2012-03-19Merge branch 'for-3.4/cleanup-and-fixes' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra into tegra/cleanups * 'for-3.4/cleanup-and-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra: ARM: tegra: select USB_ULPI if USB is selected arm/tegra: pcie: fix return value of function arm/tegra: add timeout to PCIe PLL lock detection loop arm/tegra: fix harmony pinmux for PCIe
2012-03-18ARM: tegra: select USB_ULPI if USB is selectedArnd Bergmann
Automatically select USB_ULPI if USB is enabled on Tegra. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alan Ott <alan@signal11.us> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-18arm/tegra: pcie: fix return value of functionDmitry Artamonow
In previous patch (arm/tegra: add timeout to PCIe PLL lock detection loop) tegra_pcie_enable_controller() function type has been changed from void to int, but the last return statement wasn't converted, so function returns undefined value. Fix it. Also while at it, address couple of minor concerns raised by reviewers: use usleep_range for delay, and lower the value of timeout to 300ms to be consistent with Nvidia Vibrante kernel. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-07arm/tegra: add timeout to PCIe PLL lock detection loopDmitry Artamonow
Tegra PCIe driver waits for PLL to lock using busy loop. If PLL fails to lock for some reason, this leads to silent lockup while booting (as PCIe code is not modular). Fix by adding timeout, so if PLL doesn't lock in a couple of seconds, just PCIe driver fails and machine continues to boot. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-07arm/tegra: fix harmony pinmux for PCIeDmitry Artamonow
Commit 6e96aca397 (arm/tegra: Harmony PCIe: Don't touch pinmux) removed runtime tri-state toggling for PCIe related pinmux groups, but it seems that the fact that all of them are tri-state by default has been overlooked. Change defaults for these groups to TEGRA_TRI_NORMAL. Signed-off-by: Dmitry Artamonow <mad_soft@inbox.ru> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-04Merge tag 'tegra-cleanups' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra into tegra/cleanups Minor fixes that weren't urgent enough to go into 3.3. The two paz00 patches are in mainline already but got merged after the branch point for this branch, so they're duplicated. I also ended up merging in rmk/for-armsoc into this later on to fix a bug introduced by it, so it's included but it's not the base of this branch. * tag 'tegra-cleanups' of git://git.kernel.org/pub/scm/linux/kernel/git/olof/tegra: ARM: tegra: Enable CPUIdle on Tegra20 ARM: tegra: export usb phy symbols ARM: tegra: build localtimer support only when needed ARM: tegra: select CPU_FREQ_TABLE ARM: tegra: select required CPU and L2 errata options ARM: tegra: paz00: fix wrong UART port on mini-pcie plug ARM: tegra: paz00: fix wrong SD1 power gpio Signed-off-by: Arnd Bergmann <arnd@arndb.de>
2012-03-04ARM: tegra: Enable CPUIdle on Tegra20Peter De Schrijver
As the LP3 code also works for Tegra20, we can enable cpuidle for Tegra20. Signed-off-by: Peter De Schrijver <pdeschrijver@nvidia.com> Acked-by: Stephen Warren <swarren@nvidia.com> Tested-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-04ARM: tegra: export usb phy symbolsArnd Bergmann
The ehci driver can be a module, so the functions provided by the tegra platform code used by ehci-tegra need to be exported. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-04ARM: tegra: build localtimer support only when neededArnd Bergmann
It is possible to build a tegra kernel without localtimer support, so the tegra specific parts should only be built when that is indeed enabled. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-04ARM: tegra: select CPU_FREQ_TABLEArnd Bergmann
The tegra cpufreq implementation relies on the cpu_freq_table code, so make sure that this is always there when needed. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: Olof Johansson <olof@lixom.net>
2012-03-04Merge branch 'depends/rmk/for-armsoc' into for-3.4/cleanup-and-fixesOlof Johansson
2012-02-26ARM: tegra: select required CPU and L2 errata optionsStephen Warren
