2009-12-23sfc: QT2025C: Switch into self-configure mode when not in loopbackMatthew Slattery
The PHY boots in a mode which is not necessarily optimal. This change switches it to self-configure mode (except when in loopback, which won't work in that mode if an SFP+ module is not present) by rebooting the PHY's microcontroller, and replicating the sequence of configuration writes from the boot EEPROM with the appropriate changes. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: QT2025C: Work around PHY bugMatthew Slattery
If we see the PHY remaining stuck in a link-down state due to PCS being down while PMA/PMD is up, we briefly switch to PMA/PMD loopback and back, which usually unsticks it. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: Fix DMA mapping cleanup in case of an error in TSONeil Turton
We need buffer->len to remain valid to work out the correct address to be unmapped. We therefore need to clear buffer->len after the unmap operation. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: Include XGXS in XMAC link status check except in XGMII loopbackBen Hutchings
The XGXS block may not get a link immediately in XGXS or XAUI loopback modes, so we still need to check it. Split falcon_xaui_link_ok() into falcon_xgxs_link_ok(), which checks only the Falcon XGXS block, and falcon_xmac_link_ok(), which checks one or both sides of the link as appropriate. Also rename falcon_check_xaui_link() to falcon_xmac_link_ok_retry(). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-23sfc: Move PHY software state initialisation from init() into probe()Steve Hodgson
This prevents efx->link_advertising from being blatted during a reset. The phy_short_reach sysfs node is now destroyed later in the port shutdown process, so check for STATE_RUNNING after acquiring the rtnl_lock (just like in set_phy_flash_cfg). Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-21Merge branch 'master' of ↵David S. Miller
2009-12-21ps3_gelic_wireless: Fix build failure due to missing WEXT_PRIVBenjamin Herrenschmidt
The option to support the old style PSK interface in the PS3 GELIC wireless drivers requires CONFIG_WEXT_PRIV to be set Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Geoff Levand <geoffrey.levand@am.sony.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21mac80211: fix WMM AP settings applicationJohannes Berg
My commit 77fdaa12cea26c204cc12c312fe40bc0f3dcdfd8 Author: Johannes Berg <johannes@sipsolutions.net> Date: Tue Jul 7 03:45:17 2009 +0200 mac80211: rework MLME for multiple authentications inadvertedly broke WMM because it removed, along with a bunch of other now useless initialisations, the line initialising sdata->u.mgd.wmm_last_param_set to -1 which would make it adopt any WMM parameter set. If, as is usually the case, the AP uses WMM parameter set sequence number zero, we'd never update it until the AP changes the sequence number. Add the missing initialisation back to get the WMM settings from the AP applied locally. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org [2.6.31+] Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21mac80211: fix peer HT capabilitiesJohannes Berg
I noticed yesterday, because Jeff had noticed a speed regression, cf. bug http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2138 that the SM PS settings for peers were wrong. Instead of overwriting the SM PS settings with the local bits, we need to keep the remote bits. The bug was part of the original HT code from over two years ago, but unfortunately nobody noticed that it makes no sense -- we shouldn't be overwriting the peer's setting with our own but rather keep it intact when masking the peer capabilities with our own. While fixing that, I noticed that the masking of capabilities is completely useless for most of the bits, so also fix those other bits. Finally, I also noticed that PSMP_SUPPORT no longer exists in the final 802.11n version, so also remove that. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwmc3200wifi: Fix test of unsigned in iwm_ntf_stop_resume_tx()Roel Kluin
