The general kernel memory allocation functions return void pointers
and there is no need to cast their return values.
Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com>
kmalloc() returns a void pointer, so there is no need to cast it in
drivers/net/irda/kingsun-sir.c::kingsun_probe().
This patch fixes a crash that may occur when the routine dev_mc_sync()
deletes an address from the list it is currently going through. It
saves the pointer to the next element before deleting the current one.
The problem may also exist in dev_mc_unsync().
Signed-off-by: Benjamin Thery <benjamin.thery@bull.net>
Acked-by: Patrick McHardy <kaber@trash.net>
{s,d}_{session,tunnel} in pppol2tp_addr are actually host-endian
everywhere. We might switch them to net-endian, of course, but
that structure is exposed to userland via getname...
Now that the DMA engine has a multi-client interface, fix the ioatdma
driver to play along. At the same time, remove a couple of unnecessary
reads and writes.
Signed-off-by: Shannon Nelson <shannon.nelson@intel.com>
Function declared static in forward declaration, but not in actual code.
Signed-off-by: Stephen Hemminger <shemminger@linux-foundation.org>
More noodlin on long flights, patch bin. Sparse warning fix for eql.
Replacing n & (n - 1) for power of 2 check by is_power_of_2(n)
Signed-off-by: vignesh babu <vignesh.babu@wipro.com>
People often get tripped up by this function and think that
it does not implemented the prescribed algorithms from
RFC2414 and RFC3390, even though it does.
So add a comment to head off such misunderstandings in the
future.
Fix IP[V6]_ADD_MEMBERSHIP and IP[V6]_DROP_MEMBERSHIP to
return -EPROTO for connection oriented sockets.
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
The headers in tc_ematch are used by iproute2, so these headers should
be processed.
In testing our ESP/AH offload hardware, I discovered an issue with how
AH handles mutable fields in IPv4. RFC 4302 (AH) states the following
on the subject:
For IPv4, the entire option is viewed as a unit; so even
though the type and length fields within most options are immutable
in transit, if an option is classified as mutable, the entire option
is zeroed for ICV computation purposes.
The current implementation does not zero the type and length fields,
resulting in authentication failures when communicating with hosts
that do (i.e. FreeBSD).
I have tested record route and timestamp options (ping -R and ping -T)
on a small network involving Windows XP, FreeBSD 6.2, and Linux hosts,
with one router. In the presence of these options, the FreeBSD and
Linux hosts (with the patch or with the hardware) can communicate.
The Windows XP host simply fails to accept these packets with or
without the patch.
I have also been trying to test source routing options (using
traceroute -g), but haven't had much luck getting this option to work
*without* AH, let alone with.
Signed-off-by: Nick Bowler <nbowler@ellipticsemi.com>
runtime limit and wakeup granularity used to be a function of
granularity and that was incorrect changed to sched_latency.
Fix this to make wakeup granularity a function of min-granularity,
and the runtime limit equal to latency.
* git://git.kernel.org/pub/scm/linux/kernel/git/mingo/linux-2.6-sched:
sched: cleanup, sched_granularity -> sched_min_granularity
sched: adaptive scheduler granularity
sched: fix CONFIG_SCHED_DEBUG dependency of lockdep sysctls
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6:
firewire: Add ref-counting for sbp2 orbs (fix command abortion)
firewire: fix unloading of fw-ohci while devices are attached
ieee1394: sbp2: fix sbp2_remove_device for error cases
due to adaptive granularity scheduling the role of sched_granularity
has changed to "minimum granularity", so rename the variable (and the
tunable) accordingly.
Instead of specifying the preemption granularity, specify the wanted
latency. By fixing the granlarity to a constany the wakeup latency
it a function of the number of running tasks on the rq.
Invert this relation.
sysctl_sched_granularity becomes a minimum for the dynamic granularity
computed from the new sysctl_sched_latency.
Then use this latency to do more intelligent granularity decisions: if
there are fewer tasks running then we can schedule coarser. This helps
performance while still always keeping the latency target.
Make the lockdep sysctls not depend on CONFIG_SCHED_DEBUG.
This handles the case where we get the status write before getting the
complete_transaction callback ("status write for unknown orb"). In
this case, we just assume that the initial orb pointer transaction
succeeded and finish the orb. To prevent the transaction callback
from touching freed memory, we ref-count the orb structures.
Signed-off-by: Kristian Høgsberg <krh@redhat.com>
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
Fix panic in run_timer_softirq right after "modprobe -r firewire-ohci"
if a FireWire disk was attached and firewire-sbp2 loaded.
Bug found by Olaf Hering <olh@suse.de>:
sbp2util_remove_command_orb_pool requires a valid lu->hi pointer.