The ARM IP revisions in Tegra are: Tegra20: CPU r1p1, PL310 r2p0 Tegra30: CPU A01=r2p7/>=A02=r2p9, NEON r2p3-50, PL310 r3p1-50 Based on work by Olof Johansson, although the actual list of errata is somewhat different here, since I added a bunch more and removed one PL310 erratum that doesn't seem applicable. Signed-off-by: Stephen Warren <swarren@nvidia.com> Cc: stable@vger.kernel.org Signed-off-by: Olof Johansson <olof@lixom.net>
2012-02-22Merge branch 'entry-macro-cleanup' of git://sources.calxeda.com/kernel/linux ↵Russell King
into for-armsoc
2012-02-21ARM: remove disable_fiq and arch_ret_to_user macrosRob Herring
Now that most platforms don't need disable_fiq and arch_ret_to_user macros, we can remove the empty macros or empty entry-macro.S files. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Jamie Iles <jamie@jamieiles.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Tony Lindgren <tony@atomide.com> Acked-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Shawn Guo <shawn.guo@linaro.org>
2012-02-21ARM: make entry-macro.S depend on !MULTI_IRQ_HANDLERRob Herring
With the removal of disable_fiq on rpc and addition MULTI_IRQ_HANDLER, entry-macro.S is no longer needed for platforms that select MULTI_IRQ_HANDLER and the include of it can be conditional. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com>
2012-02-21ARM: rpc: make default fiq handler run-time installedRob Herring
Only rpc uses disable_fiq macro. Change it to a run-time installed default FIQ handler. The handler is installed before FIQ is enabled so the behavior should be unchanged. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-02-21ARM: make arch_ret_to_user macro optionalRob Herring
Only 3 platforms need arch_ret_to_user macro, so add ARCH_HAS_RET_TO_USER kconfig option and make iop13xx, iop32x and iop33x select it. Signed-off-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Nicolas Pitre <nico@linaro.org>
2012-02-08Linux 3.3-rc3v3.3-rc3Linus Torvalds
2012-02-08Merge branch 'iommu/fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu One patch fixes an bug in the ARM/MSM IOMMU code which returned sucess in the unmap function even when an error occured and the other patch adds a workaround into the AMD IOMMU driver to better handle broken IVRS ACPI tables (this patch fixes the case when a device is not listed in the table but actually translated by the iommu). * 'iommu/fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/joro/iommu: iommu/msm: Fix error handling in msm_iommu_unmap() iommu/amd: Work around broken IVRS tables
2012-02-08Merge branch '3.3-rc-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending This series contains pending target bug-fixes and cleanups for v3.3-rc3 that have been addressed the past weeks in lio-core.git. Some of the highlights include: - Fix handling for control CDBs with data greater than PAGE_SIZE (andy) - Use IP_FREEBIND for iscsi-target to address network portal creation issues with systemd (dax) - Allow PERSISTENT RESERVE IN for non-reservation holder (marco) - Fix iblock se_dev_attrib.unmap_granularity (marco) - Fix unsupported WRITE_SAME sense payload handling (martin) - Add workaround for zero-length control CDB handling (nab) - Fix discovery with INADDR_ANY and IN6ADDR_ANY_INIT (nab) - Fix target_submit_cmd() exception handling (nab) - Return correct ASC for unimplemented VPD pages (roland) - Don't zero pages used for data buffers (roland) - Fix return code of core_tpg_.*_lun (sebastian) * '3.3-rc-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (26 commits) target: Fix unsupported WRITE_SAME sense payload iscsi: use IP_FREEBIND socket option iblock: fix handling of large requests target: handle empty string writes in sysfs iscsi_target: in_aton needs linux/inet.h target: Fix iblock se_dev_attrib.unmap_granularity target: Fix target_submit_cmd() exception handling target: Change target_submit_cmd() to return void target: accept REQUEST_SENSE with 18bytes target: Fail INQUIRY commands with EVPD==0 but PAGE CODE!=0 target: Return correct ASC for unimplemented VPD pages iscsi-target: Fix discovery with INADDR_ANY and IN6ADDR_ANY_INIT target: Allow control CDBs with data > 1 page iscsi-target: Fix up a few assignments iscsi-target: make one-bit bitfields unsigned iscsi-target: Fix double list_add with iscsit_alloc_buffs reject iscsi-target: Fix reject release handling in iscsit_free_cmd() target: fix return code of core_tpg_.*_lun target: use save/restore lock primitive in core_dec_lacl_count() target: avoid multiple outputs in scsi_dump_inquiry() ...
