2011-07-01perf: Add context field to perf_eventAvi Kivity
The perf_event overflow handler does not receive any caller-derived argument, so many callers need to resort to looking up the perf_event in their local data structure. This is ugly and doesn't scale if a single callback services many perf_events. Fix by adding a context parameter to perf_event_create_kernel_counter() (and derived hardware breakpoints APIs) and storing it in the perf_event. The field can be accessed from the callback as event->overflow_handler_context. All callers are updated. Signed-off-by: Avi Kivity <avi@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1309362157-6596-2-git-send-email-avi@redhat.com Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf, arch: Add generic NODE cache eventsPeter Zijlstra
Add a NODE level to the generic cache events which is used to measure local vs remote memory accesses. Like all other cache events, an ACCESS is HIT+MISS, if there is no way to distinguish between reads and writes do reads only etc.. The below needs filling out for !x86 (which I filled out with unsupported events). I'm fairly sure ARM can leave it like that since it doesn't strike me as an architecture that even has NUMA support. SH might have something since it does appear to have some NUMA bits. Sparc64, PowerPC and MIPS certainly want a good look there since they clearly are NUMA capable. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: David Miller <davem@davemloft.net> Cc: Anton Blanchard <anton@samba.org> Cc: David Daney <ddaney@caviumnetworks.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: Will Deacon <will.deacon@arm.com> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1303508226.4865.8.camel@laptop Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf, intel: Try alternative OFFCORE encodingsPeter Zijlstra
Since the OFFCORE registers are fully symmetric, try the other one when the specified one is already in use. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1306141897.18455.8.camel@twins Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf_events: Add Intel Sandy Bridge offcore_response low-level supportStephane Eranian
This patch adds Intel Sandy Bridge offcore_response support by providing the low-level constraint table for those events. On Sandy Bridge, there are two offcore_response events. Each uses its own dedictated extra register. But those registers are NOT shared between sibling CPUs when HT is on unlike Nehalem/Westmere. They are always private to each CPU. But they still need to be controlled within an event group. All events within an event group must use the same value for the extra MSR. That's not controlled by the second patch in this series. Furthermore on Sandy Bridge, the offcore_response events have NO counter constraints contrary to what the official documentation indicates, so drop the events from the contraint table. Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110606145712.GA7304@quad Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf_events: Fix validation of events using an extra regStephane Eranian
The validate_group() function needs to validate events with extra shared regs. Within an event group, only events with the same value for the extra reg can co-exist. This was not checked by validate_group() because it was missing the shared_regs logic. This patch changes the allocation of the fake cpuc used for validation to also point to a fake shared_regs structure such that group events be properly testing. It modifies __intel_shared_reg_get_constraints() to use spin_lock_irqsave() to avoid lockdep issues. Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110606145708.GA7279@quad Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf_events: Update Intel extra regs shared constraints managementStephane Eranian
This patch improves the code managing the extra shared registers used for offcore_response events on Intel Nehalem/Westmere. The idea is to use static allocation instead of dynamic allocation. This simplifies greatly the get and put constraint routines for those events. The patch also renames per_core to shared_regs because the same data structure gets used whether or not HT is on. When HT is off, those events still need to coordination because they use a extra MSR that has to be shared within an event group. Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110606145703.GA7258@quad Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf: Remove the perf_output_begin(.sample) argumentPeter Zijlstra