`queue' was unsigned so the test did not work. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Reviewed-by: Pavel Roskin <proski@gnu.org> Acked-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21Libertas: fix buffer overflow in lbs_get_essid()Daniel Mack
The libertas driver copies the SSID buffer back to the wireless core and appends a trailing NULL character for termination. This is a) unnecessary because the buffer is allocated with kzalloc and is hence already NULLed when this function is called, and b) for priv->curbssparams.ssid_len == 32, it writes back one byte too much which causes memory corruptions. Fix this by removing the extra write. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Stephen Hemminger <shemminger@vyatta.com> Cc: Maithili Hinge <maithili@marvell.com> Cc: Kiran Divekar <dkiran@marvell.com> Cc: Michael Hirsch <m.hirsch@raumfeld.com> Cc: netdev@vger.kernel.org Cc: libertas-dev@lists.infradead.org Cc: linux-wireless@lists.infradead.org Cc: stable@kernel.org Acked-by: Holger Schurig <holgerschurig@gmail.com> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21drivers/net/wireless/iwlwifi/iwl-tx.c: fix gcc-3.4.5 warningakpm@linux-foundation.org
drivers/net/wireless/iwlwifi/iwl-tx.c: In function `iwl_hw_txq_ctx_free': drivers/net/wireless/iwlwifi/iwl-tx.c:410: warning: suggest explicit braces to avoid ambiguous `else' Cc: Zhu Yi <yi.zhu@intel.com> Cc: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21ath9k: Stop ANI when doing a resetSujith
The MIB counters are disabled when doing a chip reset. Since ANI depends on the MIB registers for its operation, relying on the contents of said registers during HW reset results in sub-optimal performance. Cc: stable@kernel.org Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21ath9k: Fix TX queue drainingSujith
When TX DMA termination has failed, the HW has to be reset completely. Doing a fast channel change in this case is insufficient. Also, change the debug level of a couple of messages to FATAL. Cc: stable@kernel.org Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21ath9k: Fix bug in assigning sequence numberSujith
The internal, driver-specific maintenance of sequence numbers is applicable only for HT frames. Also, remove comments that are not relevant anymore. Signed-off-by: Sujith <Sujith.Manoharan@atheros.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21rt2x00: Fix calculation of rt2800 iveiv entry offset.Gertjan van Wingerde
Fix typo. The index should be multiplied by the entry size, not 'and'-ed. Found via code-inspection. Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: fix 40MHz operation setting on cards that do not allow itReinette Chatre
Some devices have 40MHz operation disabled entirely. Ensure that driver do not enable 40MHz operation if a channel does not allow this. This fixes http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2135 Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> CC: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwl3945: fix panic in iwl3945 driverZhu Yi
3945 updated write_ptr without regard to read_ptr on the Tx path. This messes up our TFD on high load and result in the following: <1>[ 7290.414172] IP: [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.414205] PGD 0 <1>[ 7290.414214] Thread overran stack, or stack corrupted <0>[ 7290.414229] Oops: 0002 [#1] PREEMPT SMP <0>[ 7290.414246] last sysfs file: /sys/devices/platform/coretemp.1/temp1_input <4>[ 7290.414265] CPU 0 <4>[ 7290.414274] Modules linked in: af_packet nfsd usb_storage usb_libusual cpufreq_powersave exportfs cpufreq_conservative iwl3945 nfs cpufreq_userspace snd_hda_codec_realtek