2006-03-27[PATCH] uml: move libc-dependent irq code to os-LinuxJeff Dike
The serial UML OS-abstraction layer patch (um/kernel dir). This moves all systemcalls from irq_user.c file under os-Linux dir Signed-off-by: Gennady Sharapov <Gennady.V.Sharapov@intel.com> Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: fix some printf formatsJeff Dike
Some printf formats are incorrect for large memory sizes. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: fix declaration of exit()Jeff Dike
This fixes a conflict between a header and what gcc "knows" the declaration' to be. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] uml: fix build warnings in __get_userJeff Dike
Fix a gcc warning about losing qualifiers to the first argument of copy_from_user. The typeof change for correctness, and fixes a lot of the warnings, but there are some cases where x has some extra qualifiers, like volatile, which copy_from_user can't know about. For these, the void * cast seems to be necessary. Also cleaned up some of the whitespace and got rid of the emacs comment at the bottom. Signed-off-by: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-27[PATCH] PM-Timer: don't use workaround if chipset is not buggyOGAWA Hirofumi
Current timer_pm.c reads I/O port triple times, in order to avoid the bug of chipset. But I/O port is slow. 2.6.16 (pmtmr) Simple gettimeofday: 3.6532 microseconds 2.6.16+patch (pmtmr) Simple gettimeofday: 1.4582 microseconds [if chip is buggy, probably it will be 7us or more in 4.2% of probability.] This patch adds blacklist of buggy chip, and if chip is not buggy, this uses fast normal version instead of slow workaround version. If chip is buggy, warnings "pmtmr is slow". But sounds like there is gray zone. I found the PIIX4 errata, but I couldn't find the ICH4 errata. But some motherboard seems to have problem. So, if we found a ICH4, generate warnings, and use a workaround version. If user's ICH4 is good, the user can specify the "pmtmr_good" boot parameter to use fast version. Acked-by: John Stultz <johnstul@us.ibm.com> Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[SPARC64]: Kill duplicate exports of string library functions.David S. Miller
Kbuild now points these out. Signed-off-by: David S. Miller <davem@davemloft.net>
2006-03-26[SPARC64]: Update defconfig.David S. Miller
2006-03-26[PATCH] one ipc/sem.c->mutex.c converstion too many..Manfred Spraul
Ingo's sem2mutex patch incorrectly replaced one reference to ipc/sem.c with ipc/mutex.c in a comment. Signed-off-by: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: drivers/char/ftape/lowlevel/fdc-io.c: Correct a comment Kconfig help: MTD_JEDECPROBE already supports Intel Remove ugly debugging stuff do_mounts.c: Minor ROOT_DEV comment cleanup BUG_ON() Conversion in drivers/s390/block/dasd_devmap.c BUG_ON() Conversion in mm/mempool.c BUG_ON() Conversion in mm/memory.c BUG_ON() Conversion in kernel/fork.c BUG_ON() Conversion in ipc/sem.c BUG_ON() Conversion in fs/ext2/ BUG_ON() Conversion in fs/hfs/ BUG_ON() Conversion in fs/dcache.c BUG_ON() Conversion in fs/buffer.c BUG_ON() Conversion in input/serio/hp_sdc_mlc.c BUG_ON() Conversion in md/dm-table.c BUG_ON() Conversion in md/dm-path-selector.c BUG_ON() Conversion in drivers/isdn BUG_ON() Conversion in drivers/char BUG_ON() Conversion in drivers/mtd/
2006-03-26drivers/char/ftape/lowlevel/fdc-io.c: Correct a commentBastien Roucaries
This patch correct a comment about cli(). Signed-off-by: Bastien Roucaries <roucaries.bastien@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-26Kconfig help: MTD_JEDECPROBE already supports IntelAdrian Bunk
Intel chips are already supported. Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: David Woodhouse <dwmw2@infradead.org>
2006-03-26[PATCH] bitops: hweight() speedupAkinobu Mita
<linux@horizon.com> wrote: This is an extremely well-known technique. You can see a similar version that uses a multiply for the last few steps at http://graphics.stanford.edu/~seander/bithacks.html#CountBitsSetParallel whch refers to "Software Optimization Guide for AMD Athlon 64 and Opteron Processors" http://www.amd.com/us-en/assets/content_type/white_papers_and_tech_docs/25112.PDF It's section 8.6, "Efficient Implementation of Population-Count Function in 32-bit Mode", pages 179-180. It uses the name that I am more familiar with, "popcount" (population count), although "Hamming weight" also makes sense. Anyway, the proof of correctness proceeds as follows: b = a - ((a >> 1) & 0x55555555); c = (b & 0x33333333) + ((b >> 2) & 0x33333333); d = (c + (c >> 4)) & 0x0f0f0f0f; #if SLOW_MULTIPLY