There's no point to force the caller to know about the internal
genl_sock to use inside struct net, just have them pass the network
namespace. This doesn't really change code generation since it's
an inline, but makes the caller less magic - there's never any
reason to pass another socket.
The new name is more expressive - this isn't a generic unbind
function but rather only a little undo helper for use only in
netlink_bind().
git://git.kernel.org/pub/scm/linux/kernel/git/bluetooth/bluetooth
Johan Hedberg says:
Here's one more bluetooth pull request for 3.19. We've got two fixes:
- Fix for accepting connections with old user space versions of BlueZ
- Fix for Bluetooth controllers that don't have a public address
Both of these are regressions that were introduced in 3.17, so the
appropriate Cc: stable annotations are provided.
Please let me know if there are any issues pulling. Thanks.
git://git.kernel.org/pub/scm/linux/kernel/git/kvalo/wireless-drivers
o Paul made a Kconfig dependency fix to ipw2200, it was not possible to
enable that driver because Wireless Extensions is now disabled by default.
o Mika fixed brcmfmac not to crash when platform data is not populated
o Emmanuel provided few fixes to iwlwifi, he says:
"I have here new device IDs and a fix for double free bug I
introduced. I also fix an issue with the RFKILL interrupt - the HW
needs us to ACK the interrupt again after we reset it. Liad fixes an
issue with the firmware debugging infrastructure. While working on
torture scenarios of firmware restarts, Eliad found an issue which
he fixed."
GSO isn't the only offload feature with restrictions that
potentially can't be expressed with the current features mechanism.
Checksum is another although it's a general issue that could in
theory apply to anything. Even if it may be possible to
implement these restrictions in other ways, it can result in
duplicate code or inefficient per-packet behavior.
This generalizes ndo_gso_check so that drivers can remove any
features that don't make sense for a given packet, similar to
netif_skb_features(). It also converts existing driver
restrictions to the new format, completing the work that was
done to support tunnel protocols since the issues apply to
checksums as well.
By actually removing features from the set that are used to do
offloading, it solves another problem with the existing
interface. In these cases, GSO would run with the original set
of features and not do anything because it appears that
segmentation is not required.
CC: Tom Herbert <therbert@google.com>
CC: Joe Stringer <joestringer@nicira.com>
CC: Eric Dumazet <edumazet@google.com>
CC: Hayes Wang <hayeswang@realtek.com>
Signed-off-by: Jesse Gross <jesse@nicira.com>
Acked-by: Tom Herbert <therbert@google.com>
Fixes: 04ffcb255f22 ("net: Add ndo_gso_check")
Tested-by: Hayes Wang <hayeswang@realtek.com>
The second init_completion call should be a reinit_completion here.
patch is against 3.18.0 linux-next
Signed-off-by: Nicholas Mc Guire <der.herr@hofr.at>
After commit
d7480fd3b173 ("neigh: remove dynamic neigh table registration support"),
this field is not used anymore.
CC: Cong Wang <xiyou.wangcong@gmail.com>
Signed-off-by: Nicolas Dichtel <nicolas.dichtel@6wind.com>
Acked-by: Cong Wang <xiyou.wangcong@gmail.com>
This property is no longer used in the code yet the code looks for it in the device tree.
It does not cause an error if it's not in the tree.
Signed-off-by: Kedareswara rao Appana <appanad@xilinx.com>
Use generic config_init callback also for KSZ8021 and KSZ8031.
This has been avoided this far due to commit b838b4aced99 ("phy/micrel:
KSZ8031RNL RMII clock reconfiguration bug"), which claims that the PHY
becomes unresponsive if the broadcast-disable flag is set before
configuring the clock mode.
Turns out that the problem seemingly worked-around by the above
mentioned commit was really due to a hardware-configuration issue, where
the PHY was in fact strapped to address 3 rather than 0.
