2006-09-13[PATCH] sky2: big endianStephen Hemminger
Fix support for big endian platforms like PPC. Still not sure about VLAN acceleration (does it need swapping)? Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] sky2: fiber supportStephen Hemminger
Fix the support for fiber connected gigabit boards. Allow half duplex gigabit to be configured. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] sky2: tx pause bug fixStephen Hemminger
Fix problems with transmit pause frames. The driver was telling the GMAC to flush (not process) pause frames. Manually disabling pause wasn't working because of problems in the setup. This maybe the cause of the lockup under load. http://bugzilla.kernel.org/show_bug.cgi?id=6839 Patch against netdev-2.6 git tree Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13drivers/net: Trim trailing whitespaceJeff Garzik
2006-09-13[PATCH] ehea: IBM eHEA Ethernet Device DriverJan-Bernd Themann
Hi Jeff, I fixed the __iomem issue and tested the driver with sparse. Looks good so far. Thanks for your effort. Jan-Bernd Themann Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com> drivers/net/Kconfig | 9 drivers/net/Makefile | 1 drivers/net/ehea/Makefile | 6 drivers/net/ehea/ehea.h | 447 ++++++ drivers/net/ehea/ehea_ethtool.c | 294 ++++ drivers/net/ehea/ehea_hcall.h | 51 drivers/net/ehea/ehea_hw.h | 287 ++++ drivers/net/ehea/ehea_main.c | 2654 ++++++++++++++++++++++++++++++++++++++++ drivers/net/ehea/ehea_phyp.c | 705 ++++++++++ drivers/net/ehea/ehea_phyp.h | 455 ++++++ drivers/net/ehea/ehea_qmr.c | 582 ++++++++ drivers/net/ehea/ehea_qmr.h | 358 +++++ 12 files changed, 5849 insertions(+) Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: NAPI implementationDon Fry
Implement NAPI changes to pcnet32 driver. Compile default is off. Listed as experimental. Len and Don both worked on a NAPI implementation and have both tested these changes. An e1000 blasting short packets to the pcnet32 will lockup Don's system until the receive storm stops. Without NAPI Len's system watchdog would expire causing the system to reboot. With NAPI the system will stay operational. Tested ia32 and ppc64. Tested '970A, '971, '972, '973, '975, '976, and '978. The Kconfig changes came from Len. Don is to blame for all the others. Signed-off-by: Len Sorensen <lsorense@csclub.uwaterloo.ca> Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: break receive routine into two pieces.Don Fry
Breaking the receive frame processing into two routines for greater clarity. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: move/create receive and transmit routinesDon Fry
Move the receive routine and create the transmit routine. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: magic number cleanupDon Fry
Change some magic numbers to clearer names. A few whitespace changes. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13[PATCH] pcnet32: remove unnecessary save/restore register accesses.Don Fry
Delete unnecessary save/restore of rap in interrupt handler and statistics. tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-09-13[PATCH] mv643xx_eth: Unmap DMA buffers in receive pathDale Farnsworth
Fix a missing call to dma_unmap_single() in the receive path. Without this call, errors have been observed on non-cache-coherent systems. Signed-off-by Dale Farnsworth <dale@farnsworth.org> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-13Merge branch 'master' into upstream-fixesJeff Garzik
2006-09-12[PATCH] e1000: revert 'e1000: Remove 0x1000 as supported device'Auke-Jan H Kok
The commit 'e1000: Remove 0x1000 as supported device' (Jeff Kirsher, 673a052fde79ab5e9dce569b0336358812ddba2d) Removes PIC device ID 8086:1000 from the list of supported devices. A fix was submitted for the original issue (commit 6a9516989f94df10d9a27ba543c6b53b3e69c84a). This commit reverts commit 673a052fde79ab5e9dce569b0336358812ddba2d and re-enables 82542rev3 chips completely. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-12Merge tag 'r8169-20060912-00' of ↵Jeff Garzik
git://electric-eye.fr.zoreil.com/home/romieu/linux-2.6 into tmp
2006-09-12Merge tag '8139cp-20060912-00' of ↵Jeff Garzik
2006-09-12Linux v2.6.18-rc7v2.6.18-rc7Linus Torvalds
One last time..