acpi_cpufreq uvcvideo lockd iwlcore snd_hda_intel joydev coretemp nfs_acl videodev snd_hda_codec mac80211 v4l1_compat snd_hwdep sbp2 v4l2_compat_ioctl32 uhci_hcd psmouse auth_rpcgss ohci1394 cfg80211 ehci_hcd video ieee1394 snd_pcm serio_raw battery ac nvidia(P) usbcore output sunrpc evdev lirc_ene0100 snd_page_alloc rfkill tg3 libphy fuse lzo lzo_decompress lzo_compress <6>[ 7290.414486] Pid: 0, comm: swapper Tainted: P 2.6.32-rc8-wl #213 Aspire 5720 <6>[ 7290.414507] RIP: 0010:[<ffffffffa0dd53a1>] [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <6>[ 7290.414541] RSP: 0018:ffff880002203d60 EFLAGS: 00010246 <6>[ 7290.414557] RAX: 000000000000004f RBX: ffff880064c11600 RCX: 0000000000000013 <6>[ 7290.414576] RDX: ffffffffa0ddcf20 RSI: ffff8800512b7008 RDI: 0000000000000038 <6>[ 7290.414596] RBP: ffff880002203dd0 R08: 0000000000000000 R09: 0000000000000100 <6>[ 7290.414616] R10: 0000000000000001 R11: 0000000000000000 R12: 00000000000000a0 <6>[ 7290.414635] R13: 0000000000000002 R14: 0000000000000013 R15: 0000000000020201 <6>[ 7290.414655] FS: 0000000000000000(0000) GS:ffff880002200000(0000) knlGS:0000000000000000 <6>[ 7290.414677] CS: 0010 DS: 0018 ES: 0018 CR0: 000000008005003b <6>[ 7290.414693] CR2: 0000000000000041 CR3: 0000000001001000 CR4: 00000000000006f0 <6>[ 7290.414712] DR0: 0000000000000000 DR1: 0000000000000000 DR2: 0000000000000000 <6>[ 7290.414732] DR3: 0000000000000000 DR6: 00000000ffff0ff0 DR7: 0000000000000400 <4>[ 7290.414752] Process swapper (pid: 0, threadinfo ffffffff81524000, task ffffffff81528b60) <0>[ 7290.414772] Stack: <4>[ 7290.414780] ffff880002203da0 0000000000000046 0000000000000000 0000000000000046 <4>[ 7290.414804] <0> 0000000000000282 0000000000000282 0000000000000282 ffff880064c12010 <4>[ 7290.414830] <0> ffff880002203db0 ffff880064c11600 ffff880064c12e50 ffff8800512b7000 <0>[ 7290.414858] Call Trace: <0>[ 7290.414867] <IRQ> <4>[ 7290.414884] [<ffffffffa0dc8c47>] iwl3945_irq_tasklet+0x657/0x1740 [iwl3945] <4>[ 7290.414910] [<ffffffff8138fc60>] ? _spin_unlock+0x30/0x60 <4>[ 7290.414931] [<ffffffff81049a21>] tasklet_action+0x101/0x110 <4>[ 7290.414950] [<ffffffff8104a3d0>] __do_softirq+0xc0/0x160 <4>[ 7290.414968] [<ffffffff8100d01c>] call_softirq+0x1c/0x30 <4>[ 7290.414986] [<ffffffff8100eff5>] do_softirq+0x75/0xb0 <4>[ 7290.415003] [<ffffffff81049ee5>] irq_exit+0x95/0xa0 <4>[ 7290.415020] [<ffffffff8100e547>] do_IRQ+0x77/0xf0 <4>[ 7290.415038] [<ffffffff8100c7d3>] ret_from_intr+0x0/0xf <0>[ 7290.415052] <EOI> <4>[ 7290.415067] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415087] [<ffffffff81234f04>] ? acpi_idle_enter_bm+0x27a/0x2a5 <4>[ 7290.415107] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415130] [<ffffffff812c11f3>] ? cpuidle_idle_call+0x93/0xf0 <4>[ 7290.415149] [<ffffffff8100b0d7>] ? cpu_idle+0xa7/0x110 <4>[ 7290.415168] [<ffffffff8137b3d5>] ? rest_init+0x75/0x80 <4>[ 7290.415187] [<ffffffff8158cd0a>] ? start_kernel+0x3a7/0x3b3 <4>[ 7290.415206] [<ffffffff8158c315>] ? x86_64_start_reservations+0x125/0x129 <4>[ 7290.415227] [<ffffffff8158c3fd>] ? x86_64_start_kernel+0xe4/0xeb <0>[ 7290.415243] Code: 00 41 39 ce 0f 8d e8 01 00 00 48 8b 47 40 48 63 d2 48 69 d2 98 00 00 00 4c 8b 04 02 48 c7 c2 20 cf dd a0 49 8d 78 38 49 8d 40 4f <c6> 47 09 00 c6 47 0c 00 c6 47 0f 00 c6 47 12 00 c6 47 15 00 49 <1>[ 7290.415382] RIP [<ffffffffa0dd53a1>] iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.415410] RSP <ffff880002203d60> <0>[ 7290.415421] CR2: 0000000000000041 <4>[ 7290.415436] ---[ end trace ec46807277caa515 ]--- <0>[ 7290.415450] Kernel panic - not syncing: Fatal exception in interrupt <4>[ 7290.415468] Pid: 0, comm: swapper Tainted: P D 2.6.32-rc8-wl #213 <4>[ 7290.415486] Call Trace: <4>[ 7290.415495] <IRQ> [<ffffffff8138c040>] panic+0x7d/0x13a <4>[ 7290.415519] [<ffffffff8101071a>] oops_end+0xda/0xe0 <4>[ 