2008-01-30lguest: per-vcpu lguest timersGlauber de Oliveira Costa
Here, I introduce per-vcpu timers. With this, we can have local expiries, needed for accounting time in smp guests Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: make hypercalls use the vcpu structGlauber de Oliveira Costa
this patch changes do_hcall() and do_async_hcall() interfaces (and obviously their callers) to get a vcpu struct. Again, a vcpu services the hypercall, not the whole guest Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: make write() operation smp awareGlauber de Oliveira Costa
This patch makes the write() file operation smp aware. Which means, receiving the vcpu_id value through the offset parameter, and being well aware to which vcpu we're talking to. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: per-cpu run guestGlauber de Oliveira Costa
This patch makes the run_guest() routine use the lg_cpu struct. This is required since in a smp guest environment, there's no more the notion of "running the guest", but rather, it is "running the vcpu" Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: initialize vcpuGlauber de Oliveira Costa
this patch initializes the first vcpu in the initialize() routing, which is responsible for starting the process of putting the guest up. right now, as much of the fields are still not per-vcpu, it does not do much. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: adapt launcher to per-cpunessGlauber de Oliveira Costa
This patch makes uses of pread() and pwrite() in lguest launcher to communicate the vcpu id to the lguest driver. The id is kept in a thread variable, which means we'll span in the future, vcpus as threads. But right now, only the infrastructure is out there. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: introduce vcpu structGlauber de Oliveira Costa
this patch introduces a vcpu struct for lguest. In upcoming patches, more and more fields will be moved from the lguest struct to the vcpu Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: Reboot supportBalaji Rao
Reboot Implemented (Prevent fd leak, fix style and fix documentation --RR) Signed-off-by: Balaji Rao <balajirrao@gmail.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: remove pv_info dependencyGlauber de Oliveira Costa
Currently, lguest module can't be compiled without the PARAVIRT flag being on. This is a fake dependency, since the module itself shouldn't need any paravirt override. Reason for that is the reference to pv_info structure in initial loading tests. This patch removes it in favour of a more generic error message. Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30lguest: fix drivers/lguest Makefile entryGlauber de Oliveira Costa
Parts depend on CONFIG_LGUEST, not just CONFIG_LGUEST_GUEST Signed-off-by: Glauber de Oliveira Costa <gcosta@redhat.com> Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2008-01-30Merge git://git.linux-nfs.org/pub/linux/nfs-2.6Linus Torvalds
* git://git.linux-nfs.org/pub/linux/nfs-2.6: (118 commits) NFSv4: Iterate through all nfs_clients when the server recalls a delegation NFSv4: Deal more correctly with duplicate delegations NFS: Fix a potential race between umount and nfs_access_cache_shrinker() NFS: Add an asynchronous delegreturn operation for use in nfs_clear_inode nfs: convert NFS_*(inode) helpers to static inline nfs: obliterate NFS_FLAGS macro NFS: Address memory leaks in the NFS client mount option parser nfs4: allow nfsv4 acls on non-regular-files NFS: Optimise away the sigmask code in aio/dio reads and writes SUNRPC: Don't bother changing the sigmask for asynchronous RPC calls SUNRPC: rpcb_getport_sync() passes incorrect address size to rpc_create() SUNRPC: Clean up block comment preceding rpcb_getport_sync() SUNRPC: Use appropriate argument types in rpcb client SUNRPC: rpcb_getport_sync() should use built-in hostname generator SUNRPC: Clean up functions that free address_strings array NFS: NFS version number is unsigned NLM: Fix a bogus 'return' in nlmclnt_rpc_release NLM: Introduce an arguments structure for nlmclnt_init() NLM/NFS: Use cached nlm_host when calling nlmclnt_proc() NFS: Invoke nlmclnt_init during NFS mount processing ...
