2011-02-24usb: musb: core: set has_tt flagFelipe Balbi
MUSB is a non-standard host implementation which can handle all speeds with the same core. We need to set has_tt flag after commit d199c96d41d80a567493e12b8e96ea056a1350c1 (USB: prevent buggy hubs from crashing the USB stack) in order for MUSB HCD to continue working. Signed-off-by: Felipe Balbi <balbi@ti.com> Cc: stable <stable@kernel.org> Cc: Alan Stern <stern@rowland.harvard.edu> Tested-by: Michael Jones <michael.jones@matrix-vision.de> Tested-by: Alexander Holler <holler@ahsoftware.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-22USB: xhci: mark local functions as staticDmitry Torokhov
Functions that are not used outsde of the module they are defined should be marked as static. Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2011-02-20USB: xhci: fix couple sparse annotationsDmitry Torokhov
There is no point in casting to (void *) when setting up xhci->ir_set as it only makes us lose __iomem annotation and makes sparse unhappy. OTOH we do need to cast to (void *) when calculating xhci->dba from offset, but since it is IO memory we need to annotate it as such. Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2011-02-20USB: xhci: rework xhci_print_ir_set() to get ir set from xhci itselfDmitry Torokhov
xhci->ir_set points to __iomem region, but xhci_print_ir_set accepts plain struct xhci_intr_reg * causing multiple sparse warning at call sites and inside the fucntion when we try to read that memory. Instead of adding __iomem qualifier to the argument let's rework the function so it itself gets needed register set from xhci and prints it. Signed-off-by: Dmitry Torokhov <dtor@vmware.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com>
2011-02-20USB: Reset USB 3.0 devices on (re)discoveryLuben Tuikov
If the device isn't reset, the XHCI HCD sends SET ADDRESS to address 0 while the device is already in Addressed state, and the request is dropped on the floor as it is addressed to the default address. This sequence of events, which this patch fixes looks like this: usb_reset_and_verify_device() hub_port_init() hub_set_address() SET_ADDRESS to 0 with 1 usb_get_device_descriptor(udev, 8) usb_get_device_descriptor(udev, 18) descriptors_changed() --> goto re_enumerate: hub_port_logical_disconnect() kick_khubd() And then: hub_events() hub_port_connect_change() usb_disconnect() usb_disable_device() new device struct sets device state to Powered choose_address() hub_port_init() <-- no reset, but SET ADDRESS to 0 with 1, timeout! The solution is to always reset the device in hub_port_init() to put it in a known state. Note from Sarah Sharp: This patch should be queued for stable trees all the way back to 2.6.34, since that was the first kernel that supported configured device reset. The code this patch touches has been there since 2.6.32, but the bug would never be hit before 2.6.34 because the xHCI driver would completely reject an attempt to reset a configured device under xHCI. Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@kernel.org
2011-02-20xhci: Fix an error in count_sg_trbs_needed()Paul Zimmerman
The expression while (running_total < sg_dma_len(sg)) does not take into account that the remaining data length can be less than sg_dma_len(sg). In that case, running_total can end up being greater than the total data length, so an extra TRB is counted. Changing the expression to while (running_total < sg_dma_len(sg) && running_total < temp) fixes that. This patch should be queued for stable kernels back to 2.6.31. Signed-off-by: Paul Zimmerman <paulz@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@kernel.org
2011-02-20xhci: Fix errors in the running total calculations in the TRB mathPaul Zimmerman
