2017-02-18tcp: fix 0 divide in __tcp_select_window()Eric Dumazet
[ Upstream commit 06425c308b92eaf60767bc71d359f4cbc7a561f8 ] syszkaller fuzzer was able to trigger a divide by zero, when TCP window scaling is not enabled. SO_RCVBUF can be used not only to increase sk_rcvbuf, also to decrease it below current receive buffers utilization. If mss is negative or 0, just return a zero TCP window. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Acked-by: Neal Cardwell <ncardwell@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-18ipv6: pointer math error in ip6_tnl_parse_tlv_enc_lim()Dan Carpenter
[ Upstream commit 63117f09c768be05a0bf465911297dc76394f686 ] Casting is a high precedence operation but "off" and "i" are in terms of bytes so we need to have some parenthesis here. Fixes: fbfa743a9d2a ("ipv6: fix ip6_tnl_parse_tlv_enc_lim()") Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Acked-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-18ipv6: fix ip6_tnl_parse_tlv_enc_lim()Eric Dumazet
[ Upstream commit fbfa743a9d2a0ffa24251764f10afc13eb21e739 ] This function suffers from multiple issues. First one is that pskb_may_pull() may reallocate skb->head, so the 'raw' pointer needs either to be reloaded or not used at all. Second issue is that NEXTHDR_DEST handling does not validate that the options are present in skb->data, so we might read garbage or access non existent memory. With help from Willem de Bruijn. Signed-off-by: Eric Dumazet <edumazet@google.com> Reported-by: Dmitry Vyukov <dvyukov@google.com> Cc: Willem de Bruijn <willemb@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-18can: Fix kernel panic at security_sock_rcv_skbEric Dumazet
[ Upstream commit f1712c73714088a7252d276a57126d56c7d37e64 ] Zhang Yanmin reported crashes [1] and provided a patch adding a synchronize_rcu() call in can_rx_unregister() The main problem seems that the sockets themselves are not RCU protected. If CAN uses RCU for delivery, then sockets should be freed only after one RCU grace period. Recent kernels could use sock_set_flag(sk, SOCK_RCU_FREE), but let's ease stable backports with the following fix instead. [1] BUG: unable to handle kernel NULL pointer dereference at (null) IP: [<ffffffff81495e25>] selinux_socket_sock_rcv_skb+0x65/0x2a0 Call Trace: <IRQ> [<ffffffff81485d8c>] security_sock_rcv_skb+0x4c/0x60 [<ffffffff81d55771>] sk_filter+0x41/0x210 [<ffffffff81d12913>] sock_queue_rcv_skb+0x53/0x3a0 [<ffffffff81f0a2b3>] raw_rcv+0x2a3/0x3c0 [<ffffffff81f06eab>] can_rcv_filter+0x12b/0x370 [<ffffffff81f07af9>] can_receive+0xd9/0x120 [<ffffffff81f07beb>] can_rcv+0xab/0x100 [<ffffffff81d362ac>] __netif_receive_skb_core+0xd8c/0x11f0 [<ffffffff81d36734>] __netif_receive_skb+0x24/0xb0 [<ffffffff81d37f67>] process_backlog+0x127/0x280 [<ffffffff81d36f7b>] net_rx_action+0x33b/0x4f0 [<ffffffff810c88d4>] __do_softirq+0x184/0x440 [<ffffffff81f9e86c>] do_softirq_own_stack+0x1c/0x30 <EOI> [<ffffffff810c76fb>] do_softirq.part.18+0x3b/0x40 [<ffffffff810c8bed>] do_softirq+0x1d/0x20 [<ffffffff81d30085>] netif_rx_ni+0xe5/0x110 [<ffffffff8199cc87>] slcan_receive_buf+0x507/0x520 [<ffffffff8167ef7c>] flush_to_ldisc+0x21c/0x230 [<ffffffff810e3baf>] process_one_work+0x24f/0x670 [<ffffffff810e44ed>] worker_thread+0x9d/0x6f0 [<ffffffff810e4450>] ? rescuer_thread+0x480/0x480 [<ffffffff810ebafc>] kthread+0x12c/0x150 [<ffffffff81f9ccef>] ret_from_fork+0x3f/0x70 Reported-by: Zhang Yanmin <yanmin.zhang@intel.com> Signed-off-by: Eric Dumazet <edumazet@google.com> Acked-by: Oliver Hartkopp <socketcan@hartkopp.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14Linux 4.4.49v4.4.49Greg Kroah-Hartman
2017-02-14drm/i915: fix use-after-free in page_flip_completed()Andrey Ryabinin
commit 5351fbb1bf1413f6024892093528280769ca852f upstream. page_flip_completed() dereferences 'work' variable after executing queue_work(). This is not safe as the 'work' item might be already freed by queued work: BUG: KASAN: use-after-free in page_flip_completed+0x3ff/0x490 at addr ffff8803dc010f90 Call Trace: __asan_report_load8_noabort+0x59/0x80 page_flip_completed+0x3ff/0x490 intel_finish_page_flip_mmio+0xe3/0x130 intel_pipe_handle_vblank+0x2d/0x40 gen8_irq_handler+0x4a7/0xed0 __handle_irq_event_percpu+0xf6/0x860 handle_irq_event_percpu+0x6b/0x160 handle_irq_event+0xc7/0x1b0 handle_edge_irq+0x1f4/0xa50 handle_irq+0x41/0x70 do_IRQ+0x9a/0x200 common_interrupt+0x89/0x89 Freed: kfree+0x113/0x4d0 intel_unpin_work_fn+0x29a/0x3b0 process_one_work+0x79e/0x1b70 worker_thread+0x611/0x1460 kthread+0x241/0x3a0 ret_from_fork+0x27/0x40 Move queue_work() after trace_i915_flip_complete() to fix this. Fixes: e5510fac98a7 ("drm/i915: add tracepoints for flip requests & completions") Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/20170126143211.24013-1-aryabinin@virtuozzo.com (cherry picked from commit 05c41f926fcc7ef838c80a6a99d84f67b4e0b824) Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Andrey Ryabinin <aryabinin@virtuozzo.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14ALSA: seq: Don't handle loop timeout at snd_seq_pool_done()Takashi Iwai
commit 37a7ea4a9b81f6a864c10a7cb0b96458df5310a3 upstream. snd_seq_pool_done() syncs with closing of all opened threads, but it aborts the wait loop with a timeout, and proceeds to the release resource even if not all threads have been closed. The timeout was 5 seconds, and if you run a crazy stuff, it can exceed easily, and may result in the access of the invalid memory address -- this is what syzkaller detected in a bug report. As a fix, let the code graduate from naiveness, simply remove the loop timeout. BugLink: http://lkml.kernel.org/r/CACT4Y+YdhDV2H5LLzDTJDVF-qiYHUHhtRaW4rbb4gUhTCQB81w@mail.gmail.com Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14ALSA: seq: Fix race at creating a queueTakashi Iwai
commit 4842e98f26dd80be3623c4714a244ba52ea096a8 upstream. When a sequencer queue is created in snd_seq_queue_alloc(),it adds the new queue element to the public list before referencing it. Thus the queue might be deleted before the call of snd_seq_queue_use(), and it results in the use-after-free error, as spotted by syzkaller. The fix is to reference the queue object at the right time. Reported-by: Dmitry Vyukov <dvyukov@google.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14xen-netfront: Delete rx_refill_timer in xennet_disconnect_backend()Boris Ostrovsky
