2009-04-07namespaces: mqueue namespace: adapt sysctlSerge E. Hallyn
Largely inspired from ipc/ipc_sysctl.c. This patch isolates the mqueue sysctl stuff in its own file. [akpm@linux-foundation.org: build fix] Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Nadia Derbey <Nadia.Derbey@bull.net> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: ipc namespaces: implement support for posix msqueuesSerge E. Hallyn
Implement multiple mounts of the mqueue file system, and link it to usage of CLONE_NEWIPC. Each ipc ns has a corresponding mqueuefs superblock. When a user does clone(CLONE_NEWIPC) or unshare(CLONE_NEWIPC), the unshare will cause an internal mount of a new mqueuefs sb linked to the new ipc ns. When a user does 'mount -t mqueue mqueue /dev/mqueue', he mounts the mqueuefs superblock. Posix message queues can be worked with both through the mq_* system calls (see mq_overview(7)), and through the VFS through the mqueue mount. Any usage of mq_open() and friends will work with the acting task's ipc namespace. Any actions through the VFS will work with the mqueuefs in which the file was created. So if a user doesn't remount mqueuefs after unshare(CLONE_NEWIPC), mq_open("/ab") will not be reflected in "ls /dev/mqueue". If task a mounts mqueue for ipc_ns:1, then clones task b with a new ipcns, ipcns:2, and then task a is the last task in ipc_ns:1 to exit, then (1) ipc_ns:1 will be freed, (2) it's superblock will live on until task b umounts the corresponding mqueuefs, and vfs actions will continue to succeed, but (3) sb->s_fs_info will be NULL for the sb corresponding to the deceased ipc_ns:1. To make this happen, we must protect the ipc reference count when a) a task exits and drops its ipcns->count, since it might be dropping it to 0 and freeing the ipcns b) a task accesses the ipcns through its mqueuefs interface, since it bumps the ipcns refcount and might race with the last task in the ipcns exiting. So the kref is changed to an atomic_t so we can use atomic_dec_and_lock(&ns->count,mq_lock), and every access to the ipcns through ns = mqueuefs_sb->s_fs_info is protected by the same lock. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: mqueue ns: move mqueue_mnt into struct ipc_namespaceSerge E. Hallyn
Move mqueue vfsmount plus a few tunables into the ipc_namespace struct. The CONFIG_IPC_NS boolean and the ipc_namespace struct will serve both the posix message queue namespaces and the SYSV ipc namespaces. The sysctl code will be fixed separately in patch 3. After just this patch, making a change to posix mqueue tunables always changes the values in the initial ipc namespace. Signed-off-by: Cedric Le Goater <clg@fr.ibm.com> Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07namespaces: move proc_net_get_sb to a generic fs/super.c helperSerge E. Hallyn
The mqueuefs filesystem will use this helper as well. Proc's main get_sb could also be made to use it, but that will require a bit more rework. Signed-off-by: Serge E. Hallyn <serue@us.ibm.com> Cc: Cedric Le Goater <clg@fr.ibm.com> Cc: Alexey Dobriyan <adobriyan@gmail.com> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07uvesafb: documentation updateMichal Januszewski
Update the uvesafb documentation to accurately reflect the default options used by the driver. Signed-off-by: Michal Januszewski <spock@gentoo.org> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07fbdev: i.MX31: fix panning, error handling, clean upGuennadi Liakhovetski
1. check for errors returned from clk_get() 2. fix "Unbalanced enable for IRQ 160" 3. fix transmit descriptor handling in panning 4. clean frame buffer on blank - useful for OLED displays 5. formatting clean up Signed-off-by: Guennadi Liakhovetski <lg@denx.de> Cc: Dan Williams <dan.j.williams@intel.com> Cc: Sascha Hauer <s.hauer@pengutronix.de> Cc: Krzysztof Helt <krzysztof.h1@poczta.fm> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07tdfxfb: make use of DDC information about connected monitorKrzysztof Helt
Read DDC information from a connected monitor and use it to select initial mode (if the mode is not specified). Also, use the information to protect against modes outside the monitor specs. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Tested-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07tdfxfb: move I2C functionality into the tdfxfbKrzysztof Helt
The I2C functionality provided by the i2c-voodoo3 driver is moved into the tdfxfb (frame buffer driver for Voodoo3 cards). This way there is no conflict between the i2c driver and the fb driver. The tdfxfb does not make use from the DDC functionality yet but provides all the functionality of the i2c-voodoo3 driver. Signed-off-by: Krzysztof Helt <krzysztof.h1@wp.pl> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: support kretprobe and jprobe per-probe disablingMasami Hiramatsu