7290.415538] [<ffffffff8102e1ea>] no_context+0xea/0x250 <4>[ 7290.415557] [<ffffffff81038991>] ? select_task_rq_fair+0x511/0x780 <4>[ 7290.415578] [<ffffffff8102e475>] __bad_area_nosemaphore+0x125/0x1e0 <4>[ 7290.415597] [<ffffffff81038d0c>] ? __enqueue_entity+0x7c/0x80 <4>[ 7290.415616] [<ffffffff81039201>] ? enqueue_task_fair+0x111/0x150 <4>[ 7290.415636] [<ffffffff8102e53e>] bad_area_nosemaphore+0xe/0x10 <4>[ 7290.415656] [<ffffffff8102e8fa>] do_page_fault+0x26a/0x320 <4>[ 7290.415674] [<ffffffff813905df>] page_fault+0x1f/0x30 <4>[ 7290.415697] [<ffffffffa0dd53a1>] ? iwl3945_rx_reply_tx+0xc1/0x450 [iwl3945] <4>[ 7290.415723] [<ffffffffa0dc8c47>] iwl3945_irq_tasklet+0x657/0x1740 [iwl3945] <4>[ 7290.415746] [<ffffffff8138fc60>] ? _spin_unlock+0x30/0x60 <4>[ 7290.415764] [<ffffffff81049a21>] tasklet_action+0x101/0x110 <4>[ 7290.415783] [<ffffffff8104a3d0>] __do_softirq+0xc0/0x160 <4>[ 7290.415801] [<ffffffff8100d01c>] call_softirq+0x1c/0x30 <4>[ 7290.415818] [<ffffffff8100eff5>] do_softirq+0x75/0xb0 <4>[ 7290.415835] [<ffffffff81049ee5>] irq_exit+0x95/0xa0 <4>[ 7290.415852] [<ffffffff8100e547>] do_IRQ+0x77/0xf0 <4>[ 7290.415869] [<ffffffff8100c7d3>] ret_from_intr+0x0/0xf <4>[ 7290.415883] <EOI> [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415911] [<ffffffff81234f04>] ? acpi_idle_enter_bm+0x27a/0x2a5 <4>[ 7290.415931] [<ffffffff81234efa>] ? acpi_idle_enter_bm+0x270/0x2a5 <4>[ 7290.415952] [<ffffffff812c11f3>] ? cpuidle_idle_call+0x93/0xf0 <4>[ 7290.415971] [<ffffffff8100b0d7>] ? cpu_idle+0xa7/0x110 <4>[ 7290.415989] [<ffffffff8137b3d5>] ? rest_init+0x75/0x80 <4>[ 7290.416007] [<ffffffff8158cd0a>] ? start_kernel+0x3a7/0x3b3 <4>[ 7290.416026] [<ffffffff8158c315>] ? x86_64_start_reservations+0x125/0x129 <4>[ 7290.416047] [<ffffffff8158c3fd>] ? x86_64_start_kernel+0xe4/0xeb Reported-by: Maxim Levitsky <maximlevitsky@gmail.com> Tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> CC: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: initialize spinlock before useReinette Chatre
Recent powersaving work resulted in power management ops being called during EEPROM initialization. The lock used by these functions is not initialized at this time. Ensure lock is initialized before it is used. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwl3945: disable power saveReinette Chatre
we see from http://bugzilla.intellinuxwireless.org/show_bug.cgi?id=2125 that power saving does not work well on 3945. Since then power saving has also been connected with association problems where an AP deathenticates a 3945 after it is unable to transmit data to it - this happens when 3945 enters power savings mode. Disable power save support until issues are resolved. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> CC: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: fix more eeprom endian bugsJohannes Berg
I've also for a long time had a problem with the temperature calculation code, which I had fixed by byte-swapping the values, and now it turns out that was the correct fix after all. Also, any use of iwl_eeprom_query_addr() that is for more than a u8 must be cast to little endian, and some structs as well. Fix all this. Again, no real impact on platforms that already are little endian. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: fix EEPROM/OTP reading endian annotations and a bugJohannes Berg