commit 74470954857c264168d2b5a113904cf0cfd27d18 upstream. rx_refill_timer should be deleted as soon as we disconnect from the backend since otherwise it is possible for the timer to go off before we get to xennet_destroy_queues(). If this happens we may dereference queue->rx.sring which is set to NULL in xennet_disconnect_backend(). Signed-off-by: Boris Ostrovsky <boris.ostrovsky@oracle.com> Reviewed-by: Juergen Gross <jgross@suse.com> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14scsi: mpt3sas: disable ASPM for MPI2 controllersojab
commit ffdadd68af5a397b8a52289ab39d62e1acb39e63 upstream. MPI2 controllers sometimes got lost (i.e. disappear from /sys/bus/pci/devices) if ASMP is enabled. Signed-off-by: Slava Kardakov <ojab@ojab.ru> Fixes: https://bugzilla.kernel.org/show_bug.cgi?id=60644 Acked-by: Sreekanth Reddy <Sreekanth.Reddy@broadcom.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14scsi: aacraid: Fix INTx/MSI-x issue with older controllersDave Carroll
commit 8af8e1c22f9994bb1849c01d66c24fe23f9bc9a0 upstream. commit 78cbccd3bd68 ("aacraid: Fix for KDUMP driver hang") caused a problem on older controllers which do not support MSI-x (namely ASR3405,ASR3805). This patch conditionalizes the previous patch to controllers which support MSI-x Fixes: 78cbccd3bd68 ("aacraid: Fix for KDUMP driver hang") Reported-by: Arkadiusz Miskiewicz <a.miskiewicz@gmail.com> Signed-off-by: Dave Carroll <david.carroll@microsemi.com> Reviewed-by: Raghava Aditya Renukunta <RaghavaAditya.Renukunta@microsemi.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14scsi: zfcp: fix use-after-free by not tracing WKA port open/close on failed sendSteffen Maier
commit 2dfa6688aafdc3f74efeb1cf05fb871465d67f79 upstream. Dan Carpenter kindly reported: <quote> The patch d27a7cb91960: "zfcp: trace on request for open and close of WKA port" from Aug 10, 2016, leads to the following static checker warning: drivers/s390/scsi/zfcp_fsf.c:1615 zfcp_fsf_open_wka_port() warn: 'req' was already freed. drivers/s390/scsi/zfcp_fsf.c 1609 zfcp_fsf_start_timer(req, ZFCP_FSF_REQUEST_TIMEOUT); 1610 retval = zfcp_fsf_req_send(req); 1611 if (retval) 1612 zfcp_fsf_req_free(req); ^^^ Freed. 1613 out: 1614 spin_unlock_irq(&qdio->req_q_lock); 1615 if (req && !IS_ERR(req)) 1616 zfcp_dbf_rec_run_wka("fsowp_1", wka_port, req->req_id); ^^^^^^^^^^^ Use after free. 1617 return retval; 1618 } Same thing for zfcp_fsf_close_wka_port() as well. </quote> Rather than relying on req being NULL (or ERR_PTR) for all cases where we don't want to trace or should not trace, simply check retval which is unconditionally initialized with -EIO != 0 and it can only become 0 on successful retval = zfcp_fsf_req_send(req). With that we can also remove the then again unnecessary unconditional initialization of req which was introduced with that earlier commit. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Suggested-by: Benjamin Block <bblock@linux.vnet.ibm.com> Signed-off-by: Steffen Maier <maier@linux.vnet.ibm.com> Fixes: d27a7cb91960 ("zfcp: trace on request for open and close of WKA port") Reviewed-by: Benjamin Block <bblock@linux.vnet.ibm.com> Reviewed-by: Jens Remus <jremus@linux.vnet.ibm.com> Signed-off-by: Martin K. Petersen <martin.petersen@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14netvsc: Set maximum GSO size in the right placeBen Hutchings
Commit a50af86dd49e "netvsc: reduce maximum GSO size" was wrongly backported to 4.4-stable. The maximum size needs to be set before the net device is registered, in netvsc_probe(). Signed-off-by: Ben Hutchings <ben@decadent.org.uk> Cc: Stephen Hemminger <sthemmin@microsoft.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14mac80211: Fix adding of mesh vendor IEsThorsten Horstmann
commit da7061c82e4a1bc6a5e134ef362c86261906c860 upstream. The function ieee80211_ie_split_vendor doesn't return 0 on errors. Instead it returns any offset < ielen when WLAN_EID_VENDOR_SPECIFIC is found. The return value in mesh_add_vendor_ies must therefore be checked against ifmsh->ie_len and not 0. Otherwise all ifmsh->ie starting with WLAN_EID_VENDOR_SPECIFIC will be rejected. Fixes: 082ebb0c258d ("mac80211: fix mesh beacon format") Signed-off-by: Thorsten Horstmann <thorsten@defutech.de> Signed-off-by: Mathias Kretschmer <mathias.kretschmer@fit.fraunhofer.de> Signed-off-by: Simon Wunderlich <sw@simonwunderlich.de> [sven@narfation.org: Add commit message] Signed-off-by: Sven Eckelmann <sven@narfation.org> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14ARM: 8642/1: LPAE: catch pending imprecise abort on unmaskAlexander Sverdlin
commit 97a98ae5b8acf08d07d972c087b2def060bc9b73 upstream. Asynchronous external abort is coded differently in DFSR with LPAE enabled. Fixes: 9254970c "ARM: 8447/1: catch pending imprecise abort on unmask". Signed-off-by: Alexander Sverdlin <alexander.sverdlin@nokia.com> Cc: Russell King <linux@armlinux.org.uk> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: linux-arm-kernel@lists.infradead.org Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14target: Fix COMPARE_AND_WRITE ref leak for non GOOD statusNicholas Bellinger
commit 9b2792c3da1e80f2d460167d319302a24c9ca2b7 upstream. This patch addresses a long standing bug where the commit phase of COMPARE_AND_WRITE would result in a se_cmd->cmd_kref reference leak if se_cmd->scsi_status returned non SAM_STAT_GOOD. This would manifest first as a lost SCSI response, and eventual hung task during fabric driver logout or re-login, as existing shutdown logic waited for the COMPARE_AND_WRITE se_cmd->cmd_kref to reach zero. To address this bug, compare_and_write_post() has been changed to drop the incorrect !cmd->scsi_status conditional that was preventing *post_ret = 1 for being set during non SAM_STAT_GOOD status. This patch has been tested with SAM_STAT_CHECK_CONDITION status from normal target_complete_cmd() callback path, as well as the incoming __target_execute_cmd() submission failure path when se_cmd->execute_cmd() returns non zero status. Reported-by: Donald White <dew@datera.io> Cc: Donald White <dew@datera.io> Tested-by: Gary Guo <ghg@datera.io> Cc: Gary Guo <ghg@datera.io> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14target: Fix early transport_generic_handle_tmr abort scenarioNicholas Bellinger