e = d + (d >> 8) f = e + (e >> 16); return f & 63; #else /* Useful if multiply takes at most 4 cycles */ return (d * 0x01010101) >> 24; #endif The input value a can be thought of as 32 1-bit fields each holding their own hamming weight. Now look at it as 16 2-bit fields. Each 2-bit field a1..a0 has the value 2*a1 + a0. This can be converted into the hamming weight of the 2-bit field a1+a0 by subtracting a1. That's what the (a >> 1) & mask subtraction does. Since there can be no borrows, you can just do it all at once. Enumerating the 4 possible cases: 0b00 = 0 -> 0 - 0 = 0 0b01 = 1 -> 1 - 0 = 1 0b10 = 2 -> 2 - 1 = 1 0b11 = 3 -> 3 - 1 = 2 The next step consists of breaking up b (made of 16 2-bir fields) into even and odd halves and adding them into 4-bit fields. Since the largest possible sum is 2+2 = 4, which will not fit into a 4-bit field, the 2-bit ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ "which will not fit into a 2-bit field" fields have to be masked before they are added. After this point, the masking can be delayed. Each 4-bit field holds a population count from 0..4, taking at most 3 bits. These numbers can be added without overflowing a 4-bit field, so we can compute c + (c >> 4), and only then mask off the unwanted bits. This produces d, a number of 4 8-bit fields, each in the range 0..8. From this point, we can shift and add d multiple times without overflowing an 8-bit field, and only do a final mask at the end. The number to mask with has to be at least 63 (so that 32 on't be truncated), but can also be 128 or 255. The x86 has a special encoding for signed immediate byte values -128..127, so the value of 255 is slower. On other processors, a special "sign extend byte" instruction might be faster. On a processor with fast integer multiplies (Athlon but not P4), you can reduce the final few serially dependent instructions to a single integer multiply. Consider d to be 3 8-bit values d3, d2, d1 and d0, each in the range 0..8. The multiply forms the partial products: d3 d2 d1 d0 d3 d2 d1 d0 d3 d2 d1 d0 + d3 d2 d1 d0 ---------------------- e3 e2 e1 e0 Where e3 = d3 + d2 + d1 + d0. e2, e1 and e0 obviously cannot generate any carries. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26Remove ugly debugging stuffArtem B. Bityuckiy
2006-03-26[PATCH] bitops: hweight() related cleanupAkinobu Mita
By defining generic hweight*() routines - hweight64() will be defined on all architectures - hweight_long() will use architecture optimized hweight32() or hweight64() I found two possible cleanups by these reasons. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: remove unused generic bitops in include/linux/bitops.hAkinobu Mita
generic_{ffs,fls,fls64,hweight{64,32,16,8}}() were moved into include/asm-generic/bitops.h. So all architectures don't use them. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: ntfs: remove generic_ffs()Akinobu Mita
Now the only user who are using generic_ffs() is ntfs filesystem. This patch isolates generic_ffs() as ntfs_ffs() for ntfs. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: ia64: make partial_page.bitmap an unsigned longAkinobu Mita
The find_*_bit() routines are defined to work on a pointer to unsigned long. But partial_page.bitmap is unsigned int and it is passed to find_*_bit() in arch/ia64/ia32/sys_ia32.c. So the compiler will print warnings. This patch changes to unsigned long instead. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sh: make thread_info.flags an unsigned longAkinobu Mita
The test_bit() routines are defined to work on a pointer to unsigned long. But thread_info.flags is __u32 (unsigned int) on sh and it is passed to flag set/clear/test wrappers in include/linux/thread_info.h. So the compiler will print warnings. This patch changes to unsigned long instead. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: update include/asm-generic/bitops.hAkinobu Mita
Currently include/asm-generic/bitops.h is not referenced from anywhere. But it will be the benefit of those who are trying to port Linux to another architecture. So update it by same manner Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: xtensa: use generic bitopsAkinobu Mita
- remove {,test_and_}{set,clear,change}_bit() - remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove generic_fls64() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove generic_hweight{32,16,8}() - remove sched_find_first_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Chris Zankel <chris@zankel.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: x86_64: use generic bitopsAkinobu Mita
