2006-01-03[IP_SOCKGLUE]: Remove most of the tcp specific callsArnaldo Carvalho de Melo
As DCCP needs to be called in the same spots. Now we have a member in inet_sock (is_icsk), set at sock creation time from struct inet_protosw->flags (if INET_PROTOSW_ICSK is set, like for TCP and DCCP) to see if a struct sock instance is a inet_connection_sock for places like the ones in ip_sockglue.c (v4 and v6) where we previously were looking if sk_type was SOCK_STREAM, that is insufficient because we now use the same code for DCCP, that has sk_type SOCK_DCCP. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP]: Move the TCPF_ enum to tcp_states.hArnaldo Carvalho de Melo
Upcoming patches will make, for instance, ip_sockglue.c need just this enum and not all of tcp.h. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET6]: Generalise tcp_v6_hash_connectArnaldo Carvalho de Melo
Renaming it to inet6_hash_connect, making it possible to ditch dccp_v6_hash_connect and share the same code with TCP instead. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[INET]: Generalise tcp_v4_hash_connectArnaldo Carvalho de Melo
Renaming it to inet_hash_connect, making it possible to ditch dccp_v4_hash_connect and share the same code with TCP instead. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TWSK]: Introduce struct timewait_sock_opsArnaldo Carvalho de Melo
So that we can share several timewait sockets related functions and make the timewait mini sockets infrastructure closer to the request mini sockets one. Next changesets will take advantage of this, moving more code out of TCP and DCCP v4 and v6 to common infrastructure. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Use reqsk_free in dccp_v4_conn_requestArnaldo Carvalho de Melo
Now we have the destructor (dccp_v4_reqsk_destructor) in our request_sock_ops vtable. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Introduce DCCPv6Arnaldo Carvalho de Melo
Still needs mucho polishing, specially in the checksum code, but works just fine, inet_diag/iproute2 and all 8) Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Export ipv6_opt_acceptedArnaldo Carvalho de Melo
It was already non-TCP specific, will be used by DCCPv6. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Prepare the AF agnostic core for the introduction of DCCPv6Arnaldo Carvalho de Melo
Basically exports a similar set of functions as the one exported by the non-AF specific TCP code. In the process moved some non-AF specific code from dccp_v4_connect to dccp_connect_init and moved the checksum verification from dccp_invalid_packet to dccp_v4_rcv, so as to use it in dccp_v6_rcv too. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Just rename dccp_v4_prot to dccp_protArnaldo Carvalho de Melo
To match TCP equivalent. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Export some symbols for DCCPv6Arnaldo Carvalho de Melo
2006-01-03[IPV6]: Introduce inet6_timewait_sockArnaldo Carvalho de Melo
Out of tcp6_timewait_sock, that now is just an aggregation of inet_timewait_sock and inet6_timewait_sock, using tw_ipv6_offset in struct inet_timewait_sock, that is common to the IPv6 transport protocols that use timewait sockets, like DCCP and TCP. tw_ipv6_offset plays the struct inet_sock pinfo6 role, i.e. for the generic code to find the IPv6 area in a timewait sock. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise some functionsArnaldo Carvalho de Melo
Using sk->sk_protocol instead of IPPROTO_TCP. Will be used by DCCPv6 in the next changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[AF_UNIX]: Remove superfluous reference counting in unix_stream_sendmsgBenjamin LaHaise
AF_UNIX stream socket performance on P4 CPUs tends to suffer due to a lot of pipeline flushes from atomic operations. The patch below removes the sock_hold() and sock_put() in unix_stream_sendmsg(). This should be safe as the socket still holds a reference to its peer which is only released after the file descriptor's final user invokes unix_release_sock(). The only consideration is that we must add a memory barrier before setting the peer initially. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NET]: Avoid atomic xchg() for non-error caseBenjamin LaHaise
It also looks like there were 2 places where the test on sk_err was missing from the event wait logic (in sk_stream_wait_connect and sk_stream_wait_memory), while the rest of the sock_error() users look to be doing the right thing. This version of the patch fixes those, and cleans up a few places that were testing ->sk_err directly. Signed-off-by: Benjamin LaHaise <benjamin.c.lahaise@intel.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPVS]: remove dead codeRoberto Nibali
