2010-03-10rndis_wlan: Implement cfg80211 PMKSA APIJussi Kivilinna
Add support for cfg80211 set_pmksa/del_pmksa/flush_pmksa. Updating PMKID entry list is done on driver side since NDIS API requires full list update. v2: - fixed to use new netdev_dbg/warn/etc instead of old devdbg/warn/etc - fixed false padding from struct ndis_80211_bssid_info Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10rndis_wlan: get max_num_pmkids from deviceJussi Kivilinna
Extend rndis_wlan_get_caps() to get 802.11 capabilities and maximum supported number of PMKIDs by device. v2: fixed to use new netdev_dbg/warn/etc instead of old devdbg/warn/etc Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10rndis_wlan: remove unused variables from priv structureJussi Kivilinna
Some variables were left unused after cfg80211 conversion. Remove those and related deadcode. Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10rndis_wlan: copy only useful data from rndis_command respondJussi Kivilinna
rndis_query_oid() uses full output buffer size to copy response buffer from rndis_command()/device. This doesn't cause problems as response buffer is sized based on output buffer but does copy extra unset bytes. So change rndis_query_oid() so that only meaningful bytes are being copied. Also in case of malfunctioning device/cable/etc returned data offset from device might be wrong so bound check memory access correctly, so add checks for this. v2: fixed to use new netdev_dbg/warn/etc instead of old devdbg/warn/etc Signed-off-by: Jussi Kivilinna <jussi.kivilinna@mbnet.fi> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10minstrel: make the rate control ops reusable from another rc implementationFelix Fietkau
This patch makes it possible to reuse the minstrel rate control ops from another rate control module. This is useful in preparing for the new 802.11n implementation of minstrel, which will reuse the old code for legacy stations. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10minstrel: simplify and fix debugfs codeFelix Fietkau
This patch cleans up the debugfs read function for the statistics by using simple_read_from_buffer instead of its own semi-broken hack. Also removes a useless member of the minstrel debugfs info struct. Signed-off-by: Felix Fietkau <nbd@openwrt.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10ath5k: Fix TX/RX padding for all framesBenoit Papillault
Currently, the padding position is based on ieee80211_get_hdrlen_from_skb(). This is not correct since the HW does padding on RX (and expect the same padding to be present on TX) at the following position : - management : 24 + 6 if 4-addr format - control : 24 + 6 if 4-addr format - data : 24 + 6 if 4-addr format + 2 if QoS - invalid : 24 + 6 if 4-addr format whereas ieee80211_get_hdrlen_from_skb() is : - management : 24 - control : 16 except for ACK/CTS where it is 10 - data : 24 + 6 if 4-addr format + 2 if QoS + 2 if QoS & order - invalid : 24 So, correct frames are not affected : management frames do not use 4-addr format, control frames have no body and invalid frames are ... not valid by definition. However, in order to use monitor interface for debugging purpose, one must be able to send/receive any frames, be it correct or not. Such frames are affected by incorrect padding. Moreover, since padding is added on TX, we need to remove it before calling ieee80211_tx_status. This affect TX packets received by monitor interfaces. It has been tested between an ath5k based card (AR5212) and an ar9170usb based card (netgear WNDA3100) using a frame generator and a monitor interface for each card. v2: Added ath5k_add_padding / ath5k_remove_padding Signed-off-by: Benoit Papillault <benoit.papillault@free.fr> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10mac80211: give warning if building w/out rate ctrl algorithmAndres Salomon
I discovered that if EMBEDDED=y, one can accidentally build a mac80211 stack and drivers w/ no rate control algorithm. For drivers like RTL8187 that don't supply their own RC algorithms, this will cause ieee80211_register_hw to fail (making the driver unusable). This will tell kconfig to provide a warning if no rate control algorithms have been selected. That'll at least warn the user; users that know that their drivers supply a rate control algorithm can safely ignore the warning, and those who don't know (or who expect to be using multiple drivers) can select a default RC algorithm. Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Cc: stable@kernel.org Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10iwmc3200wifi: typo fix and code cleanupZhu Yi
Fix wrong IWM_RX_TICKET_DROP_REASON_MSK macro define, typo and other small cleanups. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10iwmc3200wifi: mark some pmksa functions staticZhu Yi
This fixes the sparse warnings. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10iwmc3200wifi: increase concatenated bufferZhu Yi
Increase concatenated buffer from 8K to 32K to get better performance. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10iwmc3200wifi: protect rx_tickets and rx_packets[] listsZhu Yi