Since only samples call perf_output_sample() its much saner (and more correct) to put the sample logic in there than in the perf_output_begin()/perf_output_end() pair. Saves a useless argument, reduces conditionals and shrinks struct perf_output_handle, win! Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-2crpvsx3cqu67q3zqjbnlpsc@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf: Remove the nmi parameter from the swevent and overflow interfacePeter Zijlstra
The nmi parameter indicated if we could do wakeups from the current context, if not, we would set some state and self-IPI and let the resulting interrupt do the wakeup. For the various event classes: - hardware: nmi=0; PMI is in fact an NMI or we run irq_work_run from the PMI-tail (ARM etc.) - tracepoint: nmi=0; since tracepoint could be from NMI context. - software: nmi=[0,1]; some, like the schedule thing cannot perform wakeups, and hence need 0. As one can see, there is very little nmi=1 usage, and the down-side of not using it is that on some platforms some software events can have a jiffy delay in wakeup (when arch_irq_work_raise isn't implemented). The up-side however is that we can remove the nmi parameter and save a bunch of conditionals in fast paths. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: Will Deacon <will.deacon@arm.com> Cc: Deng-Cheng Zhu <dengcheng.zhu@gmail.com> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Paul Mundt <lethal@linux-sh.org> Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jason Wessel <jason.wessel@windriver.com> Cc: Don Zickus <dzickus@redhat.com> Link: http://lkml.kernel.org/n/tip-agjev8eu666tvknpb3iaj0fg@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf, x86: Add hw_watchdog_set_attr() in a sake of nmi-watchdog on P4Cyrill Gorcunov
Due to restriction and specifics of Netburst PMU we need a separated event for NMI watchdog. In particular every Netburst event consumes not just a counter and a config register, but also an additional ESCR register. Since ESCR registers are grouped upon counters (i.e. if ESCR is occupied for some event there is no room for another event to enter until its released) we need to pick up the "least" used ESCR (or the most available one) for nmi-watchdog purposes -- so MSR_P4_CRU_ESCR2/3 was chosen. With this patch nmi-watchdog and perf top should be able to run simultaneously. Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org> CC: Lin Ming <ming.m.lin@intel.com> CC: Arnaldo Carvalho de Melo <acme@redhat.com> CC: Frederic Weisbecker <fweisbec@gmail.com> Tested-and-reviewed-by: Don Zickus <dzickus@redhat.com> Tested-and-reviewed-by: Stephane Eranian <eranian@google.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110623124918.GC13050@sun Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01events: Ensure that timers are updated without requiring read() callEric B Munson
The event tracing infrastructure exposes two timers which should be updated each time the value of the counter is updated. Currently, these counters are only updated when userspace calls read() on the fd associated with an event. This means that counters which are read via the mmap'd page exclusively never have their timers updated. This patch adds ensures that the timers are updated each time the values in the mmap'd page are updated. Signed-off-by: Eric B Munson <emunson@mgebm.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1308932786-5111-1-git-send-email-emunson@mgebm.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01events: Move lockless timer calculation into helper functionEric B Munson
Take the timer calculation from perf_output_read and move it to a helper function for any place that needs timer values but cannot take the ctx->lock. Signed-off-by: Eric B Munson <emunson@mgebm.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1308861279-15216-2-git-send-email-emunson@mgebm.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01events: Add note to update_event_times comment about holding ctx->lockEric B Munson
Signed-off-by: Eric B Munson <emunson@mgebm.net> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1308861279-15216-1-git-send-email-emunson@mgebm.net Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf: Remove 64-bit alignment padding from perf_event_contextRichard Kennedy
Reorder perf_event_context to remove 8 bytes of 64 bit alignment padding shrinking its size to 192 bytes, allowing it to fit into a smaller slab and use one fewer cache lines. Signed-off-by: Richard Kennedy <richard@rsk.demon.co.uk> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1307460819.1950.5.camel@castor.rsk Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01perf_events: Fix perf buffer watermark settingVince Weaver