commit c54eeffbe9338fa982dc853d816fda9202a13b5a upstream. This patch fixes a bug where incoming task management requests can be explicitly aborted during an active LUN_RESET, but who's struct work_struct are canceled in-flight before execution. This occurs when core_tmr_drain_tmr_list() invokes cancel_work_sync() for the incoming se_tmr_req->task_cmd->work, resulting in cmd->work for target_tmr_work() never getting invoked and the aborted TMR waiting indefinately within transport_wait_for_tasks(). To address this case, perform a CMD_T_ABORTED check early in transport_generic_handle_tmr(), and invoke the normal path via transport_cmd_check_stop_to_fabric() to complete any TMR kthreads blocked waiting for CMD_T_STOP in transport_wait_for_tasks(). Also, move the TRANSPORT_ISTATE_PROCESSING assignment earlier into transport_generic_handle_tmr() so the existing check in core_tmr_drain_tmr_list() avoids attempting abort the incoming se_tmr_req->task_cmd->work if it has already been queued into se_device->tmr_wq. Reported-by: Rob Millner <rlm@daterainc.com> Tested-by: Rob Millner <rlm@daterainc.com> Cc: Rob Millner <rlm@daterainc.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14target: Use correct SCSI status during EXTENDED_COPY exceptionNicholas Bellinger
commit 0583c261e6325f392c1f7a1b9112e31298e1a4bd upstream. This patch adds the missing target_complete_cmd() SCSI status parameter change in target_xcopy_do_work(), that was originally missing in commit 926317de33. It correctly propigates up the correct SCSI status during EXTENDED_COPY exception cases, instead of always using the hardcoded SAM_STAT_CHECK_CONDITION from original code. This is required for ESX host environments that expect to hit SAM_STAT_RESERVATION_CONFLICT for certain scenarios, and SAM_STAT_CHECK_CONDITION results in non-retriable status for these cases. Reported-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Tested-by: Nixon Vincent <nixon.vincent@calsoftinc.com> Cc: Nixon Vincent <nixon.vincent@calsoftinc.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14target: Don't BUG_ON during NodeACL dynamic -> explicit conversionNicholas Bellinger
commit 391e2a6de9781e4906dd7e0b1cc097050bf43e11 upstream. After the v4.2+ RCU conversion to se_node_acl->lun_entry_hlist, a BUG_ON() was added in core_enable_device_list_for_node() to detect when the located orig->se_lun_acl contains an existing se_lun_acl pointer reference. However, this scenario can happen when a dynamically generated NodeACL is being converted to an explicit NodeACL, when the explicit NodeACL contains a different LUN mapping than the default provided by the WWN endpoint. So instead of triggering BUG_ON(), go ahead and fail instead following the original pre RCU conversion logic. Reported-by: Benjamin ESTRABAUD <ben.estrabaud@mpstor.com> Cc: Benjamin ESTRABAUD <ben.estrabaud@mpstor.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14ARM: 8643/3: arm/ptrace: Preserve previous registers for short regset writeDave Martin
commit 228dbbfb5d77f8e047b2a1d78da14b7158433027 upstream. Ensure that if userspace supplies insufficient data to PTRACE_SETREGSET to fill all the registers, the thread's old registers are preserved. Fixes: 5be6f62b0059 ("ARM: 6883/1: ptrace: Migrate to regsets framework") Signed-off-by: Dave Martin <Dave.Martin@arm.com> Acked-by: Russell King <rmk+kernel@armlinux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14hns: avoid stack overflow with CONFIG_KASANArnd Bergmann
commit b3f2d07f4649adcf6905953a10d217b5683e4077 upstream. The use of ACCESS_ONCE() looks like a micro-optimization to force gcc to use an indexed load for the register address, but it has an absolutely detrimental effect on builds with gcc-5 and CONFIG_KASAN=y, leading to a very likely kernel stack overflow aside from very complex object code: hisilicon/hns/hns_dsaf_gmac.c: In function 'hns_gmac_update_stats': hisilicon/hns/hns_dsaf_gmac.c:419:1: error: the frame size of 2912 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_ppe.c: In function 'hns_ppe_reset_common': hisilicon/hns/hns_dsaf_ppe.c:390:1: error: the frame size of 1184 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_ppe.c: In function 'hns_ppe_get_regs': hisilicon/hns/hns_dsaf_ppe.c:621:1: error: the frame size of 3632 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_rcb.c: In function 'hns_rcb_get_common_regs': hisilicon/hns/hns_dsaf_rcb.c:970:1: error: the frame size of 2784 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_gmac.c: In function 'hns_gmac_get_regs': hisilicon/hns/hns_dsaf_gmac.c:641:1: error: the frame size of 5728 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_rcb.c: In function 'hns_rcb_get_ring_regs': hisilicon/hns/hns_dsaf_rcb.c:1021:1: error: the frame size of 2208 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_main.c: In function 'hns_dsaf_comm_init': hisilicon/hns/hns_dsaf_main.c:1209:1: error: the frame size of 1904 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_xgmac.c: In function 'hns_xgmac_get_regs': hisilicon/hns/hns_dsaf_xgmac.c:748:1: error: the frame size of 4704 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_main.c: In function 'hns_dsaf_update_stats': hisilicon/hns/hns_dsaf_main.c:2420:1: error: the frame size of 1088 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] hisilicon/hns/hns_dsaf_main.c: In function 'hns_dsaf_get_regs': hisilicon/hns/hns_dsaf_main.c:2753:1: error: the frame size of 10768 bytes is larger than 1024 bytes [-Werror=frame-larger-than=] This does not seem to happen any more with gcc-7, but removing the ACCESS_ONCE seems safe anyway and it avoids a serious issue for some people. I have verified that with gcc-5.3.1, the object code we get is better in the new version both with and without CONFIG_KASAN, as we no longer allocate a 1344 byte stack frame for hns_dsaf_get_regs() but otherwise have practically identical object code. With gcc-7.0.0, removing ACCESS_ONCE has no effect, the object code is already good either way. This patch is probably not urgent to get into 4.11 as only KASAN=y builds with certain compilers are affected, but I still think it makes sense to backport into older kernels. Fixes: 511e6bc ("net: add Hisilicon Network Subsystem DSAF support") Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14cpumask: use nr_cpumask_bits for parsing functionsTejun Heo
