2008-02-28[NETNS]: Process devinet ioctl in the correct namespace.Denis V. Lunev
Add namespace parameter to devinet_ioctl and locate device inside it for state changes. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NETNS]: Register /proc/net/rt_cache for each namespace.Denis V. Lunev
2008-02-28[NETNS]: Process /proc/net/rt_cache inside a namespace.Denis V. Lunev
Show routing cache for a particular namespace only. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[IPV4]: rt_cache_get_next should take rt_genid into account.Denis V. Lunev
In the other case /proc/net/rt_cache will look inconsistent in respect to genid. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Alexey Kuznetsov <kuznet@ms2.inr.ac.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NETNS]: Process ip_rt_redirect in the correct namespace.Denis V. Lunev
2008-02-28[NETNS]: DST cleanup routines should be called inside namespace.Denis V. Lunev
Device inside the namespace can be started and downed. So, active routing cache should be cleaned up on device stop. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NETNS]: Enable inetdev_event notifier.Denis V. Lunev
After all these preparations it is time to enable main IPv4 device initialization routine inside namespace. It is safe do this now. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NETNS]: Disable multicaststing configuration inside non-initial namespace.Denis V. Lunev
Do not calls hooks from device notifiers and disallow configuration from ioctl/netlink layer. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NETNS]: Default arp parameters lookup.Denis V. Lunev
Default ARP parameters should be findable regardless of the context. Required to make inetdev_event working. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NETNS]: Register neighbour table parameters in the correct namespace.Denis V. Lunev
neigh_sysctl_register should register sysctl entries inside correct namespace to avoid naming conflict. Typical example is a loopback. Entries for it present in all namespaces. Required to make inetdev_event working. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NETNS]: Disable inetaddr notifiers in namespaces other than initial.Denis V. Lunev
ip_fib_init is kept enabled. It is already namespace-aware. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[NETFILTER]: Consolidate masq_inet_event and masq_device_event.Denis V. Lunev
They do exactly the same job. Signed-off-by: Denis V. Lunev <den@openvz.org> Acked-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[IPV4]: Remove check for ifa->ifa_dev != NULL.Denis V. Lunev
This is a callback registered to inet address notifier chain. The check is useless as: - ifa->ifa_dev is always != NULL - similar checks are abscent in all other notifiers. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[IPV4]: Remove ifa != NULL check.Denis V. Lunev
This is a callback registered to inet address notifier chain. The check is useless as: - ifa is always != NULL - similar checks are abscent in all other notifiers. Signed-off-by: Denis V. Lunev <den@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[X25]: Use proc_create() to setup ->proc_fops firstWang Chen
Use proc_create() to make sure that ->proc_fops be setup before gluing PDE to main tree. Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[WANROUTER]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[8021Q]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[IPV4]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[IPV6]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[SCTP]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[PKTGEN]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[NEIGHBOUR]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[LLC]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[IPX]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[SUNRPC]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28Merge branch 'pending' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/vxy/lksctp-dev
2008-02-28[ATM]: Use proc_create() to setup ->proc_fops firstWang Chen
2008-02-28[SCTP]: Update AUTH structures to match declarations in draft-16.Vlad Yasevich
The new SCTP socket api (draft 16) updates the AUTH API structures. We never exported these since we knew they would change. Update the rest to match the draft. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-02-28[SCTP]: Incorrect length was used in SCTP_*_AUTH_CHUNKS socket optionVlad Yasevich
The chunks are stored inside a parameter structure in the kernel and when we copy them to the user, we need to account for the parameter header. Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com>
2008-02-28[SCTP]: Clean up naming conventions of sctp protocol/address family registrationNeil Horman
I noticed while looking into some odd behavior in sctp, that the variable name sctp_pf_inet6_specific was used twice to represent two different pieces of data (its both a structure name and a pointer to that type of structure), which is confusing to say the least, and potentially dangerous depending on the variable scope. This patch cleans that up, and makes the protocol and address family registration names in SCTP more regular, increasing readability. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: Vlad Yasevich <vladislav.yasevich@hp.com> ipv6.c | 12 ++++++------ protocol.c | 12 ++++++------ 2 files changed, 12 insertions(+), 12 deletions(-)
2008-02-28[APPLETALK]: Use proc_create() to setup ->proc_fops firstWang Chen
As Davem mentioned in his recently patch (d9595a7b9c777d45a74774f1428c263a0a47f4c0) that the procfs visibility should occur after the ->proc_fops are setup. And also, Alexey provide proc_create() to make sure that ->proc_fops is setup before gluing PDE to main tree. We use proc_create(). Signed-off-by: Wang Chen <wangchen@cn.fujitsu.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: add bnx2x to MAINTAINERSEliezer Tamir
Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: update version, remove CVS stringsEliezer Tamir
2008-02-28[BNX2X]: Fix Xmit bugsEliezer Tamir
Several endianity corrections in start_xmit() Fixed TSO bug where packets were missing the TCP flags. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Prevent PCI queue overflowEliezer Tamir
Limit traffic through an internal queue to prevent overflow. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: fix slowpath races and lockingEliezer Tamir
Fixed locking between fastpath and slowpath operations. Corrected order of traffic disabling to prevent race when going down under traffic. - first have the microcode drop all incoming packets - then do the slowpath stuff - only then reset the MAC Got rid of in_reset_task. Remove_one() and friends would deference a null pointer if init_one failed. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: fix HW attentions and error handlingEliezer Tamir
Some of the HW attentions, used to indicate an error were not properly acked. This will cause the driver to endlessly receive interrupts when such an error happens. Had to break the code into smaller chunks because it got too nested. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: fix MSI-X/INT#A errataEliezer Tamir
Errata A0.158 workaround. Running in INT#A mode after running with MSI-X fails due to a PCI core bug. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: correct statisticsEliezer Tamir
Errors were summed improperly, some stats were missing. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Correct RX filtering and MC configurationEliezer Tamir
The configuration of RX filtering needed the following corrections: Drop flags need to be set per Rx queue. Have to tell the microcode to collect drop stats, and properly wait for them to complete when going down. Sometimes we failed to detect proper completion due to a logical error in the wait loop. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Correct Link managementEliezer Tamir
Properly protect PHY access between two devices on the same board with a HW lock. Use GPIO to clear all previous configurations before changing link parameters. Shut down the external PHY in case of fan failure. Reducing the MDC/MDIO clock to 2.5MHz due to problems with some devices. Resolve the flow control response according to autoneg with external PHY. Unmasking all PHY interrupts in single write to prevent a race in the interrupts order. LASI indication fixes to work with peculiarities of PHYs. Disable MAC RX to avoid a HW bug when closing the MAC under traffic. Disable parallel detection on HiGig due to HW limitation. Updating the shared memory structure to work with the current bootcode. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Correct init_one()Eliezer Tamir
Correct PCI-E info printed by init_one() In one case it failed to free the netdev. Signed-off-by: Eliezer Tamir <eliezert@broadcom.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28[BNX2X]: Spelling fixesEliezer Tamir
2008-02-28[IPCOMP]: Disable BH on output when using shared tfmHerbert Xu
Because we use shared tfm objects in order to conserve memory, (each tfm requires 128K of vmalloc memory), BH needs to be turned off on output as that can occur in process context. Previously this was done implicitly by the xfrm output code. That was lost when it became lockless. So we need to add the BH disabling to IPComp directly. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-02-28Merge branch 'master' of ↵David S. Miller
master.kernel.org:/pub/scm/linux/kernel/git/linville/wireless-2.6
2008-02-28SSB PCI core driver: use new SPROM data structureAurelien Jarno
Switch the SSB PCI core driver to the new SPROM data structure now that the old one has been removed. Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Acked-by: Michael Buesch <mb@bu3sch.de> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28Don't build bcm43xx if SSB is static and b43 PCI-SSB bridge is enabled.Alexey Zaytsev
This may happen e.g. when the ssb is statically enables by the b44 driver, and the b43 pci-ssb bridge is enbled by the b43/b43legacy drivers, or the b43/b43legacy drivers are built statically. Signed-off-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28Use a separate config option for the b43 pci to ssb bridge.Alexey Zaytsev
The bridge code was unnecessary enabled by the b44 driver, but it prevents the bcm43xx driver from being loaded, as the bridge claims the same pci ids. Now we enable the birdge only if the b43{legacy} drivers are selected. Signed-off-by: Alexey Zaytsev <alexey.zaytsev@gmail.com> Acked-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28libertas: Remove unused exportsRoland Dreier
The libertas driver exports a number of symbols with no in-tree users; remove these unused exports. lbs_reset_device() is completely unused, with no callers at all, so remove the function completely. A couple of these unused exported symbols are static, which causes the following build error on ia64 with gcc 4.2.3: drivers/net/wireless/libertas/main.c:1375: error: __ksymtab_lbs_remove_mesh causes a section type conflict drivers/net/wireless/libertas/main.c:1354: error: __ksymtab_lbs_add_mesh causes a section type conflict Signed-off-by: Roland Dreier <rolandd@cisco.com> Acked-by: Holger Schurig <hs4233@mail.mn-solutions.de> Acked-by: Dan Williams <dcbw@redhat.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2008-02-28mac80211: fix kmalloc vs. net_ratelimitJohannes Berg
The "goto end;" part definitely must not be rate limited. Signed-off-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: John W. Linville <linville@tuxdriver.com>
