.com>
Signed-off-by: Karsten Keil <kkeil@suse.de>
Signed-off-by: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Uninline netfilter okfns for those cases where gcc can generate tail-calls.
Before:
8994153 1016524 524652 10535329 a0c1a1 vmlinux
After:
8992761 1016524 524652 10533937 a0bc31 vmlinux
-1392
All cases have been verified to generate tail-calls with and without netfilter.
Now that we don't pass double skb pointers to nf_hook_slow anymore, gcc
can generate tail calls for some of the netfilter hook okfn invocations,
so there is no need to inline the functions anymore. This caused huge
code bloat since we ended up with one inlined version and one out-of-line
version since we pass the address to nf_hook_slow.
Before:
8997385 1016524 524652 10538561 a0ce41 vmlinux
After:
8994009 1016524 524652 10535185 a0c111 vmlinux
-3376
netfilter. The okfns in ipmr and xfrm4_input still remain inline because
gcc can't generate tail-calls for them.
TCP packets all have writable heads, that is, even though it's cloned, it is
writable up to the end of the TCP header. This patch makes skb_checksum_help
aware of this fact by using skb_clone_writable and avoiding a copy for TCP.
I've also modified the BUG_ON tests to be unsigned. The only case where this
makes a difference is if csum_start points to a location before skb->data.
Since skb->data should always include the header where the checksum field
is (and all currently callers adhere to that), this change is safe and may
uncover bugs later.
I got confused by the dual nature of the off variable in the
function pskb_expand_head. The csum_start offset should use
nhead instead of off which can change depending on whether we
are using offsets or pointers.
By the time we get to that switch by PHY type, we have 8bit
value. No need to keep it in u64 when u8 would do.
The Coverity checker spotted that we'll leak the storage allocated
to 'listeners' in netlink_kernel_create() when the
if (!nl_table[unit].registered)
check is false.
This patch avoids the leak.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
Acked-by: "Eric W. Biederman" <ebiederm@xmission.com>
The Coverity checker spotted that we have already oops'ed if "dst" was
NULL.
Since "dst" being NULL doesn't seem to be possible at this point this
patch removes the NULL check.
Acked-by: Masahide NAKAMURA <nakam@linux-ipv6.org>
Acked-by: Noriaki TAKAMIYA <takamiya@po.ntts.co.jp>
Noticed by Coverity checker and reported by Adrian Bunk.
This patch replaces unnecessary uses of skb_copy by pskb_expand_head
on the IPv6 input path.
This allows us to remove the double pointers later.
This patch implements the same change taht was done to ip_defrag. It
makes ipv6_frag_rcv return the last packet received of a train of fragments
rather than the head of that sequence.
This allows us to get rid of the sk_buff ** argument later.
With all the users of the double pointers removed, this patch mops up by
finally replacing all occurances of sk_buff ** in the netfilter API by
sk_buff *.
This patch replaces unnecessary uses of skb_copy, pskb_copy and
skb_realloc_headroom by functions such as skb_make_writable and
pskb_expand_head.
This patch removes the IPVS-specific version of skb_make_writable and
replaces it with the netfilter one.
Now that all callers of netfilter can guarantee that the skb is not shared,
we no longer have to copy the skb in skb_make_writable.
Due to the special location of the bridging hook, it should never see a
shared packet anyway (certainly not with any in-kernel code). So it
makes sense to unshare the skb there if necessary as that will greatly
simplify the code below it (in particular, netfilter).
As it is we always invoke pt_prev before ing_filter, even if there are no
ingress filters attached. This can cause unnecessary cloning in pt_prev.
This patch changes it so that we only invoke pt_prev if there are ingress
filters attached.
Now that ip_frag always returns the packet given to it on input, we can
change it to return an integer indicating error instead. This patch does
that and updates all its callers accordingly.
This patch is a bit of a hack. However it is worth it if you consider that
this is the only reason why we have to carry around the struct sk_buff **
pointers in netfilter.
It makes ip_defrag always return the packet that was given to it on input.
It does this by cloning the packet and replacing its original contents with
the head fragment if necessary.
This patch creates a new function skb_morph that's just like skb_clone
except that it lets user provide the spare skb that will be overwritten
by the one that's to be cloned.
This will be used by IP fragment reassembly so that we get back the same
skb that went in last (rather than the head skb that we get now which
requires us to carry around double pointers all over the place).
This patch creates a new function __copy_skb_header to merge the common
code between copy_skb_header and skb_clone. Having two functions which
are largely the same is a source of wasted labour as well as confusion.
In fact the tc_verd stuff is almost certainly a bug since it's treated
differently in skb_clone compared to the callers of copy_skb_header
(skb_copy/pskb_copy/skb_copy_expand).
I've kept that difference in tact with a comment added asking for
clarification.
