2006-06-02[CIFS] Support for older servers which require plaintext passwordsSteve French
disabled by default, but can be enabled via proc for servers which require such support. Also includes support for setting security flags for cifs. See fs/cifs/README Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-02[CIFS] Fix mapping of old SMB return code Invalid Net Name so it isSteve French
recognized on mount the old mapping of this was to ENODEV (instead of ENXIO) - but ENODEV is what mount returns when the cifs driver will not load so change this to map to ENXIO (which was what the equivalent condition returned for mapping errors from more modern servers) Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-06-01[CIFS] Missing braceSteve French
2006-06-01[CIFS] Do not overwrite aopsDave Kleikamp
cifs should not be overwriting an element of the aops structure, since the structure is shared by all cifs inodes. Instead define a separate aops structure to suit each purpose. I also took the liberty of replacing a hard-coded 4096 with PAGE_CACHE_SIZE Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org>
2006-06-01[CIFS] Fix minor build breaks due to cifs kconfig issuesSteve French
2006-06-01[CIFS] Support for setting up SMB sessions to legacy lanman servers part 2Steve French
2006-06-01[CIFS] Missing include shows up on some architecturesSteve French
2006-05-31[CIFS] Support for setting up SMB sessions to legacy lanman serversSteve French
2006-05-31[CIFS] Cleanup extra whitespace in dmesg logging. Update cifs change logSteve French
2006-05-30[PATCH] ARM: explicitly disable BTB on ixp2350Deepak Saxena
We don't enable the BTB on the ixp2350 as that can cause weird crashes (erratum #42.) However, some bootloaders enable the BTB, which means that we have to disable the BTB explicitly. Found thanks to Tom Rini. Signed-off-by: Lennert Buytenhek <buytenh@wantstofly.org> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30Revert "[PATCH] i386/x86_64: Force pci=noacpi on HP XW9300"Linus Torvalds
This reverts commit 5491d0f3e206beb95eeb506510d62a1dab462df1. As per Andi: "After some discussion with people who have the affected system it seems best to revert for 2.6.17. It broke a common BIOS workaround and PCI-X still doesn't work. Alternative is for people to change the BIOS which seems to be better right now." Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] x86_64: Don't do syscall exit tracing twiceAndi Kleen
int_ret_from_syscall already does syscall exit tracing, so no need to do it again in the caller. This caused problems for UML and some other special programs doing syscall interception. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] x86_64: Fix off by one in bad_addr checking in find_e820_areaRobert Hentosh
From: Robert Hentosh <robert_hentosh@dell.com> Actually, we just stumbled on a different bug found in find_e820_area() in e820.c. The following code does not handle the edge condition correctly: while (bad_addr(&addr, size) && addr+size < ei->addr + ei->size) ; last = addr + size; if ( last > ei->addr + ei->size ) continue; The second statement in the while loop needs to be a <= b so that it is the logical negavite of the if (a > b) outside it. It needs to read: while (bad_addr(&addr, size) && addr+size <= ei->addr + ei->size) ; In the case that failed bad_addr was returning an address that is exactly size bellow the end of the e820 range. AK: Again together with the earlier avoid edma fix this fixes boot on a Dell PE6850/16GB Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] x86_64: Handle empty node zeroDaniel Yeisley
From: Daniel Yeisley <dan.yeisley@unisys.com> It is possible to boot a Unisys ES7000 with CPUs from multiple cells, and not also include the memory from those cells. This can create a scenario where node 0 has cpus, but no associated memory. The system will boot fine in a configuration where node 0 has memory, but nodes 2 and 3 do not. [AK: I rechecked the code and generic code seems to indeed handle that already. Dan's original patch had a change for mm/slab.c that seems to be already in now.] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] x86_64: fix last_tsc calculation of PM timerJan Beulich
From: "Jan Beulich" <jbeulich@novell.com> The PM timer code updates vxtime.last_tsc, but this update was done incorrectly in two ways: - offset_delay being in microseconds requires multiplying with cpu_mhz rather than cpu_khz - the multiplication of offset_delay and cpu_khz (both being 32-bit values) on most current CPUs would overflow (observed value of the delay was approximately 4000us, yielding an overflow for frequencies starting a little above 1GHz) Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] i386: apic= command line option should always beJan Beulich