Tested-by: Bruno Thomsen <bth@kamstrup.dk>
Signed-off-by: Johan Hovold <johan@kernel.org>
When using VXLAN tunnels and a sky2 device, I have experienced
checksum failures of the following type:
[ 4297.761899] eth0: hw csum failure
[ 4297.765223] Call Trace:
[ 4297.765224] <IRQ> [<ffffffff8172f026>] dump_stack+0x46/0x58
[ 4297.765235] [<ffffffff8162ba52>] netdev_rx_csum_fault+0x42/0x50
[ 4297.765238] [<ffffffff8161c1a0>] ? skb_push+0x40/0x40
[ 4297.765240] [<ffffffff8162325c>] __skb_checksum_complete+0xbc/0xd0
[ 4297.765243] [<ffffffff8168c602>] tcp_v4_rcv+0x2e2/0x950
[ 4297.765246] [<ffffffff81666ca0>] ? ip_rcv_finish+0x360/0x360
These are reliably reproduced in a network topology of:
container:eth0 == host(OVS VXLAN on VLAN) == bond0 == eth0 (sky2) -> switch
When VXLAN encapsulated traffic is received from a similarly
configured peer, the above warning is generated in the receive
processing of the encapsulated packet. Note that the warning is
associated with the container eth0.
The skbs from sky2 have ip_summed set to CHECKSUM_COMPLETE, and
because the packet is an encapsulated Ethernet frame, the checksum
generated by the hardware includes the inner protocol and Ethernet
headers.
The receive code is careful to update the skb->csum, except in
__dev_forward_skb, as called by dev_forward_skb. __dev_forward_skb
calls eth_type_trans, which in turn calls skb_pull_inline(skb, ETH_HLEN)
to skip over the Ethernet header, but does not update skb->csum when
doing so.
This patch resolves the problem by adding a call to
skb_postpull_rcsum to update the skb->csum after the call to
eth_type_trans.
Signed-off-by: Jay Vosburgh <jay.vosburgh@canonical.com>
net/openvswitch/vport-gre.c:188:5-11: inconsistent IS_ERR and PTR_ERR, PTR_ERR on line 189
PTR_ERR should access the value just tested by IS_ERR
Semantic patch information:
There can be false positives in the patch case, where it is the call
IS_ERR that is wrong.
Generated by: scripts/coccinelle/tests/odd_ptr_err.cocci
CC: Pravin B Shelar <pshelar@nicira.com>
Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
Acked-by: Pravin B Shelar <pshelar@nicira.com>
When connectable mode is enabled (page scan on) through some non-mgmt
method the HCI_CONNECTABLE flag will not be set. For backwards
compatibility with user space versions not using mgmt we should not
require HCI_CONNECTABLE to be set if HCI_MGMT is not set.
Reported-by: Pali Rohár <pali.rohar@gmail.com>
Tested-by: Pali Rohár <pali.rohar@gmail.com>
Signed-off-by: Johan Hedberg <johan.hedberg@intel.com>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
Cc: stable@vger.kernel.org # 3.17+
When controllers set the HCI_QUIRK_INVALID_BDADDR flag, it is required
by userspace to program a valid public Bluetooth device address into
the controller before it can be used.
After successful address configuration, the internal state changes and
the controller runs the complete initialization procedure. However one
small difference is that this is no longer the HCI_SETUP stage. The
HCI_SETUP stage is only valid during initial controller setup. In this
case the stack runs the initialization as part of the HCI_CONFIG stage.
The controller version information, default name and supported commands
are only stored during HCI_SETUP. While these information are static,
they are not read initially when HCI_QUIRK_INVALID_BDADDR is set. So
when running in HCI_CONFIG state, these information need to be updated
as well.
This especially impacts Bluetooth 4.1 and later controllers using
extended feature pages and second event mask page.
The driver looks for pdata->oob_irq_supported to find out if wowl can be
supported. However, not all platforms populate pdata in which case we crash
the kernel because of NULL pointer dereference.
Fixes: 330b4e4be937 ("brcmfmac: Add wowl support for SDIO devices.")
Reported-by: Christophe Prigent <christophe.prigent@intel.com>
Signed-off-by: Mika Westerberg <mika.westerberg@linux.intel.com>
Signed-off-by: Kalle Valo <kvalo@codeaurora.org>
Commit 24a0aa212ee2 ("cfg80211: make WEXT compatibility unselectable")
made it impossible to depend on CFG80211_WEXT. It does still allow to
select that symbol. (Yes, the commit summary is confusing.)
So make IPW2200 select CFG80211_WEXT, so that the ipw2200 driver can be
enabled in config again.
Signed-off-by: Paul Bolle <pebolle@tiscali.nl>
skb_scrub_packet() is called when a packet switches between a context
such as between underlay and overlay, between namespaces, or between
L3 subnets.