Add disable/enable_kretprobe() and disable/enable_jprobe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: support per-kprobe disablingMasami Hiramatsu
Add disable_kprobe() and enable_kprobe() to disable/enable kprobes temporarily. disable_kprobe() asynchronously disables probe handlers of specified kprobe. So, after calling it, some handlers can be called at a while. enable_kprobe() enables specified kprobe. aggr_pre_handler and aggr_post_handler check disabled probes. On the other hand aggr_break_handler and aggr_fault_handler don't check it because these handlers will be called while executing pre or post handlers and usually those help error handling. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: rename kprobe_enabled to kprobes_all_disarmedMasami Hiramatsu
Rename kprobe_enabled to kprobes_all_disarmed and invert logic due to avoiding naming confusion from per-probe disabling. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: cleanup comment style in kprobes.hMasami Hiramatsu
Fix comment style in kprobes.h. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: move EXPORT_SYMBOL_GPL just after function definitionsMasami Hiramatsu
Clean up positions of EXPORT_SYMBOL_GPL in kernel/kprobes.c according to checkpatch.pl. Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07kprobes: cleanup aggr_kprobe related codeMasami Hiramatsu
Currently, kprobes can disable all probes at once, but can't disable it individually (not unregister, just disable an kprobe, because unregistering needs to wait for scheduler synchronization). These patches introduce APIs for on-the-fly per-probe disabling and re-enabling by dis-arming/re-arming its breakpoint instruction. This patch: Change old_p to ap in add_new_kprobe() for readability, copy flags member in add_aggr_kprobe(), and simplify the code flow of register_aggr_kprobe(). Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Acked-by: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> Cc: David S. Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07spi_imx: set spi_master.dma_alignment = 4Mike Rapoport
Signed-off-by: Mike Rapoport <mike@compulab.co.il> Cc: Bryan Wu <bryan.wu@analog.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07pxa2xx_spi: set spi_master.dma_alignment = 8Mike Rapoport
2009-04-07SPI: add dma_alignment field to spi_masterMike Rapoport
Some SPI controllers have restrictions on DMAable buffers alignemt. Currently if the buffer supplied by protocol driver is not properly aligned, the controller silently performs transfer in PIO mode. Addition of dma_alignment field to spi_master allows protocol drivers to perform proper alignment. Signed-off-by: Mike Rapoport <mike@compulab.co.il> Cc: Bryan Wu <bryan.wu@analog.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07spi_bfin5xx: remove unused IS_DMA_ALIGNED macroMike Rapoport
2009-04-07spi: pxa2xx_spi: introduce chipselect GPIO to simplify the common casesEric Miao
Most SPI peripherals use GPIOs as their chip selects, introduce .gpio_cs for this. Signed-off-by: Eric Miao <eric.miao@marvell.com> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07spi: limit reaches -1, tested 0Roel Kluin
With a postfix decrement limit will reach -1 rather than 0, so the warning will not be issued. Also, add a cpu_relax() into the busy-wait loop. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Mariusz Ceier <mceier@gmail.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Make mmc_spi driver work on BlackfinWolfgang Muees
1. Rewrite of the non-dma data transfer functions to use only ONE mode of TIMOD (TIMOD=0x1). With TIMOD=0, it was not possible to set the TX bit pattern. So the TDBR = 0xFFFF inside the read calls won't work. 2. Clear SPI_RDBR before reading and before duplex transfer. Otherwise the garbage data in RDBR will get read. Since mmc_spi uses a lot of duplex transfers, this is the main cause of mmc_spi failure. 3. Poll RXS for transfer completion. Polling SPIF or TXS cannot guarantee transfer completion. This may interrupt a transfer before it is finished. Also this may leave garbage data in buffer and affect next transfer. [Yi Li <yi.li@analog.com>: add a field "u16 idle_tx_val" in "struct bfin5xx_spi_chip" to specify the value to transmit if no TX value is supplied.] Signed-off-by: Wolfgang Muees <wolfgang.mues@auerswald.de> Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Add GPIO controlled SPI Slave Select supportMichael Hennerich
Add support for GPIO controlled SPI Chip Selects. To make use of this feature, set chip_select = 0 and add a proper cs_gpio to your controller_data. struct spi_board_info .chip_select = 0 struct bfin5xx_spi_chip .cs_gpio = GPIO_P### There are various SPI devices that require SPI MODE_0, and need to have the Chip Selects asserted during the entire transfer. Consider using SPI_MODE_3 (SPI_CPHA | SPI_CPOL) if your device allows it. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: fix NULL pointer crashMike Frysinger
