2006-08-10Merge branch 'tj-upstream-pci_register_driver' of ↵Jeff Garzik
git://htj.dyndns.org/libata-tj into upstream
2006-08-10Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-08-10[PATCH] libata: Use ATA_FLAG_PIO_POLLING for pdc_admaAlbert Lee
pdc_adma was overlooked and broken by the irq-pio patch: Only HSM_ST_LAST interrupts should be delivered to this LLDD. Adding ATA_FLAG_PIO_POLLING to pdc_adma fixes the problem (temporarily), before we convert the irq handler of pdc_adma to handle all interrupts. Signed-off-by: Albert Lee <albertcc@tw.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-10[ATA] Increase lba48 max-sectors from 200 to 256.Jeff Garzik
Also, moved ATA_MAX_SECTORS and ATA_MAX_SECTORS_LBA48 from linux/libata.h to linux/ata.h, now that they truly reflect the standard (well... mostly; note TODO comment). This changes the performance profile (and potential bug profile) for a bunch of drivers, so be wary.
2006-08-10Merge branch 'sii-m15w' into upstreamJeff Garzik
2006-08-10[PATCH] libata: replace pci_module_init() with pci_register_driver()Pavel Roskin
Replace pci_module_init() with pci_register_driver(). Signed-off-by: Pavel Roskin <proski@gnu.org> Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] libata: kill unused hard_port_no and legacy_modeTejun Heo
Kill unused probe_ent/ap->hard_port_no and probe_ent->legacy_mode. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] libata: replace ap->hard_port_no with ap->port_noTejun Heo
Replace ap->hard_port_no with ap->port_no. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] libata: use dummy port for stolen legacy portsTejun Heo
Use dummy port for stolen legacy ports. This makes ap->port_no always equal ap->hard_port_no. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] libata: implement dummy portTejun Heo
Implement dummy port which can be requested by setting appropriate bit in probe_ent->dummy_port_mask. The dummy port is used as placeholder for stolen legacy port. This allows libata to guarantee that index_of(ap) == ap->port_no == actual_device_port_no, and thus to remove error-prone ap->hard_port_no. As it's used only when one port of a legacy controller is reserved by some other entity (e.g. IDE), the focus is on keeping the added *code* complexity at minimum, so dummy port allocates all libata core resources and acts as a normal port. It just has all dummy port_ops. This patch only implements dummy port. The following patch will make libata use it for stolen legacy ports. Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] libata: rework legacy handling to remove much of the cruftAlan Cox
Kill host_set->next Fix simplex support Allow per platform setting of IDE legacy bases Some of this can be tidied further later on, in particular all the legacy port gunge belongs as a PCI quirk/PCI header decode to understand the special legacy IDE rules in the PCI spec. Longer term Jeff also wants to move the request_irq/free_irq out of core which will make this even cleaner. tj: folded in three followup patches - ata_piix-fix, broken-arch-fix and fix-new-legacy-handling, and separated per-dev xfermask into separate patch preceding this one. Folded in fixes are... * ata_piix-fix: fix build failure due to host_set->next removal * broken-arch-fix: add missing include/asm-*/libata-portmap.h * fix-new-legacy-handling: * In ata_pci_init_legacy_port(), probe_num was incorrectly incremented during initialization of the secondary port and probe_ent->n_ports was incorrectly fixed to 1. * Both legacy ports ended up having the same hard_port_no. * When printing port information, both legacy ports printed the first irq. Signed-off-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] libata: implement per-dev xfermaskTejun Heo
Implement per-dev xfermask. libata used to determine xfermask per-port - the fastest mode of the slowest device on the port. This patch enables per-dev xfermask. Original patch is from Alan Cox <alan@redhat.com>. The following changes are made by me. * simplex warning message is added * remove disabled device handling code which is never invoked (originally for choosing port-wide lowest PIO mode) Cc: Alan Cox <alan@redhat.com> Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] [libata] Kill 'count' var in ata_device_add()Jeff Garzik
Eliminate redundant loop variable 'count' Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] [libata] some function renamingJeff Garzik
s/ata_host_add/ata_port_add/ s/ata_host_init/ata_port_init/ libata naming got stuck in the middle of a Great Renaming: ata_host -> ata_port ata_host_set -> ata_host To eliminate confusion, let's just give up for now, and simply ensure that things are internally consistent. Signed-off-by: Jeff Garzik <jeff@garzik.org> Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-10[PATCH] libata: update ata_host_init() and rename it to ata_port_init_shost()Tejun Heo
