2010-11-18x86: Add RO/NX protection for loadable kernel modulesmatthieu castet
This patch is a logical extension of the protection provided by CONFIG_DEBUG_RODATA to LKMs. The protection is provided by splitting module_core and module_init into three logical parts each and setting appropriate page access permissions for each individual section: 1. Code: RO+X 2. RO data: RO+NX 3. RW data: RW+NX In order to achieve proper protection, layout_sections() have been modified to align each of the three parts mentioned above onto page boundary. Next, the corresponding page access permissions are set right before successful exit from load_module(). Further, free_module() and sys_init_module have been modified to set module_core and module_init as RW+NX right before calling module_free(). By default, the original section layout and access flags are preserved. When compiled with CONFIG_DEBUG_SET_MODULE_RONX=y, the patch will page-align each group of sections to ensure that each page contains only one type of content and will enforce RO/NX for each group of pages. -v1: Initial proof-of-concept patch. -v2: The patch have been re-written to reduce the number of #ifdefs and to make it architecture-agnostic. Code formatting has also been corrected. -v3: Opportunistic RO/NX protection is now unconditional. Section page-alignment is enabled when CONFIG_DEBUG_RODATA=y. -v4: Removed most macros and improved coding style. -v5: Changed page-alignment and RO/NX section size calculation -v6: Fixed comments. Restricted RO/NX enforcement to x86 only -v7: Introduced CONFIG_DEBUG_SET_MODULE_RONX, added calls to set_all_modules_text_rw() and set_all_modules_text_ro() in ftrace -v8: updated for compatibility with linux 2.6.33-rc5 -v9: coding style fixes -v10: more coding style fixes -v11: minor adjustments for -tip -v12: minor adjustments for v2.6.35-rc2-tip -v13: minor adjustments for v2.6.37-rc1-tip Signed-off-by: Siarhei Liakh <sliakh.lkml@gmail.com> Signed-off-by: Xuxian Jiang <jiang@cs.ncsu.edu> Acked-by: Arjan van de Ven <arjan@linux.intel.com> Reviewed-by: James Morris <jmorris@namei.org> Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Andi Kleen <ak@muc.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Dave Jones <davej@redhat.com> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4CE2F914.9070106@free.fr> [ minor cleanliness edits, -v14: build failure fix ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-18x86: Add NX protection for kernel dataMatthieu Castet
This patch expands functionality of CONFIG_DEBUG_RODATA to set main (static) kernel data area as NX. The following steps are taken to achieve this: 1. Linker script is adjusted so .text always starts and ends on a page bound 2. Linker script is adjusted so .rodata always start and end on a page boundary 3. NX is set for all pages from _etext through _end in mark_rodata_ro. 4. free_init_pages() sets released memory NX in arch/x86/mm/init.c 5. bios rom is set to x when pcibios is used. The results of patch application may be observed in the diff of kernel page table dumps: pcibios: -- data_nx_pt_before.txt 2009-10-13 07:48:59.000000000 -0400 ++ data_nx_pt_after.txt 2009-10-13 07:26:46.000000000 -0400 0x00000000-0xc0000000 3G pmd ---[ Kernel Mapping ]--- -0xc0000000-0xc0100000 1M RW GLB x pte +0xc0000000-0xc00a0000 640K RW GLB NX pte +0xc00a0000-0xc0100000 384K RW GLB x pte -0xc0100000-0xc03d7000 2908K ro GLB x pte +0xc0100000-0xc0318000 2144K ro GLB x pte +0xc0318000-0xc03d7000 764K ro GLB NX pte -0xc03d7000-0xc0600000 2212K RW GLB x pte +0xc03d7000-0xc0600000 2212K RW GLB NX pte 0xc0600000-0xf7a00000 884M RW PSE GLB NX pmd 0xf7a00000-0xf7bfe000 2040K RW GLB NX pte 0xf7bfe000-0xf7c00000 8K pte No pcibios: -- data_nx_pt_before.txt 2009-10-13 07:48:59.000000000 -0400 ++ data_nx_pt_after.txt 2009-10-13 07:26:46.000000000 -0400 0x00000000-0xc0000000 3G pmd ---[ Kernel Mapping ]--- -0xc0000000-0xc0100000 1M RW GLB x pte +0xc0000000-0xc0100000 1M RW GLB NX pte -0xc0100000-0xc03d7000 2908K ro GLB x pte +0xc0100000-0xc0318000 2144K ro GLB x pte +0xc0318000-0xc03d7000 764K ro GLB NX pte -0xc03d7000-0xc0600000 2212K RW GLB x pte +0xc03d7000-0xc0600000 2212K RW GLB NX pte 0xc0600000-0xf7a00000 884M RW PSE GLB NX pmd 0xf7a00000-0xf7bfe000 2040K RW GLB NX pte 0xf7bfe000-0xf7c00000 8K pte