2006-09-12Merge branch 'audit.b29' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current * 'audit.b29' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/audit-current: [PATCH] sparc64 audit syscall classes hookup [PATCH] syscall class hookup for all normal targets
2006-09-12Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [CIFS] Fix CIFS readdir access denied when SE Linux enabled
2006-09-12Merge master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvbLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/mchehab/v4l-dvb: V4L/DVB (4608c): Fix I2C dependencies for saa7146 modules V4L/DVB (4608b): i2c deps fix on DVB V4L/DVB (4605): Fixes an issue with V4L1 and make headers-install V4L/DVB (4520): Fix an error when loading bttv driver on PV M4900. V4L/DVB (4511): Restore tuner_ymec_tvf66t5_b_dff_pal_ranges[] to fix UHF switch functionality V4L/DVB (4494a): Fix compilation when V4L1 support is not present
2006-09-12Merge master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/gregkh/usb-2.6: USB: Fix unload oops and memory leak in yealink driver usbserial: Reference leak
2006-09-12Merge master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/lethal/sh64-2.6: sh64: Add a sane pm_power_off implementation. sh64: Use generic BUG_ON()/WARN_ON(). sh64: Trivial build fixes. sh64: Drop deprecated ISA tuning for legacy toolchains.
2006-09-12Merge git://oss.sgi.com:8090/xfs/xfs-2.6Linus Torvalds
* git://oss.sgi.com:8090/xfs/xfs-2.6: [XFS] Fix a bad pointer dereference in the quota statvfs handling. [XFS] Fix xfs_splice_write() so appended data gets to disk. [XFS] Fix ABBA deadlock between i_mutex and iolock. Avoid calling [XFS] Prevent free space oversubscription and xfssyncd looping.
2006-09-128139cp: ring_info removal for the transmit pathFrancois Romieu
As long as the descriptor fits on a single cacheline, the change should be almost free. Now ring_info is not used at all. Remove it. Signed-off-by: Francois Romieu <romieu@fr.zoreil.com>
2006-09-12Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-09-12[PATCH] e1000: fix TX timout hang regression for 82542rev3Auke Kok
Commit 581d708eb47cccb5f41bc0817e50c9b004011ba8 (oct. 5 2005) introduced partial Multiqueue support for e1000 which broke macro smartness in setting up head/tail registers for 82542 rev3 chipsets, making these adapters completely non-working since 2.6.15. This commit sets the proper head and tail registers for read and write descriptor rings. Ths fix was tested on an 82542 rev3 NIC and newer NICs. Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-12Merge branch 'tmp' into upstreamJeff Garzik
2006-09-12[PATCH] Remove more unnecessary driver printk'sAndy Gospodarek
As I promised last week, here is the first pass at removing all unnecessary printk's that exist in network device drivers currently in promiscuous mode. The duplicate messages are not needed so they have been removed. Some of these drivers are quite old and might not need an update, but I did them all anyway. I am currently auditing the remaining conditional printk's and will send out a patch for those soon. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-09-12Merge branch 'upstream' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream
2006-09-12Merge branch 'upstream-fixes' of ↵Jeff Garzik
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-2.6 into upstream-fixes
2006-09-12USB: Fix unload oops and memory leak in yealink driverHenk Vergonet
This patch fixes a memory leak and a kernel oops when trying to unload the driver, due to an unbalanced cleanup. Thanks Ivar Jensen for spotting my mistake. Signed-off-by: Henk Vergonet <henk.vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-12usbserial: Reference leakMatthias Urlichs
A sufficiently-large number of USB serial devices causes a reference leak when /proc/tty/drivers/usbserial is read. Signed-Off-By: Matthias Urlichs <smurf@smurf.noris.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-12[PATCH] sparc64 audit syscall classes hookupAl Viro
... that should do it for all targets; the only remaining issues are mips (currently treated as non-biarch) and handling of other OS emulations (OSF/SunOS/Solaris/???). The latter would need to be assigned new AUDIT_ARCH_... ABI numbers anyway... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-12[PATCH] syscall class hookup for all normal targetsAl Viro