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6
* 'agp-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/agp-2.6:
agp: balance ioremap checks
agp: Add device id for P4M900 to via-agp module
efficeon-agp leaks 'struct agp_bridge_data' in error paths of agp_efficeon_probe()
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6
* 'drm-patches' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6:
drm: ioremap return value checks
drm/via: Fix dmablit when blit queue is full
drm_rmmap_ioctl(): remove dead code
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
* 'upstream-linus' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6:
myri10ge: update driver version to 1.3.2-1.269
myri10ge: use pcie_get/set_readrq
ehea: fix queue destructor
ehea: fix module parameter description
ehea: fix interface to DLPAR tools
sgiseeq: Fix return type of sgiseeq_remove
sky2 1.17
sky2: only bring up watchdog if link is active
sky2: clear PCI power control reg at startup
DM9000: fix interface hang under load
phy layer: fix genphy_setup_forced (don't reset)
Don't use GFP_DMA for zone allocation.
fix realtek phy id in forcedeth
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6
* 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (30 commits)
ACPI: work around duplicate name "VID" problem on T61
acpiphp_ibm: add missing '\n' to error message
ACPI: add dump_stack() to trace acpi_format_exception programming errors
make drivers/acpi/scan.c:create_modalias() static
ACPI: Fix a warning of discarding qualifiers from pointer target type
ACPI: "ACPI handle has no context!" should be KERN_DEBUG
ACPI video hotkey: export missing ACPI video hotkey events via input layer
ACPI: Validate XSDT, use RSDT if XSDT fails
ACPI: /proc/acpi/thermal_zone trip points are now read-only, mark them as such
ACPI: fix ia64 allnoconfig build
PNP: remove null pointer checks
PNP: remove MODULE infrastructure
ISAPNP: removed unused isapnp_detected and ISAPNP_DEBUG
PNPACPI: remove unnecessary casts of "void *"
PNPACPI: simplify irq_flags()
PNP: fix up after Lindent
ACPI: enable GPEs before calling _WAK on resume
asus-laptop: Fix rmmod of asus_laptop
sony-laptop: call sonypi_compat_init earlier
sony-laptop: enable Vaio FZ events
Signed-off-by: Scott Thompson <postfail <at> hushmail.com>
Signed-off-by: Dave Airlie <airlied@linux.ie>
patchset against 2.6.23-rc3.
corrects missing ioremap return checks and balancing on iounmap calls, integrated changes per list
recommendations on the original set of patches..
Update myri10ge driver version to 1.3.2-1.269.
Signed-off-by: Brice Goglin <brice@myri.com>
Signed-off-by: Jeff Garzik <jeff@garzik.org>
Based on a patch from Peter Oruba, convert myri10ge to use pcie_get_readrq()
and pcie_set_readrq() instead of our own PCI calls and arithmetics.
These driver changes incorporate the proposed PCI-X / PCI-Express read byte
count interface. Reading and setting those values doesn't take place
"manually", instead wrapping functions are called to allow quirks for some
PCI bridges.
Signed-off by: Peter Oruba <peter.oruba@amd.com>
Based on work by Stephen Hemminger <shemminger@linux-foundation.org>
Includes hcp_epas_dtor in eq/cq/qp destructors to unmap
HW register.
Signed-off-by: Jan-Bernd Themann <themann@de.ibm.com>
Update the module parameter description of "use_mcs" to
show correct default value
Userspace DLPAR tool expects decimal numbers to be written to
and read from sysfs entries.
The driver remove method needs to return an int not void. This was just
never noticed because usually this driver is not being built as a module.
Mark new version to track if current driver is in use.
This fixes the extra timer overhead that people were whining about
as a 2.6.23 regression.
Running the watchdog timer all the time is unneeded. Change it
to run only if link is up, and reduce frequency to save power.
Make sure PCI register for PHY power gets cleared on boot, and make
sure to avoid any PCI posting problems.
When transferring data at full speed, the DM9000 network interface
sometimes stops sending/receiving data. Worse, ksoftirqd consumes
100% cpu and the net tx watchdog never triggers.
Fix by spin_lock_irqsave() in dm9000_start_xmit() to prevent the
interrupt handler from interfering.
Writing BMCR_RESET bit will reset MII_BMCR to default values. This is
clearly not what we want.
Signed-off-by: Domen Puncer <domen.puncer@telargo.com>
IP32 doesn't even have a ZONE_DMA so no point in using GFP_DMA in any
IP32-specific device driver.
As noticed by Chuck Ebbert, commit c5e3ae8823693b260ce1f217adca8add1bc0b3de
introduced a copy-paste typo, as realtek phy is 0x732 and not 0x1c1. Obvious
fix below suggested by Ayaz Abdulla.
Signed-off-by: Willy Tarreau <w@1wt.eu>
Cc: Ayaz Abdulla <aabdulla@nvidia.com>
Cc: Chuck Ebbert <cebbert@redhat.com>
This can only fix the problem that more than one video bus device
have the same AML name "VID".
ie. the proc I/F for the second "VID" video bus device is located under
/proc/acpi/video/VID1/...
As this is really rare and the ACPI proc I/F is a legacy feature that
we are planning to remove.
We won't provide a generic solution for this problem.
Signed-off-by: Zhang Rui <rui.zhang@intel.com>
Signed-off-by: Len Brown <len.brown@intel.com>
drivers/acpi/video.c
Add missing \n to error in ibm_find_acpi_device.
Signed-off-by: Jeremy Fitzhardinge <jeremy@goop.org>
Cc: Kristen Carlson Accardi <kristen.c.accardi@intel.com>
Cc: Greg Kroah-Hartman <gregkh@suse.de>
Cc: Adrian Bunk <trivial@kernel.org>
Dump the stack so we can find the secretive caller to acpi_format_exception().
This patch makes the needlessly global create_modalias() static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
drivers/acpi/ec.c: In function `acpi_ec_ecdt_probe':
drivers/acpi/ec.c:873: warning: passing arg 1 of `acpi_get_devices' discards qualifiers from pointer target type
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
