2007-07-17sys_fallocate() implementation on i386, x86_64 and powerpcAmit Arora
fallocate() is a new system call being proposed here which will allow applications to preallocate space to any file(s) in a file system. Each file system implementation that wants to use this feature will need to support an inode operation called ->fallocate(). Applications can use this feature to avoid fragmentation to certain level and thus get faster access speed. With preallocation, applications also get a guarantee of space for particular file(s) - even if later the the system becomes full. Currently, glibc provides an interface called posix_fallocate() which can be used for similar cause. Though this has the advantage of working on all file systems, but it is quite slow (since it writes zeroes to each block that has to be preallocated). Without a doubt, file systems can do this more efficiently within the kernel, by implementing the proposed fallocate() system call. It is expected that posix_fallocate() will be modified to call this new system call first and incase the kernel/filesystem does not implement it, it should fall back to the current implementation of writing zeroes to the new blocks. ToDos: 1. Implementation on other architectures (other than i386, x86_64, and ppc). Patches for s390(x) and ia64 are already available from previous posts, but it was decided that they should be added later once fallocate is in the mainline. Hence not including those patches in this take. 2. Changes to glibc, a) to support fallocate() system call b) to make posix_fallocate() and posix_fallocate64() call fallocate() Signed-off-by: Amit Arora <aarora@in.ibm.com>
2007-07-17slob: Kill off duplicate kzalloc() definition.Paul Mundt
With the slab zeroing allocations cleanups Christoph stubbed in a generic kzalloc(), which was missed on SLOB. Follow the SLAB/SLUB changes and kill off the __kzalloc() wrapper that SLOB was using. Reported-by: Jan Engelhardt <jengelh@computergmbh.de> Signed-off-by: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Revert drivers/ide/ide.c scsi_cmd_ioctl() usage changesLinus Torvalds
The old IDE driver is not ready to take generic SCSI commands, even if it uses them for some specific issues (ie the tray open/close ioctls for IDE CD-ROM's). Pointed out by Bartlomiej. I'm sure we'll have it fixed properly soon enough, but for now we should not allow it to cause problems. Cc: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Make the "z/VM unit record device driver" depend on S390Linus Torvalds
I really don't see anybody else wanting to select it ;) Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Merge branch 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.osdl.marist.edu/pub/scm/linux-2.6: [S390] Fix broken logic, SIGA flags must be bitwise ORed [S390] cio: Dont print trailing \0 in modalias_show(). [S390] Simplify stack trace. [S390] z/VM unit record device driver [S390] vmcp cleanup [S390] qdio: output queue stall on FCP and network devices [S390] Fix disassembly of RX_URRD, SI_URD & PC-relative instructions. [S390] Update default configuration.
2007-07-17Merge git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdogLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/wim/linux-2.6-watchdog: (21 commits) [WATCHDOG] at32ap700x_wdt.c - Fix compilation warnings [WATCHDOG] at32ap700x_wdt.c - Add spinlock support [WATCHDOG] at32ap700x_wdt.c - Add nowayout + MAGICCLOSE features [WATCHDOG] at32ap700x_wdt.c - timeout module parameter patch [WATCHDOG] at32ap700x_wdt.c - checkpatch.pl-0.05 clean-up's [WATCHDOG] change s3c2410_wdt to using dev_() macros for output [WATCHDOG] s3c2410_wdt announce initialisation [WATCHDOG] at32ap700x-wdt: add iounmap if probe function fails [WATCHDOG] at32ap700x-wdt: add missing iounmap in _remove [WATCHDOG] watchdog-driver-for-at32ap700x-devices-fix-2 [WATCHDOG] watchdog-driver-for-at32ap700x-devices-fix [WATCHDOG] Watchdog driver for AT32AP700X devices [WATCHDOG] Mixcom Watchdog - CodingStyle clean-up [WATCHDOG] Mixcom Watchdog - clean-up printk's [WATCHDOG] Mixcom Watchdog - clean-up printk's [WATCHDOG] Mixcom Watchdog - checkcard part 2 [WATCHDOG] Mixcom Watchdog - checkcard [WATCHDOG] Mixcom Watchdog - get rid of port offset's [WATCHDOG] Mixcom Watchdog - update "Documentation" [WATCHDOG] Remove the redundant check for pwrite() in EP93XXX watchdog. ...