Since 2.6.36 (specifically commit d57e34fdd60b ("perf: Simplify the ring-buffer logic: make perf_buffer_alloc() do everything needed"), the perf_buffer_init_code() has been mis-setting the buffer watermark if perf_event_attr.wakeup_events has a non-zero value. This is because perf_event_attr.wakeup_events is a union with perf_event_attr.wakeup_watermark. This commit re-enables the check for perf_event_attr.watermark being set before continuing with setting a non-default watermark. This bug is most noticable when you are trying to use PERF_IOC_REFRESH with a value larger than one and perf_event_attr.wakeup_events is set to one. In this case the buffer watermark will be set to 1 and you will get extraneous POLL_IN overflows rather than POLL_HUP as expected. [ avoid using attr.wakeup_events when attr.watermark is set ] Signed-off-by: Vince Weaver <vweaver1@eecs.utk.edu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: <stable@kernel.org> Link: http://lkml.kernel.org/r/alpine.DEB.2.00.1106011506390.5384@cl320.eecs.utk.edu Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01irq_work, alpha: Fix up arch hooksPeter Zijlstra
Commit e360adbe29 ("irq_work: Add generic hardirq context callbacks") fouled up the Alpha bit, not properly naming the arch specific function that raises the 'self-IPI'. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Michael Cree <mcree@orcon.net.nz> Cc: stable@kernel.org # 37+ Link: http://lkml.kernel.org/n/tip-gukh0txmql2l4thgrekzzbfy@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01irq_work, ppc: Fix up arch hooksPeter Zijlstra
Commit e360adbe29 ("irq_work: Add generic hardirq context callbacks") fouled up the ppc bit, not properly naming the arch specific function that raises the 'self-IPI'. Cc: Huang Ying <ying.huang@intel.com> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: stable@kernel.org # 37+ Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/n/tip-eg0aqien8p1aqvzu9dft6dtv@git.kernel.org Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-07-01Merge commit 'v3.0-rc5' into perf/coreIngo Molnar
Merge reason: Pick up the latest fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-06-27Linux 3.0-rc5v3.0-rc5Linus Torvalds
2011-06-27drm/i915: more struct_mutex lockingHugh Dickins
When auditing the locking in i915_gem.c (for a prospective change which I then abandoned), I noticed two places where struct_mutex is not held across GEM object manipulations that would usually require it. Since one is in initial setup and the other in driver unload, I'm guessing the mutex is not required for either; but post a patch in case it is. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Keith Packard <keithp@keithp.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drm/i915: use shmem_truncate_rangeHugh Dickins
The interface to ->truncate_range is changing very slightly: once "tmpfs: take control of its truncate_range" has been applied, this can be applied. For now there is only a slight inefficiency while this remains unapplied, but it will soon become essential for managing shmem's use of swap. Change i915_gem_object_truncate() to use shmem_truncate_range() directly: which should also spare i915 later change if we switch from inode_operations->truncate_range to file_operations->fallocate. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Keith Packard <keithp@keithp.com> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drm/i915: use shmem_read_mapping_pageHugh Dickins
Soon tmpfs will stop supporting ->readpage and read_cache_page_gfp(): once "tmpfs: add shmem_read_mapping_page_gfp" has been applied, this patch can be applied to ease the transition. Make i915_gem_object_get_pages_gtt() use shmem_read_mapping_page_gfp() in the one place it's needed; elsewhere use shmem_read_mapping_page(), with the mapping's gfp_mask properly initialized. Forget about __GFP_COLD: since tmpfs initializes its pages with memset, asking for a cold page is counter-productive. Include linux/shmem_fs.h also in drm_gem.c: with shmem_file_setup() now declared there too, we shall remove the prototype from linux/mm.h later. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Chris Wilson <chris@chris-wilson.co.uk> Cc: Keith Packard <keithp@keithp.com> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drm/ttm: use shmem_read_mapping_pageHugh Dickins
Soon tmpfs will stop supporting ->readpage and read_mapping_page(): once "tmpfs: add shmem_read_mapping_page_gfp" has been applied, this patch can be applied to ease the transition. ttm_tt_swapin() and ttm_tt_swapout() use shmem_read_mapping_page() in place of read_mapping_page(), since their swap_space has been created with shmem_file_setup(). Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Dave Airlie <airlied@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/tty/serial/8250_pci.c: fix warningAndrew Morton