While we already scrub the packet mark, connection tracking entry,
and cached destination, the security mark/context is left intact.
It seems wrong to inherit the security context of a packet when going
from overlay to underlay or across forwarding paths.
Signed-off-by: Thomas Graf <tgraf@suug.ch>
Acked-by: Flavio Leitner <fbl@sysclose.org>
When vlan tags are stacked, it is very likely that the outer tag is stored
in skb->vlan_tci and skb->protocol shows the inner tag's vlan_proto.
Currently netif_skb_features() first looks at skb->protocol even if there
is the outer tag in vlan_tci, thus it incorrectly retrieves the protocol
encapsulated by the inner vlan instead of the inner vlan protocol.
This allows GSO packets to be passed to HW and they end up being
corrupted.
Fixes: 58e998c6d239 ("offloading: Force software GSO for multiple vlan tags.")
Signed-off-by: Toshiaki Makita <makita.toshiaki@lab.ntt.co.jp>
Pravin B Shelar says:
openvswitch: datapath fixes
Following patch series is mostly targeted to MPLS fixes. other
patches are related datapth transmit path error handling.
In case of error vxlan_xmit_one() can free already freed skb.
Also fixes memory leak of dst-entry.
Fixes: acbf74a7630 ("vxlan: Refactor vxlan driver to make use
of the common UDP tunnel functions").
Signed-off-by: Pravin B Shelar <pshelar@nicira.com>
Today vport-send has complex error handling because it involves
freeing skb and updating stats depending on return value from
vport send implementation.
This can be simplified by delegating responsibility of freeing
skb to the vport implementation for all cases. So that
vport-send needs just update stats.
Fixes: 91b7514cdf ("openvswitch: Unify vport error stats
handling")
MPLS GSO needs to know inner most protocol to process GSO packets.
Fixes: 25cd9ba0abc ("openvswitch: Add basic MPLS support to
kernel").
Linux stack does not implement GSO for packet with multiple
encapsulations. Therefore there was check in MPLS action
validation to detect such case, But this check introduced
bug which deleted one or more actions from actions list.
Following patch removes this check to fix the validation.
kernel").
Reported-by: Srinivas Neginhal <sneginha@vmware.com>
Acked-by: Jarno Rajahalme <jrajahalme@nicira.com>
MPLS and Tunnel GSO does not work together. Reject packet which
request such GSO.
Fixes: 0d89d2035f ("MPLS: Add limited GSO support").
Fixes MPLS GSO for case when mpls is compiled as kernel module.
This patch rearranges the loop in net_rx_action to reduce the
amount of jumping back and forth when reading the code.
We should only perform the softnet_break check after we have polled
at least one device in net_rx_action. Otherwise a zero or negative
setting of netdev_budget can lock up the whole system.
The commit d75b1ade567ffab085e8adbbdacf0092d10cd09c (net: less
interrupt masking in NAPI) required drivers to leave poll_list
empty if the entire budget is consumed.
We have already had two broken drivers so let's add a check for
this.
This patch creates a new function napi_poll and moves the napi
polling code from net_rx_action into it.
Gateway having bandwidth_down equal to zero are not accepted
at all and so never added to the Gateway list.
For this reason checking the bandwidth_down member in
batadv_gw_out_of_range() is useless.
This is probably a copy/paste error and this check was supposed
to be "!gw_node" only. Moreover, the way the check is written
now may also lead to a NULL dereference.
Fix this by rewriting the if-condition properly.
Introduced by 414254e342a0d58144de40c3da777521ebaeeb07
("batman-adv: tvlv - gateway download/upload bandwidth container")
Signed-off-by: Antonio Quartulli <antonio@meshcoding.com>
Reported-by: David Binderman <dcb314@hotmail.com>
Signed-off-by: Marek Lindner <mareklindner@neomailbox.ch>
The fragmentation code was replaced in 610bfc6bc99bc83680d190ebc69359a05fc7f605
("batman-adv: Receive fragmented packets and merge") by an implementation which
can handle up to 16 fragments of a packet. The packet is prepared for the split
in fragments by the function batadv_frag_send_packet and the actual split is
done by batadv_frag_create.