2007-07-17Merge branch 'bsg' of git://git.kernel.dk/data/git/linux-2.6-blockLinus Torvalds
* 'bsg' of git://git.kernel.dk/data/git/linux-2.6-block: bsg: fix missing space in version print Don't define empty struct bsg_class_device if !CONFIG_BLK_DEV_BSG bsg: Kconfig updates bsg: minor cleanup bsg: device hash table cleanup bsg: fix initialization error handling bugs bsg: mark FUJITA Tomonori as bsg maintainer bsg: convert to dynamic major bsg: address various review comments
2007-07-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: fix debug compilation error
2007-07-17Merge branch 'isdn-cleanup' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6 * 'isdn-cleanup' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6: [ISDN] HiSax hfc_pci: minor cleanups [ISDN] HiSax bkm_a4t: split setup into two smaller functions [ISDN] HiSax enternow: split setup into 3 smaller functions [ISDN] HiSax netjet_u: split setup into 3 smaller functions [ISDN] HiSax netjet_s: code movement, prep for hotplug [ISDN] HiSax: move card state alloc/setup code into separate functions [ISDN] HiSax: move card setup into separate function
2007-07-17Merge branch 'master' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6 * 'master' of master.kernel.org:/pub/scm/linux/kernel/git/davem/sparc-2.6: [SPARC64]: Kill bogus set_fs(KERNEL_DS) in do_rt_sigreturn(). [SPARC64]: Update defconfig. [SPARC64]: Kill explicit %gl register reference.
2007-07-17Merge branch 'uninit-var' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6 * 'uninit-var' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6: arch/i386/* fs/* ipc/*: mark variables with uninitialized_var() drivers/*: mark variables with uninitialized_var()
2007-07-17Merge branch 'warnings' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6 * 'warnings' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/misc-2.6: drivers/atm/ambassador: kill uninit'd var warning, and fix bug [libata] sata_mv: use pci_try_set_mwi() drivers/infiniband/hw/mthca/mthca_qp: kill uninit'd var warning drivers/net/wan/sbni: kill uninit'd var warning drivers/mtd/ubi/eba: minor cleanup: tighten scope of a local var drivers/telephony/ixj: cleanup and fix gcc warning drivers/net/wan/pc300_drv: fix bug caught by gcc warning drivers/usb/misc/auerswald: fix status check, remove redundant check [netdrvr] eepro100, ne2k-pci: abort resume if pci_enable_device() fails [netdrvr] natsemi: Fix device removal bug kernel/auditfilter: kill bogus uninit'd-var compiler warning
2007-07-17smp_call_function_single() should be a macro on UPAl Viro
... or we end up with header include order problems from hell. E.g. on m68k this is 100% fatal - local_irq_enable() there wants preempt_count(), which wants task_struct fields, which we won't have when we are in smp.h pulled from sched.h. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17[SPARC64]: Kill bogus set_fs(KERNEL_DS) in do_rt_sigreturn().Oleg Nesterov
From: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-17[ISDN] HiSax hfc_pci: minor cleanupsJeff Garzik
* trim trailing whitespace * remove CONFIG_PCI ifdefs, this driver is always PCI (Kconfig enforced) * remove return statements at the tail of a function * remove indentation levels by returning an error code immediately. Makes the code much more readable, and easier to update to PCI hotplug API. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[ISDN] HiSax bkm_a4t: split setup into two smaller functionsJeff Garzik
No behavior changes, just code movement. Prep for PCI hotplug API. Well, CONFIG_PCI useless ifdef was removed. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[ISDN] HiSax enternow: split setup into 3 smaller functionsJeff Garzik
No behavior changes, just code movement. Prep for PCI hotplug API. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[ISDN] HiSax netjet_u: split setup into 3 smaller functionsJeff Garzik
2007-07-17[ISDN] HiSax netjet_s: code movement, prep for hotplugJeff Garzik
1) Remove CONFIG_PCI ifdefs. PCI is required in Kconfig. 2) Break up setup_netjet_s() into three separate internal functions. This helps facilitate upcoming use of PCI hotplug API, and in addition makes the code much easier to follow. No code is changed, just moved around. I even kept the out-of-favor "return(0)" style used in the current source code. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[ISDN] HiSax: move card state alloc/setup code into separate functionsJeff Garzik