2012-02-08Merge tag 'md-3.3-fixes' of git://neil.brown.name/mdLinus Torvalds
Some simple md-related fixes. 1/ two small fixes to ensure we handle an interrupted resync properly. 2/ avoid loading the bitmap multiple times in dm-raid * tag 'md-3.3-fixes' of git://neil.brown.name/md: md: two small fixes to handling interrupt resync. Prevent DM RAID from loading bitmap twice.
2012-02-08Merge tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6Linus Torvalds
SPI bug fixes for v3.3-rc2 Minor SPI device driver changes. A rename of the pch_spi_pcidev symbol that merely eliminates a modpost warning, and a Kconfig change to allow the Samsung spi driver to build on EXYNOS. * tag 'spi-for-linus' of git://git.secretlab.ca/git/linux-2.6: spi-topcliff-pch: rename pch_spi_pcidev to pch_spi_pcidev_driver spi: Add spi-s3c64xx driver dependency on ARCH_EXYNOS4
2012-02-08Merge branch 'akpm' (Andrew's tree)Linus Torvalds
Five fixes * branch 'akpm': pcmcia: fix socket refcount decrementing on each resume mm: fix UP THP spin_is_locked BUGs drivers/leds/leds-lm3530.c: fix setting pltfm->als_vmax mm: compaction: check for overlapping nodes during isolation for migration nilfs2: avoid overflowing segment numbers in nilfs_ioctl_clean_segments()
2012-02-08pcmcia: fix socket refcount decrementing on each resumeRussell King
This fixes a memory-corrupting bug: not only does it cause the warning, but as a result of dropping the refcount to zero, it causes the pcmcia_socket0 device structure to be freed while it still has references, causing slab caches corruption. A fatal oops quickly follows this warning - often even just a 'dmesg' following the warning causes the kernel to oops. While testing suspend/resume on an ARM device with PCMCIA support, and a CF card inserted, I found that after five suspend and resumes, the kernel would complain, and shortly die after with slab corruption. WARNING: at include/linux/kref.h:41 kobject_get+0x28/0x50() As the message doesn't give a clue about which kobject, and the built-in debugging in drivers/base/power/main.c happens too late, this was added right before each get_device(): printk("%s: %p [%s] %u\n", __func__, dev, kobject_name(&dev->kobj), atomic_read(&dev->kobj.kref.refcount)); and on the 3rd s2ram cycle, the following behaviour observed: On the 3rd suspend/resume cycle: dpm_prepare: c1a0d998 [pcmcia_socket0] 3 dpm_suspend: c1a0d998 [pcmcia_socket0] 3 dpm_suspend_noirq: c1a0d998 [pcmcia_socket0] 3 dpm_resume_noirq: c1a0d998 [pcmcia_socket0] 3 dpm_resume: c1a0d998 [pcmcia_socket0] 3 dpm_complete: c1a0d998 [pcmcia_socket0] 2 4th: dpm_prepare: c1a0d998 [pcmcia_socket0] 2 dpm_suspend: c1a0d998 [pcmcia_socket0] 2 dpm_suspend_noirq: c1a0d998 [pcmcia_socket0] 2 dpm_resume_noirq: c1a0d998 [pcmcia_socket0] 2 dpm_resume: c1a0d998 [pcmcia_socket0] 2 dpm_complete: c1a0d998 [pcmcia_socket0] 1 5th: dpm_prepare: c1a0d998 [pcmcia_socket0] 1 dpm_suspend: c1a0d998 [pcmcia_socket0] 1 dpm_suspend_noirq: c1a0d998 [pcmcia_socket0] 1 