Both functions calculate the size of a fragment themself. But their calculation
differs because batadv_frag_send_packet also subtracts ETH_HLEN. Therefore,
the check in batadv_frag_send_packet "can a full fragment can be created?" may
return true even when batadv_frag_create cannot create a full fragment.
The function batadv_frag_create doesn't check the size of the skb before
splitting it and therefore might try to create a larger fragment than the
remaining buffer. This creates an integer underflow and an invalid len is given
to skb_split.
Signed-off-by: Sven Eckelmann <sven@narfation.org>
("batman-adv: Receive fragmented packets and merge"). The new code provided a
mostly unused parameter skb for the merging function. It is used inside the
function to calculate the additionally needed skb tailroom. But instead of
increasing its own tailroom, it is only increasing the tailroom of the first
queued skb. This is not correct in some situations because the first queued
entry can be a different one than the parameter.
An observed problem was:
1. packet with size 104, total_size 1464, fragno 1 was received
- packet is queued
2. packet with size 1400, total_size 1464, fragno 0 was received
- packet is queued at the end of the list
3. enough data was received and can be given to the merge function
(1464 == (1400 - 20) + (104 - 20))
- merge functions gets 1400 byte large packet as skb argument
4. merge function gets first entry in queue (104 byte)
- stored as skb_out
5. merge function calculates the required extra tail as total_size - skb->len
- pskb_expand_head tail of skb_out with 64 bytes
6. merge function tries to squeeze the extra 1380 bytes from the second queued
skb (1400 byte aka skb parameter) in the 64 extra tail bytes of skb_out
Instead calculate the extra required tail bytes for skb_out also using skb_out
instead of using the parameter skb. The skb parameter is only used to get the
total_size from the last received packet. This is also the total_size used to
decide that all fragments were received.
Reported-by: Philipp Psurek <philipp.psurek@gmail.com>
Acked-by: Martin Hundebøll <martin@hundeboll.net>
Commit cecda693a969816bac5e470e1d9c9c0ef5567bca ("net: keep original skb
which only needs header checking during software GSO") keeps the original
skb for packets that only needs header check, but it doesn't drop the
packet if software segmentation or header check were failed.
Fixes cecda693a9 ("net: keep original skb which only needs header checking during software GSO")
Signed-off-by: Jason Wang <jasowang@redhat.com>
When xfrm6_policy_check() is used, _decode_session6() is called after some
intermediate functions. This function uses IP6CB(), thus TCP_SKB_CB() must be
prepared after the call of xfrm6_policy_check().
Before this patch, scenarii with IPv6 + TCP + IPsec Transport are broken.
Fixes: 971f10eca186 ("tcp: better TCP_SKB_CB layout to reduce cache line misses")
Reported-by: Huaibin Wang <huaibin.wang@6wind.com>
Suggested-by: Eric Dumazet <edumazet@google.com>
Decode and display Port Type and Module Type for ethtool get_settings() call
Signed-off-by: Hariprasad Shenai <hariprasad@chelsio.com>
interrupt masking in NAPI) breaks caif.
It is now required that if the entire budget is consumed when poll
returns, the napi poll_list must remain empty. However, like some
other drivers caif tries to do a last-ditch check and if there is
more work it will call napi_schedule and then immediately process
some of this new work. Should the entire budget be consumed while
processing such new work then we will violate the new caller
contract.
This patch fixes this by not touching any work when we reschedule
in caif.
iowrite32() will byteswap it's argument on big endian archs.
iowrite32be() will byteswap on little endian archs.
Since we don't want to do this unnecessary byteswap on the fast path,
doorbell is stored in the NIC's native endianness. Using the right
iowrite() according to the arch endianness.
CC: Wei Yang <weiyang@linux.vnet.ibm.com>
CC: David Laight <david.laight@aculab.com>
Fixes: 6a4e812 ("net/mlx4_en: Avoid calling bswap in tx fast path")
Signed-off-by: Amir Vadai <amirv@mellanox.com>
For linux-3.18.0
The driver lacks netif_napi_del in the normal path and error path
to match the call of netif_napi_add in rtl8139_init_one.
This patch fixes this problem.
Signed-off-by: Jia-Ju Bai <baijiaju1990@163.com>
For linux-3.18.0
When pci_request_regions is failed in rtl8139_init_board, pci_disable_device
is not called to disable the device which are enabled by pci_enable_device,
because of disable_dev_on_err is not assigned 1.
