2005-11-06[SCSI] raid class updateJames Bottomley
- Update raid class to use nested classes for raid components (this will allow us to move to a component control model now) - Make the raid level an enumeration rather than and int. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-06[SCSI] Fix transport class oopsJames Bottomley
There's an oops that sometimes shows up with SCSI transport classes in sysfs_hash_and_remove. The problem is that now, because of the class to device and vice versa symlinks, all classes have to be removed from visibility *before* the device is removed from visibility. The transport class trigger points violate this, so bring them back into conformance. Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-05[PATCH] reset tss->io_bitmap_owner in sys_ioperm()Bart Oldeman
my patch "x86: initialise tss->io_bitmap_owner to something" (commit ID d5cd4aadd3d220afac8e3e6d922e333592551f7d) introduced a problem with a program (DOSEMU) that called ioperm after already doing some port i/o. The problem is that a process switch return causes tss->io_bitmap_base to be set to IO_BITMAP_OFFSET so that the fault (that *really* sets the io bitmap) never triggers. This fixes that regression. Signed-off-by: Bart Oldeman <bartoldeman@users.sourceforge.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-05[PATCH] Set the vga cursor even when hiddenSamuel Thibault
Some visually impaired people use hardware devices which directly read the vga screen. When newt for instance asks to hide the cursor for better visual aspect, the kernel puts the vga cursor out of the screen, so that the cursor position can't be read by the hardware device. This is a great loss for such people. Here is a patch which uses the same technique as CUR_NONE for hiding the cursor while still moving it. Mario, you should apply it to the speakup kernel for access floppies asap. I'll submit a 2.4 patch too. Signed-off-by: samuel.thibault@ens-lyon.org Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-05Merge branch 'upstream-linus' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/jgarzik/netdev-2.6
2005-11-05[PATCH] phy address mask support for generic phy layerMatt Porter
Adds a phy_mask field to struct mii_bus and uses it. This field indicates each phy address to be ignored when probing the mdio bus. This support is needed for the fs_enet and ibm_emac drivers to be converted to the generic phy layer among other drivers. Many systems lock up on probing certain phy addresses or probing doesn't return 0xffff when nothing is found at the address. A new driver I'm working on also makes use of this mask. Signed-off-by: Matt Porter <mporter@kernel.crashing.org> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05[PATCH] pcnet32: Prevent hang with 79c976Don Fry
Some boards using the 79c976 pcnet32 chip will hang the system if the ethtool --register-dump is performed with the device operational. The request to read bcr30 is retried by the PCI device infinitely without returning data, hanging the system. Tested ia32 and ppc64. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05[PATCH] pcnet32: AT2700/2701 and Bugzilla 2699 & 4551Don Fry
This patch is a better fix for Allied Telesyn 2700/2701 FX boards than the change made in early January this year. It allows the user to select the speed/duplex via module_param, but if no selection is made, forces the speed to 100 FD. It fixes both Bugzilla bugs 2669 and 4551. Tested ia32 and ppc64 by myself, and by the originator of bug 2669. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05[PATCH] pcnet32: show name of failing deviceDon Fry
Display the name eth%d or pci_name() of device which fails to allocate memory. When changing ring size via ethtool, it also releases the lock before returning on error. Added comment that the caller of pcnet32_alloc_ring must call pcnet32_free_ring on error, to avoid leak. Tested ia32 by forcing allocation errors. Signed-off-by: Don Fry <brazilnut@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05[PATCH] S2io: Updated documentationRavinandan Arakali
Hi, This patch provides updated documentation on the Neterion(S2io) driver. Please review the patch. Signed-off-by: Ravinandan Arakali <ravinandan.arakali@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05[PATCH] S2io: Multi buffer mode supportAnanda Raju
Hi, This patch provides dynamic two buffer-mode and 3 buffer-mode options. Previously 2 buffer-mode was compilation option. Now with this patch applied one can load driver in 2 buffer-mode with module-load parameter ie. #insmod s2io.ko rx_ring_mode=2 This patch also provides 3 buffer-mode which provides header separation functionality. In 3 buffer-mode skb->data will have L2/L3/L4 headers and "skb_shinfo(skb)->frag_list->data" will have have L4 payload. one can load driver in 3 buffer-mode with same above module-load parameter ie. #insmod s2io.ko rx_ring_mode=3 Please review the patch. Signed-off-by: Ananda Raju <ananda.raju@neterion.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05[PATCH] drivers/net/wireless/airo.c unsigned comparasonGabriel A. Devenyi