The construct "le16_to_cpu((__force __le16)(r >> 16))" has always bothered me when looking through the iwlwifi code, it shouldn't be necessary to __force anything, and before this code, "r" was obtained with an ioread32, which swaps each of the two u16 values in it properly when swapping the entire u32 value. I've had arguments about this code with people before, but always conceded they were right because removing it only made things not work at all on big endian platforms. However, analysing a failure of the OTP reading code, I now finally figured out what is going on, and why my intuition about that code being wrong was right all along. It turns out that the 'priv->eeprom' u8 array really wants to have the data in it in little endian. So the force code above and all really converts *to* little endian, not from it. Cf., for instance, the function iwl_eeprom_query16() -- it reads two u8 values and combines them into a u16, in a little-endian way. And considering it more, it makes sense to have the eeprom array as on the device, after all not all values really are 16-bit values, the MAC address for instance is not. Now, what this really means is that all the annotations are completely wrong. The eeprom reading code should fill the priv->eeprom array as a __le16 array, with __le16 values. This also means that iwl_read_otp_word() should really have a __le16 pointer as the data argument, since it should be filling that in a format suitable for priv->eeprom. Propagating these changes throughout, iwl_find_otp_image() is found to be, now obviously visible, defective -- it uses the data returned by iwl_read_otp_word() directly as if it was CPU endianness. Fixing that, which is this hunk of the patch: - next_link_addr = link_value * sizeof(u16); + next_link_addr = le16_to_cpu(link_value) * sizeof(u16); is the only real change of this patch. Everything else is just fixing the sparse annotations. Also, the bug only shows up on big endian platforms with a 1000 series card. 5000 and previous series do not use OTP, and 6000 series has shadow RAM support which means we don't ever use the defective code on any cards but 1000. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Cc: stable@kernel.org Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21rt2x00: Disable powersaving for rt61pci and rt2800pci.Gertjan van Wingerde
We've had many reports of rt61pci failures with powersaving enabled. Therefore, as a stop-gap measure, disable powersaving of the rt61pci until we have found a proper solution. Also disable powersaving on rt2800pci as it most probably will show the same problem. Cc: stable@kernel.org Signed-off-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21drivers/net/wireless: Correct code taking the size of a pointerJulia Lawall
sizeof(iv16) and sizeof(iv32) are the sizes of pointers. Change them to the size of the copied data. Furthermore, iveiv_entry is a local structure that has just been initialized and is not visible outside this function. Thus, there would seem to be no point to copy data into it. The order of the arguments is thus changed to copy the data into the parameters, which are provided as pointers, suggesting in this case that they should be used to return values. A simplified version of the semantic patch that finds the first problem is as follows: (http://coccinelle.lip6.fr/) // <smpl> @@ expression *x; expression f; type T; @@ *f(...,(T)x,...) // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> Acked-by: Gertjan van Wingerde <gwingerde@gmail.com> Acked-by: Ivo van Doorn <IvDoorn@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21ath9k: Last fix for TX software padding.Benoit Papillault
First, we copy/paste the padding stuff from ath9k_tx to ath_tx_cabq since it needs to same kind of padding, but for internally generated beacons. Next, software padding done on TX needs to be removed before calling ieee80211_tx_status. The code was already there in ath_tx_complete but it was wrong. Fix it by using ath9k_cmn_padpos. This later code has been tested by sending packets to a monitor interface and reading packets from the same interface. Signed-off-by: Benoit PAPILLAULT <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: fix syslog message for event log dump sizeWey-Yi Guy