commit 4d59b6ccf000862beed6fc0765d3209f98a8d8a2 upstream. Commit 513e3d2d11c9 ("cpumask: always use nr_cpu_ids in formatting and parsing functions") converted both cpumask printing and parsing functions to use nr_cpu_ids instead of nr_cpumask_bits. While this was okay for the printing functions as it just picked one of the two output formats that we were alternating between depending on a kernel config, doing the same for parsing wasn't okay. nr_cpumask_bits can be either nr_cpu_ids or NR_CPUS. We can always use nr_cpu_ids but that is a variable while NR_CPUS is a constant, so it can be more efficient to use NR_CPUS when we can get away with it. Converting the printing functions to nr_cpu_ids makes sense because it affects how the masks get presented to userspace and doesn't break anything; however, using nr_cpu_ids for parsing functions can incorrectly leave the higher bits uninitialized while reading in these masks from userland. As all testing and comparison functions use nr_cpumask_bits which can be larger than nr_cpu_ids, the parsed cpumasks can erroneously yield false negative results. This made the taskstats interface incorrectly return -EINVAL even when the inputs were correct. Fix it by restoring the parse functions to use nr_cpumask_bits instead of nr_cpu_ids. Link: http://lkml.kernel.org/r/20170206182442.GB31078@htj.duckdns.org Fixes: 513e3d2d11c9 ("cpumask: always use nr_cpu_ids in formatting and parsing functions") Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Martin Steigerwald <martin.steigerwald@teamix.de> Debugged-by: Ben Hutchings <ben.hutchings@codethink.co.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14Revert "x86/ioapic: Restore IO-APIC irq_chip retrigger callback"Linus Torvalds
commit d966564fcdc19e13eb6ba1fbe6b8101070339c3d upstream. This reverts commit 020eb3daaba2857b32c4cf4c82f503d6a00a67de. Gabriel C reports that it causes his machine to not boot, and we haven't tracked down the reason for it yet. Since the bug it fixes has been around for a longish time, we're better off reverting the fix for now. Gabriel says: "It hangs early and freezes with a lot RCU warnings. I bisected it down to : > Ruslan Ruslichenko (1): > x86/ioapic: Restore IO-APIC irq_chip retrigger callback Reverting this one fixes the problem for me.. The box is a PRIMERGY TX200 S5 , 2 socket , 2 x E5520 CPU(s) installed" and Ruslan and Thomas are currently stumped. Reported-and-bisected-by: Gabriel C <nix.or.die@gmail.com> Cc: Ruslan Ruslichenko <rruslich@cisco.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-14selinux: fix off-by-one in setprocattrStephen Smalley
commit 0c461cb727d146c9ef2d3e86214f498b78b7d125 upstream. SELinux tries to support setting/clearing of /proc/pid/attr attributes from the shell by ignoring terminating newlines and treating an attribute value that begins with a NUL or newline as an attempt to clear the attribute. However, the test for clearing attributes has always been wrong; it has an off-by-one error, and this could further lead to reading past the end of the allocated buffer since commit bb646cdb12e75d82258c2f2e7746d5952d3e321a ("proc_pid_attr_write(): switch to memdup_user()"). Fix the off-by-one error. Even with this fix, setting and clearing /proc/pid/attr attributes from the shell is not straightforward since the interface does not support multiple write() calls (so shells that write the value and newline separately will set and then immediately clear the attribute, requiring use of echo -n to set the attribute), whereas trying to use echo -n "" to clear the attribute causes the shell to skip the write() call altogether since POSIX says that a zero-length write causes no side effects. Thus, one must use echo -n to set and echo without -n to clear, as in the following example: $ echo -n unconfined_u:object_r:user_home_t:s0 > /proc/$$/attr/fscreate $ cat /proc/$$/attr/fscreate unconfined_u:object_r:user_home_t:s0 $ echo "" > /proc/$$/attr/fscreate $ cat /proc/$$/attr/fscreate Note the use of /proc/$$ rather than /proc/self, as otherwise the cat command will read its own attribute value, not that of the shell. There are no users of this facility to my knowledge; possibly we should just get rid of it. UPDATE: Upon further investigation it appears that a local process with the process:setfscreate permission can cause a kernel panic as a result of this bug. This patch fixes CVE-2017-2618. Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov> [PM: added the update about CVE-2017-2618 to the commit description] Signed-off-by: Paul Moore <paul@paul-moore.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: James Morris <james.l.morris@oracle.com>
2017-02-14ARC: [arcompact] brown paper bag bug in unaligned access delay slot fixupVineet Gupta
commit a524c218bc94c705886a0e0fedeee45d1931da32 upstream. Reported-by: Jo-Philipp Wich <jo@mein.io> Fixes: 9aed02feae57bf7 ("ARC: [arcompact] handle unaligned access delay slot") Cc: linux-kernel@vger.kernel.org Cc: linux-snps-arc@lists.infradead.org Signed-off-by: Vineet Gupta <vgupta@synopsys.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09Linux 4.4.48v4.4.48Greg Kroah-Hartman
2017-02-09base/memory, hotplug: fix a kernel oops in show_valid_zones()Toshi Kani