Calculations like running_total = TRB_MAX_BUFF_SIZE - (sg_dma_address(sg) & (TRB_MAX_BUFF_SIZE - 1)); if (running_total != 0) num_trbs++; are incorrect, because running_total can never be zero, so the if() expression will never be true. I think the intention was that running_total be in the range of 0 to TRB_MAX_BUFF_SIZE-1, not 1 to TRB_MAX_BUFF_SIZE. So adding a running_total &= TRB_MAX_BUFF_SIZE - 1; fixes the problem. This patch should be queued for stable kernels back to 2.6.31. Signed-off-by: Paul Zimmerman <paulz@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@kernel.org
2011-02-20xhci: Clarify some expressions in the TRB mathPaul Zimmerman
This makes it easier to spot some problems, which will be fixed by the next patch in the series. Also change dev_dbg to dev_err in check_trb_math(), so any math errors will be visible even when running with debug disabled. Note: This patch changes the expressions containing "((1 << TRB_MAX_BUFF_SHIFT) - 1)" to use the equivalent "(TRB_MAX_BUFF_SIZE - 1)". No change in behavior is intended for those expressions. This patch should be queued for stable kernels back to 2.6.31. Signed-off-by: Paul Zimmerman <paulz@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@kernel.org
2011-02-20xhci: Avoid BUG() in interrupt contextPaul Zimmerman
Change the BUGs in xhci_find_new_dequeue_state() to WARN_ONs, to avoid bringing down the box if one of them is hit This patch should be queued for stable kernels back to 2.6.31. Signed-off-by: Paul Zimmerman <paulz@synopsys.com> Signed-off-by: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: stable@kernel.org
2011-02-17Revert "USB: Reset USB 3.0 devices on (re)discovery"Greg Kroah-Hartman
This reverts commit 637d11bfb814637ec7b81e878db3ffea6408a89a. Sarah wants to tweak it some more before it's applied to the tree. Cc: Luben Tuikov <ltuikov@yahoo.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17Merge branch 'for-greg' of git://gitorious.org/usb/usb into usb-linusGreg Kroah-Hartman
* 'for-greg' of git://gitorious.org/usb/usb: usb: musb: omap2430: fix kernel panic on reboot usb: musb: fix build breakage
2011-02-17USB: musb: omap2430: fix kernel panic on rebootJohan Hovold
Cancel idle timer in musb_platform_exit. The idle timer could trigger after clock had been disabled leading to kernel panic when MUSB_DEVCTL is accessed in musb_do_idle on 2.6.37. The fault below is no longer triggered on 2.6.38-rc4 (clock is disabled later, and only if compiled as a module, and the offending memory access has moved) but the timer should be cancelled nonetheless. Rebooting... musb_hdrc musb_hdrc: remove, state 4 usb usb1: USB disconnect, address 1 musb_hdrc musb_hdrc: USB bus 1 deregistered Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa0ab060 Internal error: : 1028 [#1] PREEMPT last sysfs file: /sys/kernel/uevent_seqnum Modules linked in: CPU: 0 Not tainted (2.6.37+ #6) PC is at musb_do_idle+0x24/0x138 LR is at musb_do_idle+0x18/0x138 pc : [<c02377d8>] lr : [<c02377cc>] psr: 80000193 sp : cf2bdd80 ip : cf2bdd80 fp : c048a20c r10: c048a60c r9 : c048a40c r8 : cf85e110 r7 : cf2bc000 r6 : 40000113 r5 : c0489800 r4 : cf85e110 r3 : 00000004 r2 : 00000006 r1 : fa0ab000 r0 : cf8a7000 Flags: Nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user Control: 10c5387d Table: 8faac019 DAC: 00000015 Process reboot (pid: 769, stack limit = 0xcf2bc2f0) Stack: (0xcf2bdd80 to 0xcf2be000) dd80: 00000103 c0489800 c02377b4 c005fa34 00000555 c0071a8c c04a3858 cf2bdda8 dda0: 00000555 c048a00c cf2bdda8 cf2bdda8 1838beb0 00000103 00000004 cf2bc000 ddc0: 00000001 00000001 c04896c8 0000000a 00000000 c005ac14 00000001 c003f32c dde0: 00000000 00000025 00000000 cf2bc000 00000002 00000001 cf2bc000 00000000 de00: 00000001 c005ad08 cf2bc000 c002e07c c03ec039 ffffffff fa200000 c0033608 de20: 00000001 00000000 cf852c14 cf81f200 c045b714 c045b708 cf2bc000 c04a37e8 de40: c0033c04 cf2bc000 00000000 00000001 cf2bde68 cf2bde68 c01c3abc c004f7d8 de60: 60000013 ffffffff c0033c04 00000000 01234567 fee1dead 00000000 c006627c de80: 00000001 c00662c8 28121969 c00663ec cfa38c40 cf9f6a00 