This patch removes dead code. I don't see the reason to keep this cruft around, besides cluttering the nice and functionally working code. Signed-off-by: Roberto Nibali <ratz@drugphish.ch> Signed-off-by: Horms <horms@verge.net.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[UDP]: udp_checksum_init return valueStephen Hemminger
Since udp_checksum_init always returns 0 there is no point in having it return a value. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IP]: Simplify and consolidate MSG_PEEK error handlingHerbert Xu
When a packet is obtained from skb_recv_datagram with MSG_PEEK enabled it is left on the socket receive queue. This means that when we detect a checksum error we have to be careful when trying to free the packet as someone could have dequeued it in the time being. Currently this delicate logic is duplicated three times between UDPv4, UDPv6 and RAWv6. This patch moves them into a one place and simplifies the code somewhat. This is based on a suggestion by Eric Dumazet. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[DCCP]: Introduce dccp_ipv4_af_opsArnaldo Carvalho de Melo
And make the core DCCP code AF agnostic, just like TCP, now its time to work on net/dccp/ipv6.c, we are close to the end! Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: Move v4_addr2sockaddr from TCP to icskArnaldo Carvalho de Melo
Renaming it to inet_csk_addr2sockaddr. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: Rename struct tcp_func to struct inet_connection_sock_af_opsArnaldo Carvalho de Melo
And move it to struct inet_connection_sock. DCCP will use it in the upcoming changesets. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Introduce inet6_rsk()Arnaldo Carvalho de Melo
And inet6_rsk_offset in inet_request_sock, for the same reasons as inet_sock's pinfo6 member. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[IPV6]: Generalise tcp_v6_search_req & tcp_v6_synq_addArnaldo Carvalho de Melo
More work is needed tho to introduce inet6_request_sock from tcp6_request_sock, in the same layout considerations as ipv6_pinfo in inet_sock, next changeset will do that. Signed-off-by: Arnaldo Carvalho de Melo <acme@mandriva.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[ICSK]: make inet_csk_reqsk_queue_hash_add timeout arg unsigned longArnaldo Carvalho de Melo
2006-01-03[IPV6]: Generalise __tcp_v6_hash, renaming it to __inet6_hashArnaldo Carvalho de Melo
2006-01-03[IPV6]: Reuse inet_csk_get_port in tcp_v6_get_portArnaldo Carvalho de Melo
2006-01-03[IPV4]: Safer reassemblyHerbert Xu
Another spin of Herbert Xu's "safer ip reassembly" patch for 2.6.16. (The original patch is here: http://marc.theaimsgroup.com/?l=linux-netdev&m=112281936522415&w=2 and my only contribution is to have tested it.) This patch (optionally) does additional checks before accepting IP fragments, which can greatly reduce the possibility of reassembling fragments which originated from different IP datagrams. Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: Arthur Kepner <akepner@sgi.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NETFILTER] ebtables: Support nf_log API from ebt_log and ebt_ulogBart De Schuymer
This makes ebt_log and ebt_ulog use the new nf_log api. This enables the bridging packet filter to log packets e.g. via nfnetlink_log. Signed-off-by: Bart De Schuymer <bdschuym@pandora.be> Signed-off-by: Harald Welte <laforge@netfilter.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[NETFILTER] ip_tables: NUMA-aware allocationEric Dumazet
Part of a performance problem with ip_tables is that memory allocation is not NUMA aware, but 'only' SMP aware (ie each CPU normally touch separate cache lines) Even with small iptables rules, the cost of this misplacement can be high on common workloads. Instead of using one vmalloc() area (located in the node of the iptables process), we now allocate an area for each possible CPU, using vmalloc_node() so that memory should be allocated in the CPU's node if possible. Port to arp_tables and ip6_tables by Harald Welte. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP] BIC: CUBIC window growth (2.0)Stephen Hemminger
Replace existing BIC version 1.1 with new version 2.0. The main change is to replace the window growth function with a cubic function as described in: http://www.csc.ncsu.edu/faculty/rhee/export/bitcp/cubic-paper.pdf Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[TCP] BIC: spelling and whitespaceStephen Hemminger