Just code movement. No code changes or cleanups besides that which is required to call the new functions from the old code site. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[ISDN] HiSax: move card setup into separate functionJeff Garzik
No behavior changes, just code movement. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17mixart: Add missing vmalloc.h includeFrank Lichtenheld
Fixes the following build error: CC sound/pci/mixart/mixart_hwdep.o sound/pci/mixart/mixart_hwdep.c: In function ‘mixart_hwdep_dsp_load’: sound/pci/mixart/mixart_hwdep.c:610: error: implicit declaration of function ‘vmalloc’ sound/pci/mixart/mixart_hwdep.c:617: error: implicit declaration of function ‘vfree’ Signed-off-by: Frank Lichtenheld <frank@lichtenheld.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17hppb: Add missing dma-mapping.h includeFrank Lichtenheld
This fixes the following build-error: CC drivers/parisc/hppb.o drivers/parisc/hppb.c: In function ‘hppb_probe’: drivers/parisc/hppb.c:73: error: implicit declaration of function ‘ccio_request_resource’ Signed-off-by: Frank Lichtenheld <frank@lichtenheld.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17arch/i386/* fs/* ipc/*: mark variables with uninitialized_var()Jeff Garzik
Mark variables with uninitialized_var() if such a warning appears, and analysis proves that the var is initialized properly on all paths it is used. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17drivers/*: mark variables with uninitialized_var()Jeff Garzik
Mark variables in drivers/* with uninitialized_var() if such a warning appears, and analysis proves that the var is initialized properly on all paths it is used. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17drivers/atm/ambassador: kill uninit'd var warning, and fix bugJeff Garzik
An uninitialized variable warning illuminated an area where indeed the variable was being used without initialization. Unfortunately, after verifying all such paths were fixed, the warning still appears. So we follow the initialization practice of other variables in this function. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[libata] sata_mv: use pci_try_set_mwi()Jeff Garzik
Because sometimes in life, it's ok to fail. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17drivers/infiniband/hw/mthca/mthca_qp: kill uninit'd var warningJeff Garzik
drivers/infiniband/hw/mthca/mthca_qp.c: In function ‘mthca_tavor_post_send’: drivers/infiniband/hw/mthca/mthca_qp.c:1594: warning: ‘f0’ may be used uninitialized in this function drivers/infiniband/hw/mthca/mthca_qp.c: In function ‘mthca_arbel_post_send’: drivers/infiniband/hw/mthca/mthca_qp.c:1949: warning: ‘f0’ may be used uninitialized in this function Initializing 'f0' is not strictly necessary in either case, AFAICS. I was considering use of uninitialized_var(), but looking at the complex flow of control in each function, I feel it is wiser and safer to simply zero the var and be certain of ourselves. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17drivers/net/wan/sbni: kill uninit'd var warningJeff Garzik
It's actually convenient in the code to initialize this and a sister variable to zero. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17drivers/mtd/ubi/eba: minor cleanup: tighten scope of a local varJeff Garzik
2007-07-17drivers/telephony/ixj: cleanup and fix gcc warningJeff Garzik
1) Fix gcc uninit'd var warnings by adding 'default' switch stmt labels in two cases. It was lightning-strikes unlikely that a problem would ever arise, but not impossible. 2) Tighten the scope of 'blankword' in two cases. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17drivers/net/wan/pc300_drv: fix bug caught by gcc warningJeff Garzik
The warning drivers/net/wan/pc300_drv.c: In function ‘cpc_open’: drivers/net/wan/pc300_drv.c:2942: warning: ‘br’ may be used uninitialized in this function was valid. Ensure 'br' is initialized in all cases. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17drivers/usb/misc/auerswald: fix status check, remove redundant checkJeff Garzik
1) We should only set 'actual_length' output variable if usb length is known to be good. 2) No need to check actual_length for NULL. The only caller always passes non-NULL value. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[netdrvr] eepro100, ne2k-pci: abort resume if pci_enable_device() failsJeff Garzik