Update ata_host_init() such that it only initializes SCSI host related stuff and doesn't call into ata_port_init(), and rename it to ata_port_init_shost(). Signed-off-by: Tejun Heo <htejun@gmail.com>
2006-08-09Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-08-09[PATCH] libata: clear sdev->locked on door lock failureTejun Heo
SCSI EH locks door if sdev->locked is set. Sometimes door lock command fails continuously (e.g. when medium is not present) and as libata uses EH to acquire sense data, this easily creates a loop where a failed lock door invokes EH and EH issues lock door on completion. This patch clears sdev->locked on door lock failure to break this loop. This problem has been spotted and diagnosed by Unicorn Chang <uchang@tw.ibm.com>. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-09[PATCH] Fix compile problem when sata debugging is onKeith Owens
Fix a sata debug print statement that still uses an old variable name. Signed-off-by: Keith Owens <kaos@ocs.com.au> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-09[PATCH] ahci: remove IRQ mask clearing from init_controller()Tejun Heo
Initial IRQ mask clearing is done by libata-core by freezing all ports prior to requesting IRQ. Remove redundant IRQ clearing from init_controller(). Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-09[PATCH] libata: Add support for SATA attachment to SAS adaptersBrian King
The following patch enhances libata to allow SAS device drivers to utilize libata to talk to SATA devices. It introduces some new APIs which allow libata to be used without allocating a virtual scsi host. New APIs: ata_sas_port_alloc - Allocate an ata_port ata_sas_port_init - Initialize an ata_port (probe device, etc) ata_sas_port_destroy - Free an ata_port allocated by ata_sas_port_alloc ata_sas_slave_configure - configure scsi device ata_sas_queuecmd - queue a scsi command, similar to ata_scsi_queuecomand These new APIs can be used either directly by a SAS LLDD or could be used by the SAS transport class. Possible usage for a SAS LLDD would be: scsi_scan_host target_alloc ata_sas_port_alloc slave_alloc ata_sas_port_init slave_configure ata_sas_slave_configure Commands received by the LLDD for SATA devices would call ata_sas_queuecmd. Device teardown would occur with: slave_destroy port_disable target_destroy ata_sas_port_destroy Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-09[PATCH] libata: Move ata_probe_ent_alloc to libata_coreBrian King
Move ata_probe_ent_alloc to libata-core. It will also be used by future SAS/SATA integration patches. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-09[PATCH] libata: Add ata_port_initBrian King
Separate out the ata_port initialization from ata_host_init so that it can be used in future SAS patches. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-09[PATCH] libata: Add ata_host_set_initBrian King
Add ata_host_set_init in preparation for SAS attached SATA. Signed-off-by: Brian King <brking@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-08-08Merge branch 'upstream-fixes' into upstreamJeff Garzik
2006-08-08Merge branch 'tj-upstream-fixes' of git://htj.dyndns.org/libata-tj into ↵Jeff Garzik
upstream-fixes
2006-08-07Merge branch 'master' into upstreamJeff Garzik
2006-08-06Linux v2.6.18-rc4v2.6.18-rc4Linus Torvalds
2006-08-06Merge branch 'for-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of master.kernel.org:/pub/scm/linux/kernel/git/dtor/input: (24 commits) Input: ati_remote - use msec instead of jiffies Input: ati_remote - add missing input_sync() Input: ati_remote - relax permissions sysfs module parameters Input: ati_remote - make filter time a module parameter Input: atkbd - restore repeat rate when resuming Input: trackpoint - activate protocol when resuming Input: logips2pp - fix button mapping for MX300 Input: keyboard - change to use kzalloc Input: serio/gameport - check whether driver core calls succeeded Input: spaceball - make 4000FLX Lefty work Input: keyboard - simplify emulate_raw() implementation Input: keyboard - remove static variable and clean up initialization Input: hiddev - use standard list implementation Input: add missing handler->start() call Input: HID - fix potential out-of-bound array access Input: fix list iteration in input_release_device() Input: iforce - add Trust Force Feedback Race Master support Input: iforce - check array bounds before accessing elements Input: libps2 - warn instead of oopsing when passed bad arguments Input: fm801-gp - fix use after free ...