Fis the warning drivers/tty/serial/8250_pci.c:1457: warning: initialization from incompatible pointer type Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/misc/ioc4.c: fix section mismatch / race conditionRalf Baechle
Fix this section mismatch: WARNING: drivers/misc/ioc4.o(.data+0x144): Section mismatch in reference from the variable ioc4_load_modules_work to the function .devinit.text:ioc4_load_modules() The variable ioc4_load_modules_work references the function __devinit ioc4_load_modules() If the reference is valid then annotate the variable with __init* or __refdata (see linux/init.h) or name the variable: *driver, *_template, *_timer, *_sht, *_ops, *_probe, *_probe_one, *_console This one is potentially fatal; by the time ioc4_load_modules is invoked it may already have been freed. For that reason ioc4_load_modules_work can't be turned to __devinitdata but also because it's referenced in ioc4_exit. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Acked-by: Brent Casavant <bcasavan@sgi.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/leds/leds-lp5523.c: fix section mismatchesRalf Baechle
Fix this section mismatch: WARNING: drivers/leds/leds-lp5523.o(.text+0x12f4): Section mismatch in reference from the function lp5523_probe() to the function .init.text:lp5523_init_led() The function lp5523_probe() references the function __init lp5523_init_led(). This is often because lp5523_probe lacks a __init annotation or the annotation of lp5523_init_led is wrong. Fixing this one triggers one more mismatch, fix that one as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/leds/leds-lp5521.c: fix section mismatchesRalf Baechle
Fix this section mismatch: WARNING: drivers/leds/leds-lp5521.o(.text+0xf2c): Section mismatch in reference from the function lp5521_probe() to the function .init.text:lp5521_init_led() The function lp5521_probe() references the function __init lp5521_init_led(). This is often because lp5521_probe lacks a __init annotation or the annotation of lp5521_init_led is wrong. Fixing this mismatch triggers one more mismatch, fix that one as well. Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27memcg: fix direct softlimit reclaim to be called in limit pathKAMEZAWA Hiroyuki
Commit d149e3b25d7c ("memcg: add the soft_limit reclaim in global direct reclaim") adds a softlimit hook to shrink_zones(). By this, soft limit is called as try_to_free_pages() do_try_to_free_pages() shrink_zones() mem_cgroup_soft_limit_reclaim() Then, direct reclaim is memcg softlimit hint aware, now. But, the memory cgroup's "limit" path can call softlimit shrinker. try_to_free_mem_cgroup_pages() do_try_to_free_pages() shrink_zones() mem_cgroup_soft_limit_reclaim() This will cause a global reclaim when a memcg hits limit. This is bug. soft_limit_reclaim() should be called when scanning_global_lru(sc) == true. And the commit adds a variable "total_scanned" for counting softlimit scanned pages....it's not "total". This patch removes the variable and update sc->nr_scanned instead of it. This will affect shrink_slab()'s scan condition but, global LRU is scanned by softlimit and I think this change makes sense. TODO: avoid too much scanning of a zone when softlimit did enough work. Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Cc: Ying Han <yinghan@google.com> Cc: Michal Hocko <mhocko@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27taskstats: don't allow duplicate entries in listener modeVasiliy Kulikov
Currently a single process may register exit handlers unlimited times. It may lead to a bloated listeners chain and very slow process terminations. Eg after 10KK sent TASKSTATS_CMD_ATTR_REGISTER_CPUMASKs ~300 Mb of kernel memory is stolen for the handlers chain and "time id" shows 2-7 seconds instead of normal 0.003. It makes it possible to exhaust all kernel memory and to eat much of CPU time by triggerring numerous exits on a single CPU. The patch limits the number of times a single process may register itself on a single CPU to one. One little issue is kept unfixed - as taskstats_exit() is called before exit_files() in do_exit(), the orphaned listener entry (if it was not explicitly deregistered) is kept until the next someone's exit() and implicit deregistration in send_cpu_listeners(). So, if a process registered itself as a listener exits and the next spawned process gets the same pid, it would inherit taskstats attributes. Signed-off-by: Vasiliy Kulikov <segooon@gmail.com> Cc: Balbir Singh <bsingharora@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: fix assertion mapping->nrpages == 0 in end_writeback()Jan Kara