2006-01-03[TCP] BIC: remove low utilization code.Stephen Hemminger
The latest BICTCP patch at: http://www.csc.ncsu.edu:8080/faculty/rhee/export/bitcp/index_files/Page546.htm disables the low_utilization feature of BICTCP because it doesn't work in some cases. This patch removes it. Signed-off-by: Stephen Hemminger <shemminger@osdl.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[LSM-IPSec]: Per-packet access control.Trent Jaeger
This patch series implements per packet access control via the extension of the Linux Security Modules (LSM) interface by hooks in the XFRM and pfkey subsystems that leverage IPSec security associations to label packets. Extensions to the SELinux LSM are included that leverage the patch for this purpose. This patch implements the changes necessary to the SELinux LSM to create, deallocate, and use security contexts for policies (xfrm_policy) and security associations (xfrm_state) that enable control of a socket's ability to send and receive packets. Patch purpose: The patch is designed to enable the SELinux LSM to implement access control on individual packets based on the strongly authenticated IPSec security association. Such access controls augment the existing ones in SELinux based on network interface and IP address. The former are very coarse-grained, and the latter can be spoofed. By using IPSec, the SELinux can control access to remote hosts based on cryptographic keys generated using the IPSec mechanism. This enables access control on a per-machine basis or per-application if the remote machine is running the same mechanism and trusted to enforce the access control policy. Patch design approach: The patch's main function is to authorize a socket's access to a IPSec policy based on their security contexts. Since the communication is implemented by a security association, the patch ensures that the security association's negotiated and used have the same security context. The patch enables allocation and deallocation of such security contexts for policies and security associations. It also enables copying of the security context when policies are cloned. Lastly, the patch ensures that packets that are sent without using a IPSec security assocation with a security context are allowed to be sent in that manner. A presentation available at www.selinux-symposium.org/2005/presentations/session2/2-3-jaeger.pdf from the SELinux symposium describes the overall approach. Patch implementation details: The function which authorizes a socket to perform a requested operation (send/receive) on a IPSec policy (xfrm_policy) is selinux_xfrm_policy_lookup. The Netfilter and rcv_skb hooks ensure that if a IPSec SA with a securit y association has not been used, then the socket is allowed to send or receive the packet, respectively. The patch implements SELinux function for allocating security contexts when policies (xfrm_policy) are created via the pfkey or xfrm_user interfaces via selinux_xfrm_policy_alloc. When a security association is built, SELinux allocates the security context designated by the XFRM subsystem which is based on that of the authorized policy via selinux_xfrm_state_alloc. When a xfrm_policy is cloned, the security context of that policy, if any, is copied to the clone via selinux_xfrm_policy_clone. When a xfrm_policy or xfrm_state is freed, its security context, if any is also freed at selinux_xfrm_policy_free or selinux_xfrm_state_free. Testing: The SELinux authorization function is tested using ipsec-tools. We created policies and security associations with particular security contexts and added SELinux access control policy entries to verify the authorization decision. We also made sure that packets for which no security context was supplied (which either did or did not use security associations) were authorized using an unlabelled context. Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-03[LSM-IPSec]: Security association restriction.Trent Jaeger