cf2bded0 cf9f6a0c dea0: 00000000 cf92f000 00008914 c02cd284 c04a55c8 c028b398 c00715c0 becf24a8 dec0: 30687465 00000000 00000000 00000000 00000002 1301a8c0 00000000 00000000 dee0: 00000002 1301a8c0 00000000 00000000 c0450494 cf527920 00011f10 cf2bdf08 df00: 00011f10 cf2bdf10 00011f10 cf2bdf18 c00f0b44 c004f7e8 cf2bdf18 cf2bdf18 df20: 00011f10 cf2bdf30 00011f10 cf2bdf38 cf401300 cf486100 00000008 c00d2b28 df40: 00011f10 cf401300 00200200 c00d3388 00011f10 cfb63a88 cfb63a80 c00c2f08 df60: 00000000 00000000 cfb63a80 00000000 cf0a3480 00000006 c0033c04 cfb63a80 df80: 00000000 c00c0104 00000003 cf0a3480 cfb63a80 00000000 00000001 00000004 dfa0: 00000058 c0033a80 00000000 00000001 fee1dead 28121969 01234567 00000000 dfc0: 00000000 00000001 00000004 00000058 00000001 00000001 00000000 00000001 dfe0: 4024d200 becf2cb0 00009210 4024d218 60000010 fee1dead 00000000 00000000 [<c02377d8>] (musb_do_idle+0x24/0x138) from [<c005fa34>] (run_timer_softirq+0x1a8/0x26) [<c005fa34>] (run_timer_softirq+0x1a8/0x26c) from [<c005ac14>] (__do_softirq+0x88/0x13) [<c005ac14>] (__do_softirq+0x88/0x138) from [<c005ad08>] (irq_exit+0x44/0x98) [<c005ad08>] (irq_exit+0x44/0x98) from [<c002e07c>] (asm_do_IRQ+0x7c/0xa0) [<c002e07c>] (asm_do_IRQ+0x7c/0xa0) from [<c0033608>] (__irq_svc+0x48/0xa8) Exception stack(0xcf2bde20 to 0xcf2bde68) de20: 00000001 00000000 cf852c14 cf81f200 c045b714 c045b708 cf2bc000 c04a37e8 de40: c0033c04 cf2bc000 00000000 00000001 cf2bde68 cf2bde68 c01c3abc c004f7d8 de60: 60000013 ffffffff [<c0033608>] (__irq_svc+0x48/0xa8) from [<c004f7d8>] (sub_preempt_count+0x0/0xb8) Code: ebf86030 e5940098 e594108c e5902010 (e5d13060) ---[ end trace 3689c0d808f9bf7c ]--- Kernel panic - not syncing: Fatal exception in interrupt Cc: stable <stable@kernel.org> Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17sierra: add new ID for Airprime/Sierra USB IP modemJon Thomas
I picked up a new Sierra usb 308 (At&t Shockwave) on 2/2011 and the vendor code is 0x0f3d Looking up vendor and product id's I see: 0f3d Airprime, Incorporated 0112 CDMA 1xEVDO PC Card, PC 5220 Sierra and Airprime are somehow related and I'm guessing the At&t usb 308 might be have some common hardware with the AirPrime SL809x. Signed-off-by: Jon Thomas <jthomas@redhat.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17USB: serial/usb_wwan, fix tty NULL dereferenceJiri Slaby
tty_port_tty_get may return without any problems NULL. Handle this case and do not oops in usb_wwan_indat_callback by dereferencing it. The oops: Unable to handle kernel paging request for data at address 0x000000d8 Faulting instruction address: 0xc0175b3c Oops: Kernel access of bad area, sig: 11 [#1] PowerPC 40x Platform last sysfs file: /sys/devices/pci0000:00/0000:00:00.0/0000:01:00.0/0000:02:09.2/usb1/idVendor Modules linked in: NIP: c0175b3c LR: c0175e7c CTR: c0215c90 REGS: c77f7d50 TRAP: 0300 Not tainted (2.6.37-rc5) MSR: 00021030 <ME,CE,IR,DR> CR: 88482028 XER: 2000005f DEAR: 000000d8, ESR: 00000000 TASK = c7141b90[1149] 'wvdial' THREAD: c2750000 GPR00: 00021030 c77f7e00 c7141b90 00000000 0000000e 00000000 0000000e c0410680 GPR08: c683db00 00000000 00000001 c03c81f8 88482028 10073ef4 ffffffb9 ffffff94 GPR16: 00000000 fde036c0 00200200 00100100 00000001 ffffff8d c34fabcc 00000000 GPR24: c71120d4 00000000 00000000 0000000e 00021030 00000000 00000000 0000000e NIP [c0175b3c] tty_buffer_request_room+0x2c/0x194 LR [c0175e7c] tty_insert_flip_string_fixed_flag+0x3c/0xb0 Call Trace: [c77f7e00] [00000003] 0x3 (unreliable) [c77f7e30] [c0175e7c] tty_insert_flip_string_fixed_flag+0x3c/0xb0 [c77f7e60] [c0215df4] usb_wwan_indat_callback+0x164/0x170 ... References: https://bugzilla.kernel.org/show_bug.cgi?id=24582 Cc: Amit Shah <amitshah@gmx.net> Cc: baoyb <baoyb@avit.org.cn> Signed-off-by: Jiri Slaby <jslaby@suse.cz> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17USB: Reset USB 3.0 devices on (re)discoveryLuben Tuikov