The patch has been originally developed for Linux 2.6.34-rc2 x86 by Siarhei Liakh <sliakh.lkml@gmail.com> and Xuxian Jiang <jiang@cs.ncsu.edu>. -v1: initial patch for 2.6.30 -v2: patch for 2.6.31-rc7 -v3: moved all code into arch/x86, adjusted credits -v4: fixed ifdef, removed credits from CREDITS -v5: fixed an address calculation bug in mark_nxdata_nx() -v6: added acked-by and PT dump diff to commit log -v7: minor adjustments for -tip -v8: rework with the merge of "Set first MB as RW+NX" Signed-off-by: Siarhei Liakh <sliakh.lkml@gmail.com> Signed-off-by: Xuxian Jiang <jiang@cs.ncsu.edu> Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Morris <jmorris@namei.org> Cc: Andi Kleen <ak@muc.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Dave Jones <davej@redhat.com> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4CE2F82E.60601@free.fr> [ minor cleanliness edits ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-18x86: Fix improper large page preservationmatthieu castet
This patch fixes a bug in try_preserve_large_page() which may result in improper large page preservation and improper application of page attributes to the memory area outside of the original change request. More specifically, the problem manifests itself when set_memory_*() is called for several pages at the beginning of the large page and try_preserve_large_page() erroneously concludes that the change can be applied to whole large page. The fix consists of 3 parts: 1. Addition of "required" protection attributes in static_protections(), so .data and .bss can be guaranteed to stay "RW" 2. static_protections() is now called for every small page within large page to determine compatibility of new protection attributes (instead of just small pages within the requested range). 3. Large page can be preserved only if attribute change is large-page-aligned and covers whole large page. -v1: Try_preserve_large_page() patch for Linux 2.6.34-rc2 -v2: Replaced pfn check with address check for kernel rw-data Signed-off-by: Siarhei Liakh <sliakh.lkml@gmail.com> Signed-off-by: Xuxian Jiang <jiang@cs.ncsu.edu> Reviewed-by: Suresh Siddha <suresh.b.siddha@intel.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: James Morris <jmorris@namei.org> Cc: Andi Kleen <ak@muc.de> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Dave Jones <davej@redhat.com> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> LKML-Reference: <4CE2F7F3.8030809@free.fr> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-11-15Linux 2.6.37-rc2v2.6.37-rc2Linus Torvalds
2010-11-15capabilities/syslog: open code cap_syslog logic to fix build failureEric Paris
The addition of CONFIG_SECURITY_DMESG_RESTRICT resulted in a build failure when CONFIG_PRINTK=n. This is because the capabilities code which used the new option was built even though the variable in question didn't exist. The patch here fixes this by moving the capabilities checks out of the LSM and into the caller. All (known) LSMs should have been calling the capabilities hook already so it actually makes the code organization better to eliminate the hook altogether. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: James Morris <jmorris@namei.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-15Merge branch 'omap-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6 * 'omap-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tmlind/linux-omap-2.6: arm: omap1: devices: need to return with a value OMAP1: camera.h: add missing include omap: dma: Add read-back to DMA interrupt handler to avoid spuriousinterrupts OMAP2: Devkit8000: Fix mmc regulator failure
2010-11-15Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (w83795) Check for BEEP pin availability hwmon: (w83795) Clear intrusion alarm immediately hwmon: (w83795) Read the intrusion state properly hwmon: (w83795) Print the actual temperature channels as sources hwmon: (w83795) List all usable temperature sources hwmon: (w83795) Expose fan control method hwmon: (w83795) Fix fan control mode attributes hwmon: (lm95241) Check validity of input values hwmon: Change mail address of Hans J. Koch
2010-11-15Merge branch 'i2c-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'i2c-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: i2c: Sanity checks on adapter registration i2c: Mark i2c_adapter.id as deprecated i2c: Drivers shouldn't include <linux/i2c-id.h> i2c: Delete unused adapter IDs i2c: Remove obsolete cleanup for clientdata