2006-08-06Merge master.kernel.org:/pub/scm/linux/kernel/git/perex/alsaLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/perex/alsa: [ALSA] Don't reject O_RDWR at opening PCM OSS with read/write-only device [ALSA] snd-emu10k1: Implement support for Audigy 2 ZS [SB0353] [ALSA] add MAINTAINERS entry for snd-aoa [ALSA] aoa: platform function gpio: ignore errors from functions that don't exist [ALSA] make snd-powermac load even when it can't bind the device [ALSA] aoa: fix toonie codec [ALSA] aoa: feature gpio layer: fix IRQ access [ALSA] Conversions from kmalloc+memset to k(z|c)alloc [ALSA] snd-emu10k1: Fixes ALSA bug#2190
2006-08-06Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [LAPB]: Fix windowsize check [TCP]: Fixes IW > 2 cases when TCP is application limited [PKT_SCHED] RED: Fix overflow in calculation of queue average [LLX]: SOCK_DGRAM interface fixes [PKT_SCHED]: Return ENOENT if qdisc module is unavailable [BRIDGE]: netlink status fix
2006-08-06[PATCH] SCX200_ACB: eliminate spurious timeout errorsDavid Woodhouse
While busy-waiting for completion, check the hardware after scheduling; don't schedule and then immediately check the _timeout_. If the yield() took a long time (as it does on my OLPC prototype board when it's busy), we'd report a timeout even though the hardware was now ready. This fixes it, and also switches the yield() for a cond_resched() because we don't actually want to be _that_ nice about it. I see nice tightly-packed SMBus transactions now, rather than waiting for milliseconds between successive phases. Actually, we shouldn't be busy-waiting here at all. We should be using interrupts. That's an exercise for another day though. Signed-off-by: David Woodhouse <dwmw2@infradead.org> Cc: Christer Weinigel <wingel@nano-system.com> Cc: <Jordan.Crouse@amd.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] udf: initialize parts of inode earlier in createEric Sandeen
I saw an oops down this path when trying to create a new file on a UDF filesystem which was internally marked as readonly, but mounted rw: udf_create udf_new_inode new_inode alloc_inode udf_alloc_inode udf_new_block returns EIO due to readonlyness iput (on error) udf_put_inode udf_discard_prealloc udf_next_aext udf_current_aext udf_get_fileshortad OOPS the udf_discard_prealloc() path was examining uninitialized fields of the udf inode. udf_discard_prealloc() already has this code to short-circuit the discard path if no extents are preallocated: if (UDF_I_ALLOCTYPE(inode) == ICBTAG_FLAG_AD_IN_ICB || inode->i_size == UDF_I_LENEXTENTS(inode)) { return; } so if we initialize UDF_I_LENEXTENTS(inode) = 0 earlier in udf_new_inode, we won't try to free the (not) preallocated blocks, since this will match the i_size = 0 set when the inode was initialized. Signed-off-by: Eric Sandeen <sandeen@sandeen.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] futex: Apply recent futex fixes to futex_compatThomas Gleixner
The recent fixups in futex.c need to be applied to futex_compat.c too. Fixes a hang reported by Olaf. Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Olaf Hering <olh@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] pnpacpi: reject ACPI_PRODUCER resourcesmatthieu castet
A patch in -mm kernel correct the parsing of "address resources" of pnpacpi. Before we assumed it was memory only, but it could be also IO. But this change show an hidden bug : some resources could be producer type that are not handled by pnp layer. So we should ignore the producer resources. This patch fixes bug 6292 (http://bugzilla.kernel.org/show_bug.cgi?id=6292). Some devices like PNP0A03 have 0xd00-0xffff and 0x0-0xcf7 as IO producer resources. Before correcting "address resources" parsing, it was seen as memory and was harmless, because nobody tried to reserve this memory range as it should be IO. With the correction it become IO resources, and make failed all others device that want to register IO in this range and use pnp layer (like a ISA sound card). The solution is to ignore producer resources Signed-off-by: Matthieu CASTET <castet.matthieu@free.fr> Signed-off-by: Uwe Bugla <uwe.bugla@gmx.de> Cc: Bjorn Helgaas <bjorn.helgaas@hp.com> Cc: Adam Belay <ambx1@neo.rr.com> Cc: "Brown, Len" <len.brown@intel.com> Acked-by: Shaohua Li <shaohua.li@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] reiserfs_write_full_page() should not get_block past eofChris Mason