dpm_resume_noirq: c1a0d998 [pcmcia_socket0] 1 dpm_resume: c1a0d998 [pcmcia_socket0] 1 dpm_complete: c1a0d998 [pcmcia_socket0] 0 ------------[ cut here ]------------ WARNING: at include/linux/kref.h:41 kobject_get+0x28/0x50() Modules linked in: ucb1x00_core Backtrace: [<c0212090>] (dump_backtrace+0x0/0x110) from [<c04799dc>] (dump_stack+0x18/0x1c) [<c04799c4>] (dump_stack+0x0/0x1c) from [<c021cba0>] (warn_slowpath_common+0x50/0x68) [<c021cb50>] (warn_slowpath_common+0x0/0x68) from [<c021cbdc>] (warn_slowpath_null+0x24/0x28) [<c021cbb8>] (warn_slowpath_null+0x0/0x28) from [<c0335374>] (kobject_get+0x28/0x50) [<c033534c>] (kobject_get+0x0/0x50) from [<c03804f4>] (get_device+0x1c/0x24) [<c0388c90>] (dpm_complete+0x0/0x1a0) from [<c0389cc0>] (dpm_resume_end+0x1c/0x20) ... Looking at commit 7b24e7988263 ("pcmcia: split up central event handler"), the following change was made to cs.c: return 0; } #endif - - send_event(skt, CS_EVENT_PM_RESUME, CS_EVENT_PRI_LOW); + if (!(skt->state & SOCKET_CARDBUS) && (skt->callback)) + skt->callback->early_resume(skt); return 0; } And the corresponding change in ds.c is from: -static int ds_event(struct pcmcia_socket *skt, event_t event, int priority) -{ - struct pcmcia_socket *s = pcmcia_get_socket(skt); ... - switch (event) { ... - case CS_EVENT_PM_RESUME: - if (verify_cis_cache(skt) != 0) { - dev_dbg(&skt->dev, "cis mismatch - different card\n"); - /* first, remove the card */ - ds_event(skt, CS_EVENT_CARD_REMOVAL, CS_EVENT_PRI_HIGH); - mutex_lock(&s->ops_mutex); - destroy_cis_cache(skt); - kfree(skt->fake_cis); - skt->fake_cis = NULL; - s->functions = 0; - mutex_unlock(&s->ops_mutex); - /* now, add the new card */ - ds_event(skt, CS_EVENT_CARD_INSERTION, - CS_EVENT_PRI_LOW); - } - break; ... - } - pcmcia_put_socket(s); - return 0; -} /* ds_event */ to: +static int pcmcia_bus_early_resume(struct pcmcia_socket *skt) +{ + if (!verify_cis_cache(skt)) { + pcmcia_put_socket(skt); + return 0; + } + dev_dbg(&skt->dev, "cis mismatch - different card\n"); + /* first, remove the card */ + pcmcia_bus_remove(skt); + mutex_lock(&skt->ops_mutex); + destroy_cis_cache(skt); + kfree(skt->fake_cis); + skt->fake_cis = NULL; + skt->functions = 0; + mutex_unlock(&skt->ops_mutex); + /* now, add the new card */ + pcmcia_bus_add(skt); + return 0; +} As can be seen, the original function called pcmcia_get_socket() and pcmcia_put_socket() around the guts, whereas the replacement code calls pcmcia_put_socket() only in one path. This creates an imbalance in the refcounting. Testing with pcmcia_put_socket() put removed shows that the bug is gone: dpm_suspend: c1a10998 [pcmcia_socket0] 5 dpm_suspend_noirq: c1a10998 [pcmcia_socket0] 5 dpm_resume_noirq: c1a10998 [pcmcia_socket0] 5 dpm_resume: c1a10998 [pcmcia_socket0] 5 dpm_complete: c1a10998 [pcmcia_socket0] 5 Tested-by: Russell King <rmk+kernel@arm.linux.org.uk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk> Cc: Dominik Brodowski <linux@dominikbrodowski.net> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-08mm: fix UP THP spin_is_locked BUGsHugh Dickins