2007-07-17[netdrvr] natsemi: Fix device removal bugJeff Garzik
This episode illustrates how an overused warning can train people to ignore that warning, which winds up hiding bugs. The warning drivers/net/natsemi.c: In function ‘natsemi_remove1’: drivers/net/natsemi.c:3222: warning: ignoring return value of ‘device_create_file’, declared with attribute warn_unused_result is oft-ignored, even though at close inspection one notices this occurs in the /remove/ function, not normally where creation occurs. A quick s/create/remove/ and we are fixed, with the warning gone. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17kernel/auditfilter: kill bogus uninit'd-var compiler warningJeff Garzik
Kill this warning... kernel/auditfilter.c: In function ‘audit_receive_filter’: kernel/auditfilter.c:1213: warning: ‘ndw’ may be used uninitialized in this function kernel/auditfilter.c:1213: warning: ‘ndp’ may be used uninitialized in this function ...with a simplification of the code. audit_put_nd() can accept NULL arguments, just like kfree(). It is cleaner to init two existing vars to NULL, remove the redundant test variable 'putnd_needed' branches, and call audit_put_nd() directly. As a desired side effect, the warning goes away. Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-07-17[SPARC64]: Update defconfig.David S. Miller
2007-07-17[SPARC64]: Kill explicit %gl register reference.David S. Miller
Older binutils can't handle it. Use SET_GL() instead, which is explicitly for this purpose. Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/avi/kvm: (80 commits) KVM: Use CPU_DYING for disabling virtualization KVM: Tune hotplug/suspend IPIs KVM: Keep track of which cpus have virtualization enabled SMP: Allow smp_call_function_single() to current cpu i386: Allow smp_call_function_single() to current cpu x86_64: Allow smp_call_function_single() to current cpu HOTPLUG: Adapt thermal throttle to CPU_DYING HOTPLUG: Adapt cpuset hotplug callback to CPU_DYING HOTPLUG: Add CPU_DYING notifier KVM: Clean up #includes KVM: Remove kvmfs in favor of the anonymous inodes source KVM: SVM: Reliably detect if SVM was disabled by BIOS KVM: VMX: Remove unnecessary code in vmx_tlb_flush() KVM: MMU: Fix Wrong tlb flush order KVM: VMX: Reinitialize the real-mode tss when entering real mode KVM: Avoid useless memory write when possible KVM: Fix x86 emulator writeback KVM: Add support for in-kernel pio handlers KVM: VMX: Fix interrupt checking on lightweight exit KVM: Adds support for in-kernel mmio handlers ...
2007-07-17Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/aegl/linux-2.6: [IA64] Clean away some code inside some non-existent CONFIG ifdefs [IA64] ar.itc access must really be after xtime_lock.sequence has been read [IA64] correctly count CPU objects in the ia64/sn hwperf interface [IA64] arbitary speed tty ioctl support [IA64] use machvec=dig on hpzx1 platforms
2007-07-17atl1: missing includeAl Viro
2007-07-17mark a bunch of ISA|EISA|PCI drivers as suchAl Viro
2007-07-17missing exports of csum_...Al Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17um_kmalloc() remnantsAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jeff Dike <jdike@addtoit.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17sparc32 has working dma-mapping only with CONFIG_PCIAl Viro
Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17saner typechecking in generic unaligned.hAl Viro
Verify that types would match for assignment (under sizeof, so we are safe from side effects or any code actually getting generated), then explicitly cast everywhere to the fixed-sized types. Kills a bunch of bogus warnings about constants being truncated (gcc, sparse), finds a pile of endianness problems hidden by old noise (sparse). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17alpha __init fixesAl Viro
__init and __initdata stuff used from __devinit one Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17alpha termios.h hadn't been updatedAl Viro
... fortunately, termios and ktermios there are identical, so no run-time breakage happened. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17no USB on M32RAl Viro
Won't build due to lack of dma-mapping. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