- remove sched_find_first_bit() - remove generic_hweight{64,32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: v850: use generic bitopsAkinobu Mita
- remove ffz() - remove find_{next,first}{,_zero}_bit() - remove generic_ffs() - remove generic_fls() - remove generic_fls64() - remove __ffs() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Miles Bader <uclinux-v850@lsi.nec.co.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sparc64: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove __ffs() - remove generic_fls() - remove generic_fls64() - remove sched_find_first_bit() - remove ffs() - unless defined(ULTRA_HAS_POPULATION_COUNT) - remove generic_hweight{64,32,16,8}() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sparc: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove __ffs() - remove sched_find_first_bit() - remove ffs() - remove generic_fls() - remove generic_fls64() - remove generic_hweight{32,16,8}() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: William Lee Irwin III <wli@holomorphy.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sh64: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove __ffs() - remove find_{next,first}{,_zero}_bit() - remove generic_hweight{32,16,8}() - remove sched_find_first_bit() - remove generic_ffs() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Richard Curnow <rc@rc0.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: sh: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove find_{next,first}{,_zero}_bit() - remove generic_ffs() - remove generic_hweight{32,16,8}() - remove sched_find_first_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Kazumoto Kojima <kkojima@rr.iij4u.or.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: s390: use generic bitopsAkinobu Mita
- remove generic_ffs() - remove generic_fls() - remove generic_fls64() - remove generic_hweight{64,32,16,8}() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: powerpc: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove generic_fls64() - remove generic_hweight{64,32,16,8}() - remove sched_find_first_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: parisc: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove generic_fls64() - remove generic_hweight{32,16,8}() - remove generic_hweight64() - remove sched_find_first_bit() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: mips: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - unless defined(CONFIG_CPU_MIPS32) or defined(CONFIG_CPU_MIPS64) - remove __ffs() - remove ffs() - remove ffz() - remove fls() - remove fls64() - remove find_{next,first}{,_zero}_bit() - remove sched_find_first_bit() - remove generic_hweight64() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: m68knommu: use generic bitopsAkinobu Mita
- remove ffs() - remove __ffs() - remove sched_find_first_bit() - remove ffz() - remove find_{next,first}{,_zero}_bit() - remove generic_hweight() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Greg Ungerer <gerg@uclinux.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] ppc: fix undefined reference to hweight32Akinobu Mita
Build fix for ppc Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] m68k: fix undefined reference to generic_find_next_zero_le_bitAkinobu Mita
This patch reverts ext2 bitmap functions. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: m68k: use generic bitopsAkinobu Mita
- remove generic_fls64() - remove sched_find_first_bit() - remove generic_hweight() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Roman Zippel <zippel@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: m32r: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove find_{next,first}{,_zero}_bit() - remove __ffs() - remove generic_fls() - remove generic_fls64() - remove sched_find_first_bit() - remove generic_ffs() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Hirokazu Takata <takata@linux-m32r.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: ia64: use generic bitopsAkinobu Mita
- remove generic_fls64() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove sched_find_first_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: "Luck, Tony" <tony.luck@intel.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: i386: use generic bitopsAkinobu Mita
- remove generic_fls64() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: h8300: use generic bitopsAkinobu Mita