Fix CONFIG_TRANSPARENT_HUGEPAGE=y CONFIG_SMP=n CONFIG_DEBUG_VM=y CONFIG_DEBUG_SPINLOCK=n kernel: spin_is_locked() is then always false, and so triggers some BUGs in Transparent HugePage codepaths. asm-generic/bug.h mentions this problem, and provides a WARN_ON_SMP(x); but being too lazy to add VM_BUG_ON_SMP, BUG_ON_SMP, WARN_ON_SMP_ONCE, VM_WARN_ON_SMP_ONCE, just test NR_CPUS != 1 in the existing VM_BUG_ONs. Signed-off-by: Hugh Dickins <hughd@google.com> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-08drivers/leds/leds-lm3530.c: fix setting pltfm->als_vmaxAxel Lin
In current code, pltfm->als_vmin is set to LM3530_ALS_WINDOW_mV and pltfm->als_vmax is 0. This does not make sense. I think what we want here is setting pltfm->als_vmax to LM3530_ALS_WINDOW_mV. Both als_vmin and als_vmax local variables will be set to pltfm->als_vmin and pltfm->als_vmax by a few lines latter. Thus also remove a redundant assignment for als_vmin and als_vmax in this patch. Signed-off-by: Axel Lin <axel.lin@gmail.com> Cc: Shreshtha Kumar Sahu <shreshthakumar.sahu@stericsson.com> Acked-by: Milo(Woogyom) Kim <milo.kim@ti.com> Tested-by: Milo(Woogyom) Kim <milo.kim@ti.com> Cc: Richard Purdie <rpurdie@rpsys.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-08mm: compaction: check for overlapping nodes during isolation for migrationMel Gorman
When isolating pages for migration, migration starts at the start of a zone while the free scanner starts at the end of the zone. Migration avoids entering a new zone by never going beyond the free scanned. Unfortunately, in very rare cases nodes can overlap. When this happens, migration isolates pages without the LRU lock held, corrupting lists which will trigger errors in reclaim or during page free such as in the following oops BUG: unable to handle kernel NULL pointer dereference at 0000000000000008 IP: [<ffffffff810f795c>] free_pcppages_bulk+0xcc/0x450 PGD 1dda554067 PUD 1e1cb58067 PMD 0 Oops: 0000 [#1] SMP CPU 37 Pid: 17088, comm: memcg_process_s Tainted: G X RIP: free_pcppages_bulk+0xcc/0x450 Process memcg_process_s (pid: 17088, threadinfo ffff881c2926e000, task ffff881c2926c0c0) Call Trace: free_hot_cold_page+0x17e/0x1f0 __pagevec_free+0x90/0xb0 release_pages+0x22a/0x260 pagevec_lru_move_fn+0xf3/0x110 putback_lru_page+0x66/0xe0 unmap_and_move+0x156/0x180 migrate_pages+0x9e/0x1b0 compact_zone+0x1f3/0x2f0 compact_zone_order+0xa2/0xe0 try_to_compact_pages+0xdf/0x110 __alloc_pages_direct_compact+0xee/0x1c0 __alloc_pages_slowpath+0x370/0x830 __alloc_pages_nodemask+0x1b1/0x1c0 alloc_pages_vma+0x9b/0x160 do_huge_pmd_anonymous_page+0x160/0x270 do_page_fault+0x207/0x4c0 page_fault+0x25/0x30 The "X" in the taint flag means that external modules were loaded but but is unrelated to the bug triggering. The real problem was because the PFN layout looks like this Zone PFN ranges: DMA 0x00000010 -> 0x00001000 DMA32 0x00001000 -> 