Under heavy memory and filesystem load, users observe the assertion mapping->nrpages == 0 in end_writeback() trigger. This can be caused by page reclaim reclaiming the last page from a mapping in the following race: CPU0 CPU1 ... shrink_page_list() __remove_mapping() __delete_from_page_cache() radix_tree_delete() evict_inode() truncate_inode_pages() truncate_inode_pages_range() pagevec_lookup() - finds nothing end_writeback() mapping->nrpages != 0 -> BUG page->mapping = NULL mapping->nrpages-- Fix the problem by doing a reliable check of mapping->nrpages under mapping->tree_lock in end_writeback(). Analyzed by Jay <jinshan.xiong@whamcloud.com>, lost in LKML, and dug out by Miklos Szeredi <mszeredi@suse.de>. Cc: Jay <jinshan.xiong@whamcloud.com> Cc: Miklos Szeredi <mszeredi@suse.de> Signed-off-by: Jan Kara <jack@suse.cz> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm/memory-failure.c: fix spinlock vs mutex orderPeter Zijlstra
We cannot take a mutex while holding a spinlock, so flip the order and fix the locking documentation. Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/misc/lkdtm.c: fix race when crashpoint is hit multiple times before ↵Josh Hunt
checking count We observed the crash point count going negative in cases where the crash point is hit multiple times before the check of "count == 0" is done. Because of this we never call lkdtm_do_action(). This patch just adds a spinlock to protect count. Reported-by: Tapan Dhimant <tdhimant@akamai.com> Signed-off-by: Josh Hunt <johunt@akamai.com> Acked-by: Ankita Garg <ankita@in.ibm.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27include/linux/compat.h: declare compat_sys_sendmmsg()Chris Metcalf
This is required for tilegx to be able to use the compat unistd.h header where compat_sys_sendmmsg() is now mentioned. Signed-off-by: Chris Metcalf <cmetcalf@tilera.com> Cc: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27romfs: fix romfs_get_unmapped_area() argument checkBob Liu
romfs_get_unmapped_area() checks argument `len' without considering PAGE_ALIGN which will cause do_mmap_pgoff() return -EINVAL error after commit f67d9b1576c ("nommu: add page_align to mmap"). Fix the check by changing it in same way ramfs_nommu_get_unmapped_area() was changed in ramfs/file-nommu.c. Signed-off-by: Bob Liu <lliubbo@gmail.com> Cc: David Howells <dhowells@redhat.com> Cc: Paul Mundt <lethal@linux-sh.org> Acked-by: Greg Ungerer <gerg@snapgear.com> Cc: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27um: add asm/percpu.hRichard Weinberger
To make SLUB work on UML we need this_cpu_cmpxchg from asm-generic/percpu.h. Signed-off-by: Richard Weinberger <richard@nod.at> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27drivers/rtc/rtc-ds1307.c: add support for RTC device pt7c4338Priyanka Jain
PT7C4338 chip is being manufactured by Pericom Technology Inc. It is a serial real-time clock which provides: 1) Low-power clock/calendar. 2) Programmable square-wave output. It has 56 bytes of nonvolatile RAM. Its register set is same as that of rtc device: DS1307. Signed-off-by: Priyanka Jain <Priyanka.Jain@freescale.com> Acked-by: Timur Tabi <timur@freescale.com> Reviewed-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: add shmem_read_mapping_page_gfpHugh Dickins
Although it is used (by i915) on nothing but tmpfs, read_cache_page_gfp() is unsuited to tmpfs, because it inserts a page into pagecache before calling the filesystem's ->readpage: tmpfs may have pages in swapcache which only it knows how to locate and switch to filecache. At present tmpfs provides a ->readpage method, and copes with this by copying pages; but soon we can simplify it by removing its ->readpage. Provide shmem_read_mapping_page_gfp() now, ready for that transition, Export shmem_read_mapping_page_gfp() and add it to list in shmem_fs.h, with shmem_read_mapping_page() inline for the common mapping_gfp case. (shmem_read_mapping_page_gfp or shmem_read_cache_page_gfp? Generally the read_mapping_page functions use the mapping's ->readpage, and the read_cache_page functions use the supplied filler, so I think read_cache_page_gfp was slightly misnamed.) Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27tmpfs: take control of its truncate_rangeHugh Dickins