Protect rx_tickets and rx_packets[] lists with spinlocks to fix the race condition for concurrent list operations. In iwmc3200wifi both sdio_isr_worker and rx_worker workqueues can access the rx ticket and packets lists at the same time under high rx load. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10iwmc3200wifi: add ftrace event tracing supportZhu Yi
Add event tracer for iwmc3200wifi driver. When enabled, all the commands and responses between the driver and firmware (also including Tx/Rx frames) will be recorded in the ftrace ring buffer. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10iwmc3200wifi: remove "_safe" for some list_for_each_entry usageZhu Yi
Use list_for_each_entry instead of list_for_each_entry_safe in places iteration against list entry removal is not required. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10iwmc3200wifi: refuse to associate on unallowed channelsZhu Yi
We need to make sure we don't associate with APs on unallowed channels (according to regulatory setting). This could happen when the channel is not specified (auto-select) within the connection request. In this case we get the AP's channel until the firmware indicates the association succeeded later. We need to verify the associated channel. If the channel is disabled by regulatory, we have to disassociate with the AP. Signed-off-by: Zhu Yi <yi.zhu@intel.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10enhance sysfs rfkill interfaceflorian@mickler.org
This commit introduces two new sysfs knobs. /sys/class/rfkill/rfkill[0-9]+/blocked_hw: (ro) hardblock kill state /sys/class/rfkill/rfkill[0-9]+/blocked_sw: (rw) softblock kill state Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-10Document the rfkill sysfs ABIflorian@mickler.org
This moves sysfs ABI info from Documentation/rfkill.txt to the ABI subfolder and reformats it. This also schedules the deprecated sysfs parts to be removed in 2012 (claim file) and 2014 (state file). Signed-off-by: Florian Mickler <florian@mickler.org> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-09iwl3945: check ucode load error codeAbhijeet Kolekar
Check successful completion of BSM loading. Give a chance to load BSM again. If BSM loading is unsuccessful we should exit and not initilize NIC. Before this checking even if the BSM loading failed driver tries to initilize the NIC which should not be the case. Signed-off-by: Abhijeet Kolekar <abhijeet.kolekar@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: clean up queue/fifo handlingJohannes Berg
4965 hardware has 7 queues reserved and the remaining ones used for aggregation, 5000 and higher need to have 10 reserved. This is not very clear in the code right now, unfortunately. Introduce a new IWL_TX_FIFO_UNUSED constant and make the queue/FIFO mapping arrays able to hold that value, and change the setup code to reserve all queues in the arrays (the queue number is the index) and use the new unused constant to not map those queues to any FIFO. Additionally, clear up the AC/queue mapping code to be more understandable. The mapping is the identity mapping right now, but with the mapping function I think it's easier to understand what happens there. Finally, HCCA isn't implemented at all and I think newer microcode removed it, so let's remove all mention of it in the code, some comments remain for 4965. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Acked-by: Shanyu Zhao <shanyu.zhao@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: add internal short scan support for 3945Wey-Yi Guy
Add internal short scan support for 3945 NIC, This allows 3945 NIC to support radio reset request like the other series of NICs. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove unnecessary parameter in scan functionWey-Yi Guy
small change to remove unnecessary "ret" parameter since it not being used. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove duplicate functionWey-Yi Guy
"internal_scan" debugfs function serves the same propose of mode "0" of "force_reset" debugfs function. Remove it to avoid duplicate. Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove needlessly exported symbolsReinette Chatre
iwl_apm_stop_master and iwl_internal_short_hw_scan are only used within iwlcore and thus do not need to be exported. Reported-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: change WEP key protection to use mutexJohannes Berg
For later station notification support we would like WEP key setting to be done synchronously always. Currently all places from which WEP key is set can sleep, but the usage of sta_lock prevents it to do so. Modify the locking to use priv->mutex instead and thus enable this call to sleep. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove un-necessary parametersWey-Yi Guy
small code cleanup to remove un-necessary parameters Signed-off-by: Wey-Yi Guy <wey-yi.w.guy@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlagn: move sysfs flags and filter_flags files to debugfsJohannes Berg