This patch series implements per packet access control via the extension of the Linux Security Modules (LSM) interface by hooks in the XFRM and pfkey subsystems that leverage IPSec security associations to label packets. Extensions to the SELinux LSM are included that leverage the patch for this purpose. This patch implements the changes necessary to the XFRM subsystem, pfkey interface, ipv4/ipv6, and xfrm_user interface to restrict a socket to use only authorized security associations (or no security association) to send/receive network packets. Patch purpose: The patch is designed to enable access control per packets based on the strongly authenticated IPSec security association. Such access controls augment the existing ones based on network interface and IP address. The former are very coarse-grained, and the latter can be spoofed. By using IPSec, the system can control access to remote hosts based on cryptographic keys generated using the IPSec mechanism. This enables access control on a per-machine basis or per-application if the remote machine is running the same mechanism and trusted to enforce the access control policy. Patch design approach: The overall approach is that policy (xfrm_policy) entries set by user-level programs (e.g., setkey for ipsec-tools) are extended with a security context that is used at policy selection time in the XFRM subsystem to restrict the sockets that can send/receive packets via security associations (xfrm_states) that are built from those policies. A presentation available at www.selinux-symposium.org/2005/presentations/session2/2-3-jaeger.pdf from the SELinux symposium describes the overall approach. Patch implementation details: On output, the policy retrieved (via xfrm_policy_lookup or xfrm_sk_policy_lookup) must be authorized for the security context of the socket and the same security context is required for resultant security association (retrieved or negotiated via racoon in ipsec-tools). This is enforced in xfrm_state_find. On input, the policy retrieved must also be authorized for the socket (at __xfrm_policy_check), and the security context of the policy must also match the security association being used. The patch has virtually no impact on packets that do not use IPSec. The existing Netfilter (outgoing) and LSM rcv_skb hooks are used as before. Also, if IPSec is used without security contexts, the impact is minimal. The LSM must allow such policies to be selected for the combination of socket and remote machine, but subsequent IPSec processing proceeds as in the original case. Testing: The pfkey interface is tested using the ipsec-tools. ipsec-tools have been modified (a separate ipsec-tools patch is available for version 0.5) that supports assignment of xfrm_policy entries and security associations with security contexts via setkey and the negotiation using the security contexts via racoon. The xfrm_user interface is tested via ad hoc programs that set security contexts. These programs are also available from me, and contain programs for setting, getting, and deleting policy for testing this interface. Testing of sa functions was done by tracing kernel behavior. Signed-off-by: Trent Jaeger <tjaeger@cse.psu.edu> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-01-02Linux v2.6.15v2.6.15Linus Torvalds
Hey, it's fifteen years today since I bought the machine that got Linux started. January 2nd is a good date.
2006-01-02[PATCH] Make sure interleave masks have at least one node setAndi Kleen
Otherwise a bad mem policy system call can confuse the interleaving code into referencing undefined nodes. Originally reported by Doug Chapman I was told it's CVE-2005-3358 (one has to love these security people - they make everything sound important) Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-02[PATCH] Avoid namespace pollution in <asm/param.h>Dag-Erling Smørgrav
In commit 3D59121003721a8fad11ee72e646fd9d3076b5679c, the x86 and x86-64 <asm/param.h> was changed to include <linux/config.h> for the configurable timer frequency. However, asm/param.h is sometimes used in userland (it is included indirectly from <sys/param.h>), so your commit pollutes the userland namespace with tons of CONFIG_FOO macros. This greatly confuses software packages (such as BusyBox) which use CONFIG_FOO macros themselves to control the inclusion of optional features. After a short exchange, Christoph approved this patch Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-02[PATCH] powerpc: more g5 overtemp problem fixBenjamin Herrenschmidt
Some G5s still occasionally experience shutdowns due to overtemp conditions despite the recent fix. After analyzing logs from such machines, it appears that the overtemp code is a bit too quick at shutting the machine down when reaching the critical temperature (tmax + 8) and doesn't leave the fan enough time to actually cool it down. This happens if the temperature of a CPU suddenly rises too high in a very short period of time, or occasionally on boot (that is the CPUs are already overtemp by the time the driver loads). This patches makes the code a bit more relaxed, leaving a few seconds to the fans to do their job before kicking the machine shutown. Signed-off-by: Benjamin Herrenschmidt <benh@kernel.crashing.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-31[PATCH] x86: teach dump_task_regs() about the -8 offset.Stas Sergeev