2.6.35's new truncate convention gave tmpfs the opportunity to control its file truncation, no longer enforced from outside by vmtruncate(). We shall want to build upon that, to handle pagecache and swap together. Slightly redefine the ->truncate_range interface: let it now be called between the unmap_mapping_range()s, with the filesystem responsible for doing the truncate_inode_pages_range() from it - just as the filesystem is nowadays responsible for doing that from its ->setattr. Let's rename shmem_notify_change() to shmem_setattr(). Instead of calling the generic truncate_setsize(), bring that code in so we can call shmem_truncate_range() - which will later be updated to perform its own variant of truncate_inode_pages_range(). Remove the punch_hole unmap_mapping_range() from shmem_truncate_range(): now that the COW's unmap_mapping_range() comes after ->truncate_range, there is no need to call it a third time. Export shmem_truncate_range() and add it to the list in shmem_fs.h, so that i915_gem_object_truncate() can call it explicitly in future; get this patch in first, then update drm/i915 once this is available (until then, i915 will just be doing the truncate_inode_pages() twice). Though introduced five years ago, no other filesystem is implementing ->truncate_range, and its only other user is madvise(,,MADV_REMOVE): we expect to convert it to fallocate(,FALLOC_FL_PUNCH_HOLE,,) shortly, whereupon ->truncate_range can be removed from inode_operations - shmem_truncate_range() will help i915 across that transition too. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: move shmem prototypes to shmem_fs.hHugh Dickins
Before adding any more global entry points into shmem.c, gather such prototypes into shmem_fs.h. Remove mm's own declarations from swap.h, but for now leave the ones in mm.h: because shmem_file_setup() and shmem_zero_setup() are called from various places, and we should not force other subsystems to update immediately. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27mm: move vmtruncate_range to truncate.cHugh Dickins
You would expect to find vmtruncate_range() next to vmtruncate() in mm/truncate.c: move it there. Signed-off-by: Hugh Dickins <hughd@google.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27Fix some kernel-doc warningsVitaliy Ivanov
Fix 'make htmldocs' warnings: Warning(/include/linux/hrtimer.h:153): No description found for parameter 'clockid' Warning(/include/linux/device.h:604): Excess struct/union/enum/typedef member 'of_match' description in 'device' Warning(/include/net/sock.h:349): Excess struct/union/enum/typedef member 'sk_rmem_alloc' description in 'sock' Signed-off-by: Vitaliy Ivanov <vitalivanov@gmail.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-06-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: mmc: queue: bring discard_granularity/alignment into line with SCSI mmc: queue: append partition subname to queue thread name mmc: core: make erase timeout calculation allow for gated clock mmc: block: switch card to User Data Area when removing the block driver mmc: sdio: reset card during power_restore mmc: cb710: fix #ifdef HAVE_EFFICIENT_UNALIGNED_ACCESS mmc: sdhi: DMA slave ID 0 is invalid mmc: tmio: fix regression in TMIO_MMC_WRPROTECT_DISABLE handling mmc: omap_hsmmc: use original sg_len for dma_unmap_sg mmc: omap_hsmmc: fix ocr mask usage mmc: sdio: fix runtime PM path during driver removal mmc: Add PCI fixup quirks for Ricoh 1180:e823 reader mmc: sdhi: fix module unloading mmc: of_mmc_spi: add NO_IRQ define to of_mmc_spi.c mmc: vub300: fix null dereferences in error handling
2011-06-27Fix node_start/end_pfn() definition for mm/page_cgroup.cKAMEZAWA Hiroyuki
commit 21a3c96 uses node_start/end_pfn(nid) for detection start/end of nodes. But, it's not defined in linux/mmzone.h but defined in /arch/???/include/mmzone.h which is included only under CONFIG_NEED_MULTIPLE_NODES=y. Then, we see mm/page_cgroup.c: In function 'page_cgroup_init': mm/page_cgroup.c:308: error: implicit declaration of function 'node_start_pfn' mm/page_cgroup.c:309: error: implicit declaration of function 'node_end_pfn' So, fixiing page_cgroup.c is an idea... But node_start_pfn()/node_end_pfn() is a very generic macro and should be implemented in the same manner for all archs. (m32r has different implementation...) This patch removes definitions of node_start/end_pfn() in each archs and defines a unified one in linux/mmzone.h. It's not under CONFIG_NEED_MULTIPLE_NODES, now. A result of macro expansion is here (mm/page_cgroup.c) for !NUMA start_pfn = ((&contig_page_data)->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (&contig_page_data); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); for NUMA (x86-64) start_pfn = ((node_data[nid])->node_start_pfn); end_pfn = ({ pg_data_t *__pgdat = (node_data[nid]); __pgdat->node_start_pfn + __pgdat->node_spanned_pages;}); Changelog: - fixed to avoid using "nid" twice in node_end_pfn() macro. Reported-and-acked-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-and-tested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Mel Gorman <mgorman@suse.de> Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: btrfs: fix inconsonant inode information Btrfs: make sure to update total_bitmaps when freeing cache V3 Btrfs: fix type mismatch in find_free_extent() Btrfs: make sure to record the transid in new inodes