2010-11-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: PCI: sysfs: fix printk warnings PCI: fix pci_bus_alloc_resource() hang, prefer positive decode PCI: read current power state at enable time PCI: fix size checks for mmap() on /proc/bus/pci files x86/PCI: coalesce overlapping host bridge windows PCI hotplug: ibmphp: Add check to prevent reading beyond mapped area
2010-11-15i2c: Sanity checks on adapter registrationJean Delvare
Make sure I2C adapters being registered have the required struct fields set. If they don't, problems will happen later. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-11-15i2c: Mark i2c_adapter.id as deprecatedJean Delvare
It's about time to make it clear that i2c_adapter.id is deprecated. Hopefully this will remind the last user to move over to a different strategy. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jarod Wilson <jarod@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
2010-11-15i2c: Drivers shouldn't include <linux/i2c-id.h>Jean Delvare
Drivers don't need to include <linux/i2c-id.h>, especially not when they don't use anything that header file provides. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Michael Hunold <michael@mihu.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-11-15i2c: Delete unused adapter IDsJean Delvare
Delete unused I2C adapter IDs. Special cases are: * I2C_HW_B_RIVA was still set in driver rivafb, however no other driver is ever looking for this value, so we can safely remove it. * I2C_HW_B_HDPVR is used in staging driver lirc_zilog, however no adapter ID is ever set to this value, so the code in question never runs. As the code additionally expects that I2C_HW_B_HDPVR may not be defined, we can delete it now and let the lirc_zilog driver maintainer rewrite this piece of code. Big thanks for Hans Verkuil for doing all the hard work :) Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Jarod Wilson <jarod@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
2010-11-15i2c: Remove obsolete cleanup for clientdataWolfram Sang
A few new i2c-drivers came into the kernel which clear the clientdata-pointer on exit. This is obsolete meanwhile, so fix it and hope the word will spread. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Alan Cox <alan@linux.intel.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-11-15include/linux/kernel.h: Move logging bits to include/linux/printk.hLinus Torvalds
Move the logging bits from kernel.h into printk.h so that there is a bit more logical separation of the generic from the printk logging specific parts. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-15Fix gcc 4.5.1 miscompiling drivers/char/i8k.c (again)Jim Bos
The fix in commit 6b4e81db2552 ("i8k: Tell gcc that *regs gets clobbered") to work around the gcc miscompiling i8k.c to add "+m (*regs)" caused register pressure problems and a build failure. Changing the 'asm' statement to 'asm volatile' instead should prevent that and works around the gcc bug as well, so we can remove the "+m". [ Background on the gcc bug: a memory clobber fails to mark the function the asm resides in as non-pure (aka "__attribute__((const))"), so if the function does nothing else that triggers the non-pure logic, gcc will think that that function has no side effects at all. As a result, callers will be mis-compiled. Adding the "+m" made gcc see that it's not a pure function, and so does "asm volatile". The problem was never really the need to mark "*regs" as changed, since the memory clobber did that part - the problem was just a bug in the gcc "pure" function analysis - Linus ] Signed-off-by: Jim Bos <jim876@xs4all.nl> Acked-by: Jakub Jelinek <jakub@redhat.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-15hwmon: (w83795) Check for BEEP pin availabilityJean Delvare
On the W83795ADG, there's a single pin for BEEP and OVT#, so you can't have both. Check the configuration and don't create beep attributes when BEEP pin is not available. The W83795G has a dedicated BEEP pin so the functionality is always available there. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-15hwmon: (w83795) Clear intrusion alarm immediatelyJean Delvare