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (131 commits)
NFSv4: Fix a typo in nfs_inode_reclaim_delegation
NFS: Add a boot parameter to disable 64 bit inode numbers
NFS: nfs_refresh_inode should clear cache_validity flags on success
NFS: Fix a connectathon regression in NFSv3 and NFSv4
NFS: Use nfs_refresh_inode() in ops that aren't expected to change the inode
SUNRPC: Don't call xprt_release in call refresh
SUNRPC: Don't call xprt_release() if call_allocate fails
SUNRPC: Fix buggy UDP transmission
[23/37] Clean up duplicate includes in
[2.6 patch] net/sunrpc/rpcb_clnt.c: make struct rpcb_program static
SUNRPC: Use correct type in buffer length calculations
SUNRPC: Fix default hostname created in rpc_create()
nfs: add server port to rpc_pipe info file
NFS: Get rid of some obsolete macros
NFS: Simplify filehandle revalidation
NFS: Ensure that nfs_link() returns a hashed dentry
NFS: Be strict about dentry revalidation when doing exclusive create
NFS: Don't zap the readdir caches upon error
NFS: Remove the redundant nfs_reval_fsid()
NFSv3: Always use directory post-op attributes in nfs3_proc_lookup
Fix up trivial conflict due to sock_owned_by_user() cleanup manually in
net/sunrpc/xprtsock.c
git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep
* 'v2.6.24-lockdep' of git://git.kernel.org/pub/scm/linux/kernel/git/peterz/linux-2.6-lockdep:
lockdep: annotate dir vs file i_mutex
lockdep: per filesystem inode lock class
lockdep: annotate kprobes irq fiddling
lockdep: annotate rcu_read_{,un}lock{,_bh}
lockdep: annotate journal_start()
lockdep: s390: connect the sysexit hook
lockdep: x86_64: connect the sysexit hook
lockdep: i386: connect the sysexit hook
lockdep: syscall exit check
lockdep: fixup mutex annotations
lockdep: fix mismatched lockdep_depth/curr_chain_hash
lockdep: Avoid /proc/lockdep & lock_stat infinite output
lockdep: maintainers
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6:
[IA64] update sn2_defconfig
[IA64] Fix kernel hangup in kdump on INIT
[IA64] Fix kernel panic in kdump on INIT
[IA64] Remove vector from ia64_machine_kexec()
[IA64] Fix race when multiple cpus go through MCA
[IA64] Remove needless delay in MCA rendezvous
[IA64] add driver for ACPI methods to call native firmware
[IA64] abstract SAL_CALL wrapper to allow other firmware entry points
[IA64] perfmon: Remove exit_pfm_fs()
[IA64] tree-wide: Misc __cpu{initdata, init, exit} annotations
Commit 5a7ad7f044941316dc98eda2a087a12a7a50649d removed all uses of
'retval', but didn't remove the variable itself.
Update defonfig file for sn2 to match recent changes in config options.
Signed-off-by: Jes Sorensen <jes@sgi.com>
Signed-off-by: Tony Luck <tony.luck@intel.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched: (140 commits)
sched: sync wakeups preempt too
sched: affine sync wakeups
sched: guest CPU accounting: maintain guest state in KVM
sched: guest CPU accounting: maintain stats in account_system_time()
sched: guest CPU accounting: add guest-CPU /proc/<pid>/stat fields
sched: guest CPU accounting: add guest-CPU /proc/stat field
sched: domain sysctl fixes: add terminator comment
sched: domain sysctl fixes: do not crash on allocation failure
sched: domain sysctl fixes: unregister the sysctl table before domains
sched: domain sysctl fixes: use for_each_online_cpu()
sched: domain sysctl fixes: use kcalloc()
Make scheduler debug file operations const
sched: enable wake-idle on CONFIG_SCHED_MC=y
sched: reintroduce topology.h tunings
sched: allow the immediate migration of cache-cold tasks
sched: debug, improve migration statistics
sched: debug: increase width of debug line
sched: activate task_hot() only on fair-scheduled tasks
sched: reintroduce cache-hot affinity
sched: speed up context-switches a bit
* master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-misc-2.6: (207 commits)
[SCSI] gdth: fix CONFIG_ISA build failure
[SCSI] esp_scsi: remove __dev{init,exit}
[SCSI] gdth: !use_sg cleanup and use of scsi accessors
[SCSI] gdth: Move members from SCp to gdth_cmndinfo, stage 2
[SCSI] gdth: Setup proper per-command private data
[SCSI] gdth: Remove gdth_ctr_tab[]
[SCSI] gdth: switch to modern scsi host registration
[SCSI] gdth: gdth_interrupt() gdth_get_status() & gdth_wait() fixes
[SCSI] gdth: clean up host private data
[SCSI] gdth: Remove virt hosts
[SCSI] gdth: Reorder scsi_host_template intitializers
[SCSI] gdth: kill gdth_{read,write}[bwl] wrappers
[SCSI] gdth: Remove 2.4.x support, in-kernel changelog
[SCSI] gdth: split out pci probing
[SCSI] gdth: split out eisa probing
[SCSI] gdth: split out isa probing
gdth: Make one abuse of scsi_cmnd less obvious
[SCSI] NCR5380: Use scsi_eh API for REQUEST_SENSE invocation
[SCSI] usb storage: use scsi_eh API in REQUEST_SENSE execution
[SCSI] scsi_error: Refactoring scsi_error to facilitate in synchronous REQUEST_SENSE
master.kernel.org:/pub/scm/linux/kernel/git/airlied/agp-2.6
* 'agp-patches' of master.kernel.org:/pub/scm/linux/kernel/git/airlied/agp-2.6:
fix use after free in amd create gatt pages
AGP fix race condition between unmapping and freeing pages
ssh://master.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of ssh://master.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
via invalid device ids removal
radeon: Commit the ring after each partial texture upload blit.