From: "Jan Beulich" <jbeulich@novell.com> When using apic= on the kernel command line, this had no effect for machines matched by either the ACPI MADT or the MPS OEM table scan. However, when such option is specified, it should also take effect for this set of systems. Signed-off-by: Jan Beulich <jbeulich@novell.com> Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] x86_64: Fix no IOMMU warning in PCI-GART driverAndi Kleen
Complaining about the IOMMU not compiled in doesn't make sense here because it is clearly compiled in. Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] x86_64: Fix stack/mmap randomization for compat tasksAndi Kleen
ia32_setup_arg_pages would ignore the passed in random stack top and use its own static value. Now it uses the 8bit of randomness native i386 would use too. This indirectly fixes mmap randomization for 32bit processes too, which depends on the stack randomization. Should also give slightly better virtual cache colouring and possibly better performance with HyperThreading. Signed-off-by: Andi Kleen <ak@suse.de> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30[PATCH] cfq-iosched: fixup locking and ->queue_list list managementJens Axboe
- Drop cic from the list when seen as dead. - Fixup the locking, just use a simple spinlock. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgartLinus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davej/agpgart: [AGPGART] VIA PT880 Ultra support. [AGPGART] Fix Nforce3 suspend on amd64. [AGPGART] Enable SIS AGP driver on x86-64 for EM64T systems
2006-05-30Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: [[CIFS] Pass truncate open flag through on file open in case setattr fails [CIFS] Fix typos in previous fix [CIFS] endian fix for new POSIX byte range lock support [CIFS] fix memory leak in cifs session info struct on reconnect [CIFS] ACPI suspend oops [CIFS] Do not limit the length of share names (was 100 for whole UNC name) [CIFS] Fix new POSIX Locking for setting lock_type correctly on unlock
2006-05-30Merge master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6Linus Torvalds
* master.kernel.org:/pub/scm/linux/kernel/git/davem/net-2.6: [NETFILTER]: PPTP helper: fix sstate/cstate typo [NETFILTER]: mark H.323 helper experimental [NETFILTER]: Fix small information leak in SO_ORIGINAL_DST (CVE-2006-1343)
2006-05-30[[CIFS] Pass truncate open flag through on file open in case setattr failsSteve French
on set size to zero. Signed-off-by: Sebastian Voitzsch <sebastoam/vpotzscj@web.de> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-05-30[CIFS] Fix typos in previous fixSteve French
2006-05-30[CIFS] endian fix for new POSIX byte range lock supportSteve French
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-05-30[CIFS] fix memory leak in cifs session info struct on reconnectSteve French
2006-05-30[CIFS] ACPI suspend oopsSteve French
Wasn't able to reproduce a hard hang, but was able to get an oops if suspended the machine during a copy to the cifs mount. This led to some things hanging, including a "sync". Also got I/O errors when trying to access the mount afterwards (even when didn't see the oops), and had to unmount and remount in order to access the filesystem. This patch fixed the oops. Signed-off-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-05-30[CIFS] Do not limit the length of share names (was 100 for whole UNC name)Steve French
during mount. Especially important for some non-Western languages. Signed-off-by: Steve French <sfrench@us.ibm.com>
2006-05-30[CIFS] Fix new POSIX Locking for setting lock_type correctly on unlockSteve French
2006-05-29Input: psmouse - DMI updates for lifebook protocolKenan Esau
Added different lifebook-versions and the CF-18 to the corresponding dmi-table. Signed-off-by: Kenan Esau <kenan.esau@conan.de> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-05-29Input: change from numbered to named switchesRichard Purdie
Remove the numbered SW_* entries from the input system and assign names to the existing users. Signed-off-by: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-05-29Input: alps - fix old protocol decodingYotam Medini
Correct touchpad left & right keys assignments for ALPS_OLDPROTO that were swapped. Old protocol is used on UMAX ActionBook-530T notebook. Signed-off-by: Yotam Medini <yotam.medini@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-05-29Input: wistron - add support for AOpen Barebook 1559asmasc@theaterzentrum.at
2006-05-29Input: psmouse - add detection of Logitech TrackMan Wheel trackballZbigniew Luszpinski
2006-05-29Input: sidewinder - fix memory leakJesper Juhl