When trigger event log dumping from debugfs, the entire event log should be dumped and the size should match the number of events being dump. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: power up all devices for EEPROM readReinette Chatre
Recent commits "iwlwifi: remove power-wasting calls to apm_ops.init()" and "iwlagn: power up device before initializing EEPROM" had the goal of reducing device power consumption from the time the module is loaded until the interface is brought up and the device's power saving mechanisms kick in. The idea is that once the module is loaded there is no need for the device to consume power until the interface is brought up. With the current solution the device is only powered up during EEPROM read, and then so also only if the EEPROM type is OTP. We have found that on certain platforms even non-OTP devices require power to be up during EEPROM read. On these platforms the driver never loads and the system log contains the following: iwlagn 0000:03:00.0: MAC is in deep sleep!. CSR_GP_CNTRL = 0x080403D8 We thus now power up all devices during EEPROM read. Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-21iwlwifi: allocated rx page accounting cleanupZhu Yi
In iwlwifi, priv->alloc_rxb_page is used to keep track of the Rx pages allocated by the driver. This cleans up the page free routines by introducing __iwl_free_pages/iwl_free_pages so that the accounting is more accurate and less error prone. This also fixes two instances where the counter was not updated. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2009-12-20bnx2: Fix bnx2_netif_stop() merge error.Michael Chan
The error was introduced while merging: commit 4529819c45161e4a119134f56ef504e69420bc98 bnx2: reset_task is crashing the kernel. Fixing it. Signed-off-by: Michael Chan <mchan@broadcom.com>k Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18gianfar: Fix bit definitions of IMASK_GRSC and IMASK_GTSCSandeep Gopalpet
Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18gianfar: Fix stats supportSandeep Gopalpet
This patch updates the per rx/tx queue stats. To update the per rx queue stats a new structure has been introduced rx_q_stats. The per tx queue stats are updated via the netdev_queue structure itself. Note that we update only the tx_packtes, tx_bytes, rx_packets, rx_bytes and rx_dropped stats on a per queue basis. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18gianfar: Fix a filer bugSandeep Gopalpet
We need to enable filer whenever we need to use multiple RX queues. Also, need to program RIR0 register with the required distribution we require, if using RX filer hashing support for packet distribution to multiple queues. Signed-off-by: Sandeep Gopalpet <Sandeep.Kumar@freescale.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18bnx2: fixing a timout error due not refreshing TX timers correctlyBreno Leitao
When running the following script on an active bnx2 interface: while(true); do ifconfig ethX mtu 9000; ifconfig ethX mtu 1500; done A timeout error appears and dumps the following stack: NETDEV WATCHDOG: eth4 (bnx2): transmit queue 0 timed out ------------[ cut here ]------------ Badness at net/sched/sch_generic.c:261 <snip> This patch just fixes the way that ->trans_start is refreshed. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18can/at91: don't check platform_get_irq's return value against zeroUwe Kleine-König
platform_get_irq returns -ENXIO on failure, so !irq was probably always true. Better use (int)irq <= 0. Note that a return value of zero is still handled as error even though this could mean irq0. This is a followup to 305b3228f9ff4d59f49e6d34a7034d44ee8ce2f0 that changed the return value of platform_get_irq from 0 to -ENXIO on error. Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18mISDN: use DECLARE_COMPLETION_ONSTACK for non-constant completionYong Zhang