This patch fix this problem.
This platform_driver does not need to set an owner, it will be populated by the
driver core.
Signed-off-by: Wolfram Sang <wsa@the-dreams.de>
The s6000 Xtensa support has been removed from the kernel in
4006e565e1500db4. There are no other chips using this driver.
While the Mentor/Alcatel PE-MCXMAC IP core is also used in other
designs (Freescale Gianfar/UCC, QLogic NetXen, Solarflare, Agere
ET-1310, Netlogic XLR/XLS), none of these use this driver as it
heavily depends on the s6000 DMA engine. In fact, there is no
code sharing across any of the aforementioned devices.
Signed-off-by: Daniel Glöckner <dg@emlix.com>
Remove the function port_cfg_dis_learn() that is not used anywhere.
This was partially found by using a static code analysis program called cppcheck.
Signed-off-by: Rickard Strandqvist <rickard_strandqvist@spectrumdigital.se>
During driver load in tg3_init_one, if the driver detects DMA activity before
intializing the chip tg3_halt is called. As part of tg3_halt interrupts are
disabled using routine tg3_disable_ints. This routine was using mailbox value
which was not initialized (default value is 0). As a result driver was writing
0x00000001 to pci config space register 0, which is the vendor id / device id.
This driver bug was exposed because of the commit a7877b17a667 (PCI: Check only
the Vendor ID to identify Configuration Request Retry). Also this issue is only
seen in older generation chipsets like 5722 because config space write to offset
0 from driver is possible. The newer generation chips ignore writes to offset 0.
Also without commit a7877b17a667, for these older chips when a GRC reset is
issued the Bootcode would reprogram the vendor id/device id, which is the reason
this bug was masked earlier.
Fixed by initializing the interrupt mailbox registers before calling tg3_halt.
Please queue for -stable.
Reported-by: Nils Holland <nholland@tisys.org>
Reported-by: Marcelo Ricardo Leitner <marcelo.leitner@gmail.com>
Signed-off-by: Prashant Sreedharan <prashant@broadcom.com>
Signed-off-by: Michael Chan <mchan@broadcom.com>
Resolve conflicts between glibc definition of IPV6 socket options
and those defined in Linux headers. Looks like earlier efforts to
solve this did not cover all the definitions.
It resolves warnings during iproute2 build.
Please consider for stable as well.
Signed-off-by: Stephen Hemminger <stephen@networkplumber.org>
Acked-by: Hannes Frederic Sowa <hannes@stressinduktion.org>
The changed names are union fields with the same size, so the existing code
still works. But, we now update these variables to the correct names.
Signed-off-by: Haiyang Zhang <haiyangz@microsoft.com>
Reviewed-by: K. Y. Srinivasan <kys@microsoft.com>
interrupt masking in NAPI) breaks virtio_net in an insidious way.
other drivers virtio_net tries to do a last-ditch check and if
there is more work it will call napi_schedule and then immediately
process some of this new work. Should the entire budget be consumed
while processing such new work then we will violate the new caller
contract.
in virtio_net.
The worst part of this bug is that the list corruption causes other
napi users to be moved off-list. In my case I was chasing a stall
in IPsec (IPsec uses netif_rx) and I only belatedly realised that it
was virtio_net which caused the stall even though the virtio_net
poll was still functioning perfectly after IPsec stalled.
Acked-by: Jason Wang <jasowang@redhat.com>
Both stmmac_open() and stmmac_resume() call stmmac_hw_setup(), and
stmmac_hw_setup() call stmmac_init_ptp() unconditionally. However, only
stmmac_release() calls stmmac_release_ptp(). Since stmmac_suspend()
doesn't call stmmac_release_ptp(), stmmac_resume() also needn't call
stmmac_init_ptp().
This patch also fix a "scheduling while atomic" problem when resume
from suspend/hibernation. Because stmmac_init_ptp() will trigger
scheduling while stmmac_resume() hold a spinlock.