commit a96dfddbcc04336bbed50dc2b24823e45e09e80c upstream. Reading a sysfs "memoryN/valid_zones" file leads to the following oops when the first page of a range is not backed by struct page. show_valid_zones() assumes that 'start_pfn' is always valid for page_zone(). BUG: unable to handle kernel paging request at ffffea017a000000 IP: show_valid_zones+0x6f/0x160 This issue may happen on x86-64 systems with 64GiB or more memory since their memory block size is bumped up to 2GiB. [1] An example of such systems is desribed below. 0x3240000000 is only aligned by 1GiB and this memory block starts from 0x3200000000, which is not backed by struct page. BIOS-e820: [mem 0x0000003240000000-0x000000603fffffff] usable Since test_pages_in_a_zone() already checks holes, fix this issue by extending this function to return 'valid_start' and 'valid_end' for a given range. show_valid_zones() then proceeds with the valid range. [1] 'Commit bdee237c0343 ("x86: mm: Use 2GB memory block size on large-memory x86-64 systems")' Link: http://lkml.kernel.org/r/20170127222149.30893-3-toshi.kani@hpe.com Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Zhang Zhen <zhenzhang.zhang@huawei.com> Cc: Reza Arbab <arbab@linux.vnet.ibm.com> Cc: David Rientjes <rientjes@google.com> Cc: Dan Williams <dan.j.williams@intel.com> Cc: <stable@vger.kernel.org> [4.4+] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09x86/irq: Make irq activate operations symmetricThomas Gleixner
commit aaaec6fc755447a1d056765b11b24d8ff2b81366 upstream. The recent commit which prevents double activation of interrupts unearthed interesting code in x86. The code (ab)uses irq_domain_activate_irq() to reconfigure an already activated interrupt. That trips over the prevention code now. Fix it by deactivating the interrupt before activating the new configuration. Fixes: 08d85f3ea99f1 "irqdomain: Avoid activating interrupts more than once" Reported-and-tested-by: Mike Galbraith <efault@gmx.de> Reported-and-tested-by: Borislav Petkov <bp@alien8.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de> Cc: Andrey Ryabinin <aryabinin@virtuozzo.com> Cc: Marc Zyngier <marc.zyngier@arm.com> Link: http://lkml.kernel.org/r/alpine.DEB.2.20.1701311901580.3457@nanos Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09USB: serial: option: add device ID for HP lt2523 (Novatel E371)Bjørn Mork
commit 5d03a2fd2292e71936c4235885c35ccc3c94695b upstream. Yet another laptop vendor rebranded Novatel E371. Signed-off-by: Bjørn Mork <bjorn@mork.no> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09usb: gadget: f_fs: Assorted buffer overflow checks.Vincent Pelletier
commit 83e526f2a2fa4b2e82b6bd3ddbb26b70acfa8947 upstream. OS descriptor head, when flagged as provided, is accessed without checking if it fits in provided buffer. Verify length before access. Also, there are other places where buffer length it checked after accessing offsets which are potentially past the end. Check buffer length before as well to fail cleanly. Signed-off-by: Vincent Pelletier <plr.vincent@gmail.com> Acked-by: Felipe Balbi <felipe.balbi@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09USB: Add quirk for WORLDE easykey.25 MIDI keyboardLukáš Lalinský
commit d9b2997e4a0a874e452df7cdd7de5a54502bd0aa upstream. Add a quirk for WORLDE easykey.25 MIDI keyboard (idVendor=0218, idProduct=0401). The device reports that it has config string descriptor at index 3, but when the system selects the configuration and tries to get the description, it returns a -EPROTO error, the communication restarts and this keeps repeating over and over again. Not requesting the string descriptor makes the device work correctly. Relevant info from Wireshark: [...] CONFIGURATION DESCRIPTOR bLength: 9 bDescriptorType: 0x02 (CONFIGURATION) wTotalLength: 101 bNumInterfaces: 2 bConfigurationValue: 1 iConfiguration: 3 Configuration bmAttributes: 0xc0 SELF-POWERED NO REMOTE-WAKEUP 1... .... = Must be 1: Must be 1 for USB 1.1 and higher .1.. .... = Self-Powered: This device is SELF-POWERED ..0. .... = Remote Wakeup: This device does NOT support remote wakeup bMaxPower: 50 (100mA) [...] 45 0.369104 host 2.38.0 USB 64 GET DESCRIPTOR Request STRING [...] URB setup bmRequestType: 0x80 1... .... = Direction: Device-to-host .00. .... = Type: Standard (0x00) ...0 0000 = Recipient: Device (0x00) bRequest: GET DESCRIPTOR (6) Descriptor Index: 0x03 bDescriptorType: 0x03 Language Id: English (United States) (0x0409) wLength: 255 46 0.369255 2.38.0 host USB 64 GET DESCRIPTOR Response STRING[Malformed Packet] [...] Frame 46: 64 bytes on wire (512 bits), 64 bytes captured (512 bits) on interface 0 USB URB [Source: 2.38.0] [Destination: host] URB id: 0xffff88021f62d480 URB type: URB_COMPLETE ('C') URB transfer type: URB_CONTROL (0x02) Endpoint: 0x80, Direction: IN Device: 38 URB bus id: 2 Device setup request: not relevant ('-') Data: present (0) URB sec: 1484896277 URB usec: 455031 URB status: Protocol error (-EPROTO) (-71) URB length [bytes]: 0 Data length [bytes]: 0 [Request in: 45] [Time from request: 0.000151000 seconds] Unused Setup Header Interval: 0 Start frame: 0 Copy of Transfer Flags: 0x00000200 Number of ISO descriptors: 0 [Malformed Packet: USB] [Expert Info (Error/Malformed): Malformed Packet (Exception occurred)] [Malformed Packet (Exception occurred)] [Severity level: Error] [Group: Malformed] Signed-off-by: Lukáš Lalinský <lukas@oxygene.sk> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09USB: serial: pl2303: add ATEN device IDMarcel J.E. Mol
commit d07830db1bdb254e4b50d366010b219286b8c937 upstream. Seems that ATEN serial-to-usb devices using pl2303 exist with different device ids. This patch adds a missing device ID so it is recognised by the driver. Signed-off-by: Marcel J.E. Mol <marcel@mesa.nl> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09USB: serial: qcserial: add Dell DW5570 QDLAleksander Morgado
commit 24d615a694d649aa2e167c3f97f62bdad07e3f84 upstream. The Dell DW5570 is a re-branded Sierra Wireless MC8805 which will by default boot with vid 0x413c and pid 0x81a3. When triggered QDL download mode, the device switches to pid 0x81a6 and provides the standard TTY used for firmware upgrade. Signed-off-by: Aleksander Morgado <aleksander@aleksander.es> Signed-off-by: Johan Hovold <johan@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09KVM: x86: do not save guest-unsupported XSAVE stateRadim Krčmář