If the device isn't reset, the XHCI HCD sends SET ADDRESS to address 0 while the device is already in Addressed state, and the request is dropped on the floor as it is addressed to the default address. This sequence of events, which this patch fixes looks like this: usb_reset_and_verify_device() hub_port_init() hub_set_address() SET_ADDRESS to 0 with 1 usb_get_device_descriptor(udev, 8) usb_get_device_descriptor(udev, 18) descriptors_changed() --> goto re_enumerate: hub_port_logical_disconnect() kick_khubd() And then: hub_events() hub_port_connect_change() usb_disconnect() usb_disable_device() new device struct sets device state to Powered choose_address() hub_port_init() <-- no reset, but SET ADDRESS to 0 with 1, timeout! The solution is to always reset the device in hub_port_init() to put it in a known state. Signed-off-by: Luben Tuikov <ltuikov@yahoo.com> Cc: Sarah Sharp <sarah.a.sharp@linux.intel.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17USB: Add quirk for Samsung Android phone modemMaciej Szmigiero
My Galaxy Spica needs this quirk when in modem mode, otherwise it causes endless USB bus resets and is unusable in this mode. Unfortunately Samsung decided to reuse ID of its old CDMA phone SGH-I500 for the modem part. That's why in addition to this patch the visor driver must be prevented from binding to SPH-I500 ID, so ACM driver can do that. Signed-off-by: Maciej Szmigiero <mhej@o2.pl> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17USB: Add Samsung SGH-I500/Android modem ID switch to visor driverMaciej Szmigiero
[USB]Add Samsung SGH-I500/Android modem ID switch to visor driver Samsung decided to reuse USB ID of its old CDMA phone SGH-I500 for the modem part of some of their Android phones. At least Galaxy Spica is affected. This modem needs ACM driver and does not work with visor driver which binds the conflicting ID for SGH-I500. Because SGH-I500 is pretty an old hardware its best to add switch to visor driver in cause somebody still wants to use that phone with Linux. Note that this is needed only when using the Android phone as modem, not in USB storage or ADB mode. Signed-off-by: Maciej Szmigiero <mhej@o2.pl> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17USB: add quirks entry for Keytouch QWERTY PanelAlan Stern
This patch (as1448) adds a quirks entry for the Keytouch QWERTY Panel firmware, used in the IEC 60945 keyboard. This device crashes during enumeration when the computer asks for its configuration string descriptor. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Tested-by: kholis <nur.kholis.majid@gmail.com> CC: <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-02-17usb: musb: omap2430: fix kernel panic on rebootJohan Hovold
Cancel idle timer in musb_platform_exit. The idle timer could trigger after clock had been disabled leading to kernel panic when MUSB_DEVCTL is accessed in musb_do_idle on 2.6.37. The fault below is no longer triggered on 2.6.38-rc4 (clock is disabled later, and only if compiled as a module, and the offending memory access has moved) but the timer should be cancelled nonetheless. Rebooting... musb_hdrc musb_hdrc: remove, state 4 usb usb1: USB disconnect, address 1 musb_hdrc musb_hdrc: USB bus 1 deregistered Unhandled fault: external abort on non-linefetch (0x1028) at 0xfa0ab060 Internal error: : 1028 [#1] PREEMPT last sysfs file: /sys/kernel/uevent_seqnum Modules linked in: CPU: 0 Not tainted (2.6.37+ #6) PC is at musb_do_idle+0x24/0x138 LR is at musb_do_idle+0x18/0x138 pc : [<c02377d8>] lr : [<c02377cc>] psr: 80000193 sp : cf2bdd80 ip : cf2bdd80 fp : c048a20c r10: c048a60c r9 : c048a40c r8 : cf85e110 r7 : cf2bc000 r6 : 40000113 r5 : c0489800 r4 : cf85e110 r3 : 00000004 r2 : 00000006 r1 : fa0ab000 r0 : cf8a7000 Flags: Nzcv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user Control: 10c5387d Table: 8faac019 DAC: 00000015 Process reboot (pid: 769, stack limit = 0xcf2bc2f0) Stack: (0xcf2bdd80 to 0xcf2be000) dd80: 00000103 c0489800 c02377b4 c005fa34 00000555 c0071a8c c04a3858 cf2bdda8 dda0: 00000555 c048a00c cf2bdda8 cf2bdda8 1838beb0 00000103 00000004 cf2bc000 ddc0: 00000001 00000001 c04896c8 0000000a 00000000 c005ac14 00000001 c003f32c dde0: 00000000 00000025 00000000 cf2bc000 00000002 00000001 cf2bc000 00000000 de00: 00000001 c005ad08 cf2bc000 c002e07c c03ec039 ffffffff fa200000 c0033608 de20: 00000001 00000000 cf852c14 cf81f200 c045b714 c045b708 cf2bc000 c04a37e8 de40: c0033c04 cf2bc000 00000000 00000001 cf2bde68 cf2bde68 c01c3abc c004f7d8 de60: 60000013 ffffffff c0033c04 00000000 01234567 fee1dead 00000000 c006627c de80: 00000001 c00662c8 28121969 c00663ec cfa38c40 cf9f6a00 cf2bded0 cf9f6a0c dea0: 00000000 cf92f000 00008914 c02cd284 c04a55c8 c028b398 c00715c0 becf24a8 dec0: 30687465 00000000 00000000 00000000 00000002 1301a8c0 00000000 00000000 dee0: 00000002 1301a8c0 00000000 00000000 c0450494 cf527920 00011f10 cf2bdf08 df00: 00011f10 cf2bdf10 00011f10 cf2bdf18 c00f0b44 c004f7e8 cf2bdf18 cf2bdf18 df20: 00011f10 cf2bdf30 00011f10 cf2bdf38 cf401300 cf486100 00000008 c00d2b28 df40: 00011f10 cf401300 00200200 c00d3388 00011f10 cfb63a88 cfb63a80 c00c2f08 df60: 00000000 00000000 cfb63a80 00000000 cf0a3480 00000006 c0033c04 cfb63a80 df80: 00000000 c00c0104 00000003 cf0a3480 cfb63a80 00000000 00000001 00000004 dfa0: 00000058 c0033a80 00000000 00000001 fee1dead 28121969 01234567 00000000 dfc0: 00000000 00000001 00000004 00000058 00000001 00000001 00000000 00000001 dfe0: 4024d200 becf2cb0 00009210 4024d218 60000010 fee1dead 00000000 00000000 [<c02377d8>] (musb_do_idle+0x24/0x138) from [<c005fa34>] (run_timer_softirq+0x1a8/0x26) [<c005fa34>] (run_timer_softirq+0x1a8/0x26c) from [<c005ac14>] (__do_softirq+0x88/0x13) [<c005ac14>] (__do_softirq+0x88/0x138) from [<c005ad08>] (irq_exit+0x44/0x98) [<c005ad08>] (irq_exit+0x44/0x98) from [<c002e07c>] (asm_do_IRQ+0x7c/0xa0) [<c002e07c>] (asm_do_IRQ+0x7c/0xa0) from [<c0033608>] (__irq_svc+0x48/0xa8) Exception stack(0xcf2bde20 to 0xcf2bde68) de20: 00000001 00000000 cf852c14 cf81f200 c045b714 c045b708 cf2bc000 c04a37e8 de40: c0033c04 cf2bc000 00000000 00000001 cf2bde68 cf2bde68 c01c3abc c004f7d8 de60: 60000013 ffffffff [<c0033608>] (__irq_svc+0x48/0xa8) from [<c004f7d8>] (sub_preempt_count+0x0/0xb8) Code: ebf86030 e5940098 e594108c e5902010 (e5d13060) ---[ end trace 3689c0d808f9bf7c ]--- Kernel panic - not syncing: Fatal exception in interrupt Cc: stable@kernel.org Signed-off-by: Johan Hovold <jhovold@gmail.com> Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-02-17usb: musb: fix build breakageFelipe Balbi
commit 0662481855c389b75a0a54c32870cc90563d80a9 (usb: musb: disable double buffering when it's broken), introduced a compile error when gadget API is disabled. Fix it. Signed-off-by: Felipe Balbi <balbi@ti.com>
2011-02-15Linux 2.6.38-rc5v2.6.38-rc5Linus Torvalds
2011-02-15Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/gerg/m68knommu: m68knommu: set flow handler for secondary interrupt controller of 5249 m68knommu: remove use of IRQ_FLG_LOCK from 68360 platform support m68knommu: fix dereference of port.tty m68knommu: add missing linker __modver section m68knommu: fix mis-named variable int set_irq_chip loop m68knommu: add optimize memmove() function m68k: remove arch specific non-optimized memcmp() m68knommu: fix use of un-defined _TIF_WORK_MASK m68knommu: Rename m548x_wdt.c to m54xx_wdt.c m68knommu: fix m548x_wdt.c compilation after headers renaming m68knommu: Remove dependencies on nonexistent M68KNOMMU
2011-02-16m68knommu: set flow handler for secondary interrupt controller of 5249Greg Ungerer
The secondary interrupt controller of the ColdFire 5249 code is not setting the edge triggered flow handler. Set it. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-02-16m68knommu: remove use of IRQ_FLG_LOCK from 68360 platform supportGreg Ungerer