Fix NULL pointer crash when cleaning up from invalid platform resources Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: use bfin_spi_ prefix on all functionsMike Frysinger
Do this because when things crash, we get simple names like "setup" and "start_queue" which is pretty difficult to trace back to the real thing: the spi driver Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: fix bug - correct usage of struct spi_transfer.cs_changeYi Li
According to comments in linux/spi/spi.h: * All SPI transfers start with the relevant chipselect active. Normally * it stays selected until after the last transfer in a message. Drivers * can affect the chipselect signal using cs_change. * * (i) If the transfer isn't the last one in the message, this flag is * used to make the chipselect briefly go inactive in the middle of the * message. Toggling chipselect in this way may be needed to terminate * a chip command, letting a single spi_message perform all of group of * chip transactions together. * * (ii) When the transfer is the last one in the message, the chip may * stay selected until the next transfer. On multi-device SPI busses * with nothing blocking messages going to other devices, this is just * a performance hint; starting a message to another device deselects * this one. But in other cases, this can be used to ensure correctness. * Some devices need protocol transactions to be built from a series of * spi_message submissions, where the content of one message is determined * by the results of previous messages and where the whole transaction * ends when the chipselect goes intactive. Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: fix bug - spi controller driver does not ↵Yi Li
assert/deassert CS correctly This bug can be observed when two SPI devices are sharing the spi bus: One device is set as SPI CS 7, another one is using SPI CS 4. In spi_bfin5xx.c: cs_active(), cs_deactive() are used to control SPI_FLG register. From the debug bellow: cs_active: flag: 0x7f91, chip->flag: 0x7f80, cs: 7 cs_active: flag: 0xef91, chip->flag: 0xef10, cs: 4 When device A (cs_7) activate CS 7, SPI_FLG is set as 0x7f91 (however, SPI_FLG should be set as 0x7f80, or 0x6f91 if in broadcast mode). Due to some HW bug (very possibly), if SPI_FLG is set as 0x7f91, SPISSEL7 is asserted, however SPISSEL4 will be asserted too (I can see this using the scope). This is unreasonable according to HRM. Signed-off-by: Yi Li <yi.li@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: tweak magic spi dma sequence to get it working on BF54xMike Frysinger
Without this change, SPI DMA is not reliably under stress tests. Obiviously it's a hardware issue which is not addressed by any document. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: add timeout while waiting for SPIF in dma irq handlerMike Frysinger
The "while" endless loop will cause the system hang if hardware error, so we add timeout control to make the system alive. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: get dma working for SPI flashesMike Frysinger
When using a BF533-STAMP here with a W25X10 SPI flash. It works fine when enable_dma is disabled, but doesn't work at all when turning DMA on. We get just 0xff bytes back when trying to read the device. Change the code around so that it programs the SPI first and then enables DMA, it seems to work a lot better ... Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: SPI slave select code cleanupMike Frysinger
- remove duplicated definition MAX_SPI_SSEL - remove unnecessary array size Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: use the properl BIT_CTL_xxx definesMike Frysinger
use the properl BIT_CTL_... defines rather than the internal driv er CFG_SPI_... defines Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: do not check for SPI errors if DMA itself did not flag anyMike Frysinger
We only need to check SPI error when DMA failes, cause that is the DMA IRQ handling routine. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: add a few more DMA debug messagesMike Frysinger
Because of DMA hardware issue, we were trying to use software workaround. This patch add some useful debug messages to help us debugging the DMA code. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: drop bogus cast and touchup dma labelMike Frysinger
Blackfin's related DMA callback API doesn't need void * cast, so drop it. And this driver is for all Blackfin processors not only for BF53x, we update the DMA request label for more meaningful information. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: unify duplicated code in dma read/write pathsMike Frysinger