commit 00c87e9a70a17b355b81c36adedf05e84f54e10d upstream. Saving unsupported state prevents migration when the new host does not support a XSAVE feature of the original host, even if the feature is not exposed to the guest. We've masked host features with guest-visible features before, with 4344ee981e21 ("KVM: x86: only copy XSAVE state for the supported features") and dropped it when implementing XSAVES. Do it again. Fixes: df1daba7d1cb ("KVM: x86: support XSAVES usage in the host") Reviewed-by: Paolo Bonzini <pbonzini@redhat.com> Signed-off-by: Radim Krčmář <rkrcmar@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09HID: wacom: Fix poor prox handling in 'wacom_pl_irq'Jason Gerecke
commit 282e4637bc1c0b338708bcebd09d31c69abec070 upstream. Commit 025bcc1 performed cleanup work on the 'wacom_pl_irq' function, making it follow the standards used in the rest of the codebase. The change unintiontionally allowed the function to send input events from reports that are not marked as being in prox. This can cause problems as the report values for X, Y, etc. are not guaranteed to be correct. In particular, occasionally the tablet will send a report with these values set to zero. If such a report is received it can caus an unexpected jump in the XY position. This patch surrounds more of the processing code with a proximity check, preventing these zeroed reports from overwriting the current state. To be safe, only the tool type and ABS_MISC events should be reported when the pen is marked as being out of prox. Fixes: 025bcc1540 ("HID: wacom: Simplify 'wacom_pl_irq'") Signed-off-by: Jason Gerecke <jason.gerecke@wacom.com> Reviewed-by: Ping Cheng <pingc@wacom.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09percpu-refcount: fix reference leak during percpu-atomic transitionDouglas Miller
commit 966d2b04e070bc040319aaebfec09e0144dc3341 upstream. percpu_ref_tryget() and percpu_ref_tryget_live() should return "true" IFF they acquire a reference. But the return value from atomic_long_inc_not_zero() is a long and may have high bits set, e.g. PERCPU_COUNT_BIAS, and the return value of the tryget routines is bool so the reference may actually be acquired but the routines return "false" which results in a reference leak since the caller assumes it does not need to do a corresponding percpu_ref_put(). This was seen when performing CPU hotplug during I/O, as hangs in blk_mq_freeze_queue_wait where percpu_ref_kill (blk_mq_freeze_queue_start) raced with percpu_ref_tryget (blk_mq_timeout_work). Sample stack trace: __switch_to+0x2c0/0x450 __schedule+0x2f8/0x970 schedule+0x48/0xc0 blk_mq_freeze_queue_wait+0x94/0x120 blk_mq_queue_reinit_work+0xb8/0x180 blk_mq_queue_reinit_prepare+0x84/0xa0 cpuhp_invoke_callback+0x17c/0x600 cpuhp_up_callbacks+0x58/0x150 _cpu_up+0xf0/0x1c0 do_cpu_up+0x120/0x150 cpu_subsys_online+0x64/0xe0 device_online+0xb4/0x120 online_store+0xb4/0xc0 dev_attr_store+0x68/0xa0 sysfs_kf_write+0x80/0xb0 kernfs_fop_write+0x17c/0x250 __vfs_write+0x6c/0x1e0 vfs_write+0xd0/0x270 SyS_write+0x6c/0x110 system_call+0x38/0xe0 Examination of the queue showed a single reference (no PERCPU_COUNT_BIAS, and __PERCPU_REF_DEAD, __PERCPU_REF_ATOMIC set) and no requests. However, conditions at the time of the race are count of PERCPU_COUNT_BIAS + 0 and __PERCPU_REF_DEAD and __PERCPU_REF_ATOMIC set. The fix is to make the tryget routines use an actual boolean internally instead of the atomic long result truncated to a int. Fixes: e625305b3907 percpu-refcount: make percpu_ref based on longs instead of ints Link: https://bugzilla.kernel.org/show_bug.cgi?id=190751 Signed-off-by: Douglas Miller <dougmill@linux.vnet.ibm.com> Reviewed-by: Jens Axboe <axboe@fb.com> Signed-off-by: Tejun Heo <tj@kernel.org> Fixes: e625305b3907 ("percpu-refcount: make percpu_ref based on longs instead of ints") Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09mmc: sdhci: Ignore unexpected CARD_INT interruptsGabriel Krisman Bertazi
commit 161e6d44a5e2d3f85365cb717d60e363171b39e6 upstream. One of our kernelCI boxes hanged at boot because a faulty eSDHC device was triggering spurious CARD_INT interrupts for SD cards, causing CMD52 reads, which are not allowed for SD devices. This adds a sanity check to the interruption path, preventing that illegal command from getting sent if the CARD_INT interruption should be disabled. This quirk allows that particular machine to resume boot despite the faulty hardware, instead of getting hung dealing with thousands of mishandled interrupts. Suggested-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Gabriel Krisman Bertazi <krisman@collabora.co.uk> Acked-by: Adrian Hunter <adrian.hunter@intel.com> Signed-off-by: Ulf Hansson <ulf.hansson@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09can: bcm: fix hrtimer/tasklet termination in bcm op removalOliver Hartkopp
commit a06393ed03167771246c4c43192d9c264bc48412 upstream. When removing a bcm tx operation either a hrtimer or a tasklet might run. As the hrtimer triggers its associated tasklet and vice versa we need to take care to mutually terminate both handlers. Reported-by: Michael Josenhans <michael.josenhans@web.de> Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net> Tested-by: Michael Josenhans <michael.josenhans@web.de> Signed-off-by: Marc Kleine-Budde <mkl@pengutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09mm, fs: check for fatal signals in do_generic_file_read()Michal Hocko
commit 5abf186a30a89d5b9c18a6bf93a2c192c9fd52f6 upstream. do_generic_file_read() can be told to perform a large request from userspace. If the system is under OOM and the reading task is the OOM victim then it has an access to memory reserves and finishing the full request can lead to the full memory depletion which is dangerous. Make sure we rather go with a short read and allow the killed task to terminate. Link: http://lkml.kernel.org/r/20170201092706.9966-3-mhocko@kernel.org Signed-off-by: Michal Hocko <mhocko@suse.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Cc: Tetsuo Handa <penguin-kernel@I-love.SAKURA.ne.jp> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09mm/memory_hotplug.c: check start_pfn in test_pages_in_a_zone()Toshi Kani