The m68knommu arch does not define or use IRQ_FLG_LOCK in its irq subsystem. Remove obsolete use of it. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-02-16m68knommu: fix dereference of port.ttyGreg Ungerer
The struct_tty associated with a port is now a direct pointer from within the local private driver info struct. So fix all uses of it. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-02-16m68knommu: add missing linker __modver sectionGreg Ungerer
Add missing linker section __modver to fix: LD vmlinux /usr/local/bin/../m68k-uclinux/bin/ld.real: error: no memory region specified for loadable section `__modver' Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-02-16m68knommu: fix mis-named variable int set_irq_chip loopGreg Ungerer
Compiling for 68360 targets gives: CC arch/m68knommu/platform/68360/ints.o arch/m68knommu/platform/68360/ints.c: In function ‘init_IRQ’: arch/m68knommu/platform/68360/ints.c:135:16: error: ‘irq’ undeclared (first use in this function) arch/m68knommu/platform/68360/ints.c:135:16: note: each undeclared identifier is reported only once for each function it appears in Fix variable name used. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-02-16m68knommu: add optimize memmove() functionGreg Ungerer
Add an m68k/coldfire optimized memmove() function for the m68knommu arch. This is the same function as used by m68k. Simple speed tests show this is faster once buffers are larger than 4 bytes, and significantly faster on much larger buffers (4 times faster above about 100 bytes). This also goes part of the way to fixing a regression caused by commit ea61bc461d09e8d331a307916530aaae808c72a2 ("m68k/m68knommu: merge MMU and non-MMU string.h"), which breaks non-coldfire non-mmu builds (which is the 68x328 and 68360 families). They currently have no memmove() fucntion defined, since there was none in the m68knommu/lib functions. Signed-off-by: Greg Ungerer <gerg@uclinux.org>
2011-02-16m68k: remove arch specific non-optimized memcmp()Greg Ungerer
The m68k arch implements its own memcmp() function. It is not optimized in any way (it is the most strait forward coding of memcmp you can get). Remove it and use the kernels standard memcmp() implementation. This also goes part of the way to fixing a regression caused by commit ea61bc461d09e8d331a307916530aaae808c72a2 ("m68k/m68knommu: merge MMU and non-MMU string.h"), which breaks non-coldfire non-mmu builds (which is the 68x328 and 68360 families). They currently have no memcmp() function defined, since there is none in the m68knommu/lib functions. Signed-off-by: Greg Ungerer <gerg@uclinux.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
2011-02-15Merge branch 'drm-fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6 * 'drm-fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/airlied/drm-2.6: (27 commits) drm/radeon/kms: hopefully fix pll issues for real (v3) drm/radeon/kms: add bounds checking to avivo pll algo drm: fix wrong usages of drm_device in DRM Developer's Guide drm/radeon/kms: fix a few more atombios endian issues drm/radeon/kms: improve 6xx/7xx CS error output drm/radeon/kms: check AA resolve registers on r300 drm/radeon/kms: fix tracking of BLENDCNTL, COLOR_CHANNEL_MASK, and GB_Z on r300 drm/radeon/kms: use linear aligned for evergreen/ni bo blits drm/radeon/kms: use linear aligned for 6xx/7xx bo blits drm/radeon: fix race between GPU reset and TTM delayed delete thread. drm/radeon/kms: evergreen/ni big endian fixes (v2) drm/radeon/kms: 6xx/7xx big endian fixes drm/radeon/kms: atombios big endian fixes drm/radeon: 6xx/7xx non-kms endian fixes drm/radeon/kms: optimize CS state checking for r100->r500 drm: do not leak kernel addresses via /proc/dri/*/vma drm/radeon/kms: add connector table for mac g5 9600 radeon mkregtable: Add missing fclose() calls drm/radeon/kms: fix interlaced modes on dce4+ drm/radeon: fix memory debugging since d961db75ce86a84f1f04e91ad1014653ed7d9f46 ...