Callgraph of "scheduling while atomic":
stmmac_resume() --> stmmac_hw_setup() --> stmmac_init_ptp() -->
stmmac_ptp_register() --> ptp_clock_register() --> device_create() -->
device_create_groups_vargs() --> device_add() --> devtmpfs_create_node()
--> wait_for_common() --> schedule_timeout() --> __schedule()
Signed-off-by: Huacai Chen <chenhc@lemote.com>
every packet
Make TPACKET_V3 signal poll when block is closed rather than for every
packet. Side effect is that poll will be signaled when block retire
timer expires which didn't previously happen. Issue was visible when
sending packets at a very low frequency such that all blocks are retired
before packets are received by TPACKET_V3. This caused avoidable packet
loss. The fix ensures that the signal is sent when blocks are closed
which covers the normal path where the block is filled as well as the
path where the timer expires. The case where a block is filled without
moving to the next block (ie. all blocks are full) will still cause poll
to be signaled.
Signed-off-by: Dan Collins <dan@dcollins.co.nz>
git://git.kernel.org/pub/scm/linux/kernel/git/iwlwifi/iwlwifi-fixes
I have here new device IDs and a fix for double free bug I introduced.
I also fix an issue with the RFKILL interrupt - the HW needs us to ACK
Liad fixes an issue with the firmware debugging infrastructure.
While working on torture scenarios of firmware restarts, Eliad found an
issue which he fixed.
Johan Hedberg says:
pull request: bluetooth 2014-12-19
Here's one more pull request for 3.19. It contains the socket type
verification fixes from Al Viro as well as an skb double-free fix for
6lowpan from Jukka Rissanen.
Hardware always provides compliment of IP pseudo checksum. Stack expects
whole packet checksum without pseudo checksum if CHECKSUM_COMPLETE is set.
This causes checksum error in nf & ovs.
kernel: qg-19546f09-f2: hw csum failure
kernel: CPU: 9 PID: 0 Comm: swapper/9 Tainted: GF O-------------- 3.10.0-123.8.1.el7.x86_64 #1
kernel: Hardware name: Cisco Systems Inc UCSB-B200-M3/UCSB-B200-M3, BIOS B200M3.2.2.3.0.080820141339 08/08/2014
kernel: ffff881218f40000 df68243feb35e3a8 ffff881237a43ab8 ffffffff815e237b
kernel: ffff881237a43ad0 ffffffff814cd4ca ffff8829ec71eb00 ffff881237a43af0
kernel: ffffffff814c6232 0000000000000286 ffff8829ec71eb00 ffff881237a43b00
kernel: Call Trace:
kernel: <IRQ> [<ffffffff815e237b>] dump_stack+0x19/0x1b
kernel: [<ffffffff814cd4ca>] netdev_rx_csum_fault+0x3a/0x40
kernel: [<ffffffff814c6232>] __skb_checksum_complete_head+0x62/0x70
kernel: [<ffffffff814c6251>] __skb_checksum_complete+0x11/0x20
kernel: [<ffffffff8155a20c>] nf_ip_checksum+0xcc/0x100
kernel: [<ffffffffa049edc7>] icmp_error+0x1f7/0x35c [nf_conntrack_ipv4]
kernel: [<ffffffff814cf419>] ? netif_rx+0xb9/0x1d0
kernel: [<ffffffffa040eb7b>] ? internal_dev_recv+0xdb/0x130 [openvswitch]
kernel: [<ffffffffa04c8330>] nf_conntrack_in+0xf0/0xa80 [nf_conntrack]
kernel: [<ffffffff81509380>] ? inet_del_offload+0x40/0x40
kernel: [<ffffffffa049e302>] ipv4_conntrack_in+0x22/0x30 [nf_conntrack_ipv4]
kernel: [<ffffffff815005ca>] nf_iterate+0xaa/0xc0
kernel: [<ffffffff81500664>] nf_hook_slow+0x84/0x140
kernel: [<ffffffff81509dd4>] ip_rcv+0x344/0x380
Hardware verifies IP & tcp/udp header checksum but does not provide payload
checksum, use CHECKSUM_UNNECESSARY. Set it only if its valid IP tcp/udp packet.
Cc: Jiri Benc <jbenc@redhat.com>
Cc: Stefan Assmann <sassmann@redhat.com>
Reported-by: Sunil Choudhary <schoudha@redhat.com>
Signed-off-by: Govindarajulu Varadarajan <_govind@gmx.com>
Reviewed-by: Jiri Benc <jbenc@redhat.com>