For DMA TX/RX operation in pump_transfers, DMA contriguration code in TX and RX paths are almost the same. This patch unify the duplicated DMA code to make it more readable. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: pass DMA overflow error to the higher levelMike Frysinger
If the SPI bus registers a receive overflow error, pass the result back up to the higher levels. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: use len_in_bytes when we care about the number of bytes ↵Mike Frysinger
transferred Use len_in_bytes when we care about the number of bytes transferred rather than the number of spi transactions. (this value will be the same for 8bit transfers, but not any other sizes) Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: remove useless <asm/cplbinit.h>Mike Frysinger
We already moved bfin_addr_dcachable() and friends into the cacheflush header where it belongs, so don't need to include <asm/cplbinit.h> here. Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: Fix erroneous SPI Clock divisor calculationMichael Hennerich
Fix erroneous SPI Clock divisor calculation. Make sure SPI_BAUD is always >= 2. Writing a value of 0 or 1 to the SPI_BAUD register disables the serial clock. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Blackfin SPI Driver: ensure cache coherency before doing DMAVitja Makarov
Flush or invalidate caches before doing DMA transfer, if needed. [Mike Frysinger <vapier.adi@gmail.com>: add comment to address the issue "Full duplex only works for non-DMA transfers".] Signed-off-by: Vitja Makarov <vitja.makarov@gmail.com> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Signed-off-by: Bryan Wu <cooloney@kernel.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07hwmon: add support for GMT G760A fan speed PWM controllerHerbert Valerio Riedel
This controller can be found on the D-Link DNS-323 for instance, where it is to be configured via static i2c_board_info in the board-specific mach-orion/dns323-setup.c; this driver supports only the new-style driver model. Tested-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Herbert Valerio Riedel <hvr@gnu.org> Signed-off-by: Matthew Palmer <mpalmer@debian.org> Signed-off-by: Laurie Bradshaw <bradshaw.laurie@googlemail.com> Signed-off-by: Martin Michlmayr <tbm@cyrius.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07/proc/pid/maps: don't show pgoff of pure ANON VMAsKAMEZAWA Hiroyuki
Recently, it's argued that what proc/pid/maps shows is ugly when a 32bit binary runs on 64bit host. /proc/pid/maps outputs vma's pgoff member but vma->pgoff is of no use information is the vma is for ANON. With this patch, /proc/pid/maps shows just 0 if no file backing store. [akpm@linux-foundation.org: coding-style fixes] [kamezawa.hiroyu@jp.fujitsu.com: coding-style fixes] Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Mike Waychison <mikew@google.com> Reported-by: Ying Han <yinghan@google.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07mm: add /proc controls for pdflush threadsPeter W Morreale
Add /proc entries to give the admin the ability to control the minimum and maximum number of pdflush threads. This allows finer control of pdflush on both large and small machines. The rationale is simply one size does not fit all. Admins on large and/or small systems may want to tune the min/max pdflush thread count to best suit their needs. Right now the min/max is hardcoded to 2/8. While probably a fair estimate for smaller machines, large machines with large numbers of CPUs and large numbers of filesystems/block devices may benefit from larger numbers of threads working on different block devices. Even if the background flushing algorithm is radically changed, it is still likely that multiple threads will be involved and admins would still desire finer control on the min/max other than to have to recompile the kernel. The patch adds '/proc/sys/vm/nr_pdflush_threads_min' and '/proc/sys/vm/nr_pdflush_threads_max' with r/w permissions. The minimum value for nr_pdflush_threads_min is 1 and the maximum value is the current value of nr_pdflush_threads_max. This minimum is required since additional thread creation is performed in a pdflush thread itself. The minimum value for nr_pdflush_threads_max is the current value of nr_pdflush_threads_min and the maximum value can be 1000. Documentation/sysctl/vm.txt is also updated. [akpm@linux-foundation.org: fix comment, fix whitespace, use __read_mostly] Signed-off-by: Peter W Morreale <pmorreale@novell.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07mm: fix pdflush thread creation upper boundPeter W Morreale