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: pci: use security_capable() when checking capablities during config space read
2011-02-15thp: prevent hugepages during args/env copying into the user stackAndrea Arcangeli
Transparent hugepages can only be created if rmap is fully functional. So we must prevent hugepages to be created while is_vma_temporary_stack() is true. This also optmizes away some harmless but unnecessary setting of khugepaged_scan.address and it switches some BUG_ON to VM_BUG_ON. Signed-off-by: Andrea Arcangeli <aarcange@redhat.com> Acked-by: Rik van Riel <riel@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-15Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: ACPI / Video: Probe for output switch method when searching video devices. ACPI / Wakeup: Enable button GPEs unconditionally during initialization ACPI / ACPICA: Avoid crashing if _PRW is defined for the root object ACPI: Fix acpi_os_read_memory() and acpi_os_write_memory() (v2)
2011-02-15Merge branch 'tools-release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6 * 'tools-release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-idle-2.6: tools: turbostat: style updates tools: turbostat: fix bitwise and operand
2011-02-15Merge branch 'iomem' into releaseLen Brown
2011-02-15Merge branch 'fixes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx * 'fixes' of git://git.kernel.org/pub/scm/linux/kernel/git/djbw/async_tx: (21 commits) dmaengine: add slave-dma maintainer dma: ipu_idmac: do not lose valid received data in the irq handler dmaengine: imx-sdma: fix up param for the last BD in sdma_prep_slave_sg() dmaengine: imx-sdma: correct sdmac->status in sdma_handle_channel_loop() dmaengine: imx-sdma: return sdmac->status in sdma_tx_status() dmaengine: imx-sdma: set sdmac->status to DMA_ERROR in err_out of sdma_prep_slave_sg() dmaengine: imx-sdma: remove IMX_DMA_SG_LOOP handling in sdma_prep_slave_sg() dmaengine i.MX dma: initialize dma capabilities outside channel loop dmaengine i.MX DMA: do not initialize chan_id field dmaengine i.MX dma: check sg entries for valid addresses and lengths dmaengine i.MX dma: set maximum segment size for our device dmaengine i.MX SDMA: reserve channel 0 by not registering it dmaengine i.MX SDMA: initialize dma capabilities outside channel loop dmaengine i.MX SDMA: do not initialize chan_id field dmaengine i.MX sdma: check sg entries for valid addresses and lengths dmaengine i.MX sdma: set maximum segment size for our device DMA: PL08x: fix channel pausing to timeout rather than lockup DMA: PL08x: fix infinite wait when terminating transfers dmaengine: imx-sdma: fix inconsistent naming in sdma_assign_cookie() dmaengine: imx-sdma: propagate error in sdma_probe() instead of returning 0 ...