reiserfs_write_full_page does zero bytes in the file past eof, but it may call get_block on those buffers as well. On machines where the page size is larger than the blocksize, this can result in mmaped files incorrectly growing up to a block boundary during writepage. The fix is to avoid calling get_block for any blocks that are entirely past eof Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] fix reiserfs lock inversion of bkl vs inode semaphoreChris Mason
The correct lock ordering is inode lock -> BKL Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] memory hotadd fixes: enhance collision checkKAMEZAWA Hiroyuki
This patch is for collision check enhancement for memory hot add. It's better to do resouce collision check before doing memory hot add, which will touch memory management structures. And add_section() should check section exists or not before calling sparse_add_one_section(). (sparse_add_one_section() will do another check anyway. but checking in memory_hotplug.c will be easy to understand.) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: keith mannthey <kmannth@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] memory hotadd fixes: avoid registering res twiceKAMEZAWA Hiroyuki
both of acpi_memory_enable_device() and acpi_memory_add_device() may evaluate _CRS method. We should avoid evaluate device's resource twice if we could get it successfully in past. Signed-off-by: KAMEZWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] memory hotadd fixes: avoid check in acpiKAMEZAWA Hiroyuki
add_memory() does all necessary check to avoid collision. then, acpi layer doesn't have to check region by itself. (*) pfn_valid() just returns page struct is valid or not. It returns 0 if a section has been already added even is ioresource is not added. ioresource collision check in mm/memory_hotplug.c can do more precise collistion check. added enabled bit check just for sanity check.. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Cc: "Brown, Len" <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] memory hotadd fixes: find_next_system_ram catch range fixKAMEZAWA Hiroyuki
find_next_system_ram() is used to find available memory resource at onlining newly added memory. This patch fixes following problem. find_next_system_ram() cannot catch this case. Resource: (start)-------------(end) Section : (start)-------------(end) Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] memory hotadd fixes: change find_next_system_ram's return value mannerKAMEZAWA Hiroyuki
find_next_system_ram() returns valid memory range which meets requested area, only used by memory-hot-add. This function always rewrite requested resource even if returned area is not fully fit in requested one. And sometimes the returnd resource is larger than requested area. This annoyes the caller. This patch changes the returned value to fit in requested area. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] memory hotadd fixes: not-aligned memory hotadd handling fixKAMEZAWA Hiroyuki
ioresouce handling code in memory hotplug allows not-aligned memory hot add. But when memmap and other memory structures are initialized, parameters should be aligned. (if not aligned, initialization of mem_map will do wrong, it assumes parameters are aligned.) This patch fix it. And this patch allows ioresource collision check to handle -EEXIST. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Keith Mannthey <kmannth@gmail.com> Cc: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] Fix BeFS slab corruptionDiego Calleja