Fix a race on creating pdflush threads. Without the patch, it is possible to create more than MAX_PDFLUSH_THREADS threads, and this has been observed in practice on IO loaded SMP machines. The fix involves moving the lock around to protect the check against the thread count and correctly dealing with thread creation failure. This fix also _mostly_ repairs a race condition on how quickly the threads are created. The original intent was to create a pdflush thread (up to the max allowed) every second. Without this patch is is possible to create NCPUS pdflush threads concurrently. The 'mostly' caveat is because an assumption is made that thread creation will be successful. If we fail to create the thread, the miss is not considered fatal. (we will try again in 1 second) Signed-off-by: Peter W Morreale <pmorreale@novell.com> Reviewed-by: Rik van Riel <riel@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07esp: fix section mismatch warningRandy Dunlap
Not critical. WARNING: drivers/char/esp.o(.text+0x278): Section mismatch in reference from the function show_serial_version() to the variable .init.data:serial_version The function show_serial_version() references the variable __initdata serial_version. This is often because show_serial_version lacks a __initdata annotation or the annotation of serial_version is wrong. WARNING: drivers/char/esp.o(.text+0x27d): Section mismatch in reference from the function show_serial_version() to the variable .init.data:serial_name The function show_serial_version() references the variable __initdata serial_name. This is often because show_serial_version lacks a __initdata annotation or the annotation of serial_name is wrong. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andrew J. Robinson <arobinso@nyx.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07PCI: Fix oops in pci_vpd_truncateAnton Vorontsov
pci_vpd_truncate() should check for dev->vpd->attr, otherwise this might happen: sky2 driver version 1.22 Unable to handle kernel paging request for data at address 0x0000000c Faulting instruction address: 0xc01836fc Oops: Kernel access of bad area, sig: 11 [#1] [...] NIP [c01836fc] pci_vpd_truncate+0x38/0x40 LR [c029be18] sky2_probe+0x14c/0x518 Call Trace: [ef82bde0] [c029bda4] sky2_probe+0xd8/0x518 (unreliable) [ef82be20] [c018a11c] local_pci_probe+0x24/0x34 [ef82be30] [c018a14c] pci_call_probe+0x20/0x30 [ef82be50] [c018a330] __pci_device_probe+0x64/0x78 [ef82be60] [c018a44c] pci_device_probe+0x30/0x58 [ef82be80] [c01aa270] really_probe+0x78/0x1a0 [ef82bea0] [c01aa460] __driver_attach+0xa4/0xa8 [ef82bec0] [c01a96ac] bus_for_each_dev+0x60/0x9c [ef82bef0] [c01aa0b4] driver_attach+0x24/0x34 [ef82bf00] [c01a9e08] bus_add_driver+0x12c/0x1cc [ef82bf20] [c01aa87c] driver_register+0x6c/0x110 [ef82bf30] [c018a770] __pci_register_driver+0x4c/0x9c [ef82bf50] [c03782c8] sky2_init_module+0x30/0x40 [ef82bf60] [c0001dbc] do_one_initcall+0x34/0x1a0 [ef82bfd0] [c0362240] do_initcalls+0x38/0x58 This happens with CONFIG_SKY2=y, and "ip=on" kernel command line, so pci_vpd_truncate() is called before late_initcall(pci_sysfs_init), therefore ->attr isn't yet initialized. Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: tomoyo: remove "undelete domain" command.
2009-04-07Merge ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param * git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux-2.6-module-and-param: Revert "module: remove the SHF_ALLOC flag on the __versions section."
2009-04-07Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: (28 commits) powerpc: Fix oops when loading modules powerpc: Wire up preadv and pwritev powerpc/ftrace: Fix printf format warning powerpc/ftrace: Fix #if that should be #ifdef powerpc: Fix ptrace compat wrapper for FPU register access powerpc: Print information about mapping hw irqs to virtual irqs powerpc: Correct dependency of KEXEC powerpc: Disable VSX or current process in giveup_fpu/altivec powerpc/pseries: Enable relay in pseries_defconfig powerpc/pseries: Fix ibm,client-architecture comment powerpc/pseries: Scan for all events in rtasd powerpc/pseries: Add dispatch dispersion statistics powerpc: Clean up some prom printouts powerpc: Print progress of ibm,client-architecture method powerpc: Remove duplicated #include's powerpc/pmac: Fix internal modem IRQ on Wallstreet PowerBook powerpc/wdrtas: Update wdrtas_get_interval to use rtas_data_buf fsl-diu-fb: Pass the proper device for dma mapping routines powerpc/pq2fads: Update device tree for use with device-tree-aware u-boot. cpm_uart: Disable CPM udbg when re-initing CPM uart, even if not the console. ...
2009-04-07ramfs: fix double freeing s_fs_info on failed mountIngo Molnar
If ramfs mount fails, s_fs_info will be freed twice in ramfs_fill_super() and ramfs_kill_sb(), leading to kernel oops. Consolidate and beautify the code. Make sure s_fs_info and s_root are in known good states. Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