When asked to clear the intrusion alarm, do so immediately. We have to invalidate the cache to make sure the new status will be read. But we also have to read from the status register once to clear the pending alarm, as writing to CLR_CHS surprising won't clear it automatically. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-15hwmon: (w83795) Read the intrusion state properlyJean Delvare
We can't read the intrusion state from the real-time alarm registers as we do for all other alarm flags, because real-time alarm bits don't stick (by definition) and the intrusion state has to stick until explicitly cleared (otherwise it has little value.) So we have to use the interrupt status register instead, which is read from the same address but with a configuration bit flipped in another register. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-15hwmon: (w83795) Print the actual temperature channels as sourcesJean Delvare
Don't expose raw register values to user-space. Decode and encode temperature channels selected as temperature sources as needed. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-15hwmon: (w83795) List all usable temperature sourcesJean Delvare
Temperature sources are not correlated directly with temperature channels. A look-up table is required to find out which temperature sources can be used depending on which temperature channels (both analog and digital) are enabled. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-15hwmon: (w83795) Expose fan control methodJean Delvare
Expose fan control method (DC vs. PWM) using the standard sysfs attributes. I've made it read-only as the board should be wired for a given mode, the BIOS should have set up the chip for this mode, and you shouldn't have to change it. But it would be easy enough to make it changeable if someone comes up with a use case. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-15hwmon: (w83795) Fix fan control mode attributesJean Delvare
There were two bugs: * Speed cruise mode was improperly reported for all fans but fan1. * Fan control method (PWM vs. DC) was mixed with the control mode. It will be added back as a separate attribute, as per the standard sysfs interface. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com>
2010-11-15hwmon: (lm95241) Check validity of input valuesJean Delvare
This clears the following build-time warnings I was seeing: drivers/hwmon/lm95241.c: In function "set_interval": drivers/hwmon/lm95241.c:132:15: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_max2": drivers/hwmon/lm95241.c:278:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_max1": drivers/hwmon/lm95241.c:277:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_min2": drivers/hwmon/lm95241.c:249:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_min1": drivers/hwmon/lm95241.c:248:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_type2": drivers/hwmon/lm95241.c:220:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result drivers/hwmon/lm95241.c: In function "set_type1": drivers/hwmon/lm95241.c:219:1: warning: ignoring return value of "strict_strtol", declared with attribute warn_unused_result This also fixes a small race in set_interval() as a side effect: by working with a temporary local variable we prevent data->interval from being accessed at a time it contains the interval value in the wrong unit. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Davide Rizzo <elpa.rizzo@gmail.com>
2010-11-15hwmon: Change mail address of Hans J. KochHans J. Koch
My old mail address doesn't exist anymore. This changes all occurrences to my new address. Signed-off-by: Hans J. Koch <hjk@hansjkoch.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-11-15PCI: sysfs: fix printk warningsRandy Dunlap
Cast pci_resource_start() and pci_resource_len() to u64 for printk. drivers/pci/pci-sysfs.c:753: warning: format '%16Lx' expects type 'long long unsigned int', but argument 9 has type 'resource_size_t' drivers/pci/pci-sysfs.c:753: warning: format '%16Lx' expects type 'long long unsigned int', but argument 10 has type 'resource_size_t' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org>
2010-11-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixesLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/steve/gfs2-2.6-fixes: GFS2: Fix inode deallocation race