2008-01-30as-iosched: fix double locking bug in as_merged_requests()Jens Axboe
If the two requests belong to the same io context, we will attempt to lock the same lock twice. But swapping contexts is pointless in that case, so just check for rioc == nioc before doing the double lock and copy. Tested-by: Olof Johansson <olof@lixom.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-01-30NFSv4: Iterate through all nfs_clients when the server recalls a delegationTrond Myklebust
The same delegation may have been handed out to more than one nfs_client. Ensure that if a recall occurs, we return all instances. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFSv4: Deal more correctly with duplicate delegationsTrond Myklebust
If a (broken?) server hands out two different delegations for the same file, then we should return one of them. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Fix a potential race between umount and nfs_access_cache_shrinker()Trond Myklebust
Thanks to Yawei Niu for spotting the race. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Add an asynchronous delegreturn operation for use in nfs_clear_inodeTrond Myklebust
Otherwise, there is a potential deadlock if the last dput() from an NFSv4 close() or other asynchronous operation leads to nfs_clear_inode calling the synchronous delegreturn. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30nfs: convert NFS_*(inode) helpers to static inlineBenny Halevy
Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30nfs: obliterate NFS_FLAGS macroBenny Halevy
use NFS_I(inode)->flags instead Signed-off-by: Benny Halevy <bhalevy@panasas.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Address memory leaks in the NFS client mount option parserChuck Lever
David Howells noticed that repeating the same mount option twice during an NFS mount request can result in orphaned memory in certain cases. Only the client_address and mount_server.hostname strings are initialized in the mount parsing loop, so those appear to be the only two pointers that might be written over by repeating a mount option. The strings in the nfs_server section of the nfs_parsed_mount_data structure are set only once after the options are parsed, thus these are not susceptible to being overwritten. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30nfs4: allow nfsv4 acls on non-regular-filesJ. Bruce Fields
The rfc doesn't give any reason it shouldn't be possible to set an attribute on a non-regular file. And if the server supports it, then it shouldn't be up to us to prevent it. Thanks to Erez for the report and Trond for further analysis. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Tested-by: Erez Zadok <ezk@cs.sunysb.edu> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Optimise away the sigmask code in aio/dio reads and writesTrond Myklebust
There are no interruptible waits for asynchronous RPC tasks, so we don't need to wrap calls to rpc_run_task() with an rpc_clnt_sigmask/rpc_clnt_unsigmask pair. Instead we can wrap the wait_for_completion_interruptible() in nfs_direct_wait(). This means that we completely optimise away sigmask setting for the case of non-blocking aio/dio. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Don't bother changing the sigmask for asynchronous RPC callsTrond Myklebust
The caller will never sleep in rpc_execute, so don't bother setting the sigmask. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: rpcb_getport_sync() passes incorrect address size to rpc_create()Chuck Lever
The variable "sin" is a pointer, so sizeof(sin) is the size of a pointer, not the size of thing that sin points to. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up block comment preceding rpcb_getport_sync()Chuck Lever
2008-01-30SUNRPC: Use appropriate argument types in rpcb clientChuck Lever
Clean up: Follow recommendations of Chapter 5 of Documentation/CodingStyle and use "u32" instead of "__u32" for types in definitions that are not shared with user space. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: rpcb_getport_sync() should use built-in hostname generatorChuck Lever
rpc_create() can already fill in the hostname with a string representation of the server's IP address, so remove redundant logic in in rpcb_getport_sync() that does that. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up functions that free address_strings arrayChuck Lever
Clean up: document the rule (kfree) and the exceptions (RPC_DISPLAY_PROTO and RPC_DISPLAY_NETID) when freeing the objects in a transport's address_strings array. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: NFS version number is unsignedChuck Lever
RPC protocol version numbers are unsigned. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NLM: Fix a bogus 'return' in nlmclnt_rpc_releaseTrond Myklebust
2008-01-30NLM: Introduce an arguments structure for nlmclnt_init()Chuck Lever
Clean up: pass 5 arguments to nlmclnt_init() in a structure similar to the new nfs_client_initdata structure. Signed-off-by: Chuck Lever <chuck.lever@oracle.com>
2008-01-30NLM/NFS: Use cached nlm_host when calling nlmclnt_proc()Chuck Lever