commit deb88a2a19e85842d79ba96b05031739ec327ff4 upstream. Patch series "fix a kernel oops when reading sysfs valid_zones", v2. A sysfs memory file is created for each 2GiB memory block on x86-64 when the system has 64GiB or more memory. [1] When the start address of a memory block is not backed by struct page, i.e. a memory range is not aligned by 2GiB, reading its 'valid_zones' attribute file leads to a kernel oops. This issue was observed on multiple x86-64 systems with more than 64GiB of memory. This patch-set fixes this issue. Patch 1 first fixes an issue in test_pages_in_a_zone(), which does not test the start section. Patch 2 then fixes the kernel oops by extending test_pages_in_a_zone() to return valid [start, end). Note for stable kernels: The memory block size change was made by commit bdee237c0343 ("x86: mm: Use 2GB memory block size on large-memory x86-64 systems"), which was accepted to 3.9. However, this patch-set depends on (and fixes) the change to test_pages_in_a_zone() made by commit 5f0f2887f4de ("mm/memory_hotplug.c: check for missing sections in test_pages_in_a_zone()"), which was accepted to 4.4. So, I recommend that we backport it up to 4.4. [1] 'Commit bdee237c0343 ("x86: mm: Use 2GB memory block size on large-memory x86-64 systems")' This patch (of 2): test_pages_in_a_zone() does not check 'start_pfn' when it is aligned by section since 'sec_end_pfn' is set equal to 'pfn'. Since this function is called for testing the range of a sysfs memory file, 'start_pfn' is always aligned by section. Fix it by properly setting 'sec_end_pfn' to the next section pfn. Also make sure that this function returns 1 only when the range belongs to a zone. Link: http://lkml.kernel.org/r/20170127222149.30893-2-toshi.kani@hpe.com Signed-off-by: Toshi Kani <toshi.kani@hpe.com> Cc: Andrew Banman <abanman@sgi.com> Cc: Reza Arbab <arbab@linux.vnet.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09cifs: initialize file_info_lockRabin Vincent
commit 81ddd8c0c5e1cb41184d66567140cb48c53eb3d1 upstream. Reviewed-by: Jeff Layton <jlayton@redhat.com> file_info_lock is not initalized in initiate_cifs_search(), leading to the following splat after a simple "mount.cifs ... dir && ls dir/": BUG: spinlock bad magic on CPU#0, ls/486 lock: 0xffff880009301110, .magic: 00000000, .owner: <none>/-1, .owner_cpu: 0 CPU: 0 PID: 486 Comm: ls Not tainted 4.9.0 #27 Hardware name: QEMU Standard PC (i440FX + PIIX, 1996) ffffc900042f3db0 ffffffff81327533 0000000000000000 ffff880009301110 ffffc900042f3dd0 ffffffff810baf75 ffff880009301110 ffffffff817ae077 ffffc900042f3df0 ffffffff810baff6 ffff880009301110 ffff880008d69900 Call Trace: [<ffffffff81327533>] dump_stack+0x65/0x92 [<ffffffff810baf75>] spin_dump+0x85/0xe0 [<ffffffff810baff6>] spin_bug+0x26/0x30 [<ffffffff810bb159>] do_raw_spin_lock+0xe9/0x130 [<ffffffff8159ad2f>] _raw_spin_lock+0x1f/0x30 [<ffffffff8127e50d>] cifs_closedir+0x4d/0x100 [<ffffffff81181cfd>] __fput+0x5d/0x160 [<ffffffff81181e3e>] ____fput+0xe/0x10 [<ffffffff8109410e>] task_work_run+0x7e/0xa0 [<ffffffff81002512>] exit_to_usermode_loop+0x92/0xa0 [<ffffffff810026f9>] syscall_return_slowpath+0x49/0x50 [<ffffffff8159b484>] entry_SYSCALL_64_fastpath+0xa7/0xa9 Fixes: 3afca265b5f53a0 ("Clarify locking of cifs file and tcon structures and make more granular") Signed-off-by: Rabin Vincent <rabinv@axis.com> Signed-off-by: Steve French <smfrench@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09zswap: disable changing params if init failsDan Streetman
commit d7b028f56a971a2e4d8d7887540a144eeefcd4ab upstream. Add zswap_init_failed bool that prevents changing any of the module params, if init_zswap() fails, and set zswap_enabled to false. Change 'enabled' param to a callback, and check zswap_init_failed before allowing any change to 'enabled', 'zpool', or 'compressor' params. Any driver that is built-in to the kernel will not be unloaded if its init function returns error, and its module params remain accessible for users to change via sysfs. Since zswap uses param callbacks, which assume that zswap has been initialized, changing the zswap params after a failed initialization will result in WARNING due to the param callbacks expecting a pool to already exist. This prevents that by immediately exiting any of the param callbacks if initialization failed. This was reported here: https://marc.info/?l=linux-mm&m=147004228125528&w=4 And fixes this WARNING: [ 429.723476] WARNING: CPU: 0 PID: 5140 at mm/zswap.c:503 __zswap_pool_current+0x56/0x60 The warning is just noise, and not serious. However, when init fails, zswap frees all its percpu dstmem pages and its kmem cache. The kmem cache might be serious, if kmem_cache_alloc(NULL, gfp) has problems; but the percpu dstmem pages are definitely a problem, as they're used as temporary buffer for compressed pages before copying into place in the zpool. If the user does get zswap enabled after an init failure, then zswap will likely Oops on the first page it tries to compress (or worse, start corrupting memory). Fixes: 90b0fc26d5db ("zswap: change zpool/compressor at runtime") Link: http://lkml.kernel.org/r/20170124200259.16191-2-ddstreet@ieee.org Signed-off-by: Dan Streetman <dan.streetman@canonical.com> Reported-by: Marcin Miroslaw <marcin@mejor.pl> Cc: Seth Jennings <sjenning@redhat.com> Cc: Michal Hocko <mhocko@kernel.org> Cc: Sergey Senozhatsky <sergey.senozhatsky.work@gmail.com> Cc: Minchan Kim <minchan@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09svcrpc: fix oops in absence of krb5 moduleJ. Bruce Fields