The _ONSTACK variant should be used for on-stack completion, otherwise it will break lockdep. Signed-off-by: Yong Zhang <yong.zhang0@gmail.com> Acked-by: Karsten Keil <keil@b1-systems.de> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18bnx2: reset_task is crashing the kernel. Fixing it.Breno Leitao
If bnx2 schedules a reset via the reset_task, e.g., due to a TX timeout, it's possible for the NIC to be disabled with packets pending for transmit. In this case, napi_disable will loop forever, eventually crashing the kernel. This patch moves the disable of the device to after the napi_disable call. Signed-off-by: Breno Leitao <leitao@linux.vnet.ibm.com> Acked-by: Michael Chan <mchan@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18ipv6: fix an oops when force unload ipv6 moduleYang Hongyang
When I do an ipv6 module force unload,I got the following oops: #rmmod -f ipv6 ------------[ cut here ]------------ kernel BUG at mm/slub.c:2969! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/devices/pci0000:00/0000:00:11.0/0000:02:03.0/net/eth2/ifindex Modules linked in: ipv6(-) dm_multipath uinput ppdev tpm_tis tpm tpm_bios pcspkr pcnet32 mii parport_pc i2c_piix4 parport i2c_core floppy mptspi mptscsih mptbase scsi_transport_spi Pid: 2530, comm: rmmod Tainted: G R 2.6.32 #2 440BX Desktop Reference Platform/VMware Virtual Platform EIP: 0060:[<c04b73f2>] EFLAGS: 00010246 CPU: 0 EIP is at kfree+0x6a/0xdd EAX: 00000000 EBX: c09e86bc ECX: c043e4dd EDX: c14293e0 ESI: e141f1d8 EDI: e140fc31 EBP: dec58ef0 ESP: dec58ed0 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process rmmod (pid: 2530, ti=dec58000 task=decb1940 task.ti=dec58000) Stack: c14293e0 00000282 df624240 c0897d08 c09e86bc c09e86bc e141f1d8 dec58f1c <0> dec58f00 e140fc31 c09e84c4 e141f1bc dec58f14 c0689d21 dec58f1c e141f1bc <0> 00000000 dec58f2c c0689eff c09e84d8 c09e84d8 e141f1bc bff33a90 dec58f38 Call Trace: [<e140fc31>] ? ipv6_frags_exit_net+0x22/0x32 [ipv6] [<c0689d21>] ? ops_exit_list+0x19/0x3d [<c0689eff>] ? unregister_pernet_operations+0x2a/0x51 [<c0689f70>] ? unregister_pernet_subsys+0x17/0x24 [<e140fbfe>] ? ipv6_frag_exit+0x21/0x32 [ipv6] [<e141a361>] ? inet6_exit+0x47/0x122 [ipv6] [<c045f5de>] ? sys_delete_module+0x198/0x1f6 [<c04a8acf>] ? remove_vma+0x57/0x5d [<c070f63f>] ? do_page_fault+0x2e7/0x315 [<c0403218>] ? sysenter_do_call+0x12/0x28 Code: 86 00 00 00 40 c1 e8 0c c1 e0 05 01 d0 89 45 e0 66 83 38 00 79 06 8b 40 0c 89 45 e0 8b 55 e0 8b 02 84 c0 78 14 66 a9 00 c0 75 04 <0f> 0b eb fe 8b 45 e0 e8 35 15 fe ff eb 5d 8b 45 04 8b 55 e0 89 EIP: [<c04b73f2>] kfree+0x6a/0xdd SS:ESP 0068:dec58ed0 ---[ end trace 4475d1a5b0afa7e5 ]--- It's because in ip6_frags_ns_sysctl_register, "table" only alloced when "net" is not equals to "init_net".So when we free "table" in ip6_frags_ns_sysctl_unregister,we should check this first. This patch fix the problem. Signed-off-by: Yang Hongyang <yanghy@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18TI DaVinci EMAC: Fix MDIO bus frequency configurationNageswari Srinivasan
There was a typo in "if condition" checking for validity of MDIO bus frequency passed as part of platform data. Bitwise AND was being used instead of a Logical AND. Tested on: DM6467 EVM Signed-off-by: Nageswari Srinivasan <nageswari@ti.com> Acked-by: Anant Gole <anantgole@ti.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18e100: Fix broken cbs accounting due to missing memset.Roger Oksanen
Alan Stern noticed that e100 caused slab corruption. commit 98468efddb101f8a29af974101c17ba513b07be1 changed the allocation of cbs to use dma pools that don't return zeroed memory, especially the cb->status field used to track which cb to clean, causing (the visible) double freeing of skbs and a wrong free cbs count. Now the cbs are explicitly zeroed at allocation time. Reported-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Roger Oksanen <roger.oksanen@cs.helsinki.fi> Acked-by: Jesse Brandeburg <jesse.brandeburg@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18broadcom: bcm54xx_shadow_read() errors ignored in bcm54xx_adjust_rxrefclk()Roel Kluin