0x00100000 Normal 0x00100000 -> 0x01e80000 Movable zone start PFN for each node early_node_map[14] active PFN ranges 0: 0x00000010 -> 0x0000009b 0: 0x00000100 -> 0x0007a1ec 0: 0x0007a354 -> 0x0007a379 0: 0x0007f7ff -> 0x0007f800 0: 0x00100000 -> 0x00680000 1: 0x00680000 -> 0x00e80000 0: 0x00e80000 -> 0x01080000 1: 0x01080000 -> 0x01280000 0: 0x01280000 -> 0x01480000 1: 0x01480000 -> 0x01680000 0: 0x01680000 -> 0x01880000 1: 0x01880000 -> 0x01a80000 0: 0x01a80000 -> 0x01c80000 1: 0x01c80000 -> 0x01e80000 The fix is straight-forward. isolate_migratepages() has to make a similar check to isolate_freepage to ensure that it never isolates pages from a zone it does not hold the LRU lock for. This was discovered in a 3.0-based kernel but it affects 3.1.x, 3.2.x and current mainline. Signed-off-by: Mel Gorman <mgorman@suse.de> Acked-by: Michal Nazarewicz <mina86@mina86.com> Cc: <stable@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-08nilfs2: avoid overflowing segment numbers in nilfs_ioctl_clean_segments()Xi Wang
nsegs is read from userspace. Limit its value and avoid overflowing nsegs * sizeof(__u64) in the subsequent call to memdup_user(). This patch complements 481fe17e973fb9 ("nilfs2: potential integer overflow in nilfs_ioctl_clean_segments()"). Signed-off-by: Xi Wang <xi.wang@gmail.com> Cc: Haogang Chen <haogangchen@gmail.com> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-08Merge tag 'sound-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound sound fixes #2 for 3.3-rc3 A collection of small fixes, mostly for regressions. In addition, a few ASoC wm8994 updates are included, too. * tag 'sound-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: ASoC: wm8994: Disable line output discharge prior to ramping VMID ASoC: wm8994: Fix typo in VMID ramp setting ALSA: oxygen, virtuoso: fix exchanged L/R volumes of aux and CD inputs ALSA: usb-audio: add Edirol UM-3G support ALSA: hda - add support for Uniwill ECS M31EI notebook ALSA: hda - Fix error handling in patch_ca0132.c ASoC: wm8994: Enabling VMID should take a runtime PM reference ALSA: hda/realtek - Fix a wrong condition ALSA: emu8000: Remove duplicate linux/moduleparam.h include from emu8000_patch.c ALSA: hda/realtek - Add missing Bass and CLFE as vmaster slaves ASoC: wm_hubs: Correct line input to line output 2 paths ASoC: cs42l73: Fix Output [X|A|V]SP_SCLK Sourcing Mode setting for master mode ASoC: wm8962: Fix word length configuration ASoC: core: Better support for idle_bias_off suspend ignores ASoC: wm8994: Remove ASoC level register cache sync ASoC: wm_hubs: Fix routing of input PGAs to line output mixer
2012-02-08Merge tag 'asoc-3.3' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus A few small WM8994 updates to go on top of the previous lot of things that were sent. They collide with some -next work so I'd really like to get them into 3.3-rc3 if possible to merge back up into the -next code. All driver specific and unexciting in the grand scheme of things.