- remove generic_ffs() - remove find_{next,first}{,_zero}_bit() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove ext2_{set,clear}_bit_atomic() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove generic_fls() - remove generic_fls64() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Yoshinori Sato <ysato@users.sourceforge.jp> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: frv: use generic bitopsAkinobu Mita
- remove ffz() - remove find_{next,first}{,_zero}_bit() - remove generic_ffs() - remove __ffs() - remove generic_fls64() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: cris: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove generic_fls() - remove generic_fls64() - remove generic_hweight{32,16,8}() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() - remove sched_find_first_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Acked-by: Mikael Starvik <starvik@axis.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: arm26: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - remove ffz() - remove __ffs() - remove generic_fls() - remove generic_fls64() - remove generic_ffs() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Ian Molton <spyro@f2s.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: arm: use generic bitopsAkinobu Mita
- remove __{,test_and_}{set,clear,change}_bit() and test_bit() - if __LINUX_ARM_ARCH__ < 5 - remove ffz() - remove __ffs() - remove generic_fls() - remove generic_ffs() - remove generic_fls64() - remove sched_find_first_bit() - remove generic_hweight{32,16,8}() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: alpha: use generic bitopsAkinobu Mita
- unless defined(__alpha_cix__) and defined(__alpha_fix__) - remove generic_fls() - remove generic_hweight{64,32,16,8}() - remove generic_fls64() - remove find_{next,first}{,_zero}_bit() - remove ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() - remove minix_{test,set,test_and_clear,test,find_first_zero}_bit() Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic ↵Akinobu Mita
minix_{test,set,test_and_clear,test,find_first_zero}_bit() This patch introduces the C-language equivalents of the functions below: int minix_test_and_set_bit(int nr, volatile unsigned long *addr); int minix_set_bit(int nr, volatile unsigned long *addr); int minix_test_and_clear_bit(int nr, volatile unsigned long *addr); int minix_test_bit(int nr, const volatile unsigned long *addr); unsigned long minix_find_first_zero_bit(const unsigned long *addr, unsigned long size); In include/asm-generic/bitops/minix.h and include/asm-generic/bitops/minix-le.h This code largely copied from: include/asm-sparc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic ext2_{set,clear}_bit_atomic()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: int ext2_set_bit_atomic(int nr, volatile unsigned long *addr); int ext2_clear_bit_atomic(int nr, volatile unsigned long *addr); In include/asm-generic/bitops/ext2-atomic.h This code largely copied from: include/asm-sparc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
ext2_{set,clear,test,find_first_zero,find_next_zero}_bit() This patch introduces the C-language equivalents of the functions below: int ext2_set_bit(int nr, volatile unsigned long *addr); int ext2_clear_bit(int nr, volatile unsigned long *addr); int ext2_test_bit(int nr, const volatile unsigned long *addr); unsigned long ext2_find_first_zero_bit(const unsigned long *addr, unsigned long size); unsinged long ext2_find_next_zero_bit(const unsigned long *addr, unsigned long size); In include/asm-generic/bitops/ext2-non-atomic.h This code largely copied from: include/asm-powerpc/bitops.h include/asm-parisc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] fix error: __u32 undeclaredAkinobu Mita
Build fix for s390 declare __u32 and __u64. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic hweight{64,32,16,8}()Akinobu Mita
This patch introduces the C-language equivalents of the functions below: unsigned int hweight32(unsigned int w); unsigned int hweight16(unsigned int w); unsigned int hweight8(unsigned int w); unsigned long hweight64(__u64 w); In include/asm-generic/bitops/hweight.h This code largely copied from: include/linux/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic ffs()Akinobu Mita
This patch introduces the C-language equivalent of the function: int ffs(int x); In include/asm-generic/bitops/ffs.h This code largely copied from: include/linux/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] bitops: generic sched_find_first_bit()Akinobu Mita
This patch introduces the C-language equivalent of the function: int sched_find_first_bit(const unsigned long *b); In include/asm-generic/bitops/sched.h This code largely copied from: include/asm-powerpc/bitops.h Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