In bugzilla #6941, Jens Kilian reported: "The function befs_utf2nls (in fs/befs/linuxvfs.c) writes a 0 byte past the end of a block of memory allocated via kmalloc(), leading to memory corruption. This happens only for filenames which are pure ASCII and a multiple of 4 bytes in length. [...] Without DEBUG_SLAB, this leads to further corruption and hard lockups; I believe this is the bug which has made kernels later than 2.6.8 unusable for me. (This must be due to changes in memory management, the bug has been in the BeFS driver since the time it was introduced (AFAICT).) Steps to reproduce: Create a directory (in BeOS, naturally :-) with files named, e.g., "1", "22", "333", "4444", ... Mount it in Linux and do an "ls" or "find"" This patch implements the suggested fix. Credits to Jens Kilian for debugging the problem and finding the right fix. Signed-off-by: Diego Calleja <diegocg@gmail.com> Cc: Jens Kilian <jjk@acm.org> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] ieee1394: sbp2: enable auto spin-up for Maxtor disksStefan Richter
At least Maxtor OneTouch III require a "start stop unit" command after auto spin-down before the next access can proceed. This patch activates the responsible code in scsi_mod for all Maxtor SBP-2 disks. https://bugzilla.novell.com/show_bug.cgi?id=183011 Maybe that should be done for all SBP-2 disks, but better be cautious. Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Cc: Jody McIntyre <scjody@modernduck.com> Cc: Ben Collins <bcollins@ubuntu.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] Add stable branch to maintainers fileSteven Rostedt
While helping someone to submit a patch to the stable branch, I noticed that the stable branch is not listed in the MAINTAINERS file. This was after I went there to look for the email addresses for the stable branch list (stable@kernel.org). This patch adds the stable branch to the maintainers file so that people can find where to send patches when they have a fix for the stable team. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] sh: fix proc file removal for superh store queue moduleNeil Horman
Clean up proc file removal in sq module for superh arch. currently on a failed module load or on module unload a proc file is left registered which can cause a random memory execution or oopses if read after unload. This patch cleans up that deregistration. Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Acked-by: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] eicon: fix define conflict with ptraceAlexey Dobriyan
* MODE_MASK is unused in eicon driver. * Conflicts with a ptrace stuff on arm. drivers/isdn/hardware/eicon/divasync.h:259:1: warning: "MODE_MASK" redefined include2/asm/ptrace.h:48:1: warning: this is the location of the previous definition Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Karsten Keil <kkeil@suse.de> Acked-by: Armin Schindler <armin@melware.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] pSeries: hvsi char driver janitorial cleanupLinas Vepstas
A set of tty line discipline cleanup patches were introduced before the dawn of time, in kernel version 2.4.21. This patch performs that cleanup for the hvsi driver. The hvsi driver is used only on IBM pSeries PowerPC boxes. The driver was originally written by Hollis Blanchard, who has delegated maintainership to me. So this my first and maybe only patch in this official new role, because this driver is otherwise bug-free :-) Alan: "Actually its also a bug fix, tty->ldisc should be locked by refcounting and the helpers do this for you." Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Paul Mackerras <paulus@samba.org> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] pSeries hvsi char driver null pointer derefLinas Vepstas
Under certain rare circumstances, it appears that there can be be a NULL-pointer deref when a user fiddles with terminal emeulation programs while outpu is being sent to the console. This patch checks for and avoids a NULL-pointer deref. Signed-off-by: Hollis Blanchard <hollisbl@austin.ibm.com> Signed-off-by: Linas Vepstas <linas@austin.ibm.com> Cc: Paul Fulghum <paulkf@microgate.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-08-06[PATCH] Fix more per-cpu typosAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