fid is declared as a u32 (unsigned int), and then a few lines later, it is checked for a value < 0, which is clearly useless. In the two locations this function is used, in one it is *explicitly* given a negative number, which would be ignored with the current definition. Thanks to LinuxICC (http://linuxicc.sf.net). Signed-off-by: Gabriel A. Devenyi <ace@staticwave.ca> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-11-05Merge branch 'master'Jeff Garzik
2005-11-05[libata] restore sg on DMA mapping failureTejun Heo
2005-11-05Merge master.kernel.org:/pub/scm/linux/kernel/git/jejb/scsi-for-linus-2.6Linus Torvalds
2005-11-05Merge master.kernel.org:/home/rmk/linux-2.6-mmcLinus Torvalds
2005-11-05[SCSI] sd: Fix refcountingAlan Stern
Currently the driver takes a reference only for requests coming by way of the gendisk, not for requests coming by way of the struct device or struct scsi_device. Such requests can arrive in the rescan, flush, and shutdown pathways. The patch also makes the scsi_disk keep a reference to the underlying scsi_device, and it erases the scsi_device's pointer to the scsi_disk when the scsi_device is removed (since the pointer should no longer be used). This resolves Bugzilla entry #5237. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-05[MMC] Use controller id instead of driver name for printksPierre Ossman
The printks that aren't for debugging should use the name of the controller, not the driver name. Multiple MMC controllers aren't that common today, but this is the right way to do things. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-05[MMC] Fix chip config in wbsdPierre Ossman
There is a broken if clause in the wbsd driver that can cause the driver to try and configure the chip even though none is found. This results in i/o on invalid ports. Signed-off-by: Pierre Ossman <drzeus@drzeus.cx> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-04Fix ips.c compileJames Bottomley
It looks like one of the ips patches was missing a closing brace in a function Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-04Merge by HandJames Bottomley
Conflicts in dec_esp.c (Thanks Bacchus), scsi_transport_iscsi.c and scsi_transport_fc.h Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-04[libata] ATAPI pad allocation fixes/cleanupJeff Garzik
Use ata_pad_{alloc,free} in two drivers, to factor out common code. Add ata_pad_{alloc,free} to two other drivers, which needed the padding but had not been updated.
2005-11-04Merge branch 'master'Jeff Garzik
2005-11-04[PATCH] nvidiafb: Geforce 7800 series support addedCalin A. Culianu
This adds support for the Nvidia Geforce 7800 series of cards to the nvidiafb framebuffer driver. All it does is add the PCI device id for the 7800, 7800 GTX, 7800 GO, and 7800 GTX GO cards to the module device table for the nvidiafb.ko driver, so that nvidiafb.ko will actually work on these cards. I also added the relevant PCI device ids to linux/pci_ids.h I tested it on my 7800 GTX here and it works like a charm. I now can get framebuffer support on this card! Woo hoo!! Nothing like 200x75 text mode to make your eyes BLEED. ;) Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-04Merge branch 'srp' of ↵Linus Torvalds
master.kernel.org:/pub/scm/linux/kernel/git/roland/infiniband
2005-11-04Merge branch 'for-linus' of ↵Linus Torvalds
2005-11-04Merge master.kernel.org:/pub/scm/linux/kernel/git/paulus/powerpc-mergeLinus Torvalds
2005-11-05powerpc: Fix vmlinux.lds.S for 32-bitPaul Mackerras
We can't currently use asm-ppc/page.h in vmlinux.lds.S, so until we have a merged page.h, define PAGE_SIZE and KERNELBASE locally. Also gets rid of some dynamic executable cruft that we had for 32-bit. With -Ttext=$(KERNELBASE) this didn't cause any problem, but when we changed to putting . = KERNELBASE in the vmlinux.lds.S this cruft caused the text to get linked at 0xa0 instead of 0xc0000000. Oops. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-05powerpc: Merge smp.c and smp.hPaul Mackerras
This also moves setup_cpu_maps to setup-common.c (calling it smp_setup_cpu_maps) and uses it on both 32-bit and 64-bit. Signed-off-by: Paul Mackerras <paulus@samba.org>
2005-11-04NFS,SUNRPC,NLM: fix unused variable warnings when CONFIG_SYSCTL is disabledChuck Lever
Fix some dprintk's so that NLM, NFS client, and RPC client compile cleanly if CONFIG_SYSCTL is disabled. Test plan: Compile kernel with CONFIG_NFS enabled and CONFIG_SYSCTL disabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04SUNRPC: allow sunrpc.o to link when CONFIG_SYSCTL is disabledChuck Lever
The sunrpc module should build properly even when CONFIG_SYSCTL is disabled. Reported by Jan-Benedict Glaw. Test plan: Compile kernel with CONFIG_NFS as a module and built-in, and CONFIG_SYSCTL enabled and disabled. Signed-off-by: Chuck Lever <cel@netapp.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04NFSv4: Teach NFSv4 to cache locks when we hold a delegationTrond Myklebust