These files are incompatible with some changes I'm making, and don't really belong into sysfs anyway as they can only be used for debugging. Since writing them will probably crash the firmware, keep only the reading part and move them into debugfs. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove STATUS_MODE_PENDINGJohannes Berg
Since rfkill integration, mac80211 can no longer add an interface while the hardware is not ready, so STATUS_MODE_PENDING can never be set. Also, remove another superfluous channel sanity check and return the commit_rxon return value in case it failed. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove alive start adhoc restartJohannes Berg
This code will never trigger, because when we call this during interface start, neither priv->vif nor priv->iw_mode conditions will be true, and when it happens during reset then priv->vif is also NULL. Also, in both cases the same code will be executed as part of iwl_bss_info_changed(), which contains a copy of this code. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: move 3945 clip groups to 3945 dataJohannes Berg
Only used on 3945, so it can be in the 3945-specific part of the data. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: clear up AC/FIFO debug outputJohannes Berg
Not all queues are mapped for frame transmission, so saying "AC" is misleading. They are all mapped to FIFOs, obviously, though, so use that term and also say AC/CMD instead of just AC for the queue type. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove sanity checkJohannes Berg
iwl_mac_beacon_update can only be called when the operating mode is IBSS, so it doesn't need to verify that again. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove IBSS channel sanity checkJohannes Berg
mac80211 will always enforce using a channel that the driver allowed for IBSS use. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove priv->active_rate_basicJohannes Berg
This variable is assigned a default value, but then assigned zero as soon as mac80211 calls a change channel (which will happen right after the hw is started) and after that it never changes again. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove never-changing priv->rates_mask variableJohannes Berg
It's always just IWL_RATES_MASK. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove frame droppingJohannes Berg
With some of the new code in mac80211, public action frames can be exchanged as non-injected frames even while not associated. Aside from that, dropping frames here is pointless since we do deal with arbitrary frames that were injected already, so let mac80211 make the decision about which frames to allow or not. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove dead code from iwl_mac_reset_tsfJohannes Berg
iwl_mac_reset_tsf will only ever be called in IBSS mode, so checking for other modes is not useful and the code that depends on that will not be executed. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: remove superfluous channel checkJohannes Berg
mac80211 will not allow using channels not marked as allowing IBSS for IBSS mode. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlagn: remove write-only variablesJohannes Berg
Updating the variables last_rx_rssi, last_tsf and last_beacon_time needs a lot of code but they are not actually used in iwlagn (only in 3945) so we can move them to the 3945 specific data. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: move ICT data to agn part of unionJohannes Berg
Since the ICT data is all AGN specific, it can be the first data to create the _agn part of the device-specific union in the priv struct. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlwifi: move 3945 specific data into unionJohannes Berg
To be obviously correct, this patch only modifies 3945 files and the struct definition. A follow-up patch will create the AGN part of the union. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09iwlagn: move ICT code into separate fileJohannes Berg
All the ICT ISR code is iwlagn specific, and doesn't need to be in iwlcore. So create a new iwl-agn.h header file that will hold agn specific function declarations etc., and move the ICT code into a new iwl-agn-ict.c file that is linked into iwlagn. This also gets rid of exporting those symbols. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Reinette Chatre <reinette.chatre@intel.com>
2010-03-09b43: N-PHY: switch to chanspec opsRafał Miłecki
Signed-off-by: Rafał Miłecki <zajec5@gmail.com> Signed-off-by: John W. Linville <linville@tuxdriver.com>
2010-03-09b43: N-PHY: implement chanspec setupRafał Miłecki
2010-03-09b43: N-PHY: isloate 2055 radio setupRafał Miłecki
2010-03-09b43: N-PHY: adjust gain tableRafał Miłecki
2010-03-09b43: N-PHY: switch to chanspec structRafał Miłecki
2010-03-09b43: N-PHY: update post init of 2055 radioRafał Miłecki
2010-03-09b43: N-PHY: update writing channel-specific radio registersRafał Miłecki
2010-03-09b43: N-PHY: turn radio on/off (rfkill)Rafał Miłecki
2010-03-09b43: N-PHY: initialize super switchRafał Miłecki