2010-11-15Merge branch 's5p-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung * 's5p-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/kgene/linux-samsung: ARM: SAMSUNG: Fix HAVE_S3C_RTC warnings ARM: SAMSUNG: Fix HAVE_S3C2410_I2C warnings ARM: SAMSUNG: Fix HAVE_S3C2410_WATCHDOG warnings
2010-11-15Merge branch 'fbdev-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6 * 'fbdev-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/fbdev-2.6: fsl-diu-fb: drop dead ioctl define MAINTAINERS: Add an fbdev git tree entry. OMAP: DSS: Fix documentation regarding 'vram' kernel parameter OMAP: VRAM: Fix boot-time memory allocation OMAP: VRAM: improve VRAM error prints sisfb: limit POST memory test according to PCI resource length fbdev: sh_mobile_lcdc: use correct number of modes, when using the default fbdev: sh_mobile_lcdc: use the standard CEA-861 720p timing fbdev: sh_mobile_hdmi: properly clean up modedb on monitor unplug
2010-11-15Merge branches 'sh-fixes-for-linus' and 'rmobile-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6 * 'sh-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: sh: intc: Fix up build failure introduced by radix tree changes. MAINTAINERS: update the sh git tree entry. sh: clkfwk: fix up compiler warnings. sh: intc: Fix up initializers for gcc 4.5. rtc: rtc-sh - fix a memory leak * 'rmobile-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lethal/sh-2.6: ARM: mach-shmobile: ap4evb: add fsib 44100Hz rate MAINTAINERS: update the ARM SH-Mobile git tree entry. ARM: mach-shmobile: ap4evb: Mark NOR boot loader partitions read-only. ARM: mach-shmobile: intc-sh7372: fix interrupt number
2010-11-15GFS2: Fix inode deallocation raceSteven Whitehouse
This area of the code has always been a bit delicate due to the subtleties of lock ordering. The problem is that for "normal" alloc/dealloc, we always grab the inode locks first and the rgrp lock later. In order to ensure no races in looking up the unlinked, but still allocated inodes, we need to hold the rgrp lock when we do the lookup, which means that we can't take the inode glock. The solution is to borrow the technique already used by NFS to solve what is essentially the same problem (given an inode number, look up the inode carefully, checking that it really is in the expected state). We cannot do that directly from the allocation code (lock ordering again) so we give the job to the pre-existing delete workqueue and carry on with the allocation as normal. If we find there is no space, we do a journal flush (required anyway if space from a deallocation is to be released) which should block against the pending deallocations, so we should always get the space back. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2010-11-15Merge branch 'rmobile/core' into rmobile-fixes-for-linusPaul Mundt
2010-11-15ARM: mach-shmobile: ap4evb: add fsib 44100Hz rateKuninori Morimoto
Tested-by: Tony SIM <chinyeow.sim.xt@renesas.com> Tested-by: TAKEI Mitsuharu <takei.andr@gmail.com> Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-15sh: intc: Fix up build failure introduced by radix tree changes.Paul Mundt
The radix tree retry logic got a bit of an overhaul and subsequently broke the virtual IRQ subgroup build. Simply switch over to radix_tree_deref_retry() as per the filemap changes, which the virq lookup logic was modelled after in the first place. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-15Merge branch 'master' of ↵Paul Mundt
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into sh/urgent
2010-11-15fsl-diu-fb: drop dead ioctl defineMike Frysinger
The fsl-diu-fb driver no longer uses this define, and we have a common one to cover this already (FBIO_WAITFORVSYNC). Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-15MAINTAINERS: Add an fbdev git tree entry.Paul Mundt
Now that there's an fbdev git tree (this is also what is pulled in to -next), stub it in to the MAINTAINERS entry. Signed-off-by: Paul Mundt <lethal@linux-sh.org>
2010-11-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/penberg/slab-2.6: slub: Fix slub_lock down/up imbalance
2010-11-14Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2: Change some lock status member in ocfs2_lock_res to char.