Now that we have a method of dealing with delegation recalls, actually enable the caching of posix and BSD locks. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04NFSv4: Recover locks too when returning a delegationTrond Myklebust
Delegations allow us to cache posix and BSD locks, however when the delegation is recalled, we need to "flush the cache" and send the cached LOCK requests to the server. This patch sets up the mechanism for doing so. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04NFSv4: Fix recovery of flock() locks.Trond Myklebust
2005-11-04NFSv4: Return any delegations before sillyrenaming the fileTrond Myklebust
I missed this one... Any form of rename will result in a delegation recall, so it is more efficient to return the one we hold before trying the rename. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04NFSv4: Fix the handling of the error NFS4ERR_OLD_STATEIDTrond Myklebust
Ensure that we retry the failed operation... Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04NFSv4: Fix problem with OPEN_DOWNGRADETrond Myklebust
RFC 3530 states that for OPEN_DOWNGRADE "The share_access and share_deny bits specified must be exactly equal to the union of the share_access and share_deny bits specified for some subset of the OPENs in effect for current openowner on the current file. Setattr is currently violating the NFSv4 rules for OPEN_DOWNGRADE in that it may cause a downgrade from OPEN4_SHARE_ACCESS_BOTH to OPEN4_SHARE_ACCESS_WRITE despite the fact that there exists no open file with O_WRONLY access mode. Fix the problem by replacing nfs4_find_state() with a modified version of nfs_find_open_context(). Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04NFSv4: Fix a race between open() and close()Trond Myklebust
We must not remove the nfs4_state structure from the inode open lists before we are in sequence lock. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2005-11-04[USB]: Make early handoff a final fixup instead of a header one.David S. Miller
At header fixup time, it is not yet legal to ioremap() PCI device registers, yet that is what this quirk code needs to do. Signed-off-by: David S. Miller <davem@davemloft.net>
2005-11-04[PATCH] improve scheduler fairness a bitOleg Nesterov
Do not transfer remaining time slice to another cpu on process exit. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-04[MMC] Response to write commands is R1 nor R1bRussell King
2005-11-04Merge master.kernel.org:/home/rmk/linux-2.6-serialLinus Torvalds
2005-11-04Merge master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
2005-11-04Merge master.kernel.org:/pub/scm/linux/kernel/git/acme/net-2.6Linus Torvalds
2005-11-04[PATCH] ARM: Reverted 2918/1: [update] Base port of Comdial MP1000 platfromRussell King
No longer maintained
2005-11-04[PATCH] ARM: Reverted 2921/1: Support for the RTC / nvram on the Comdial MP1000Russell King
2005-11-04[PATCH] ARM: Reverted 2919/1: CS8900A ethernet driver modifications for the ↵Russell King
Comdial MP1000 No longer maintained
2005-11-04[ARM] 3097/1: change library link orderingNicolas Pitre
Patch from Nicolas Pitre We have an optimized sha1 routine (arch/arm/lib/sha1.S) meant to override the generic one in lib/sha1.c. Unfortunately lib/lib.a is listed _before_ arch/arm/lib/lib.a in the link argument list and therefore the architecture specific lib functions are not picked up before the generic versions. This patch is a quick fix to change that ordering for ARM. Here's what the kbuild maintainer had to say about it (was also CC'd on lkml): On Wed, 2 Nov 2005, Sam Ravnborg wrote: > This looks like an obvious way to achive correct ordering. > We could change it so arch defines always took precedence but > the above is so simple that it is not worth the effort. Signed-off-by: Nicolas Pitre <nico@cam.org> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-04[ARM] 3087/1: PXA2xx flash platform device conversionTodd Poynor
Patch from Todd Poynor Add platform devices for flash to Lubbock and Mainstone board files. Once in place, the two existing mtd map drivers for the boards will be converted to use a single pxa2xx map driver in the linux-mtd tree. Take 4: flash_platform_data .map_name vs. .name cleaned up, resync with merged irda patch context. Signed-off-by: Todd Poynor <tpoynor@mvista.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-11-04[ARM] 3086/1: ixp2xxx error irq handlingDave Jiang
Patch from Dave Jiang This provides support for IXP2xxx error interrupt handling. Previously there was a patch to remove this (although the original stuff was broken). Well, now the error bits are needed again. These are used extensively by the micro-engine drivers according to Deepak and also we will need it for the new EDAC code that Alan Cox is trying to push into the main kernel. Re-submit of 3072/1, generated against git tree pulled today. AFAICT, this git tree pulled in all the ARM changes that's in arm.diff. Please let me know if there are additional changes. Thx! Signed-off-by: Dave Jiang <djiang@mvista.com> Signed-off-by: Deepak Saxena <dsaxena@plexity.net> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