2011-06-27Merge branch 'for-linus' of git://oss.sgi.com/xfs/xfsLinus Torvalds
* 'for-linus' of git://oss.sgi.com/xfs/xfs: xfs: prevent bogus assert when trying to remove non-existent attribute xfs: clear XFS_IDIRTY_RELEASE on truncate down xfs: reset inode per-lifetime state when recycling it
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: hid-multitouch: add support for a new Lumio dual-touch panel HID: hid-multitouch: correct VID for Stantum panels HID: hid-multitouch: ensure slots are initialized
2011-06-27Merge branch 'fixes' of master.kernel.org:/home/rmk/linux-2.6-armLinus Torvalds
* 'fixes' of master.kernel.org:/home/rmk/linux-2.6-arm: ARM: pm: ensure ARMv7 CPUs save and restore the TLS register ARM: pm: proc-v7: fix missing struct processor pointers for suspend code ARM: 6969/1: plat-iop: fix build error ARM: 6961/1: zImage: Add build-time check for correctly-sized proc_type entries ARM: SMP: wait for CPU to be marked active ARM: 6963/1: Thumb-2: Relax relocation requirements for non-function symbols ARM: 6962/1: mach-h720x: fix build error ARM: 6959/1: SMP build fix for entry-macro-multi.S
2011-06-27Merge branch 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6Linus Torvalds
* 'for-linus' of git://git390.marist.edu/pub/scm/linux-2.6: [S390] allow setting of upper 32 bit in smp_ctl_set_bit [S390] hwsampler: Set a sane default sampling rate [S390] s390: enforce HW limits for the initial sampling rate [S390] kvm-s390: fix kconfig dependencies
2011-06-27btrfs: fix inconsonant inode informationMiao Xie
When iputting the inode, We may leave the delayed nodes if they have some delayed items that have not been dealt with. So when the inode is read again, we must look up the relative delayed node, and use the information in it to initialize the inode. Or we will get inconsonant inode information, it may cause that the same directory index number is allocated again, and hit the following oops: [ 5447.554187] err add delayed dir index item(name: pglog_0.965_0) into the insertion tree of the delayed node(root id: 262, inode id: 258, errno: -17) [ 5447.569766] ------------[ cut here ]------------ [ 5447.575361] kernel BUG at fs/btrfs/delayed-inode.c:1301! [SNIP] [ 5447.790721] Call Trace: [ 5447.793191] [<ffffffffa0641c4e>] btrfs_insert_dir_item+0x189/0x1bb [btrfs] [ 5447.800156] [<ffffffffa0651a45>] btrfs_add_link+0x12b/0x191 [btrfs] [ 5447.806517] [<ffffffffa0651adc>] btrfs_add_nondir+0x31/0x58 [btrfs] [ 5447.812876] [<ffffffffa0651d6a>] btrfs_create+0xf9/0x197 [btrfs] [ 5447.818961] [<ffffffff8111f840>] vfs_create+0x72/0x92 [ 5447.824090] [<ffffffff8111fa8c>] do_last+0x22c/0x40b [ 5447.829133] [<ffffffff8112076a>] path_openat+0xc0/0x2ef [ 5447.834438] [<ffffffff810c58e2>] ? __perf_event_task_sched_out+0x24/0x44 [ 5447.841216] [<ffffffff8103ecdd>] ? perf_event_task_sched_out+0x59/0x67 [ 5447.847846] [<ffffffff81121a79>] do_filp_open+0x3d/0x87 [ 5447.853156] [<ffffffff811e126c>] ? strncpy_from_user+0x43/0x4d [ 5447.859072] [<ffffffff8111f1f5>] ? getname_flags+0x2e/0x80 [ 5447.864636] [<ffffffff8111f179>] ? do_getname+0x14b/0x173 [ 5447.870112] [<ffffffff8111f1b7>] ? audit_getname+0x16/0x26 [ 5447.875682] [<ffffffff8112b1ab>] ? spin_lock+0xe/0x10 [ 5447.880882] [<ffffffff81112d39>] do_sys_open+0x69/0xae [ 5447.886153] [<ffffffff81112db1>] sys_open+0x20/0x22 [ 5447.891114] [<ffffffff813b9aab>] system_call_fastpath+0x16/0x1b Fix it by reusing the old delayed node. Reported-by: Jim Schutt <jaschut@sandia.gov> Signed-off-by: Miao Xie <miaox@cn.fujitsu.com> Tested-by: Jim Schutt <jaschut@sandia.gov> Signed-off-by: Chris Mason <chris.mason@oracle.com>
2011-06-26Merge git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/sfrench/cifs-2.6: cifs: mark CONFIG_CIFS_NFSD_EXPORT as BROKEN cifs: free blkcipher in smbhash
2011-06-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: cifs: propagate errors from cifs_get_root() to mount(2) cifs: tidy cifs_do_mount() up a bit cifs: more breakage on mount failures cifs: close sget() races cifs: pull freeing mountdata/dropping nls/freeing cifs_sb into cifs_umount() cifs: move cifs_umount() call into ->kill_sb() cifs: pull cifs_mount() call up sanitize cifs_umount() prototype cifs: initialize ->tlink_tree in cifs_setup_cifs_sb() cifs: allocate mountdata earlier cifs: leak on mount if we share superblock cifs: don't pass superblock to cifs_mount() cifs: don't leak nls on mount failure cifs: double free on mount failure take bdi setup/destruction into cifs_mount/cifs_umount Acked-by: Steve French <smfrench@gmail.com>