In sw_connect we leak 'buf' and 'idbuf' when we do not leave via one of the fail* labels. This was spotted by the coverity checker. Patch is compile tested only due to lack of hardware. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-05-29Input: add KEY_BATTERY keycodeMatthew Garrett
2006-05-28[NETFILTER]: PPTP helper: fix sstate/cstate typoAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-28[NETFILTER]: mark H.323 helper experimentalPatrick McHardy
2006-05-28[NETFILTER]: Fix small information leak in SO_ORIGINAL_DST (CVE-2006-1343)Marcel Holtmann
It appears that sockaddr_in.sin_zero is not zeroed during getsockopt(...SO_ORIGINAL_DST...) operation. This can lead to an information leak (CVE-2006-1343). Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Patrick McHardy <kaber@trash.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-05-28Merge branch 'upstream-fixes' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev * 'upstream-fixes' of master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/libata-dev: [PATCH] the latest consensus libata resume fix
2006-05-29ppc: Fix typo in TI_LOCAL_FLAGS definitionPaul Mackerras
A typo crept in with commit ea1e847cc202e805769c3c46ba5e5c53714068a1 which defined TI_LOCAL_FLAGS to be the offset of the `flags' field of struct thread_info, rather than the `local_flags' field. This fixes it. The typo was pointed out by Guennadi Liakhovetski. Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-05-28[PATCH] the latest consensus libata resume fixMark Lord
Okay, just to sum things up. This forces libata to wait for up to 2 seconds for BUSY|DRQ to clear on resume before continuing. [jgarzik adds...] During testing we never saw DRQ asserted, but nonetheless (a) this works and (b) testing for DRQ won't hurt. Signed-off-by: Mark Lord <liml@rtr.ca> Acked-by: Jens Axboe <axboe@suse.de> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-27Merge branch 'merge' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc * 'merge' of git://git.kernel.org/pub/scm/linux/kernel/git/paulus/powerpc: [PATCH] powerpc: fix RTC/NVRAM accesses on Maple [PATCH] ppc32 CPM_UART: various fixes for pq2 uart users [PATCH] powerpc: linuxppc64.org no more
2006-05-26[netdrvr s/390] trim trailing whitespaceJeff Garzik
Previous fix patches added a bunch of trailing whitespace, which git-applymbox complained loudly about.
2006-05-26[PATCH] s390: lcs driver bug fixes and improvements [2/2]Klaus Wacker
This is the second lcs driver patch containing the rest of lcs fixes. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-26[PATCH] s390: lcs driver bug fixes and improvements [1/2]Klaus Wacker
Several problems occured with lcs device driver: - device not operational anymore after cable pull/plug-in. - unpredictable results occured, e.g. kernel panic using cards of type QD8F. - STOPLAN and delete multicast address command were not proper recognized by OSA card under heavy network workload. - channel/device error checks missing in interrupt handler. To fix all problems at once recovery of lcs devices has been improved. missing error checks in lcs interrupt handler has been added. Once a hardware problem occurs lcs will recover the device now properly. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-26[PATCH] s390: qeth driver fixesUrsula Braun
From: Frank Blaschka <Frank.Blaschka@de.ibm.com> From: Frank Pavlic <fpavlic@de.ibm.com> - fix fake_ll during initial device bringup. fake_ll was not active after first start of the device. Problem only occured when qeth was built without IPV6 support. - avoid skb usage after invocation of qeth_flush_buffers, because skb might already be freed. - remove yet another useless netif_wake_queue in qeth_softsetup_ipv6 since this function is only called when device is going online. In this case card->state will never be in state UP. So let the net_device queue down . Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
From: Frank Pavlic <fpavlic@de.ibm.com> - correct checking of sscanf-%n value in qeth_string_to_ipaddr(). - don't use netif_stop_queue outside the hard_start_xmit routine. Rather use netif_tx_disable. - don't call qeth_netdev_init on a recovery. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-26[PATCH] s390: minor fix in cu3088Cornelia Huck
In case of a parse error for the cu3088 group attribute, return -EINVAL instead of count. Signed-off-by: Frank Pavlic <fpavlic@de.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-05-26[PATCH] pcnet32: remove incorrect pcnet32_free_ringDon Fry
During a code scan for another change I discovered that this call to pcnet32_free_ring must be removed. If the open fails due to a lack of memory all the ring structures are removed via the call to free_ring and a subsequent call to open will dereference a null pointer in pcnet32_init_ring. Please apply to 2.6.17. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