Now that each NFS mount point caches its own nlm_host structure, it can be passed to nlmclnt_proc() for each lock request. By pinning an nlm_host for each mount point, we trade the overhead of looking up or creating a fresh nlm_host struct during every NLM procedure call for a little extra memory. We also restrict the nlmclnt_proc symbol to limit the use of this call to in-tree modules. Note that nlm_lookup_host() (just removed from the client's per-request NLM processing) could also trigger an nlm_host garbage collection. Now client-side nlm_host garbage collection occurs only during NFS mount processing. Since the NFS client now holds a reference on these nlm_host structures, they wouldn't have been affected by garbage collection anyway. Given that nlm_lookup_host() reorders the global nlm_host chain after every successful lookup, and that a garbage collection could be triggered during the call, we've removed a significant amount of per-NLM-request CPU processing overhead. Sidebar: there are only a few remaining references to the internals of NFS inodes in the client-side NLM code. The only references I found are related to extracting or comparing the inode's file handle via NFS_FH(). One is in nlmclnt_grant(); the other is in nlmclnt_setlockargs(). Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Invoke nlmclnt_init during NFS mount processingChuck Lever
Cache an appropriate nlm_host structure in the NFS client's mount point metadata for later use. Note that there is no need to set NFS_MOUNT_NONLM in the error case -- if nfs_start_lockd() returns a non-zero value, its callers ensure that the mount request fails outright. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NLM: Introduce external nlm_host set-up and tear-down functionsChuck Lever
We would like to remove the per-lock-operation nlm_lookup_host() call from nlmclnt_proc(). The new architecture pins an nlm_host structure to each NFS client superblock that has the "lock" mount option set. The NFS client passes in the pinned nlm_host structure during each call to nlmclnt_proc(). NFS client unmount processing "puts" the nlm_host so it can be garbage- collected later. This patch introduces externally callable NLM functions that handle mount-time nlm_host set up and tear-down. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Fix up constant string declarations in struct rpcbind_argsTrond Myklebust
...and eliminate an unnecessary cast. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: fewer conditionals in the format_ip_address routinesChuck Lever
Clean up: have the set up routines explicitly pass the strings to be used for the transport name and NETID. This removes a number of conditionals and dependencies on rpc_xprt.prot, which is overloaded. Tighten up type checking on the address_strings array while we're at it. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30lockd: Eliminate harmless mixed sign comparison in nlmdbg_cookie2a()Chuck Lever
The cookie->len field is unsigned, so the loop index variable in nlmdbg_cookie2a() should also be unsigned. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: nfs_write_end clean upChuck Lever
Clean up: commit 4899f9c8 added nfs_write_end(), which introduces a conditional expression that returns an unsigned integer in one arm and a signed integer in the other. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Fix minor mixed sign comparison in NFS client's write logicChuck Lever
Clean up: PAGE_CACHE_SIZE is unsigned, and nfs_pageio_init() takes a size_t. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Use size_t for storing name lengthsChuck Lever
Clean up: always use the same type when handling buffer lengths. As a bonus, this prevents a mixed sign comparison in idmap_lookup_name. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Fix use of copy_to_user() in idmap_pipe_upcallChuck Lever
The idmap_pipe_upcall() function expects the copy_to_user() function to return a negative error value if the call fails, but copy_to_user() returns an unsigned long number of bytes that couldn't be copied. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Clean up fs/nfs/idmap.cChuck Lever
Clean up white space damage and use standard kernel coding conventions for return statements. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Fix use of copy_to_user() in gss_pipe_upcall()Chuck Lever
The gss_pipe_upcall() function expects the copy_to_user() function to return a negative error value if the call fails, but copy_to_user() returns an unsigned long number of bytes that couldn't be copied. Can rpc_pipefs actually retry a partially completed upcall read? If not, then gss_pipe_upcall() should punt any partial read, just like the upcall logic in net/sunrpc/cache.c. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Fix the 'proto=' mount optionTrond Myklebust
Currently, if you have a server mounted using networking protocol, you cannot specify a different value using the 'proto=' option on another mountpoint. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFS: Support per-mountpoint timeout parameters.Trond Myklebust
2008-01-30NFS: Ensure that we respect NFS_MAX_TCP_TIMEOUTTrond Myklebust
It isn't sufficient just to limit timeout->to_initval, we also need to limit to_maxval. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Add support for per-client timeout valuesTrond Myklebust
In order to be able to support setting the timeo and retrans parameters on a per-mountpoint basis, we move the rpc_timeout structure into the rpc_clnt. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30SUNRPC: Clean up the transport timeout initialisationTrond Myklebust
2008-01-30SUNRPC: cleanup for rpc_new_client()Trond Myklebust
There is no reason why we shouldn't just pass the rpc_create_args. Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
2008-01-30NFSv4: Add socket proto argument to setclientidTrond Myklebust
2008-01-30NFS: Pull covers off IPv6 address parsingChuck Lever
Now that the needed IPv6 infrastructure is in place, allow the NFS client's IP address parser to generate AF_INET6 addresses. Signed-off-by: Chuck Lever <chuck.lever@oracle.com> Signed-off-by: Trond Myklebust <Trond.Myklebust@netapp.com>