2012-02-08ASoC: wm8994: Disable line output discharge prior to ramping VMIDMark Brown
2012-02-08ASoC: wm8994: Fix typo in VMID ramp settingMark Brown
The VMID ramp rate is supposed to be 0x3, not 11b. Fix that. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-02-08ALSA: oxygen, virtuoso: fix exchanged L/R volumes of aux and CD inputsClemens Ladisch
The driver accidentally exchanged the left/right fields for stereo AC'97 mixer registers. This affected only the aux and CD inputs because the line input bypasses the AC'97 codec and the mic input is mono; cards without AC'97 (Xonar DS/DG/HDAV Slim, HG2PCI, HiFier) were not affected. Reported-and-tested-by: Abby Cedar <abbycedar@yahoo.com.au> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: 2.6.31+ <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-08ALSA: usb-audio: add Edirol UM-3G supportClemens Ladisch
Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-07Merge tag 'fbdev-fixes-for-3.3-1' of git://github.com/schandinat/linux-2.6Linus Torvalds
fbdev fixes for 3.3 It includes: - compile fix for fsl-diu-fb - fix for a suspend/resume issue in atmel_lcdfb - fix for a suspend/resume issue in OMAP - workaround for a hardware bug to avoid physical damage in OMAP - really trivial dead code removal in intelfb * tag 'fbdev-fixes-for-3.3-1' of git://github.com/schandinat/linux-2.6: atmel_lcdfb: fix usage of CONTRAST_CTR in suspend/resume intelfb: remove some dead code drivers/video: compile fixes for fsl-diu-fb.c OMAPDSS: HDMI: PHY burnout fix OMAP: 4430SDP/Panda: add HDMI HPD gpio OMAP: 4430SDP/Panda: setup HDMI GPIO muxes OMAPDSS: remove wrong HDMI HPD muxing OMAP: 4430SDP/Panda: rename HPD GPIO to CT_CP_HPD OMAP: 4430SDP/Panda: use gpio_free_array to free HDMI gpios OMAPDSS: use sync versions of pm_runtime_put
2012-02-07checkpatch: Warn on code with 6+ tab indentationJoe Perches
Overly indented code should be refactored. Suggest refactoring excessive indentation of of if/else/for/do/while/switch statements. For example: $ cat t.c #include <stdio.h> #include <stdlib.h> int main(int argc, char **argv) { if (1) if (2) if (3) if (4) if (5) if (6) if (7) if (8) ; return 0; } $ ./scripts/checkpatch.pl -f t.c WARNING: Too many leading tabs - consider code refactoring #12: FILE: t.c:12: + if (6) WARNING: Too many leading tabs - consider code refactoring #13: FILE: t.c:13: + if (7) WARNING: Too many leading tabs - consider code refactoring #14: FILE: t.c:14: + if (8) total: 0 errors, 3 warnings, 17 lines checked t.c has style problems, please review. If any of these errors are false positives, please report them to the maintainer, see CHECKPATCH in MAINTAINERS. Signed-off-by: Joe Perches <joe@perches.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-07Merge tag 'v3.3-rc2' into depends/rmk/for-armsocOlof Johansson
There were conflicts between fixes going in after 3.3-rc1 and Russell's stable arm-soc base branch. Resolving it in the dependency branch so that each topic branch shares the same resolution. Conflicts: arch/arm/mach-at91/at91cap9.c arch/arm/mach-at91/at91sam9g45.c
2012-02-07Merge tag 'ib-srpt-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband Cleanups and error path fixes for the new SRP (SCSI RDMA protocol) target. * tag 'ib-srpt-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/roland/infiniband: IB/srpt: Don't return freed pointer from srpt_alloc_ioctx_ring() IB/srpt: Fix ERR_PTR() vs. NULL checking confusion IB/srpt: Remove unneeded <linux/version.h> include IB/srpt: Use ARRAY_SIZE() instead of open-coding IB/srpt: Use DEFINE_SPINLOCK()/LIST_HEAD()
2012-02-07Merge tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhostLinus Torvalds
arch: fix ioport mapping on mips,sh Kevin Cernekee reported that recent cleanup that replaced pci_iomap with a generic function failed to take into account the differences in io port handling on mips and sh architectures. Rather than revert the changes reintroducing the code duplication, this patchset fixes this by adding ability for architectures to override ioport mapping for pci devices. Signed-off-by: Michael S. Tsirkin <mst@redhat.com> * tag 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mst/vhost: sh: use the the PCI channels's io_map_base mips: use the the PCI controller's io_map_base lib: add NO_GENERIC_PCI_IOPORT_MAP