This should fix multi-threaded core-files Signed-off-by: stsp@aknet.ru Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-31sysctl: make sure to terminate strings with a NULLinus Torvalds
This is a slightly more complete fix for the previous minimal sysctl string fix. It always terminates the returned string with a NUL, even if the full result wouldn't fit in the user-supplied buffer. The returned length is the full untruncated length, so that you can tell when truncation has occurred. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-31Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
2005-12-30[PATCH] Fix false old value return of sysctlYi Yang
For the sysctl syscall, if the user wants to get the old value of a sysctl entry and set a new value for it in the same syscall, the old value is always overwritten by the new value if the sysctl entry is of string type and if the user sets its strategy to sysctl_string. This issue lies in the strategy being run twice if the strategy is set to sysctl_string, the general strategy sysctl_string always returns 0 if success. Such strategy routines as sysctl_jiffies and sysctl_jiffies_ms return 1 because they do read and write for the sysctl entry. The strategy routine sysctl_string return 0 although it actually read and write the sysctl entry. According to my analysis, if a strategy routine do read and write, it should return 1, if it just does some necessary check but not read and write, it should return 0, for example sysctl_intvec. Signed-off-by: Yi Yang <yang.y.yi@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-30sysctl: don't overflow the user-supplied buffer with '\0'Linus Torvalds
If the string was too long to fit in the user-supplied buffer, the sysctl layer would zero-terminate it by writing past the end of the buffer. Don't do that. Noticed by Yi Yang <yang.y.yi@gmail.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-30Insanity avoidance in /procLinus Torvalds
The old /proc interfaces were never updated to use loff_t, and are just generally broken. Now, we should be using the seq_file interface for all of the proc files, but converting the legacy functions is more work than most people care for and has little upside.. But at least we can make the non-LFS rules explicit, rather than just insanely wrapping the offset or something. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-30[PATCH] Input: wacom - fix X axis setupDenny Priebe
This patch fixes a typo introduced by conversion to dynamic input_dev allocation. Signed-off-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-30[PATCH] Input: warrior - fix HAT0Y axis setupDmitry Torokhov
2005-12-30[PATCH] Input: kbtab - fix Y axis setupDmitry Torokhov
2005-12-30[ARM] 3216/1: indent and typo in drivers/serial/pxa.cErik Hovland
Patch from Erik Hovland This patch provides two changes. An indent is supplied for an if/else clause so that it is more readable. An acronym is incorrectly typed as UER when it should be IER. Signed-off-by: Erik Hovland <erik@hovland.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-12-29[PATCH] Simplify the VIDEO_SAA7134_OSS Kconfig dependency lineJean Delvare
Thanks to Roman Zippel for the suggestion. Signed-off-by: Jean Delvare <khali@linux-fr.org> [ Short explanation: Kconfig uses ternary math: n/m/y, and !m is m ] Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-29Revert radeon AGP aperture offset changesLinus Torvalds
This reverts the series of commits 67dbb4ea33731415fe09c62149a34f472719ac1d 281ab031a8c9e5b593142eb4ec59a87faae8676a 47807ce381acc34a7ffee2b42e35e96c0f322e52 that changed the GART VM start offset. It fixed some machines, but seems to continually interact badly with some X versions. Quoth Ben Herrenschmidt: "So I think at this point, the best is that we keep the old bogus code that at least is consistent with the bug in the server. I'm working on a big patch to X that reworks the memory map stuff completely and fixes those issues on the server side, I'll do a DRM patch matching this X fix as well so that the memory map is only ever set in one place and with what I hope is a correct algorithm..." Signed-off-by: Linus Torvalds <torvalds@osdl.org>