If not signed read errors are ignored. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Acked-by: Matt Carlson <mcarlson@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18e1000e: LED settings in EEPROM ignored on 82571 and 82572Bruce Allan
Do not override the customizable LED configuration set in the EEPROM. Signed-off-by: Bruce Allan <bruce.w.allan@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18netxen: use module parameter correctlyStephen Hemminger
Netxen driver is doing this bogus thing to create a control file. This fails if device doesn't exist, and overall is a bad way to do the module parameter. Rather than fix borked code, just rewrite. Just using a writeable module parameter of 0/1 is the correct way Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-18netns: fix net.ipv6.route.gc_min_interval_ms in netnsAlexey Dobriyan
sysctl table was copied, all right, but ->data for net.ipv6.route.gc_min_interval_ms was not reinitialized for "!= &init_net" case. In init_net everthing works by accident due to correct ->data initialization in source table. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-17Bluetooth: Prevent ill-timed autosuspend in USB driverOliver Neukum
The device must be marked busy as it receives data. Signed-off-by: Oliver Neukum <oliver@neukum.org> Tested-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Fix L2CAP locking scheme regressionAndrei Emeltchenko
When locking was introduced the error path branch was not taken into account. Error was found in sparse code checking. Kudos to Jani Nikula. Signed-off-by: Andrei Emeltchenko <andrei.emeltchenko@nokia.com> Acked-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Ack L2CAP I-frames before retransmit missing packetGustavo F. Padovan
Moving the Ack to before l2cap_retransmit_frame() we can avoid the case where txWindow is full and the packet can't be retransmited. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Fix unset of RemoteBusy flag for L2CAPGustavo F. Padovan
RemoteBusy flag need to be unset before l2cap_ertm_send(), otherwise l2cap_ertm_send() will return without sending packets because it checks that flag before start sending. Signed-off-by: Gustavo F. Padovan <gustavo@las.ic.unicamp.br> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-17Bluetooth: Fix PTR_ERR return of wrong pointer in hidp_setup_hid()Roel Kluin
Return the PTR_ERR of the correct pointer. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
2009-12-15net: sh_eth alignment fix for sh7724 using NET_IP_ALIGN V2Magnus Damm
Fix sh_eth for sh7724 by adding NET_IP_ALIGN support V2. Without this patch the receive data is misaligned. Signed-off-by: Magnus Damm <damm@opensource.se> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-12-15ixgbe: allow tx of pre-formatted vlan tagged packetsGurucharan Shetty
When the 82598 is fed 802.1q packets, it chokes with an error of the form: ixgbe: eth0: ixgbe_tx_csum: partial checksum but proto=81! As the logic there was not smart enough to look into the vlan header to pick out the encapsulated protocol. There are times when we'd like to send these packets out without having to configure a vlan on the interface. Here we check for the vlan tag and allow the packet to go out with the correct hardware checksum. This patch is a clone of a previously submitted patch by Arthur Jones <ajones@riverbed.com> for igb (Commit - fa4a7ef36ec834fee1719636b30d2f28f4cb0166). Signed-off-by: Gurucharan Shetty <gshetty@riverbed.com> Signed-off-by: Arthur Jones <ajones@riverbed.com> Acked-by: Mallikarjuna R Chilakala <mallikarjuna.chilakala@intel.com> Signed-off-by: Jeff Kirsher <jeffrey.t.kirsher@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