2012-02-07ACPI: remove duplicated lines of merging problems with acpi_processor_addYinghai Lu
Those lines have two copies. Signed-off-by: Yinghai Lu <yinghai@kernel.org> Cc: Thomas Renninger <trenn@suse.de> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-02-07Merge git://git.samba.org/sfrench/cifs-2.6Linus Torvalds
* git://git.samba.org/sfrench/cifs-2.6: cifs: Fix oops in session setup code for null user mounts [CIFS] Update cifs Kconfig title to match removal of experimental dependency cifs: fix printk format warnings cifs: check offset in decode_ntlmssp_challenge() cifs: NULL dereference on allocation failure
2012-02-07Merge branch 'upstream-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid * 'upstream-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/hid: HID: wiimote: fix invalid power_supply_powers call HID: wacom: Fix invalid power_supply_powers calls HID: hyperv: Properly disconnect the input device HID: usbhid: fix dead lock between open and disconect
2012-02-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: mfd: Avoid twl6040-codec PLL reconfiguration when not needed mfd: Store twl6040-codec mclk configuration
2012-02-07ALSA: hda - add support for Uniwill ECS M31EI notebookJaroslav Kysela
This hardware requires same fixup for the node 0x0f like Asus A6Rp. More information: https://bugzilla.redhat.com/show_bug.cgi?id=785417 Signed-off-by: Jaroslav Kysela <perex@perex.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-07HID: wiimote: fix invalid power_supply_powers callJiri Kosina
Analogically to d7cb3dbd1 ("HID: wacom: Fix invalid power_supply_powers calls"), fix also the same occurence in wiimote driver. Reported-by: przemo@firszt.eu Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-02-07ALSA: hda - Fix error handling in patch_ca0132.cTakashi Iwai
In patch_ca0132.c, the error returned from chipio_write() isn't checked always. Also, the power-up/down sequence isn't tracked properly in some error paths. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-02-07Merge tag 'asoc-3.3' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-linus The only particularly remarkable change here is the one for handling of the Android suspend ignore code for idle_bias_off CODECs. That one is actually a regression fix as some of the new power savings that have been introduced confused the suspend ignore code, making devices that are active for non-audio reasons look like they are idle causing them to be suspended instead of being kept active.
2012-02-07target: Fix unsupported WRITE_SAME sense payloadMartin Svec
This patch fixes a bug in target-core where unsupported WRITE_SAME ops from a target_check_write_same_discard() failure was incorrectly returning CHECK_CONDITION w/ TCM_INVALID_CDB_FIELD sense data. This was causing some clients to not properly fall back, so go ahead and use the correct TCM_UNSUPPORTED_SCSI_OPCODE sense for this case. Reported-by: Martin Svec <martin.svec@zoner.cz> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-02-07iscsi: use IP_FREEBIND socket optionDax Kelson
Use IP_FREEBIND socket option so that iscsi portal configuration with explicit IP addresses can happen during boot, before network interfaces have been assigned IPs. This is especially important on systemd based Linux boxes where system boot happens asynchronously and non-trivial configuration must be done to get targetcli.service to start synchronously after the network is configured. Reference: http://lists.fedoraproject.org/pipermail/devel/2011-October/158025.html Signed-off-by: Dax Kelson <dkelson@gurulabs.com> Cc: "Nicholas A. Bellinger" <nab@linux-iscsi.org> Cc: "Andy Grover" <agrover@redhat.com> Cc: "Lennart Poettering" <lennart@poettering.net> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-02-07iblock: fix handling of large requestsChristoph Hellwig
Requesting to many bvecs upsets bio_alloc_bioset, so limit the number we ask for to the amount it can handle. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