2011-02-15Merge branch 'for-2.6.38' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.38' of git://linux-nfs.org/~bfields/linux: nfsd: break lease on unlink due to rename nfsd4: acquire only one lease per file nfsd4: modify fi_delegations under recall_lock nfsd4: remove unused deleg dprintk's. nfsd4: split lease setting into separate function nfsd4: fix leak on allocation error nfsd4: add helper function for lease setup nfsd4: split up nfsd_break_deleg_cb NFSD: memory corruption due to writing beyond the stat array NFSD: use nfserr for status after decode_cb_op_status nfsd: don't leak dentry count on mnt_want_write failure
2011-02-15Merge branches 'core-fixes-for-linus' and 'timers-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'core-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: Revert "lockdep, timer: Fix del_timer_sync() annotation" * 'timers-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: timer debug: Hide kernel addresses via %pK in /proc/timer_list
2011-02-15Merge branch 'perf-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86: Fix text_poke_smp_batch() deadlock perf tools: Fix thread_map event synthesizing in top and record watchdog, nmi: Lower the severity of error messages ARM: oprofile: Fix backtraces in timer mode oprofile: Fix usage of CONFIG_HW_PERF_EVENTS for oprofile_perf_init and friends
2011-02-15Merge branch 'x86-fixes-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'x86-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: x86, dmi, debug: Log board name (when present) in dmesg/oops output x86, ioapic: Don't warn about non-existing IOAPICs if we have none x86: Fix mwait_usable section mismatch x86: Readd missing irq_to_desc() in fixup_irq() x86: Fix section mismatch in LAPIC initialization
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: matrix_keypad - increase the limit of rows and columns Input: wacom - fix error path in wacom_probe() Input: ads7846 - check proper condition when freeing gpio Revert "Input: do not pass injected events back to the originating handler" Input: sysrq - rework re-inject logic Input: serio - clear pending rescans after sysfs driver rebind Input: rotary_encoder - use proper irqflags Input: wacom_w8001 - report resolution to userland
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: get rid of nameidata_dentry_drop_rcu() calling nameidata_drop_rcu() drop out of RCU in return_reval split do_revalidate() into RCU and non-RCU cases in do_lookup() split RCU and non-RCU cases of need_revalidate nothing in do_follow_link() is going to see RCU
2011-02-15Merge git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstableLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/mason/btrfs-unstable: Btrfs: check return value of alloc_extent_map() Btrfs - Fix memory leak in btrfs_init_new_device() btrfs: prevent heap corruption in btrfs_ioctl_space_info() Btrfs: Fix balance panic Btrfs: don't release pages when we can't clear the uptodate bits Btrfs: fix page->private races
2011-02-15s390: remove task_show_regsMartin Schwidefsky
task_show_regs used to be a debugging aid in the early bringup days of Linux on s390. /proc/<pid>/status is a world readable file, it is not a good idea to show the registers of a process. The only correct fix is to remove task_show_regs. Reported-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-15pci: use security_capable() when checking capablities during config space readChris Wright
This reintroduces commit 47970b1b which was subsequently reverted as f00eaeea. The original change was broken and caused X startup failures and generally made privileged processes incapable of reading device dependent config space. The normal capable() interface returns true on success, but the LSM interface returns 0 on success. This thinko is now fixed in this patch, and has been confirmed to work properly. So, once again...Eric Paris noted that commit de139a3 ("pci: check caps from sysfs file open to read device dependent config space") caused the capability check to bypass security modules and potentially auditing. Rectify this by calling security_capable() when checking the open file's capabilities for config space reads. Reported-by: Eric Paris <eparis@redhat.com> Tested-by: Dave Young <hidave.darkstar@gmail.com> Acked-by: James Morris <jmorris@namei.org> Cc: Dave Airlie <airlied@gmail.com> Cc: Alex Riesen <raa.lkml@gmail.com> Cc: Sedat Dilek <sedat.dilek@googlemail.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Chris Wright <chrisw@sous-sol.org> Signed-off-by: James Morris <jmorris@namei.org>
2011-02-15get rid of nameidata_dentry_drop_rcu() calling nameidata_drop_rcu()Al Viro
can't happen anymore and didn't work right anyway Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-15drop out of RCU in return_revalAl Viro
... thus killing the need to handle drop-from-RCU in d_revalidate() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-15split do_revalidate() into RCU and non-RCU casesAl Viro
fixing oopsen in lookup_one_len() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-15in do_lookup() split RCU and non-RCU cases of need_revalidateAl Viro
and use unlikely() instead of gotos, for fsck sake... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-15nothing in do_follow_link() is going to see RCUAl Viro