commit 034dd34ff4916ec1f8f74e39ca3efb04eab2f791 upstream. Olga Kornievskaia says: "I ran into this oops in the nfsd (below) (4.10-rc3 kernel). To trigger this I had a client (unsuccessfully) try to mount the server with krb5 where the server doesn't have the rpcsec_gss_krb5 module built." The problem is that rsci.cred is copied from a svc_cred structure that gss_proxy didn't properly initialize. Fix that. [120408.542387] general protection fault: 0000 [#1] SMP ... [120408.565724] CPU: 0 PID: 3601 Comm: nfsd Not tainted 4.10.0-rc3+ #16 [120408.567037] Hardware name: VMware, Inc. VMware Virtual = Platform/440BX Desktop Reference Platform, BIOS 6.00 07/02/2015 [120408.569225] task: ffff8800776f95c0 task.stack: ffffc90003d58000 [120408.570483] RIP: 0010:gss_mech_put+0xb/0x20 [auth_rpcgss] ... [120408.584946] ? rsc_free+0x55/0x90 [auth_rpcgss] [120408.585901] gss_proxy_save_rsc+0xb2/0x2a0 [auth_rpcgss] [120408.587017] svcauth_gss_proxy_init+0x3cc/0x520 [auth_rpcgss] [120408.588257] ? __enqueue_entity+0x6c/0x70 [120408.589101] svcauth_gss_accept+0x391/0xb90 [auth_rpcgss] [120408.590212] ? try_to_wake_up+0x4a/0x360 [120408.591036] ? wake_up_process+0x15/0x20 [120408.592093] ? svc_xprt_do_enqueue+0x12e/0x2d0 [sunrpc] [120408.593177] svc_authenticate+0xe1/0x100 [sunrpc] [120408.594168] svc_process_common+0x203/0x710 [sunrpc] [120408.595220] svc_process+0x105/0x1c0 [sunrpc] [120408.596278] nfsd+0xe9/0x160 [nfsd] [120408.597060] kthread+0x101/0x140 [120408.597734] ? nfsd_destroy+0x60/0x60 [nfsd] [120408.598626] ? kthread_park+0x90/0x90 [120408.599448] ret_from_fork+0x22/0x30 Fixes: 1d658336b05f "SUNRPC: Add RPC based upcall mechanism for RPCGSS auth" Cc: Simo Sorce <simo@redhat.com> Reported-by: Olga Kornievskaia <kolga@netapp.com> Tested-by: Olga Kornievskaia <kolga@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09NFSD: Fix a null reference case in find_or_create_lock_stateid()Kinglong Mee
commit d19fb70dd68c4e960e2ac09b0b9c79dfdeefa726 upstream. nfsd assigns the nfs4_free_lock_stateid to .sc_free in init_lock_stateid(). If nfsd doesn't go through init_lock_stateid() and put stateid at end, there is a NULL reference to .sc_free when calling nfs4_put_stid(ns). This patch let the nfs4_stid.sc_free assignment to nfs4_alloc_stid(). Fixes: 356a95ece7aa "nfsd: clean up races in lock stateid searching..." Signed-off-by: Kinglong Mee <kinglongmee@gmail.com> Reviewed-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09powerpc: Add missing error check to prom_find_boot_cpu()Darren Stevens
commit af2b7fa17eb92e52b65f96604448ff7a2a89ee99 upstream. prom_init.c calls 'instance-to-package' twice, but the return is not checked during prom_find_boot_cpu(). The result is then passed to prom_getprop(), which could be PROM_ERROR. Add a return check to prevent this. This was found on a pasemi system, where CFE doesn't have a working 'instance-to package' prom call. Before Commit 5c0484e25ec0 ('powerpc: Endian safe trampoline') the area around addr 0 was mostly 0's and this doesn't cause a problem. Once the macro 'FIXUP_ENDIAN' has been added to head_64.S, the low memory area now has non-zero values, which cause the prom_getprop() call to hang. mpe: Also confirmed that under SLOF if 'instance-to-package' did fail with PROM_ERROR we would crash in SLOF. So the bug is not specific to CFE, it's just that other open firmwares don't trigger it because they have a working 'instance-to-package'. Fixes: 5c0484e25ec0 ("powerpc: Endian safe trampoline") Signed-off-by: Darren Stevens <darren@stevens-zone.net> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09powerpc/eeh: Fix wrong flag passed to eeh_unfreeze_pe()Gavin Shan
commit f05fea5b3574a5926c53865eea27139bb40b2f2b upstream. In __eeh_clear_pe_frozen_state(), we should pass the flag's value instead of its address to eeh_unfreeze_pe(). The isolated flag is cleared if no error returned from __eeh_clear_pe_frozen_state(). We never observed the error from the function. So the isolated flag should have been always cleared, no real issue is caused because of the misused @flag. This fixes the code by passing the value of @flag to eeh_unfreeze_pe(). Fixes: 5cfb20b96f6 ("powerpc/eeh: Emulate EEH recovery for VFIO devices") Signed-off-by: Gavin Shan <gwshan@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09libata: apply MAX_SEC_1024 to all CX1-JB*-HP devicesTejun Heo
commit e0edc8c546463f268d41d064d855bcff994c52fa upstream. Marko reports that CX1-JB512-HP shows the same timeout issues as CX1-JB256-HP. Let's apply MAX_SEC_128 to all devices in the series. Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Marko Koski-Vähälä <marko@koski-vahala.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09ata: sata_mv:- Handle return value of devm_ioremap.Arvind Yadav
commit 064c3db9c564cc5be514ac21fb4aa26cc33db746 upstream. Here, If devm_ioremap will fail. It will return NULL. Then hpriv->base = NULL - 0x20000; Kernel can run into a NULL-pointer dereference. This error check will avoid NULL pointer dereference. Signed-off-by: Arvind Yadav <arvind.yadav.cs@gmail.com> Signed-off-by: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09perf/core: Fix PERF_RECORD_MMAP2 prot/flags for anonymous memoryPeter Zijlstra
commit 0b3589be9b98994ce3d5aeca52445d1f5627c4ba upstream. Andres reported that MMAP2 records for anonymous memory always have their protection field 0. Turns out, someone daft put the prot/flags generation code in the file branch, leaving them unset for anonymous memory. Reported-by: Andres Freund <andres@anarazel.de> Signed-off-by: Peter Zijlstra (Intel) <peterz@infradead.org> Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Don Zickus <dzickus@redhat.com Cc: Jiri Olsa <jolsa@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@gmail.com> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: acme@kernel.org Cc: anton@ozlabs.org Cc: namhyung@kernel.org Fixes: f972eb63b100 ("perf: Pass protection and flags bits through mmap2 interface") Link: http://lkml.kernel.org/r/20170126221508.GF6536@twins.programming.kicks-ass.net Signed-off-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-02-09crypto: arm64/aes-blk - honour iv_out requirement in CBC and CTR modesArd Biesheuvel
commit 11e3b725cfc282efe9d4a354153e99d86a16af08 upstream. Update the ARMv8 Crypto Extensions and the plain NEON AES implementations in CBC and CTR modes to return the next IV back to the skcipher API client. This is necessary for chaining to work correctly. Note that for CTR, this is only done if the request is a round multiple of the block size, since otherwise, chaining is impossible anyway. Signed-off-by: Ard Biesheuvel <ard.biesheuvel@linaro.org> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