Take default arch/*/kernel/audit.c to lib/, have those with special needs (== biarch) define AUDIT_ARCH in their Kconfig. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-09-12sh64: Add a sane pm_power_off implementation.Paul Mundt
sh64 wasn't providing a sensible pm_power_off(), add one, and just wrap it to machine_power_off, which already does the right thing. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-12sh64: Use generic BUG_ON()/WARN_ON().Paul Mundt
sh64 doesn't need to do anything special for BUG_ON() or WARN_ON(), use the generic versions. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-12sh64: Trivial build fixes.Paul Mundt
While we've been sorting out the toolchain fiasco, some of the code has suffered a bit of bitrot. Building with GCC4 also brings up some more build warnings. Trivial fixes for both issues. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-12sh64: Drop deprecated ISA tuning for legacy toolchains.Paul Mundt
The original sh64 toolchains required that we tune the ISA level accordingly to not have head.S/entry.S blow up. With current toolchains, this is no longer the case, and the syntax magically changed as well, causing all current toolchains to die a horrible death. Incidentally, code generation in other parts of the kernel is now significantly complex enough that none of the older toolchains make it very far these days, so there's not even any point in preserving legacy compatability via as-option. This fixes a long-standing issue, as noted here: http://lkml.org/lkml/2005/1/5/223 Though at the time the current toolchains were too broken to make adjusting the tuning worthwhile. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2006-09-11[PATCH] hostap_cs: added support for Proxim Harmony PCI W-Lan cardChristian Steineck
hostap_cs driver - added support for Proxim Harmony PCI W-Lan Card (uses pd6729 based pcmcia2pci bridge) Signed-off-by: Christian Steineck <memphis@machzwo.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] bcm43xx: remove dead code in bcm43xx_sysfs.cLarry Finger
Coverity CID 1160 & 1161 Remove some dead code from bcm43xx_sysfs.c in 2.6.18-rc6 Signed-off-by: Darren Jenkins <darrenrjenkins@gmail.com> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] bcm43xx: ucode debug status via sysfsLarry Finger
This patch prints out the ucode debug status to sysfs. So, users can watch the microcode status of their hardware. Signed-off-by: Martin Langer <martin-langer@gmx.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] bcm43xx: Add firmware version printoutLarry Finger
This patch prints microcode revision, patchlevel, date and time to KERN_INFO. Also, version 4.xx microcodes (rev>0x128) will be rejected by the driver, because they still do not work. Signed-off-by: Martin Langer <martin-langer@gmx.de> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] bcm43xx: remove dead statistics codeLarry Finger
This patch removes code that was make obsolete when the wireless statistics in bcm43xx-softmac were changed, but was overlooked at that time. The value of bcm->stats.link_quality computed here is never used. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] Prism54 : add bitrates to scan resultJean Tourrilhes
This patch adds bitrate information to the scan result in the Prism54 driver, like some/most other driver do. Signed-off-by: Jean Tourrilhes <jt@hpl.hp.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] zd1211rw: Removed unneeded packed attributesUlrich Kunitz
Inspired by an e-mail by Stephen Hemminger I decided to remove all unneeded packed attributes from the code where the member variables are already aligned. This avoids horrible code being generated on some architectures. Signed-off-by: Ulrich Kunitz <kune@deine-taler.de> Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] zd1211rw: Add ID for Asus WL-159gDaniel Drake
Tested by Vincent TOUCHARD zd1211 chip 0b05:170c v4802 high 00-11-d8 AL2230_RF pa0 g--- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] zd1211rw: Add ID for Siemens Gigaset USB Stick 54Daniel Drake
Tested by Martin Dummer. zd1211 chip 0b3b:5630 v4330 high 00-01-e3 RF2959_RF pa0 --- Signed-off-by: Daniel Drake <dsd@gentoo.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2006-09-11[PATCH] bcm43xx: Correct out of sequence initialization stepLarry Finger
This patch fixes an out of sequence step in the bcm43xx_init_board routine for bcm43xx-softmac. Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