i915: fix vbl swap allocation size.
drm: Replace DRM_IOCTL_ARGS with (dev, data, file_priv) and remove DRM_DEVICE.
drm: remove XFREE86_VERSION macros.
drm: Replace filp in ioctl arguments with drm_file *file_priv.
drm: Remove DRM_ERR OS macro.
* 'nfs-server-stable' of git://linux-nfs.org/~bfields/linux:
knfsd: query filesystem for NFSv4 getattr of FATTR4_MAXNAME
knfsd: nfsv4 delegation recall should take reference on client
knfsd: don't shutdown callbacks until nfsv4 client is freed
knfsd: let nfsd manage timing out its own leases
knfsd: Add source address to sunrpc svc errors
knfsd: 64 bit ino support for NFS server
svcgss: move init code into separate function
knfsd: remove code duplication in nfsd4_setclientid()
nfsd warning fix
knfsd: fix callback rpc cred
knfsd: move nfsv4 slab creation/destruction to module init/exit
knfsd: spawn kernel thread to probe callback channel
knfsd: nfs4 name->id mapping not correctly parsing negative downcall
knfsd: demote some printk()s to dprintk()s
knfsd: cleanup of nfsd4 cmp_* functions
knfsd: delete code made redundant by map_new_errors
nfsd: fix horrible indentation in nfsd_setattr
nfsd: remove unused cache_for_each macro
nfsd: tone down inaccurate dprintk
Kill unused variables
Signed-off-by: Geert Uytterhoeven <Geert.Uytterhoeven@sonycom.com>
Fix bogus copying of data into userspace when HIDIOCGRDESC is issued.
HID-transport layer makes sure that dev->hid->rdesc is not larger than
HID_MAX_DESCRIPTOR_SIZE.
Noticed-by: Al Viro <viro@ftp.linux.org.uk>
make sure sync wakeups preempt too - the scheduler will not
overschedule as we've got various throttles against that.
As a result, sync wakeups can be used more widely in the kernel
(to signal wakeup affinity between tasks), and no arbitrary
latencies will be introduced either.
make sync wakeups affine for cache-cold tasks: if a cache-cold task
is woken up by a sync wakeup then use the opportunity to migrate it
straight away. (the two tasks are 'related' because they communicate)
Modify KVM to update guest time accounting.
[ mingo@elte.hu: ported to 2.6.24 KVM. ]
Signed-off-by: Laurent Vivier <Laurent.Vivier@bull.net>
Acked-by: Avi Kivity <avi@qumranet.com>
modify account_system_time() to add cputime to cpustat->guest if we are
running a VCPU. We add this cputime to cpustat->user instead of
cpustat->system because this part of KVM code is in fact user code
although it is executed in the kernel. We duplicate VCPU time between
guest and user to allow an unmodified "top(1)" to display correct value.
A modified "top(1)" is able to display good cpu user time and cpu guest
time by subtracting cpu guest time from cpu user time. Update "gtime" in
task_struct accordingly.
like for cpustat, introduce the "gtime" (guest time of the task) and
"cgtime" (guest time of the task children) fields for the
tasks. Modify signal_struct and task_struct.
Modify /proc/<pid>/stat to display these new fields.
as recent CPUs introduce a third running state, after "user" and
"system", we need a new field, "guest", in cpustat to store the time
used by the CPU to run virtual CPU. Modify /proc/stat to display this
new field.
we had an incorrect-terminator bug in sd_alloc_ctl_domain_table()
before, so add a comment that documents it.
Signed-off-by: Milton Miller <miltonm@bga.com>
Now that we are calling this at runtime, a more relaxed error path is
suggested. If an allocation fails, we just register the partial table,
which will show empty directories.
Unregister and free the sysctl table before destroying domains, then
rebuild and register after creating the new domains. This prevents the
sysctl table from pointing to freed memory for root to write.
init_sched_domain_sysctl was walking cpus 0-n and referencing per_cpu
variables. If the cpus_possible mask is not contigious this will result
in a crash referencing unallocated data. If the online mask is not
contigious then we would show offline cpus and miss online ones.