2010-11-14slub: Fix slub_lock down/up imbalancePavel Emelyanov
There are two places, that do not release the slub_lock. Respective bugs were introduced by sysfs changes ab4d5ed5 (slub: Enable sysfs support for !CONFIG_SLUB_DEBUG) and 2bce6485 ( slub: Allow removal of slab caches during boot). Acked-by: Christoph Lameter <cl@linux.com> Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: Pekka Enberg <penberg@kernel.org>
2010-11-13Merge branch 'urgent' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6 * 'urgent' of git://git.kernel.org/pub/scm/linux/kernel/git/brodo/pcmcia-2.6: drivers/pcmcia/soc_common.c: Use printf extension %pV pcmcia: fix warning in synclink driver pcmcia/sa1100: don't put machine specific init functions in .init.text pcmcia/cm4000: fix error code pd6729: Coding Style fixes
2010-11-13Revert "8250: Fix tcsetattr to avoid ioctl(TIOCMIWAIT) hang"Ingo Molnar
This reverts commit 47d3904fe40d62deee8cd46e79ca784e7a548acd. Crashes any x86 serial console bootup: Console: colour VGA+ 80x25 BUG: unable to handle kernel NULL pointer dereference at 0000000000000158 IP: [<ffffffff811ebcb4>] serial8250_do_set_termios+0x1d4/0x430 ... Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Greg KH <gregkh@suse.de> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-13Merge git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/herbert/crypto-2.6: crypto: padlock - Fix AES-CBC handling on odd-block-sized input crypto: n2 - dubious error check
2010-11-13Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: [media] soc-camera: Compile fixes for mx2-camera [media] SoC Camera: ov6650: minor cleanups [media] SOC Camera: OMAP1: typo fix [media] SoC Camera: OMAP1: update for recent videobuf changes [media] SoC Camera: OMAP1: update for recent framework changes [media] ARM mx3_camera: check for DMA engine type [media] tm6000: bugfix set tv standards [media] cafe_ccic: fix subdev configuration [media] saa7134: Fix autodetect for Behold A7 and H7 TV cards [media] v4l: kill the BKL [media] BZ#22292: dibx000_common: Restore i2c algo pointer
2010-11-13i8k: Tell gcc that *regs gets clobberedJim Bos
More recent GCC caused the i8k driver to stop working, on Slackware compiler was upgraded from gcc-4.4.4 to gcc-4.5.1 after which it didn't work anymore, meaning the driver didn't load or gave total nonsensical output. As it turned out the asm(..) statement forgot to mention it modifies the *regs variable. Credits to Andi Kleen and Andreas Schwab for providing the fix. Signed-off-by: Jim Bos <jim876@xs4all.nl> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andreas Schwab <schwab@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-13ACPI: debugfs custom_method open to non-rootDave Jones
Currently we have: --w--w--w-. 1 root root 0 2010-11-11 14:56 /sys/kernel/debug/acpi/custom_method which is just crazy. Change this to --w-------. Signed-off-by: Dave Jones <davej@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com> Cc: stable@kernel.org (for 2.6.36) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-13ocfs2: Change some lock status member in ocfs2_lock_res to char.Tao Ma
Commit 83fd9c7 changes l_level, l_requested and l_blocking of ocfs2_lock_res from int to unsigned char. But actually it is initially as -1(ocfs2_lock_res_init_common) which correspoding to 255 for unsigned char. So the whole dlm lock mechanism doesn't work now which means a disaster to ocfs2. Cc: Goldwyn Rodrigues <rgoldwyn@suse.de> Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-11-13ARM: SAMSUNG: Fix HAVE_S3C_RTC warningsKukjin Kim
This patch fixes followng build warnings. warning: (ARCH_S5P64X0 && <choice> || ARCH_S5PC100 && <choice> || ARCH_S5PV210 && <choice> || ARCH_S5PV310 && <choice>) selects HAVE_S3C_RTC which has unmet direct dependencies (RTC_CLASS) Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-11-13ARM: SAMSUNG: Fix HAVE_S3C2410_I2C warningsKukjin Kim
This patch fixes following warnings. warning: (ARCH_S3C2410 && <choice> || ARCH_S3C64XX && <choice> || ARCH_S5P64X0 && <choice> || ARCH_S5PC100 && <choice> || ARCH_S5PV210 && <choice> || ARCH_S5PV310 && <choice>) selects HAVE_S3C2410_I2C which has unmet direct dependencies (I2C) Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
2010-11-13ARM: SAMSUNG: Fix HAVE_S3C2410_WATCHDOG warningsKyungmin Park
Fix build warnings warning: (ARCH_S3C64XX && <choice> && WATCHDOG || ARCH_S5P64X0 && <choice> && WATCHDOG || ARCH_S5P6442 && <choice> && WATCHDOG || ARCH_S5PC100 && <choice> || ARCH_S5PV210 && <choice> || ARCH_S5PV310 && <choice> || MACH_SMDK6410 && ARCH_S3C64XX) selects HAVE_S3C2410_WATCHDOG which has unmet direct dependencies (WATCHDOG) Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> [kgene.kim@samsung.com: Added fix same warning(mach-s3c64xx/Kconfig)] Signed-off-by: Kukjin Kim <kgene.kim@samsung.com>
